MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/BoundBox.hpp"
#include "moab/ScdInterface.hpp"
#include <iostream>
Functions | |
void | test_bound_box () |
test add_entities, get_entities, num_entities | |
int | main () |
int main | ( | ) |
Definition at line 13 of file test_boundbox.cpp.
References RUN_TEST, and test_bound_box().
{ int err = 0; err += RUN_TEST( test_bound_box ); if( !err ) printf( "ALL TESTS PASSED\n" ); else printf( "%d TESTS FAILED\n", err ); return err; }
void test_bound_box | ( | ) |
Definition at line 27 of file test_boundbox.cpp.
References moab::CartVect::array(), box(), center(), CHECK, CHECK_ERR, CHECK_REAL_EQUAL, moab::BoundBox::compute_center(), moab::ScdInterface::construct_box(), moab::BoundBox::contains_point(), moab::BoundBox::diagonal_length(), moab::BoundBox::diagonal_squared(), dist(), moab::BoundBox::distance(), moab::BoundBox::distance_squared(), ErrorCode, moab::Core::get_coords(), moab::BoundBox::intersects_box(), length(), mb, moab::ScdBox::num_elements(), moab::Interface::query_interface(), moab::ScdBox::start_element(), moab::ScdBox::start_vertex(), moab::BoundBox::update(), moab::BoundBox::update_max(), and moab::BoundBox::update_min().
Referenced by main().
{ BoundBox box; CartVect vec( 0.0 ); double tol = 0.0; std::vector< double > vals( 6, 0.0 ); BoundBox other_box( &vals[0] ); // test for contains point failure bool result = box.contains_point( vec.array(), tol ); CHECK( !result ); result = box.intersects_box( other_box, tol ); CHECK( !result ); box = other_box; tol = 1.0e-10; // test for success result = box.contains_point( &vals[0], tol ); CHECK( result ); result = box.intersects_box( other_box, tol ); CHECK( result ); // check update functions CartVect three( 3.0 ); box.update_max( three.array() ); result = box.contains_point( three.array(), tol ); CHECK( result ); result = box.contains_point( ( three * 1.1 ).array(), tol ); CHECK( !result ); result = box.intersects_box( BoundBox( three, three ), tol ); CHECK( result ); result = box.intersects_box( BoundBox( 1.1 * three, 3.0 * three ), tol ); CHECK( !result ); CartVect negthree( -3.0 ); box.update_min( negthree.array() ); result = box.contains_point( negthree.array(), tol ); CHECK( result ); result = box.contains_point( ( negthree * 1.1 ).array(), tol ); CHECK( !result ); result = box.intersects_box( BoundBox( negthree, negthree ), tol ); CHECK( result ); result = box.intersects_box( BoundBox( 3.0 * negthree, 1.1 * negthree ), tol ); CHECK( !result ); for( int i = 0; i < 3; i++ ) { vals[i] = -4.0; vals[3 + i] = 4.0; } box.update( &vals[0] ); result = box.contains_point( &vals[0], tol ); CHECK( result ); result = box.contains_point( ( CartVect( &vals[0] ) * 1.1 ).array(), tol ); CHECK( !result ); result = box.intersects_box( BoundBox( &vals[0] ), tol ); CHECK( result ); result = box.intersects_box( BoundBox( 1.2 * CartVect( &vals[0] ), 1.1 * CartVect( &vals[0] ) ), tol ); CHECK( !result ); // check length functions tol = 1.0e-6; // box should be 8 on a side, or 3*(2^3)^2 or 192 for diag length squared double diagsq = box.diagonal_squared(); CHECK_REAL_EQUAL( diagsq, 192.0, tol ); double diag = box.diagonal_length(); CHECK_REAL_EQUAL( diag, sqrt( 3.0 ) * 8.0, tol ); // check distance function // face-centered vals[0] = vals[1] = 0.0; vals[2] = 6.0; double dist = box.distance_squared( CartVect( &vals[0] ).array() ); CHECK_REAL_EQUAL( dist, 4.0, tol ); dist = box.distance( CartVect( &vals[0] ).array() ); CHECK_REAL_EQUAL( dist, 2.0, tol ); // edge-centered vals[0] = 0.0; vals[1] = vals[2] = 6.0; dist = box.distance_squared( CartVect( &vals[0] ).array() ); CHECK_REAL_EQUAL( dist, 8.0, tol ); dist = box.distance( CartVect( &vals[0] ).array() ); CHECK_REAL_EQUAL( dist, sqrt( 8.0 ), tol ); // vertex-centered vals[0] = vals[1] = vals[2] = 6.0; dist = box.distance_squared( CartVect( &vals[0] ).array() ); CHECK_REAL_EQUAL( dist, 12.0, tol ); dist = box.distance( CartVect( &vals[0] ).array() ); CHECK_REAL_EQUAL( dist, sqrt( 12.0 ), tol ); // check entity-based functions Core mb; ScdInterface* scdi; ErrorCode rval = mb.query_interface( scdi );CHECK_ERR( rval ); ScdBox* scd_box; // create a 10x10x10 box rval = scdi->construct_box( HomCoord( 0, 0, 0 ), HomCoord( 10, 10, 10 ), NULL, 0, scd_box );CHECK_ERR( rval ); EntityHandle vert = scd_box->start_vertex(), elem = scd_box->start_element(); rval = box.update( mb, vert );CHECK_ERR( rval ); rval = mb.get_coords( &vert, 1, &vals[0] );CHECK_ERR( rval ); tol = 1.0e-10; result = box.contains_point( &vals[0], tol ); CHECK( result ); rval = box.update( mb, elem );CHECK_ERR( rval ); rval = mb.get_coords( &elem, 1, &vals[0] );CHECK_ERR( rval ); result = box.contains_point( &vals[0], tol ); CHECK( result ); Range all_elems( elem, elem + scd_box->num_elements() - 1 ); rval = box.update( mb, all_elems );CHECK_ERR( rval ); CartVect center; box.compute_center( center ); tol = 1.0e-6; CHECK_REAL_EQUAL( ( center - CartVect( 5.0, 5.0, 5.0 ) ).length(), 0.0, tol ); }
