moab::WriteHDF5::TagDesc Struct Reference
Tag to write to file. More...
#include <WriteHDF5.hpp>
+ Collaboration diagram for moab::WriteHDF5::TagDesc:
Public Member Functions
bool have_dense (const ExportType &type) const
bool operator< (const TagDesc &) const
Public Attributes
Tag tag_id
 The tag handle.
wid_t sparse_offset
 The offset at which to begin writting this processor's data. Always zero except for parallel IO.
wid_t var_data_offset
 For variable-length tags, a second offset for the tag data table, separate from the offset used for the ID and Index tables. Always zero except for parallel IO.
bool write_sparse
 Write sparse tag data (for serial, is always equal to !range.empty())
unsigned long max_num_ents
 If doing parallel IO, largest number, over all processes, of entities for which to write tag data. Zero if unused.
unsigned long max_num_vals
 For variable-length tags during parallel IO: the largest number of tag values to be written on by any process, used to calculate the total number of collective writes that all processes must do. Zero for fixed-length tags or if not doing parallel IO.
std::vector< ExportTypedense_list
 List of entity groups for which to write tag data in dense format.
Detailed Description
Definition at line 153 of file WriteHDF5.hpp.
Member Function Documentation
bool moab::WriteHDF5::TagDesc::have_dense ( const ExportType type) const [inline]
Definition at line 179 of file WriteHDF5.hpp.
References dense_list, and moab::WriteHDF5::find().
Referenced by moab::WriteHDF5::get_sparse_tagged_entities().
            return std::find( dense_list.begin(), dense_list.end(), type ) != dense_list.end();
bool moab::WriteHDF5::TagDesc::operator< ( const TagDesc ) const
Member Data Documentation
Definition at line 177 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5::create_tag(), have_dense(), and moab::WriteHDF5::write_tag().
Definition at line 168 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data(), moab::WriteHDF5::gather_tags(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_sparse_tag(), and moab::WriteHDF5::write_var_len_indices().
Definition at line 173 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data(), moab::WriteHDF5::gather_tags(), and moab::WriteHDF5::write_var_len_data().
Definition at line 163 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data(), moab::WriteHDF5::gather_tags(), moab::WriteHDF5::write_var_len_data(), and moab::WriteHDF5::write_var_len_indices().
Definition at line 165 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data(), moab::WriteHDF5::gather_tags(), and moab::WriteHDF5::write_tag().
List of all members.
The documentation for this struct was generated from the following file:
