set_stats Struct Reference
+ Collaboration diagram for set_stats:
Public Member Functions
void add (const set_stats &other)
void clear ()
Public Attributes
stat_set stats [MBMAXTYPE]
stat_set edge_uses
size_t nodes
Detailed Description
Definition at line 103 of file size.cpp.
Member Function Documentation
void set_stats::add ( const set_stats other) [inline]
Definition at line 109 of file size.cpp.
References edge_uses, MBMAXTYPE, and stats.
Referenced by main().
        for( int i = 0; i < MBMAXTYPE; ++i )
            stats[i].add( other.stats[i] );
        edge_uses.add( other.edge_uses );
void set_stats::clear ( ) [inline]
Definition at line 116 of file size.cpp.
References MBMAXTYPE.
            stats[i].clear();
        edge_uses.clear();
Member Data Documentation
Definition at line 106 of file size.cpp.
Referenced by add(), gather_set_stats(), and print_stats().
Definition at line 107 of file size.cpp.
Referenced by gather_set_stats(), and print_stats().
Definition at line 105 of file size.cpp.
List of all members.
The documentation for this struct was generated from the following file:
