MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"
#include "TestRunner.hpp"
#include "moab/ProgOptions.hpp"
#include <limits>
#include <cstdlib>
#include <iterator>
Defines | |
#define | ARGCV(A) ( sizeof( A ) / sizeof( ( A )[0] ) ), const_cast< char** >( A ) |
Functions | |
void | test_flag_opt_short () |
void | test_flag_opt_long_short () |
void | test_flag_opt_long () |
void | test_flag_cancel () |
void | test_flag_store_false () |
void | test_int_opt () |
void | test_int_arg () |
void | test_real_opt () |
void | test_real_arg () |
void | test_string_opt () |
void | test_string_arg () |
void | test_string_rank_subst () |
void | test_int_vect_opt () |
void | test_int_vect_arg () |
void | test_optional_args () |
void | test_optional_arg () |
void | test_squashed_short () |
int | main (int argc, char *argv[]) |
#define ARGCV | ( | A | ) | ( sizeof( A ) / sizeof( ( A )[0] ) ), const_cast< char** >( A ) |
Definition at line 33 of file test_prog_opt.cpp.
Referenced by test_flag_cancel(), test_flag_opt_long(), test_flag_opt_long_short(), test_flag_opt_short(), test_flag_store_false(), test_int_arg(), test_int_opt(), test_int_vect_arg(), test_int_vect_opt(), test_optional_arg(), test_optional_args(), test_real_arg(), test_real_opt(), test_squashed_short(), test_string_arg(), test_string_opt(), and test_string_rank_subst().
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 35 of file test_prog_opt.cpp.
References REGISTER_TEST, RUN_TESTS, test_flag_cancel(), test_flag_opt_long(), test_flag_opt_long_short(), test_flag_opt_short(), test_flag_store_false(), test_int_arg(), test_int_opt(), test_int_vect_arg(), test_int_vect_opt(), test_optional_arg(), test_optional_args(), test_real_arg(), test_real_opt(), test_squashed_short(), test_string_arg(), test_string_opt(), and test_string_rank_subst().
{ // make ProgOptions abort() rather than exiting with an // error code for invalid options so that we can catch // the signal and continue with later tests #ifndef WIN32 setenv( "MOAB_PROG_OPT_ABORT", "1", 0 ); #endif REGISTER_TEST( test_flag_opt_short ); REGISTER_TEST( test_flag_opt_long_short ); REGISTER_TEST( test_flag_opt_long ); REGISTER_TEST( test_flag_cancel ); REGISTER_TEST( test_flag_store_false ); REGISTER_TEST( test_int_opt ); REGISTER_TEST( test_int_arg ); REGISTER_TEST( test_real_opt ); REGISTER_TEST( test_real_arg ); REGISTER_TEST( test_string_opt ); REGISTER_TEST( test_string_arg ); REGISTER_TEST( test_string_rank_subst ); REGISTER_TEST( test_int_vect_opt ); REGISTER_TEST( test_int_vect_arg ); REGISTER_TEST( test_optional_args ); REGISTER_TEST( test_optional_arg ); REGISTER_TEST( test_squashed_short ); #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); #endif int result = RUN_TESTS( argc, argv ); #ifdef MOAB_HAVE_MPI MPI_Finalize(); #endif return result; }
void test_flag_cancel | ( | ) |
Definition at line 112 of file test_prog_opt.cpp.
References ProgOptions::add_cancel_opt, ProgOptions::addOpt(), ARGCV, CHECK, ProgOptions::parseCommandLine(), and value().
Referenced by main().
{ ProgOptions opts1; bool value = false; opts1.addOpt< void >( "flag", "my flag", &value, ProgOptions::add_cancel_opt ); const char* argv1[] = { "test", "--flag" }; opts1.parseCommandLine( ARGCV( argv1 ) ); CHECK( value ); ProgOptions opts2; value = true; opts2.addOpt< void >( "flag", "my flag", &value, ProgOptions::add_cancel_opt ); const char* argv2[] = { "test", "--flag", "--no-flag" }; opts2.parseCommandLine( ARGCV( argv2 ) ); CHECK( !value ); ProgOptions opts3; value = false; opts3.addOpt< void >( "flag", "my flag", &value, ProgOptions::add_cancel_opt ); const char* argv3[] = { "test", "--flag", "--no-flag", "--flag" }; opts3.parseCommandLine( ARGCV( argv3 ) ); CHECK( value ); }
void test_flag_opt_long | ( | ) |
Definition at line 99 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_EQUAL, ProgOptions::numOptSet(), ProgOptions::parseCommandLine(), and value().
{ ProgOptions opts3; bool value = false; opts3.addOpt< void >( "long,l", "long opt", &value ); const char* argv3[] = { "prog", "--long", "--long" }; opts3.parseCommandLine( ARGCV( argv3 ) ); CHECK( value ); CHECK_EQUAL( 2, opts3.numOptSet( ",l" ) ); CHECK_EQUAL( 2, opts3.numOptSet( "long,l" ) ); CHECK_EQUAL( 2, opts3.numOptSet( "long" ) ); }
void test_flag_opt_long_short | ( | ) |
Definition at line 86 of file test_prog_opt.cpp.
{ ProgOptions opts2; bool value = false; opts2.addOpt< void >( "long,l", "long opt", &value ); const char* argv2[] = { "prog", "-l", "-l" }; opts2.parseCommandLine( ARGCV( argv2 ) ); CHECK( value ); CHECK_EQUAL( 2, opts2.numOptSet( ",l" ) ); CHECK_EQUAL( 2, opts2.numOptSet( "long,l" ) ); CHECK_EQUAL( 2, opts2.numOptSet( "long" ) ); }
void test_flag_opt_short | ( | ) |
Definition at line 75 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_EQUAL, ProgOptions::numOptSet(), and ProgOptions::parseCommandLine().
{ ProgOptions opts1; bool value1 = false; opts1.addOpt< void >( ",s", "short opt", &value1 ); const char* argv1[] = { "prog", "-s" }; opts1.parseCommandLine( ARGCV( argv1 ) ); CHECK( value1 ); CHECK_EQUAL( 1, opts1.numOptSet( ",s" ) ); }
void test_flag_store_false | ( | ) |
Definition at line 136 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, ProgOptions::parseCommandLine(), and ProgOptions::store_false.
{ ProgOptions opts1; bool value1 = true; opts1.addOpt< void >( ",s", "short opt", &value1, ProgOptions::store_false ); const char* argv1[] = { "prog", "-s" }; opts1.parseCommandLine( ARGCV( argv1 ) ); CHECK( !value1 ); }
void test_int_arg | ( | ) |
Definition at line 171 of file test_prog_opt.cpp.
References ProgOptions::addRequiredArg(), ARGCV, CHECK_EQUAL, ProgOptions::getReqArg(), and ProgOptions::parseCommandLine().
{ ProgOptions opts; int val1 = 5; opts.addRequiredArg( "arg", "my test arg", &val1 ); opts.addRequiredArg< int >( "arg2", "my other test arg" ); const char* argv[] = { "test", "--", "-1", "-010" }; opts.parseCommandLine( ARGCV( argv ) ); CHECK_EQUAL( -1, val1 ); CHECK_EQUAL( -010, opts.getReqArg< int >( "arg2" ) ); // octal -10 == decimal -8 CHECK_EQUAL( -1, opts.getReqArg< int >( "arg" ) ); }
void test_int_opt | ( | ) |
Definition at line 146 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_EQUAL, ProgOptions::getOpt(), ProgOptions::getOptAllArgs(), and ProgOptions::parseCommandLine().
{ ProgOptions opts; int val1 = -1; opts.addOpt( "long,s", "my int opt", &val1 ); const char* argv[] = { "test", "-s", "2", "--long", "-0xA", "--long=5" }; opts.parseCommandLine( ARGCV( argv ) ); CHECK_EQUAL( 5, val1 ); int val2 = -1; CHECK( opts.getOpt( ",s", &val2 ) ); CHECK_EQUAL( 5, val2 ); val2 = -1; CHECK( opts.getOpt( "long,s", &val2 ) ); CHECK_EQUAL( 5, val2 ); val2 = -1; CHECK( opts.getOpt( "long", &val2 ) ); CHECK_EQUAL( 5, val2 ); std::vector< int > list; opts.getOptAllArgs( ",s", list ); CHECK_EQUAL( (size_t)3, list.size() ); CHECK_EQUAL( 2, list[0] ); CHECK_EQUAL( -10, list[1] ); CHECK_EQUAL( 5, list[2] ); }
void test_int_vect_arg | ( | ) |
Definition at line 374 of file test_prog_opt.cpp.
References ProgOptions::addRequiredArg(), ARGCV, CHECK_ARRAYS_EQUAL, CHECK_EQUAL, ProgOptions::getReqArg(), and ProgOptions::parseCommandLine().
{ ProgOptions opts; std::vector< int > list1; opts.addRequiredArg( "ints", "int list", &list1 ); const char* argv[] = { "test", "5,6,-3--1,10" }; const int exp1[] = { 5, 6, -3, -2, -1, 10 }; const int exp1_len = sizeof( exp1 ) / sizeof( exp1[0] ); opts.parseCommandLine( ARGCV( argv ) ); CHECK_ARRAYS_EQUAL( exp1, exp1_len, &list1[0], list1.size() ); CHECK_EQUAL( list1, opts.getReqArg< std::vector< int > >( "ints" ) ); }
void test_int_vect_opt | ( | ) |
Definition at line 339 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_ARRAYS_EQUAL, CHECK_EQUAL, ProgOptions::getOpt(), ProgOptions::getOptAllArgs(), ProgOptions::parseCommandLine(), and size.
{ ProgOptions opts; std::vector< int > list1, list2; opts.addOpt( "ids,d", "id list", &list1 ); const char* argv[] = { "test", "--ids=1,2,3", "--ids", "4-10", "-d", "4-5,2" }; const int exp1[] = { 1, 2, 3 }; const int exp1_len = sizeof( exp1 ) / sizeof( exp1[0] ); const int exp2[] = { 4, 5, 6, 7, 8, 9, 10 }; const int exp2_len = sizeof( exp2 ) / sizeof( exp2[0] ); const int exp3[] = { 4, 5, 2 }; const int exp3_len = sizeof( exp3 ) / sizeof( exp3[0] ); std::vector< int > all; std::copy( exp1, exp1 + exp1_len, std::back_inserter( all ) ); std::copy( exp2, exp2 + exp2_len, std::back_inserter( all ) ); std::copy( exp3, exp3 + exp3_len, std::back_inserter( all ) ); opts.parseCommandLine( ARGCV( argv ) ); CHECK_EQUAL( all, list1 ); CHECK( opts.getOpt( ",d", &list2 ) ); CHECK_ARRAYS_EQUAL( exp3, exp3_len, &list2[0], list2.size() ); std::vector< std::vector< int > > lists; opts.getOptAllArgs( "ids", lists ); CHECK_EQUAL( (size_t)3, lists.size() ); CHECK_ARRAYS_EQUAL( exp1, exp1_len, &lists[0][0], lists[0].size() ); CHECK_ARRAYS_EQUAL( exp2, exp2_len, &lists[1][0], lists[1].size() ); CHECK_ARRAYS_EQUAL( exp3, exp3_len, &lists[2][0], lists[2].size() ); list2.clear(); opts.getOptAllArgs( "ids", list2 ); CHECK_EQUAL( all, list2 ); }
void test_optional_arg | ( | ) |
Definition at line 416 of file test_prog_opt.cpp.
References ProgOptions::addOptionalArgs(), ProgOptions::addRequiredArg(), ARGCV, CHECK, CHECK_EQUAL, ProgOptions::getArgs(), init(), and ProgOptions::parseCommandLine().
{ ProgOptions opts1; std::string init, fini; opts1.addRequiredArg( "init", "required initial argument", &init ); opts1.addOptionalArgs< std::string >( 1, "mid", "optional arguments" ); opts1.addRequiredArg( "fini", "required final argument", &fini ); const char* argv1[] = { "test", "arg1", "arg2" }; opts1.parseCommandLine( ARGCV( argv1 ) ); std::vector< std::string > list; CHECK_EQUAL( "arg1", init ); CHECK_EQUAL( "arg2", fini ); opts1.getArgs( "mid", list ); CHECK( list.empty() ); ProgOptions opts2; init.clear(); fini.clear(); opts2.addRequiredArg( "init", "required initial argument", &init ); opts2.addOptionalArgs< std::string >( 1, "mid", "optional arguments" ); opts2.addRequiredArg( "fini", "required final argument", &fini ); const char* argv2[] = { "test", "arg1", "arg2", "arg3" }; opts2.parseCommandLine( ARGCV( argv2 ) ); CHECK_EQUAL( "arg1", init ); CHECK_EQUAL( "arg3", fini ); list.clear(); opts2.getArgs( "mid", list ); CHECK_EQUAL( (size_t)1, list.size() ); CHECK_EQUAL( "arg2", list[0] ); }
void test_optional_args | ( | ) |
Definition at line 389 of file test_prog_opt.cpp.
References ProgOptions::addOptionalArgs(), ProgOptions::addRequiredArg(), ARGCV, CHECK, CHECK_EQUAL, ProgOptions::getArgs(), and ProgOptions::parseCommandLine().
{ ProgOptions opts1; std::string arg; opts1.addOptionalArgs< std::string >( 0, "opts", "optional arguments" ); opts1.addRequiredArg( "req", "required final argument", &arg ); const char* argv1[] = { "test", "arg" }; opts1.parseCommandLine( ARGCV( argv1 ) ); std::vector< std::string > list; CHECK_EQUAL( "arg", arg ); opts1.getArgs( "opts", list ); CHECK( list.empty() ); ProgOptions opts2; arg.clear(); opts2.addOptionalArgs< std::string >( 0, "opts", "optional arguments" ); opts2.addRequiredArg( "req", "required final argument", &arg ); const char* argv2[] = { "test", "arg1", "arg2", "arg" }; opts2.parseCommandLine( ARGCV( argv2 ) ); CHECK_EQUAL( "arg", arg ); list.clear(); opts2.getArgs( "opts", list ); CHECK_EQUAL( (size_t)2, list.size() ); CHECK_EQUAL( "arg1", list[0] ); CHECK_EQUAL( "arg2", list[1] ); }
void test_real_arg | ( | ) |
Definition at line 210 of file test_prog_opt.cpp.
References ProgOptions::addRequiredArg(), ARGCV, CHECK_REAL_EQUAL, EPS, epsilon, ProgOptions::getReqArg(), and ProgOptions::parseCommandLine().
{ const double EPS = std::numeric_limits< double >::epsilon(); ProgOptions opts; double val1 = 5; opts.addRequiredArg( "arg", "my test arg", &val1 ); opts.addRequiredArg< double >( "arg2", "my other test arg" ); const char* argv[] = { "test", "--", "-1.2", "1.01e-3" }; opts.parseCommandLine( ARGCV( argv ) ); CHECK_REAL_EQUAL( -1.2, val1, EPS ); CHECK_REAL_EQUAL( 1.01e-3, opts.getReqArg< double >( "arg2" ), EPS ); CHECK_REAL_EQUAL( -1.2, opts.getReqArg< double >( "arg" ), EPS ); }
void test_real_opt | ( | ) |
Definition at line 184 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_EQUAL, CHECK_REAL_EQUAL, EPS, epsilon, ProgOptions::getOpt(), ProgOptions::getOptAllArgs(), and ProgOptions::parseCommandLine().
{ const double EPS = std::numeric_limits< double >::epsilon(); ProgOptions opts; double val1 = -1; opts.addOpt( "long,s", "my real opt", &val1 ); const char* argv[] = { "test", "-s", "2", "--long", "2e5", "--long=-0.01" }; opts.parseCommandLine( ARGCV( argv ) ); CHECK_REAL_EQUAL( -0.01, val1, EPS ); double val2 = -1; CHECK( opts.getOpt( ",s", &val2 ) ); CHECK_REAL_EQUAL( -0.01, val2, EPS ); val2 = -1; CHECK( opts.getOpt( "long,s", &val2 ) ); CHECK_REAL_EQUAL( -0.01, val2, EPS ); val2 = -1; CHECK( opts.getOpt( "long", &val2 ) ); CHECK_REAL_EQUAL( -0.01, val2, EPS ); std::vector< double > list; opts.getOptAllArgs( ",s", list ); CHECK_EQUAL( (size_t)3, list.size() ); CHECK_REAL_EQUAL( 2, list[0], EPS ); CHECK_REAL_EQUAL( 2e5, list[1], EPS ); CHECK_REAL_EQUAL( -0.01, list[2], EPS ); }
void test_squashed_short | ( | ) |
Definition at line 447 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_EQUAL, CHECK_REAL_EQUAL, ProgOptions::numOptSet(), and ProgOptions::parseCommandLine().
{ ProgOptions opts; int intval = 0; double realval = 0; bool flagval = false; std::string strval; opts.addOpt< void >( ",f", "flag", &flagval ); opts.addOpt( ",i", "int", &intval ); opts.addOpt( ",r", "real", &realval ); opts.addOpt( ",s", "str", &strval ); const char* argv[] = { "test", "-ifsrff", "-0xBEEF", "string", "-1.0e55" }; opts.parseCommandLine( ARGCV( argv ) ); CHECK_EQUAL( -0xBEEF, intval ); CHECK_REAL_EQUAL( -1.0e55, realval, 1e-6 ); CHECK_EQUAL( "string", strval ); CHECK( flagval ); CHECK_EQUAL( 3, opts.numOptSet( ",f" ) ); CHECK_EQUAL( 1, opts.numOptSet( ",i" ) ); CHECK_EQUAL( 1, opts.numOptSet( ",r" ) ); CHECK_EQUAL( 1, opts.numOptSet( ",s" ) ); }
void test_string_arg | ( | ) |
Definition at line 268 of file test_prog_opt.cpp.
{ ProgOptions opts; std::string val2; opts.addRequiredArg< std::string >( "arg", "my test arg" ); opts.addRequiredArg( "arg2", "my other test arg", &val2 ); const char* argv[] = { "test", "my_string", "with spaces" }; opts.parseCommandLine( ARGCV( argv ) ); CHECK_EQUAL( "with spaces", val2 ); CHECK_EQUAL( "my_string", opts.getReqArg< std::string >( "arg" ) ); CHECK_EQUAL( "with spaces", opts.getReqArg< std::string >( "arg2" ) ); }
void test_string_opt | ( | ) |
Definition at line 224 of file test_prog_opt.cpp.
{ ProgOptions opts; std::string val1; opts.addOpt( "long,s", "my first opt", &val1 ); opts.addOpt< std::string >( "second,2", "my second opt" ); const char* argv[] = { "test", "--long", "2", "-s", "foobar", "-2", "two", "--second=testval" }; opts.parseCommandLine( ARGCV( argv ) ); CHECK_EQUAL( "foobar", val1 ); std::string val2; CHECK( opts.getOpt( ",s", &val2 ) ); CHECK_EQUAL( "foobar", val2 ); val2.clear(); CHECK( opts.getOpt( "long,s", &val2 ) ); CHECK_EQUAL( "foobar", val2 ); val2.clear(); CHECK( opts.getOpt( "long", &val2 ) ); CHECK_EQUAL( "foobar", val2 ); val2.clear(); CHECK( opts.getOpt( ",2", &val2 ) ); CHECK_EQUAL( "testval", val2 ); val2.clear(); CHECK( opts.getOpt( "second,2", &val2 ) ); CHECK_EQUAL( "testval", val2 ); val2.clear(); CHECK( opts.getOpt( "second", &val2 ) ); CHECK_EQUAL( "testval", val2 ); std::vector< std::string > list; opts.getOptAllArgs( "long", list ); CHECK_EQUAL( (size_t)2, list.size() ); CHECK_EQUAL( "2", list[0] ); CHECK_EQUAL( "foobar", list[1] ); list.clear(); opts.getOptAllArgs( ",2", list ); CHECK_EQUAL( (size_t)2, list.size() ); CHECK_EQUAL( "two", list[0] ); CHECK_EQUAL( "testval", list[1] ); }
void test_string_rank_subst | ( | ) |
Definition at line 281 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ProgOptions::addRequiredArg(), ARGCV, buffer, CHECK, CHECK_EQUAL, ProgOptions::getOpt(), ProgOptions::getOptAllArgs(), ProgOptions::getReqArg(), MPI_COMM_WORLD, ProgOptions::parseCommandLine(), rank, ProgOptions::rank_subst, size, and MBMesquite::width().
{ std::string exp1 = "ddd%"; std::string exp2 = "%"; std::string exp2b = "foo%bar"; std::string exp3 = "%string%"; std::string exp4 = "file.%"; ProgOptions opts; std::string val1, val2, val3, val4; opts.addOpt( ",n", "no subst flag", &val1, 0 ); opts.addOpt( "dosub,s", "subst flag", &val2, ProgOptions::rank_subst ); opts.addRequiredArg( "nos", "no subst arg", &val3, 0 ); opts.addRequiredArg( "sub", "subst arg", &val4, ProgOptions::rank_subst ); std::string eqflg( "--dosub=" ); eqflg += exp2; const char* argv[] = { "test", exp3.c_str(), exp4.c_str(), "-s", exp2b.c_str(), "-n", exp1.c_str(), eqflg.c_str() }; opts.parseCommandLine( ARGCV( argv ) ); #ifdef MOAB_HAVE_MPI int rank, size; MPI_Comm_rank( MPI_COMM_WORLD, &rank ); MPI_Comm_size( MPI_COMM_WORLD, &size ); char buffer[64]; int width = 1; while( size > 10 ) { width++; size /= 10; } sprintf( buffer, "%0*d", width, rank ); exp2 = buffer; exp2b = std::string( "foo" ) + buffer + "bar"; exp4 = std::string( "file." ) + buffer; #endif CHECK_EQUAL( exp1, val1 ); CHECK_EQUAL( exp2, val2 ); CHECK_EQUAL( exp3, val3 ); CHECK_EQUAL( exp4, val4 ); val1.clear(); val2.clear(); CHECK( opts.getOpt( ",n", &val1 ) ); CHECK( opts.getOpt( "dosub", &val2 ) ); CHECK_EQUAL( exp1, val1 ); CHECK_EQUAL( exp2, val2 ); CHECK_EQUAL( exp3, opts.getReqArg< std::string >( "nos" ) ); CHECK_EQUAL( exp4, opts.getReqArg< std::string >( "sub" ) ); std::vector< std::string > list; opts.getOptAllArgs( ",s", list ); CHECK_EQUAL( (size_t)2, list.size() ); CHECK_EQUAL( exp2b, list[0] ); CHECK_EQUAL( exp2, list[1] ); }
