smoab::detail::internal::SubsetArray Struct Reference
#include <LinearCellConnectivity.h>
+ Collaboration diagram for smoab::detail::internal::SubsetArray:
Public Types
typedef std::vector
< EntityHandle >
::const_iterator
const_iterator
typedef std::vector
< EntityHandle >::iterator
iterator
Public Member Functions
 SubsetArray (EntityHandle *realConn, int numCells, int currentVertsPerCell, int newVertsPerCell)
const_iterator begin () const
iterator begin ()
const_iterator end () const
iterator end ()
Private Attributes
std::vector< EntityHandleArray
Detailed Description
Definition at line 19 of file LinearCellConnectivity.h.
Member Typedef Documentation
smoab::detail::internal::SubsetArray::SubsetArray ( EntityHandle realConn,
int  numCells,
int  newVertsPerCell
) [inline]
Definition at line 21 of file LinearCellConnectivity.h.
References Array, and size.
        : Array()
                const int size = numCells * newVertsPerCell;
                this->Array.reserve( size );
                if( currentVertsPerCell == newVertsPerCell )
                    std::copy( realConn, realConn + size, std::back_inserter( this->Array ) );
                else
                    //skip copy only the first N points which we want
                    //since moab stores linear points first per cell
                    EntityHandle* pos = realConn;
                    for( int i = 0; i < numCells; ++i )
                        std::copy( pos, pos + newVertsPerCell, std::back_inserter( this->Array ) );
                        pos += currentVertsPerCell;
Member Function Documentation
Definition at line 44 of file LinearCellConnectivity.h.
References Array.
                return this->Array.begin();
Definition at line 48 of file LinearCellConnectivity.h.
References Array.
Definition at line 53 of file LinearCellConnectivity.h.
References Array.
                return this->Array.end();
Definition at line 57 of file LinearCellConnectivity.h.
References Array.
Member Data Documentation
Definition at line 63 of file LinearCellConnectivity.h.
Referenced by begin(), end(), and SubsetArray().
List of all members.
The documentation for this struct was generated from the following file:
