moab::AdaptiveKDTree::Plane Struct Reference
Split plane. More...
#include <AdaptiveKDTree.hpp>
Public Member Functions
bool left_side (const double point[3])
bool right_side (const double point[3])
double distance (const double point[3]) const
Public Attributes
double coord
 Location of plane as coordinate on normal axis.
int norm
 The principal axis that is the normal of the plane;.
Detailed Description
Split plane.
Definition at line 156 of file AdaptiveKDTree.hpp.
Member Function Documentation
double moab::AdaptiveKDTree::Plane::distance ( const double  point[3]) const [inline]
return distance from point to plane
Definition at line 172 of file AdaptiveKDTree.hpp.
References coord, and norm.
            return fabs( point[norm] - coord );
bool moab::AdaptiveKDTree::Plane::left_side ( const double  point[3]) [inline]
return true if point is below/to the left of the split plane
Definition at line 162 of file AdaptiveKDTree.hpp.
            return point[norm] < coord;
bool moab::AdaptiveKDTree::Plane::right_side ( const double  point[3]) [inline]
return true if point is above/to the right of the split plane
Definition at line 167 of file AdaptiveKDTree.hpp.
Referenced by moab::AdaptiveKDTree::find_close_triangle().
            return point[norm] > coord;
Member Data Documentation
List of all members.
The documentation for this struct was generated from the following file:
