stl_test.cpp
00001 #include "TestUtil.hpp"
00002 #include "moab/Core.hpp"
00003 #include "moab/Range.hpp"
00004 #include <cmath>
00005 #include <algorithm>
00006
00007 using namespace moab;
00008
00009 /* Input test file: test/sample.stl
00010  *
00011  * Example ASCII STL file from:
00012  *  http://people.sc.fsu.edu/~burkardt/data/stla/stla.html
00013  */
00014 #ifdef MESHDIR
00015 static const char sample[] = STRINGIFY( MESHDIR ) "/io/sample.stl";
00016 #else
00017 static const char sample[] = "sample.stl";
00018 #endif
00019
00020 // Use static keyword so that tmp_file can only be accessed within this file
00021 static const char* tmp_file = "test.stl";
00022
00023 void test_read_ascii();
00024 void test_write_ascii();
00025 void test_type_option();
00026 void test_detect_type();
00027 void test_endian_option();
00028 void test_big_endian();
00029 void test_little_endian();
00030 void test_detect_byte_order();
00031
00032 void read_file( Interface& moab, const char* input_file, const char* options = "" );
00033 void convert_file( const char* source_file, const char* dest_file, const char* options = "" );
00034 // check that the mesh constains the simple tetrahedron defined
00035 // in test/sample.stl
00036 void check_mesh_is_tet( Interface& moab );
00037
00038 int main()
00039 {
00040     int result = 0;
00041
00042     result += RUN_TEST( test_read_ascii );
00043     result += RUN_TEST( test_write_ascii );
00044     result += RUN_TEST( test_type_option );
00045     result += RUN_TEST( test_detect_type );
00046     result += RUN_TEST( test_endian_option );
00047     result += RUN_TEST( test_big_endian );
00048     result += RUN_TEST( test_little_endian );
00049     result += RUN_TEST( test_detect_byte_order );
00050
00051     remove( tmp_file );
00052     return result;
00053 }
00054
00055 ErrorCode read_file_( Interface& moab, const char* input_file, const char* options = "" )
00056 {
00057     ErrorCode rval = moab.load_file( input_file, 0, options );
00058     return rval;
00059 }
00060
00061 void read_file( Interface& moab, const char* input_file, const char* options )
00062 {
00063     ErrorCode rval = read_file_( moab, input_file, options );CHECK_ERR( rval );
00064 }
00065
00066 void convert_file( const char* input_file, const char* output_file, const char* options )
00067 {
00068     ErrorCode rval;
00069     Core moab;
00070
00071     rval = moab.load_file( input_file );CHECK_ERR( rval );
00072
00073     rval = moab.write_file( output_file, "STL", options );CHECK_ERR( rval );
00074 }
00075
00076 void test_read_ascii()
00077 {
00078     Core moab;
00079     read_file( moab, sample, "ASCII" );
00080     check_mesh_is_tet( moab );
00081 }
00082
00083 void test_write_ascii()
00084 {
00085     convert_file( sample, tmp_file, "ASCII" );
00086     Core moab;
00087     read_file( moab, tmp_file, "ASCII" );
00088     remove( tmp_file );
00089     check_mesh_is_tet( moab );
00090 }
00091
00092 void test_type_option()
00093 {
00094     ErrorCode rval;
00095     Core moab;
00096
00097     rval = read_file_( moab, sample, "BINARY" );
00098     CHECK( MB_SUCCESS != rval );
00099
00100     convert_file( sample, tmp_file, "BINARY" );
00101     rval = read_file_( moab, tmp_file, "ASCII" );
00102     CHECK( MB_SUCCESS != rval );
00103
00104     remove( tmp_file );
00105 }
00106
00107 void test_detect_type()
00108 {
00109     Core moab;
00110
00111     read_file( moab, sample );
00112
00113     convert_file( sample, tmp_file, "BINARY" );
00114     read_file_( moab, tmp_file );
00115
00116     remove( tmp_file );
00117 }
00118
00119 void test_endian_option()
00120 {
00121     ErrorCode rval;
00122     Core moab;
00123
00124     convert_file( sample, tmp_file, "BINARY;BIG_ENDIAN" );
00125     rval = read_file_( moab, tmp_file, "BINARY;LITTLE_ENDIAN" );
00126     CHECK( MB_SUCCESS != rval );
00127
00128     convert_file( sample, tmp_file, "BINARY;LITTLE_ENDIAN" );
00129     rval = read_file_( moab, tmp_file, "BINARY;BIG_ENDIAN" );
00130     CHECK( MB_SUCCESS != rval );
00131
00132     remove( tmp_file );
00133 }
00134
00135 void test_big_endian()
00136 {
00137     Core moab;
00138     convert_file( sample, tmp_file, "BINARY;BIG_ENDIAN" );
00139     read_file( moab, tmp_file, "BINARY;BIG_ENDIAN" );
00140     check_mesh_is_tet( moab );
00141     remove( tmp_file );
00142 }
00143
00144 void test_little_endian()
00145 {
00146     Core moab;
00147     convert_file( sample, tmp_file, "BINARY;LITTLE_ENDIAN" );
00148     read_file( moab, tmp_file, "BINARY;LITTLE_ENDIAN" );
00149     check_mesh_is_tet( moab );
00150     remove( tmp_file );
00151 }
00152
00153 void test_detect_byte_order()
00154 {
00155     Core moab;
00156
00157     convert_file( sample, tmp_file, "BINARY;LITTLE_ENDIAN" );
00158     read_file( moab, tmp_file, "BINARY" );
00159
00160     convert_file( sample, tmp_file, "BINARY;BIG_ENDIAN" );
00161     read_file( moab, tmp_file, "BINARY" );
00162
00163     remove( tmp_file );
00164 }
00165
00166 void check_mesh_is_tet( Interface& moab )
00167 {
00168     ErrorCode rval;
00169     Range verts, tris, other;
00170     rval = moab.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval );
00171     rval = moab.get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( rval );
00172     rval = moab.get_entities_by_handle( 0, other );CHECK_ERR( rval );
00173
00174     CHECK_EQUAL( 4, (int)verts.size() );
00175     CHECK_EQUAL( 4, (int)tris.size() );
00176     other = subtract( other, verts );
00177     other = subtract( other, tris );
00178     CHECK( other.all_of_type( MBENTITYSET ) );
00179
00180     const double expt_coords[4][3] = { { 0, 0, 0 }, { 1, 0, 0 }, { 0, 1, 0 }, { 0, 0, 1 } };
00181     EntityHandle vert_handles[4]   = { 0, 0, 0, 0 };
00182     for( Range::iterator i = verts.begin(); i != verts.end(); ++i )
00183     {
00184         double coords[3];
00185         rval = moab.get_coords( &*i, 1, coords );CHECK_ERR( rval );
00186
00187         bool found = false;
00188         for( int j = 0; j < 4; ++j )
00189         {
00190             double ds = 0;
00191             for( int d = 0; d < 3; ++d )
00192             {
00193                 double dl = expt_coords[j][d] - coords[d];
00194                 ds += dl * dl;
00195             }
00196
00197             if( ds < 1e-6 )
00198             {
00199                 CHECK_EQUAL( (EntityHandle)0, vert_handles[j] );
00200                 vert_handles[j] = *i;
00201                 found           = true;
00202                 break;
00203             }
00204         }
00205         CHECK( found );
00206     }
00207
00208     const int expt_conn[4][3]   = { { 0, 1, 3 }, { 0, 2, 1 }, { 0, 3, 2 }, { 1, 2, 3 } };
00209     EntityHandle tri_handles[4] = { 0, 0, 0, 0 };
00210     for( Range::iterator i = tris.begin(); i != tris.end(); ++i )
00211     {
00212         const EntityHandle* conn = 0;
00213         int len                  = 0;
00214         rval                     = moab.get_connectivity( *i, conn, len );CHECK_ERR( rval );
00215         CHECK_EQUAL( 3, len );
00216
00217         int conn_idx[3] = { static_cast< int >( std::find( vert_handles, vert_handles + 4, conn[0] ) - vert_handles ),
00218                             static_cast< int >( std::find( vert_handles, vert_handles + 4, conn[1] ) - vert_handles ),
00219                             static_cast< int >( std::find( vert_handles, vert_handles + 4, conn[2] ) - vert_handles ) };
00220         CHECK( conn_idx[0] != 4 );
00221         CHECK( conn_idx[1] != 4 );
00222         CHECK( conn_idx[2] != 4 );
00223
00224         bool found = false;
00225         for( int j = 0; j < 4; ++j )
00226         {
00227             int k = std::find( expt_conn[j], expt_conn[j] + 3, conn_idx[0] ) - expt_conn[j];
00228             if( k == 3 ) continue;
00229
00230             if( expt_conn[j][( k + 1 ) % 3] == conn_idx[1] && expt_conn[j][( k + 2 ) % 3] == conn_idx[2] )
00231             {
00232                 CHECK_EQUAL( (EntityHandle)0, tri_handles[j] );
00233                 tri_handles[j] = *i;
00234                 found          = true;
00235                 break;
00236             }
00237         }
00238         CHECK( found );
00239     }
00240 }
