moab::BSPTreePoly::VertexUse Struct Reference
+ Collaboration diagram for moab::BSPTreePoly::VertexUse:
Public Member Functions
 VertexUse (Edge *edge, Vertex *vtx)
 ~VertexUse ()
void set_vertex (BSPTreePoly::Vertex *&vtx_ptr)
Public Attributes
BSPTreePoly::VertexUsenextPtr
BSPTreePoly::VertexUseprevPtr
BSPTreePoly::VertexvtxPtr
BSPTreePoly::EdgeedgePtr
Detailed Description
Definition at line 34 of file BSPTreePoly.cpp.
Definition at line 203 of file BSPTreePoly.cpp.
References nextPtr, prevPtr, and moab::BSPTreePoly::Vertex::usePtr.
        : vtxPtr( vtx ), edgePtr( edge )
    if( !vtx->usePtr )
        vtx->usePtr = prevPtr = nextPtr = this;
        return;
    nextPtr = vtx->usePtr;
    prevPtr = nextPtr->prevPtr;
    assert( prevPtr->nextPtr == nextPtr );
    nextPtr->prevPtr = this;
    prevPtr->nextPtr = this;
Definition at line 218 of file BSPTreePoly.cpp.
    if( nextPtr == this )
        assert( prevPtr == this );
        assert( vtxPtr->usePtr == this );
        vtxPtr->usePtr = 0;
        delete vtxPtr;
    else if( vtxPtr->usePtr == this )
        vtxPtr->usePtr = nextPtr;
    nextPtr->prevPtr = prevPtr;
    prevPtr->nextPtr = nextPtr;
    nextPtr = prevPtr = 0;
Member Function Documentation
Definition at line 235 of file BSPTreePoly.cpp.
Referenced by moab::split_edge().
    if( vtxPtr )
        if( nextPtr == prevPtr )
            assert( nextPtr == this );
            vtxPtr->usePtr = 0;
            delete vtx;
            vtx = 0;
        else
            if( vtxPtr->usePtr == this ) vtxPtr->usePtr = nextPtr;
    if( vtx )
        vtxPtr                  = vtx;
        nextPtr                 = vtxPtr->usePtr->nextPtr;
        prevPtr                 = vtxPtr->usePtr;
        vtxPtr->usePtr->nextPtr = this;
Member Data Documentation
List of all members.
The documentation for this struct was generated from the following file:
