scdseq_timing.cpp File Reference
#include "ScdVertexSeq.hpp"
#include "ScdElementSeq.hpp"
#include "EntitySequenceManager.hpp"
#include "EntitySequence.hpp"
#include "moab/Core.hpp"
#include "moab/ReadUtilIface.hpp"
#include <iostream>
#include <ctime>
+ Include dependency graph for scdseq_timing.cpp:
Functions
int create_3dtri_3_sequences (Core *gMB, const int intervals, EntityHandle *vstart, EntityHandle *estart)
int create_3dtri_ucd_sequences (Core *gMB, const int intervals, EntityHandle *vstart, EntityHandle *estart)
void print_time ()
int main (int argc, char **argv)
Function Documentation
int create_3dtri_3_sequences ( Core gMB,
EntityHandle vstart,
EntityHandle estart
Definition at line 176 of file scdseq_timing.cpp.
References ErrorCode, MB_SUCCESS, MBHEX, MBVERTEX, moab::Core::sequence_manager(), and moab::HomCoord::unitv.
    // create 3 brick esequences arranged such that the all share a common (tri-valent) edge;
    // orient each region similarly to the 2dtri_3_esequences test problem, swept into 3d in the
    // positive k direction.  This direction is divided into intervals intervals
    // intervals and intervals controls the i and j intervals in region 0, intervals follows from
    // that; intervals divides the k axis
    // input is 4 interval settings controlling the 4 degrees of freedom on the interfacesp
    int errors = 0;
    ScdVertexSeq* vseq[3];
    ScdElementSeq* eseq[3];
    // set vseq parametric spaces directly from intervals-4
    // use 0-based parameterization on vseq's just for fun, which means we'll have to transform into
    // eseq system
    HomCoord vseq0_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals, intervals, intervals ) };
    HomCoord vseq1_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals - 1, intervals, intervals ) };
    HomCoord vseq2_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals - 1, intervals - 1, intervals ) };
    // get the seq manager from gMB
    EntitySequenceManager* seq_mgr = gMB->sequence_manager();
    // create three vertex sequences
    EntitySequence* dum_seq;
    vseq[0] = vseq[1] = vseq[2] = NULL;
    // first vertex sequence
    ErrorCode result =
        seq_mgr->create_scd_sequence( vseq0_minmax[0], vseq0_minmax[1], MBVERTEX, 1, vstart[0], dum_seq );
    if( NULL != dum_seq ) vseq[0] = dynamic_cast< ScdVertexSeq* >( dum_seq );
    assert( MB_FAILURE != result && vstart[0] != 0 && dum_seq != NULL && vseq[0] != NULL );
    // second vertex sequence
    result = seq_mgr->create_scd_sequence( vseq1_minmax[0], vseq1_minmax[1], MBVERTEX, 1, vstart[1], dum_seq );
    if( NULL != dum_seq ) vseq[1] = dynamic_cast< ScdVertexSeq* >( dum_seq );
    assert( MB_FAILURE != result && vstart[1] != 0 && dum_seq != NULL && vseq[1] != NULL );
    // third vertex sequence
    result = seq_mgr->create_scd_sequence( vseq2_minmax[0], vseq2_minmax[1], MBVERTEX, 1, vstart[2], dum_seq );
    if( NULL != dum_seq ) vseq[2] = dynamic_cast< ScdVertexSeq* >( dum_seq );
    assert( MB_FAILURE != result && vstart[2] != 0 && dum_seq != NULL && vseq[2] != NULL );
    // now create the three element sequences
    // set eseq parametric spaces directly from intervals-4
    // use 0-based parameterization on eseq's just for fun, which means we'll have to transform into
    // eseq system
    HomCoord eseq0_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals, intervals, intervals ) };
    HomCoord eseq1_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals, intervals, intervals ) };
    HomCoord eseq2_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( intervals, intervals, intervals ) };
    eseq[0] = eseq[1] = eseq[2] = NULL;
    // create the first element sequence
    result = seq_mgr->create_scd_sequence( eseq0_minmax[0], eseq0_minmax[1], MBHEX, 1, estart[0], dum_seq );
    if( NULL != dum_seq ) eseq[0] = dynamic_cast< ScdElementSeq* >( dum_seq );
    assert( MB_FAILURE != result && estart[0] != 0 && dum_seq != NULL && eseq[0] != NULL );
    // only need to add one vseq to this, unity transform
    result = eseq[0]->add_vsequence( vseq[0],
                                     // trick: if I know it's going to be unity, just input
                                     // 3 sets of equivalent points
                                     vseq0_minmax[0], vseq0_minmax[0], vseq0_minmax[0], vseq0_minmax[0],
                                     vseq0_minmax[0], vseq0_minmax[0] );
    if( MB_SUCCESS != result )
        std::cout << "Couldn't add first vsequence to first element sequence in tri-composite 3d eseq." << std::endl;
        errors++;
    // create the second element sequence
    result = seq_mgr->create_scd_sequence( eseq1_minmax[0], eseq1_minmax[1], MBHEX, 1, estart[1], dum_seq );
    if( NULL != dum_seq ) eseq[1] = dynamic_cast< ScdElementSeq* >( dum_seq );
    assert( MB_FAILURE != result && estart[1] != 0 && dum_seq != NULL && eseq[1] != NULL );
    // add shared side from first vseq to this eseq, with bb to get just the face
    result = eseq[1]->add_vsequence( vseq[0],
                                     // p1: origin in both systems
                                     vseq0_minmax[0], eseq0_minmax[0],
                                     // p2: one unit along the shared line (i in one, j in other)
                                     vseq0_minmax[0] + HomCoord::unitv[0], eseq0_minmax[0] + HomCoord::unitv[1],
                                     // p3: arbitrary
                                     // set bb such that it's the jmin side of vseq
                                     true, eseq[1]->min_params(),
                                     HomCoord( eseq[1]->min_params().i(), eseq[1]->max_params().j(),
                                               eseq[1]->max_params().k() ) );
        std::cout << "Couldn't add shared vsequence to second element sequence in tri-composite 3d eseq." << std::endl;
        errors++;
    // add second vseq to this eseq, with different orientation but all of it (no bb input)
    result =
        eseq[1]->add_vsequence( vseq[1],
                                // p1: origin/i+1 (vseq/eseq)
                                vseq1_minmax[0], eseq1_minmax[0] + HomCoord::unitv[0],
                                // p2: j+1 from p1
                                vseq1_minmax[0] + HomCoord::unitv[1],
                                eseq1_minmax[0] + HomCoord::unitv[0] + HomCoord::unitv[1],
                                // p3: i+1 from p1
                                vseq1_minmax[0] + HomCoord::unitv[0], eseq[1]->min_params() + HomCoord::unitv[0] * 2 );
        std::cout << "Couldn't add second vseq to second element sequence in tri-composite 3d eseq." << std::endl;
        errors++;
    // create the third element sequence
    result = seq_mgr->create_scd_sequence( eseq2_minmax[0], eseq2_minmax[1], MBHEX, 1, estart[2], dum_seq );
    if( NULL != dum_seq ) eseq[2] = dynamic_cast< ScdElementSeq* >( dum_seq );
    assert( MB_FAILURE != result && estart[2] != 0 && dum_seq != NULL && eseq[2] != NULL );
    // add shared side from second vseq to this eseq
    result = eseq[2]->add_vsequence(
        vseq[1],
        // p1: origin/j+1 (vseq/eseq)
        vseq1_minmax[0], eseq[2]->min_params() + HomCoord::unitv[1],
        // p2: i+1/j+2 (vseq/eseq)
        vseq1_minmax[0] + HomCoord::unitv[0], eseq[2]->min_params() + HomCoord::unitv[1] * 2,
        // p3: arbitrary
        // bb input such that we only get one side of eseq parameter space
        true, eseq[2]->min_params() + HomCoord::unitv[1],
        HomCoord( eseq[2]->min_params().i(), eseq[2]->max_params().j(), eseq[2]->max_params().k() ) );
        std::cout << "Couldn't add shared vsequence to third element sequence in tri-composite 3d eseq." << std::endl;
        errors++;
    result = eseq[2]->add_vsequence( vseq[0],
                                     // p1: origin/origin
                                     vseq1_minmax[0], eseq2_minmax[0],
                                     // p2: j+1/i+1
                                     vseq1_minmax[0] + HomCoord::unitv[1], eseq2_minmax[0] + HomCoord::unitv[0],
                                     // p3: arbitrary
                                     true, eseq2_minmax[0],
                                     HomCoord( eseq2_minmax[1].i(), eseq2_minmax[0].j(), eseq2_minmax[1].k() ) );
        std::cout << "Couldn't add left shared vsequence to third element sequence in "
                     "tri-composite 3d eseq."
                  << std::endl;
        errors++;
    // add third vseq to this eseq
    result = eseq[2]->add_vsequence( vseq[2],
                                     // p1: origin/i+1,j+1
                                     vseq2_minmax[0], eseq[2]->min_params() + HomCoord::unitv[0] + HomCoord::unitv[1],
                                     // p2: i+1 from p1
                                     vseq2_minmax[0] + HomCoord::unitv[0],
                                     eseq[2]->min_params() + HomCoord::unitv[0] * 2 + HomCoord::unitv[1],
                                     // p3: j+1 from p1
                                     vseq2_minmax[0] + HomCoord::unitv[1],
                                     eseq[2]->min_params() + HomCoord::unitv[0] + HomCoord::unitv[1] * 2 );
        std::cout << "Couldn't add third vseq to third element sequence in tri-composite 3d eseq." << std::endl;
        errors++;
    return errors;
int create_3dtri_ucd_sequences ( Core gMB,
EntityHandle estart
Definition at line 350 of file scdseq_timing.cpp.
References conn, moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), MB_START_ID, MBHEX, and moab::Interface::query_interface().
Referenced by main().
    ReadUtilIface* readMeshIface;
    gMB->query_interface( readMeshIface );
    int num_elements = intervals * intervals * intervals;
    int num_verts    = ( intervals + 1 ) * ( intervals + 1 ) * ( intervals + 1 );
    std::vector< double* > arrays;
    for( int i = 0; i < 3; i++ )
        readMeshIface->get_node_coords( 3, num_verts, MB_START_ID, vstart[i], arrays );
        arrays.clear();
    EntityHandle* conn[3];
    // allocate 3 arrays to initialize connectivity data
        readMeshIface->get_element_connect( num_elements, 8, MBHEX, 1, estart[i], conn[i] );
        // now, initialize connectivity data to what it should be; just fudge for now
        for( int j = 0; j < num_elements * 8; j++ )
            conn[i][j] = vstart[i];
    return 0;
int main ( int  argc,
char **  argv
Definition at line 46 of file scdseq_timing.cpp.
References create_3dtri_3_sequences(), create_3dtri_ucd_sequences(), ErrorCode, moab::Core::get_connectivity(), gMB, MB_SUCCESS, and print_time().
    int errors = 0;
    // first we need to make a new Core
    Core* gMB = new Core();
    // get the intervals
    if( argc < 2 )
        std::cout << "Usage: <scdseq_timing> <#intervals> " << std::endl
                  << " where #intervals is the number of intervals on each side of each cube." << std::endl;
        return 0;
    int intervals;
    sscanf( argv[1], "%d", &intervals );
    char do_option[8];
    bool do_scd = true, do_ucd = true;
    if( argc > 2 )
        sscanf( argv[2], "%s", do_option );
        if( do_option[0] == 'u' )
            do_scd = false;
        else if( do_option[0] == 's' )
            do_ucd = false;
        else
            std::cout << "Didn't understand input; doing both scd and ucd." << std::endl;
    EntityHandle estart[3], vstart[3];
    int total_elements = intervals * intervals * intervals;
    std::vector< EntityHandle > connect;
    ErrorCode result;
    clock_t start, stop;
    float time;
    char inp[1];
    // wait for input to get memory reading
    std::cout << "Hit any key and return to continue...";
    std::cin >> inp;
    std::cout << std::endl;
    if( do_scd )
        // create structured mesh
        errors = create_3dtri_3_sequences( gMB, intervals, vstart, estart );
        if( errors != 0 )
            std::cout << "Problem creating structured sequences." << std::endl;
            return errors;
        // get connectivity
        start = clock();
        for( int j = 0; j < 3; j++ )
            for( int i = 0; i < total_elements; i++ )
                result = gMB->get_connectivity( estart[j] + i, connect );
                if( MB_SUCCESS != result ) break;
                connect.clear();
        stop = clock();
        time = static_cast< float >( stop - start ) / CLOCKS_PER_SEC;
        std::cout << "Time to get connectivity for scd mesh of " << 3 * total_elements << " elements: " << time
                  << " seconds." << std::endl;
        print_time();
        std::cin >> inp;
        // destroy this mesh
        delete gMB;
    if( do_ucd )
        // now do the same thing, only unstructured
        gMB = new Core();
        // create the elements
        errors = create_3dtri_ucd_sequences( gMB, intervals, vstart, estart );
        if( errors != 0 )
            std::cout << "Problem creating unstructured sequences." << std::endl;
            return errors;
        // get connectivity
        start = clock();
                connect.clear();
        stop = clock();
        std::cout << "Time to get connectivity for ucd mesh of " << 3 * total_elements << " elements: " << time
        print_time();
        std::cin >> inp;
        delete gMB;
void print_time ( )
Definition at line 381 of file scdseq_timing.cpp.
      struct rusage r_usage;
      float utime, stime;
      getrusage(RUSAGE_SELF, &r_usage);
      if (r_usage.ru_maxrss == 0) {
          // this machine doesn't return rss - try going to /proc
          // print the file name to open
        char file_str[4096], dum_str[4096];
        int file_ptr = -1, file_len;
        file_ptr = open("/proc/self/stat", O_RDONLY);
        file_len = read(file_ptr, file_str, sizeof(file_str)-1);
        if (file_len == 0) return;
        close(file_ptr);
        file_str[file_len] = '\0';
          // read the preceeding fields and the ones we really want...
        int dum_int;
        unsigned int dum_uint, vm_size, rss;
        static int page_size = getpagesize();
        int num_fields = sscanf(file_str,
                                "%d " // pid
                                "%s " // comm
                                "%c " // state
                                "%d %d %d %d %d " // ppid, pgrp, session, tty, tpgid
                                "%u %u %u %u %u " // flags, minflt, cminflt, majflt, cmajflt
                                "%d %d %d %d %d %d " // utime, stime, cutime, cstime, counter,
      priority
                                "%u %u " // timeout, itrealvalue
                                "%d " // starttime
                                "%u %u", // vsize, rss
                                &dum_int,
                                dum_str,
                                dum_str,
                                &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
                                &dum_uint, &dum_uint, &dum_uint, &dum_uint, &dum_uint,
                                &dum_int, &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
                                &dum_int,
                                &vm_size, &rss);
        if (num_fields == 24) {
          r_usage.ru_maxrss = rss/page_size;
          r_usage.ru_idrss = vm_size/page_size;
      utime = (float)r_usage.ru_utime.tv_sec +
        ((float)r_usage.ru_utime.tv_usec/1.e6);
      stime = (float)r_usage.ru_stime.tv_sec +
        ((float)r_usage.ru_stime.tv_usec/1.e6);
      static int pagesize = getpagesize();
      std::cout << "Execution time = " << utime+stime << ", max RSS = "
                << r_usage.ru_maxrss*pagesize << " bytes." << std::endl;
