moab::VtkElemType Struct Reference
Structure defining relation between MOAB and VTK element types. VTK had different types for quadratic than linear elements, so a tuple of the MOAB type and number of elements maps to a VTK type. More...
#include <VtkUtil.hpp>
+ Collaboration diagram for moab::VtkElemType:
Public Attributes
const char * name
 String name for use in error messages.
unsigned vtk_type
 VTK integer type.
EntityType mb_type
 MOAB type.
unsigned num_nodes
 Number of nodes (0 for polygon)
const unsigned * node_order
 VTK element node ordering, indexed by < the VTK node position and containing < the corresponding MOAB node position. < NOTE: This field is NULL if MOAB and VTK < ordering is the same!
Detailed Description
Definition at line 28 of file VtkUtil.hpp.
Member Data Documentation
MOAB type.
Definition at line 32 of file VtkUtil.hpp.
Referenced by moab::ReadVtk::vtk_read_unstructured_grid().
Definition at line 30 of file VtkUtil.hpp.
Definition at line 34 of file VtkUtil.hpp.
Referenced by moab::ReadVtk::vtk_read_unstructured_grid(), and moab::WriteVtk::write_elems().
Definition at line 33 of file VtkUtil.hpp.
VTK integer type.
Definition at line 31 of file VtkUtil.hpp.
Referenced by moab::WriteVtk::write_elems().
List of all members.
The documentation for this struct was generated from the following file:
