test_exo.cpp File Reference
#include "moab/Defines.h"
#include "moab/Core.hpp"
#include "ReadWriteExoII.hpp"
#include "moab/_MBSet.hpp"
#include <iostream>
+ Include dependency graph for test_exo.cpp:
Functions
std::ostream & operator<< (std::ostream &out, const std::vector< int > &v)
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 31 of file test_exo.cpp.
References ErrorCode.
    // check for file name on command line
    if( 2 != argc )
        std::cout << "Usage: " << argv[0] << " <exoII_file_name>" << std::endl;
        return 1;
    Core mdb;
    ReadWriteExoII reader( &mdb );
    ErrorCode result = reader.load_file( argv[1], NULL );
    std::cout << "Result of reading file = " << ( MB_FAILURE == result ? "FAILURE." : "SUCCESS." ) << std::endl;
    // print some data about the mesh
    int num_nodes    = mdb.total_num_nodes();
    int num_elements = mdb.total_num_elements();
    std::cout << "Total number of nodes, elements read = " << num_nodes << ", " << num_elements << std::endl;
    // get the nodeset meshsets and blocks
    std::vector< MB_MBSet* > blocks, nodesets, sidesets;
    std::vector< int > block_ids, nodeset_ids, sideset_ids;
    const std::set< MB_MBSet* >& gms = MB_MBSet::GlobalMBSets();
    std::set< MB_MBSet* >::const_iterator this_it = gms.begin(), end_it = MB_MBSet::GlobalMBSets().end();
    MB_MBSet* this_meshset;
    int bc_tag;
    for( ; this_it != end_it; ++this_it )
        // get the next set
        this_meshset = *this_it;
        bc_tag = reader.get_block_id( this_meshset );
        if( -1 != bc_tag )
            blocks.push_back( this_meshset );
            block_ids.push_back( bc_tag );
        // same for nodeset tag
        bc_tag = reader.get_nodeset_id( this_meshset );
        if( -1 != bc_tag )
            nodesets.push_back( this_meshset );
            nodeset_ids.push_back( bc_tag );
        // same for sideset tag
        bc_tag = reader.get_sideset_id( this_meshset );
        if( -1 != bc_tag )
            sidesets.push_back( this_meshset );
            sideset_ids.push_back( bc_tag );
    // std::vector<int>::iterator set_it;
    std::cout << "Block numbers read: " << std::endl;
    if( !blocks.empty() )
        std::cout << block_ids << std::endl;
    else
        std::cout << "(no blocks)" << std::endl;
    std::cout << "Nodeset numbers read: " << std::endl;
    if( !nodesets.empty() )
        std::cout << nodeset_ids << std::endl;
    else
        std::cout << "(no nodesets)" << std::endl;
    std::cout << "Sideset numbers read: " << std::endl;
    if( !sidesets.empty() )
        std::cout << sideset_ids << std::endl;
    else
        std::cout << "(no sidesets)" << std::endl;
std::ostream& operator<< ( std::ostream &  out,
const std::vector< int > &  v
Definition at line 25 of file test_exo.cpp.
    std::copy( v.begin(), v.end(), std::ostream_iterator< int >( std::cout, " " ) );
    return out;
