structured3.cpp File Reference
#include "moab/Core.hpp"
#include "moab/ParallelComm.hpp"
#include "moab/ScdInterface.hpp"
#include "moab/HomXform.hpp"
#include "moab/ProgOptions.hpp"
#include "MBTagConventions.hpp"
#include "TestUtil.hpp"
#include <string>
#include <iomanip>
#include <iostream>
#include <cassert>
+ Include dependency graph for structured3.cpp:
Functions
void create_parallel_mesh ()
int main (int argc, char *argv[])
Variables
int NC
const int ITERS = 50
Function Documentation
Definition at line 42 of file structured3.cpp.
References moab::ScdBox::box_set(), CHECK_ERR, moab::ScdInterface::construct_box(), ErrorCode, moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::exchange_tags(), moab::ScdParData::gDims, moab::Core::get_last_error(), moab::Core::globalId_tag(), ITERS, MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_DOUBLE, mbint, MPI_COMM_WORLD, NC, moab::ScdParData::partMethod, moab::ScdParData::pComm, moab::Interface::query_interface(), moab::ParallelComm::rank(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::size(), moab::ScdParData::SQIJK, and moab::Core::tag_get_handle().
Referenced by main().
    Core mbint;
    ParallelComm pc( &mbint, MPI_COMM_WORLD );
    ScdInterface* scdi;
    ErrorCode rval = mbint.query_interface( scdi );CHECK_ERR( rval );
    // pc.set_debug_verbosity(2);
    // create a structured mesh in parallel
    ScdBox* new_box;
    ScdParData par_data;
    par_data.pComm    = &pc;
    par_data.gDims[0] = par_data.gDims[1] = par_data.gDims[2] = 0;
    par_data.gDims[3] = par_data.gDims[4] = par_data.gDims[5] = NC;
    if( ( par_data.gDims[3] - par_data.gDims[0] ) * ( par_data.gDims[3] - par_data.gDims[0] ) *
            ( par_data.gDims[3] - par_data.gDims[0] ) <
        (int)pc.size() )
        std::cerr << "Too few processors for this number of elements." << std::endl;CHECK_ERR( MB_FAILURE );
    par_data.partMethod = ScdParData::SQIJK;
    // timing data
    double times[5];  // tstart, tvert, tnonvert, tghost, titer;
    times[0] = MPI_Wtime();
    rval     = scdi->construct_box( HomCoord(), HomCoord(), NULL, 0,  // no vertex positions
                                    new_box, NULL,                    // not locally periodic
                                    &par_data, true,
                                    false );  // assign global ids, don't resolve shared verts
    CHECK_ERR( rval );
    // get global id tag
    Tag tag = mbint.globalId_tag();
    // resolve shared verts
    std::cout << "Resolving shared ents..." << std::endl;
    rval = pc.resolve_shared_ents( new_box->box_set(), -1, 0, &tag );CHECK_ERR( rval );
    times[1] = MPI_Wtime();
    std::cout << "Exchanging ghost cells..." << std::endl;
    rval = pc.exchange_ghost_cells( -1, -1, 0, 0, true, true );CHECK_ERR( rval );
    times[2] = MPI_Wtime();
    //  pc.list_entities(0,-1);
    rval = pc.exchange_ghost_cells( -1, 0, 1, 0, true );
    if( MB_SUCCESS != rval )
        std::string err;
        mbint.get_last_error( err );
        std::cerr << "Error: proc " << pc.rank() << ": " << err << std::endl;
    CHECK_ERR( rval );
    times[3] = MPI_Wtime();
    // Create a tag, used in exchange_tags
    int def_val = 1.0;
    rval        = mbint.tag_get_handle( "test_tag", 1, MB_TYPE_DOUBLE, tag, MB_TAG_DENSE | MB_TAG_EXCL, &def_val );CHECK_ERR( rval );
    Range empty_range;
    if( !pc.rank() ) std::cout << "Exchanging tags: ";
    for( int i = 0; i < ITERS; i++ )
        if( !pc.rank() ) std::cout << i << ";";
        pc.exchange_tags( tag, empty_range );CHECK_ERR( rval );
    if( !pc.rank() ) std::cout << std::endl;
    times[4] = MPI_Wtime();
    for( int i = 4; i >= 1; i-- )
        times[i] -= times[i - 1];
    double tottimes[5] = { 0.0 };
    MPI_Reduce( times + 1, tottimes + 1, 4, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD );
    if( !pc.rank() )
        std::cout << "Times:             " << std::endl
                  << "Create:            " << times[1] << std::endl
                  << "Resolve verts:     " << times[2] << std::endl
                  << "Resolve non-verts: " << times[3] << std::endl
                  << "Exchange ghosts:   " << times[4] << std::endl;
int main ( int  argc,
char *  argv[]
Definition at line 27 of file structured3.cpp.
References ProgOptions::addOpt(), create_parallel_mesh(), ProgOptions::getOpt(), NC, ProgOptions::parseCommandLine(), and RUN_TEST.
    MPI_Init( &argc, &argv );
    ProgOptions po;
    po.addOpt< int >( "int,i", "Number of intervals on a side" );
    po.parseCommandLine( argc, argv );
    if( !po.getOpt( "int", &NC ) ) NC = 4;
    int err = RUN_TEST( create_parallel_mesh );
    MPI_Finalize();
    return err;
Variable Documentation
Definition at line 23 of file structured3.cpp.
Referenced by create_parallel_mesh().
int NC
Definition at line 16 of file structured3.cpp.
Referenced by create_parallel_mesh(), and main().
