test_entsetFB.cpp
00001 #include "moab/MOABConfig.h"
00002 #include "FBiGeom.h"
00003 #include "iMesh.h"
00004 #include "iRel.h"
00005
00006 #include <cstdio>
00007 #include <cstdlib>
00008 #include <cstring>
00009
00010 #define DEFAULT_TEST_FILE  shell.h5m
00011 #define DEFAULT_TEST_FILE1 shellQuad.h5m
00012
00013 // clang-format off
00014
00015 #define STRINGIFY_( X ) #X
00016 #define STRINGIFY( X )  STRINGIFY_( X )
00017 #if defined( MESHDIR ) && defined( MOAB_HAVE_HDF5 )
00018 #define DEFAULT_INPUT_FILE  STRINGIFY( MESHDIR/fbigeom/DEFAULT_TEST_FILE )
00019 #define DEFAULT_INPUT_FILE1 STRINGIFY( MESHDIR/fbigeom/DEFAULT_TEST_FILE1 )
00020 #else
00021 #error Specify MESHDIR to compile test
00022 #endif
00023
00024 #define CHECK_SIZE_C( type, array, allocated_size, size )            \
00025     if( NULL == *(array) || *(allocated_size) == 0 )                     \
00026     {        \
00027         *(array)          = (type*)malloc( sizeof( type ) * (size) );    \
00028         *(allocated_size) = size;                                      \
00029     }        \
00030     else if( *(allocated_size) < (size) )                                \
00031     {        \
00032         printf( "   Array passed in is non-zero but too short.\n" ); \
00033     }
00034
00035 // clang-format on
00036
00037 typedef void* iRel_EntityHandle;
00038
00039 /*!
00040   prints out a result string based on the value of error_code
00041 */
00042 void handle_error_code( const int result, int* number_failed, int* number_not_implemented, int* number_successful )
00043 {
00044     if( result )
00045     {
00046         printf( "Success" );
00047         ( *number_successful )++;
00048     }
00049     else
00050     {
00051         printf( "Failure" );
00052         ( *number_failed )++;
00053     }
00054 }
00055
00056 int print_geom_info( FBiGeom_Instance geom, iBase_EntityHandle gent )
00057 {
00058     /* print information about this entity */
00059     int ent_type;
00060     int result;
00061     const char* type_names[] = { "Vertex", "Edge", "Face", "Region" };
00062
00063     FBiGeom_getEntType( geom, gent, &ent_type, &result );
00064
00065     if( iBase_SUCCESS != result )
00066     {
00067         printf( "Trouble getting entity adjacencies or types." );
00068         return 0;
00069     }
00070
00071     printf( "%s 0x%lx\n", type_names[ent_type], (unsigned long)gent );
00072
00073     return 1;
00074 }
00075
00076 int print_mesh_info( iMesh_Instance mesh, iBase_EntityHandle ment )
00077 {
00078     /* print information about this entity */
00079
00080     /* get adjacencies first; assume not more than 50 */
00081     iBase_EntityHandle adj_ents[50], *adj_ents_ptr = adj_ents;
00082     int ent_types[50], *ent_types_ptr              = ent_types;
00083     int adj_ents_alloc = 50, adj_ents_size, ent_types_size, ent_types_allocated = 50;
00084     int result;
00085     iBase_TagHandle* ment_tags = NULL;
00086     int ment_tags_size, ment_tags_alloc;
00087     char** tag_names;
00088     int i;
00089     const char* type_names[] = { "Vertex", "Edge", "Face", "Region" };
00090     int tag_type;
00091
00092     char* dum_handle     = NULL;
00093     int dum_handle_alloc = 0, dum_handle_size = 0;
00094     int int_data;
00095     double dbl_data;
00096     iBase_EntityHandle eh_data;
00097
00098     iMesh_getEntAdj( mesh, ment, iBase_ALL_TYPES, &adj_ents_ptr, &adj_ents_alloc, &adj_ents_size, &result );
00099
00100     if( iBase_SUCCESS != result ) return 0;
00101
00102     /* put this ent on the end, then get types */
00103     adj_ents[adj_ents_size] = ment;
00104     iMesh_getEntArrType( mesh, adj_ents, adj_ents_size + 1, &ent_types_ptr, &ent_types_allocated, &ent_types_size,
00105                          &result );
00106     if( iBase_SUCCESS != result )
00107     {
00108         printf( "Trouble getting entity adjacencies or types." );
00109         return 0;
00110     }
00111
00112     /* get tags on ment */
00113     iMesh_getAllTags( mesh, ment, &ment_tags, &ment_tags_alloc, &ment_tags_size, &result );
00114
00115     printf( "Trouble getting tags on an entity or their names." );
00116
00117     /* while we're at it, get all the tag names */
00118
00119     tag_names = (char**)malloc( ment_tags_size * sizeof( char* ) );
00120
00121     for( i = 0; i < ment_tags_size; i++ )
00122     {
00123         tag_names[i] = (char*)malloc( 120 * sizeof( char ) );
00124         iMesh_getTagName( mesh, ment_tags[i], tag_names[i], &result, 120 );
00125     }
00126
00127     /* now print the information */
00128     printf( "%s %ld:\n", type_names[ent_types[ent_types_size - 1]], (long)ment );
00129     printf( "Adjacencies:" );
00130     for( i = 0; i < adj_ents_size; i++ )
00131     {
00132         if( i > 0 ) printf( ", " );
00133         printf( "%s %ld", type_names[ent_types[i]], (long)adj_ents[i] );
00134     }
00135     printf( "\nTags: \n" );
00136     for( i = 0; i < ment_tags_size; i++ )
00137     {
00138         printf( "%s ", tag_names[i] );
00139         iMesh_getTagType( mesh, ment_tags[i], &tag_type, &result );
00140         if( iBase_SUCCESS != result )
00141             printf( "(trouble getting type...)\n" );
00142         else
00143         {
00144             dum_handle       = NULL;
00145             dum_handle_alloc = 0, dum_handle_size = 0;
00146
00147             switch( tag_type )
00148             {
00149                 case iBase_INTEGER:
00150                     iMesh_getIntData( mesh, ment, ment_tags[i], &int_data, &result );
00151                     printf( "(Int value=%d)", int_data );
00152                     break;
00153                 case iBase_DOUBLE:
00154                     iMesh_getDblData( mesh, ment, ment_tags[i], &dbl_data, &result );
00155                     printf( "(Dbl value=%f)", dbl_data );
00156                     break;
00157                 case iBase_ENTITY_HANDLE:
00158                     iMesh_getEHData( mesh, ment, ment_tags[i], &eh_data, &result );
00159                     printf( "(EH value=%ld)", (long)eh_data );
00160                     break;
00161                 case iBase_BYTES:
00162                     iMesh_getData( mesh, ment, ment_tags[i], (void**)&dum_handle, &dum_handle_alloc, &dum_handle_size,
00163                                    &result );
00164                     if( NULL != dum_handle && dum_handle_size > 0 ) printf( "(Opaque value=%c)", dum_handle[0] );
00165                     break;
00166             }
00167         }
00168
00169         printf( "\n" );
00170     }
00171     printf( "(end tags)\n\n" );
00172     free( ment_tags );
00173     return 1;
00174 }
00175
00176 /*!
00177   @test
00178   Load Mesh
00179   @li Load a geom and a mesh file
00180 */
00181 int load_geom_mesh_test( const char* geom_filename,
00182                          const char* mesh_filename,
00183                          FBiGeom_Instance geom,
00184                          iMesh_Instance mesh )
00185 {
00186     /* load a geom */
00187     int result;
00188     FBiGeom_load( geom, geom_filename, 0, &result, strlen( geom_filename ), 0 );
00189     if( iBase_SUCCESS != result )
00190     {
00191         printf( "ERROR : can not load a geometry\n" );
00192         return 0;
00193     }
00194
00195     /* load a mesh */
00196     iMesh_load( mesh, 0, mesh_filename, 0, &result, strlen( mesh_filename ), 0 );
00197     if( iBase_SUCCESS != result )
00198     {
00199         printf( "ERROR : can not load a mesh\n" );
00200         return 0;
00201     }
00202
00203     return 1;
00204 }
00205
00206 /*!
00207   @test
00208   TSTTLasso create relation  Test
00209   @li Create relation between geom and mesh
00210 */
00211 int create_relation_test( iRel_Instance assoc, FBiGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle* pair )
00212 {
00213     int result;
00214
00215     iBase_Instance iface1, iface2;
00216     int type1, type2;
00217     int ent_or_set1, ent_or_set2;
00218     int status1, status2;
00219
00220     iRel_PairHandle tmp_pair;
00221     iRel_PairHandle* pair_ptr = &tmp_pair;
00222     int pairs_alloc           = 1, pairs_size;
00223
00224     /* create an relation, entity to set */
00225     iRel_createPair( assoc, geom, iRel_ENTITY, iRel_FBIGEOM_IFACE, iRel_ACTIVE, mesh, iRel_SET, iRel_IMESH_IFACE,
00226                      iRel_ACTIVE, pair, &result );
00227     if( iBase_SUCCESS != result )
00228     {
00229         printf( "Couldn't create a new relation.\n" );
00230         return 0;
00231     }
00232
00233     iRel_getPairInfo( assoc, *pair, &iface1, &ent_or_set1, &type1, &status1, &iface2, &ent_or_set2, &type2, &status2,
00234                       &result );
00235     if( iBase_SUCCESS != result )
00236     {
00237         printf( "Couldn't retrieve relation info.\n" );
00238         return 0;
00239     }
00240     if( iface1 != geom || ent_or_set1 != iRel_ENTITY || type1 != iRel_FBIGEOM_IFACE || iface2 != mesh ||
00241         ent_or_set2 != iRel_SET || type2 != iRel_IMESH_IFACE )
00242     {
00243         printf( "Unexpected relation info returned.\n" );
00244         return 0;
00245     }
00246
00247     iRel_findPairs( assoc, geom, &pair_ptr, &pairs_alloc, &pairs_size, &result );
00248     if( iBase_SUCCESS != result )
00249     {
00250         printf( "Couldn't find relation pair when querying geom.\n" );
00251         return 0;
00252     }
00253     if( pairs_size != 1 || tmp_pair != *pair )
00254     {
00255         printf( "Unexpected relation pairs returned when querying geom.\n" );
00256         return 0;
00257     }
00258
00259     iRel_findPairs( assoc, mesh, &pair_ptr, &pairs_alloc, &pairs_size, &result );
00260     if( iBase_SUCCESS != result )
00261     {
00262         printf( "Couldn't find relation pair when querying mesh.\n" );
00263         return 0;
00264     }
00265     if( pairs_size != 1 || tmp_pair != *pair )
00266     {
00267         printf( "Unexpected relation pairs returned when querying mesh.\n" );
00268         return 0;
00269     }
00270
00271     return 1;
00272 }
00273
00274 /*!
00275   @test
00276   TSTTLasso relate geom and mesh Test
00277   @li Check relation between geom and mesh
00278 */
00279 int relate_geom_mesh_test( iRel_Instance assoc, FBiGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair )
00280 {
00281     /* relate geometry entities with coresponding mesh entity sets */
00282     iBase_EntityHandle* gentities = NULL;
00283     int gentities_size = 0, gentities_alloc = 0;
00284     int result;
00285
00286     iBase_EntitySetHandle* mentity_handles = NULL;
00287     int mentity_handles_size = 0, mentity_handles_alloc = 0;
00288
00289     const char* dim_tag_name = "GEOM_DIMENSION";
00290     iBase_TagHandle dim_tag_mesh;
00291
00292     iBase_EntitySetHandle* mentities_vec;
00293     int mentities_vec_size;
00294     int i;
00295
00296     iBase_EntitySetHandle* out_mentities = NULL;
00297     int out_mentities_size = 0, out_mentities_alloc = 0;
00298
00299     iBase_EntitySetHandle* out_mentities2 = NULL;
00300     int out_mentities2_size = 0, out_mentities2_alloc = 0;
00301
00302     iBase_EntityHandle* out_gentities = NULL;
00303     int out_gentities_size = 0, out_gentities_alloc = 0;
00304
00305     FBiGeom_getEntities( geom, NULL, iBase_VERTEX, &gentities, &gentities_alloc, &gentities_size, &result );
00306     if( iBase_SUCCESS != result )
00307     {
00308         printf( "Failed to get gentities by type in relate_geom_mesh_test.\n" );
00309         return 0;
00310     }
00311
00312     iRel_inferEntArrRelations( assoc, pair, gentities, gentities_size, 0, &result );
00313     if( iBase_SUCCESS != result )
00314     {
00315         printf( "Failed to relate geom entities in relate_geom_mesh_test.\n" );
00316         return 0;
00317     }
00318
00319     /* relate coresponding mesh entity sets for geometry entities */
00320     /* get 1-dimensional mesh entitysets */
00321
00322     iMesh_getEntSets( mesh, NULL, 1, &mentity_handles, &mentity_handles_alloc, &mentity_handles_size, &result );
00323     if( iBase_SUCCESS != result )
00324     {
00325         printf( "Problem to get all entity sets.\n" );
00326         return 0;
00327     }
00328
00329     /* get geom dimension tags for mesh entitysets */
00330     iMesh_createTag( mesh, dim_tag_name, 1, iBase_INTEGER, &dim_tag_mesh, &result, 15 );
00331     if( iBase_SUCCESS != result && result != iBase_TAG_ALREADY_EXISTS )
00332     {
00333         printf( "Couldn't create geom dim tag for mesh entities.\n" );
00334         return 0;
00335     }
00336
00337     /* get 1-dimensional mesh entitysets */
00338     mentities_vec      = (iBase_EntitySetHandle*)malloc( mentity_handles_size * sizeof( iBase_EntitySetHandle ) );
00339     mentities_vec_size = 0;
00340
00341     for( i = 0; i < mentity_handles_size; i++ )
00342     {
00343         int dim;
00344         iMesh_getEntSetIntData( mesh, mentity_handles[i], dim_tag_mesh, &dim, &result );
00345         if( iBase_SUCCESS != result ) continue;
00346
00347         if( dim == 1 ) mentities_vec[mentities_vec_size++] = mentity_handles[i];
00348     }
00349
00350     iRel_inferSetArrRelations( assoc, pair, mentities_vec, mentities_vec_size, 1, &result );
00351     if( iBase_SUCCESS != result )
00352     {
00353         printf( "Failed to relate mesh entities in relate_geom_mesh_test.\n" );
00354         return 0;
00355     }
00356
00357     /* relate all geometry and mesh entities */
00358     iRel_inferAllRelations( assoc, pair, &result );
00359     if( iBase_SUCCESS != result )
00360     {
00361         printf( "Failed to relate all geom and mesh entities in relate_geom_mesh_test.\n" );
00362         return 0;
00363     }
00364
00365     /* reset geom entities list and get all geom entities (prev
00366        only vertices) */
00367     free( gentities );
00368     gentities       = NULL;
00369     gentities_alloc = 0;
00370     FBiGeom_getEntities( geom, NULL, iBase_ALL_TYPES, &gentities, &gentities_alloc, &gentities_size, &result );
00371     if( iBase_SUCCESS != result )
00372     {
00373         printf( "Failed to get gentities by type in relate_geom_mesh_test.\n" );
00374         return 0;
00375     }
00376
00377     /* get related mesh entity sets for geometry entities */
00378     iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities, &out_mentities_alloc,
00379                                   &out_mentities_size, &result );
00380     if( iBase_SUCCESS != result )
00381     {
00382         printf( "Failed to get geom entities in relate_geom_mesh_test.\n" );
00383         return 0;
00384     }
00385
00386     if( out_mentities_size != gentities_size )
00387     {
00388         printf( "Number of input geom entities and output mesh entity sets should be same\n" );
00389         return 0;
00390     }
00391
00392     /* now try deleting this relation */
00393     iRel_rmvEntArrRelation( assoc, pair, gentities, gentities_size, 0, &result );
00394     if( iBase_SUCCESS != result )
00395     {
00396         printf( "Failed to remove relation in relate_geom_mesh_test.\n" );
00397         return 0;
00398     }
00399     iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities2, &out_mentities2_alloc,
00400                                   &out_mentities2_size, &result );
00401     if( iBase_SUCCESS == result )
00402     {
00403         printf( "Shouldn't have gotten mesh sets in relate_geom_mesh_test.\n" );
00404         return 0;
00405     }
00406
00407     /* restore the relation, since we need it later */
00408     iRel_setEntArrSetArrRelation( assoc, pair, gentities, gentities_size, out_mentities, out_mentities_size, &result );
00409     if( iBase_SUCCESS != result )
00410     {
00411         printf( "Failed to restore relation in relate_geom_mesh_test.\n" );
00412         return 0;
00413     }
00414
00415     /* get related geometry entities for mesh entity sets */
00416     iRel_getSetArrEntArrRelation( assoc, pair, out_mentities, out_mentities_size, 1, &out_gentities,
00417                                   &out_gentities_alloc, &out_gentities_size, &result );
00418     if( iBase_SUCCESS != result )
00419     {
00420         printf( "Failed to get mesh entities in relate_geom_mesh_test.\n" );
00421         return 0;
00422     }
00423
00424     if( out_mentities_size != out_gentities_size )
00425     {
00426         printf( "Number of input mesh entity sets and output geom entities should be same\n" );
00427         return 0;
00428     }
00429     free( mentity_handles );
00430     mentity_handles = NULL;
00431     free( gentities );
00432     gentities = NULL;
00433     free( mentity_handles );
00434     mentity_handles = NULL;
00435     free( out_mentities );
00436     out_mentities = NULL;
00437     free( mentities_vec );
00438     mentities_vec = NULL;
00439     free( out_gentities );
00440     out_gentities = NULL;
00441     return 1;
00442 }
00443
00444 /*!
00445   @test
00446   TSTTAssoc move to test
00447   @li Move meshes onto the given geometry
00448 */
00449 int query_relations_test( iRel_Instance assoc, FBiGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair )
00450 {
00451     /* get all the geom entities, and find relation to some mesh entity */
00452     iBase_EntityHandle* gentities = NULL;
00453     int gentities_size = 0, gentities_alloc = 0;
00454     int result;
00455
00456     iBase_EntitySetHandle* out_mentities = NULL;
00457     int out_mentities_size, out_mentities_alloc = 0;
00458
00459     char descr[120];
00460     int i;
00461     int is_list;
00462
00463     iBase_EntityHandle* out_gentities = NULL;
00464     int out_gentities_size, out_gentities_alloc = 0;
00465
00466     FBiGeom_getEntities( geom, NULL, iBase_ALL_TYPES, &gentities, &gentities_alloc, &gentities_size, &result );
00467     if( iBase_SUCCESS != result )
00468     {
00469         printf( "Problem getting all geom entities.\n" );
00470         return 0;
00471     }
00472
00473     iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities, &out_mentities_alloc,
00474                                   &out_mentities_size, &result );
00475     /* might not all be */
00476     if( iBase_SUCCESS != result )
00477     {
00478         printf( "Failed to get mesh entities related to geom entities in query_relations_test.\n" );
00479
00480         iRel_getDescription( assoc, descr, sizeof( descr ) - 1 );
00481         printf( "Entities missing relations: %s\n", descr );
00482
00483         for( i = 0; i < gentities_size; i++ )
00484         {
00485             print_geom_info( geom, gentities[i] );
00486         }
00487
00488         return 0;
00489     }
00490
00491     /* check that they're all non-null */
00492     if( out_mentities_size != gentities_size )
00493     {
00494         printf( "Number of mesh & related geom entities don't match.\n" );
00495         return 0;
00496     }
00497
00498     /* check to make sure they're mesh sets; how to do that? */
00499     for( i = 0; i < out_mentities_size; i++ )
00500     {
00501         iMesh_isList( mesh, (iBase_EntitySetHandle)out_mentities[i], &is_list, &result );
00502         if( iBase_SUCCESS != result )
00503         {
00504             printf( "Entity set returned from classification wasn't valid.\n" );
00505             return 0;
00506         }
00507     }
00508
00509     /* now turn around and check classification of those mesh entities */
00510     iRel_getSetArrEntArrRelation( assoc, pair, out_mentities, out_mentities_size, 1, &out_gentities,
00511                                   &out_gentities_alloc, &out_gentities_size, &result );
00512     if( iBase_SUCCESS != result )
00513     {
00514         printf( "Failed to get geom entities related to mesh entities in query_relations_test.\n" );
00515         return 0;
00516     }
00517
00518     /* check that they're all non-null */
00519     if( out_mentities_size != out_gentities_size )
00520     {
00521         printf( "Number of geom & related mesh entities don't match.\n" );
00522         return 0;
00523     }
00524
00525     free( gentities );
00526     gentities = NULL;
00527     free( out_mentities );
00528     out_mentities = NULL;
00529     free( out_gentities );
00530     out_gentities = NULL;
00531     /* ok, we're done */
00532     return 1;
00533 }
00534
00535 int main( int argc, char* argv[] )
00536 {
00537     /* Check command line arg */
00538     const char* geom_filename = DEFAULT_INPUT_FILE;
00539     const char* mesh_filename = DEFAULT_INPUT_FILE1;
00540
00541     int result;
00542     int number_tests                 = 0;
00543     int number_tests_successful      = 0;
00544     int number_tests_not_implemented = 0;
00545     int number_tests_failed          = 0;
00546
00547     FBiGeom_Instance geom;
00548     iMesh_Instance mesh;
00549     iRel_Instance assoc;
00550     iRel_PairHandle pair;
00551
00552     if( argc == 2 && !strcmp( argv[1], "-h" ) )
00553     {
00554         printf( "Usage: %s <geom_filename> <mesh_filename>\n", argv[0] );
00555         return 1;
00556     }
00557     else if( argc == 2 )
00558     {
00559         geom_filename = argv[1];
00560         mesh_filename = argv[1];
00561     }
00562     else if( argc == 3 )
00563     {
00564         geom_filename = argv[1];
00565         mesh_filename = argv[2];
00566     }
00567
00568     /* initialize the Geometry */
00569     FBiGeom_newGeom( 0, &geom, &result, 0 );
00570
00571     /* initialize the Mesh */
00572     iMesh_newMesh( 0, &mesh, &result, 0 );
00573
00574     /* initialize the Associate */
00575     iRel_create( 0, &assoc, &result, 0 );
00576
00577     /* Print out Header information */
00578     printf( "\n\niRel TEST PROGRAM:\n\n" );
00579
00580     /* load_geom_mesh test */
00581     printf( "   load_geom_mesh: " );
00582     result = load_geom_mesh_test( geom_filename, mesh_filename, geom, mesh );
00583     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
00584     number_tests++;
00585     printf( "\n" );
00586
00587     /* create_relation test */
00588     printf( "   create_relation: " );
00589     result = create_relation_test( assoc, geom, mesh, &pair );
00590     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
00591     number_tests++;
00592     printf( "\n" );
00593
00594     /* relate_geom_mesh test */
00595     printf( "   relate_geom_mesh: " );
00596     result = relate_geom_mesh_test( assoc, geom, mesh, pair );
00597     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
00598     number_tests++;
00599     printf( "\n" );
00600
00601     /* query_relations test */
00602     printf( "   query_relations: " );
00603     result = query_relations_test( assoc, geom, mesh, pair );
00604     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
00605     number_tests++;
00606     printf( "\n" );
00607
00608     /* summary */
00609
00610     printf( "\niRel TEST SUMMARY: \n" );
00611     printf( "   Number Tests:           %d\n", number_tests );
00612     printf( "   Number Successful:      %d\n", number_tests_successful );
00613     printf( "   Number Not Implemented: %d\n", number_tests_not_implemented );
00614     printf( "   Number Failed:          %d\n", number_tests_failed );
00615     printf( "\n\n" );
00616
00617     iRel_destroy( assoc, &result );
00618     iMesh_dtor( mesh, &result );
00619     FBiGeom_dtor( geom, &result );
00620
00621     return number_tests_failed != 0;
00622 }
