moab::BSPTree::Plane Struct Reference
struct to store a plane More...
#include <BSPTree.hpp>
Public Member Functions
 Plane ()
 Plane (const double n[3], double d)
 Plane (double a, double b, double c, double d)
 Plane (Axis normal, double point_on_axis)
double signed_distance (const double point[3]) const
bool below (const double point[3]) const
bool above (const double point[3]) const
double distance (const double point[3]) const
void flip ()
void set (const double normal[3], const double point[3])
void set (const double pt1[3], const double pt2[3], const double pt3[3])
void set (double i, double j, double k, double cff)
void set (Axis normal, double point_on_axis)
Public Attributes
double norm [3]
 Unit normal of plane.
double coeff
 norm[0]*x + norm[1]*y + norm[2]*z + coeff = 0
Detailed Description
If plane is defined as Ax+By+Cz+D=0, then norm={A,B,C} and coeff=-D.
Definition at line 81 of file BSPTree.hpp.
Definition at line 83 of file BSPTree.hpp.
Referenced by set().
: coeff( 0.0 ) {}
moab::BSPTree::Plane::Plane ( const double  n[3],
double  d
) [inline]
Definition at line 84 of file BSPTree.hpp.
References norm.
                                             : coeff( d )
            norm[0] = n[0];
            norm[1] = n[1];
            norm[2] = n[2];
moab::BSPTree::Plane::Plane ( double  a,
double  b,
double  c,
double  d
) [inline]
a x + b y + c z + d = 0
Definition at line 91 of file BSPTree.hpp.
References norm.
                                                        : coeff( d )
            norm[0] = a;
            norm[1] = b;
            norm[2] = c;
moab::BSPTree::Plane::Plane ( Axis  normal,
) [inline]
Create Y = 1 plane by doing Plane( Y, 1.0 );
Definition at line 98 of file BSPTree.hpp.
References norm.
                                                   : coeff( -point_on_axis )
            norm[0] = norm[1] = norm[2] = 0;
            norm[normal]                = 1.0;
Member Function Documentation
bool moab::BSPTree::Plane::above ( const double  point[3]) const [inline]
return true if point is above the plane
Definition at line 124 of file BSPTree.hpp.
References signed_distance().
Referenced by moab::BSPTreeBoxIter::intersects(), moab::BSPTree::leaf_containing_point(), and moab::BSPTreeBoxIter::side_above_plane().
            return signed_distance( point ) >= 0.0;
bool moab::BSPTree::Plane::below ( const double  point[3]) const [inline]
return true if point is below the plane
Definition at line 118 of file BSPTree.hpp.
            return signed_distance( point ) <= 0.0;
double moab::BSPTree::Plane::distance ( const double  point[3]) const [inline]
Definition at line 129 of file BSPTree.hpp.
Referenced by moab::BSPTreeBoxIter::side_on_plane().
            return fabs( signed_distance( point ) );
void moab::BSPTree::Plane::set ( const double  normal[3],
) [inline]
Definition at line 143 of file BSPTree.hpp.
References moab::dot(), and Plane().
            const double dot = normal[0] * point[0] + normal[1] * point[1] + normal[2] * point[2];
            *this            = Plane( normal, -dot );
void moab::BSPTree::Plane::set ( const double  pt1[3],
const double  pt3[3]
Definition at line 84 of file BSPTree.cpp.
    const double v1[]  = { pt2[0] - pt1[0], pt2[1] - pt1[1], pt2[2] - pt1[2] };
    const double v2[]  = { pt3[0] - pt1[0], pt3[1] - pt1[1], pt3[2] - pt1[2] };
    const double nrm[] = { v1[1] * v2[2] - v1[2] * v2[1], v1[2] * v2[0] - v1[0] * v2[2],
                           v1[0] * v2[1] - v1[1] * v2[0] };
    set( nrm, pt1 );
void moab::BSPTree::Plane::set ( double  i,
double  j,
double  k,
double  cff
) [inline]
Definition at line 151 of file BSPTree.hpp.
References Plane().
            *this = Plane( i, j, k, cff );
void moab::BSPTree::Plane::set ( Axis  normal,
) [inline]
Create Y = 1 plane by doing set( Y, 1.0 );
Definition at line 157 of file BSPTree.hpp.
References coeff, and norm.
            coeff   = -point_on_axis;
            norm[normal]                = 1.0;
double moab::BSPTree::Plane::signed_distance ( const double  point[3]) const [inline]
Signed distance from point to plane: absolute value is distance from point to plane positive if 'above' plane, negative if 'below' Note: assumes unit-length normal.
Definition at line 112 of file BSPTree.hpp.
Referenced by above(), below(), distance(), moab::BSPTreeBoxIter::get_neighbors(), and moab::BSPTreeBoxIter::splits().
            return point[0] * norm[0] + point[1] * norm[1] + point[2] * norm[2] + coeff;
Member Data Documentation
Definition at line 105 of file BSPTree.hpp.
Referenced by moab::BSPTreeIter::calculate_polyhedron(), flip(), moab::plane_cut_edge(), set(), moab::BSPTree::set_split_plane(), and signed_distance().
List of all members.
The documentation for this struct was generated from the following files:
