surfplot.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "MBTagConventions.hpp"
#include <iostream>
#include <fstream>
#include <limits>
#include <cstdlib>
#include <cmath>
+ Include dependency graph for surfplot.cpp:
Classes
struct  CartVect3D
Defines
#define USAGE_ERROR   1
#define READ_ERROR   2
#define WRITE_ERROR   3
#define SURFACE_NOT_FOUND   4
#define OTHER_ERROR   5
Enumerations
enum  FileType { POSTSCRIPT, GNUPLOT, SVG }
Functions
static void usage_error (const char *name)
static CartVect3D operator- (const CartVect3D &a, const CartVect3D &b)
static double operator% (const CartVect3D &a, const CartVect3D &b)
static CartVect3D operator* (const CartVect3D &a, const CartVect3D &b)
static void find_rotation (CartVect3D plane_normal, double matrix[3][3])
static void transform_point (CartVect3D &point, double matrix[3][3])
static void write_gnuplot (std::ostream &stream, const std::vector< CartVect3D > &list)
static void write_svg (std::ostream &stream, const std::vector< CartVect3D > &list)
static void write_eps (std::ostream &stream, const std::vector< CartVect3D > &list, int surface_id)
int main (int argc, char *argv[])
static void box_max (CartVect3D &cur_max, const CartVect3D &pt)
static void box_min (CartVect3D &cur_min, const CartVect3D &pt)
Define Documentation
Definition at line 15 of file surfplot.cpp.
Referenced by main().
Definition at line 12 of file surfplot.cpp.
Definition at line 14 of file surfplot.cpp.
Definition at line 11 of file surfplot.cpp.
Referenced by usage_error().
Definition at line 13 of file surfplot.cpp.
Enumeration Type Documentation
enum FileType
Enumerator:
POSTSCRIPT
GNUPLOT
SVG
Definition at line 195 of file surfplot.cpp.
Function Documentation
static void find_rotation ( CartVect3D  plane_normal,
double  matrix[3][3]
) [static]
Definition at line 128 of file surfplot.cpp.
References CartVect3D::len(), CartVect3D::x, CartVect3D::y, and CartVect3D::z.
    // normalize
    plane_normal /= plane_normal.len();
    if( fabs( plane_normal.x ) < 0.1 ) plane_normal.x = 0.0;
    if( fabs( plane_normal.y ) < 0.1 ) plane_normal.y = 0.0;
    if( fabs( plane_normal.z ) < 0.1 ) plane_normal.z = 0.0;
    // calculate vector to rotate about
    const CartVect3D Z( 0, 0, 1 );
    CartVect3D vector = plane_normal * Z;
    const double len  = vector.len();
    // If vector is zero, no rotation
    if( len < 1e-2 )
        matrix[0][0] = matrix[1][1] = matrix[2][2] = 1.0;
        matrix[0][1] = matrix[1][0] = 0.0;
        matrix[0][2] = matrix[2][0] = 0.0;
        matrix[1][2] = matrix[2][1] = 0.0;
        return;
    vector /= len;
    const double cosine = plane_normal % Z;
    const double sine   = sqrt( 1 - cosine * cosine );
    std::cerr << "Rotation: " << acos( cosine ) << " [" << vector.x << ' ' << vector.y << ' ' << vector.z << ']'
              << std::endl;
    const double x = vector.x;
    const double y = vector.y;
    const double z = vector.z;
    const double c = cosine;
    const double s = sine;
    const double o = 1.0 - cosine;
    matrix[0][0] = c + x * x * o;
    matrix[0][1] = -z * s + x * y * o;
    matrix[0][2] = y * s + x * z * o;
    matrix[1][0] = z * s + x * z * o;
    matrix[1][1] = c + y * y * o;
    matrix[1][2] = -x * s + y * z * o;
    matrix[2][0] = -y * s + x * z * o;
    matrix[2][1] = x * s + y * z * o;
    matrix[2][2] = c + z * z * o;
int main ( int  argc,
char *  argv[]
Definition at line 204 of file surfplot.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, find_rotation(), GEOM_DIMENSION_TAG_NAME, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), GNUPLOT, CartVect3D::len(), moab::Interface::load_mesh(), MB_FILE_DOES_NOT_EXIST, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, OTHER_ERROR, POSTSCRIPT, READ_ERROR, moab::Range::size(), SURFACE_NOT_FOUND, SVG, moab::Interface::tag_get_handle(), transform_point(), moab::Interface::UNION, usage_error(), write_eps(), write_gnuplot(), write_svg(), CartVect3D::x, CartVect3D::y, and CartVect3D::z.
    Interface* moab = new Core();
    ErrorCode result;
    std::vector< CartVect3D >::iterator iter;
    FileType type = GNUPLOT;
    int idx = 1;
    if( argc == 4 )
        if( !strcmp( argv[idx], "-p" ) )
            type = POSTSCRIPT;
        else if( !strcmp( argv[idx], "-g" ) )
            type = GNUPLOT;
        else if( !strcmp( argv[idx], "-s" ) )
            type = SVG;
        else
            usage_error( argv[0] );
        ++idx;
    // scan CL args
    int surface_id;
    if( argc - idx != 2 ) usage_error( argv[0] );
    char* endptr;
    surface_id = strtol( argv[idx], &endptr, 0 );
    if( !endptr || *endptr ) usage_error( argv[0] );
    ++idx;
    // Load mesh
    result = moab->load_mesh( argv[idx] );
    if( MB_SUCCESS != result )
        if( MB_FILE_DOES_NOT_EXIST == result )
            std::cerr << argv[idx] << " : open failed.\n";
        else
            std::cerr << argv[idx] << " : error reading file.\n";
        return READ_ERROR;
    // Get tag handles
    EntityHandle surface;
    const int dimension = 2;  // surface
    if( surface_id )
        Tag tags[2];
        result = moab->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tags[0] );
            std::cerr << "No geometry tag.\n";
            return OTHER_ERROR;
        tags[1] = moab->globalId_tag();
        // Find entityset for surface.
        const void* tag_values[] = { &dimension, &surface_id };
        Range surfaces;
        moab->get_entities_by_type_and_tag( 0, MBENTITYSET, tags, tag_values, 2, surfaces );
        if( surfaces.size() != 1 )
            std::cerr << "Found " << surfaces.size() << " surfaces with ID " << surface_id << std::endl;
            return SURFACE_NOT_FOUND;
        surface = *surfaces.begin();
    else
        surface = 0;
    // Get surface mesh
    Range elements;
    result = moab->get_entities_by_dimension( surface, dimension, elements );
        std::cerr << "Internal error\n";
        return OTHER_ERROR;
    // Calculate average corner normal in surface mesh
    CartVect3D normal( 0, 0, 0 );
    std::vector< EntityHandle > vertices;
    std::vector< CartVect3D > coords;
    for( Range::iterator i = elements.begin(); i != elements.end(); ++i )
        vertices.clear();
        result = moab->get_connectivity( &*i, 1, vertices, true );
            return OTHER_ERROR;
        coords.clear();
        coords.resize( vertices.size() );
        result = moab->get_coords( &vertices[0], vertices.size(), reinterpret_cast< double* >( &coords[0] ) );
            return OTHER_ERROR;
        for( size_t j = 0; j < coords.size(); ++j )
            CartVect3D v1 = coords[( j + 1 ) % coords.size()] - coords[j];
            CartVect3D v2 = coords[( j + 1 ) % coords.size()] - coords[( j + 2 ) % coords.size()];
            normal += ( v1 * v2 );
    normal /= normal.len();
    // Get edges from elements
    Range edge_range;
    result = moab->get_adjacencies( elements, 1, true, edge_range, Interface::UNION );
        return OTHER_ERROR;
    // Get vertex coordinates for each edge
    std::vector< EntityHandle > edges( edge_range.size() );
    std::copy( edge_range.begin(), edge_range.end(), edges.begin() );
    vertices.clear();
    result = moab->get_connectivity( &edges[0], edges.size(), vertices, true );
        return OTHER_ERROR;
    coords.clear();
        return OTHER_ERROR;
    // Rotate points such that the projection into the view plane
    // can be accomplished by discarding the 'z' coordinate of each
    // point.
    std::cerr << "Plane normal: [" << normal.x << ' ' << normal.y << ' ' << normal.z << ']' << std::endl;
    double transform[3][3];
    find_rotation( normal, transform );
    for( iter = coords.begin(); iter != coords.end(); ++iter )
        transform_point( *iter, transform );
    // Write the file.
    switch( type )
        case POSTSCRIPT:
            write_eps( std::cout, coords, surface_id );
            break;
        case SVG:
            write_svg( std::cout, coords );
            break;
        default:
            write_gnuplot( std::cout, coords );
            break;
    return 0;
static double operator% ( const CartVect3D a,
const CartVect3D b
) [static]
Definition at line 108 of file surfplot.cpp.
References CartVect3D::x, CartVect3D::y, and CartVect3D::z.
    return a.x * b.x + a.y * b.y + a.z * b.z;
static CartVect3D operator* ( const CartVect3D a,
const CartVect3D b
) [static]
Definition at line 113 of file surfplot.cpp.
    CartVect3D result;
    result.x = a.y * b.z - a.z * b.y;
    result.y = a.z * b.x - a.x * b.z;
    result.z = a.x * b.y - a.y * b.x;
    return result;
static CartVect3D operator- ( const CartVect3D a,
const CartVect3D b
) [static]
Definition at line 103 of file surfplot.cpp.
    return CartVect3D( a.x - b.x, a.y - b.y, a.z - b.z );
static void transform_point ( CartVect3D point,
double  matrix[3][3]
) [static]
Definition at line 178 of file surfplot.cpp.
    const double x = point.x;
    const double y = point.y;
    const double z = point.z;
    point.x = x * matrix[0][0] + y * matrix[0][1] + z * matrix[0][2];
    point.y = x * matrix[1][0] + y * matrix[1][1] + z * matrix[1][2];
    point.z = x * matrix[2][0] + y * matrix[2][1] + z * matrix[2][2];
static void usage_error ( const char *  name) [static]
Definition at line 17 of file surfplot.cpp.
References USAGE_ERROR.
    std::cerr << "Usage: " << name << " [-g|-p] <Surface_ID> <input_file>" << std::endl
              << "\t-g           -  Write GNU Plot data file (default)." << std::endl
              << "\t-p           -  Write encapsulated postscript file" << std::endl
              << "\t-s           -  Write an SVG file" << std::endl
              << "\t<Surface_ID> -  ID of surface containing mesh to export (0 for entire file)." << std::endl
              << "\t<input_file> -  Mesh file to read." << std::endl
              << std::endl
              << "  This utility plots the mesh of a single geometric surface "
              << "projected to a plane.  The output file is written to stdout." << std::endl;
    exit( USAGE_ERROR );
void write_eps ( std::ostream &  stream,
const std::vector< CartVect3D > &  list,
int  surface_id
) [static]
Definition at line 406 of file surfplot.cpp.
References box_max(), box_min(), CartVect3D::x, and CartVect3D::y.
    // Coordinate range to use within EPS file
    const int X_MAX = 540;  // 540 pts / 72 pts/inch = 7.5 inches
    const int Y_MAX = 720;  // 720 pts / 72 pts/inch = 10 inches
    std::vector< CartVect3D >::const_iterator iter;
    // Get bounding box
    const double D_MAX = std::numeric_limits< double >::max();
    CartVect3D min( D_MAX, D_MAX, 0 );
    CartVect3D max( -D_MAX, -D_MAX, 0 );
        box_max( max, *iter );
        box_min( min, *iter );
    // Calculate translation to page coordinates
    CartVect3D offset = CartVect3D( 0, 0, 0 ) - min;
    CartVect3D scale  = max - min;
    scale.x           = X_MAX / scale.x;
    scale.y           = Y_MAX / scale.y;
    if( scale.x > scale.y )  // keep proportions
        scale.x = scale.y;
    else
        scale.y = scale.x;
    // std::cerr << "Min: " << min.x << ' ' << min.y <<
    //           "  Max: " << max.x << ' ' << max.y << std::endl
    //          << "Offset: " << offset.x << ' ' << offset.y <<
    //           "  Scale: " << scale.x << ' ' << scale.y << std::endl;
    // Write header stuff
    s << "%!PS-Adobe-2.0 EPSF-2.0" << std::endl;
    s << "%%Creator: MOAB surfplot" << std::endl;
    s << "%%Title: Surface " << id << std::endl;
    s << "%%DocumentData: Clean7Bit" << std::endl;
    s << "%%Origin: 0 0" << std::endl;
    int max_x = (int)( ( max.x + offset.x ) * scale.x );
    int max_y = (int)( ( max.y + offset.y ) * scale.y );
    s << "%%BoundingBox: 0 0 " << max_x << ' ' << max_y << std::endl;
    s << "%%Pages: 1" << std::endl;
    s << "%%BeginProlog" << std::endl;
    s << "save" << std::endl;
    s << "countdictstack" << std::endl;
    s << "mark" << std::endl;
    s << "newpath" << std::endl;
    s << "/showpage {} def" << std::endl;
    s << "/setpagedevice {pop} def" << std::endl;
    s << "%%EndProlog" << std::endl;
    s << "%%Page: 1 1" << std::endl;
    s << "1 setlinewidth" << std::endl;
    s << "0.0 setgray" << std::endl;
        double x1 = ( iter->x + offset.x ) * scale.x;
        double y1 = ( iter->y + offset.y ) * scale.y;
        if( ++iter == coords.end() ) break;
        double x2 = ( iter->x + offset.x ) * scale.x;
        double y2 = ( iter->y + offset.y ) * scale.y;
        s << x1 << ' ' << y1 << " moveto" << std::endl;
        s << x2 << ' ' << y2 << " lineto" << std::endl;
        s << "stroke" << std::endl;
    s << "%%Trailer" << std::endl;
    s << "cleartomark" << std::endl;
    s << "exch sub { end } repeat" << std::endl;
    s << "restore" << std::endl;
    s << "%%EOF" << std::endl;
void write_gnuplot ( std::ostream &  stream,
) [static]
Definition at line 370 of file surfplot.cpp.
    stream << std::endl;
        stream << iter->x << ' ' << iter->y << std::endl;
        ++iter;
        if( iter == coords.end() )
            break;
    std::cerr << "Display with gnuplot command \"plot with lines\"\n";
void write_svg ( std::ostream &  stream,
) [static]
Definition at line 485 of file surfplot.cpp.
References box_max(), box_min(), size, CartVect3D::x, and CartVect3D::y.
    // Get bounding box
    CartVect3D size = max - min;
    // scale to 640 pixels on a side
    double scale = 640.0 / ( size.x > size.y ? size.x : size.y );
    size *= scale;
    file << "<?xml version=\"1.0\" standalone=\"no\"?>" << std::endl;
    file << "<!DOCTYPE svg PUBLIC \"-//W3C//DTD SVG 1.1//EN\" "
         << "\"http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd\">" << std::endl;
    file << std::endl;
    file << "<svg width=\"" << (int)size.x << "\" height=\"" << (int)size.y
         << "\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\">" << std::endl;
    int left = (int)( min.x * scale );
    int top  = (int)( min.y * scale );
    while( iter != coords.end() )
        file << "<line "
             << "x1=\"" << (int)( scale * iter->x ) - left << "\" "
             << "y1=\"" << (int)( scale * iter->y ) - top << "\" ";
        ++iter;
        file << "x2=\"" << (int)( scale * iter->x ) - left << "\" "
             << "y2=\"" << (int)( scale * iter->y ) - top << "\" "
             << " style=\"stroke:rgb(99,99,99);stroke-width:2\""
             << "/>" << std::endl;
        ++iter;
    // Write footer
    file << "</svg>" << std::endl;
