MBMesquite::DimConst< D > Struct Template Reference
Dimension-specific constants. More...
#include <TMPCommon.hpp>
Detailed Description
template<unsigned D>
struct MBMesquite::DimConst< D >
Provide constants that depend on a template dimension parameter. For use in implementing targe metrics for which the target metric implementation is templatized on the dimension of of the matrix.
In optimized code these should reduce to literal constants.
Definition at line 158 of file TMPCommon.hpp.
The documentation for this struct was generated from the following file:
