setup.cpp File Reference
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "MsqVertex.hpp"
#include <iostream>
#include <cstdlib>
#include <cassert>
#include <map>
#include <vector>
#include <algorithm>
+ Include dependency graph for setup.cpp:
Functions
void usage (const char *argv0)
int main (int argc, char *argv[])
Variables
const double PERTURB_FRACT = 0.4
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 27 of file setup.cpp.
References MBMesquite::arrptr(), conn, corners, MBMesquite::MeshImpl::elements_get_attached_vertices(), MBMesquite::MeshImpl::elements_get_topologies(), fixed, MBMesquite::MeshImpl::get_all_elements(), MBMesquite::MeshImpl::get_all_vertices(), init(), MBMesquite::Mesh::INT, MBMesquite::MeshImpl::mark_skin_fixed(), mesh, n, PERTURB_FRACT, MBMesquite::MeshImpl::read_vtk(), skin(), MBMesquite::MeshImpl::tag_create(), MBMesquite::MeshImpl::tag_set_vertex_data(), usage, MBMesquite::MeshImpl::vertex_set_coordinates(), MBMesquite::MeshImpl::vertices_get_attached_elements(), MBMesquite::MeshImpl::vertices_get_coordinates(), MBMesquite::MeshImpl::vertices_get_fixed_flag(), and MBMesquite::MeshImpl::write_vtk().
    if( argc != 4 ) usage( argv[0] );
    char* endptr = 0;
    const long n = strtol( argv[1], &endptr, 0 );
    if( *endptr || n < 0 ) usage( argv[0] );
    // read input mesh
    MeshImpl mesh;
    MsqPrintError err( std::cerr );
    mesh.read_vtk( argv[2], err );
    if( err ) return 1;
    // get skin vertices
    mesh.mark_skin_fixed( err, true );
    if( err ) return 1;
    std::vector< Mesh::VertexHandle > verts;
    mesh.get_all_vertices( verts, err );
    if( err ) return 1;
    std::vector< bool > fixed;
    mesh.vertices_get_fixed_flag( arrptr( verts ), fixed, verts.size(), err );
    if( err ) return 1;
    std::vector< Mesh::VertexHandle > skin;
    for( size_t i = 0; i < verts.size(); ++i )
        if( fixed[i] ) skin.push_back( verts[i] );
    // create map for vertex depth, and initialize to 0 for skin vertices
    std::map< Mesh::VertexHandle, int > depth;
    std::map< Mesh::VertexHandle, int >::iterator d_iter;
    for( size_t i = 0; i < skin.size(); ++i )
        depth[skin[i]] = 0;
    // get all elements
    std::vector< Mesh::ElementHandle > curr, next;
    std::vector< Mesh::ElementHandle > conn;
    std::vector< size_t > off;
    mesh.get_all_elements( next, err );
    // build sorted list of higher-order vertices
    std::vector< Mesh::VertexHandle > higher_order;
    for( size_t i = 0; i < next.size(); ++i )
        Mesh::ElementHandle elem = next[i];
        conn.clear();
        mesh.elements_get_attached_vertices( &elem, 1, conn, off, err );
        if( err ) return 1;
        EntityTopology type;
        mesh.elements_get_topologies( &elem, &type, 1, err );
        std::copy( conn.begin() + TopologyInfo::corners( type ), conn.end(), std::back_inserter( higher_order ) );
    std::sort( higher_order.begin(), higher_order.end() );
    higher_order.erase( std::unique( higher_order.begin(), higher_order.end() ), higher_order.end() );
    // build depth map for all vertices
    while( !next.empty() )
        curr.swap( next );
        next.clear();
        while( !curr.empty() )
            Mesh::ElementHandle elem = curr.back();
            curr.pop_back();
            conn.clear();
            if( err ) return 1;
            int min = std::numeric_limits< int >::max();
            for( size_t i = 0; i < conn.size(); ++i )
                d_iter = depth.find( conn[i] );
                if( d_iter != depth.end() && d_iter->second < min ) min = d_iter->second;
            if( min == std::numeric_limits< int >::max() )
                next.push_back( elem );
                continue;
                if( d_iter == depth.end() || d_iter->second > min + 1 ) depth[conn[i]] = min + 1;
    // write depth map to tag for debugging purposes
    std::vector< int > depth_vals( verts.size() );
        depth_vals[i] = depth[verts[i]];
    TagHandle tag = mesh.tag_create( "depth", Mesh::INT, 1, 0, err );
    if( err ) return 1;
    mesh.tag_set_vertex_data( tag, verts.size(), arrptr( verts ), arrptr( depth_vals ), err );
    if( err ) return 1;
    // set tag specifying slaved vertices
        if( std::binary_search( higher_order.begin(), higher_order.end(), verts[i] ) )
            depth_vals[i] = depth[verts[i]] > n;
        else
            depth_vals[i] = 0;
    tag = mesh.tag_create( "slaved", Mesh::INT, 1, 0, err );
    if( err ) return 1;
    if( err ) return 1;
    // perturb mid-edge nodes along boundary
    std::vector< MsqVertex > coords;
        if( !std::binary_search( higher_order.begin(), higher_order.end(), skin[i] ) ) continue;
        curr.clear();
        mesh.vertices_get_attached_elements( &skin[i], 1, curr, off, err );
        if( err ) return 1;
        assert( curr.size() == 1 );
        conn.clear();
        mesh.elements_get_attached_vertices( arrptr( curr ), 1, conn, off, err );
        if( err ) return 1;
        // estimate element center
        coords.resize( conn.size() );
        mesh.vertices_get_coordinates( arrptr( conn ), arrptr( coords ), conn.size(), err );
        if( err ) return 1;
        Vector3D mean( 0.0 );
        for( size_t j = 0; j < coords.size(); ++j )
            mean += coords[j];
        mean /= coords.size();
        size_t idx = std::find( conn.begin(), conn.end(), skin[i] ) - conn.begin();
        assert( idx < conn.size() );
        Vector3D init = coords[idx];
        Vector3D pos  = ( 1 - PERTURB_FRACT ) * init + PERTURB_FRACT * mean;
        mesh.vertex_set_coordinates( skin[i], pos, err );
        if( err ) return 1;
    mesh.write_vtk( argv[3], err );
    if( err ) return 1;
    return 0;
void usage ( const char *  argv0)
Definition at line 16 of file setup.cpp.
    std::cerr << "Usage: " << argv0 << " <depth> <input_file> <output_file>" << std::endl;
    exit( 1 );
Variable Documentation
Definition at line 12 of file setup.cpp.
Referenced by main().
