iBase_EntityArrIterator_Private Struct Reference
#include <MBIter.hpp>
+ Inheritance diagram for iBase_EntityArrIterator_Private:
Classes
class  IsType
Public Member Functions
 iBase_EntityArrIterator_Private (iBase_EntityType type, iMesh_EntityTopology topology, EntityHandle set, int array_sz, bool recursive=false)
virtual ~iBase_EntityArrIterator_Private ()
int array_size () const
virtual ErrorCode step (int num_steps, bool &at_end)=0
virtual void get_entities (Core *mb, EntityHandle *array, int &count_out)=0
virtual ErrorCode reset (Interface *mb)=0
void remove_type (std::vector< EntityHandle > &vect, EntityType t)
void remove_type (Range &range, EntityType t)
Protected Attributes
iBase_EntityType entType
iMesh_EntityTopology entTopo
EntityHandle entSet
int arrSize
bool isRecursive
Detailed Description
Definition at line 11 of file MBIter.hpp.
iBase_EntityArrIterator_Private::iBase_EntityArrIterator_Private ( iBase_EntityType  type,
EntityHandle  set,
int  array_sz,
bool  recursive = false
) [inline]
Definition at line 21 of file MBIter.hpp.
        : entType( type ), entTopo( topology ), entSet( set ), arrSize( array_sz ), isRecursive( recursive )
Definition at line 30 of file MBIter.hpp.
Member Function Documentation
Definition at line 32 of file MBIter.hpp.
References arrSize.
Referenced by iMesh_getNextEntArrIter().
        return arrSize;
virtual void iBase_EntityArrIterator_Private::get_entities ( Core *  mb,
EntityHandle *  array,
int &  count_out
) [pure virtual]
Implemented in MBIter< Container >.
void iBase_EntityArrIterator_Private::remove_type ( std::vector< EntityHandle > &  vect,
EntityType  t
) [inline]
Definition at line 57 of file MBIter.hpp.
Referenced by MBIter< Container >::reset().
        vect.erase( std::remove_if( vect.begin(), vect.end(), IsType( t ) ), vect.end() );
void iBase_EntityArrIterator_Private::remove_type ( Range &  range,
EntityType  t
) [inline]
Definition at line 62 of file MBIter.hpp.
        std::pair< Range::iterator, Range::iterator > p = range.equal_range( t );
        range.erase( p.first, p.second );
virtual ErrorCode iBase_EntityArrIterator_Private::reset ( Interface *  mb) [pure virtual]
Referenced by iMesh_resetEntArrIter().
virtual ErrorCode iBase_EntityArrIterator_Private::step ( int  num_steps,
bool &  at_end
) [pure virtual]
Referenced by iMesh_stepEntArrIter().
Member Data Documentation
Definition at line 17 of file MBIter.hpp.
Referenced by array_size(), and MBIter< Container >::get_entities().
EntityHandle iBase_EntityArrIterator_Private::entSet [protected]
Definition at line 16 of file MBIter.hpp.
Definition at line 18 of file MBIter.hpp.
List of all members.
The documentation for this struct was generated from the following file:
