testSmooth.cpp File Reference
#include "FBiGeom.h"
#include <iostream>
#include <set>
#include <algorithm>
#include <vector>
#include <iterator>
#include <iomanip>
#include <cassert>
#include <cstring>
#include <cmath>
+ Include dependency graph for testSmooth.cpp:
Classes
class  SimpleArray< T >
Defines
#define CHECK(STR)   if( err != iBase_SUCCESS ) return print_error( STR, err, geom, __FILE__, __LINE__ )
#define STRINGIFY(S)   XSTRINGIFY( S )
#define XSTRINGIFY(S)   #S
#define ARRAY_INOUT(A)   A.ptr(), &( A ).capacity(), &( A ).size()
#define ARRAY_IN(A)   &( A )[0], ( A ).size()
Typedefs
typedef iBase_TagHandle TagHandle
typedef iBase_EntityHandle GentityHandle
typedef iBase_EntitySetHandle GentitysetHandle
Functions
static bool print_error (const char *desc, int err, FBiGeom_Instance geom, const char *file, int line)
bool smooth_test (const std::string &filename, FBiGeom_Instance)
bool tags_test (FBiGeom_Instance geom)
bool tag_get_set_test (FBiGeom_Instance geom)
bool tag_info_test (FBiGeom_Instance geom)
bool gentityset_test (FBiGeom_Instance geom, bool, bool)
bool topology_adjacencies_test (FBiGeom_Instance geom)
bool geometry_evaluation_test (FBiGeom_Instance geom)
bool construct_test (FBiGeom_Instance geom)
bool primitives_test (FBiGeom_Instance geom)
bool transforms_test (FBiGeom_Instance geom)
bool booleans_test (FBiGeom_Instance geom)
bool shutdown_test (FBiGeom_Instance geom, std::string &engine_opt)
bool save_entset_test (FBiGeom_Instance geom)
bool mesh_size_test (FBiGeom_Instance geom)
bool normals_test (FBiGeom_Instance geom)
bool ray_test (FBiGeom_Instance geom)
void handle_error_code (const bool result, int &number_failed, int &, int &number_successful)
int main (int argc, char *argv[])
static bool compare_box (const double *expected_min, const double *expected_max, const double *actual_min, const double *actual_max)
static int get_entities (FBiGeom_Instance geom, int entity_type, std::vector< iBase_EntityHandle > &entities_out, iBase_TagHandle id_tag=0, std::vector< int > *ids_out=0)
static int check_firmness (FBiGeom_Instance geom, const std::vector< iBase_EntityHandle > &entities, const std::vector< int > &ids, iBase_TagHandle firmness_tag, const char *expected_value, const char *ent_type_str)
static int count_num_with_tag (FBiGeom_Instance geom, const std::vector< iBase_EntityHandle > &ents, iBase_TagHandle tag)
Define Documentation
#define ARRAY_IN (   A)    &( A )[0], ( A ).size()
Definition at line 125 of file testSmooth.cpp.
#define ARRAY_INOUT (   A)    A.ptr(), &( A ).capacity(), &( A ).size()
Definition at line 124 of file testSmooth.cpp.
Referenced by normals_test(), and ray_test().
#define CHECK (   STR)    if( err != iBase_SUCCESS ) return print_error( STR, err, geom, __FILE__, __LINE__ )
Definition at line 25 of file testSmooth.cpp.
Referenced by main(), normals_test(), ray_test(), and smooth_test().
#define STRINGIFY (   S)    XSTRINGIFY( S )
Definition at line 28 of file testSmooth.cpp.
Referenced by main().
#define XSTRINGIFY (   S)    #S
Definition at line 29 of file testSmooth.cpp.
Typedef Documentation
Definition at line 46 of file testSmooth.cpp.
Definition at line 47 of file testSmooth.cpp.
Definition at line 45 of file testSmooth.cpp.
Function Documentation
static int check_firmness ( FBiGeom_Instance  geom,
const std::vector< iBase_EntityHandle > &  entities,
const std::vector< int > &  ids,
const char *  expected_value,
const char *  ent_type_str
) [static]
Definition at line 1423 of file testSmooth.cpp.
References FBiGeom_getArrData, iBase_FAILURE, and iBase_SUCCESS.
    const int firmness_size = 4;
    std::vector< char > firmness( firmness_size * entities.size() );
    char* byte_ptr = &firmness[0];
    int err, junk1 = firmness.size(), junk2 = entities.size() * firmness_size;
    FBiGeom_getArrData( geom, &entities[0], entities.size(), firmness_tag, (void**)&byte_ptr, &junk1, &junk2, &err );
    if( iBase_SUCCESS != err ) return err;
    bool all_correct = true;
    for( unsigned i = 0; i < entities.size(); ++i )
        if( std::string( &firmness[firmness_size * i], firmness_size ) != expected_value ) all_correct = false;
    if( !all_correct )
        std::cout << "ERROR: Expected \"" << expected_value << "\" firmness "
                  << "for all " << ent_type_str << "." << std::endl;
        std::cout << "ID  Actual  " << std::endl;
            std::cout << std::setw( 2 ) << ids[i] << "  " << std::string( &firmness[firmness_size * i], firmness_size )
                      << std::endl;
        return iBase_FAILURE;
    return iBase_SUCCESS;
static bool compare_box ( const double *  expected_min,
const double *  expected_max,
const double *  actual_min,
const double *  actual_max
) [static]
Definition at line 1212 of file testSmooth.cpp.
    bool same   = true;
    double dtol = 1.0e-6;
    for( int i = 0; i < 3; ++i )
        if( expected_min[i] < actual_min[i] - dtol || expected_min[i] * 10 > actual_min[i] ||
            expected_max[i] > actual_max[i] + dtol || expected_max[i] * 10 < actual_max[i] )
            same = false;
    return same;
Test:
TSTTG construct Test
  • Check construction of geometry
static int count_num_with_tag ( FBiGeom_Instance  geom,
const std::vector< iBase_EntityHandle > &  ents,
iBase_TagHandle  tag
) [static]
Definition at line 1455 of file testSmooth.cpp.
References FBiGeom_getData, FBiGeom_getTagSizeBytes, iBase_SUCCESS, and iBase_TAG_NOT_FOUND.
    int err, bytes;
    FBiGeom_getTagSizeBytes( geom, tag, &bytes, &err );
    if( iBase_SUCCESS != err ) return -1;
    std::vector< char > data( bytes );
    int success_count = 0;
    for( size_t i = 0; i < ents.size(); ++i )
        char* ptr = &data[0];
        int junk1 = bytes, junk2;
        FBiGeom_getData( geom, ents[i], tag, (void**)&ptr, &junk1, &junk2, &err );
        if( iBase_TAG_NOT_FOUND == err ) continue;
        ++success_count;
    return success_count;
bool gentityset_test ( FBiGeom_Instance  geom,
bool  ,
bool
Test:
TSTT gentity sets test (just implemented parts for now)
  • Check gentity sets
Test:
FBiGeom_MOAB topology adjacencies Test
  • Check topology information
  • Check adjacency
static int get_entities ( FBiGeom_Instance  geom,
int  entity_type,
std::vector< iBase_EntityHandle > &  entities_out,
iBase_TagHandle  id_tag = 0,
std::vector< int > *  ids_out = 0
) [static]
Definition at line 1391 of file testSmooth.cpp.
References FBiGeom_getEntities, FBiGeom_getIntArrData, FBiGeom_getNumOfType, FBiGeom_getRootSet, and iBase_SUCCESS.
    int err, num;
    iBase_EntitySetHandle root;
    FBiGeom_getRootSet( geom, &root, &err );
    FBiGeom_getNumOfType( geom, root, entity_type, &num, &err );
    entities_out.resize( num );
    int junk1                    = entities_out.size(), junk2;
    iBase_EntityHandle* junk_ptr = &entities_out[0];
    FBiGeom_getEntities( geom, root, entity_type, &junk_ptr, &junk1, &junk2, &err );
    assert( num == junk1 && num == junk2 );
    if( !ids_out ) return iBase_SUCCESS;
    ids_out->resize( num );
    int* int_ptr = &( *ids_out )[0];
    FBiGeom_getIntArrData( geom, &entities_out[0], num, id_tag, &int_ptr, &junk1, &junk2, &err );
void handle_error_code ( const bool  result,
int &  number_failed,
int &  ,
int &  number_successful
Definition at line 146 of file testSmooth.cpp.
    if( result )
        std::cout << "Success";
        number_successful++;
    else
        std::cout << "Failure";
        number_failed++;
int main ( int  argc,
char *  argv[]
Definition at line 160 of file testSmooth.cpp.
References CHECK, FBiGeom_newGeom, geom, geometry_evaluation_test(), handle_error_code(), normals_test(), ray_test(), shutdown_test(), smooth_test(), STRINGIFY, tags_test(), and topology_adjacencies_test().
    std::string filename = STRINGIFY( MESHDIR ) "/shell.h5m";
    std::string engine_opt;
    if( argc == 1 )
        std::cout << "Using default input file: " << filename << std::endl;
    else if( argc == 2 )
        filename = argv[1];
    else
        std::cerr << "Usage: " << argv[0] << " [geom_filename]" << std::endl;
        return 1;
    bool result;
    int number_tests                 = 0;
    int number_tests_successful      = 0;
    int number_tests_not_implemented = 0;
    int number_tests_failed          = 0;
    // initialize the Mesh
    int err;
    FBiGeom_Instance geom;
    FBiGeom_newGeom( engine_opt.c_str(), &geom, &err, engine_opt.length() );
    CHECK( "Interface initialization didn't work properly." );
    // Print out Header information
    std::cout << "\n\nITAPS GEOMETRY INTERFACE TEST PROGRAM:\n\n";
    // gLoad test
    std::cout << "   Smooth faceting load and initialization: \n";
    result = smooth_test( filename, geom );
    handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
    number_tests++;
    std::cout << "\n";
    // tags test
    std::cout << "   tags: ";
    result = tags_test( geom );
    number_tests++;
    std::cout << "\n";
     // gentitysets test
     std::cout << "   gentity sets: ";
     result = gentityset_test(geom, false, false);
     handle_error_code(result, number_tests_failed,
     number_tests_successful);
     number_tests++;
     std::cout << "\n";
    // topology adjacencies test
    std::cout << "   topology adjacencies: ";
    result = topology_adjacencies_test( geom );
    number_tests++;
    std::cout << "\n";
    // geometry evaluation test
    std::cout << "   geometry evaluation: \n";
    result = geometry_evaluation_test( geom );
    number_tests++;
    std::cout << "\n";
    // normals evaluation test
    std::cout << "   normals geometry evaluation: \n";
    result = normals_test( geom );
    number_tests++;
    std::cout << "\n";
    // ray tracing test
    std::cout << "   ray intersection test: \n";
    result = ray_test( geom );
    number_tests++;
    std::cout << "\n";
     // construct test
     std::cout << "   construct: ";
     result = construct_test(geom);
     number_tests++;
     std::cout << "\n";
     // primitives test
     std::cout << "   primitives: ";
     result = primitives_test(geom);
     number_tests++;
     std::cout << "\n";
     // transforms test
     std::cout << "   transforms: ";
     result = transforms_test(geom);
     number_tests++;
     std::cout << "\n";
     // booleans test
     std::cout << "   booleans: ";
     result = booleans_test(geom);
     number_tests++;
     std::cout << "\n";
     #if defined(HAVE_ACIS) && !defined(FORCE_OCC)
     std::cout << "   mesh size: ";
     result = mesh_size_test(geom);
     number_tests++;
     std::cout << "\n";
     // save entset test
     std::cout << "   save entset: ";
     result = save_entset_test(geom);
     number_tests++;
     std::cout << "\n";
     #endif
    // shutdown test
    std::cout << "   shutdown: ";
    result = shutdown_test( geom, engine_opt );
    number_tests++;
    std::cout << "\n";
    // summary
    std::cout << "\nTSTT TEST SUMMARY: \n"
              << "   Number Tests:           " << number_tests << "\n"
              << "   Number Successful:      " << number_tests_successful << "\n"
              << "   Number Not Implemented: " << number_tests_not_implemented << "\n"
              << "   Number Failed:          " << number_tests_failed << "\n\n"
              << std::endl;
    return number_tests_failed;
Definition at line 1050 of file testSmooth.cpp.
References ARRAY_INOUT, SimpleArray< T >::begin(), CHECK, SimpleArray< T >::end(), FBiGeom_getEntBoundBox, FBiGeom_getEntities, FBiGeom_getEntNrmlXYZ, FBiGeom_getRootSet, iBase_ALL_TYPES, iBase_EDGE, iBase_VERTEX, root_set, and SimpleArray< T >::size().
    int i, err;
    iBase_EntitySetHandle root_set;
    FBiGeom_getRootSet( geom, &root_set, &err );
    CHECK( "ERROR : getRootSet failed!" );
    int top          = iBase_VERTEX;
    int num_test_top = iBase_ALL_TYPES;
    std::vector< std::vector< iBase_EntityHandle > > gentity_vectors( num_test_top );
    // fill the vectors of each topology entities
    // like lines vector, polygon vector, triangle vector,
    // quadrilateral, polyhedrron, tet, hex, prism, pyramid,
    // septahedron vectors
    for( i = top; i < num_test_top; i++ )
        SimpleArray< iBase_EntityHandle > gentities;
        FBiGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err );
        CHECK( "Failed to get gentities in adjacencies_test." );
        gentity_vectors[i].resize( gentities.size() );
        std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() );
    // check adjacencies in both directions
    double min[3], max[3];
    double normal[3] = { .0, .0, .0 };
    std::vector< iBase_EntityHandle >::iterator vit;
    for( i = iBase_REGION; i > iBase_EDGE; i-- )
        for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit )
            iBase_EntityHandle this_gent = *vit;
            FBiGeom_getEntBoundBox( geom, this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err );
            CHECK( "Failed to get bounding box of entity." );
            FBiGeom_getEntNrmlXYZ( geom, this_gent, ( max[0] + min[0] ) / 2, ( max[1] + min[1] ) / 2,
                                   ( max[2] + min[2] ) / 2, &normal[0], &normal[1], &normal[2], &err );
            CHECK( "Failed to get normal to the closest point." );
            std::cout << " entity of type " << i << " closest normal to center:\n  " << normal[0] << " " << normal[1]
                      << " " << normal[2] << "\n";
    return true;
static bool print_error ( const char *  desc,
int  err,
const char *  file,
int  line
) [static]
Definition at line 31 of file testSmooth.cpp.
References buffer, and FBiGeom_getDescription.
    char buffer[1024];
    FBiGeom_getDescription( geom, buffer, sizeof( buffer ) );
    buffer[sizeof( buffer ) - 1] = '\0';
    std::cerr << "ERROR: " << desc << std::endl
              << "  Error code: " << err << std::endl
              << "  Error desc: " << buffer << std::endl
              << "  At        : " << file << ':' << line << std::endl;
    return false;  // must always return false or CHECK macro will break
bool ray_test ( FBiGeom_Instance  geom)
Definition at line 1100 of file testSmooth.cpp.
References ARRAY_INOUT, CHECK, FBiGeom_getEntBoundBox, FBiGeom_getEntities, FBiGeom_getEntType, FBiGeom_getPntRayIntsct, FBiGeom_getRootSet, iBase_FACE, iBase_INTERLEAVED, root_set, and SimpleArray< T >::size().
    int err;
    int top = iBase_FACE;
    SimpleArray< iBase_EntityHandle > faces;
    FBiGeom_getEntities( geom, root_set, top, ARRAY_INOUT( faces ), &err );
    // check only the first face
    iBase_EntityHandle first_face = faces[0];
    FBiGeom_getEntBoundBox( geom, first_face, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err );
    // assume that the ray shot from the bottom of the box (middle) is a pretty good candidate
    // in z direction
    double x = ( min[0] + max[0] ) / 2, y = ( min[1] + max[1] ) / 2, z = min[2];
    SimpleArray< iBase_EntityHandle > intersect_entity_handles;
    SimpleArray< double > intersect_coords;
    SimpleArray< double > param_coords;
    FBiGeom_getPntRayIntsct( geom, x, y, z,  // shot from
                             0., 0., 1.,     // direction
                             ARRAY_INOUT( intersect_entity_handles ), iBase_INTERLEAVED,
                             ARRAY_INOUT( intersect_coords ), ARRAY_INOUT( param_coords ), &err );
    CHECK( "Failed to find ray intersections points " );
    for( int i = 0; i < intersect_entity_handles.size(); i++ )
        int j;
        FBiGeom_getEntType( geom, intersect_entity_handles[i], &j, &err );
        CHECK( "Failed to get type of entity." );
        std::cout << " entity of type " << j << " n: " << intersect_entity_handles[i] << "\n"
                  << intersect_coords[3 * i] << " " << intersect_coords[3 * i + 1] << " " << intersect_coords[3 * i + 2]
                  << "\n"
                  << " distance: " << param_coords[i] << "\n";
    return true;
bool shutdown_test ( FBiGeom_Instance  geom,
std::string &  engine_opt
bool smooth_test ( const std::string &  filename,
Test:
Load Mesh
  • Load a mesh file
Test:
Load Mesh
  • Load a mesh file
Definition at line 326 of file testSmooth.cpp.
References CHECK, FBiGeom_getNumOfType, FBiGeom_getRootSet, FBiGeom_load, and root_set.
    int err;
    char opts[] = "SMOOTH;";
    FBiGeom_load( geom, &filename[0], opts, &err, filename.length(), 8 );
    // FBiGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 );
    CHECK( "ERROR : can not load a geometry" );
    // print out the number of entities
    std::cout << "Model contents: " << std::endl;
    const char* gtype[] = { "vertices: ", "edges: ", "faces: ", "regions: " };
    for( int i = 0; i <= 3; ++i )
        int count;
        FBiGeom_getNumOfType( geom, root_set, i, &count, &err );
        CHECK( "Error: problem getting entities after gLoad." );
        std::cout << gtype[i] << count << std::endl;
    return true;
bool tags_test ( FBiGeom_Instance  geom)
Test:
Test tag creating, reading, writing, deleting
  • Load a mesh file
Test:
TSTTG topology adjacencies Test
  • Check adjacency
