readutil_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "Internals.hpp"
#include "moab/ReadUtilIface.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
+ Include dependency graph for readutil_test.cpp:
Defines
#define IS_BUILDING_MB
#define CHKERR(A)
#define RUN_TEST(A)   _run_test( ( A ), #A )
Typedefs
typedef ErrorCode(* TestFunc )()
Functions
ErrorCode gather_related_test ()
static void _run_test (TestFunc func, const char *func_str)
int main (int, char **)
Variables
int number_tests = 0
int number_tests_failed = 0
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 13 of file readutil_test.cpp.
Referenced by gather_related_test().
Definition at line 4 of file readutil_test.cpp.
#define RUN_TEST (   A)    _run_test( ( A ), #A )
Definition at line 63 of file readutil_test.cpp.
Referenced by main().
Typedef Documentation
typedef ErrorCode( * TestFunc)()
Definition at line 65 of file readutil_test.cpp.
Function Documentation
static void _run_test ( TestFunc  func,
const char *  func_str
) [static]
Definition at line 66 of file readutil_test.cpp.
References moab::error(), ErrorCode, moab::Core::get_error_string(), MB_SUCCESS, number_tests, and number_tests_failed.
    ++number_tests;
    std::cout << "   " << func_str << ": ";
    std::cout.flush();
    ErrorCode error = func();
    if( MB_SUCCESS == error )
        std::cout << "Success" << std::endl;
    else if( MB_FAILURE == error )
        std::cout << "Failure" << std::endl;
    else
        Core moab;
        std::cout << "Failed: " << moab.get_error_string( error ) << std::endl;
    if( MB_SUCCESS != error )
        ++number_tests_failed;
Definition at line 23 of file readutil_test.cpp.
References moab::Core::add_parent_child(), moab::Range::begin(), C, CHKERR, moab::Core::create_meshset(), moab::E, ErrorCode, moab::ReadUtilIface::gather_related_ents(), moab::Range::insert(), mb, MB_SUCCESS, MESHSET_SET, and moab::Range::size().
    // create an entityset structure and test related entities function
    // sets: A
    //       B  C
    //       D  E
    // if D is passed in to gather_related_ents, A-D should be returned, and E should not be
    EntityHandle A, B, C, D, E;
    Core mb;
    ErrorCode rval = mb.create_meshset( MESHSET_SET, A );CHKERR( rval );
    rval = mb.create_meshset( MESHSET_SET, B );CHKERR( rval );
    rval = mb.create_meshset( MESHSET_SET, C );CHKERR( rval );
    rval = mb.create_meshset( MESHSET_SET, D );CHKERR( rval );
    rval = mb.create_meshset( MESHSET_SET, E );CHKERR( rval );
    rval = mb.add_parent_child( A, B );CHKERR( rval );
    rval = mb.add_parent_child( B, D );CHKERR( rval );
    rval = mb.add_parent_child( C, D );CHKERR( rval );
    rval = mb.add_parent_child( C, E );CHKERR( rval );
    // now test it
    ReadUtilIface* readMeshIface;
    mb.Interface::query_interface( readMeshIface );
    Range init_range, set_range, all_sets( A, E );
    init_range.insert( D );
    rval = readMeshIface->gather_related_ents( init_range, set_range );CHKERR( rval );
    if( set_range.size() != 4 ) return MB_FAILURE;
    all_sets -= set_range;
    if( 1 != all_sets.size() || *all_sets.begin() != E ) return MB_FAILURE;
    return MB_SUCCESS;
int main ( int  ,
char **
Definition at line 89 of file readutil_test.cpp.
References gather_related_test(), number_tests, number_tests_failed, and RUN_TEST.
    RUN_TEST( gather_related_test );
    std::cout << "\nMB TEST SUMMARY: \n"
              << "   Number Tests:           " << number_tests << "\n"
              << "   Number Successful:      " << number_tests - number_tests_failed << "\n"
              << "   Number Failed:          " << number_tests_failed << "\n\n";
    return number_tests_failed;
Variable Documentation
Definition at line 61 of file readutil_test.cpp.
Referenced by _run_test(), and main().
Definition at line 62 of file readutil_test.cpp.
