moab::BSPTreePoly::EdgeUse Struct Reference
+ Collaboration diagram for moab::BSPTreePoly::EdgeUse:
Public Member Functions
 EdgeUse (Edge *edge)
 EdgeUse (Edge *edge, Face *face)
 ~EdgeUse ()
BSPTreePoly::Vertexstart () const
BSPTreePoly::Vertexend () const
int sense () const
void insert_after (BSPTreePoly::EdgeUse *prev)
void insert_before (BSPTreePoly::EdgeUse *next)
Public Attributes
BSPTreePoly::EdgeUseprevPtr
BSPTreePoly::EdgeUsenextPtr
BSPTreePoly::EdgeedgePtr
BSPTreePoly::FacefacePtr
Detailed Description
Definition at line 46 of file BSPTreePoly.cpp.
Definition at line 264 of file BSPTreePoly.cpp.
: prevPtr( 0 ), nextPtr( 0 ), edgePtr( edge ), facePtr( 0 ) {}
Definition at line 266 of file BSPTreePoly.cpp.
References nextPtr, prevPtr, and moab::BSPTreePoly::Face::usePtr.
        : edgePtr( edge ), facePtr( face )
    assert( !face->usePtr );
    face->usePtr = prevPtr = nextPtr = this;
    if( !face->usePtr )
        return;
    nextPtr = face->usePtr;
    prevPtr = nextPtr->prevPtr;
    assert( prevPtr->nextPtr == nextPtr );
    nextPtr->prevPtr = this;
    prevPtr->nextPtr = this;
Definition at line 312 of file BSPTreePoly.cpp.
    if( facePtr->usePtr == this ) facePtr->usePtr = ( nextPtr == this ) ? 0 : nextPtr;
    if( edgePtr->forwardPtr == this ) edgePtr->forwardPtr = 0;
    if( edgePtr->reversePtr == this ) edgePtr->reversePtr = 0;
    if( !edgePtr->forwardPtr && !edgePtr->reversePtr ) delete edgePtr;
    nextPtr->prevPtr = prevPtr;
    prevPtr->nextPtr = nextPtr;
    nextPtr = prevPtr = 0;
Member Function Documentation
Definition at line 284 of file BSPTreePoly.cpp.
References end(), facePtr, nextPtr, and prevPtr.
Referenced by moab::BSPTreePoly::cut_polyhedron(), moab::BSPTreePoly::set(), and moab::split_edge().
    // shouldn't already be in a face
    assert( !facePtr );
    // adjacent edges should share vertices
    assert( start() == prev->end() );
    facePtr          = prev->facePtr;
    nextPtr          = prev->nextPtr;
    prevPtr          = prev;
Definition at line 298 of file BSPTreePoly.cpp.
References facePtr, nextPtr, prevPtr, and start().
Referenced by moab::split_edge().
    assert( !facePtr );
    assert( end() == next->start() );
    facePtr          = next->facePtr;
    prevPtr          = next->prevPtr;
    nextPtr          = next;
Definition at line 326 of file BSPTreePoly.cpp.
        return 1;
    else if( edgePtr->reversePtr == this )
        return -1;
    else
        return 0;
Definition at line 336 of file BSPTreePoly.cpp.
Referenced by moab::BSPTreePoly::cut_polyhedron(), insert_before(), moab::BSPTreePoly::is_valid(), and moab::split_face().
        return edgePtr->start();
        return edgePtr->end();
    else
        return 0;
Member Data Documentation
List of all members.
The documentation for this struct was generated from the following file:
