size.cpp
00001 #include <iostream>
00002 #include <cstdlib>
00003 #include <vector>
00004 #include <set>
00005 #include <string>
00006 #include <cstdio>
00007 #include <iomanip>
00008 #include "moab/MOABConfig.h"
00009 #ifndef WIN32
00010 #include <sys/times.h>
00011 #include <climits>
00012 #include <unistd.h>
00013 #endif
00014 #include <ctime>
00015 #ifdef MOAB_HAVE_MPI
00016 #include "moab_mpi.h"
00017 #endif
00018 #if !defined( _MSC_VER ) && !defined( __MINGW32__ )
00019 #include <termios.h>
00020 #include <sys/ioctl.h>
00021 #endif
00022 #include <cmath>
00023 #include <cassert>
00024 #include <cfloat>
00025
00026 #include "moab/Core.hpp"
00027 #include "moab/Range.hpp"
00028 #include "MBTagConventions.hpp"
00029 #include "moab/Interface.hpp"
00030 #include "moab/ReaderWriterSet.hpp"
00031
00032 /* Exit values */
00033 #define USAGE_ERROR   1
00034 #define READ_ERROR    2
00035 #define WRITE_ERROR   3
00036 #define OTHER_ERROR   4
00037 #define ENT_NOT_FOUND 5
00038
00039 using namespace moab;
00040
00041 #include "measure.hpp"
00042
00043 static void print_usage( const char* name, std::ostream& stream )
00044 {
00045     stream << "Usage: " << name << " <options> <input_file> [<input_file2> ...]" << std::endl
00046            << "Options: " << std::endl
00047            << "\t-f             - List available file formats and exit." << std::endl
00048            << "\t-g             - print counts by geometric owner" << std::endl
00049            << "\t-h             - Print this help text and exit." << std::endl
00050            << "\t-l             - Print counts of mesh" << std::endl
00051            << "\t-ll            - Verbose listing of every entity" << std::endl
00052            << "\t-m             - Print counts per block/boundary" << std::endl
00053            << "\t-O option      - Specify read option." << std::endl
00054 #ifdef MOAB_HAVE_MPI
00055            << "\t-p[0|1|2]      - Read in parallel[0], optionally also doing resolve_shared_ents "
00056               "(1) and exchange_ghosts (2)"
00057            << std::endl
00058 #endif
00059            << "\t-t             - Print counts by tag" << std::endl
00060            << "\t-T             - Time read of files." << std::endl
00061            << "\t--             - treat all subsequent options as file names" << std::endl
00062            << "\t                 (allows file names beginning with '-')" << std::endl;
00063 }
00064
00065 Core mb;
00066
00067 struct stat_set
00068 {
00069     double sum;
00070     double sqr;
00071     double min;
00072     double max;
00073     long count;
00074
00075     inline stat_set() : sum( 0 ), sqr( 0 ), min( HUGE_VAL ), max( 0 ), count( 0 ) {}
00076
00077     inline void add( double val )
00078     {
00079         if( val < min ) min = val;
00080         if( val > max ) max = val;
00081         sum += val;
00082         sqr += val * val;
00083         ++count;
00084     }
00085
00086     inline void add( const stat_set& stats )
00087     {
00088         if( stats.min < min ) min = stats.min;
00089         if( stats.max > max ) max = stats.max;
00090         sum += stats.sum;
00091         sqr += stats.sqr;
00092         count += stats.count;
00093     }
00094
00095     inline void clear()
00096     {
00097         sum = sqr = 0.0;
00098         max = count = 0;
00099         min         = HUGE_VAL;
00100     }
00101 };
00102
00103 struct set_stats
00104 {
00105     stat_set stats[MBMAXTYPE];
00106     stat_set edge_uses;
00107     size_t nodes;
00108
00109     void add( const set_stats& other )
00110     {
00111         for( int i = 0; i < MBMAXTYPE; ++i )
00112             stats[i].add( other.stats[i] );
00113         edge_uses.add( other.edge_uses );
00114     }
00115
00116     void clear()
00117     {
00118         for( int i = 0; i < MBMAXTYPE; ++i )
00119             stats[i].clear();
00120         edge_uses.clear();
00121     }
00122 };
00123
00124 static ErrorCode gather_set_stats( EntityHandle set, set_stats& stats )
00125 {
00126     int count;
00127     ErrorCode rval = mb.get_number_entities_by_type( set, MBVERTEX, count );
00128     if( MB_SUCCESS != rval ) return rval;
00129     stats.nodes = count;
00130
00131     int edge_vtx_idx[2];
00132     std::vector< EntityHandle > conn;
00133     std::vector< double > coords;
00134     for( EntityType type = MBEDGE; type < MBENTITYSET; ++type )
00135     {
00136         int num_edges = CN::NumSubEntities( type, 1 );
00137
00138         Range range;
00139         rval = mb.get_entities_by_type( set, type, range, true );
00140         if( MB_SUCCESS != rval ) return rval;
00141         for( Range::iterator i = range.begin(); i != range.end(); ++i )
00142         {
00143             rval = mb.get_connectivity( &*i, 1, conn, true );
00144             if( MB_SUCCESS != rval ) return rval;
00145             if( type == MBPOLYHEDRON )
00146             {
00147                 std::vector< EntityHandle > dum_conn( conn );
00148                 conn.clear();
00149                 rval = mb.get_adjacencies( &dum_conn[0], dum_conn.size(), 0, false, conn, Interface::UNION );
00150                 if( MB_SUCCESS != rval ) return rval;
00151             }
00152             coords.resize( 3 * conn.size() );
00153             rval = mb.get_coords( &conn[0], conn.size(), &coords[0] );
00154             if( MB_SUCCESS != rval ) return rval;
00155             stats.stats[type].add( measure( type, conn.size(), &coords[0] ) );
00156
00157             if( type != MBEDGE )
00158             {
00159                 if( type == MBPOLYGON ) num_edges = conn.size();
00160
00161                 for( int e = 0; e < num_edges; ++e )
00162                 {
00163                     if( type == MBPOLYGON )
00164                     {
00165                         edge_vtx_idx[0] = e;
00166                         edge_vtx_idx[1] = ( e + 1 ) % num_edges;
00167                     }
00168                     else
00169                         CN::SubEntityVertexIndices( type, 1, e, edge_vtx_idx );
00170                     stats.edge_uses.add( edge_length( &coords[3 * edge_vtx_idx[0]], &coords[3 * edge_vtx_idx[1]] ) );
00171                 }
00172             }
00173         }
00174     }
00175     return MB_SUCCESS;
00176 }
00177
00178 struct TagCounts
00179 {
00180     TagCounts( std::string n ) : name( n )
00181     {
00182         std::fill( counts, counts + MBMAXTYPE, 0 );
00183     }
00184     std::string name;
00185     int counts[MBMAXTYPE];
00186 };
00187
00188 static ErrorCode gather_tag_counts( EntityHandle set, std::vector< TagCounts >& counts )
00189 {
00190     std::vector< Tag > tags;
00191     mb.tag_get_tags( tags );
00192     for( size_t i = 0; i < tags.size(); ++i )
00193     {
00194         std::string name;
00195         ErrorCode rval = mb.tag_get_name( tags[i], name );
00196         if( MB_SUCCESS != rval || name.empty() ) continue;
00197
00198         counts.push_back( name );
00199         for( EntityType t = MBVERTEX; t != MBMAXTYPE; ++t )
00200             mb.get_number_entities_by_type_and_tag( set, t, &tags[i], 0, 1, counts.back().counts[t] );
00201     }
00202
00203     return MB_SUCCESS;
00204 }
00205
00206 void add_tag_counts( std::vector< TagCounts >& counts, const std::vector< TagCounts >& add )
00207 {
00208     for( size_t i = 0; i < add.size(); ++i )
00209     {
00210         size_t j;
00211         for( j = 0; j < counts.size(); ++j )
00212             if( add[i].name == counts[j].name ) break;
00213         if( j == counts.size() )
00214         {
00215             counts.push_back( add[i] );
00216             continue;
00217         }
00218         for( EntityType t = MBVERTEX; t != MBMAXTYPE; ++t )
00219             counts[j].counts[t] += add[i].counts[t];
00220     }
00221 }
00222
00223 static const char* dashes( unsigned count )
00224 {
00225     static std::vector< char > dashes;
00226     dashes.clear();
00227     dashes.resize( count + 1, '-' );
00228     dashes[count] = '\0';
00229     return &dashes[0];
00230 }
00231
00232 static void print_tag_counts( const std::vector< TagCounts >& counts )
00233 {
00234     if( counts.empty() )
00235     {
00236         printf( "<No tags>\n" );
00237         return;
00238     }
00239
00240     int widths[MBMAXTYPE] = { 0 };
00241     int name_width        = 0;
00242     for( size_t i = 0; i < counts.size(); ++i )
00243     {
00244         if( counts[i].name.length() > (unsigned)name_width ) name_width = counts[i].name.length();
00245         for( EntityType t = MBVERTEX; t != MBMAXTYPE; ++t )
00246             if( counts[i].counts[t] != 0 ) widths[t] = std::max( 8, (int)strlen( CN::EntityTypeName( t ) ) );
00247     }
00248
00249     if( 0 == std::min_element( widths, widths + MBMAXTYPE ) )
00250     {
00251         printf( "<No Tagged Entities>\n" );
00252         return;
00253     }
00254
00255     // Print header line
00256     const char* name_title = "Tag Name";
00257     if( (unsigned)name_width < strlen( name_title ) ) name_width = strlen( name_title );
00258     printf( "%*s", name_width, name_title );
00259     for( EntityType t = MBVERTEX; t != MBMAXTYPE; ++t )
00260         if( widths[t] ) printf( " %*s", widths[t], CN::EntityTypeName( t ) );
00261     printf( "\n%s", dashes( name_width ) );
00262     for( EntityType t = MBVERTEX; t != MBMAXTYPE; ++t )
00263         if( widths[t] ) printf( " %s", dashes( widths[t] ) );
00264     printf( "\n" );
00265
00266     // print data
00267     for( size_t i = 0; i < counts.size(); ++i )
00268     {
00269         printf( "%*s", name_width, counts[i].name.c_str() );
00270         for( EntityType t = MBVERTEX; t != MBMAXTYPE; ++t )
00271             if( widths[t] ) printf( " %*d", widths[t], counts[i].counts[t] );
00272         printf( "\n" );
00273     }
00274 }
00275
00276 static void print_stats( set_stats& stats )
00277 {
00278     const char* edge_use_name = "1D Side";
00279     const char* vertex_name   = "Vertex";
00280
00281     bool have_some = stats.edge_uses.count > 0 || stats.nodes > 0;
00282     for( int i = 0; i < MBMAXTYPE; ++i )
00283         if( stats.stats[i].count > 0 ) have_some = true;
00284
00285     if( !have_some )
00286     {
00287         std::cout << "NO MESH" << std::endl;
00288         return;
00289     }
00290
00291     // get field widths
00292     unsigned type_width  = std::max( strlen( vertex_name ), strlen( edge_use_name ) );
00293     unsigned count_width = 5;
00294     unsigned total_width = 5;
00295     unsigned total_prec  = 2;
00296     unsigned precision   = 5;
00297     int total_log        = -10000;
00298
00299     unsigned node_count_width = (unsigned)( ceil( log10( (double)stats.nodes ) ) ) + 1;
00300     if( count_width < node_count_width ) count_width = node_count_width;
00301
00302     for( EntityType i = MBEDGE; i < MBMAXTYPE; ++i )
00303     {
00304         stat_set& s = stats.stats[i];
00305
00306         if( s.count == 0 ) continue;
00307
00308         unsigned len = strlen( CN::EntityTypeName( i ) );
00309         if( len > type_width ) type_width = len;
00310
00311         unsigned cw = (unsigned)( ceil( log10( (double)s.count ) ) ) + 1;
00312         if( cw > count_width ) count_width = cw;
00313
00314         int tl = (unsigned)( ceil( log10( fabs( s.sum ) ) ) ) + 1;
00315         if( tl > total_log ) total_log = tl;
00316     }
00317
00318     if( total_log > (int)total_width || total_log == -10000 )
00319     {
00320         total_width = 8;
00321         total_prec  = 2;
00322     }
00323     else if( total_log <= -(int)total_width )
00324     {
00325         total_width = -total_log + 5;
00326         total_prec  = 2;
00327     }
00328     else if( total_log < 1 )
00329     {
00330         total_width = -total_log + 4;
00331         total_prec  = -total_log + 1;
00332     }
00333     else
00334     {
00335         total_width += 2;
00336     }
00337
00338     // get terminal width
00339     unsigned term_width = 80;
00340 #if !defined( _MSC_VER ) && !defined( __MINGW32__ )
00341     struct winsize size;
00342     if( ioctl( fileno( stdout ), TIOCGWINSZ, (char*)&size ) == 0 ) term_width = size.ws_col;
00343     if( !term_width ) term_width = 80;
00344 #endif
00345     assert( term_width > 7 + type_width + count_width + total_width );
00346
00347     term_width -= 7;  // spaces
00348     term_width -= type_width;
00349     term_width -= count_width;
00350     term_width -= total_width;
00351     unsigned val_width = term_width / 5;
00352     if( val_width < 8 ) val_width = 8;
00353
00354     printf( "%*s %*s %*s %*s %*s %*s %*s %*s\n", type_width, "type", count_width, "count", total_width, "total",
00355             val_width, "minimum", val_width, "average", val_width, "rms", val_width, "maximum", val_width, "std.dev." );
00356
00357     printf( "%*s ", type_width, dashes( type_width ) );
00358     printf( "%*s ", count_width, dashes( count_width ) );
00359     printf( "%*s ", total_width, dashes( total_width ) );
00360     printf( "%*s ", val_width, dashes( val_width ) );
00361     printf( "%*s ", val_width, dashes( val_width ) );
00362     printf( "%*s ", val_width, dashes( val_width ) );
00363     printf( "%*s ", val_width, dashes( val_width ) );
00364     printf( "%*s\n", val_width, dashes( val_width ) );
00365
00366     for( EntityType i = MBEDGE; i <= MBMAXTYPE; ++i )
00367     {
00368         stat_set& s = ( i == MBMAXTYPE ) ? stats.edge_uses : stats.stats[i];
00369
00370         if( s.count == 0 ) continue;
00371
00372         double tmp_dbl = s.sqr / s.count - s.sum * s.sum / (double)s.count / (double)s.count;
00373         if( tmp_dbl < 0.0 )
00374         {
00375             if( tmp_dbl < -100.0 * DBL_EPSILON )
00376                 std::cout << "WARNING: stat values dubious, s^2 - sig_s = " << tmp_dbl << std::endl;
00377             tmp_dbl = 0.0;
00378         }
00379
00380         printf( "%*s %*ld %*.*g %*.*g %*.*g %*.*g %*.*g %*.*g\n", type_width,
00381                 i == MBMAXTYPE ? edge_use_name : CN::EntityTypeName( i ), count_width, s.count, total_width, total_prec,
00382                 s.sum, val_width, precision, s.min, val_width, precision, s.sum / s.count, val_width, precision,
00383                 sqrt( s.sqr / s.count ), val_width, precision, s.max, val_width, precision, sqrt( tmp_dbl ) );
00384     }
00385     printf( "%*s %*lu\n", type_width, vertex_name, count_width, (unsigned long)stats.nodes );
00386
00387     puts( "" );
00388 }
00389
00390 bool parse_id_list( const char* string, std::set< int >& results )
00391 {
00392     bool okay   = true;
00393     char* mystr = strdup( string );
00394     for( const char* ptr = strtok( mystr, "," ); ptr; ptr = strtok( 0, "," ) )
00395     {
00396         char* endptr;
00397         long val = strtol( ptr, &endptr, 0 );
00398         if( endptr == ptr || val <= 0 )
00399         {
00400             std::cerr << "Not a valid id: " << ptr << std::endl;
00401             okay = false;
00402             break;
00403         }
00404
00405         long val2 = val;
00406         if( *endptr == '-' )
00407         {
00408             const char* sptr = endptr + 1;
00409             val2             = strtol( sptr, &endptr, 0 );
00410             if( endptr == sptr || val2 <= 0 )
00411             {
00412                 std::cerr << "Not a valid id: " << sptr << std::endl;
00413                 okay = false;
00414                 break;
00415             }
00416             if( val2 < val )
00417             {
00418                 std::cerr << "Invalid id range: " << ptr << std::endl;
00419                 okay = false;
00420                 break;
00421             }
00422         }
00423
00424         if( *endptr )
00425         {
00426             std::cerr << "Unexpected character: " << *endptr << std::endl;
00427             okay = false;
00428             break;
00429         }
00430
00431         for( ; val <= val2; ++val )
00432             if( !results.insert( (int)val ).second ) std::cerr << "Warning: duplicate Id: " << val << std::endl;
00433     }
00434
00435     free( mystr );
00436     return okay;
00437 }
00438
00439 bool make_opts_string( std::vector< std::string > options, std::string& opts )
00440 {
00441     opts.clear();
00442     if( options.empty() ) return true;
00443
00444     // choose a separator character
00445     std::vector< std::string >::const_iterator i;
00446     char separator             = '\0';
00447     const char* alt_separators = ";+,:\t\n";
00448     for( const char* sep_ptr = alt_separators; *sep_ptr; ++sep_ptr )
00449     {
00450         bool seen = false;
00451         for( i = options.begin(); i != options.end(); ++i )
00452             if( i->find( *sep_ptr, 0 ) != std::string::npos )
00453             {
00454                 seen = true;
00455                 break;
00456             }
00457         if( !seen )
00458         {
00459             separator = *sep_ptr;
00460             break;
00461         }
00462     }
00463     if( !separator )
00464     {
00465         std::cerr << "Error: cannot find separator character for options string" << std::endl;
00466         return false;
00467     }
00468     if( separator != ';' )
00469     {
00470         opts = ";";
00471         opts += separator;
00472     }
00473
00474     // concatenate options
00475     i = options.begin();
00476     opts += *i;
00477     for( ++i; i != options.end(); ++i )
00478     {
00479         opts += separator;
00480         opts += *i;
00481     }
00482
00483     return true;
00484 }
00485
00486 void list_formats( Interface* gMB )
00487 {
00488     const char iface_name[] = "ReaderWriterSet";
00489     ErrorCode err;
00490     ReaderWriterSet* set = 0;
00491     ReaderWriterSet::iterator i;
00492     std::ostream& str = std::cout;
00493
00494     // get ReaderWriterSet
00495     err = gMB->query_interface( set );
00496     if( err != MB_SUCCESS || !set )
00497     {
00498         std::cerr << "Internal error:  Interface \"" << iface_name << "\" not available.\n";
00499         exit( OTHER_ERROR );
00500     }
00501
00502     // get field width for format description
00503     size_t w = 0;
00504     for( i = set->begin(); i != set->end(); ++i )
00505         if( i->description().length() > w ) w = i->description().length();
00506
00507     // write table header
00508     str << "Format  " << std::setw( w ) << std::left << "Description"
00509         << "  Read  Write  File Name Suffixes\n"
00510         << "------  " << std::setw( w ) << std::setfill( '-' ) << "" << std::setfill( ' ' )
00511         << "  ----  -----  ------------------\n";
00512
00513     // write table data
00514     for( i = set->begin(); i != set->end(); ++i )
00515     {
00516         std::vector< std::string > ext;
00517         i->get_extensions( ext );
00518         str << std::setw( 6 ) << i->name() << "  " << std::setw( w ) << std::left << i->description() << "  "
00519             << ( i->have_reader() ? " yes" : "  no" ) << "  " << ( i->have_writer() ? "  yes" : "   no" ) << " ";
00520         for( std::vector< std::string >::iterator j = ext.begin(); j != ext.end(); ++j )
00521             str << " " << *j;
00522         str << std::endl;
00523     }
00524     str << std::endl;
00525
00526     gMB->release_interface( set );
00527     exit( 0 );
00528 }
00529
00530 static void usage_error( const char* name )
00531 {
00532     print_usage( name, std::cerr );
00533 #ifdef MOAB_HAVE_MPI
00534     MPI_Finalize();
00535 #endif
00536     exit( USAGE_ERROR );
00537 }
00538
00539 static void print_time( int clk_per_sec, const char* prefix, clock_t ticks, std::ostream& stream )
00540 {
00541     ticks *= clk_per_sec / 100;
00542     clock_t centi   = ticks % 100;
00543     clock_t seconds = ticks / 100;
00544     stream << prefix;
00545     if( seconds < 120 )
00546     {
00547         stream << ( ticks / 100 ) << "." << centi << "s" << std::endl;
00548     }
00549     else
00550     {
00551         clock_t minutes = ( seconds / 60 ) % 60;
00552         clock_t hours   = ( seconds / 3600 );
00553         seconds %= 60;
00554         if( hours ) stream << hours << "h";
00555         if( minutes ) stream << minutes << "m";
00556         if( seconds || centi ) stream << seconds << "." << centi << "s";
00557         stream << " (" << ( ticks / 100 ) << "." << centi << "s)" << std::endl;
00558     }
00559 }
00560
00561 clock_t usr_time, sys_time, abs_time;
00562
00563 #ifdef WIN32
00564
00565 void reset_times()
00566 {
00567     abs_time = clock();
00568 }
00569
00570 void write_times( std::ostream& stream )
00571 {
00572     clock_t abs_tm = clock();
00573     print_time( CLOCKS_PER_SEC, "  ", abs_tm - abs_time, stream );
00574     abs_time = abs_tm;
00575 }
00576
00577 #else
00578
00579 void reset_times()
00580 {
00581     tms timebuf;
00582     abs_time = times( &timebuf );
00583     usr_time = timebuf.tms_utime;
00584     sys_time = timebuf.tms_stime;
00585 }
00586
00587 void write_times( std::ostream& stream )
00588 {
00589     clock_t usr_tm, sys_tm, abs_tm;
00590     tms timebuf;
00591     abs_tm = times( &timebuf );
00592     usr_tm = timebuf.tms_utime;
00593     sys_tm = timebuf.tms_stime;
00594     print_time( sysconf( _SC_CLK_TCK ), "  real:   ", abs_tm - abs_time, stream );
00595     print_time( sysconf( _SC_CLK_TCK ), "  user:   ", usr_tm - usr_time, stream );
00596     print_time( sysconf( _SC_CLK_TCK ), "  system: ", sys_tm - sys_time, stream );
00597     abs_time = abs_tm;
00598     usr_time = usr_tm;
00599     sys_time = sys_tm;
00600 }
00601
00602 #endif
00603
00604 const char* geom_type_names[] = { "Vertex", "Curve", "Surface", "Volume" };
00605 const char* mesh_type_names[] = { "Dirichlet Set", "Neumann Set", "Material Set" };
00606 const char* mesh_type_tags[]  = { DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME, MATERIAL_SET_TAG_NAME };
00607
00608 int main( int argc, char* argv[] )
00609 {
00610     bool geom_owners     = false;
00611     bool mesh_owners     = false;
00612     bool just_list       = false;
00613     bool just_list_basic = false;
00614     bool tag_count       = false;
00615     std::vector< std::string > file_list;
00616     set_stats total_stats, file_stats;
00617     std::vector< TagCounts > total_counts, file_counts;
00618     ErrorCode rval;
00619
00620     Range range;
00621
00622     int i;
00623     std::vector< std::string > read_opts;
00624
00625     int proc_id = 0;
00626 #ifdef MOAB_HAVE_MPI
00627     MPI_Init( &argc, &argv );
00628     MPI_Comm_rank( MPI_COMM_WORLD, &proc_id );
00629 #endif
00630
00631     // scan arguments
00632     bool do_flag     = true;
00633     bool print_times = false;
00634     bool parallel = false, resolve_shared = false, exchange_ghosts = false;
00635     bool printed_usage = false;
00636     for( i = 1; i < argc; i++ )
00637     {
00638         if( !argv[i][0] ) usage_error( argv[0] );
00639
00640         if( do_flag && argv[i][0] == '-' )
00641         {
00642             switch( argv[i][1] )
00643             {
00644                     // do flag arguments:
00645                 case '-':
00646                     do_flag = false;
00647                     break;
00648                 case 'T':
00649                     print_times = true;
00650                     break;
00651                 case 'h':
00652                 case 'H':
00653                     print_usage( argv[0], std::cerr );
00654                     printed_usage = true;
00655                     break;
00656                 case 'f':
00657                     list_formats( &mb );
00658                     break;
00659                 case 'l':
00660                     if( strlen( argv[i] ) == 2 )
00661                         just_list_basic = true;
00662                     else if( strlen( argv[i] ) == 3 && argv[i][2] == 'l' )
00663                         just_list = true;
00664                     break;
00665 #ifdef MOAB_HAVE_MPI
00666                 case 'p':
00667                     parallel = true;
00668                     if( argv[i][2] == '1' || argv[i][2] == '2' ) resolve_shared = true;
00669                     if( argv[i][2] == '2' ) exchange_ghosts = true;
00670                     break;
00671 #endif
00672                 case 'g':
00673                     geom_owners = true;
00674                     break;
00675                 case 'm':
00676                     mesh_owners = true;
00677                     break;
00678                 case 't':
00679                     tag_count = true;
00680                     break;
00681                 default:
00682                     ++i;
00683                     switch( argv[i - 1][1] )
00684                     {
00685                         case 'O':
00686                             read_opts.push_back( argv[i] );
00687                             break;
00688                         default:
00689                             std::cerr << "Invalid option: " << argv[i] << std::endl;
00690                     }
00691             }
00692         }
00693         // do file names
00694         else
00695         {
00696             file_list.push_back( argv[i] );
00697         }
00698     }
00699
00700     // construct options string from individual options
00701     std::string read_options;
00702     if( parallel )
00703     {
00704         read_opts.push_back( "PARALLEL=READ_PART" );
00705         read_opts.push_back( "PARTITION=PARALLEL_PARTITION" );
00706     }
00707     if( resolve_shared ) read_opts.push_back( "PARALLEL_RESOLVE_SHARED_ENTS" );
00708     if( exchange_ghosts ) read_opts.push_back( "PARALLEL_GHOSTS=3.0.1" );
00709
00710     if( !make_opts_string( read_opts, read_options ) )
00711     {
00712 #ifdef MOAB_HAVE_MPI
00713         MPI_Finalize();
00714 #endif
00715         return USAGE_ERROR;
00716     }
00717
00718     if( file_list.empty() && !printed_usage ) print_usage( argv[0], std::cerr );
00719
00720     for( std::vector< std::string >::iterator f = file_list.begin(); f != file_list.end(); ++f )
00721     {
00722         reset_times();
00723         printf( "File %s:\n", f->c_str() );
00724         if( MB_SUCCESS != mb.load_file( f->c_str(), NULL, read_options.c_str() ) )
00725         {
00726             fprintf( stderr, "Error reading file: %s\n", f->c_str() );
00727             return 1;
00728         }
00729
00730         if( tag_count )
00731             rval = gather_tag_counts( 0, file_counts );
00732         else if( !just_list )
00733             rval = gather_set_stats( 0, file_stats );
00734         else
00735             rval = MB_SUCCESS;
00736
00737         if( MB_SUCCESS != rval )
00738         {
00739             fprintf( stderr, "Error processing mesh from file: %s\n", f->c_str() );
00740             return 1;
00741         }
00742
00743         if( tag_count )
00744         {
00745             add_tag_counts( total_counts, file_counts );
00746             print_tag_counts( file_counts );
00747             file_counts.clear();
00748         }
00749         else if( just_list )
00750         {
00751             mb.list_entities( 0, -1 );
00752         }
00753         else
00754         {
00755             total_stats.add( file_stats );
00756             print_stats( file_stats );
00757             file_stats.clear();
00758         }
00759
00760         if( geom_owners )
00761         {
00762             Range entities;
00763             Tag dim_tag = 0, id_tag = 0;
00764             rval = mb.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, dim_tag );
00765             if( MB_TAG_NOT_FOUND == rval )
00766             {
00767                 fprintf( stderr, "No geometry tag defined.\n" );
00768             }
00769             else if( MB_SUCCESS != rval )
00770             {
00771                 fprintf( stderr, "Error retreiving geometry tag.\n" );
00772                 return 2;
00773             }
00774
00775             id_tag = mb.globalId_tag();
00776
00777             if( dim_tag && id_tag )
00778             {
00779                 if( MB_SUCCESS != mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, 0, 1, entities ) )
00780                 {
00781                     fprintf( stderr, "Error retreiving geometry entitities.\n" );
00782                 }
00783             }
00784
00785             if( entities.empty() )
00786             {
00787                 fprintf( stderr, "No geometry entities defined in file.\n" );
00788             }
00789
00790             for( Range::iterator rit = entities.begin(); rit != entities.end(); ++rit )
00791             {
00792                 int id = 0, dim = 0;
00793                 if( MB_SUCCESS != mb.tag_get_data( dim_tag, &*rit, 1, &dim ) ||
00794                     MB_SUCCESS != mb.tag_get_data( id_tag, &*rit, 1, &id ) )
00795                 {
00796                     fprintf( stderr, "Error retreiving tag data for geometry entity.\n" );
00797                     continue;
00798                 }
00799
00800                 printf( "%s %d:\n", geom_type_names[dim], id );
00801                 if( tag_count )
00802                     rval = gather_tag_counts( *rit, file_counts );
00803                 else if( !just_list && !just_list_basic )
00804                     rval = gather_set_stats( *rit, file_stats );
00805
00806                 if( MB_SUCCESS != rval )
00807                     fprintf( stderr, "Error processing mesh from file: %s\n", f->c_str() );
00808                 else if( tag_count )
00809                     print_tag_counts( file_counts );
00810                 else if( just_list )
00811                     mb.list_entities( 0, 1 );
00812                 else if( just_list_basic )
00813                     mb.list_entities( 0, 0 );
00814                 else
00815                     print_stats( file_stats );
00816
00817                 file_stats.clear();
00818                 file_counts.clear();
00819             }
00820         }
00821
00822         if( mesh_owners )
00823         {
00824             for( int t = 0; t < 3; ++t )
00825             {
00826                 Range entities;
00827                 Tag tag = 0;
00828                 rval    = mb.tag_get_handle( mesh_type_tags[t], 1, MB_TYPE_INTEGER, tag );
00829                 if( MB_TAG_NOT_FOUND == rval )
00830                 {
00831                     continue;
00832                 }
00833                 else if( MB_SUCCESS != rval )
00834                 {
00835                     fprintf( stderr, "Error retreiving %s tag.\n", mesh_type_tags[t] );
00836                     return 2;
00837                 }
00838
00839                 if( MB_SUCCESS != mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, entities ) )
00840                 {
00841                     fprintf( stderr, "Error retreiving %s entitities.\n", mesh_type_names[t] );
00842                     continue;
00843                 }
00844
00845                 for( Range::iterator rit = entities.begin(); rit != entities.end(); ++rit )
00846                 {
00847                     int id = 0;
00848                     if( MB_SUCCESS != mb.tag_get_data( tag, &*rit, 1, &id ) )
00849                     {
00850                         fprintf( stderr, "Error retreiving tag data for %s entity.\n", mesh_type_names[t] );
00851                         continue;
00852                     }
00853
00854                     printf( "%s %d:\n", mesh_type_names[t], id );
00855                     if( tag_count )
00856                     {
00857                         rval = gather_tag_counts( *rit, file_counts );
00858                         if( MB_SUCCESS != rval )
00859                             fprintf( stderr, "Error processing tags from file: %s\n", f->c_str() );
00860                         else
00861                             print_tag_counts( file_counts );
00862                     }
00863                     else if( just_list )
00864                         mb.list_entities( 0, 1 );
00865                     else if( just_list_basic )
00866                         mb.list_entities( 0, 0 );
00867                     else if( !just_list && !just_list_basic )
00868                     {
00869                         rval = gather_set_stats( *rit, file_stats );
00870
00871                         if( rval != MB_SUCCESS )
00872                             fprintf( stderr, "Error processing mesh from file: %s\n", f->c_str() );
00873                         else
00874                             print_stats( file_stats );
00875                     }
00876                     file_stats.clear();
00877                     file_counts.clear();
00878                 }
00879             }
00880         }
00881
00882         if( print_times && !proc_id ) write_times( std::cout );
00883         mb.delete_mesh();
00884     }
00885
00886     if( file_list.size() > 1 && !just_list && !just_list_basic )
00887     {
00888         printf( "Total for all files:\n" );
00889         if( tag_count )
00890             print_tag_counts( total_counts );
00891         else
00892             print_stats( total_stats );
00893     }
00894 #ifdef MOAB_HAVE_MPI
00895     MPI_Finalize();
00896 #endif
00897     return 0;
00898 }
