moab::StatData::Stat< T > Struct Template Reference
+ Inheritance diagram for moab::StatData::Stat< T >:
+ Collaboration diagram for moab::StatData::Stat< T >:
Public Member Functions
 Stat ()
void accum (T v)
Public Attributes
T min
T max
double sum
double sqr
Detailed Description
template<typename T>
struct moab::StatData::Stat< T >
Definition at line 1765 of file OrientedBoxTreeTool.cpp.
moab::StatData::Stat< T >::Stat ( ) [inline]
Definition at line 1769 of file OrientedBoxTreeTool.cpp.
               : sum( 0.0 ), sqr( 0.0 )
            std::numeric_limits< T > lim;
            min = lim.max();
            if( lim.is_integer )
                max = lim.min();
            else
                max = -lim.max();
Member Function Documentation
void moab::StatData::Stat< T >::accum ( T  v) [inline]
Definition at line 1778 of file OrientedBoxTreeTool.cpp.
Referenced by moab::OrientedBoxTreeTool::recursive_stats().
            if( v < min ) min = v;
            if( v > max ) max = v;
            sum += v;
            sqr += (double)v * v;
Member Data Documentation
T moab::StatData::Stat< T >::max
Definition at line 1767 of file OrientedBoxTreeTool.cpp.
Referenced by moab::OrientedBoxTreeTool::stats().
T moab::StatData::Stat< T >::min
double moab::StatData::Stat< T >::sqr
Definition at line 1768 of file OrientedBoxTreeTool.cpp.
double moab::StatData::Stat< T >::sum
List of all members.
The documentation for this struct was generated from the following file:
