scdtest.cpp
00001 #include <string>
00002 #include <iomanip>
00003 #include <iostream>
00004 #include <cassert>
00005
00006 #include "moab/Core.hpp"
00007 #include "moab/ParallelComm.hpp"
00008 #include "moab/HomXform.hpp"
00009 #include "MBParallelConventions.h"
00010 #include "MBTagConventions.hpp"
00011
00012 using namespace moab;
00013
00014 // Number of cells in each direction:
00015 // const int NC = 2;
00016
00017 const int NI = 2;
00018 const int NJ = 2;
00019 const int NK = 1;
00020
00021 // Number of processes:
00022 // const int NPROCS = 4;
00023
00024 // Domain size:
00025 // const double DSIZE = 10.0;
00026
00027 // MOAB objects:
00028 Interface* mbint   = NULL;
00029 ParallelComm* mbpc = NULL;
00030
00031 // Local domain starting and ending hex indexes:
00032 int is, js, ks;
00033 int ie, je, ke;
00034
00035 // Obvious:
00036 int rank;
00037 int size;
00038
00039 void set_local_domain_bounds();
00040 void create_hexes_and_verts();
00041 void resolve_and_exchange();
00042 void error( ErrorCode err );
00043
00044 int main( int argc, char* argv[] )
00045 {
00046     MPI_Init( &argc, &argv );
00047     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00048     MPI_Comm_size( MPI_COMM_WORLD, &size );
00049     if( size != 4 && size != 2 )
00050     {
00051         std::cerr << "Run this with 2 or 4 processes\n";
00052         MPI_Finalize();
00053         exit( 1 );
00054     }
00055
00056     mbint = new Core();
00057     mbpc  = new ParallelComm( mbint, MPI_COMM_WORLD );
00058
00059     set_local_domain_bounds();
00060     create_hexes_and_verts();
00061     resolve_and_exchange();
00062
00063     delete mbpc;  // ParallelComm instance should be deleted before MOAB instance is deleted
00064     delete mbint;
00065
00066     MPI_Finalize();
00067     return 0;
00068 }
00069
00070 void set_local_domain_bounds()
00071 {
00072     switch( size )
00073     {
00074         case 2:
00075             switch( rank )
00076             {
00077                 case 0:
00078                     is = 0;
00079                     ie = NI / 2;
00080                     js = 0;
00081                     je = NJ;
00082                     ks = 0;
00083                     ke = NK;
00084                     break;
00085                 case 1:
00086                     is = NI / 2;
00087                     ie = NI;
00088                     js = 0;
00089                     je = NJ;
00090                     ks = 0;
00091                     ke = NK;
00092                     break;
00093             }
00094             break;
00095
00096         case 4:
00097             switch( rank )
00098             {
00099                 case 0:
00100                     is = 0;
00101                     ie = NI / 2;
00102                     js = 0;
00103                     je = NJ / 2;
00104                     ks = 0;
00105                     ke = NK;
00106                     break;
00107                 case 1:
00108                     is = NI / 2;
00109                     ie = NI;
00110                     js = 0;
00111                     je = NJ / 2;
00112                     ks = 0;
00113                     ke = NK;
00114                     break;
00115                 case 2:
00116                     is = 0;
00117                     ie = NI / 2;
00118                     js = NJ / 2;
00119                     je = NJ;
00120                     ks = 0;
00121                     ke = NK;
00122                     break;
00123                 case 3:
00124                     is = NI / 2;
00125                     ie = NI;
00126                     js = NJ / 2;
00127                     je = NJ;
00128                     ks = 0;
00129                     ke = NK;
00130                     break;
00131             }
00132             break;
00133
00134         default:
00135             std::cerr << "Run this with 4 processes\n";
00136             exit( 1 );
00137     }
00138 }
00139
00140 void create_hexes_and_verts()
00141 {
00142     Core* mbcore = dynamic_cast< Core* >( mbint );
00143     HomCoord coord_min( 0, 0, 0 );
00144     HomCoord coord_max( ie - is, je - js, ke - ks );
00145     EntitySequence* vertex_seq = NULL;
00146     EntitySequence* cell_seq   = NULL;
00147     EntityHandle vs, cs;
00148
00149     error( mbcore->create_scd_sequence( coord_min, coord_max, MBVERTEX, 1, vs, vertex_seq ) );
00150     error( mbcore->create_scd_sequence( coord_min, coord_max, MBHEX, 1, cs, cell_seq ) );
00151
00152     HomCoord p1( 0, 0, 0 );
00153     HomCoord p2( 1, 0, 0 );
00154     HomCoord p3( 0, 1, 0 );
00155
00156     error( mbcore->add_vsequence( vertex_seq, cell_seq, p1, p1, p2, p2, p3, p3 ) );
00157
00158     // Set global id's:
00159     int gid;
00160     Tag global_id_tag   = mbint->globalId_tag();
00161     EntityHandle handle = vs;
00162     int i, j, k;
00163
00164     ErrorCode err;
00165
00166     for( k = ks; k < ke + 1; k++ )
00167         for( j = js; j < je + 1; j++ )
00168             for( i = is; i < ie + 1; i++ )
00169             {
00170                 gid = 1 + i + j * ( NI + 1 ) + k * ( NI + 1 ) * ( NJ + 1 );
00171                 err = mbint->tag_set_data( global_id_tag, &handle, 1, &gid );
00172                 if( err != MB_SUCCESS )
00173                 {
00174                     exit( 1 );
00175                 }
00176                 handle++;
00177             }
00178
00179     handle = cs;
00180     for( k = ks; k < ke; k++ )
00181         for( j = js; j < je; j++ )
00182             for( i = is; i < ie; i++ )
00183             {
00184                 gid = 1 + i + j * NI + k * NI * NJ;
00185                 error( mbint->tag_set_data( global_id_tag, &handle, 1, &gid ) );
00186                 handle++;
00187             }
00188 }
00189
00190 void resolve_and_exchange()
00191 {
00192     EntityHandle entity_set;
00193
00194     // Create the entity set:
00195     error( mbint->create_meshset( MESHSET_SET, entity_set ) );
00196
00197     // Get a list of hexes:
00198     Range range;
00199     error( mbint->get_entities_by_type( 0, MBHEX, range ) );
00200
00201     // Add entities to the entity set:
00202     error( mbint->add_entities( entity_set, range ) );
00203
00204     // Add the MATERIAL_SET tag to the entity set:
00205     Tag tag;
00206     error( mbint->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag ) );
00207     error( mbint->tag_set_data( tag, &entity_set, 1, &rank ) );
00208
00209     // Set up partition sets. This is where MOAB is actually told what
00210     // entities each process owns:
00211     error( mbint->get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, NULL, 1, mbpc->partition_sets() ) );
00212
00213     // Finally, determine which entites are shared and exchange the
00214     // ghosted entities:
00215     error( mbpc->resolve_shared_ents( 0, -1, -1 ) );
00216     error( mbpc->exchange_ghost_cells( -1, 0, 1, 0, true ) );
00217 }
00218
00219 void error( ErrorCode err )
00220 {
00221     if( err != MB_SUCCESS )
00222     {
00223         std::cerr << "Error: MOAB function failed\n";
00224         assert( 0 );
00225     }
00226 }
