test_remapping.cpp File Reference
#include <iostream>
#include "moab/Core.hpp"
#include "moab/Remapping/TempestRemapper.hpp"
#include "Internals.hpp"
#include "TestRunner.hpp"
+ Include dependency graph for test_remapping.cpp:
Defines
#define IS_BUILDING_MB
Functions
void test_tempest_cs_create ()
void test_tempest_rll_create ()
void test_tempest_ico_create ()
void test_tempest_mpas_create ()
void test_tempest_overlap_combinations ()
void test_tempest_to_moab_convert ()
int main (int argc, char **argv)
Variables
static const double radius = 1.0
const double MOAB_PI = 3.1415926535897932384626433832795028841971693993751058209749445923
static const double surface_area = 4.0 * MOAB_PI * radius * radius
static const std::string outFilenames [5]
Define Documentation
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 33 of file test_remapping.cpp.
Function Documentation
Definition at line 73 of file test_remapping.cpp.
References CHECK_EQUAL, CHECK_REAL_EQUAL, moab::error(), ierr, outFilenames, and surface_area.
Referenced by main().
    NcError error( NcError::verbose_nonfatal );
    const int blockSize           = 30;
    const std::string outFilename = outFilenames[0];
    std::cout << "Creating TempestRemap Cubed-Sphere Mesh ...\n";
    Mesh tempest_mesh;
    int ierr = GenerateCSMesh( tempest_mesh, blockSize, outFilename, "NetCDF4" );
    CHECK_EQUAL( ierr, 0 );
    // Compute the surface area of CS mesh
    const double sphere_area = tempest_mesh.CalculateFaceAreas( false );
    CHECK_REAL_EQUAL( sphere_area, surface_area, 1e-10 );
Definition at line 110 of file test_remapping.cpp.
    const bool computeDual        = false;
    const std::string outFilename = outFilenames[2];
    std::cout << "Creating TempestRemap Icosahedral Mesh ...\n";
    Mesh tempest_mesh;
    int ierr = GenerateICOMesh( tempest_mesh, blockSize, computeDual, outFilename, "NetCDF4" );
    // Compute the surface area of ICO mesh
Definition at line 127 of file test_remapping.cpp.
    const bool computeDual        = true;
    const std::string outFilename = outFilenames[3];
    std::cout << "Creating TempestRemap MPAS Mesh (dual of the Icosahedral) ...\n";
    Mesh tempest_mesh;
    // Compute the surface area of MPAS mesh
Definition at line 144 of file test_remapping.cpp.
    const std::string outFilename = outFilenames[4];
    Mesh inpMesh( outFilenames[0] );
    // verify input mesh area first
    const double inpArea = inpMesh.CalculateFaceAreas( false );
    CHECK_REAL_EQUAL( inpArea, surface_area, 1e-10 );
    for( int isrc = 0; isrc < 4; ++isrc )
        for( int jsrc = 0; jsrc < 4; ++jsrc )
            std::cout << "Computing Overlap between " << outFilenames[isrc] << " and " << outFilenames[jsrc]
                      << " ...\n";
            Mesh tempest_mesh;
            int ierr = GenerateOverlapMesh( outFilenames[isrc], outFilenames[jsrc], tempest_mesh, outFilename,
                                            "NetCDF4", "exact", false, false, false, false, false );
            // verify overlap mesh area
            const double ovArea = tempest_mesh.CalculateFaceAreas( false );
            CHECK_REAL_EQUAL( ovArea, surface_area, 1e-10 );
Definition at line 89 of file test_remapping.cpp.
    const std::string outFilename = outFilenames[1];
    std::cout << "Creating TempestRemap Latitude-Longitude Mesh ...\n";
    Mesh tempest_mesh;
    int ierr =
        GenerateRLLMesh( tempest_mesh, blockSize * 2, blockSize, 0.0, 360.0, -90.0, 90.0, false, false, true, "", "",
                         "",  // std::string strInputFile, std::string strInputFileLonName, std::string
                              // strInputFileLatName,
                         outFilename, "NetCDF4",  // std::string strOutputFile, std::string strOutputFormat
                         false );
    // Compute the surface area of RLL mesh
Definition at line 171 of file test_remapping.cpp.
References CHECK, moab::ParallelComm::check_all_shared_handles(), CHECK_EQUAL, CHECK_ERR, moab::TempestRemapper::constructEdgeMap, moab::TempestRemapper::ConvertMeshToTempest(), moab::TempestRemapper::ConvertTempestMesh(), moab::TempestRemapper::CS, moab::error(), ErrorCode, moab::TempestRemapper::GetMesh(), moab::TempestRemapper::GetMeshSet(), moab::TempestRemapper::initialize(), moab::TempestRemapper::LoadMesh(), moab::TempestRemapper::meshValidate, MPI_COMM_WORLD, outFilenames, moab::Remapper::SourceMesh, and moab::Remapper::TargetMesh.
    // Allocate and create MOAB Remapper object
    moab::ErrorCode rval;
    moab::Interface* mbCore = new( std::nothrow ) moab::Core;
    CHECK( NULL != mbCore );
#ifdef MOAB_HAVE_MPI
    moab::ParallelComm* pcomm       = new moab::ParallelComm( mbCore, MPI_COMM_WORLD, 0 );
    moab::TempestRemapper* remapper = new moab::TempestRemapper( mbCore, pcomm );
#else
    moab::TempestRemapper* remapper = new moab::TempestRemapper( mbCore );
#endif
    remapper->meshValidate     = true;
    remapper->constructEdgeMap = true;
    remapper->initialize();
    rval = pcomm->check_all_shared_handles();CHECK_ERR( rval );
#endif
    rval = remapper->LoadMesh( moab::Remapper::SourceMesh, outFilenames[0], moab::TempestRemapper::CS );CHECK_ERR( rval );
    // Load the meshes and validate
    rval = remapper->ConvertTempestMesh( moab::Remapper::SourceMesh );CHECK_ERR( rval );
    Mesh* srcTempest = remapper->GetMesh( moab::Remapper::SourceMesh );
    moab::EntityHandle srcset = remapper->GetMeshSet( moab::Remapper::SourceMesh );
    moab::EntityHandle& tgtset = remapper->GetMeshSet( moab::Remapper::TargetMesh );
    tgtset = srcset;
    rval = remapper->ConvertMeshToTempest( moab::Remapper::TargetMesh );CHECK_ERR( rval );
    Mesh* tgtTempest = remapper->GetMesh( moab::Remapper::TargetMesh );
    const size_t tempest_nodes_src = srcTempest->nodes.size(), tempest_elems_src = srcTempest->faces.size();
    const size_t tempest_nodes_tgt = tgtTempest->nodes.size(), tempest_elems_tgt = tgtTempest->faces.size();
    CHECK_EQUAL( tempest_nodes_src, tempest_nodes_tgt );
    CHECK_EQUAL( tempest_elems_src, tempest_elems_tgt );
    delete remapper;
    delete pcomm;
#endif
    delete mbCore;
Variable Documentation
Definition at line 42 of file test_remapping.cpp.
const std::string outFilenames[5] [static]
Initial value:
 { "outTempestCS.g", "outTempestRLL.g", "outTempestICO.g", "outTempestICOD.g",
                                             "outTempestOV.g" }
Definition at line 44 of file test_remapping.cpp.
Referenced by test_tempest_cs_create(), test_tempest_ico_create(), test_tempest_mpas_create(), test_tempest_overlap_combinations(), test_tempest_rll_create(), and test_tempest_to_moab_convert().
const double radius = 1.0 [static]
Definition at line 41 of file test_remapping.cpp.
