test_mesh_refiner.cpp File Reference
#include "moab/Core.hpp"
#include "EdgeSizeSimpleImplicit.hpp"
#include "SimplexTemplateRefiner.hpp"
#include "MeshRefiner.hpp"
#include "moab/Interface.hpp"
#include "MBParallelConventions.h"
#include "TestUtil.hpp"
#include <iostream>
#include <sstream>
#include <map>
#include <ctime>
+ Include dependency graph for test_mesh_refiner.cpp:
Functions
int TestMeshRefiner (int argc, char *argv[])
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 174 of file test_mesh_refiner.cpp.
References TestMeshRefiner().
    return TestMeshRefiner( argc, argv );
int TestMeshRefiner ( int  argc,
char *  argv[]
Definition at line 27 of file test_mesh_refiner.cpp.
References moab::Interface::create_meshset(), ErrorCode, moab::Interface::get_entities_by_type(), moab::Interface::list_entities(), moab::Interface::load_file(), MB_SUCCESS, MBTET, MESHSET_SET, output_filename, moab::MeshRefiner::refine(), moab::EntityRefiner::set_edge_size_evaluator(), moab::MeshRefiner::set_entity_refiner(), moab::EdgeSizeSimpleImplicit::set_ratio(), and moab::Interface::write_file().
Referenced by main().
    int nprocs, rank;
#ifdef MOAB_HAVE_MPI
    MPI_Init( &argc, &argv );
    MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
#else   // MOAB_HAVE_MPI
    nprocs = 1;
    rank   = 0;
#endif  // MOAB_HAVE_MPI
    // sleep(20);
    // Create the input mesh and, if -new-mesh is specified, an output mesh
    std::string ifname   = argc > 1 ? argv[1] : TestDir + "fourVolsBare.cub";
    bool input_is_output = false, do_output = false;
    std::string output_filename;
    if( argc > 2 )
        if( !strcmp( argv[2], "-new-mesh" ) )
            input_is_output = true;
        else
            do_output       = true;
            output_filename = std::string( argv[2] );
    Interface* imesh = new Core;                            // ( rank, nprocs );
    Interface* omesh = input_is_output ? imesh : new Core;  // ( rank, nprocs );
    // Use an ParallelComm object to help set up the input mesh
    ParallelComm* ipcomm = new ParallelComm( imesh, MPI_COMM_WORLD );
    // ReadParallel* readpar = new ReadParallel( imesh, ipcomm );
    EntityHandle set_handle;
    std::ostringstream parallel_options;
    if( nprocs > 1 )
        parallel_options << "PARALLEL=READ_DELETE"
                         << ";"  // NB: You can use BCAST_DELETE or READ_DELETE here.
                         //<< "PARALLEL=BCAST_DELETE" << ";" // NB: You can use BCAST_DELETE or READ_DELETE here.
                         << "PARTITION=MATERIAL_SET"
                         << "PARTITION_DISTRIBUTE"
                         << "PARALLEL_RESOLVE_SHARED_ENTS"
                         << "CPUTIME";
#endif
    ErrorCode rval = imesh->create_meshset( MESHSET_SET, set_handle );
    if( MB_SUCCESS != rval )
        std::cout << "Trouble creating set, exiting." << std::endl;
        return 1;
    rval = imesh->load_file( ifname.c_str(), &set_handle, parallel_options.str().c_str() );
        std::cout << "Trouble reading mesh file " << ifname << ", exiting." << std::endl;
        return 1;
    // Print out what we have so far, one process at a time
    for( int i = 0; i < nprocs; ++i )
        MPI_Barrier( MPI_COMM_WORLD );
        if( i == rank )
            std::cout << "\n************** Rank: " << ( rank ) << " of: " << nprocs << "\n";
            imesh->list_entities( 0, 0 );
            std::cout << "**************\n\n";
    // The refiner will need an implicit function to be used as an indicator function for
    // subdivision:
    EdgeSizeSimpleImplicit* eval = new EdgeSizeSimpleImplicit();
    eval->set_ratio( 2. );
    // Refine the mesh
    MeshRefiner* mref            = new MeshRefiner( imesh, omesh );
    SimplexTemplateRefiner* eref = new SimplexTemplateRefiner;
    mref->set_entity_refiner( eref );
    // mref->add_vertex_tag( tag_floatular );
    // mref->add_vertex_tag( tag_intular );
    // (We don't add tag_gid to the refiner's tag manager because it is special)
    eref->set_edge_size_evaluator( eval );
    Range ents_to_refine;
    imesh->get_entities_by_type( set_handle, MBTET, ents_to_refine );  // refine just the tets
    // ents_to_refine.insert( set_handle ); // refine everything multiple times (because subsets are
    // not disjoint)
#ifdef _WIN32
    struct timeval tic, toc;
    gettimeofday( &tic, 0 );
    mref->refine( ents_to_refine );
    gettimeofday( &toc, 0 );
    std::cout << "\nTime: " << ( ( toc.tv_sec - tic.tv_sec ) * 1000 + ( toc.tv_usec - tic.tv_usec ) / 1000. )
              << " ms\n\n";
#endif
    if( do_output )
        parallel_options.clear();
        if( nprocs > 1 ) parallel_options << "PARALLEL=WRITE_PART";
        omesh->write_file( output_filename.c_str(), NULL, parallel_options.str().c_str() );
    // Print out the results, one process at a time
        if( i == rank )
            omesh->list_entities( 0, 0 );
    omesh->list_entities( 0, 1 );
    // Clean up
    // delete readpar;
    delete ipcomm;
    if( omesh != imesh ) delete omesh;
    delete imesh;
    delete mref;  // mref will delete eref
    MPI_Finalize();
    return 0;
