testc_cbind.cpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 /** TSTT Mesh Interface Unit Test
00017  *
00018  * This program tests TSTT mesh interface functions through the SIDL interface.
00019  * In a nutshell, the test creates (or accesses) an implementation instance,
00020  * tells it to load a file (specified on the command line), then calls a
00021  * number of functions evaluating that mesh.  This test also tests mesh, set
00022  * and tag creation and evaluation functions.
00023  *
00024  * Usage: testcxx <mesh_file_name>
00025  *
00026  * Compiling
00027  * ---------
00028  * 1. Build your server (your implementation of the TSTT mesh interface) under
00029  *    SIDL/Babel and put it in a library in the Babel-generated server directory,
00030  *    ${SERVER_DIR}/libimpl.so.  Any include files needed to instantiate this
00031  *    server from applications should also be in that directory.  See note a) below.
00032  * 2. Change the definition of IMPLEMENTATION_CLASS below to be the
00033  *    namespace-qualified name of your implementation class.  This definition is
00034  *    used in the main to instantiate the server using the SIDL _create function, e.g.
00035  *    .   TSTTB::Mesh mesh = IMPLEMENTATION_CLASS._create();
00036  *    (we put the definition of IMPLEMENTATION_CLASS at the top of this file so that
00037  *    you don't have to understand the rest of the source code to use this test).  See
00038  *    note b) below.
00039  * 3. Include the file(s) needed which declare the implementation's namespace and
00040  *    class
00041  * 4. Compile this test file to an object file:
00042  *        g++ -fpic -I. -I${BABEL}/include -I${SERVER_DIR} -c testcxx.cpp
00043  * 5. Link the application:
00044  *        g++ -o testcxx testcxx.o -ltest -L${BABEL_LIBS} -lsidl
00045  *
00046  * Notes
00047  * -----
00048  * a) The files don't absolutely need to be arranged as described above.  For
00049  *    example, some projects put their custom implementation files somewhere besides
00050  *    ${SERVER_DIR}, to keep them separate from Babel-generated files.
00051  * b) This test assumes interface instances are created using a direct call to the
00052  *    SIDL _create() function for that class.  Another way to do this would be to
00053  *    call a factory linked into the test.  To change the method used to construct
00054  *    the interface instance for this test, see the use of IMPLEMENTATION_CLASS towards
00055  *    the end of this file.
00056  */
00057
00058 #include <cstdio>
00059 #include <cstring>
00060 #include <cstdlib>
00061 #include "iMesh.h"
00062 #include "iMesh_extensions.h"
00063 #include "moab/Types.hpp"
00064 #include "TestUtil.hpp"
00065 using namespace moab;
00066 extern enum iBase_ErrorType iBase_ERROR_MAP[MB_FAILURE + 1];
00067
00068 #define FALSE 0
00069 #define TRUE  1
00070
00071 #define DEFAULT_TEST_FILE brick.vtk
00072
00073 // clang-format off
00074
00075 #ifdef SRCDIR
00076 #define DEFAULT_INPUT_FILE STRINGIFY( SRCDIR/DEFAULT_TEST_FILE )
00077 #else
00078 #define DEFAULT_INPUT_FILE STRINGIFY( DEFAULT_TEST_FILE )
00079 #endif
00080
00081 static bool assert_pass;
00082 #define ASSERT( COND )                                     \
00083     assert_pass = true;                                    \
00084     if( !( COND ) )                                        \
00085     {                                                      \
00086         PRINT_ASSERT_FAILURE( #COND, __FILE__, __LINE__ ); \
00087         assert_pass = false;                               \
00088     }
00089
00090 void PRINT_ASSERT_FAILURE( const char* cond, const char* file, int line )
00091 {
00092     printf( "Condition: %s\n", cond );
00093     printf( " failed at %s line %d\n", file, line );
00094 }
00095
00096 #define CHK( err )                                                       \
00097     if( (err) != iBase_SUCCESS ) do                                        \
00098         {        \
00099             printf( "%s:%d ITAPS error %d\n", __FILE__, __LINE__, err ); \
00100             return 0;                                                    \
00101     } while( 0 )
00102
00103 // clang-format on
00104
00105 static iBase_EntitySetHandle root_set;
00106
00107 /*!
00108   prints out a result string based on the value of error_code
00109 */
00110 void handle_error_code( const int result, int* number_failed, int* /*number_not_implemented*/, int* number_successful )
00111 {
00112     if( result )
00113     {
00114         printf( "Success\n" );
00115         ( *number_successful )++;
00116     }
00117     else
00118     {
00119         printf( "Failure\n" );
00120         ( *number_failed )++;
00121     }
00122 }
00123
00124 /*!
00125   @test
00126   Load Mesh
00127   @li Load a mesh file
00128 */
00129 int load_mesh_test( const char* filename, iMesh_Instance mesh )
00130 {
00131     /* load a mesh */
00132     int result;
00133     iMesh_load( mesh, root_set, filename, NULL, &result, strlen( filename ), 0 );
00134     if( iBase_SUCCESS != result )
00135     {
00136         printf( "ERROR : can not load a mesh from file %s\n", filename );
00137         return FALSE;
00138     }
00139
00140     return TRUE;
00141 }
00142
00143 #define TEST_ERROR_CODE( A, B )        \
00144     if( iBase_ERROR_MAP[( A )] != ( B ) )                                                        \
00145     {        \
00146         printf( "ERROR: Invalid mapping for MOAB error code %s\n", #A );                         \
00147         printf( "       Expected %d, actual is %d\n", (int)iBase_ERROR_MAP[( A )], (int)( B ) ); \
00148         return FALSE;        \
00149     }
00150
00151 int error_code_test( iMesh_Instance /*mesh*/ )
00152 {
00153     TEST_ERROR_CODE( MB_SUCCESS, iBase_SUCCESS )
00154     TEST_ERROR_CODE( MB_TYPE_OUT_OF_RANGE, iBase_INVALID_ENTITY_TYPE )
00155     TEST_ERROR_CODE( MB_MEMORY_ALLOCATION_FAILED, iBase_MEMORY_ALLOCATION_FAILED )
00156     TEST_ERROR_CODE( MB_ENTITY_NOT_FOUND, iBase_INVALID_ENTITY_HANDLE )
00157     TEST_ERROR_CODE( MB_TAG_NOT_FOUND, iBase_TAG_NOT_FOUND )
00158     TEST_ERROR_CODE( MB_FILE_DOES_NOT_EXIST, iBase_FILE_NOT_FOUND )
00159     TEST_ERROR_CODE( MB_UNSUPPORTED_OPERATION, iBase_NOT_SUPPORTED )
00160     TEST_ERROR_CODE( MB_UNHANDLED_OPTION, iBase_INVALID_ARGUMENT )
00161     TEST_ERROR_CODE( MB_FAILURE, iBase_FAILURE )
00162     return TRUE;
00163 }
00164
00165 /*!
00166   @test
00167   TSTT topology dimension Test
00168   @li Check 2d topology dimensions
00169 */
00170 int topology_dimension_test( iMesh_Instance mesh )
00171 {
00172     iBase_EntityHandle* faces = NULL;
00173     int faces_alloc           = 0, faces_size;
00174     int result, i;
00175     int* dimensions      = NULL;
00176     int dimensions_alloc = 0, dimensions_size;
00177
00178     /* first get 2D entities */
00179     iMesh_getEntities( mesh, root_set, iBase_FACE, iMesh_ALL_TOPOLOGIES, &faces, &faces_alloc, &faces_size, &result );
00180     if( iBase_SUCCESS != result )
00181     {
00182         printf( "Failed to get faces in entity_sets_test.\n" );
00183         return FALSE;
00184     }
00185
00186     /* get dimensions of faces */
00187     iMesh_getEntArrType( mesh, faces, faces_size, &dimensions, &dimensions_alloc, &dimensions_size, &result );
00188     if( iBase_SUCCESS != result )
00189     {
00190         printf( "Failed to get dimensions of faces in topology_test.\n" );
00191         free( faces );
00192         return FALSE;
00193     }
00194
00195     if( dimensions_size != faces_size )
00196     {
00197         printf( "Didn't get the right number of types in topology_test.\n" );
00198         free( faces );
00199         free( dimensions );
00200         return FALSE;
00201     }
00202
00203     /* make sure all elements are 2D */
00204     for( i = 0; i < faces_size; i++ )
00205     {
00206         if( dimensions[i] != iBase_FACE )
00207         {
00208             free( faces );
00209             free( dimensions );
00210             return FALSE;
00211         }
00212     }
00213
00214     free( faces );
00215     free( dimensions );
00216
00217     return TRUE;
00218 }
00219
00220 /*!
00221   @test
00222   TSTT topology adjacency Test
00223   @li Check topology information
00224   @li Check adjacency
00225   @li Get interior and exterior elements
00226 */
00227 /* make each topological entity vectors, check their topology */
00228 /* types, get interior and exterior faces of hexes */
00229 int topology_adjacency_test( iMesh_Instance mesh )
00230 {
00231     int result, i, j, entities_alloc, entities_size, *topologies;
00232     int topologies_alloc, topologies_size;
00233     iBase_EntityHandle *entities, *entity_vectors[iMesh_ALL_TOPOLOGIES] = { NULL };
00234     int entity_vectors_sizes[iMesh_ALL_TOPOLOGIES] = { 0 };
00235     int top_j, num_tops, region_type, num_region;
00236     iBase_EntityHandle* adj_faces   = NULL;
00237     int adj_faces_alloc             = 0, adj_faces_size;
00238     int* face_offsets               = NULL;
00239     int face_offsets_alloc          = 0, face_offsets_size, face_loaded;
00240     iBase_EntityHandle* adj_regions = NULL;
00241     int adj_regions_alloc           = 0, adj_regions_size;
00242     int* region_offsets             = NULL;
00243     int region_offsets_alloc        = 0, region_offsets_size;
00244     iBase_EntityHandle *interior, *exterior;
00245     int num_int = 0, num_ext = 0, found, next_offset, iter;
00246     int num_faces_per_region;
00247     ;
00248
00249     /* fill the vectors of each topology entities */
00250     /* like lines vector, polygon vector, triangle vector, */
00251     /* quadrilateral, polyhedrron, tet, hex, prism, pyramid, */
00252     /* septahedron vectors */
00253     for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
00254     {
00255         entities       = NULL;
00256         entities_alloc = 0;
00257         iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, i, &entities, &entities_alloc, &entities_size, &result );
00258         if( iBase_SUCCESS != result )
00259         {
00260             printf( "Failed to get entities in adjacencies_test.\n" );
00261             return FALSE;
00262         }
00263
00264         if( entities_alloc > 0 )
00265         {
00266             topologies       = NULL;
00267             topologies_alloc = 0;
00268             iMesh_getEntArrTopo( mesh, entities, entities_alloc, &topologies, &topologies_alloc, &topologies_size,
00269                                  &result );
00270             if( iBase_SUCCESS != result )
00271             {
00272                 printf( "Failed to get topologies in adjacencies_test.\n" );
00273                 return FALSE;
00274             }
00275
00276             if( topologies_size != entities_size )
00277             {
00278                 printf( "Didn't get the right number of topologies "
00279                         "in topology_adjacency_test.\n" );
00280                 free( topologies );
00281                 free( entities );
00282                 return FALSE;
00283             }
00284
00285             /* put entities into vectors of each topology */
00286             entity_vectors[i] = (iBase_EntityHandle*)malloc( entities_size * sizeof( iBase_EntityHandle ) );
00287
00288             for( j = 0; j < entities_size; j++ )
00289             {
00290                 if( topologies[j] < iMesh_POINT || topologies[j] >= iMesh_ALL_TOPOLOGIES )
00291                     printf( "Didn't find entity type for this topology." );
00292                 else
00293                 {
00294                     entity_vectors[i][entity_vectors_sizes[i]] = entities[j];
00295                     entity_vectors_sizes[i]++;
00296                 }
00297             }
00298
00299             free( topologies );
00300         }
00301
00302         free( entities );
00303     }
00304
00305     /* check number of entities for each topology */
00306     for( top_j = 0; top_j < iMesh_ALL_TOPOLOGIES; top_j++ )
00307     {
00308         num_tops = 0;
00309         iMesh_getNumOfTopo( mesh, root_set, top_j, &num_tops, &result );
00310         if( iBase_SUCCESS != result )
00311         {
00312             printf( "Failed to get number of topologies in adjacencies_test.\n" );
00313             for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
00314                 free( entity_vectors[i] );
00315             return FALSE;
00316         }
00317
00318         if( entity_vectors_sizes[top_j] != num_tops )
00319         {
00320             printf( "Topology count mismatch.\n" );
00321             for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
00322                 free( entity_vectors[i] );
00323             return FALSE;
00324         }
00325     }
00326
00327     /* change if 3d topology entities are added or removed */
00328     for( region_type = iMesh_TETRAHEDRON; region_type < iMesh_ALL_TOPOLOGIES; region_type++ )
00329     {
00330         /* get all adjacent faces of regions  */
00331         iBase_EntityHandle* region_vector = entity_vectors[region_type];
00332
00333         num_region = entity_vectors_sizes[region_type];
00334
00335         if( num_region > 0 )
00336         {
00337             adj_faces          = NULL;
00338             adj_faces_alloc    = 0;
00339             face_offsets       = NULL;
00340             face_offsets_alloc = 0;
00341
00342             iMesh_getEntArrAdj( mesh, region_vector, num_region, iBase_FACE, &adj_faces, &adj_faces_alloc,
00343                                 &adj_faces_size, &face_offsets, &face_offsets_alloc, &face_offsets_size, &result );
00344             if( iBase_SUCCESS != result )
00345             {
00346                 printf( "Failed to get adjacent faces of regions in adjacencies_test.\n" );
00347                 for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
00348                     free( entity_vectors[i] );
00349                 return FALSE;
00350             }
00351
00352             if( num_region + 1 != face_offsets_size )
00353             {
00354                 printf( "Number of offsets didn't agree with number of "
00355                         "regions in topology_adjacency_test.\n" );
00356                 free( face_offsets );
00357                 free( adj_faces );
00358                 for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
00359                     free( entity_vectors[i] );
00360                 return FALSE;
00361             }
00362
00363             face_loaded = FALSE;
00364
00365             /* check # of faces really loaded */
00366             if( region_type == iMesh_TETRAHEDRON )
00367             {
00368                 if( adj_faces_size == 4 * num_region ) face_loaded = TRUE;
00369             }
00370             else if( region_type == iMesh_HEXAHEDRON )
00371             {
00372                 if( adj_faces_size == 6 * num_region ) face_loaded = TRUE;
00373             }
00374             else if( region_type == iMesh_PRISM )
00375             {
00376                 if( adj_faces_size == 5 * num_region ) face_loaded = TRUE;
00377             }
00378             else if( region_type == iMesh_PYRAMID )
00379             {
00380                 if( adj_faces_size == 5 * num_region ) face_loaded = TRUE;
00381             }
00382             else if( region_type == iMesh_SEPTAHEDRON )
00383             {
00384                 if( adj_faces_size == 7 * num_region ) face_loaded = TRUE;
00385             }
00386             else
00387                 face_loaded = FALSE;
00388
00389             /* get all adjacent regions of adjacent faces */
00390             adj_regions          = NULL;
00391             adj_regions_alloc    = 0;
00392             region_offsets       = NULL;
00393             region_offsets_alloc = 0;
00394             iMesh_getEntArrAdj( mesh, adj_faces, adj_faces_size, iBase_REGION, &adj_regions, &adj_regions_alloc,
00395                                 &adj_regions_size, &region_offsets, &region_offsets_alloc, &region_offsets_size,
00396                                 &result );
00397             if( iBase_SUCCESS != result )
00398             {
00399                 printf( "Failed to get regions from faces in adjacencies_test.\n" );
00400                 free( face_offsets );
00401                 free( adj_faces );
00402                 for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
00403                     free( entity_vectors[i] );
00404                 return FALSE;
00405             }
00406
00407             if( adj_faces_size + 1 != region_offsets_size )
00408             {
00409                 printf( "Number of offsets didn't agree with number of faces in "
00410                         "topology_adjacency_test.\n" );
00411                 free( face_offsets );
00412                 free( region_offsets );
00413                 free( adj_faces );
00414                 free( adj_regions );
00415                 for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
00416                     free( entity_vectors[i] );
00417                 return FALSE;
00418             }
00419
00420             interior = (iBase_EntityHandle*)malloc( adj_faces_size * sizeof( iBase_EntityHandle ) ),
00421             exterior = (iBase_EntityHandle*)malloc( adj_faces_size * sizeof( iBase_EntityHandle ) );
00422             num_int  = 0;
00423             num_ext  = 0;
00424
00425             /* find the interior faces having two adjacent regions */
00426             for( i = 0; i < adj_faces_size; i++ )
00427             {
00428                 next_offset = 0;
00429                 if( i == adj_faces_size - 1 )
00430                     next_offset = adj_regions_size;
00431                 else
00432                     next_offset = region_offsets[i + 1];
00433
00434                 if( next_offset - region_offsets[i] == 2 )
00435                 {
00436                     found = FALSE;
00437                     for( iter = 0; iter < num_int; iter++ )
00438                     {
00439                         if( interior[iter] == adj_faces[i] )
00440                         {
00441                             found = TRUE;
00442                             break;
00443                         }
00444                     }
00445                     if( !found ) interior[num_int++] = adj_faces[i];
00446                 }
00447             }
00448
00449             /* now remove any interior faces from the previous adjacent faces list */
00450             /* and we should be left with exterior faces */
00451             for( i = 0; i < adj_faces_size; i++ )
00452             {
00453                 found = FALSE;
00454                 for( iter = 0; iter < num_int; iter++ )
00455                 {
00456                     if( interior[iter] == adj_faces[i] )
00457                     {
00458                         found = TRUE;
00459                         break;
00460                     }
00461                 }
00462                 if( !found ) exterior[num_ext++] = adj_faces[i];
00463             }
00464
00465             num_faces_per_region = face_offsets[1] - face_offsets[0];
00466
00467             /* check # of exterior and interior faces */
00468             /* should be #exterior_faces + 2 * #interior_faces = #faces_per_region */
00469             /* * #regions */
00470             if( face_loaded )
00471             {
00472                 if( num_ext + 2 * num_int != num_faces_per_region * num_region )
00473                 {
00474                     printf( "exterior/interior failure: %d ext, %d int, %d regions, %d faces per\n", num_ext, num_int,
00475                             num_region, num_faces_per_region );
00476                     free( face_offsets );
00477                     free( region_offsets );
00478                     free( adj_faces );
00479                     free( adj_regions );
00480                     free( interior );
00481                     free( exterior );
00482                     for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
00483                         free( entity_vectors[i] );
00484                     return FALSE;
00485                 }
00486             }
00487
00488             free( face_offsets );
00489             free( region_offsets );
00490             free( adj_faces );
00491             free( adj_regions );
00492             free( interior );
00493             free( exterior );
00494         }
00495     }
00496
00497     for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
00498         free( entity_vectors[i] );
00499
00500     return TRUE;
00501 }
00502
00503 int qsort_comp_handles( const void* h1, const void* h2 )
00504 {
00505     return *(char**)h1 - *(char**)h2;
00506 }
00507
00508 /*!
00509   @test
00510   TSTT EntityType Connectivity Test
00511   @li Get coordinates for all type enities
00512 */
00513
00514 int entity_connectivity_test( iMesh_Instance mesh )
00515 {
00516     int type, result;
00517     int *offsets, offsets_alloc, offsets_size;
00518     int *indices, indices_alloc, indices_size;
00519     iBase_EntityHandle *entities, *adj_ents, *entities2, *sorted;
00520     int entities_alloc, entities_size, adj_ents_alloc, adj_ents_size;
00521     int entities2_alloc, entities2_size;
00522     iBase_EntityHandle adj_ents2[27], *adj_ents2_ptr = adj_ents2;
00523     int adj_ents2_alloc = 27, adj_ents2_size, i, size;
00524
00525     for( type = iBase_EDGE; type < iBase_ALL_TYPES; type++ )
00526     {
00527         entities       = NULL;
00528         entities_alloc = 0;
00529         adj_ents       = NULL;
00530         adj_ents_alloc = 0;
00531         indices        = NULL;
00532         indices_alloc  = 0;
00533         offsets        = NULL;
00534         offsets_alloc  = 0;
00535         iMesh_getAdjEntIndices( mesh, root_set, type, iMesh_ALL_TOPOLOGIES, iBase_VERTEX, &entities, &entities_alloc,
00536                                 &entities_size, &adj_ents, &adj_ents_alloc, &adj_ents_size, &indices, &indices_alloc,
00537                                 &indices_size, &offsets, &offsets_alloc, &offsets_size, &result );
00538         if( iBase_SUCCESS != result )
00539         {
00540             printf( "Failed to get indices of vertices in connectivity_test, type=%d.\n", type );
00541             return FALSE;
00542         }
00543
00544         if( entities_alloc != entities_size )
00545         {
00546             printf( "Number of entities didn't agree with array size in connectivity_test.\n" );
00547             free( entities );
00548             free( adj_ents );
00549             free( indices );
00550             free( offsets );
00551             return FALSE;
00552         }
00553
00554         if( offsets_alloc != offsets_size )
00555         {
00556             printf( "Number of offsets didn't agree with array size in connectivity_test.\n" );
00557             free( entities );
00558             free( adj_ents );
00559             free( indices );
00560             free( offsets );
00561             return FALSE;
00562         }
00563
00564         if( indices_alloc != indices_size )
00565         {
00566             printf( "Number of indices didn't agree with array size in connectivity_test.\n" );
00567             free( entities );
00568             free( adj_ents );
00569             free( indices );
00570             free( offsets );
00571             return FALSE;
00572         }
00573
00574         if( adj_ents_alloc != adj_ents_size )
00575         {
00576             printf( "Number of adjacent entities didn't agree with array size in "
00577                     "connectivity_test.\n" );
00578             free( entities );
00579             free( adj_ents );
00580             free( indices );
00581             free( offsets );
00582             return FALSE;
00583         }
00584
00585         if( offsets_size != entities_size + 1 )
00586         {
00587             printf( "Invalid/inconsistent offset size from iMesh_getAdjEntIndices.\n" );
00588             free( entities );
00589             free( adj_ents );
00590             free( indices );
00591             free( offsets );
00592             return FALSE;
00593         }
00594
00595         /* check that results are valid */
00596         for( i = 0; i < entities_size; ++i )
00597         {
00598             ASSERT( offsets[i] < offsets[i + 1] && offsets[i] < indices_size );
00599             if( !assert_pass )
00600             {
00601                 free( entities );
00602                 free( adj_ents );
00603                 free( indices );
00604                 free( offsets );
00605                 return FALSE;
00606             }
00607         }
00608
00609         for( i = 0; i < indices_size; ++i )
00610         {
00611             ASSERT( indices[i] >= 0 && indices[i] < adj_ents_size );
00612             if( !assert_pass )
00613             {
00614                 free( entities );
00615                 free( adj_ents );
00616                 free( indices );
00617                 free( offsets );
00618                 return FALSE;
00619             }
00620         }
00621
00622         /* compare initial entity list against result of iMesh_getEntities */
00623         entities2       = NULL;
00624         entities2_alloc = 0;
00625         iMesh_getEntities( mesh, root_set, type, iMesh_ALL_TOPOLOGIES, &entities2, &entities2_alloc, &entities2_size,
00626                            &result );
00627         ASSERT( iBase_SUCCESS == result );
00628         if( !assert_pass )
00629         {
00630             free( entities );
00631             free( adj_ents );
00632             free( indices );
00633             free( offsets );
00634             return FALSE;
00635         }
00636
00637         size   = sizeof( iBase_EntityHandle ) * entities_size;
00638         sorted = (iBase_EntityHandle*)malloc( size );
00639         memcpy( sorted, entities, size );
00640         qsort( sorted, entities_size, sizeof( iBase_EntityHandle ), &qsort_comp_handles );
00641         qsort( entities2, entities2_size, sizeof( iBase_EntityHandle ), &qsort_comp_handles );
00642
00643         ASSERT( entities_size == entities2_size && !memcmp( sorted, entities2, size ) );
00644         if( !assert_pass )
00645         {
00646             free( entities );
00647             free( adj_ents );
00648             free( indices );
00649             free( offsets );
00650             free( entities2 );
00651             free( sorted );
00652             return FALSE;
00653         }
00654
00655         free( entities2 );
00656         free( sorted );
00657
00658         /* compare results against output of iMesh_getEntAdj */
00659         for( i = 0; i < entities_size; ++i )
00660         {
00661             iMesh_getEntAdj( mesh, entities[i], iBase_VERTEX, &adj_ents2_ptr, &adj_ents2_alloc, &adj_ents2_size,
00662                              &result );
00663             ASSERT( iBase_SUCCESS == result );
00664             if( !assert_pass )
00665             {
00666                 free( entities );
00667                 free( adj_ents );
00668                 free( indices );
00669                 free( offsets );
00670                 return FALSE;
00671             }
00672
00673             ASSERT( adj_ents2_ptr == adj_ents2 ); /* shouldn't change */
00674             if( !assert_pass )
00675             {
00676                 free( entities );
00677                 free( adj_ents );
00678                 free( indices );
00679                 free( offsets );
00680                 return FALSE;
00681             }
00682
00683             ASSERT( adj_ents2_alloc == 27 ); /* shouldn't change */
00684             if( !assert_pass )
00685             {
00686                 free( entities );
00687                 free( adj_ents );
00688                 free( indices );
00689                 free( offsets );
00690                 return FALSE;
00691             }
00692
00693             /* compare results */
00694             size = offsets[i + 1] - offsets[i];
00695             ASSERT( size == adj_ents2_size );
00696             while( --size >= 0 )
00697             {
00698                 ASSERT( adj_ents2[size] == adj_ents[indices[offsets[i] + size]] );
00699                 if( !assert_pass )
00700                 {
00701                     free( entities );
00702                     free( adj_ents );
00703                     free( indices );
00704                     free( offsets );
00705                     return FALSE;
00706                 }
00707             }
00708         }
00709
00710         free( entities );
00711         free( adj_ents );
00712         free( indices );
00713         free( offsets );
00714
00715         /*
00716             offsets = NULL;
00717             offsets_alloc = 0;
00718             entities = NULL;
00719             entities_alloc = 0;
00720
00721             iMesh_getAdjEntities(mesh, root_set, type,
00722                                  iMesh_ALL_TOPOLOGIES, iBase_VERTEX,
00723                                  &entities, &entities_alloc, &entities_size,
00724                                  &offsets, &offsets_alloc, &offsets_size,
00725                                  &result);
00726             if (iBase_SUCCESS != result) {
00727               printf("Failed to get indices of adjacent entity vertices in connectivity_test.\n");
00728               return FALSE;
00729             }
00730
00731             if (entities_alloc != entities_size ||
00732                 offsets_alloc != offsets_size) {
00733               printf("Number of elements didn't agree with array size for an array in
00734            connectivity_test.\n"); return FALSE;
00735             }
00736
00737             free(offsets);
00738             free(entities);
00739         */
00740     }
00741
00742     return TRUE;
00743 }
00744
00745 /*!
00746   @test
00747   TSTT entity sets sub test
00748   @li Check entity sets
00749 */
00750
00751 /* helper function used to report errors in # sets */
00752 int check_esets( iMesh_Instance mesh, const int num_sets );
00753
00754 int entity_sets_subtest( iMesh_Instance mesh, int is_list, int /*num_iter*/ )
00755 {
00756     int i, num_type = iBase_ALL_TYPES - iBase_VERTEX;
00757     // int num_all_entities_super = 0;
00758     iBase_EntitySetHandle es_array[iBase_ALL_TYPES - iBase_VERTEX];
00759     int number_array[iBase_ALL_TYPES - iBase_VERTEX];
00760     int ent_type                 = iBase_VERTEX;
00761     iBase_EntityHandle* entities = NULL;
00762     int entities_alloc           = 0, entities_size;
00763     iBase_EntitySetHandle parent_child, super_set = NULL;
00764     iBase_EntitySetHandle temp_es1, temp_es2, temp_es3;
00765     iBase_EntityHandle *edges = NULL, *faces = NULL, *temp_entities1 = NULL, *temp_entities2 = NULL;
00766     int edges_alloc = 0, faces_alloc = 0, temp_entities1_alloc = 0, temp_entities2_alloc = 0;
00767     int edges_size, faces_size, temp_entities1_size, temp_entities2_size;
00768     int* types      = NULL;
00769     int types_alloc = 0, types_size;
00770     int num_rest, num_regions;
00771     iBase_EntityHandle* regions      = NULL;
00772     int regions_alloc                = 0, regions_size;
00773     iBase_EntitySetHandle* parents   = NULL;
00774     int parents_alloc                = 0, parents_size, temp_numb, is_child;
00775     iBase_EntitySetHandle* es_array1 = NULL;
00776     int es_array1_alloc              = 0, es_array1_size, num_super;
00777     iBase_EntityHandle* all_entities = NULL;
00778     int all_entities_alloc           = 0, all_entities_size, k, l;
00779     iBase_EntityHandle* adj_faces    = NULL;
00780     int adj_faces_alloc              = 0, adj_faces_size;
00781     int* face_offsets                = NULL;
00782     int face_offsets_alloc           = 0, face_offsets_size;
00783     iBase_EntityHandle* hexes        = NULL;
00784     int hexes_alloc                  = 0, hexes_size;
00785     iBase_EntitySetHandle hex_set;
00786
00787     /* get the number of whole mesh */
00788     int n_whole_mesh = 0;
00789     int result;
00790     iMesh_getNumEntSets( mesh, root_set, 1, &n_whole_mesh, &result );
00791     if( iBase_SUCCESS != result )
00792     {
00793         printf( "Problem to get the number of all entity sets in whole mesh.\n" );
00794         return FALSE;
00795     }
00796
00797     /* add entities to entitysets by type */
00798     for( ; ent_type < num_type; ent_type++ )
00799     {
00800         /* initialize the entityset */
00801         iMesh_createEntSet( mesh, is_list, &es_array[ent_type], &result );
00802         if( iBase_SUCCESS != result )
00803         {
00804             printf( "Problem creating entityset.\n" );
00805             return FALSE;
00806         }
00807
00808         /* get entities by type in total "mesh" */
00809         entities       = NULL;
00810         entities_alloc = 0;
00811         iMesh_getEntities( mesh, root_set, ent_type, iMesh_ALL_TOPOLOGIES, &entities, &entities_alloc, &entities_size,
00812                            &result );
00813         if( iBase_SUCCESS != result )
00814         {
00815             printf( "Failed to get entities by type in entity_sets_test.\n" );
00816             return FALSE;
00817         }
00818
00819         if( entities_alloc != entities_size )
00820         {
00821             printf( "Number of entities didn't agree with array size in entity_sets_subtest.\n" );
00822             free( entities );
00823             return FALSE;
00824         }
00825
00826         /* add entities into entity set */
00827         if( 0 != entities_size )
00828         {
00829             iMesh_addEntArrToSet( mesh, entities, entities_size, es_array[ent_type], &result );
00830             if( iBase_SUCCESS != result )
00831             {
00832                 printf( "Failed to add entities in entity_sets_test.\n" );
00833                 free( entities );
00834                 return FALSE;
00835             }
00836         }
00837
00838         /* Check to make sure entity set really has correct number of entities in it */
00839         iMesh_getNumOfType( mesh, es_array[ent_type], ent_type, number_array + ent_type, &result );
00840
00841         if( iBase_SUCCESS != result )
00842         {
00843             printf( "Failed to get number of entities by type in entity_sets_test.\n" );
00844             free( entities );
00845             return FALSE;
00846         }
00847
00848         /* compare the number of entities by type */
00849         if( number_array[ent_type] != entities_size )
00850         {
00851             printf( "Number of entities by type is not correct\n" );
00852             free( entities );
00853             return FALSE;
00854         }
00855
00856         /* add to number of all entities in super set */
00857         // num_all_entities_super += entities_size;
00858
00859         free( entities );
00860     }
00861
00862     if( !check_esets( mesh, n_whole_mesh + num_type ) ) return FALSE;
00863
00864     /* make a super set having all entitysets */
00865     super_set = NULL;
00866     iMesh_createEntSet( mesh, is_list, &super_set, &result );
00867     if( iBase_SUCCESS != result )
00868     {
00869         printf( "Failed to create a super set in entity_sets_test.\n" );
00870         return FALSE;
00871     }
00872
00873     for( i = 0; i < num_type; i++ )
00874     {
00875         iMesh_addEntSet( mesh, es_array[i], super_set, &result );
00876         if( iBase_SUCCESS != result )
00877         {
00878             printf( "Failed to add a set to a super set in entity_sets_test.\n" );
00879             return FALSE;
00880         }
00881     }
00882
00883     if( !check_esets( mesh, n_whole_mesh + num_type + 1 ) ) return FALSE;
00884
00885     /*----------TEST intEAN OPERATIONS----------------*/
00886
00887     iMesh_createEntSet( mesh, is_list, &temp_es1, &result );
00888     if( iBase_SUCCESS != result )
00889     {
00890         printf( "Failed to create a super set in entity_sets_test.\n" );
00891         return FALSE;
00892     }
00893
00894     if( !check_esets( mesh, n_whole_mesh + num_type + 2 ) )
00895     {
00896         return FALSE;
00897     }
00898
00899     /* Subtract */
00900     /* add all EDGEs and FACEs to temp_es1 */
00901     /* get all EDGE entities */
00902     edges       = NULL;
00903     edges_alloc = 0;
00904     iMesh_getEntities( mesh, es_array[iBase_EDGE], iBase_EDGE, iMesh_ALL_TOPOLOGIES, &edges, &edges_alloc, &edges_size,
00905                        &result );
00906
00907     if( iBase_SUCCESS != result )
00908     {
00909         printf( "Failed to get edge entities in entity_sets_test.\n" );
00910         return FALSE;
00911     }
00912
00913     /* add EDGEs to es1 */
00914     iMesh_addEntArrToSet( mesh, edges, edges_size, temp_es1, &result );
00915     if( iBase_SUCCESS != result )
00916     {
00917         printf( "Failed to add edge entities in entity_sets_test.\n" );
00918         free( edges );
00919         return FALSE;
00920     }
00921
00922     /* get all FACE entities */
00923     faces       = NULL;
00924     faces_alloc = 0;
00925     iMesh_getEntities( mesh, es_array[iBase_FACE], iBase_FACE, iMesh_ALL_TOPOLOGIES, &faces, &faces_alloc, &faces_size,
00926                        &result );
00927     if( iBase_SUCCESS != result )
00928     {
00929         printf( "Failed to get face entities in entity_sets_test.\n" );
00930         free( edges );
00931         return FALSE;
00932     }
00933
00934     /* add FACEs to es1 */
00935     iMesh_addEntArrToSet( mesh, faces, faces_size, temp_es1, &result );
00936     if( iBase_SUCCESS != result )
00937     {
00938         printf( "Failed to add face entities in entity_sets_test.\n" );
00939         free( edges );
00940         free( faces );
00941         return FALSE;
00942     }
00943
00944     /* subtract EDGEs */
00945
00946     iMesh_subtract( mesh, temp_es1, es_array[iBase_EDGE], &temp_es2, &result );
00947     if( iBase_SUCCESS != result )
00948     {
00949         printf( "Failed to subtract entitysets in entity_sets_test.\n" );
00950         free( edges );
00951         free( faces );
00952         return FALSE;
00953     }
00954
00955     temp_entities1       = NULL;
00956     temp_entities1_alloc = 0;
00957     iMesh_getEntities( mesh, temp_es2, iBase_FACE, iMesh_ALL_TOPOLOGIES, &temp_entities1, &temp_entities1_alloc,
00958                        &temp_entities1_size, &result );
00959     if( iBase_SUCCESS != result )
00960     {
00961         printf( "Failed to get face entities in entity_sets_test.\n" );
00962         free( edges );
00963         free( faces );
00964         return FALSE;
00965     }
00966
00967     if( faces_size != temp_entities1_size )
00968     {
00969         printf( "not match number of entitysets after subtraction "
00970                 "in entity_sets_test.\n" );
00971         free( edges );
00972         free( faces );
00973         free( temp_entities1 );
00974         return FALSE;
00975     }
00976
00977     /* check there's nothing but faces in face_es */
00978     types       = NULL;
00979     types_alloc = 0;
00980     iMesh_getEntArrType( mesh, temp_entities1, temp_entities1_size, &types, &types_alloc, &types_size, &result );
00981     if( iBase_SUCCESS != result )
00982     {
00983         printf( "Failed to get types of entities in entity_sets_test.\n" );
00984         free( edges );
00985         free( faces );
00986         free( temp_entities1 );
00987         return FALSE;
00988     }
00989     for( i = 0; i < types_size; i++ )
00990     {
00991         if( types[i] != iBase_FACE )
00992         {
00993             printf( "wrong entity type for face test in entity_sets_test.\n" );
00994             free( edges );
00995             free( faces );
00996             free( temp_entities1 );
00997             free( types );
00998             return FALSE;
00999         }
01000     }
01001
01002     iMesh_destroyEntSet( mesh, temp_es2, &result );
01003     if( iBase_SUCCESS != result )
01004     {
01005         printf( "Failed to destroy temp es2.\n" );
01006         free( edges );
01007         free( faces );
01008         free( temp_entities1 );
01009         free( types );
01010         return FALSE;
01011     }
01012
01013     if( !check_esets( mesh, n_whole_mesh + num_type + 2 ) )
01014     {
01015         free( edges );
01016         free( faces );
01017         free( temp_entities1 );
01018         free( types );
01019         return FALSE;
01020     }
01021
01022     /*------------Intersect------------ */
01023
01024     /* clean out the temp_ms1 */
01025     iMesh_rmvEntArrFromSet( mesh, faces, faces_size, temp_es1, &result );
01026     if( iBase_SUCCESS != result )
01027     {
01028         printf( "Failed to remove face entities in entity_sets_test.\n" );
01029         free( edges );
01030         free( faces );
01031         free( temp_entities1 );
01032         free( types );
01033         return FALSE;
01034     }
01035
01036     /* check if it is really cleaned out */
01037     iMesh_getNumOfType( mesh, temp_es1, iBase_FACE, &num_rest, &result );
01038     if( iBase_SUCCESS != result )
01039     {
01040         printf( "Failed to get number of entities by type in entity_sets_test.\n" );
01041         free( edges );
01042         free( faces );
01043         free( temp_entities1 );
01044         free( types );
01045         return FALSE;
01046     }
01047
01048     if( num_rest != 0 )
01049     {
01050         printf( "failed to remove correctly.\n" );
01051         free( edges );
01052         free( faces );
01053         free( temp_entities1 );
01054         free( types );
01055         return FALSE;
01056     }
01057
01058     /* add EDGEs to temp es1 */
01059     iMesh_addEntArrToSet( mesh, edges, edges_size, temp_es1, &result );
01060     if( iBase_SUCCESS != result )
01061     {
01062         printf( "Failed to add edge entities in entity_sets_test.\n" );
01063         free( edges );
01064         free( faces );
01065         free( temp_entities1 );
01066         free( types );
01067         return FALSE;
01068     }
01069
01070     /* add FACEs to temp es1 */
01071     iMesh_addEntArrToSet( mesh, faces, faces_size, temp_es1, &result );
01072     if( iBase_SUCCESS != result )
01073     {
01074         printf( "Failed to add edge entities in entity_sets_test.\n" );
01075         free( edges );
01076         free( faces );
01077         free( temp_entities1 );
01078         free( types );
01079         return FALSE;
01080     }
01081
01082     /* intersect temp_es1 with edges meshset  */
01083     /* temp_ms1 entityset is altered */
01084     iMesh_intersect( mesh, temp_es1, es_array[iBase_EDGE], &temp_es2, &result );
01085     if( iBase_SUCCESS != result )
01086     {
01087         printf( "Failed to intersect in entity_sets_test.\n" );
01088         free( edges );
01089         free( faces );
01090         free( temp_entities1 );
01091         free( types );
01092         return FALSE;
01093     }
01094
01095     temp_entities2       = NULL;
01096     temp_entities2_alloc = 0;
01097     iMesh_getEntities( mesh, temp_es2, iBase_FACE, iMesh_ALL_TOPOLOGIES, &temp_entities2, &temp_entities2_alloc,
01098                        &temp_entities2_size, &result );
01099     if( iBase_SUCCESS != result )
01100     {
01101         printf( "Failed to get face entities in entity_sets_test.\n" );
01102         free( edges );
01103         free( faces );
01104         free( temp_entities1 );
01105         free( types );
01106         return FALSE;
01107     }
01108
01109     if( temp_entities2_size != 0 )
01110     {
01111         printf( "wrong number of faces.\n" );
01112         free( edges );
01113         free( faces );
01114         free( temp_entities1 );
01115         free( temp_entities2 );
01116         free( types );
01117         return FALSE;
01118     }
01119
01120     iMesh_destroyEntSet( mesh, temp_es2, &result );
01121     if( iBase_SUCCESS != result )
01122     {
01123         printf( "Failed to destroy temp es2.\n" );
01124         free( edges );
01125         free( faces );
01126         free( temp_entities1 );
01127         free( temp_entities2 );
01128         free( types );
01129         return FALSE;
01130     }
01131
01132     if( !check_esets( mesh, n_whole_mesh + num_type + 2 ) )
01133     {
01134         free( edges );
01135         free( faces );
01136         free( temp_entities1 );
01137         free( temp_entities2 );
01138         free( types );
01139         return FALSE;
01140     }
01141
01142     /*-------------Unite-------------- */
01143
01144     iMesh_createEntSet( mesh, is_list, &temp_es2, &result );
01145     if( iBase_SUCCESS != result )
01146     {
01147         printf( "Failed to create a temp entityset in entity_sets_test.\n" );
01148         free( edges );
01149         free( faces );
01150         free( temp_entities1 );
01151         free( temp_entities2 );
01152         free( types );
01153         return FALSE;
01154     }
01155
01156     /* get all regions */
01157     regions       = NULL;
01158     regions_alloc = 0;
01159     iMesh_getEntities( mesh, es_array[iBase_REGION], iBase_REGION, iMesh_ALL_TOPOLOGIES, &regions, &regions_alloc,
01160                        &regions_size, &result );
01161     if( iBase_SUCCESS != result )
01162     {
01163         printf( "Failed to get region entities in entity_sets_test.\n" );
01164         free( edges );
01165         free( faces );
01166         free( temp_entities1 );
01167         free( temp_entities2 );
01168         free( types );
01169         return FALSE;
01170     }
01171
01172     /* add REGIONs to temp es2 */
01173     iMesh_addEntArrToSet( mesh, regions, regions_size, temp_es2, &result );
01174     if( iBase_SUCCESS != result )
01175     {
01176         printf( "Failed to add region entities in entity_sets_test.\n" );
01177         free( edges );
01178         free( faces );
01179         free( temp_entities1 );
01180         free( temp_entities2 );
01181         free( types );
01182         free( regions );
01183         return FALSE;
01184     }
01185
01186     /* unite temp_es1 and temp_es2 */
01187     iMesh_unite( mesh, temp_es1, temp_es2, &temp_es3, &result );
01188     if( iBase_SUCCESS != result )
01189     {
01190         printf( "Failed to unite in entity_sets_test.\n" );
01191         free( edges );
01192         free( faces );
01193         free( temp_entities1 );
01194         free( temp_entities2 );
01195         free( types );
01196         free( regions );
01197         return FALSE;
01198     }
01199
01200     /* perform the check */
01201     iMesh_getNumOfType( mesh, temp_es3, iBase_REGION, &num_regions, &result );
01202     if( iBase_SUCCESS != result )
01203     {
01204         printf( "Failed to get number of region entities by type in entity_sets_test.\n" );
01205         free( edges );
01206         free( faces );
01207         free( temp_entities1 );
01208         free( temp_entities2 );
01209         free( types );
01210         free( regions );
01211         return FALSE;
01212     }
01213
01214     if( num_regions != number_array[iBase_REGION] )
01215     {
01216         printf( "different number of regions in entity_sets_test.\n" );
01217         free( edges );
01218         free( faces );
01219         free( temp_entities1 );
01220         free( temp_entities2 );
01221         free( types );
01222         free( regions );
01223         return FALSE;
01224     }
01225
01226     if( !check_esets( mesh, n_whole_mesh + num_type + 4 ) )
01227     {
01228         free( edges );
01229         free( faces );
01230         free( temp_entities1 );
01231         free( temp_entities2 );
01232         free( types );
01233         free( regions );
01234         return FALSE;
01235     }
01236
01237     /*--------Test parent/child stuff in entiysets----------- */
01238
01239     /* Add 2 meshsets as children to another */
01240     iMesh_createEntSet( mesh, is_list, &parent_child, &result );
01241     if( iBase_SUCCESS != result )
01242     {
01243         printf( "Problem creating entityset in entity_sets_test.\n" );
01244         free( edges );
01245         free( faces );
01246         free( temp_entities1 );
01247         free( temp_entities2 );
01248         free( types );
01249         free( regions );
01250         return FALSE;
01251     }
01252
01253     iMesh_addPrntChld( mesh, es_array[iBase_VERTEX], parent_child, &result );
01254     if( iBase_SUCCESS != result )
01255     {
01256         printf( "Problem add parent in entity_sets_test.\n" );
01257         free( edges );
01258         free( faces );
01259         free( temp_entities1 );
01260         free( temp_entities2 );
01261         free( types );
01262         free( regions );
01263         return FALSE;
01264     }
01265
01266     /* check if parent is really added */
01267     parents       = NULL;
01268     parents_alloc = 0;
01269     iMesh_getPrnts( mesh, parent_child, 0, &parents, &parents_alloc, &parents_size, &result );
01270     if( iBase_SUCCESS != result )
01271     {
01272         printf( "Problem getting parents in entity_sets_test.\n" );
01273         free( edges );
01274         free( faces );
01275         free( temp_entities1 );
01276         free( temp_entities2 );
01277         free( types );
01278         free( regions );
01279         return FALSE;
01280     }
01281
01282     if( parents_size != 1 )
01283     {
01284         printf( "number of parents is not correct in entity_sets_test.\n" );
01285         free( edges );
01286         free( faces );
01287         free( temp_entities1 );
01288         free( temp_entities2 );
01289         free( types );
01290         free( regions );
01291         free( parents );
01292         return FALSE;
01293     }
01294
01295     /* get the number of child entitysets */
01296     iMesh_getNumChld( mesh, es_array[iBase_VERTEX], 0, &temp_numb, &result );
01297     if( iBase_SUCCESS != result )
01298     {
01299         printf( "Problem getting number of children in entity_sets_test.\n" );
01300         free( edges );
01301         free( faces );
01302         free( temp_entities1 );
01303         free( temp_entities2 );
01304         free( types );
01305         free( regions );
01306         free( parents );
01307         return FALSE;
01308     }
01309
01310     if( temp_numb != 1 )
01311     {
01312         printf( "number of children is not correct in entity_sets_test.\n" );
01313         free( edges );
01314         free( faces );
01315         free( temp_entities1 );
01316         free( temp_entities2 );
01317         free( types );
01318         free( regions );
01319         free( parents );
01320         return FALSE;
01321     }
01322
01323     /* parent_child and es_array[iBase_VERTEX] should be related */
01324     is_child = 0;
01325     iMesh_isChildOf( mesh, es_array[iBase_VERTEX], parent_child, &is_child, &result );
01326     if( iBase_SUCCESS != result )
01327     {
01328         printf( "Problem checking relation in entity_sets_test.\n" );
01329         free( edges );
01330         free( faces );
01331         free( temp_entities1 );
01332         free( temp_entities2 );
01333         free( types );
01334         free( regions );
01335         free( parents );
01336         return FALSE;
01337     }
01338     if( !is_child )
01339     {
01340         printf( "parent_child and es_array[iBase_VERTEX] should be related\n" );
01341         free( edges );
01342         free( faces );
01343         free( temp_entities1 );
01344         free( temp_entities2 );
01345         free( types );
01346         free( regions );
01347         free( parents );
01348         return FALSE;
01349     }
01350
01351     /* es_array[iBase_FACE] and es_array[iBase_REGION] are not related */
01352     is_child = FALSE;
01353     iMesh_isChildOf( mesh, es_array[iBase_FACE], es_array[iBase_REGION], &is_child, &result );
01354     if( iBase_SUCCESS != result )
01355     {
01356         printf( "Problem checking relation in entity_sets_test.\n" );
01357         free( edges );
01358         free( faces );
01359         free( temp_entities1 );
01360         free( temp_entities2 );
01361         free( types );
01362         free( regions );
01363         free( parents );
01364         return FALSE;
01365     }
01366     if( is_child )
01367     {
01368         printf( "es_array[iBase_REGION] and es_array[iBase_FACE] should not be related\n" );
01369         free( edges );
01370         free( faces );
01371         free( temp_entities1 );
01372         free( temp_entities2 );
01373         free( types );
01374         free( regions );
01375         free( parents );
01376         return FALSE;
01377     }
01378
01379     if( !check_esets( mesh, n_whole_mesh + num_type + 5 ) )
01380     {
01381         free( edges );
01382         free( faces );
01383         free( temp_entities1 );
01384         free( temp_entities2 );
01385         free( types );
01386         free( regions );
01387         free( parents );
01388         return FALSE;
01389     }
01390
01391     /*--------test modify and query functions----------------------------- */
01392
01393     /* get all entity sets in super set */
01394     es_array1       = NULL;
01395     es_array1_alloc = 0;
01396     iMesh_getEntSets( mesh, super_set, 0, &es_array1, &es_array1_alloc, &es_array1_size, &result );
01397     if( iBase_SUCCESS != result )
01398     {
01399         printf( "Problem to get entity sets in super set.\n" );
01400         free( edges );
01401         free( faces );
01402         free( temp_entities1 );
01403         free( temp_entities2 );
01404         free( types );
01405         free( regions );
01406         free( parents );
01407         return FALSE;
01408     }
01409
01410     /* get the number of entity sets in super set */
01411     iMesh_getNumEntSets( mesh, super_set, 0, &num_super, &result );
01412     if( iBase_SUCCESS != result )
01413     {
01414         printf( "Problem to get the number of all entity sets in super set.\n" );
01415         free( edges );
01416         free( faces );
01417         free( temp_entities1 );
01418         free( temp_entities2 );
01419         free( types );
01420         free( regions );
01421         free( parents );
01422         free( es_array1 );
01423         return FALSE;
01424     }
01425
01426     /* the number of entity sets in super set should be same */
01427     if( num_super != es_array1_size )
01428     {
01429         printf( "the number of entity sets in super set should be same.\n" );
01430         return FALSE;
01431     }
01432
01433     /* get all entities in super set */
01434     all_entities       = NULL;
01435     all_entities_alloc = 0;
01436     iMesh_getEntities( mesh, super_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &all_entities, &all_entities_alloc,
01437                        &all_entities_size, &result );
01438     if( iBase_SUCCESS != result )
01439     {
01440         printf( "Problem to get all entities in super set.\n" );
01441         free( edges );
01442         free( faces );
01443         free( temp_entities1 );
01444         free( temp_entities2 );
01445         free( types );
01446         free( regions );
01447         free( parents );
01448         free( es_array1 );
01449         return FALSE;
01450     }
01451
01452     /* compare the number of all entities in super set */
01453     /* NOTE: TEST COMMENTED OUT UNTIL RESOLUTION OF WHETHER GETENTITIES */
01454     /* SHOULD GET A NUM_HOPS ARGUMENT */
01455     /*  if (num_all_entities_super != all_entities_size) { */
01456     /*    printf("number of all entities in super set should be same.\n"); */
01457     /*    return FALSE; */
01458     /*  } */
01459
01460     /* test add, remove and get all entity sets using super set */
01461     /* check GetAllEntitySets works recursively and dosen't return */
01462     /* multi sets */
01463     for( k = 0; k < num_super; k++ )
01464     {
01465         /* add entity sets of super set to each entity set of super set */
01466         /* make multiple child super sets */
01467         iBase_EntitySetHandle es_k = es_array1[k];
01468         for( l = 0; l < es_array1_size; l++ )
01469         {
01470             iMesh_addEntSet( mesh, es_array1[l], es_k, &result );
01471             if( iBase_SUCCESS != result )
01472             {
01473                 printf( "Problem to add entity set to entityset.\n" );
01474                 free( edges );
01475                 free( faces );
01476                 free( temp_entities1 );
01477                 free( temp_entities2 );
01478                 free( types );
01479                 free( regions );
01480                 free( parents );
01481                 free( es_array1 );
01482                 free( all_entities );
01483                 return FALSE;
01484             }
01485         }
01486
01487         /* add super set to each entity set */
01488         iMesh_addEntSet( mesh, super_set, es_k, &result );
01489         if( iBase_SUCCESS != result )
01490         {
01491             printf( "Problem to add super set to entitysets.\n" );
01492             free( edges );
01493             free( faces );
01494             free( temp_entities1 );
01495             free( temp_entities2 );
01496             free( types );
01497             free( regions );
01498             free( parents );
01499             free( es_array1 );
01500             free( all_entities );
01501             return FALSE;
01502         }
01503
01504         /* add one entity sets multiple times */
01505         for( l = 0; l < 3; l++ )
01506         {
01507             iMesh_addEntSet( mesh, temp_es1, es_k, &result );
01508             if( iBase_SUCCESS != result )
01509             {
01510                 printf( "Problem to add temp set to entitysets.\n" );
01511                 free( edges );
01512                 free( faces );
01513                 free( temp_entities1 );
01514                 free( temp_entities2 );
01515                 free( types );
01516                 free( regions );
01517                 free( parents );
01518                 free( es_array1 );
01519                 free( all_entities );
01520                 return FALSE;
01521             }
01522         }
01523     }
01524
01525     /* get all hexes and get faces of that hexes */
01526     hexes       = NULL;
01527     hexes_alloc = 0;
01528
01529     iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, iMesh_HEXAHEDRON, &hexes, &hexes_alloc, &hexes_size, &result );
01530     if( iBase_SUCCESS != result )
01531     {
01532         printf( "Failed to get hexes in entity_sets_test.\n" );
01533         free( edges );
01534         free( faces );
01535         free( temp_entities1 );
01536         free( temp_entities2 );
01537         free( types );
01538         free( regions );
01539         free( parents );
01540         free( es_array1 );
01541         free( all_entities );
01542         return FALSE;
01543     }
01544
01545     /* get adjacent face of hexes */
01546     adj_faces          = NULL;
01547     adj_faces_alloc    = 0;
01548     face_offsets       = NULL;
01549     face_offsets_alloc = 0;
01550
01551     iMesh_getEntArrAdj( mesh, hexes, hexes_size, iBase_FACE, &adj_faces, &adj_faces_alloc, &adj_faces_size,
01552                         &face_offsets, &face_offsets_alloc, &face_offsets_size, &result );
01553     if( iBase_SUCCESS != result )
01554     {
01555         printf( "Problem to get adjacent entities in entitysets_test.\n" );
01556         free( edges );
01557         free( faces );
01558         free( temp_entities1 );
01559         free( temp_entities2 );
01560         free( types );
01561         free( regions );
01562         free( parents );
01563         free( es_array1 );
01564         free( all_entities );
01565         free( hexes );
01566         return FALSE;
01567     }
01568
01569     iMesh_createEntSet( mesh, FALSE, &hex_set, &result );
01570     if( iBase_SUCCESS != result )
01571     {
01572         printf( "Problem creating entityset in entity_sets_test.\n" );
01573         free( edges );
01574         free( faces );
01575         free( temp_entities1 );
01576         free( temp_entities2 );
01577         free( types );
01578         free( regions );
01579         free( parents );
01580         free( es_array1 );
01581         free( all_entities );
01582         free( hexes );
01583         free( adj_faces );
01584         free( face_offsets );
01585         return FALSE;
01586     }
01587
01588     iMesh_addEntArrToSet( mesh, hexes, hexes_size, hex_set, &result );
01589     if( iBase_SUCCESS != result )
01590     {
01591         printf( "Failed to add hexes in entity_sets_test.\n" );
01592         free( edges );
01593         free( faces );
01594         free( temp_entities1 );
01595         free( temp_entities2 );
01596         free( types );
01597         free( regions );
01598         free( parents );
01599         free( es_array1 );
01600         free( all_entities );
01601         free( hexes );
01602         free( adj_faces );
01603         free( face_offsets );
01604         return FALSE;
01605     }
01606
01607     free( edges );
01608     free( faces );
01609     free( temp_entities1 );
01610     free( temp_entities2 );
01611     free( types );
01612     free( regions );
01613     free( parents );
01614     free( es_array1 );
01615     free( all_entities );
01616     free( hexes );
01617     free( adj_faces );
01618     free( face_offsets );
01619
01620     return TRUE;
01621 }
01622
01623 int check_esets( iMesh_Instance mesh, const int num_sets )
01624 {
01625     int entity_sets_size;
01626
01627     int result;
01628     iMesh_getNumEntSets( mesh, root_set, 1, &entity_sets_size, &result );
01629     if( iBase_SUCCESS != result )
01630     {
01631         printf( "Problem to get all entity sets in mesh.\n" );
01632         return FALSE;
01633     }
01634     if( entity_sets_size != num_sets )
01635     {
01636         printf( "the number of entity sets in whole mesh should be %d"
01637                 ", actual number is %d.\n",
01638                 num_sets, entity_sets_size );
01639         return FALSE;
01640     }
01641
01642     return TRUE;
01643 }
01644
01645 /*!
01646   @test
01647   TSTT entity sets Test
01648   @li Check entity sets
01649 */
01650 int entity_sets_test( iMesh_Instance mesh )
01651 {
01652     int iter_num = 0, result;
01653     /* check  */
01654     int i;
01655     for( i = 0; i < 2; i++ )
01656     {
01657         iter_num++;
01658
01659         result = entity_sets_subtest( mesh, i, iter_num );
01660         if( !result ) return result;
01661     }
01662
01663     return TRUE;
01664 }
01665
01666 /*!
01667   @test
01668   Vertex Coordinates
01669   @li Get coordinates of vertices by 2 different methods then compare them
01670 */
01671 int vertex_coordinates_test( iMesh_Instance mesh )
01672 {
01673     iBase_EntityHandle* verts = NULL;
01674     int verts_alloc           = 0, verts_size;
01675     double* vert_coords       = NULL;
01676     int vert_coords_alloc     = 0, vert_coords_size;
01677
01678     /* check storage order */
01679     int result;
01680     int this_order;
01681     iMesh_getDfltStorage( mesh, &this_order, &result );
01682     if( iBase_SUCCESS != result )
01683     {
01684         printf( "failed to get preferred storage order in vertex_coordinates_test.\n" );
01685         return FALSE;
01686     }
01687
01688     /* now get the vertex coordinates from a vertex array */
01689     /* need to get the vertices in the model */
01690     verts       = NULL;
01691     verts_alloc = 0;
01692     iMesh_getEntities( mesh, root_set, iBase_VERTEX, iMesh_POINT, &verts, &verts_alloc, &verts_size, &result );
01693     if( iBase_SUCCESS != result )
01694     {
01695         printf( "failed to get entities in vertex_coordinates_test.\n" );
01696         return FALSE;
01697     }
01698
01699     /* get the coordinates in one array */
01700     vert_coords       = NULL;
01701     vert_coords_alloc = 0;
01702
01703     iMesh_getVtxArrCoords( mesh, verts, verts_size, iBase_INTERLEAVED, &vert_coords, &vert_coords_alloc,
01704                            &vert_coords_size, &result );
01705     if( iBase_SUCCESS != result )
01706     {
01707         printf( "failed to get vertex cooridinate of entities in vertex_coordinates_test.\n" );
01708         free( verts );
01709         return FALSE;
01710     }
01711
01712     free( verts );
01713     free( vert_coords );
01714
01715     /* if we get here, this test was successful */
01716     return TRUE;
01717 }
01718
01719 /*!
01720   @test
01721   TSTT Tag Info test
01722   @li Tests tagCreate, tagDelete, tagGetName, tagGetSize, tagGetHandle
01723 */
01724 int tag_info_test( iMesh_Instance mesh )
01725 {
01726     char dum_name[120];
01727     int dum_name_size = 120;
01728     int dum_size;
01729     int error = FALSE;
01730     iBase_TagHandle dum_handle;
01731     /* Create a tag */
01732     int result;
01733     iBase_TagHandle tag_handle = NULL;
01734     const char* tag_name       = "int_tag";
01735     int tag_name_size          = 8;
01736     iMesh_createTag( mesh, tag_name, 1, iBase_INTEGER, &tag_handle, &result, tag_name_size );
01737     if( iBase_SUCCESS != result )
01738     {
01739         printf( "Failed to create tag int_tag in vertex_tag_test." );
01740         return FALSE;
01741     }
01742
01743     /* check tag info functions */
01744     iMesh_getTagName( mesh, tag_handle, dum_name, &result, dum_name_size );
01745     if( iBase_SUCCESS != result )
01746     {
01747         printf( "Couldn't get name of tag just created.\n" );
01748         return FALSE;
01749     }
01750     if( strcmp( dum_name, "int_tag" ) != 0 )
01751     {
01752         printf( "Tag names didn't match.\n" );
01753         return FALSE;
01754     }
01755
01756     iMesh_getTagSizeBytes( mesh, tag_handle, &dum_size, &result );
01757     if( iBase_SUCCESS != result )
01758     {
01759         printf( "Couldn't get size of tag just created.\n" );
01760         return FALSE;
01761     }
01762     if( dum_size != sizeof( int ) )
01763     {
01764         printf( "Tag sizes didn't match.\n" );
01765         return FALSE;
01766     }
01767
01768     iMesh_getTagHandle( mesh, tag_name, &dum_handle, &result, tag_name_size );
01769     if( iBase_SUCCESS != result )
01770     {
01771         printf( "Couldn't get handle of tag just created.\n" );
01772         return FALSE;
01773     }
01774     if( dum_handle != tag_handle )
01775     {
01776         printf( "Tag handles didn't match.\n" );
01777         return FALSE;
01778     }
01779
01780     /* test non-forced version of tagDelete; forced version tested later, */
01781     /* when we have entities around */
01782     iMesh_destroyTag( mesh, tag_handle, FALSE, &result );
01783     if( iBase_SUCCESS != result )
01784     {
01785         printf( "Couldn't delete tag just created.\n" );
01786         return FALSE;
01787     }
01788
01789     /* look for that tag, to make sure it got deleted */
01790     iMesh_getTagHandle( mesh, tag_name, &tag_handle, &result, tag_name_size );
01791     if( iBase_SUCCESS != result )
01792     {
01793         error = TRUE;
01794     }
01795     if( !error )
01796     {
01797         printf( "tagGetHandle was able to find handle for deleted tag.\n" );
01798         return FALSE;
01799     }
01800
01801     return TRUE;
01802 }
01803
01804 int vertex_int_tag_test( iMesh_Instance mesh, iBase_EntityHandle* verts, int /*verts_size*/, iBase_TagHandle* int_tag )
01805 {
01806     int result;
01807     iBase_EntityHandle dum_vert = verts[0];
01808
01809     int dum_val        = 11, dum_val2;
01810     void* dum_val2_ptr = &dum_val2;
01811     int dum_val2_alloc = sizeof( int ), dum_val2_size;
01812
01813     /* create a tag */
01814     const char* tag_name = "int_tag";
01815     int tag_name_size    = 8;
01816     iMesh_createTag( mesh, tag_name, 1, iBase_INTEGER, int_tag, &result, tag_name_size );
01817     if( iBase_SUCCESS != result )
01818     {
01819         printf( "Failed to create tag int_tag in vertex_int_tag_test.\n" );
01820         return FALSE;
01821     }
01822
01823     /* put a value in the first vertex and retrieve */
01824     iMesh_setArrData( mesh, &dum_vert, 1, *int_tag, (const char*)( &dum_val ), sizeof( int ), &result );
01825     if( iBase_SUCCESS != result )
01826     {
01827         printf( "Failed to set int tag (val=11) in vertex_int_tag_test.\n" );
01828         return FALSE;
01829     }
01830
01831     iMesh_getArrData( mesh, &dum_vert, 1, *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
01832     if( iBase_SUCCESS != result || dum_val2 != 11 )
01833     {
01834         printf( "Failed to get int tag (val=11) in vertex_int_tag_test.\n" );
01835         return FALSE;
01836     }
01837
01838     if( dum_val2 != 11 )
01839     {
01840
01841         printf( "Value of vertex tag (val=11) wrong.\n" );
01842         return FALSE;
01843     }
01844
01845     /* put a value in the last vertex and retrieve */
01846     dum_val = 12;
01847
01848     iMesh_setArrData( mesh, &dum_vert, 1, *int_tag, (char*)( &dum_val ), sizeof( int ), &result );
01849     if( iBase_SUCCESS != result )
01850     {
01851         printf( "Failed to set int tag (val=12) in vertex_int_tag_test.\n" );
01852         return FALSE;
01853     }
01854
01855     iMesh_getArrData( mesh, &dum_vert, 1, *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
01856     if( iBase_SUCCESS != result )
01857     {
01858         printf( "Failed to get int tag (val=12) in vertex_int_tag_test.\n" );
01859         return FALSE;
01860     }
01861
01862     if( dum_val2 != 12 )
01863     {
01864
01865         printf( "Value of vertex tag (val=12) wrong.\n" );
01866         return FALSE;
01867     }
01868
01869     /* ok, the int tag test worked */
01870     return TRUE;
01871 }
01872
01873 int vertex_double_tag_test( iMesh_Instance mesh,
01874                             iBase_EntityHandle* verts,
01875                             int /*verts_size*/,
01876                             iBase_TagHandle* double_tag )
01877 {
01878     int result;
01879
01880     iBase_EntityHandle dum_vert = verts[0];
01881     double dum_val              = 1.0e6, dum_val2;
01882     void* dum_val2_ptr          = &dum_val2;
01883     int dum_val2_alloc          = sizeof( double ), dum_val2_size;
01884
01885     /* create a tag */
01886     const char* tag_name = "double_tag";
01887     int tag_name_size    = 11;
01888     iMesh_createTag( mesh, tag_name, 1, iBase_DOUBLE, double_tag, &result, tag_name_size );
01889     if( iBase_SUCCESS != result )
01890     {
01891         printf( "Failed to create tag double_tag in vertex_double_tag_test.\n" );
01892         return FALSE;
01893     }
01894
01895     /* put a value in the first vertex and retrieve */
01896     iMesh_setArrData( mesh, &dum_vert, 1, *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
01897     if( iBase_SUCCESS != result )
01898     {
01899         printf( "Failed to set double tag (val=1.0e6) in vertex_double_tag_test.\n" );
01900         return FALSE;
01901     }
01902
01903     iMesh_getArrData( mesh, &dum_vert, 1, *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
01904     if( iBase_SUCCESS != result )
01905     {
01906         printf( "Failed to get double tag (val=1.0e6) in vertex_double_tag_test.\n" );
01907         return FALSE;
01908     }
01909
01910     if( dum_val2 != 1.0e6 )
01911     {
01912         printf( "Value of vertex tag (val=1.0e6) wrong.\n" );
01913         return FALSE;
01914     }
01915
01916     /* put a value in the last vertex and retrieve */
01917     dum_val = 2.0e9;
01918
01919     iMesh_setArrData( mesh, &dum_vert, 1, *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
01920     if( iBase_SUCCESS != result )
01921     {
01922         printf( "Failed to set double tag (val=2.0e9) in vertex_double_tag_test.\n" );
01923         return FALSE;
01924     }
01925
01926     iMesh_getArrData( mesh, &dum_vert, 1, *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
01927     if( iBase_SUCCESS != result )
01928     {
01929         printf( "Failed to get double tag (val=2.0e9) in vertex_double_tag_test.\n" );
01930         return FALSE;
01931     }
01932
01933     if( dum_val2 != 2.0e9 )
01934     {
01935         printf( "Value of vertex tag (val=2.0e9) wrong.\n" );
01936         return FALSE;
01937     }
01938
01939     /* ok, the double tag test worked */
01940     return TRUE;
01941 }
01942
01943 /* Add a struct Vertex Tag to the database */
01944 struct TagStruct
01945 {
01946     double test_double;
01947     int test_int1, test_int2;
01948 };
01949
01950 int vertex_struct_tag_test( iMesh_Instance mesh,
01951                             iBase_EntityHandle* verts,
01952                             int /*verts_size*/,
01953                             iBase_TagHandle* struct_tag )
01954 {
01955     int result;
01956     iBase_EntityHandle dum_vert = verts[0];
01957     struct TagStruct dum_struct = { 3.0e12, 2, 3 }, dum_struct2;
01958     void* dum_struct2_ptr       = &dum_struct2;
01959     int dum_struct_alloc        = sizeof( struct TagStruct ), dum_struct_size;
01960
01961     /* create a tag */
01962     const char* tag_name = "struct_tag";
01963     int tag_name_size    = 11;
01964     iMesh_createTag( mesh, tag_name, sizeof( struct TagStruct ), iBase_BYTES, struct_tag, &result, tag_name_size );
01965     if( iBase_SUCCESS != result )
01966     {
01967         printf( "Failed to create tag struct_tag in vertex_struct_tag_test.\n" );
01968         return FALSE;
01969     }
01970
01971     /* put a value in the first vertex and retrieve */
01972
01973     /* careful setting the value, since tags are opaque */
01974     iMesh_setArrData( mesh, &dum_vert, 1, *struct_tag, (const char*)&dum_struct, sizeof( struct TagStruct ), &result );
01975     if( iBase_SUCCESS != result )
01976     {
01977         printf( "Failed to set struct tag in vertex_struct_tag_test.\n" );
01978         return FALSE;
01979     }
01980
01981     iMesh_getArrData( mesh, &dum_vert, 1, *struct_tag, &dum_struct2_ptr, &dum_struct_alloc, &dum_struct_size, &result );
01982     if( iBase_SUCCESS != result )
01983     {
01984         printf( "Failed to get struct tag in vertex_struct_tag_test.\n" );
01985         return FALSE;
01986     }
01987
01988     if( dum_struct_size != sizeof( struct TagStruct ) )
01989     {
01990         printf( "Size of vertex struct tag wrong.\n" );
01991         return FALSE;
01992     }
01993     if( dum_struct2.test_int1 != dum_struct.test_int1 || dum_struct2.test_int2 != dum_struct.test_int2 ||
01994         dum_struct2.test_double != dum_struct.test_double )
01995     {
01996         printf( "Value of vertex struct tag wrong.\n" );
01997         return FALSE;
01998     }
01999
02000     /* ok, the int tag test worked */
02001     return TRUE;
02002 }
02003
02004 int vertex_tag_delete_test( iMesh_Instance mesh, iBase_EntityHandle* verts, int /*verts_size*/ )
02005 {
02006     int result;
02007     int delete_err = FALSE;
02008
02009     /* test forced, unforced deletion of tags from entities */
02010
02011     /* test getAlliBase_TagHandles for first entity */
02012     iBase_TagHandle* all_tags     = NULL;
02013     iBase_EntityHandle dum_entity = verts[0];
02014     int all_tags_alloc            = 0, all_tags_size;
02015     iMesh_getAllTags( mesh, verts[0], &all_tags, &all_tags_alloc, &all_tags_size, &result );
02016     if( iBase_SUCCESS != result )
02017     {
02018         printf( "Couldn't get all tag handles from vertex.\n" );
02019         return FALSE;
02020     }
02021
02022     iMesh_rmvArrTag( mesh, &dum_entity, 1, all_tags[0], &result );
02023     if( iBase_SUCCESS != result )
02024     {
02025         printf( "Couldn't remove tag from vertex.\n" );
02026         free( all_tags );
02027         return FALSE;
02028     }
02029
02030     iMesh_destroyTag( mesh, all_tags[1], FALSE, &result );
02031     if( iBase_SUCCESS != result )
02032     {
02033         delete_err = TRUE;
02034     }
02035     if( !delete_err )
02036     {
02037         printf( "Error when unforced-deleting tag in use on a vertex.\n" );
02038         free( all_tags );
02039         return FALSE;
02040     }
02041
02042     iMesh_destroyTag( mesh, all_tags[1], TRUE, &result );
02043     if( iBase_SUCCESS != result )
02044     {
02045         printf( "Couldn't force-delete a tag in use on a vertex.\n" );
02046         free( all_tags );
02047         return FALSE;
02048     }
02049
02050     free( all_tags );
02051
02052     /* ok, we're done */
02053     return TRUE;
02054 }
02055
02056 int vertex_tag_test( iMesh_Instance mesh )
02057 {
02058     int result;
02059
02060     iBase_TagHandle int_tag, double_tag, struct_tag;
02061     int int_err, double_err, struct_err, tag_delete_err;
02062
02063     int info_err = tag_info_test( mesh );
02064
02065     /* get all the vertices */
02066     iBase_EntityHandle* verts = NULL;
02067     int verts_alloc           = 0, verts_size;
02068     iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, iMesh_POINT, &verts, &verts_alloc, &verts_size, &result );
02069     if( iBase_SUCCESS != result )
02070     {
02071         printf( "entitysetGetEntities failed in vertex_tag_test.\n" );
02072         return FALSE;
02073     }
02074
02075     /* vertex int tag */
02076     int_err = vertex_int_tag_test( mesh, verts, verts_size, &int_tag );
02077
02078     /* vertex double tag */
02079     double_err = vertex_double_tag_test( mesh, verts, verts_size, &double_tag );
02080
02081     /* vertex struct tag */
02082     struct_err = vertex_struct_tag_test( mesh, verts, verts_size, &struct_tag );
02083
02084     tag_delete_err = vertex_tag_delete_test( mesh, verts, verts_size );
02085
02086     free( verts );
02087
02088     return ( info_err && int_err && double_err && struct_err && tag_delete_err );
02089 }
02090
02091 int entityset_int_tag_test( iMesh_Instance mesh, iBase_EntitySetHandle* sets, int sets_size, iBase_TagHandle* int_tag )
02092 {
02093     int result;
02094     int dum_val        = 11, dum_val2;
02095     void* dum_val2_ptr = &dum_val2;
02096     int dum_val2_alloc = sizeof( int ), dum_val2_size;
02097
02098     /* create a tag */
02099     const char* tag_name = "set_int_tag";
02100     iMesh_createTag( mesh, tag_name, 1, iBase_INTEGER, int_tag, &result, 12 );
02101     if( iBase_SUCCESS != result )
02102     {
02103         printf( "Failed to create tag int_tag in entityset_int_tag_test.\n" );
02104         return FALSE;
02105     }
02106
02107     /* put a value in the first set and retrieve */
02108
02109     iMesh_setEntSetData( mesh, sets[0], *int_tag, (char*)( &dum_val ), sizeof( int ), &result );
02110     if( iBase_SUCCESS != result )
02111     {
02112         printf( "Failed to set int tag (val=11) in entityset_int_tag_test.\n" );
02113         return FALSE;
02114     }
02115
02116     dum_val2 = 0;
02117     iMesh_getEntSetData( mesh, sets[0], *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
02118     if( iBase_SUCCESS != result )
02119     {
02120         printf( "Failed to get int tag (val=11) in entityset_int_tag_test." );
02121         return FALSE;
02122     }
02123
02124     if( dum_val2 != 11 )
02125     {
02126         printf( "Value of entityset tag (val=11) wrong.\n" );
02127         return FALSE;
02128     }
02129
02130     /* put a value in the last faces and retrieve */
02131     dum_val = 12;
02132     iMesh_setEntSetData( mesh, sets[sets_size - 1], *int_tag, (char*)( &dum_val ), sizeof( int ), &result );
02133     if( iBase_SUCCESS != result )
02134     {
02135         printf( "Failed to set int tag (val=12) in entityset_int_tag_test." );
02136         return FALSE;
02137     }
02138
02139     iMesh_getEntSetData( mesh, sets[sets_size - 1], *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
02140     if( iBase_SUCCESS != result )
02141     {
02142         printf( "Failed to get int tag (val=12) in entityset_int_tag_test." );
02143         return FALSE;
02144     }
02145
02146     if( dum_val2 != 12 )
02147     {
02148         printf( "Value of entityset tag (val=12) wrong.\n" );
02149         return FALSE;
02150     }
02151
02152     /* ok, the int tag test worked */
02153     return TRUE;
02154 }
02155
02156 int entityset_double_tag_test( iMesh_Instance mesh,
02157                                iBase_EntitySetHandle* sets,
02158                                int sets_size,
02159                                iBase_TagHandle* double_tag )
02160 {
02161     int result;
02162     double dum_val     = 1.0e6, dum_val2;
02163     void* dum_val2_ptr = &dum_val2;
02164     int dum_val2_alloc = sizeof( double ), dum_val2_size;
02165
02166     /* create a tag */
02167     const char* tag_name = "set_double_tag";
02168     iMesh_createTag( mesh, tag_name, 1, iBase_DOUBLE, double_tag, &result, 15 );
02169     if( iBase_SUCCESS != result )
02170     {
02171         printf( "Failed to create tag double_tag in entityset_double_tag_test.\n" );
02172         return FALSE;
02173     }
02174
02175     /* put a value in the first set and retrieve */
02176
02177     iMesh_setEntSetData( mesh, sets[0], *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
02178     if( iBase_SUCCESS != result )
02179     {
02180         printf( "Failed to set double tag (val=11) in entityset_double_tag_test.\n" );
02181         return FALSE;
02182     }
02183
02184     dum_val2 = 0;
02185     iMesh_getEntSetData( mesh, sets[0], *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
02186     if( iBase_SUCCESS != result )
02187     {
02188         printf( "Failed to get double tag (val=1.0e6) in entityset_double_tag_test." );
02189         return FALSE;
02190     }
02191
02192     if( dum_val2 != 1.0e6 )
02193     {
02194         printf( "Value of entityset tag (val=11) wrong.\n" );
02195         return FALSE;
02196     }
02197
02198     /* put a value in the last faces and retrieve */
02199     dum_val = 2.0e9;
02200     iMesh_setEntSetData( mesh, sets[sets_size - 1], *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
02201     if( iBase_SUCCESS != result )
02202     {
02203         printf( "Failed to set double tag (val=2.0e9) in entityset_double_tag_test." );
02204         return FALSE;
02205     }
02206
02207     iMesh_getEntSetData( mesh, sets[sets_size - 1], *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size,
02208                          &result );
02209     if( iBase_SUCCESS != result )
02210     {
02211         printf( "Failed to get double tag (val=2.0e9) in entityset_double_tag_test." );
02212         return FALSE;
02213     }
02214
02215     if( dum_val2 != 2.0e9 )
02216     {
02217         printf( "Value of entityset tag (val=2.0e9) wrong.\n" );
02218         return FALSE;
02219     }
02220
02221     /* ok, the double tag test worked */
02222     return TRUE;
02223 }
02224
02225 int entityset_struct_tag_test( iMesh_Instance mesh,
02226                                iBase_EntitySetHandle* /*sets*/,
02227                                int /*sets_size*/,
02228                                iBase_TagHandle* struct_tag )
02229 {
02230     int result;
02231     struct TagStruct dum_struct = { 3.0e12, 2, 3 }, dum_struct2;
02232     void* dum_struct2_ptr       = &dum_struct2;
02233     int dum_struct_alloc        = sizeof( struct TagStruct ), dum_struct_size;
02234
02235     /* create a tag */
02236     const char* tag_name = "set_struct_tag";
02237     iMesh_createTag( mesh, tag_name, sizeof( struct TagStruct ), iBase_BYTES, struct_tag, &result, 11 );
02238     if( iBase_SUCCESS != result )
02239     {
02240         printf( "Failed to create tag struct_tag in entityset_struct_tag_test.\n" );
02241         return FALSE;
02242     }
02243
02244     /* put a value in the first vertex and retrieve */
02245
02246     /* careful setting the value, since tags are opaque */
02247     iMesh_setEntSetData( mesh, root_set, *struct_tag, (const char*)&dum_struct, sizeof( struct TagStruct ), &result );
02248     if( iBase_SUCCESS != result )
02249     {
02250         printf( "Failed to set struct tag in entityset_struct_tag_test.\n" );
02251         return FALSE;
02252     }
02253
02254     iMesh_getEntSetData( mesh, root_set, *struct_tag, &dum_struct2_ptr, &dum_struct_alloc, &dum_struct_size, &result );
02255     if( iBase_SUCCESS != result )
02256     {
02257         printf( "Failed to get struct tag in entityset_struct_tag_test.\n" );
02258         return FALSE;
02259     }
02260
02261     if( dum_struct_size != sizeof( struct TagStruct ) )
02262     {
02263         printf( "Size of entityset struct tag wrong.\n" );
02264         return FALSE;
02265     }
02266     if( dum_struct2.test_int1 != dum_struct.test_int1 || dum_struct2.test_int2 != dum_struct.test_int2 ||
02267         dum_struct2.test_double != dum_struct.test_double )
02268     {
02269         printf( "Value of entityset struct tag wrong.\n" );
02270         return FALSE;
02271     }
02272
02273     /* ok, the int tag test worked */
02274     return TRUE;
02275 }
02276
02277 int entityset_tag_delete_test( iMesh_Instance mesh, iBase_EntitySetHandle* sets, int sets_size )
02278 {
02279     /* test forced, unforced deletion of tags from entities */
02280     int result;
02281     int delete_err = FALSE;
02282
02283     /* test getAlliBase_TagHandles for first entity */
02284     iBase_TagHandle* all_tags = NULL;
02285     if( sets_size < 1 )
02286     {
02287         printf( "no sets.\n" );
02288         return FALSE;
02289     }
02290     iBase_EntitySetHandle dum_entity = sets[0];
02291     int all_tags_alloc               = 0, all_tags_size;
02292     iMesh_getAllEntSetTags( mesh, sets[0], &all_tags, &all_tags_alloc, &all_tags_size, &result );
02293     if( iBase_SUCCESS != result )
02294     {
02295         printf( "Couldn't get all tag handles from entityset.\n" );
02296         free( all_tags );
02297         return FALSE;
02298     }
02299
02300     iMesh_rmvEntSetTag( mesh, dum_entity, all_tags[0], &result );
02301     if( iBase_SUCCESS != result )
02302     {
02303         printf( "Couldn't remove tag from entityset.\n" );
02304         free( all_tags );
02305         return FALSE;
02306     }
02307
02308     iMesh_destroyTag( mesh, all_tags[1], FALSE, &result );
02309     if( iBase_SUCCESS != result )
02310     {
02311         delete_err = TRUE;
02312     }
02313     if( !delete_err )
02314     {
02315         printf( "Error when unforced-deleting tag in use on a entityset.\n" );
02316         free( all_tags );
02317         return FALSE;
02318     }
02319
02320     iMesh_destroyTag( mesh, all_tags[1], TRUE, &result );
02321     if( iBase_SUCCESS != result )
02322     {
02323         printf( "Couldn't force-delete a tag in use on a entityset.\n" );
02324         free( all_tags );
02325         return FALSE;
02326     }
02327
02328     free( all_tags );
02329
02330     /* ok, we're done */
02331     return TRUE;
02332 }
02333
02334 /*!
02335   @test
02336   TSTT entityset tag Test
02337   @li Check entityset tags
02338 */
02339 int entityset_tag_test( iMesh_Instance mesh )
02340 {
02341     int result;
02342     iBase_TagHandle int_tag, double_tag, struct_tag;
02343     int int_success, double_success, struct_success, tag_delete_success;
02344
02345     /* get the sets */
02346     iBase_EntitySetHandle* esets = NULL;
02347     int esets_alloc              = 0, esets_size;
02348     iMesh_getEntSets( mesh, root_set, 1, &esets, &esets_alloc, &esets_size, &result );
02349     if( iBase_SUCCESS != result )
02350     {
02351         printf( "entitysetGetEntities failed in entityset_tag_test.\n" );
02352         free( esets );
02353         return FALSE;
02354     }
02355
02356     /* entityset int tag */
02357     int_success = entityset_int_tag_test( mesh, esets, esets_size, &int_tag );
02358
02359     /* entityeset double tag */
02360     double_success = entityset_double_tag_test( mesh, esets, esets_size, &double_tag );
02361
02362     /* entityset struct tag */
02363     struct_success = entityset_struct_tag_test( mesh, esets, esets_size, &struct_tag );
02364
02365     tag_delete_success = entityset_tag_delete_test( mesh, esets, esets_size );
02366
02367     free( esets );
02368
02369     return ( int_success && double_success && struct_success && tag_delete_success );
02370 }
02371
02372 int mesh_int_tag_test( iMesh_Instance mesh, iBase_TagHandle* int_tag )
02373 {
02374     int result;
02375     int dum_val        = 11, dum_val2;
02376     void* dum_val2_ptr = &dum_val2;
02377     int dum_val2_alloc = sizeof( int ), dum_val2_size;
02378
02379     /* create a tag */
02380     const char* tag_name = "mesh_int_tag";
02381     iMesh_createTag( mesh, tag_name, 1, iBase_INTEGER, int_tag, &result, 12 );
02382     if( iBase_SUCCESS != result )
02383     {
02384         printf( "Failed to create tag int_tag in mesh_int_tag_test.\n" );
02385         return FALSE;
02386     }
02387
02388     /* put a value in the first set and retrieve */
02389
02390     iMesh_setEntSetData( mesh, root_set, *int_tag, (char*)( &dum_val ), sizeof( int ), &result );
02391     if( iBase_SUCCESS != result )
02392     {
02393         printf( "Failed to set int tag (val=11) in mesh_int_tag_test.\n" );
02394         return FALSE;
02395     }
02396
02397     dum_val2 = 0;
02398     iMesh_getEntSetData( mesh, root_set, *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
02399     if( iBase_SUCCESS != result )
02400     {
02401         printf( "Failed to get int tag (val=11) in mesh_int_tag_test." );
02402         return FALSE;
02403     }
02404
02405     if( dum_val2 != 11 )
02406     {
02407         printf( "Value of entityset tag (val=11) wrong.\n" );
02408         return FALSE;
02409     }
02410
02411     /* put a value in the last faces and retrieve */
02412     dum_val = 12;
02413     iMesh_setEntSetData( mesh, root_set, *int_tag, (char*)( &dum_val ), sizeof( int ), &result );
02414     if( iBase_SUCCESS != result )
02415     {
02416         printf( "Failed to set int tag (val=12) in mesh_int_tag_test." );
02417         return FALSE;
02418     }
02419
02420     iMesh_getEntSetData( mesh, root_set, *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
02421     if( iBase_SUCCESS != result )
02422     {
02423         printf( "Failed to get int tag (val=12) in mesh_int_tag_test." );
02424         return FALSE;
02425     }
02426
02427     if( dum_val2 != 12 )
02428     {
02429         printf( "Value of entityset tag (val=12) wrong.\n" );
02430         return FALSE;
02431     }
02432
02433     /* ok, the int tag test worked */
02434     return TRUE;
02435 }
02436
02437 int mesh_double_tag_test( iMesh_Instance mesh, iBase_TagHandle* double_tag )
02438 {
02439     int result;
02440     double dum_val     = 1.0e6, dum_val2;
02441     void* dum_val2_ptr = &dum_val2;
02442     int dum_val2_alloc = sizeof( double ), dum_val2_size;
02443
02444     /* create a tag */
02445     const char* tag_name = "mesh_double_tag";
02446     iMesh_createTag( mesh, tag_name, 1, iBase_DOUBLE, double_tag, &result, 15 );
02447     if( iBase_SUCCESS != result )
02448     {
02449         printf( "Failed to create tag double_tag in mesh_double_tag_test.\n" );
02450         return FALSE;
02451     }
02452
02453     /* put a value in the first set and retrieve */
02454
02455     iMesh_setEntSetData( mesh, root_set, *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
02456     if( iBase_SUCCESS != result )
02457     {
02458         printf( "Failed to set double tag (val=11) in mesh_double_tag_test.\n" );
02459         return FALSE;
02460     }
02461
02462     dum_val2 = 0;
02463     iMesh_getEntSetData( mesh, root_set, *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
02464     if( iBase_SUCCESS != result )
02465     {
02466         printf( "Failed to get double tag (val=1.0e6) in mesh_double_tag_test." );
02467         return FALSE;
02468     }
02469
02470     if( dum_val2 != 1.0e6 )
02471     {
02472         printf( "Value of entityset tag (val=11) wrong.\n" );
02473         return FALSE;
02474     }
02475
02476     /* put a value in the last faces and retrieve */
02477     dum_val = 2.0e9;
02478     iMesh_setEntSetData( mesh, root_set, *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
02479     if( iBase_SUCCESS != result )
02480     {
02481         printf( "Failed to set double tag (val=2.0e9) in mesh_double_tag_test." );
02482         return FALSE;
02483     }
02484
02485     iMesh_getEntSetData( mesh, root_set, *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
02486     if( iBase_SUCCESS != result )
02487     {
02488         printf( "Failed to get double tag (val=2.0e9) in mesh_double_tag_test." );
02489         return FALSE;
02490     }
02491
02492     if( dum_val2 != 2.0e9 )
02493     {
02494         printf( "Value of entityset tag (val=2.0e9) wrong.\n" );
02495         return FALSE;
02496     }
02497
02498     /* ok, the double tag test worked */
02499     return TRUE;
02500 }
02501
02502 int mesh_struct_tag_test( iMesh_Instance mesh, iBase_TagHandle* struct_tag )
02503 {
02504     int result;
02505     struct TagStruct dum_struct = { 3.0e12, 2, 3 }, dum_struct2;
02506     void* dum_struct2_ptr       = &dum_struct2;
02507     int dum_struct_alloc        = sizeof( struct TagStruct ), dum_struct_size;
02508
02509     /* create a tag */
02510     const char* tag_name = "mesh_struct_tag";
02511     iMesh_createTag( mesh, tag_name, sizeof( struct TagStruct ), iBase_BYTES, struct_tag, &result, 11 );
02512     if( iBase_SUCCESS != result )
02513     {
02514         printf( "Failed to create tag struct_tag in vertex_struct_tag_test.\n" );
02515         return FALSE;
02516     }
02517
02518     /* put a value in the first vertex and retrieve */
02519
02520     /* careful setting the value, since tags are opaque */
02521     iMesh_setEntSetData( mesh, root_set, *struct_tag, (const char*)&dum_struct, sizeof( struct TagStruct ), &result );
02522     if( iBase_SUCCESS != result )
02523     {
02524         printf( "Failed to set struct tag in mesh_struct_tag_test.\n" );
02525         return FALSE;
02526     }
02527
02528     iMesh_getEntSetData( mesh, root_set, *struct_tag, &dum_struct2_ptr, &dum_struct_alloc, &dum_struct_size, &result );
02529     if( iBase_SUCCESS != result )
02530     {
02531         printf( "Failed to get struct tag in mesh_struct_tag_test.\n" );
02532         return FALSE;
02533     }
02534
02535     if( dum_struct_size != sizeof( struct TagStruct ) )
02536     {
02537         printf( "Size of entityset struct tag wrong.\n" );
02538         return FALSE;
02539     }
02540     if( dum_struct2.test_int1 != dum_struct.test_int1 || dum_struct2.test_int2 != dum_struct.test_int2 ||
02541         dum_struct2.test_double != dum_struct.test_double )
02542     {
02543         printf( "Value of entityset struct tag wrong.\n" );
02544         return FALSE;
02545     }
02546
02547     /* ok, the int tag test worked */
02548     return TRUE;
02549 }
02550
02551 int mesh_tag_delete_test( iMesh_Instance mesh )
02552 {
02553     /* test forced, unforced deletion of tags from entities */
02554     int result;
02555     int delete_err = FALSE;
02556
02557     /* test getAlliBase_TagHandles for first entity */
02558     iBase_TagHandle* all_tags = NULL;
02559     int all_tags_alloc        = 0, all_tags_size;
02560     iMesh_getAllEntSetTags( mesh, root_set, &all_tags, &all_tags_alloc, &all_tags_size, &result );
02561     if( iBase_SUCCESS != result )
02562     {
02563         printf( "Couldn't get all tag handles from entityset.\n" );
02564         return FALSE;
02565     }
02566
02567     iMesh_rmvEntSetTag( mesh, root_set, all_tags[0], &result );
02568     if( iBase_SUCCESS != result )
02569     {
02570         printf( "Couldn't remove tag from entityset.\n" );
02571         free( all_tags );
02572         return FALSE;
02573     }
02574
02575     iMesh_destroyTag( mesh, all_tags[1], FALSE, &result );
02576     if( iBase_SUCCESS != result )
02577     {
02578         delete_err = TRUE;
02579     }
02580     if( !delete_err )
02581     {
02582         printf( "Error when unforced-deleting tag in use on a entityset.\n" );
02583         free( all_tags );
02584         return FALSE;
02585     }
02586
02587     iMesh_destroyTag( mesh, all_tags[1], TRUE, &result );
02588     if( iBase_SUCCESS != result )
02589     {
02590         printf( "Couldn't force-delete a tag in use on a entityset.\n" );
02591         free( all_tags );
02592         return FALSE;
02593     }
02594
02595     free( all_tags );
02596
02597     /* ok, we're done */
02598     return TRUE;
02599 }
02600
02601 /*!
02602   @test
02603   TSTT entityset tag Test
02604   @li Check entityset tags
02605 */
02606 int mesh_tag_test( iMesh_Instance mesh )
02607 {
02608     iBase_TagHandle int_tag, double_tag, struct_tag;
02609
02610     /* entityset int tag */
02611     int int_success = mesh_int_tag_test( mesh, &int_tag );
02612
02613     /* entityeset double tag */
02614     int double_success = mesh_double_tag_test( mesh, &double_tag );
02615
02616     /* entityset struct tag */
02617     int struct_success = mesh_struct_tag_test( mesh, &struct_tag );
02618
02619     int tag_delete_success = mesh_tag_delete_test( mesh );
02620
02621     return ( int_success && double_success && struct_success && tag_delete_success );
02622 }
02623
02624 int set_remove_contained_regression( iMesh_Instance mesh )
02625 {
02626     int err, contained;
02627     iBase_EntitySetHandle set, sub;
02628
02629     iMesh_createEntSet( mesh, 0, &set, &err );
02630     if( iBase_SUCCESS != err ) return 0;
02631     iMesh_createEntSet( mesh, 1, &sub, &err );
02632     if( iBase_SUCCESS != err ) return 0;
02633
02634     iMesh_addEntSet( mesh, sub, set, &err );
02635     if( iBase_SUCCESS != err ) return 0;
02636
02637     iMesh_isEntSetContained( mesh, set, sub, &contained, &err );
02638     if( iBase_SUCCESS != err ) return 0;
02639     if( !contained )
02640     {
02641         fprintf( stderr, "isEntSetContained returned false for contained set\n" );
02642         return 0;
02643     }
02644
02645     iMesh_rmvEntSet( mesh, sub, set, &err );
02646     if( iBase_SUCCESS != err ) return 0;
02647
02648     iMesh_isEntSetContained( mesh, set, sub, &contained, &err );
02649     if( iBase_SUCCESS != err ) return 0;
02650     if( contained )
02651     {
02652         fprintf( stderr, "isEntSetContained returned true for removed set\n" );
02653         return 0;
02654     }
02655
02656     return 1;
02657 }
02658
02659 int all_adjacency_regression( iMesh_Instance mesh )
02660 {
02661     int err;
02662
02663     double coords[] = { 0, 0, 0, 1, 1, 1 };
02664
02665     iBase_EntityHandle* verts = NULL;
02666     int verts_alloc           = 0, verts_size;
02667
02668     iBase_EntityHandle line;
02669     int status;
02670
02671     iBase_EntityHandle* adj = NULL;
02672     int adj_alloc           = 0, adj_size;
02673
02674     iMesh_newMesh( "", &mesh, &err, 0 );
02675     if( iBase_SUCCESS != err ) return 0;
02676
02677     iMesh_createVtxArr( mesh, 2, iBase_INTERLEAVED, coords, 6, &verts, &verts_alloc, &verts_size, &err );
02678     if( iBase_SUCCESS != err ) return 0;
02679
02680     iMesh_createEnt( mesh, iMesh_LINE_SEGMENT, verts, 2, &line, &status, &err );
02681     if( iBase_SUCCESS != err || status != iBase_NEW ) return 0;
02682
02683     iMesh_getEntAdj( mesh, verts[0], iBase_ALL_TYPES, &adj, &adj_alloc, &adj_size, &err );
02684     if( iBase_SUCCESS != err ) return 0;
02685     if( adj_size != 1 || adj[0] != line )
02686     {
02687         printf( "Bad: couldn't find adjacency for vertex\n" );
02688         return 0;
02689     }
02690     free( adj );
02691
02692     adj_alloc = 0;
02693     adj       = NULL;
02694     iMesh_getEntAdj( mesh, line, iBase_ALL_TYPES, &adj, &adj_alloc, &adj_size, &err );
02695     if( iBase_SUCCESS != err ) return 0;
02696     if( adj_size != 2 ||
02697         ( ( adj[0] != verts[0] || adj[1] != verts[1] ) && ( adj[0] != verts[1] || adj[1] != verts[0] ) ) )
02698     {
02699         printf( "Bad: couldn't find adjacencies for line\n" );
02700         free( adj );
02701         free( verts );
02702         return 0;
02703     }
02704     free( adj );
02705     free( verts );
02706     iMesh_dtor( mesh, &err );
02707     if( iBase_SUCCESS != err ) return 0;
02708     return 1;
02709 }
02710
02711 static int ordered_set_regression( iMesh_Instance mesh )
02712 {
02713     double coords[] = { 0, 0, 0, 1, 1, 1 };
02714     iBase_EntityHandle line, *p, verts[2], ents_in[3], ents_out[3];
02715     iBase_EntitySetHandle set;
02716     int i, err, status, two = 2, three = 3;
02717
02718     iMesh_newMesh( "", &mesh, &err, 0 );
02719     CHK( err );
02720     p = verts;
02721     iMesh_createVtxArr( mesh, 2, iBase_INTERLEAVED, coords, 6, &p, &two, &two, &err );
02722     CHK( err );
02723     iMesh_createEnt( mesh, iMesh_LINE_SEGMENT, verts, 2, &line, &status, &err );
02724     CHK( err );
02725     if( status != iBase_NEW ) return 0;
02726     iMesh_createEntSet( mesh, 1, &set, &err );
02727     CHK( err );
02728     ents_in[0] = verts[1];
02729     ents_in[1] = line;
02730     ents_in[2] = verts[0];
02731     iMesh_addEntArrToSet( mesh, ents_in, three, set, &err );
02732     CHK( err );
02733     p = ents_out;
02734     iMesh_getEntities( mesh, set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &p, &three, &three, &err );
02735     CHK( err );
02736     for( i = 0; i < three; i++ )
02737     {
02738         if( ents_in[i] != ents_out[i] )
02739         {
02740             printf( "Ordered set does not preserve order\n" );
02741             return 0;
02742         }
02743     }
02744     iMesh_dtor( mesh, &err );
02745     CHK( err );
02746     return 1;
02747 }
02748
02749 int array_allocation( iMesh_Instance mesh )
02750 {
02751     int err;
02752
02753     double coords[] = { 0, 0, 0, 1, 1, 1, 2, 2, 2, 3, 3, 3 };
02754
02755     iBase_EntityHandle* verts = NULL;
02756     int verts_alloc           = 0, verts_size;
02757
02758     iBase_EntityHandle* ents;
02759     int ents_alloc, ents_size;
02760
02761     iMesh_newMesh( "", &mesh, &err, 0 );
02762     if( iBase_SUCCESS != err ) return 0;
02763
02764     iMesh_getRootSet( mesh, &root_set, &err );
02765     if( iBase_SUCCESS != err )
02766     {
02767         printf( "Failed to return a root set.\n" );
02768         return 0;
02769     }
02770
02771     iMesh_createVtxArr( mesh, 4, iBase_INTERLEAVED, coords, 12, &verts, &verts_alloc, &verts_size, &err );
02772     if( iBase_SUCCESS != err ) return 0;
02773
02774     free( verts );
02775
02776     /* test for proper allocation when array pointer passed in null but alloc'd size not */
02777     ents_alloc = 3;
02778     ents       = NULL;
02779     iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &ents, &ents_alloc, &ents_size, &err );
02780     CHK( err );
02781
02782     free( ents );
02783
02784     /* test for proper allocation when array pointer passed in non-null but alloc'd size 0 */
02785     ents_alloc = 0;
02786     iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &ents, &ents_alloc, &ents_size, &err );
02787     CHK( err );
02788
02789     free( ents );
02790
02791     /* test for failure when passed in alloc'd size is smaller than it should be */
02792     ents_alloc -= 1;
02793     iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &ents, &ents_alloc, &ents_size, &err );
02794     if( iBase_BAD_ARRAY_SIZE != err && iBase_BAD_ARRAY_DIMENSION != err )
02795     {
02796         err = iBase_FAILURE;
02797         CHK( err );
02798     }
02799
02800     iMesh_dtor( mesh, &err );
02801     CHK( err );
02802
02803     return 1;
02804 }
02805
02806 int compare_single_iter( const char* info,
02807                          iMesh_Instance mesh,
02808                          iBase_EntitySetHandle set,
02809                          iBase_EntityHandle* contents,
02810                          int contents_size,
02811                          enum iBase_EntityType type,
02812                          enum iMesh_EntityTopology topo )
02813 {
02814     iBase_EntityIterator iter = 0;
02815     int i, twice, has_data, result = iBase_SUCCESS, result2;
02816     iBase_EntityHandle value;
02817
02818     iMesh_initEntIter( mesh, set, type, topo, 0, &iter, &result );
02819     if( iBase_SUCCESS != result )
02820     {
02821         printf( "%s:%d: Error %d initializing %s iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
02822                 (int)type, (int)topo );
02823         return result;
02824     }
02825
02826     for( twice = 0; twice < 2; ++twice )
02827     {
02828
02829         for( i = 0; i < contents_size; ++i )
02830         {
02831             iMesh_getNextEntIter( mesh, iter, &value, &has_data, &result );
02832             if( iBase_SUCCESS != result )
02833             {
02834                 printf( "%s:%d: Error %d stepping %s iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
02835                         (int)type, (int)topo );
02836                 goto end_single_iter;
02837             }
02838
02839             if( !has_data )
02840             {
02841                 printf( "%s:%d: %s iterator for type %d/topo %d ended prematurely at %d of %d\n", __FILE__, __LINE__,
02842                         info, (int)type, (int)topo, i, contents_size );
02843                 result = iBase_FAILURE;
02844                 goto end_single_iter;
02845             }
02846
02847             if( value != contents[i] )
02848             {
02849                 printf( "%s:%d: %s iterator for type %d/topo %d returned incorrect value at %d of %d\n", __FILE__,
02850                         __LINE__, info, (int)type, (int)topo, i, contents_size );
02851                 result = iBase_FAILURE;
02852                 goto end_single_iter;
02853             }
02854         }
02855
02856         iMesh_getNextEntIter( mesh, iter, &value, &has_data, &result );
02857         if( iBase_SUCCESS != result )
02858         {
02859             printf( "%s:%d: Error %d stepping %s iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
02860                     (int)type, (int)topo );
02861             goto end_single_iter;
02862         }
02863
02864         if( has_data )
02865         {
02866             printf( "%s:%d: %s iterator for type %d/topo %d did not end after %d values\n", __FILE__, __LINE__, info,
02867                     (int)type, (int)topo, contents_size );
02868             result = iBase_FAILURE;
02869             goto end_single_iter;
02870         }
02871
02872         iMesh_resetEntIter( mesh, iter, &result );
02873         if( iBase_SUCCESS != result )
02874         {
02875             printf( "%s:%d: Error %d resetting %s iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
02876                     (int)type, (int)topo );
02877             result = iBase_FAILURE;
02878             goto end_single_iter;
02879         }
02880     }
02881
02882 end_single_iter:
02883     iMesh_endEntIter( mesh, iter, &result2 );
02884     if( iBase_SUCCESS != result2 )
02885     {
02886         printf( "%s:%d: Error %d releasing %s iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
02887                 (int)type, (int)topo );
02888         if( iBase_SUCCESS == result ) result = result2;
02889     }
02890     return result;
02891 }
02892
02893 int compare_array_iter( const char* info,
02894                         iMesh_Instance mesh,
02895                         iBase_EntitySetHandle set,
02896                         iBase_EntityHandle* contents,
02897                         int contents_size,
02898                         int array_size,
02899                         enum iBase_EntityType type,
02900                         enum iMesh_EntityTopology topo )
02901 {
02902     iBase_EntityArrIterator iter = 0;
02903     int i, j, twice, has_data, result = iBase_SUCCESS, result2;
02904     iBase_EntityHandle* values;
02905     int values_size, values_alloc = array_size;
02906     values = (iBase_EntityHandle*)malloc( array_size * sizeof( iBase_EntityHandle ) );
02907
02908     iMesh_initEntArrIter( mesh, set, type, topo, array_size, 0, &iter, &result );
02909     if( iBase_SUCCESS != result )
02910     {
02911         printf( "%s:%d: Error %d initializing %s array iterator for type %d/topo %d\n", __FILE__, __LINE__, result,
02912                 info, (int)type, (int)topo );
02913         free( values );
02914         return result;
02915     }
02916
02917     for( twice = 0; twice < 2; ++twice )
02918     {
02919         i = 0;
02920         while( i < contents_size )
02921         {
02922
02923             iMesh_getNextEntArrIter( mesh, iter, &values, &values_alloc, &values_size, &has_data, &result );
02924             if( iBase_SUCCESS != result )
02925             {
02926                 printf( "%s:%d: Error %d stepping %s array iterator for type %d/topo %d\n", __FILE__, __LINE__, result,
02927                         info, (int)type, (int)topo );
02928                 goto end_arr_iter;
02929             }
02930
02931             if( !has_data || !values_size )
02932             {
02933                 printf( "%s:%d: %s array iterator for type %d/topo %d ended prematurely at %d of %d\n", __FILE__,
02934                         __LINE__, info, (int)type, (int)topo, i, contents_size );
02935                 result = iBase_FAILURE;
02936                 goto end_arr_iter;
02937             }
02938
02939             if( i + values_size > contents_size )
02940             {
02941                 printf( "%s:%d: %s array iterator for type %d/topo %d returned more than %d handles\n", __FILE__,
02942                         __LINE__, info, (int)type, (int)topo, contents_size );
02943                 result = iBase_FAILURE;
02944                 goto end_arr_iter;
02945             }
02946
02947             if( contents_size - i >= array_size && values_size < array_size )
02948             {
02949                 printf( "%s:%d: %s array iterator for type %d/topo %d returned fewer than %d handles\n", __FILE__,
02950                         __LINE__, info, (int)type, (int)topo, array_size );
02951                 result = iBase_FAILURE;
02952                 goto end_arr_iter;
02953             }
02954
02955             for( j = 0; j < values_size; ++j, ++i )
02956             {
02957                 if( values[j] != contents[i] )
02958                 {
02959                     printf( "%s:%d: %s array iterator for type %d/topo %d returned incorrect value "
02960                             "at %d of %d\n",
02961                             __FILE__, __LINE__, info, (int)type, (int)topo, i, contents_size );
02962                     result = iBase_FAILURE;
02963                     goto end_arr_iter;
02964                 }
02965             }
02966         }
02967
02968         iMesh_getNextEntArrIter( mesh, iter, &values, &values_alloc, &values_size, &has_data, &result );
02969         if( iBase_SUCCESS != result )
02970         {
02971             printf( "%s:%d: Error %d stepping %s array iterator for type %d/topo %d\n", __FILE__, __LINE__, result,
02972                     info, (int)type, (int)topo );
02973             goto end_arr_iter;
02974         }
02975
02976         if( has_data || values_size )
02977         {
02978             printf( "%s:%d: %s array iterator for type %d/topo %d did not end after %d values\n", __FILE__, __LINE__,
02979                     info, (int)type, (int)topo, contents_size );
02980             result = iBase_FAILURE;
02981             goto end_arr_iter;
02982         }
02983
02984         iMesh_resetEntArrIter( mesh, iter, &result );
02985         if( iBase_SUCCESS != result )
02986         {
02987             printf( "%s:%d: Error %d resetting %s array iterator for type %d/topo %d\n", __FILE__, __LINE__, result,
02988                     info, (int)type, (int)topo );
02989             result = iBase_FAILURE;
02990             goto end_arr_iter;
02991         }
02992     }
02993
02994 end_arr_iter:
02995     free( values );
02996     iMesh_endEntArrIter( mesh, iter, &result2 );
02997     if( iBase_SUCCESS != result2 )
02998     {
02999         printf( "%s:%d: Error %d releasing %s array iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
03000                 (int)type, (int)topo );
03001         if( iBase_SUCCESS == result ) result = result2;
03002     }
03003     return result;
03004 }
03005
03006 int test_iterator_common( const char* info,
03007                           iMesh_Instance mesh,
03008                           iBase_EntitySetHandle set,
03009                           int array_size,
03010                           enum iBase_EntityType type,
03011                           enum iMesh_EntityTopology topo )
03012 {
03013     iBase_EntityHandle* contents = NULL;
03014     int content_size = 0, content_alloc = 0;
03015     int result;
03016
03017     iMesh_getEntities( mesh, set, type, topo, &contents, &content_alloc, &content_size, &result );
03018     CHK( result );
03019     if( array_size == 1 )
03020         result = compare_single_iter( info, mesh, set, contents, content_size, type, topo );
03021     else
03022         result = compare_array_iter( info, mesh, set, contents, content_size, array_size, type, topo );
03023     free( contents );
03024     return result;
03025 }
03026
03027 int test_iterator( iMesh_Instance mesh )
03028 {
03029     int result, i;
03030     iBase_EntitySetHandle root, list, set, *setptr;
03031     iBase_EntityHandle* array = NULL;
03032     int array_len = 0, array_size = 0;
03033
03034     iMesh_getRootSet( mesh, &root, &result );
03035     CHK( result );
03036
03037     /* create some sets containing every other handle */
03038     iMesh_getEntities( mesh, root, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &array, &array_size, &array_len, &result );
03039     CHK( result );
03040     for( i = 1; i < array_size; i += 2 )
03041         array[i] = array[i - 1];
03042     for( i = 0; i < 2; ++i )
03043     {
03044         setptr = i ? &list : &set;
03045         iMesh_createEntSet( mesh, i, setptr, &result );
03046         if( iBase_SUCCESS != result ) free( array );
03047         CHK( result );
03048         iMesh_addEntArrToSet( mesh, array, array_size, *setptr, &result );
03049         if( iBase_SUCCESS != result ) free( array );
03050         CHK( result );
03051     }
03052     free( array );
03053
03054     /* test single iterator and array iterator for all types */
03055     for( i = 0; i < iBase_ALL_TYPES; ++i )
03056     {
03057         array_size = 2 * i + 2;
03058         result     = test_iterator_common( "root", mesh, root, 1, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
03059         CHK( result );
03060         result = test_iterator_common( "root", mesh, root, array_size, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
03061         CHK( result );
03062         result = test_iterator_common( "list", mesh, list, 1, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
03063         CHK( result );
03064         result = test_iterator_common( "list", mesh, list, array_size, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
03065         CHK( result );
03066         result = test_iterator_common( "set", mesh, set, 1, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
03067         CHK( result );
03068         result = test_iterator_common( "set", mesh, set, array_size, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
03069         CHK( result );
03070     }
03071
03072     /* test single iterator and array iterator for all types */
03073     for( i = 0; i < iMesh_ALL_TOPOLOGIES; ++i )
03074     {
03075         array_size = 2 * i + 2;
03076         result     = test_iterator_common( "root", mesh, root, 1, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
03077         CHK( result );
03078         result = test_iterator_common( "root", mesh, root, array_size, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
03079         CHK( result );
03080         result = test_iterator_common( "list", mesh, list, 1, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
03081         CHK( result );
03082         result = test_iterator_common( "list", mesh, list, array_size, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
03083         CHK( result );
03084         result = test_iterator_common( "set", mesh, set, 1, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
03085         CHK( result );
03086         result = test_iterator_common( "set", mesh, set, array_size, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
03087         CHK( result );
03088     }
03089
03090     return 1;
03091 }
03092
03093 int main( int argc, char* argv[] )
03094 {
03095     /* Check command line arg */
03096     const char* filename;
03097     int number_tests                 = 0;
03098     int number_tests_successful      = 0;
03099     int number_tests_not_implemented = 0;
03100     int number_tests_failed          = 0;
03101     int result;
03102     iMesh_Instance mesh = NULL;
03103
03104     if( argc == 2 )
03105     {
03106         filename = argv[1];
03107     }
03108     else
03109     {
03110         printf( "Usage: %s <mesh_filename>\n", argv[0] );
03111         if( argc != 1 ) return 1;
03112         printf( "  No file specified.  Defaulting to: %s\n", DEFAULT_INPUT_FILE );
03113         filename = DEFAULT_INPUT_FILE;
03114     }
03115
03116     /* initialize the Mesh */
03117     iMesh_newMesh( NULL, &mesh, &result, 0 );
03118     if( iBase_SUCCESS != result )
03119     {
03120         printf( "Failed to create a mesh instance.\n" );
03121         return 1;
03122     }
03123     iMesh_getRootSet( mesh, &root_set, &result );
03124     if( iBase_SUCCESS != result )
03125     {
03126         printf( "Failed to return a root set.\n" );
03127         return 1;
03128     }
03129
03130     /* Print out Header information */
03131     printf( "\n\nTSTT TEST PROGRAM:\n\n" );
03132
03133     /* load_mesh test */
03134     printf( "   load_mesh: " );
03135     result = load_mesh_test( filename, mesh );
03136     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03137     number_tests++;
03138     printf( "\n" );
03139
03140     /* topology_adjacency_test */
03141     printf( "   topology_adjacency_test: " );
03142     result = topology_adjacency_test( mesh );
03143     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03144     number_tests++;
03145     printf( "\n" );
03146
03147     /* entity connectivity test */
03148     printf( "   entity_connectivity_test: " );
03149     result = entity_connectivity_test( mesh );
03150     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03151     number_tests++;
03152     printf( "\n" );
03153
03154     /* vertex_coordinates_test */
03155     printf( "   vertex_coordinates_test: " );
03156     result = vertex_coordinates_test( mesh );
03157     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03158     number_tests++;
03159     printf( "\n" );
03160
03161     /* topology dimension test */
03162     printf( "   topology_dimension_test: " );
03163     result = topology_dimension_test( mesh );
03164     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03165     number_tests++;
03166     printf( "\n" );
03167
03168     /* entity sets test */
03169     printf( "   entity_sets_test: " );
03170     result = entity_sets_test( mesh );
03171     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03172     number_tests++;
03173     printf( "\n" );
03174
03175     /* vertex tag test */
03176     printf( "   vertex_tag_test: " );
03177     result = vertex_tag_test( mesh );
03178     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03179     number_tests++;
03180     printf( "\n" );
03181
03182     /* entityset tag test */
03183     printf( "   entityset_tag_test: " );
03184     result = entityset_tag_test( mesh );
03185     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03186     number_tests++;
03187     printf( "\n" );
03188
03189     /* mesh tag test */
03190     printf( "   mesh_tag_test: " );
03191     result = mesh_tag_test( mesh );
03192     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03193     number_tests++;
03194     printf( "\n" );
03195
03196     /* iterator test */
03197     printf( "   test_iterator: " );
03198     result = test_iterator( mesh );
03199     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03200     number_tests++;
03201     printf( "\n" );
03202
03203     /* regression test for remove/contained bug */
03204     printf( "   set_remove_contained_regression: " );
03205     result = set_remove_contained_regression( mesh );
03206     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03207     number_tests++;
03208     printf( "\n" );
03209
03210     /* regression test for adjacencies with iBase_ALL_TYPES bug */
03211     printf( "   all_adjacency_regression: " );
03212     result = all_adjacency_regression( mesh );
03213     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03214     number_tests++;
03215     printf( "\n" );
03216
03217     /* test for error codes */
03218     printf( "   error_code_test: " );
03219     result = error_code_test( mesh );
03220     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03221     number_tests++;
03222     printf( "\n" );
03223
03224     /* regression test for ordered sets not preserving order */
03225     printf( "   ordered_set_regression: " );
03226     result = ordered_set_regression( mesh );
03227     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03228     number_tests++;
03229     printf( "\n" );
03230
03231     /* test for array allocation behavior */
03232     printf( "   array_allocation_regression: " );
03233     result = array_allocation( mesh );
03234     handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
03235     number_tests++;
03236     printf( "\n" );
03237
03238     /* summary */
03239
03240     printf( "\nTSTT TEST SUMMARY: \n" );
03241
03242     printf( "   Number Tests:           %d\n", number_tests );
03243     printf( "   Number Successful:      %d\n", number_tests_successful );
03244     printf( "   Number Not Implemented: %d\n", number_tests_not_implemented );
03245     printf( "   Number Failed:          %d\n", number_tests_failed );
03246     printf( "\n\n\n" );
03247
03248     /* delete the mesh */
03249     iMesh_dtor( mesh, &result );
03250     if( iBase_SUCCESS != result )
03251     {
03252         printf( "Failed to destruct the mesh instance.\n" );
03253         return 1;
03254     }
03255
03256     return number_tests_failed;
03257 }
