scdtest.cpp File Reference
#include <string>
#include <iomanip>
#include <iostream>
#include <cassert>
#include "moab/Core.hpp"
#include "moab/ParallelComm.hpp"
#include "moab/HomXform.hpp"
#include "MBParallelConventions.h"
#include "MBTagConventions.hpp"
+ Include dependency graph for scdtest.cpp:
Functions
void set_local_domain_bounds ()
void create_hexes_and_verts ()
void resolve_and_exchange ()
void error (ErrorCode err)
int main (int argc, char *argv[])
Variables
const int NI = 2
const int NJ = 2
const int NK = 1
Interfacembint = NULL
ParallelCommmbpc = NULL
int is
int js
int ks
int ie
int je
int ke
int rank
int size
Function Documentation
Definition at line 140 of file scdtest.cpp.
References moab::Core::add_vsequence(), moab::Core::create_scd_sequence(), moab::error(), ErrorCode, moab::Interface::globalId_tag(), ie, is, je, js, ke, ks, MB_SUCCESS, mbcore, MBHEX, mbint, MBVERTEX, NI, NJ, and moab::Interface::tag_set_data().
Referenced by main().
    Core* mbcore = dynamic_cast< Core* >( mbint );
    HomCoord coord_min( 0, 0, 0 );
    HomCoord coord_max( ie - is, je - js, ke - ks );
    EntitySequence* vertex_seq = NULL;
    EntitySequence* cell_seq   = NULL;
    EntityHandle vs, cs;
    error( mbcore->create_scd_sequence( coord_min, coord_max, MBVERTEX, 1, vs, vertex_seq ) );
    error( mbcore->create_scd_sequence( coord_min, coord_max, MBHEX, 1, cs, cell_seq ) );
    HomCoord p1( 0, 0, 0 );
    HomCoord p2( 1, 0, 0 );
    HomCoord p3( 0, 1, 0 );
    error( mbcore->add_vsequence( vertex_seq, cell_seq, p1, p1, p2, p2, p3, p3 ) );
    // Set global id's:
    int gid;
    Tag global_id_tag   = mbint->globalId_tag();
    EntityHandle handle = vs;
    int i, j, k;
    ErrorCode err;
    for( k = ks; k < ke + 1; k++ )
        for( j = js; j < je + 1; j++ )
            for( i = is; i < ie + 1; i++ )
                gid = 1 + i + j * ( NI + 1 ) + k * ( NI + 1 ) * ( NJ + 1 );
                err = mbint->tag_set_data( global_id_tag, &handle, 1, &gid );
                if( err != MB_SUCCESS )
                    exit( 1 );
                handle++;
    handle = cs;
    for( k = ks; k < ke; k++ )
        for( j = js; j < je; j++ )
            for( i = is; i < ie; i++ )
                gid = 1 + i + j * NI + k * NI * NJ;
                error( mbint->tag_set_data( global_id_tag, &handle, 1, &gid ) );
                handle++;
void error ( ErrorCode  err)
Definition at line 219 of file scdtest.cpp.
References MB_SUCCESS.
        std::cerr << "Error: MOAB function failed\n";
        assert( 0 );
int main ( int  argc,
char *  argv[]
Definition at line 44 of file scdtest.cpp.
References create_hexes_and_verts(), mbint, mbpc, MPI_COMM_WORLD, rank, resolve_and_exchange(), set_local_domain_bounds(), and size.
    MPI_Init( &argc, &argv );
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
    MPI_Comm_size( MPI_COMM_WORLD, &size );
    if( size != 4 && size != 2 )
        std::cerr << "Run this with 2 or 4 processes\n";
        MPI_Finalize();
        exit( 1 );
    mbint = new Core();
    mbpc  = new ParallelComm( mbint, MPI_COMM_WORLD );
    set_local_domain_bounds();
    create_hexes_and_verts();
    resolve_and_exchange();
    delete mbpc;  // ParallelComm instance should be deleted before MOAB instance is deleted
    delete mbint;
    MPI_Finalize();
    return 0;
Definition at line 190 of file scdtest.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), moab::error(), moab::ParallelComm::exchange_ghost_cells(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), MATERIAL_SET_TAG_NAME, MB_TYPE_INTEGER, MBENTITYSET, MBHEX, mbint, mbpc, MESHSET_SET, moab::ParallelComm::partition_sets(), rank, moab::ParallelComm::resolve_shared_ents(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
    EntityHandle entity_set;
    // Create the entity set:
    error( mbint->create_meshset( MESHSET_SET, entity_set ) );
    // Get a list of hexes:
    Range range;
    error( mbint->get_entities_by_type( 0, MBHEX, range ) );
    // Add entities to the entity set:
    error( mbint->add_entities( entity_set, range ) );
    // Add the MATERIAL_SET tag to the entity set:
    Tag tag;
    error( mbint->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag ) );
    error( mbint->tag_set_data( tag, &entity_set, 1, &rank ) );
    // Set up partition sets. This is where MOAB is actually told what
    // entities each process owns:
    error( mbint->get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, NULL, 1, mbpc->partition_sets() ) );
    // Finally, determine which entites are shared and exchange the
    // ghosted entities:
    error( mbpc->resolve_shared_ents( 0, -1, -1 ) );
    error( mbpc->exchange_ghost_cells( -1, 0, 1, 0, true ) );
Definition at line 70 of file scdtest.cpp.
References ie, is, je, js, ke, ks, NI, NJ, NK, rank, and size.
    switch( size )
        case 2:
            switch( rank )
                case 0:
                    is = 0;
                    ie = NI / 2;
                    js = 0;
                    je = NJ;
                    ks = 0;
                    ke = NK;
                    break;
                case 1:
                    is = NI / 2;
                    ie = NI;
                    js = 0;
                    je = NJ;
                    ks = 0;
                    ke = NK;
                    break;
            break;
        case 4:
            switch( rank )
                case 0:
                    is = 0;
                    ie = NI / 2;
                    js = 0;
                    je = NJ / 2;
                    ks = 0;
                    ke = NK;
                    break;
                case 1:
                    is = NI / 2;
                    ie = NI;
                    js = 0;
                    je = NJ / 2;
                    ks = 0;
                    ke = NK;
                    break;
                case 2:
                    is = 0;
                    ie = NI / 2;
                    js = NJ / 2;
                    je = NJ;
                    ks = 0;
                    ke = NK;
                    break;
                case 3:
                    is = NI / 2;
                    ie = NI;
                    js = NJ / 2;
                    je = NJ;
                    ks = 0;
                    ke = NK;
                    break;
            break;
        default:
            std::cerr << "Run this with 4 processes\n";
            exit( 1 );
Variable Documentation
int je
int js
Definition at line 32 of file scdtest.cpp.
Referenced by create_hexes_and_verts(), and set_local_domain_bounds().
int ke
Definition at line 33 of file scdtest.cpp.
int ks
const int NI = 2
Definition at line 17 of file scdtest.cpp.
Referenced by create_hexes_and_verts(), main(), and set_local_domain_bounds().
const int NJ = 2
Definition at line 18 of file scdtest.cpp.
const int NK = 1
Definition at line 19 of file scdtest.cpp.
Referenced by set_local_domain_bounds().
int rank
Definition at line 36 of file scdtest.cpp.
int size
Definition at line 37 of file scdtest.cpp.
