QuadMetricVals Struct Reference
#include <verdict.h>
Public Attributes
double edge_ratio
double max_edge_ratio
double aspect_ratio
double radius_ratio
double med_aspect_frobenius
double max_aspect_frobenius
double skew
double taper
double warpage
double area
double stretch
double minimum_angle
double maximum_angle
double oddy
double condition
double jacobian
double scaled_jacobian
double shear
double shape
double relative_size_squared
double shape_and_size
double shear_and_size
double distortion
Detailed Description
QuadMetricVals is a struct used to return calculated metrics when calling the function v_quad_quality(...)
The following is an example of how this struct is used with Verdict.
Example:
    QuadMetricVals quad_metrics = {0};
    unsigned long metrics_flag = 0;
    metrics_flag += V_QUAD_SHAPE;
    metrics_flag += V_QUAD_DISTORTION;
    metrics_flag += V_QUAD_AREA;
    double quad_nodes[4][3];
    get_quad_nodes( quad_nodes );  //some user-defined function to load
                                   //xyz coordinate info. into array
    v_quad_quality( 4, quad_nodes, metrics_flag, quad_metrics );
    double my_shape      = quad_metrics.shape;
    double my_distortion = quad_metrics.distortion;
    double my_area       = quad_metrics.area;
Definition at line 164 of file verdict.h.
Member Data Documentation
See also:
v_quad_area function
Definition at line 185 of file verdict.h.
Referenced by moab::VerdictWrapper::all_quality_measures(), and v_quad_quality().
See also:
v_quad_aspect_ratio function
Definition at line 171 of file verdict.h.
See also:
v_quad_condition function
Definition at line 195 of file verdict.h.
See also:
v_quad_distortion function
Definition at line 211 of file verdict.h.
See also:
v_quad_edge_ratio function
Definition at line 167 of file verdict.h.
See also:
v_quad_jacobian function
Definition at line 197 of file verdict.h.
See also:
v_quad_largest_angle function
Definition at line 191 of file verdict.h.
See also:
v_quad_smallest_angle function
Definition at line 189 of file verdict.h.
See also:
v_quad_oddy function
Definition at line 193 of file verdict.h.
See also:
v_quad_radius_ratio function
Definition at line 173 of file verdict.h.
See also:
v_quad_shape function
Definition at line 203 of file verdict.h.
See also:
v_quad_shear function
Definition at line 201 of file verdict.h.
See also:
v_quad_skew function
Definition at line 179 of file verdict.h.
See also:
v_quad_stretch function
Definition at line 187 of file verdict.h.
See also:
v_quad_taper function
Definition at line 181 of file verdict.h.
See also:
v_quad_warpage function
Definition at line 183 of file verdict.h.
List of all members.
The documentation for this struct was generated from the following file:
