readrtt_test.cpp File Reference
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/Types.hpp"
#include "MBTagConventions.hpp"
#include <cmath>
#include <algorithm>
+ Include dependency graph for readrtt_test.cpp:
Functions
void test_loadfile_1 ()
void test_meshset_tags_1 ()
void test_tets_1 ()
void test_tet_tags_1 ()
void test_triangles_1 ()
void test_triangles_tags_1 ()
void test_vertices_1 ()
void test_loadfile_2 ()
void test_meshset_tags_2 ()
void test_tets_2 ()
void test_tet_tags_2 ()
void test_triangles_2 ()
void test_triangles_tags_2 ()
void test_vertices_2 ()
void read_file (Interface &moab, const char *input_file)
int main ()
Variables
std::string example1 = "unittest/io/rtttest_v100.rtt"
std::string example2 = "unittest/io/rtttest_v101.rtt"
Function Documentation
void read_file ( Interface moab,
const char *  input_file
void test_loadfile_1 ( )
Definition at line 62 of file readrtt_test.cpp.
References example1, and read_file().
Referenced by main().
    Core moab;
    read_file( moab, example1.c_str() );
void test_loadfile_2 ( )
Definition at line 220 of file readrtt_test.cpp.
References example2, and read_file().
    Core moab;
    read_file( moab, example2.c_str() );
Definition at line 68 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, dim_tag, entities, ErrorCode, example1, GEOM_DIMENSION_TAG_NAME, moab::Core::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), moab::Core::globalId_tag(), id_tag, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, read_file(), and moab::Core::tag_get_handle().
    Core moab;
    // load the data into moab
    // query the dataset to make sure that there are the correct number of cells
    Range entities;
    ErrorCode rval = moab.get_entities_by_type( 0, moab::MBENTITYSET, entities );CHECK_ERR( rval );
    Tag id_tag = moab.globalId_tag();
    // get the entities that are tagged
    rval = moab.get_entities_by_type_and_tag( 0, moab::MBENTITYSET, &id_tag, 0, 1, entities );CHECK_ERR( rval );
    // each tet should have the material tag
    int num_vols     = 10;
    int num_surfaces = 129;
    int num_sets     = entities.size();
    CHECK_EQUAL( num_sets, num_vols + num_surfaces + 1 + 1 );
    // from the entities, get the volume meshsets, get it from the dim tag
    Tag dim_tag;
    entities.clear();
    // get the tag handle
    rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, dim_tag, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval );
    // get the entities that are tagged with dim 3
    int dim3                          = 3;
    const void* const tag_vals_dim3[] = { &dim3 };
    rval = moab.get_entities_by_type_and_tag( 0, moab::MBENTITYSET, &dim_tag, tag_vals_dim3, 1, entities );CHECK_ERR( rval );
    // there should only be 10 meshsets of dimension 3
    CHECK_EQUAL( num_vols, num_sets );
    entities.clear();
    // get the entities that are tagged with dim 2
    int dim2                          = 2;
    const void* const tag_vals_dim2[] = { &dim2 };
    rval = moab.get_entities_by_type_and_tag( 0, moab::MBENTITYSET, &dim_tag, tag_vals_dim2, 1, entities );CHECK_ERR( rval );
    // there should only be 129 meshsets of dimension 2
    CHECK_EQUAL( num_surfaces, num_sets );
Definition at line 226 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, dim_tag, entities, ErrorCode, example2, GEOM_DIMENSION_TAG_NAME, moab::Core::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), moab::Core::globalId_tag(), id_tag, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, read_file(), and moab::Core::tag_get_handle().
    Core moab;
    Range entities;
    int num_vols     = 3;
    int num_surfaces = 24;
    Tag dim_tag;
    entities.clear();
    int dim3                          = 3;
    entities.clear();
    int dim2                          = 2;
void test_tet_tags_1 ( )
Definition at line 128 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example1, moab::Core::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBTET, read_file(), and moab::Core::tag_get_handle().
    Core moab;
    Range entities;
    ErrorCode rval = moab.get_entities_by_type( 0, moab::MBTET, entities );CHECK_ERR( rval );
    int num_tets        = 26710;
    int num_tet_in_moab = entities.size();
    CHECK_EQUAL( num_tet_in_moab, num_tets );
    // get the number of tets tagged with
    entities.clear();
    Tag material_number;
    rval = moab.tag_get_handle( "MATERIAL_NUMBER", 1, MB_TYPE_INTEGER, material_number, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval );
    rval = moab.get_entities_by_type_and_tag( 0, moab::MBTET, &material_number, 0, 1, entities );
    int num_tet_tag = entities.size();
    CHECK_EQUAL( num_tet_tag, num_tets );CHECK_ERR( rval );
void test_tet_tags_2 ( )
Definition at line 286 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example2, moab::Core::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBTET, read_file(), and moab::Core::tag_get_handle().
    Core moab;
    Range entities;
    int num_tets        = 84;
    entities.clear();
void test_tets_1 ( )
Definition at line 114 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example1, moab::Core::get_entities_by_type(), MBTET, and read_file().
    Core moab;
    // cells = 26710 - number of tets
    Range entities;
void test_tets_2 ( )
Definition at line 272 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example2, moab::Core::get_entities_by_type(), MBTET, and read_file().
    Core moab;
    Range entities;
    int num_tets        = 84;
void test_triangles_1 ( )
Definition at line 154 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example1, moab::Core::get_entities_by_type(), MBTRI, and read_file().
    Core moab;
    Range entities;
    ErrorCode rval = moab.get_entities_by_type( 0, moab::MBTRI, entities );CHECK_ERR( rval );
    int num_tri         = 6383;  // num tris annotated in rtttest.rtt
    int num_tri_in_moab = entities.size();
    CHECK_EQUAL( num_tri_in_moab, num_tri );
void test_triangles_2 ( )
Definition at line 312 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example2, moab::Core::get_entities_by_type(), MBTRI, and read_file().
    Core moab;
    Range entities;
    int num_tri         = 60;  // num tris annotated in rtttest.rtt
Definition at line 168 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example1, moab::Core::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBTRI, read_file(), and moab::Core::tag_get_handle().
    Core moab;
    Range entities;
    // get the number of tris tagged with SURFACE_NUMBER
    entities.clear();
    Tag surface_number;
    rval = moab.tag_get_handle( "SURFACE_NUMBER", 1, MB_TYPE_INTEGER, surface_number, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval );
    rval = moab.get_entities_by_type_and_tag( 0, moab::MBTRI, &surface_number, 0, 1, entities );
    // each tri should have the surface number tag
    int num_tri_tag = entities.size();
    CHECK_EQUAL( num_tri_tag, num_tri );CHECK_ERR( rval );
    // get the number of tris tagged with SIDEID_TAG
    entities.clear();
    Tag sideid_tag;
    rval = moab.tag_get_handle( "SIDEID_TAG", 1, MB_TYPE_INTEGER, sideid_tag, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval );
    rval = moab.get_entities_by_type_and_tag( 0, moab::MBTRI, &sideid_tag, 0, 1, entities );
    // each tri should have the sideid tag
Definition at line 326 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example2, moab::Core::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBTRI, read_file(), and moab::Core::tag_get_handle().
    Core moab;
    Range entities;
    entities.clear();
    Tag surface_number;
    entities.clear();
    Tag sideid_tag;
void test_vertices_1 ( )
Definition at line 206 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example1, moab::Core::get_entities_by_type(), MBVERTEX, and read_file().
    Core moab;
    Range entities;
    ErrorCode rval = moab.get_entities_by_type( 0, moab::MBVERTEX, entities );CHECK_ERR( rval );
    int num_verts         = 5397;  // num verts annotated in rtttest.rtt
    int num_verts_in_moab = entities.size();
    CHECK_EQUAL( num_verts_in_moab, num_verts );
void test_vertices_2 ( )
Definition at line 364 of file readrtt_test.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, example2, moab::Core::get_entities_by_type(), MBVERTEX, and read_file().
    Core moab;
    Range entities;
    int num_verts         = 40;  // num verts annotated in rtttest.rtt
Variable Documentation
