seqperf.cpp
00001 #include <ctime>
00002 #include <cassert>
00003 #include <iostream>
00004 #include <sstream>
00005 #include "moab/Core.hpp"
00006 #include "moab/ReadUtilIface.hpp"
00007
00008 #define PRINT_SEQUENCE_COUNT
00009
00010 #ifdef PRINT_SEQUENCE_COUNT
00011 #ifndef IS_BUILDING_MB
00012 #define IS_BUILDING_MB
00013 #endif
00014 #include "EntitySequence.hpp"
00015 #ifdef MB_ENTITY_SEQUENCE_HPP
00016 #include "EntitySequenceManager.hpp"
00017 #else
00018 #include "SequenceManager.hpp"
00019 #endif
00020 #endif
00021
00022 using namespace moab;
00023
00024 // constants
00025 const bool dump_mesh          = false;  //!< write mesh to vtk file
00026 const int default_intervals   = 25;     //!< defaul interval count for cubic structured hex mesh
00027 const int default_query_count = 100;    //!< number of times to do each query set
00028 const int default_order[]     = { 0, 1, 2 };
00029 const int default_create[]    = { 0, 1 };
00030 const int default_delete[]    = { 0, 10, 30, 50, 70, 90 };
00031 #define ARRSIZE( A ) ( sizeof( A ) / sizeof( ( A )[0] ) )
00032
00033 // input parameters
00034 long numSideInt, numVert, numElem;  //!< total counts;
00035 int queryCount;                     //!< number of times to do each query set
00036
00037 // misc globals
00038 Core mb_core;                       //!< moab instance
00039 Interface& mb = mb_core;            //!< moab instance
00040 EntityHandle vertStart, elemStart;  //!< first handle
00041 ReadUtilIface* readTool    = 0;
00042 long* queryVertPermutation = 0;  //!< pupulated by init(): "random" order for vertices
00043 long* queryElemPermutation = 0;  //!< pupulated by init(): "random" order for elements
00044
00045 //! Generate random permutation of values in [0,count-1]
00046 long* permutation( long count )
00047 {
00048     srand( count );
00049     long* array = new long[count];
00050     for( long i = 0; i < count; ++i )
00051         array[i] = i;
00052
00053     for( long i = 0; i < count; ++i )
00054     {
00055         long r = rand();
00056         if( count > RAND_MAX )
00057         {
00058             r += RAND_MAX * rand();
00059             if( count / RAND_MAX > RAND_MAX )
00060             {
00061                 long t = (long)RAND_MAX * rand();
00062                 r += (long)RAND_MAX * t;
00063             }
00064         }
00065         std::swap( array[i], array[r % count] );
00066     }
00067
00068     return array;
00069 }
00070
00071 //! Initialize global variables
00072 void init()
00073 {
00074     ErrorCode rval = mb.query_interface( readTool );
00075     if( rval || !readTool )
00076     {
00077         assert( false );
00078         abort();
00079     }
00080
00081     queryVertPermutation = permutation( numVert );
00082     queryElemPermutation = permutation( numElem );
00083 }
00084
00085 void create_vertices_single();  //!< create vertices one at a time
00086 void create_vertices_block();   //!< create vertices in block using ReadUtilIface
00087 void create_elements_single();  //!< create elements one at a time
00088 void create_elements_block();   //!< create elements in block using ReadUtilIface
00089
00090 void forward_order_query_vertices( int percent );  //!< calculate mean of all vertex coordinates
00091 void reverse_order_query_vertices( int percent );  //!< calculate mean of all vertex coordinates
00092 void random_order_query_vertices( int percent );   //!< calculate mean of all vertex coordinates
00093
00094 void forward_order_query_elements( int percent );  //!< check all element connectivity for valid vertex handles
00095 void reverse_order_query_elements( int percent );  //!< check all element connectivity for valid vertex handles
00096 void random_order_query_elements( int percent );   //!< check all element connectivity for valid vertex handles
00097
00098 void forward_order_query_element_verts( int percent );  //!< calculate centroid
00099 void reverse_order_query_element_verts( int percent );  //!< calculate centroid
00100 void random_order_query_element_verts( int percent );   //!< calculate centroid
00101
00102 void forward_order_delete_vertices( int percent );  //!< delete x% of vertices
00103 void reverse_order_delete_vertices( int percent );  //!< delete x% of vertices
00104 void random_order_delete_vertices( int percent );   //!< delete x% of vertices
00105
00106 void forward_order_delete_elements( int percent );  //!< delete x% of elements
00107 void reverse_order_delete_elements( int percent );  //!< delete x% of elements
00108 void random_order_delete_elements( int percent );   //!< delete x% of elements
00109
00110 void create_missing_vertices( int percent );  //!< re-create deleted vertices
00111 void create_missing_elements( int percent );  //!< re-create deleted elements
00112
00113 #ifdef PRINT_SEQUENCE_COUNT
00114 unsigned get_number_sequences( EntityType type );
00115 #endif
00116
00117 /* Build arrays of function pointers, indexed by the order the entities are traversed in */
00118
00119 typedef void ( *naf_t )();
00120 typedef void ( *iaf_t )( int );
00121
00122 iaf_t query_verts[3] = { &forward_order_query_vertices, &reverse_order_query_vertices, &random_order_query_vertices };
00123
00124 iaf_t query_elems[3] = { &forward_order_query_elements, &reverse_order_query_elements, &random_order_query_elements };
00125
00126 iaf_t query_elem_verts[3] = { &forward_order_query_element_verts, &reverse_order_query_element_verts,
00127                               &random_order_query_element_verts };
00128
00129 iaf_t delete_verts[3] = { &forward_order_delete_vertices, &reverse_order_delete_vertices,
00130                           &random_order_delete_vertices };
00131
00132 iaf_t delete_elems[3] = { &forward_order_delete_elements, &reverse_order_delete_elements,
00133                           &random_order_delete_elements };
00134
00135 const char* order_strs[] = { "Forward", "Reverse", "Random" };
00136
00137 //! Coordinates for ith vertex in structured hex mesh
00138 inline void vertex_coords( long vert_index, double& x, double& y, double& z );
00139 //! Connectivity for ith hex in structured hex mesh
00140 inline void element_conn( long elem_index, EntityHandle conn[8] );
00141 //! True if passed index is one of the x% to be deleted
00142 inline bool deleted_vert( long index, int percent );
00143 //! True if passed index is one of the x% to be deleted
00144 inline bool deleted_elem( long index, int percent );
00145 //! if (deleted_vert(index,percent)) delete vertex
00146 inline void delete_vert( long index, int percent );
00147 //! if (deleted_elem(index,percent)) delete element
00148 inline void delete_elem( long index, int percent );
00149
00150 //! print usage and exit
00151 void usage()
00152 {
00153     std::cerr << "Usage: seqperf [-i <intervals>] [-o <order>] [-d <percent>] [-b|-s] [-q <count>]" << std::endl;
00154     std::cerr << " -i specify size of cubic structured hex mesh in intervals.  Default: " << default_intervals
00155               << std::endl;
00156     std::cerr << " -o one of \"forward\", \"reverse\", or \"random\".  May be specified multiple "
00157                  "times.  Default is all."
00158               << std::endl;
00159     std::cerr << " -d percent of entities to delete.  May be specified multiple times.  Default is {";
00160     for( unsigned i = 0; i < ARRSIZE( default_delete ) - 1; ++i )
00161         std::cerr << default_delete[i] << ",";
00162     std::cerr << default_delete[ARRSIZE( default_delete ) - 1] << "}" << std::endl;
00163     std::cerr << " -b block creation of mesh" << std::endl;
00164     std::cerr << " -s single entity mesh creation" << std::endl;
00165     std::cerr << " -q number of times to repeat queries.  Default: " << default_query_count << std::endl;
00166     exit( 1 );
00167 }
00168
00169 //! convert CPU time to string
00170 std::string ts( clock_t t )
00171 {
00172     std::ostringstream s;
00173     s << ( (double)t ) / CLOCKS_PER_SEC << 's';
00174     return s.str();
00175 }
00176
00177 //! run function, printing time spent
00178 void TIME( const char* str, void ( *func )() )
00179 {
00180     std::cout << str << "... " << std::flush;
00181     clock_t t = clock();
00182     ( *func )();
00183     std::cout << ts( clock() - t ) << std::endl;
00184 }
00185
00186 //! run function query_repeat times, printing time spent
00187 void TIME_QRY( const char* str, void ( *func )( int percent ), int percent )
00188 {
00189     std::cout << str << "... " << std::flush;
00190     clock_t t = clock();
00191     for( int i = 0; i < queryCount; ++i )
00192         ( *func )( percent );
00193     std::cout << ts( clock() - t ) << std::endl;
00194 }
00195
00196 //! run function with integer argument, printing time spent
00197 void TIME_DEL( const char* str, void ( *func )( int ), int percent )
00198 {
00199     std::cout << str << "... " << std::flush;
00200     clock_t t = clock();
00201     ( *func )( percent );
00202     std::cout << ts( clock() - t ) << std::endl;
00203 }
00204
00205 //! call MB::delete_mesh().  function so can be passed to TIME
00206 void delete_mesh()
00207 {
00208     mb.delete_mesh();
00209 }
00210
00211 //! Run a single combination of test parameters
00212 void do_test( int create_mode,  //!< 0 == single, 1 == block
00213               int order,        //!< 0 == forward, 1 == reverse, 2 == random
00214               int percent )     //!< percent of entities to delete
00215 {
00216     clock_t t = clock();
00217     if( create_mode )
00218     {
00219         std::cout << "Block Entity Creation (all entities in single block of memory)" << std::endl;
00220         TIME( "  Creating initial vertices", create_vertices_block );
00221         TIME( "  Creating initial elements", create_elements_block );
00222         if( dump_mesh && !percent && mb.write_file( "seqperf.vtk" ) == MB_SUCCESS )
00223             std::cout << "Wrote mesh to file: seqperf.vtk" << std::endl;
00224     }
00225     else
00226     {
00227         std::cout << "Single Entity Creation (entities grouped in memory blocks of constant size)" << std::endl;
00228         TIME( "  Creating initial vertices", create_vertices_single );
00229         TIME( "  Creating initial elements", create_elements_single );
00230     }
00231
00232     std::cout << order_strs[order] << " order with deletion of " << percent << "% of vertices and elements"
00233               << std::endl;
00234
00235     TIME_DEL( "  Deleting elements", delete_elems[order], percent );
00236     TIME_DEL( "  Deleting vertices", delete_verts[order], percent );
00237
00238     int num_vert = 0;
00239     int num_elem = 0;
00240     mb.get_number_entities_by_type( 0, MBVERTEX, num_vert );
00241     mb.get_number_entities_by_type( 0, MBHEX, num_elem );
00242     std::cout << "  " << num_vert << " vertices and " << num_elem << " elements remaining" << std::endl;
00243 #ifdef PRINT_SEQUENCE_COUNT
00244     std::cout << "  " << get_number_sequences( MBVERTEX ) << " vertex sequences and " << get_number_sequences( MBHEX )
00245               << " element sequences." << std::endl;
00246 #endif
00247
00248     TIME_QRY( "  Querying vertex coordinates", query_verts[order], percent );
00249     TIME_QRY( "  Querying element connectivity", query_elems[order], percent );
00250     TIME_QRY( "  Querying element coordinates", query_elem_verts[order], percent );
00251
00252     TIME_DEL( "  Re-creating vertices", create_missing_vertices, percent );
00253     TIME_DEL( "  Re-creating elements", create_missing_elements, percent );
00254
00255     TIME( "  Clearing mesh instance", delete_mesh );
00256
00257     std::cout << "Total time for test: " << ts( clock() - t ) << std::endl << std::endl;
00258 }
00259
00260 void parse_order( const char* str, std::vector< int >& list )
00261 {
00262     if( str[0] == 'f' )
00263     {
00264         if( strncmp( str, "forward", strlen( str ) ) != 0 ) usage();
00265         list.push_back( 0 );
00266     }
00267     else if( str[0] != 'r' )
00268         usage();
00269     else if( str[1] == 'e' )
00270     {
00271         if( strncmp( str, "reverse", strlen( str ) ) != 0 ) usage();
00272         list.push_back( 0 );
00273     }
00274     else
00275     {
00276         if( strncmp( str, "random", strlen( str ) ) != 0 ) usage();
00277         list.push_back( 0 );
00278     }
00279 }
00280
00281 void parse_percent( const char* str, std::vector< int >& list )
00282 {
00283     char* endptr;
00284     long p = strtol( str, &endptr, 0 );
00285     if( !endptr || *endptr || p < 0 || p > 100 ) usage();
00286
00287     list.push_back( (int)p );
00288 }
00289
00290 int parse_positive_int( const char* str )
00291 {
00292     char* endptr;
00293     long p = strtol( str, &endptr, 0 );
00294     if( !endptr || *endptr || p < 1 ) usage();
00295     int result = p;
00296     if( p != (long)result )  // overflow
00297         usage();
00298
00299     return result;
00300 }
00301
00302 void check_default( std::vector< int >& list, const int* array, size_t array_len )
00303 {
00304     if( list.empty() ) std::copy( array, array + array_len, std::back_inserter( list ) );
00305 }
00306
00307 int main( int argc, char* argv[] )
00308 {
00309     // Parse arguments
00310     std::vector< int > createList, orderList, deleteList;
00311     numSideInt = default_intervals;
00312     queryCount = default_query_count;
00313
00314     for( int i = 1; i < argc; ++i )
00315     {
00316         // check that arg is a '-' followed by a single character
00317         if( argv[i][0] != '-' || argv[i][1] == '\0' || argv[i][2] != '\0' ) usage();
00318
00319         const char flag = argv[i][1];
00320         switch( flag )
00321         {
00322             case 'b':
00323                 createList.push_back( 1 );
00324                 break;
00325             case 's':
00326                 createList.push_back( 0 );
00327                 break;
00328             default:
00329                 if( ++i == argc ) usage();
00330                 switch( flag )
00331                 {
00332                     case 'i':
00333                         numSideInt = parse_positive_int( argv[i] );
00334                         break;
00335                     case 'o':
00336                         parse_order( argv[i], orderList );
00337                         break;
00338                     case 'd':
00339                         parse_percent( argv[i], deleteList );
00340                         break;
00341                     case 'q':
00342                         queryCount = parse_positive_int( argv[i] );
00343                         break;
00344                     default:
00345                         usage();
00346                 }
00347         }
00348     }
00349     check_default( createList, default_create, ARRSIZE( default_create ) );
00350     check_default( orderList, default_order, ARRSIZE( default_order ) );
00351     check_default( deleteList, default_delete, ARRSIZE( default_delete ) );
00352
00353     // Do some initialization.
00354
00355     int numSideVert = numSideInt + 1;
00356     numVert         = numSideVert * numSideVert * numSideVert;
00357     numElem         = numSideInt * numSideInt * numSideInt;
00358     if( numVert / numSideVert / numSideVert != numSideVert )  // overflow
00359         usage();
00360     init();
00361
00362     // Echo input args
00363
00364     std::cout << numSideInt << "x" << numSideInt << "x" << numSideInt << " hex grid: " << numElem << " elements and "
00365               << numVert << " vertices" << std::endl;
00366
00367     // Run tests
00368
00369     std::vector< int >::const_iterator i, j, k;
00370     clock_t t = clock();
00371     for( i = createList.begin(); i != createList.end(); ++i )
00372     {
00373         for( j = deleteList.begin(); j != deleteList.end(); ++j )
00374         {
00375             for( k = orderList.begin(); k != orderList.end(); ++k )
00376             {
00377                 do_test( *i, *k, *j );
00378             }
00379         }
00380     }
00381
00382     // Clean up
00383
00384     std::cout << "TOTAL: " << ts( clock() - t ) << std::endl << std::endl;
00385     delete[] queryVertPermutation;
00386     delete[] queryElemPermutation;
00387     return 0;
00388 }
00389
00390 inline void vertex_coords( long vert_index, double& x, double& y, double& z )
00391 {
00392     const long vs = numSideInt + 1;
00393     x             = vert_index % vs;
00394     y             = ( vert_index / vs ) % vs;
00395     z             = ( vert_index / vs / vs );
00396 }
00397
00398 inline long vert_index( long x, long y, long z )
00399 {
00400     const long vs = numSideInt + 1;
00401     return x + vs * ( y + vs * z );
00402 }
00403
00404 inline void element_conn( long elem_index, EntityHandle conn[8] )
00405 {
00406     const long x = elem_index % numSideInt;
00407     const long y = ( elem_index / numSideInt ) % numSideInt;
00408     const long z = ( elem_index / numSideInt / numSideInt );
00409     conn[0]      = vertStart + vert_index( x, y, z );
00410     conn[1]      = vertStart + vert_index( x + 1, y, z );
00411     conn[2]      = vertStart + vert_index( x + 1, y + 1, z );
00412     conn[3]      = vertStart + vert_index( x, y + 1, z );
00413     conn[4]      = vertStart + vert_index( x, y, z + 1 );
00414     conn[5]      = vertStart + vert_index( x + 1, y, z + 1 );
00415     conn[6]      = vertStart + vert_index( x + 1, y + 1, z + 1 );
00416     conn[7]      = vertStart + vert_index( x, y + 1, z + 1 );
00417 }
00418
00419 inline bool deleted_vert( long index, int percent )
00420 {
00421     return index % ( numSideInt + 1 ) >= ( numSideInt + 1 ) * ( 100 - percent ) / 100;
00422 }
00423
00424 inline bool deleted_elem( long index, int percent )
00425 {
00426     return index % numSideInt + 1 >= ( numSideInt + 1 ) * ( 100 - percent ) / 100;
00427 }
00428
00429 void create_vertices_single()
00430 {
00431     double coords[3];
00432     vertex_coords( 0, coords[0], coords[1], coords[2] );
00433     ErrorCode rval = mb.create_vertex( coords, vertStart );
00434     assert( !rval );
00435     if( rval )
00436     {
00437     }  // empty line to remove compiler warning
00438
00439     EntityHandle h;
00440     for( long i = 1; i < numVert; ++i )
00441     {
00442         vertex_coords( i, coords[0], coords[1], coords[2] );
00443         rval = mb.create_vertex( coords, h );
00444         assert( !rval );
00445         assert( h - vertStart == (EntityHandle)i );
00446     }
00447 }
00448
00449 void create_vertices_block()
00450 {
00451     std::vector< double* > arrays;
00452     ErrorCode rval = readTool->get_node_coords( 3, numVert, 0, vertStart, arrays );
00453     if( rval || arrays.size() != 3 )
00454     {
00455         assert( false );
00456         abort();
00457     }
00458     double *x = arrays[0], *y = arrays[1], *z = arrays[2];
00459     assert( x && y && z );
00460
00461     for( long i = 0; i < numVert; ++i )
00462         vertex_coords( i, *x++, *y++, *z++ );
00463 }
00464
00465 void create_elements_single()
00466 {
00467     EntityHandle conn[8];
00468     element_conn( 0, conn );
00469     ErrorCode rval = mb.create_element( MBHEX, conn, 8, elemStart );
00470     if( rval )
00471     {
00472         assert( false );
00473         abort();
00474     }
00475
00476     EntityHandle h;
00477     for( long i = 1; i < numElem; ++i )
00478     {
00479         element_conn( i, conn );
00480         rval = mb.create_element( MBHEX, conn, 8, h );
00481         assert( !rval );
00482         assert( h - elemStart == (EntityHandle)i );
00483     }
00484 }
00485
00486 void create_elements_block()
00487 {
00488     EntityHandle* conn = 0;
00489     ErrorCode rval     = readTool->get_element_connect( numElem, 8, MBHEX, 0, elemStart, conn );
00490     if( rval && !conn )
00491     {
00492         assert( false );
00493         abort();
00494     }
00495
00496     for( long i = 0; i < numElem; ++i )
00497         element_conn( i, conn + 8 * i );
00498 }
00499
00500 void forward_order_query_vertices( int percent )
00501 {
00502     ErrorCode r;
00503     double coords[3];
00504     long x, y, z;
00505     const long vert_per_edge = numSideInt + 1;
00506     const long deleted_x     = ( numSideInt + 1 ) * ( 100 - percent ) / 100;
00507     EntityHandle h           = vertStart;
00508     for( z = 0; z < vert_per_edge; ++z )
00509     {
00510         for( y = 0; y < vert_per_edge; ++y )
00511         {
00512             for( x = 0; x < deleted_x; ++x, ++h )
00513             {
00514                 r = mb.get_coords( &h, 1, coords );
00515                 if( MB_SUCCESS != r )
00516                 {
00517                     assert( false );
00518                     abort();
00519                 }
00520             }
00521             h += ( vert_per_edge - deleted_x );
00522         }
00523     }
00524 }
00525
00526 void reverse_order_query_vertices( int percent )
00527 {
00528     ErrorCode r;
00529     double coords[3];
00530     long x, y, z;
00531     const long vert_per_edge = numSideInt + 1;
00532     const long deleted_x     = ( numSideInt + 1 ) * ( 100 - percent ) / 100;
00533     EntityHandle h           = vertStart + numVert - 1;
00534     ;
00535     for( z = vert_per_edge - 1; z >= 0; --z )
00536     {
00537         for( y = vert_per_edge - 1; y >= 0; --y )
00538         {
00539             h -= ( vert_per_edge - deleted_x );
00540             for( x = deleted_x - 1; x >= 0; --x, --h )
00541             {
00542                 r = mb.get_coords( &h, 1, coords );
00543                 assert( MB_SUCCESS == r );
00544                 if( r )
00545                 {
00546                 }  // empty line to remove compiler warning
00547             }
00548         }
00549     }
00550 }
00551
00552 void random_order_query_vertices( int percent )
00553 {
00554     ErrorCode r;
00555     EntityHandle h;
00556     double coords[3];
00557     for( long i = 0; i < numVert; ++i )
00558     {
00559         if( !deleted_vert( queryVertPermutation[i], percent ) )
00560         {
00561             h = vertStart + queryVertPermutation[i];
00562             r = mb.get_coords( &h, 1, coords );
00563             assert( MB_SUCCESS == r );
00564             if( r )
00565             {
00566             }  // empty line to remove compiler warning
00567         }
00568     }
00569 }
00570
00571 void forward_order_query_elements( int percent )
00572 {
00573     ErrorCode r;
00574     const EntityHandle* conn;
00575     int len;
00576     long x, y, z;
00577     const long elem_per_edge = numSideInt;
00578     const long deleted_x     = ( numSideInt + 1 ) * ( 100 - percent ) / 100 - 1;
00579     EntityHandle h           = elemStart;
00580     for( z = 0; z < elem_per_edge; ++z )
00581     {
00582         for( y = 0; y < elem_per_edge; ++y )
00583         {
00584             for( x = 0; x < deleted_x; ++x, ++h )
00585             {
00586                 r = mb.get_connectivity( h, conn, len );
00587                 assert( MB_SUCCESS == r );
00588                 if( r )
00589                 {
00590                 }  // empty line to remove compiler warning
00591                 assert( conn && 8 == len );
00592             }
00593             h += ( elem_per_edge - deleted_x );
00594         }
00595     }
00596 }
00597
00598 void reverse_order_query_elements( int percent )
00599 {
00600     ErrorCode r;
00601     const EntityHandle* conn;
00602     int len;
00603     long x, y, z;
00604     const long elem_per_edge = numSideInt;
00605     const long deleted_x     = ( numSideInt + 1 ) * ( 100 - percent ) / 100 - 1;
00606     EntityHandle h           = elemStart + numElem - 1;
00607     ;
00608     for( z = elem_per_edge - 1; z >= 0; --z )
00609     {
00610         for( y = elem_per_edge - 1; y >= 0; --y )
00611         {
00612             h -= ( elem_per_edge - deleted_x );
00613             for( x = deleted_x - 1; x >= 0; --x, --h )
00614             {
00615                 r = mb.get_connectivity( h, conn, len );
00616                 assert( MB_SUCCESS == r );
00617                 if( r )
00618                 {
00619                 }  // empty line to remove compiler warning
00620                 assert( conn && 8 == len );
00621             }
00622         }
00623     }
00624 }
00625
00626 void random_order_query_elements( int percent )
00627 {
00628     ErrorCode r;
00629     const EntityHandle* conn;
00630     int len;
00631     for( long i = 0; i < numElem; ++i )
00632     {
00633         if( !deleted_elem( queryElemPermutation[i], percent ) )
00634         {
00635             r = mb.get_connectivity( elemStart + queryElemPermutation[i], conn, len );
00636             assert( MB_SUCCESS == r );
00637             if( r )
00638             {
00639             }  // empty line to remove compiler warning
00640             assert( conn && 8 == len );
00641         }
00642     }
00643 }
00644
00645 /*
00646 static double hex_centroid( double coords[24], double cent[3] )
00647 {
00648   double a[3], b[3], c[3], vol;
00649   cent[0] += 0.125*(coords[0] + coords[3] + coords[6] + coords[ 9] + coords[12] + coords[15] +
00650 coords[18] + coords[21]); cent[1] += 0.125*(coords[1] + coords[4] + coords[7] + coords[10] +
00651 coords[13] + coords[16] + coords[19] + coords[22]); cent[2] += 0.125*(coords[2] + coords[5] +
00652 coords[8] + coords[11] + coords[14] + coords[17] + coords[20] + coords[23]); a[0] = coords[0] +
00653 coords[3] + coords[15] + coords[12] - coords[ 9] - coords[6] - coords[18] - coords[21]; a[1] =
00654 coords[1] + coords[4] + coords[16] + coords[13] - coords[10] - coords[7] - coords[19] - coords[22];
00655   a[2] = coords[2] + coords[5] + coords[17] + coords[14] - coords[11] - coords[8] - coords[20] -
00656 coords[23]; b[0] = coords[0] + coords[ 9] + coords[21] + coords[12] - coords[3] - coords[6] -
00657 coords[18] - coords[15]; b[1] = coords[1] + coords[10] + coords[22] + coords[13] - coords[4] -
00658 coords[7] - coords[19] - coords[16]; b[2] = coords[2] + coords[11] + coords[23] + coords[14] -
00659 coords[5] - coords[8] - coords[20] - coords[17]; c[0] = coords[0] + coords[3] + coords[6] + coords[
00660 9] - coords[12] - coords[15] - coords[18] - coords[21]; c[1] = coords[1] + coords[4] + coords[7] +
00661 coords[10] - coords[13] - coords[16] - coords[19] - coords[22]; c[2] = coords[2] + coords[5] +
00662 coords[8] + coords[11] - coords[14] - coords[17] - coords[20] - coords[23]; vol = c[0]*(a[1]*b[2] -
00663 a[2]*b[1]) + c[1]*(a[2]*b[0] - a[0]*b[2]) + c[2]*(a[0]*b[1] - a[1]*b[0]); return (1./64.) * vol;
00664 }
00665 */
00666
00667 void forward_order_query_element_verts( int percent )
00668 {
00669     ErrorCode r = MB_SUCCESS;
00670     if( r )
00671     {
00672     }  // empty line to remove compiler warning
00673     const EntityHandle* conn;
00674     int len;
00675     long x, y, z;
00676     double coords[24];
00677     const long elem_per_edge = numSideInt;
00678     const long deleted_x     = ( numSideInt + 1 ) * ( 100 - percent ) / 100 - 1;
00679     EntityHandle h           = elemStart;
00680     for( z = 0; z < elem_per_edge; ++z )
00681     {
00682         for( y = 0; y < elem_per_edge; ++y )
00683         {
00684             for( x = 0; x < deleted_x; ++x, ++h )
00685             {
00686                 r = mb.get_connectivity( h, conn, len );
00687                 assert( MB_SUCCESS == r );
00688                 assert( conn && 8 == len );
00689                 r = mb.get_coords( conn, len, coords );
00690                 assert( MB_SUCCESS == r );
00691             }
00692             h += ( elem_per_edge - deleted_x );
00693         }
00694     }
00695 }
00696
00697 void reverse_order_query_element_verts( int percent )
00698 {
00699     ErrorCode r = MB_SUCCESS;
00700     if( r )
00701     {
00702     }  // empty statement to remove compiler warning
00703
00704     const EntityHandle* conn;
00705     int len;
00706     long x, y, z;
00707     double coords[24];
00708     const long elem_per_edge = numSideInt;
00709     const long deleted_x     = ( numSideInt + 1 ) * ( 100 - percent ) / 100 - 1;
00710     EntityHandle h           = elemStart + numElem - 1;
00711     ;
00712     for( z = elem_per_edge - 1; z >= 0; --z )
00713     {
00714         for( y = elem_per_edge - 1; y >= 0; --y )
00715         {
00716             h -= ( elem_per_edge - deleted_x );
00717             for( x = deleted_x - 1; x >= 0; --x, --h )
00718             {
00719                 r = mb.get_connectivity( h, conn, len );
00720                 assert( MB_SUCCESS == r );
00721                 assert( conn && 8 == len );
00722                 r = mb.get_coords( conn, len, coords );
00723                 assert( MB_SUCCESS == r );
00724             }
00725         }
00726     }
00727 }
00728
00729 void random_order_query_element_verts( int percent )
00730 {
00731     ErrorCode r = MB_SUCCESS;
00732     if( r )
00733     {
00734     }  // empty line to remove compiler warning
00735     const EntityHandle* conn;
00736     int len;
00737     double coords[24];
00738     for( long i = 0; i < numElem; ++i )
00739     {
00740         if( !deleted_elem( queryElemPermutation[i], percent ) )
00741         {
00742             r = mb.get_connectivity( elemStart + queryElemPermutation[i], conn, len );
00743             assert( MB_SUCCESS == r );
00744             assert( conn && 8 == len );
00745             r = mb.get_coords( conn, len, coords );
00746             assert( MB_SUCCESS == r );
00747         }
00748     }
00749 }
00750
00751 void forward_order_delete_vertices( int percent )
00752 {
00753     for( long i = 0; i < numVert; ++i )
00754         delete_vert( i, percent );
00755 }
00756
00757 void reverse_order_delete_vertices( int percent )
00758 {
00759     for( long i = numVert - 1; i >= 0; --i )
00760         delete_vert( i, percent );
00761 }
00762
00763 void random_order_delete_vertices( int percent )
00764 {
00765     for( long i = 0; i < numVert; ++i )
00766         delete_vert( queryVertPermutation[i], percent );
00767 }
00768
00769 void forward_order_delete_elements( int percent )
00770 {
00771     for( long i = 0; i < numElem; ++i )
00772         delete_elem( i, percent );
00773 }
00774
00775 void reverse_order_delete_elements( int percent )
00776 {
00777     for( long i = numElem - 1; i >= 0; --i )
00778         delete_elem( i, percent );
00779 }
00780
00781 void random_order_delete_elements( int percent )
00782 {
00783     for( long i = 0; i < numElem; ++i )
00784         delete_elem( queryElemPermutation[i], percent );
00785 }
00786
00787 void create_missing_vertices( int percent )
00788 {
00789     EntityHandle h;
00790     ErrorCode rval = MB_SUCCESS;
00791     if( rval )
00792     {
00793     }  // empty line to remove compiler warning
00794     double coords[3];
00795     for( long i = 0; i < numVert; ++i )
00796         if( deleted_vert( i, percent ) )
00797         {
00798             vertex_coords( i, coords[0], coords[1], coords[2] );
00799             rval = mb.create_vertex( coords, h );
00800             assert( !rval );
00801         }
00802 }
00803
00804 void create_missing_elements( int percent )
00805 {
00806     EntityHandle h;
00807     ErrorCode rval;
00808     EntityHandle conn[8];
00809     for( long i = 0; i < numElem; ++i )
00810         if( deleted_elem( i, percent ) )
00811         {
00812             element_conn( i, conn );
00813             rval = mb.create_element( MBHEX, conn, 8, h );
00814             if( rval )
00815             {
00816                 assert( false );
00817                 abort();
00818             }
00819         }
00820 }
00821
00822 inline void delete_vert( long index, int percent )
00823 {
00824     if( deleted_vert( index, percent ) )
00825     {
00826         EntityHandle h = index + vertStart;
00827         ErrorCode rval = mb.delete_entities( &h, 1 );
00828         if( rval )
00829         {
00830             assert( false );
00831             abort();
00832         }
00833     }
00834 }
00835
00836 inline void delete_elem( long index, int percent )
00837 {
00838     if( deleted_elem( index, percent ) )
00839     {
00840         EntityHandle h = index + elemStart;
00841         ErrorCode rval = mb.delete_entities( &h, 1 );
00842         if( rval )
00843         {
00844             assert( false );
00845             abort();
00846         }
00847     }
00848 }
00849
00850 #ifdef PRINT_SEQUENCE_COUNT
00851 unsigned get_number_sequences( EntityType type )
00852 {
00853 #ifdef MB_ENTITY_SEQUENCE_HPP
00854     return mb_core.sequence_manager()->entity_map( type )->size();
00855 #else
00856     return mb_core.sequence_manager()->entity_map( type ).get_sequence_count();
00857 #endif
00858 }
00859 #endif
