testgeom.cpp File Reference
#include "FBiGeom.h"
#include <iostream>
#include <set>
#include <algorithm>
#include <vector>
#include <iterator>
#include <iomanip>
#include <cassert>
#include <cstring>
#include <cmath>
+ Include dependency graph for testgeom.cpp:
Classes
class  SimpleArray< T >
Defines
#define CHECK(STR)   if( err != iBase_SUCCESS ) return print_error( STR, err, geom, __FILE__, __LINE__ )
#define STRINGIFY(S)   XSTRINGIFY( S )
#define XSTRINGIFY(S)   #S
#define ARRAY_INOUT(A)   A.ptr(), &( A ).capacity(), &( A ).size()
#define ARRAY_IN(A)   &( A )[0], ( A ).size()
Typedefs
typedef iBase_TagHandle TagHandle
typedef iBase_EntityHandle GentityHandle
typedef iBase_EntitySetHandle GentitysetHandle
Functions
static bool print_error (const char *desc, int err, FBiGeom_Instance geom, const char *file, int line)
bool gLoad_test (const std::string &filename, FBiGeom_Instance)
bool tags_test (FBiGeom_Instance geom)
bool tag_get_set_test (FBiGeom_Instance geom)
bool tag_info_test (FBiGeom_Instance geom)
bool gentityset_test (FBiGeom_Instance geom, bool, bool)
bool topology_adjacencies_test (FBiGeom_Instance geom)
bool geometry_evaluation_test (FBiGeom_Instance geom)
bool construct_test (FBiGeom_Instance geom)
bool primitives_test (FBiGeom_Instance geom)
bool transforms_test (FBiGeom_Instance geom)
bool booleans_test (FBiGeom_Instance geom)
bool shutdown_test (FBiGeom_Instance geom, std::string &engine_opt)
bool save_entset_test (FBiGeom_Instance geom)
bool mesh_size_test (FBiGeom_Instance geom)
void handle_error_code (const bool result, int &number_failed, int &, int &number_successful)
int main (int argc, char *argv[])
static bool compare_box (const double *expected_min, const double *expected_max, const double *actual_min, const double *actual_max)
static int get_entities (FBiGeom_Instance geom, int entity_type, std::vector< iBase_EntityHandle > &entities_out, iBase_TagHandle id_tag=0, std::vector< int > *ids_out=0)
static int check_firmness (FBiGeom_Instance geom, const std::vector< iBase_EntityHandle > &entities, const std::vector< int > &ids, iBase_TagHandle firmness_tag, const char *expected_value, const char *ent_type_str)
static int count_num_with_tag (FBiGeom_Instance geom, const std::vector< iBase_EntityHandle > &ents, iBase_TagHandle tag)
Define Documentation
#define ARRAY_IN (   A)    &( A )[0], ( A ).size()
Definition at line 125 of file testgeom.cpp.
Referenced by construct_test(), gentityset_test(), primitives_test(), and tag_get_set_test().
#define ARRAY_INOUT (   A)    A.ptr(), &( A ).capacity(), &( A ).size()
#define STRINGIFY (   S)    XSTRINGIFY( S )
Definition at line 28 of file testgeom.cpp.
Referenced by main(), and mesh_size_test().
#define XSTRINGIFY (   S)    #S
Definition at line 29 of file testgeom.cpp.
Typedef Documentation
Definition at line 46 of file testgeom.cpp.
Definition at line 47 of file testgeom.cpp.
Definition at line 45 of file testgeom.cpp.
Function Documentation
Definition at line 1230 of file testgeom.cpp.
References CHECK, FBiGeom_createBrick, FBiGeom_createCylinder, FBiGeom_deleteEnt, FBiGeom_sectionEnt, FBiGeom_subtractEnts, and FBiGeom_uniteEnts.
    int err;
    // construct a brick size 1, and a cylinder rad 0.25 height 2
    iBase_EntityHandle brick = 0, cyl = 0;
    FBiGeom_createBrick( geom, 1.0, 0.0, 0.0, &brick, &err );
    CHECK( "Problems creating brick for booleans test." );
    FBiGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err );
    CHECK( "Problems creating cylinder for booleans test." );
    // subtract the cylinder from the brick
    iBase_EntityHandle subtract_result = 0;
    FBiGeom_subtractEnts( geom, brick, cyl, &subtract_result, &err );
    CHECK( "Problems subtracting for booleans subtract test." );
    // section the brick
    iBase_EntityHandle section_result = 0;
    FBiGeom_sectionEnt( geom, subtract_result, 1.0, 0.0, 0.0, 0.25, true, &section_result, &err );
    CHECK( "Problems sectioning for booleans section test." );
    // unite the section result with a new cylinder
    CHECK( "Problems creating cylinder for unite test." );
    iBase_EntityHandle unite_results;
    iBase_EntityHandle unite_input[] = { section_result, cyl };
    FBiGeom_uniteEnts( geom, unite_input, 2, &unite_results, &err );
    CHECK( "Problems uniting for booleans unite test." );
    FBiGeom_deleteEnt( geom, unite_results, &err );
    CHECK( "Problems deleting for booleans unite test." );
    return true;
static int check_firmness ( FBiGeom_Instance  geom,
const std::vector< iBase_EntityHandle > &  entities,
const std::vector< int > &  ids,
const char *  expected_value,
const char *  ent_type_str
) [static]
Definition at line 1296 of file testgeom.cpp.
References FBiGeom_getArrData, iBase_FAILURE, and iBase_SUCCESS.
Referenced by mesh_size_test().
    const int firmness_size = 4;
    std::vector< char > firmness( firmness_size * entities.size() );
    char* byte_ptr = &firmness[0];
    int err, junk1 = firmness.size(), junk2 = entities.size() * firmness_size;
    FBiGeom_getArrData( geom, &entities[0], entities.size(), firmness_tag, (void**)&byte_ptr, &junk1, &junk2, &err );
    if( iBase_SUCCESS != err ) return err;
    bool all_correct = true;
    for( unsigned i = 0; i < entities.size(); ++i )
        if( std::string( &firmness[firmness_size * i], firmness_size ) != expected_value ) all_correct = false;
    if( !all_correct )
        std::cout << "ERROR: Expected \"" << expected_value << "\" firmness "
                  << "for all " << ent_type_str << "." << std::endl;
        std::cout << "ID  Actual  " << std::endl;
            std::cout << std::setw( 2 ) << ids[i] << "  " << std::string( &firmness[firmness_size * i], firmness_size )
                      << std::endl;
        return iBase_FAILURE;
    return iBase_SUCCESS;
static bool compare_box ( const double *  expected_min,
const double *  expected_max,
const double *  actual_min,
const double *  actual_max
) [static]
Definition at line 1085 of file testgeom.cpp.
Referenced by primitives_test().
    bool same   = true;
    double dtol = 1.0e-6;
    for( int i = 0; i < 3; ++i )
        if( expected_min[i] < actual_min[i] - dtol || expected_min[i] * 10 > actual_min[i] ||
            expected_max[i] > actual_max[i] + dtol || expected_max[i] * 10 < actual_max[i] )
            same = false;
    return same;
Test:
TSTTG construct Test
  • Check construction of geometry
Test:
Test:
Definition at line 1028 of file testgeom.cpp.
References ARRAY_IN, ARRAY_INOUT, CHECK, FBiGeom_createCylinder, FBiGeom_deleteEnt, FBiGeom_getArrBoundBox, FBiGeom_getEntAdj, FBiGeom_moveEnt, FBiGeom_sweepEntAboutAxis, iBase_FACE, iBase_INTERLEAVED, and SimpleArray< T >::size().
    int err;
    iBase_EntityHandle new_body = 0;
    // construct a cylinder, sweep it about an axis, and delete the result
    iBase_EntityHandle cyl = 0;
    FBiGeom_createCylinder( geom, 1.0, 1.0, 0.0, &cyl, &err );
    // Is the minor radius really supposed to be zero??? - JK
    CHECK( "Creating cylinder failed." );
    // move it onto the y axis
    FBiGeom_moveEnt( geom, cyl, 0.0, 1.0, -0.5, &err );
    CHECK( "Problems moving surface." );
    // get the surface with max z
    iBase_EntityHandle max_surf = 0;
    SimpleArray< iBase_EntityHandle > surfs;
    FBiGeom_getEntAdj( geom, cyl, iBase_FACE, ARRAY_INOUT( surfs ), &err );
    CHECK( "Problems getting max surf for rotation." );
    SimpleArray< double > max_corn, min_corn;
    FBiGeom_getArrBoundBox( geom, ARRAY_IN( surfs ), iBase_INTERLEAVED, ARRAY_INOUT( min_corn ),
                            ARRAY_INOUT( max_corn ), &err );
    for( int i = 0; i < surfs.size(); ++i )
        if( ( max_corn[3 * i + 2] ) <= dtol && ( max_corn[3 * i + 2] ) >= -dtol && ( min_corn[3 * i + 2] ) <= dtol &&
            ( min_corn[3 * i + 2] ) >= -dtol )
            max_surf = surfs[i];
            break;
    if( 0 == max_surf )
        std::cerr << "Couldn't find max surf for rotation." << std::endl;
        return false;
    // sweep it around the x axis
    FBiGeom_moveEnt( geom, cyl, 0.0, 1.0, 0.0, &err );
    FBiGeom_sweepEntAboutAxis( geom, max_surf, 360.0, 1.0, 0.0, 0.0, &new_body, &err );
    CHECK( "Problems sweeping surface about axis." );
    // now delete
    FBiGeom_deleteEnt( geom, new_body, &err );
    CHECK( "Problems deleting cylinder or swept surface body." );
    // if we got here, we were successful
    return true;
static int count_num_with_tag ( FBiGeom_Instance  geom,
const std::vector< iBase_EntityHandle > &  ents,
iBase_TagHandle  tag
) [static]
Definition at line 1328 of file testgeom.cpp.
References FBiGeom_getData, FBiGeom_getTagSizeBytes, iBase_SUCCESS, and iBase_TAG_NOT_FOUND.
    int err, bytes;
    FBiGeom_getTagSizeBytes( geom, tag, &bytes, &err );
    if( iBase_SUCCESS != err ) return -1;
    std::vector< char > data( bytes );
    int success_count = 0;
    for( size_t i = 0; i < ents.size(); ++i )
        char* ptr = &data[0];
        int junk1 = bytes, junk2;
        FBiGeom_getData( geom, ents[i], tag, (void**)&ptr, &junk1, &junk2, &err );
        if( iBase_TAG_NOT_FOUND == err ) continue;
        ++success_count;
    return success_count;
bool gentityset_test ( FBiGeom_Instance  geom,
bool  ,
bool
Test:
TSTT gentity sets test (just implemented parts for now)
  • Check gentity sets
Test:
Test:
Definition at line 509 of file testgeom.cpp.
References ARRAY_IN, ARRAY_INOUT, CHECK, children, FBiGeom_addEntArrToSet, FBiGeom_addEntSet, FBiGeom_addPrntChld, FBiGeom_createEntSet, FBiGeom_getChldn, FBiGeom_getEntities, FBiGeom_getEntSets, FBiGeom_getNumChld, FBiGeom_getNumEntSets, FBiGeom_getNumOfType, FBiGeom_getNumPrnt, FBiGeom_getPrnts, FBiGeom_getRootSet, FBiGeom_intersect, FBiGeom_isChildOf, FBiGeom_rmvEntArrFromSet, FBiGeom_rmvPrntChld, FBiGeom_subtract, FBiGeom_unite, iBase_EDGE, iBase_FACE, iBase_REGION, iBase_VERTEX, root_set, and SimpleArray< T >::size().
    int num_type = 4;
    iBase_EntitySetHandle ges_array[4];
    int number_array[4];
    // int num_all_gentities_super = 0;
    int ent_type = iBase_VERTEX;
    int err;
    iBase_EntitySetHandle root_set;
    FBiGeom_getRootSet( geom, &root_set, &err );
    CHECK( "ERROR : getRootSet failed!" );
    // get the number of sets in the whole model
    int all_sets = 0;
    FBiGeom_getNumEntSets( geom, root_set, 0, &all_sets, &err );
    CHECK( "Problem getting the number of all gentity sets in whole model." );
    // add gentities to entitysets by type
    for( ; ent_type < num_type; ent_type++ )
        // initialize the entityset
        FBiGeom_createEntSet( geom, true, &ges_array[ent_type], &err );
        CHECK( "Problem creating entityset." );
        // get entities by type in total "mesh"
        SimpleArray< iBase_EntityHandle > gentities;
        FBiGeom_getEntities( geom, root_set, ent_type, ARRAY_INOUT( gentities ), &err );
        CHECK( "Failed to get gentities by type in gentityset_test." );
        // add gentities into gentity set
        FBiGeom_addEntArrToSet( geom, ARRAY_IN( gentities ), ges_array[ent_type], &err );
        CHECK( "Failed to add gentities in entityset_test." );
        // Check to make sure entity set really has correct number of entities in it
        FBiGeom_getNumOfType( geom, ges_array[ent_type], ent_type, &number_array[ent_type], &err );
        CHECK( "Failed to get number of gentities by type in entityset_test." );
        // compare the number of entities by type
        int num_type_gentity = gentities.size();
        if( number_array[ent_type] != num_type_gentity )
            std::cerr << "Number of gentities by type is not correct" << std::endl;
            return false;
        // add to number of all entities in super set
        // num_all_gentities_super += num_type_gentity;
    // make a super set having all entitysets
    iBase_EntitySetHandle super_set;
    FBiGeom_createEntSet( geom, true, &super_set, &err );
    CHECK( "Failed to create a super set in gentityset_test." );
    for( int i = 0; i < num_type; i++ )
        FBiGeom_addEntSet( geom, ges_array[i], super_set, &err );
    //----------TEST BOOLEAN OPERATIONS----------------//
    iBase_EntitySetHandle temp_ges1;
    FBiGeom_createEntSet( geom, true, &temp_ges1, &err );
    // Subtract
    // add all EDGEs and FACEs to temp_es1
    // get all EDGE entities
    SimpleArray< iBase_EntityHandle > gedges, gfaces, temp_gentities1;
    FBiGeom_getEntities( geom, ges_array[iBase_EDGE], iBase_EDGE, ARRAY_INOUT( gedges ), &err );
    CHECK( "Failed to get gedge gentities in gentityset_test." );
    // add EDGEs to ges1
    FBiGeom_addEntArrToSet( geom, ARRAY_IN( gedges ), temp_ges1, &err );
    CHECK( "Failed to add gedge gentities in gentityset_test." );
    // get all FACE gentities
    FBiGeom_getEntities( geom, ges_array[iBase_FACE], iBase_FACE, ARRAY_INOUT( gfaces ), &err );
    CHECK( "Failed to get gface gentities in gentityset_test." );
    // add FACEs to es1
    FBiGeom_addEntArrToSet( geom, ARRAY_IN( gfaces ), temp_ges1, &err );
    CHECK( "Failed to add gface gentities in gentityset_test." );
    // subtract EDGEs
    FBiGeom_subtract( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err );
    CHECK( "Failed to subtract gentitysets in gentityset_test." );
    FBiGeom_getEntities( geom, temp_ges1, iBase_FACE, ARRAY_INOUT( temp_gentities1 ), &err );
    if( gfaces.size() != temp_gentities1.size() )
        std::cerr << "Number of entitysets after subtraction not correct \
                  << std::endl;
        return false;
    // check there's nothing but gfaces in temp_ges1
    int num_gents;
    FBiGeom_getNumOfType( geom, temp_ges1, iBase_EDGE, &num_gents, &err );
    CHECK( "Failed to get dimensions of gentities in gentityset_test." );
    if( 0 != num_gents )
        std::cerr << "Subtraction failed to remove all edges" << std::endl;
        return false;
    //------------Intersect------------
    // clean out the temp_ges1
    FBiGeom_rmvEntArrFromSet( geom, ARRAY_IN( gfaces ), temp_ges1, &err );
    CHECK( "Failed to remove gface gentities in gentityset_test." );
    // check if it is really cleaned out
    FBiGeom_getNumOfType( geom, temp_ges1, iBase_FACE, &num_gents, &err );
    CHECK( "Failed to get number of gentities by type in gentityset_test." );
    if( num_gents != 0 )
        std::cerr << "failed to remove correctly." << std::endl;
        return false;
    // add EDGEs to temp ges1
    // add FACEs to temp ges1
    // intersect temp_ges1 with gedges set
    // temp_ges1 entityset is altered
    FBiGeom_intersect( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err );
    CHECK( "Failed to intersect in gentityset_test." );
    // try to get FACEs, but there should be nothing but EDGE
        std::cerr << "wrong number of gfaces." << std::endl;
        return false;
    //-------------Unite--------------
    // get all regions
    iBase_EntitySetHandle temp_ges2;
    SimpleArray< iBase_EntityHandle > gregions;
    FBiGeom_createEntSet( geom, true, &temp_ges2, &err );
    CHECK( "Failed to create a temp gentityset in gentityset_test." );
    FBiGeom_getEntities( geom, ges_array[iBase_REGION], iBase_REGION, ARRAY_INOUT( gregions ), &err );
    CHECK( "Failed to get gregion gentities in gentityset_test." );
    // add REGIONs to temp es2
    FBiGeom_addEntArrToSet( geom, ARRAY_IN( gregions ), temp_ges2, &err );
    CHECK( "Failed to add gregion gentities in gentityset_test." );
    // unite temp_ges1 and temp_ges2
    // temp_ges1 gentityset is altered
    FBiGeom_unite( geom, temp_ges1, temp_ges2, &temp_ges1, &err );
    CHECK( "Failed to unite in gentityset_test." );
    // perform the check
    FBiGeom_getNumOfType( geom, temp_ges1, iBase_REGION, &num_gents, &err );
    CHECK( "Failed to get number of gregion gentities by type in gentityset_test." );
    if( num_gents != number_array[iBase_REGION] )
        std::cerr << "different number of gregions in gentityset_test." << std::endl;
        return false;
    //--------Test parent/child stuff in entiysets-----------
    // Add 2 sets as children to another
    iBase_EntitySetHandle parent_child;
    FBiGeom_createEntSet( geom, true, &parent_child, &err );
    CHECK( "Problem creating gentityset in gentityset_test." );
    FBiGeom_addPrntChld( geom, ges_array[iBase_VERTEX], parent_child, &err );
    CHECK( "Problem add parent in gentityset_test." );
    // check if parent is really added
    SimpleArray< iBase_EntitySetHandle > parents;
    FBiGeom_getPrnts( geom, parent_child, 1, ARRAY_INOUT( parents ), &err );
    CHECK( "Problem getting parents in gentityset_test." );
    if( parents.size() != 1 )
        std::cerr << "number of parents is not correct in gentityset_test." << std::endl;
        return false;
    // add parent and child
    // sidl::array<void*> parent_child_array = sidl::array<void*>::create1d(1);
    // int num_parent_child_array;
    // sidl::array<void*> temp_gedge_array = sidl::array<void*>::create1d(1);
    // int num_temp_gedge_array;
    // parent_child_array.set(0, parent_child);
    // temp_gedge_array.set(0, ges_array[TSTTG::EntityType_EDGE]);
    FBiGeom_addPrntChld( geom, ges_array[iBase_EDGE], parent_child, &err );
    CHECK( "Problem adding parent and child in gentityset_test." );
    // sidl::array<void*> temp_gface_array = sidl::array<void*>::create1d(1);
    // int num_temp_gface_array;
    // temp_gface_array.set(0, ges_array[TSTTG::EntityType_FACE]);
    FBiGeom_addPrntChld( geom, parent_child, ges_array[iBase_FACE], &err );
    // add child
    FBiGeom_addPrntChld( geom, parent_child, ges_array[iBase_REGION], &err );
    CHECK( "Problem adding child in gentityset_test." );
    // get the number of parent gentitysets
    num_gents = -1;
    FBiGeom_getNumPrnt( geom, parent_child, 1, &num_gents, &err );
    CHECK( "Problem getting number of parents in gentityset_test." );
    if( num_gents != 2 )
        return false;
    // get the number of child gentitysets
    num_gents = -1;
    FBiGeom_getNumChld( geom, parent_child, 1, &num_gents, &err );
    CHECK( "Problem getting number of children in gentityset_test." );
        std::cerr << "number of children is not correct in gentityset_test." << std::endl;
        return false;
    SimpleArray< iBase_EntitySetHandle > children;
    FBiGeom_getChldn( geom, parent_child, 1, ARRAY_INOUT( children ), &err );
    CHECK( "Problem getting children in gentityset_test." );
    if( children.size() != 2 )
        return false;
    // remove children
    FBiGeom_rmvPrntChld( geom, parent_child, ges_array[iBase_FACE], &err );
    CHECK( "Problem removing parent child in gentityset_test." );
    if( num_gents != 1 )
        return false;
    // parent_child and ges_array[TSTTG::EntityType_EDGE] should be related
    int result = 0;
    FBiGeom_isChildOf( geom, ges_array[iBase_EDGE], parent_child, &result, &err );
    CHECK( "Problem checking relation in gentityset_test." );
    if( !result )
        std::cerr << "parent_child and ges_array[TSTTG::EntityType_EDGE] should be related" << std::endl;
        return false;
    // ges_array[TSTTG::EntityType_FACE] and ges_array[TSTTG::REGION] are not related
    result = 2;
    FBiGeom_isChildOf( geom, ges_array[iBase_FACE], ges_array[iBase_REGION], &result, &err );
    if( result )
        std::cerr << "ges_array[TSTTG::REGION] and ges_array[TSTTG::EntityType_FACE] should not be "
                     "related"
                  << std::endl;
        return false;
    //--------test modify and query functions-----------------------------
    // check the number of gentity sets in whole mesh
    SimpleArray< iBase_EntitySetHandle > gentity_sets;
    FBiGeom_getEntSets( geom, root_set, 1, ARRAY_INOUT( gentity_sets ), &err );
    CHECK( "Problem to get all gentity sets in mesh." );
    if( gentity_sets.size() != all_sets + 8 )
        std::cerr << "the number of gentity sets in whole mesh should be 8 times of num_iter." << std::endl;
        return false;
    // get all gentity sets in super set
    SimpleArray< iBase_EntitySetHandle > ges_array1;
    FBiGeom_getEntSets( geom, super_set, 1, ARRAY_INOUT( ges_array1 ), &err );
    CHECK( "Problem to get gentity sets in super set." );
    // get the number of gentity sets in super set
    int num_super;
    FBiGeom_getNumEntSets( geom, super_set, 1, &num_super, &err );
    CHECK( "Problem to get the number of all gentity sets in super set." );
    // the number of gentity sets in super set should be same
    if( num_super != ges_array1.size() )
        std::cerr << "the number of gentity sets in super set should be same." << std::endl;
        return false;
    // get all entities in super set
    SimpleArray< iBase_EntitySetHandle > all_gentities;
    FBiGeom_getEntSets( geom, super_set, 1, ARRAY_INOUT( all_gentities ), &err );
    CHECK( "Problem to get all gentities in super set." );
    // compare the number of all gentities in super set
    // HJK : num_hops is not implemented
    // if (num_all_gentities_super != ARRAY_SIZE(all_gentities)) {
    // std::cerr << "number of all gentities in super set should be same." << std::endl;
    // success = false;
    // test add, remove and get all entitiy sets using super set
    // check GetAllGentitysets works recursively and dosen't return
    // multi sets
    for( int k = 0; k < num_super; k++ )
        // add gentity sets of super set to each gentity set of super set
        // make multiple child super sets
        iBase_EntitySetHandle ges_k = ges_array1[k];
        for( int a = 0; a < ges_array1.size(); a++ )
            FBiGeom_addEntSet( geom, ges_array1[a], ges_k, &err );
            CHECK( "Problem to add entity set." );
        // add super set to each entity set
        //    sidl::array<GentitysetHandle> superset_array
        //= sidl::array<GentitysetHandle>::create1d(1);
        // superset_array.set(0, super_set);
        // int num_superset_array;
        FBiGeom_addEntSet( geom, super_set, ges_k, &err );
        CHECK( "Problem to add super set to gentitysets." );
        // add one gentity sets multiple times
        // HJK: ??? how to deal this case?
        // sidl::array<GentitysetHandle> temp_array1
        // int num_temp_array1;
        // temp_array1.set(0, temp_ges1);
        // for (int l = 0; l < 3; l++) {
        FBiGeom_addEntSet( geom, temp_ges1, ges_k, &err );
        CHECK( "Problem to add temp set to gentitysets." );
    return true;
Test:
FBiGeom_MOAB topology adjacencies Test
  • Check topology information
  • Check adjacency
Test:
  • Check adjacency
Test:
  • Check adjacency
Definition at line 975 of file testgeom.cpp.
References ARRAY_INOUT, SimpleArray< T >::begin(), CHECK, SimpleArray< T >::end(), FBiGeom_getEntBoundBox, FBiGeom_getEntClosestPt, FBiGeom_getEntities, FBiGeom_getRootSet, iBase_ALL_TYPES, iBase_EDGE, iBase_REGION, iBase_VERTEX, root_set, and SimpleArray< T >::size().
Referenced by main().
    int i, err;
    int top          = iBase_VERTEX;
    int num_test_top = iBase_ALL_TYPES;
    std::vector< std::vector< iBase_EntityHandle > > gentity_vectors( num_test_top );
    // fill the vectors of each topology entities
    // like lines vector, polygon vector, triangle vector,
    // quadrilateral, polyhedrron, tet, hex, prism, pyramid,
    // septahedron vectors
    for( i = top; i < num_test_top; i++ )
        FBiGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err );
        CHECK( "Failed to get gentities in adjacencies_test." );
        gentity_vectors[i].resize( gentities.size() );
        std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() );
    // check adjacencies in both directions
    double min[3], max[3], on[3];
    double near[3] = { .0, .0, .0 };
    std::vector< iBase_EntityHandle >::iterator vit;
    for( i = iBase_REGION; i >= iBase_VERTEX; i-- )
        if( i != iBase_EDGE )
            for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit )
                iBase_EntityHandle this_gent = *vit;
                FBiGeom_getEntBoundBox( geom, this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err );
                CHECK( "Failed to get bounding box of entity." );
                FBiGeom_getEntClosestPt( geom, this_gent, near[0], near[1], near[2], &on[0], &on[1], &on[2], &err );
                CHECK( "Failed to get closest point on entity." );
    return true;
static int get_entities ( FBiGeom_Instance  geom,
int  entity_type,
std::vector< iBase_EntityHandle > &  entities_out,
iBase_TagHandle  id_tag = 0,
std::vector< int > *  ids_out = 0
) [static]
Definition at line 1264 of file testgeom.cpp.
References FBiGeom_getEntities, FBiGeom_getIntArrData, FBiGeom_getNumOfType, FBiGeom_getRootSet, and iBase_SUCCESS.
    int err, num;
    iBase_EntitySetHandle root;
    FBiGeom_getRootSet( geom, &root, &err );
    FBiGeom_getNumOfType( geom, root, entity_type, &num, &err );
    entities_out.resize( num );
    int junk1                    = entities_out.size(), junk2;
    iBase_EntityHandle* junk_ptr = &entities_out[0];
    FBiGeom_getEntities( geom, root, entity_type, &junk_ptr, &junk1, &junk2, &err );
    assert( num == junk1 && num == junk2 );
    if( !ids_out ) return iBase_SUCCESS;
    ids_out->resize( num );
    int* int_ptr = &( *ids_out )[0];
    FBiGeom_getIntArrData( geom, &entities_out[0], num, id_tag, &int_ptr, &junk1, &junk2, &err );
bool gLoad_test ( const std::string &  filename,
Test:
Load Mesh
  • Load a mesh file
Definition at line 305 of file testgeom.cpp.
References CHECK, FBiGeom_getNumOfType, FBiGeom_getRootSet, FBiGeom_load, and root_set.
    int err;
    FBiGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 );
    CHECK( "ERROR : can not load a geometry" );
    // print out the number of entities
    std::cout << "Model contents: " << std::endl;
    const char* gtype[] = { "vertices: ", "edges: ", "faces: ", "regions: " };
    for( int i = 0; i <= 3; ++i )
        int count;
        FBiGeom_getNumOfType( geom, root_set, i, &count, &err );
        CHECK( "Error: problem getting entities after gLoad." );
        std::cout << gtype[i] << count << std::endl;
    return true;
void handle_error_code ( const bool  result,
int &  number_failed,
int &  ,
int &  number_successful
Definition at line 143 of file testgeom.cpp.
    if( result )
        std::cout << "Success";
        number_successful++;
    else
        std::cout << "Failure";
        number_failed++;
int main ( int  argc,
char *  argv[]
Definition at line 157 of file testgeom.cpp.
References FBiGeom_newGeom, geom, geometry_evaluation_test(), gLoad_test(), handle_error_code(), shutdown_test(), STRINGIFY, tags_test(), and topology_adjacencies_test().
    std::string filename = STRINGIFY( MESHDIR ) "/shell.h5m";
    std::string engine_opt;
    if( argc == 1 )
        std::cout << "Using default input file: " << filename << std::endl;
    else if( argc == 2 )
        filename = argv[1];
    else
        std::cerr << "Usage: " << argv[0] << " [geom_filename]" << std::endl;
        return 1;
    bool result;
    int number_tests                 = 0;
    int number_tests_successful      = 0;
    int number_tests_not_implemented = 0;
    int number_tests_failed          = 0;
    // initialize the Mesh
    int err;
    FBiGeom_Instance geom;
    FBiGeom_newGeom( engine_opt.c_str(), &geom, &err, engine_opt.length() );
    // Print out Header information
    std::cout << "\n\nITAPS GEOMETRY INTERFACE TEST PROGRAM:\n\n";
    // gLoad test
    std::cout << "   gLoad: ";
    result = gLoad_test( filename, geom );
    handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
    number_tests++;
    std::cout << "\n";
    // tags test
    std::cout << "   tags: ";
    result = tags_test( geom );
    number_tests++;
    std::cout << "\n";
      // gentitysets test
    std::cout << "   gentity sets: ";
    result = gentityset_test(geom, false, false);
    handle_error_code(result, number_tests_failed,
                      number_tests_successful);
    number_tests++;
    std::cout << "\n";
    // topology adjacencies test
    std::cout << "   topology adjacencies: ";
    result = topology_adjacencies_test( geom );
    number_tests++;
    std::cout << "\n";
    // geometry evaluation test
    std::cout << "   geometry evaluation: ";
    result = geometry_evaluation_test( geom );
    number_tests++;
    std::cout << "\n";
      // construct test
    std::cout << "   construct: ";
    result = construct_test(geom);
    number_tests++;
    std::cout << "\n";
      // primitives test
    std::cout << "   primitives: ";
    result = primitives_test(geom);
    number_tests++;
    std::cout << "\n";
      // transforms test
    std::cout << "   transforms: ";
    result = transforms_test(geom);
    number_tests++;
    std::cout << "\n";
      // booleans test
    std::cout << "   booleans: ";
    result = booleans_test(geom);
    number_tests++;
    std::cout << "\n";
  #if defined(HAVE_ACIS) && !defined(FORCE_OCC)
    std::cout << "   mesh size: ";
    result = mesh_size_test(geom);
    number_tests++;
    std::cout << "\n";
      // save entset test
    std::cout << "   save entset: ";
    result = save_entset_test(geom);
    number_tests++;
    std::cout << "\n";
  #endif
    // shutdown test
    std::cout << "   shutdown: ";
    result = shutdown_test( geom, engine_opt );
    number_tests++;
    std::cout << "\n";
    // summary
    std::cout << "\nTSTT TEST SUMMARY: \n"
              << "   Number Tests:           " << number_tests << "\n"
              << "   Number Successful:      " << number_tests_successful << "\n"
              << "   Number Not Implemented: " << number_tests_not_implemented << "\n"
              << "   Number Failed:          " << number_tests_failed << "\n\n"
              << std::endl;
    return number_tests_failed;
Definition at line 1351 of file testgeom.cpp.
References CHECK, check_firmness(), count_num_with_tag(), FBiGeom_deleteAll, FBiGeom_getDblArrData, FBiGeom_getIntArrData, FBiGeom_getTagHandle, FBiGeom_load, get_entities(), iBase_EDGE, iBase_FACE, iBase_FAILURE, iBase_REGION, iBase_SUCCESS, iBase_VERTEX, size, sizes, and STRINGIFY.
    const char* filename = STRINGIFY( SRCDIR ) "/size.sat";
    int err, junk1, junk2;
    bool result = true;
    FBiGeom_deleteAll( geom, &err );
    CHECK( "" );
    FBiGeom_load( geom, filename, 0, &err, strlen( filename ), 0 );
    CHECK( "Failed to load input file: 'size.sat'" );
    // get tag handles
    iBase_TagHandle interval, size, firmness, id;
    FBiGeom_getTagHandle( geom, "MESH_INTERVAL", &interval, &err, strlen( "MESH_INTERVAL" ) );
    CHECK( "FBiGeom_getTagHandle(\"MESH_INTERVAL\")" );
    FBiGeom_getTagHandle( geom, "MESH_SIZE", &size, &err, strlen( "MESH_SIZE" ) );
    CHECK( "FBiGeom_getTagHandle(\"MESH_SIZE\")" );
    FBiGeom_getTagHandle( geom, "SIZE_FIRMNESS", &firmness, &err, strlen( "SIZE_FIRMNESS" ) );
    CHECK( "FBiGeom_getTagHandle(\"SIZE_FIRMNESS\")" );
    FBiGeom_getTagHandle( geom, "GLOBAL_ID", &id, &err, strlen( "GLOBAL_ID" ) );
    CHECK( "FBiGeom_getTagHandle(\"GLOBAL_ID\")" );
    // get entity lists
    std::vector< iBase_EntityHandle > verts, curves, surfs, vols;
    std::vector< int > vert_ids, curve_ids, surf_ids, vol_ids;
    err = get_entities( geom, iBase_VERTEX, verts, id, &vert_ids );
    CHECK( "" );
    err = get_entities( geom, iBase_EDGE, curves, id, &curve_ids );
    CHECK( "" );
    err = get_entities( geom, iBase_FACE, surfs, id, &surf_ids );
    CHECK( "" );
    err = get_entities( geom, iBase_REGION, vols, id, &vol_ids );
    CHECK( "" );
    // expect interval count to be the same as ID for every curve
    std::vector< int > intervals( curves.size() );
    int* int_ptr = &intervals[0];
    junk1 = junk2 = curves.size();
    FBiGeom_getIntArrData( geom, &curves[0], curves.size(), interval, &int_ptr, &junk1, &junk2, &err );
    CHECK( "Failed to get intervals for curves" );
    if( intervals != curve_ids )
        std::cout << "ERROR: Incorrect curve intervals for one or more curves." << std::endl;
        std::cout << "ID  Expected  Actual" << std::endl;
        for( unsigned i = 0; i < curves.size(); ++i )
            std::cout << std::setw( 2 ) << curve_ids[i] << "  " << std::setw( 8 ) << curve_ids[i] << "  "
                      << std::setw( 6 ) << intervals[i] << std::endl;
        result = false;
    // expect size to be the same as ID for every surface
    std::vector< double > sizes( surfs.size() );
    double* dbl_ptr = &sizes[0];
    junk1 = junk2 = surfs.size();
    FBiGeom_getDblArrData( geom, &surfs[0], surfs.size(), size, &dbl_ptr, &junk1, &junk2, &err );
    CHECK( "Failed to get sizes for surfaces" );
    for( unsigned i = 0; i < surfs.size(); ++i )
        if( fabs( sizes[i] - (double)surf_ids[i] ) > 1e-8 ) all_correct = false;
    if( !all_correct )
        std::cout << "ERROR: Incorrect mesh size for one or more surfaces." << std::endl;
        std::cout << "ID  Expected  Actual  " << std::endl;
            std::cout << std::setw( 2 ) << surf_ids[i] << "  " << std::setw( 8 ) << (double)surf_ids[i] << "  "
                      << std::setw( 8 ) << sizes[i] << std::endl;
        result = false;
    err = result ? iBase_SUCCESS : iBase_FAILURE;
    CHECK( "Invalid size or interval data" );
    // expect "HARD" firmness on all curves
    err = check_firmness( geom, curves, curve_ids, firmness, "HARD", "curves" );
    CHECK( "Invalid curve firmness" );
    // expect "SOFT" firmness on all surfaces
    err = check_firmness( geom, surfs, surf_ids, firmness, "SOFT", "surfaces" );
    CHECK( "Invalid surface firmness" );
    // expect no firmnes on other entities
    err = count_num_with_tag( geom, verts, firmness ) ? iBase_FAILURE : iBase_SUCCESS;
    CHECK( "Got firmness for vertex." );
    err = count_num_with_tag( geom, vols, firmness ) ? iBase_FAILURE : iBase_SUCCESS;
    CHECK( "Got firmness for volume." );
    // expect no interval tag on any entities except curves
    err = count_num_with_tag( geom, verts, interval ) ? iBase_FAILURE : iBase_SUCCESS;
    CHECK( "Got interval count for vertex." );
    err = count_num_with_tag( geom, vols, interval ) ? iBase_FAILURE : iBase_SUCCESS;
    CHECK( "Got interval count for volume." );
    // expect no size tag on any entities except surfaces
    // curves should have size of one of their parent surfaces
    err = count_num_with_tag( geom, verts, size ) ? iBase_FAILURE : iBase_SUCCESS;
    CHECK( "Got mesh size for vertex." );
    err = count_num_with_tag( geom, vols, size ) ? iBase_FAILURE : iBase_SUCCESS;
    CHECK( "Got mesh size for volume." );
    return true;
Definition at line 1102 of file testgeom.cpp.
References ARRAY_IN, ARRAY_INOUT, CHECK, compare_box(), FBiGeom_createBrick, FBiGeom_createCylinder, FBiGeom_createTorus, FBiGeom_deleteEnt, FBiGeom_getArrBoundBox, and iBase_INTERLEAVED.
    int err;
    SimpleArray< iBase_EntityHandle > prims( 3 );
    iBase_EntityHandle prim;
    FBiGeom_createBrick( geom, 1.0, 2.0, 3.0, &prim, &err );
    CHECK( "createBrick failed." );
    prims[0] = prim;
    FBiGeom_createCylinder( geom, 1.0, 4.0, 2.0, &prim, &err );
    CHECK( "createCylinder failed." );
    prims[1] = prim;
    FBiGeom_createTorus( geom, 2.0, 1.0, &prim, &err );
    CHECK( "createTorus failed." );
    prims[2] = prim;
    // verify the bounding boxes for Acis based entities
    FBiGeom_getArrBoundBox( geom, ARRAY_IN( prims ), iBase_INTERLEAVED, ARRAY_INOUT( min_corn ),
    double preset_min_corn[] =
        // min brick corner xyz
        { -0.5, -1.0, -1.5,
          // min cyl corner xyz
          -4.0, -2.0, -0.5,
          // min torus corner xyz
          -3.0, -3.0, -1.0 };
    double preset_max_corn[] =
        // max brick corner xyz
        { 0.5, 1.0, 1.5,
          // max cyl corner xyz
          4.0, 2.0, 0.5,
          // max torus corner xyz
          3.0, 3.0, 1.0 };
    if( !compare_box( preset_min_corn, preset_max_corn, &min_corn[0], &max_corn[0] ) )
        std::cerr << "Box check failed for brick" << std::endl;
        return false;
    if( !compare_box( preset_min_corn + 3, preset_max_corn + 3, &min_corn[3], &max_corn[3] ) )
        std::cerr << "Box check failed for cylinder" << std::endl;
        return false;
    if( !compare_box( preset_min_corn + 6, preset_max_corn + 6, &min_corn[6], &max_corn[6] ) )
        std::cerr << "Box check failed for torus" << std::endl;
        return false;
    // must have worked; delete the entities then return
        FBiGeom_deleteEnt( geom, prims[i], &err );
        CHECK( "Problems deleting primitive after boolean check." );
    return true;
static bool print_error ( const char *  desc,
int  err,
const char *  file,
int  line
) [static]
Definition at line 31 of file testgeom.cpp.
References buffer, and FBiGeom_getDescription.
Referenced by save_entset_test().
    char buffer[1024];
    FBiGeom_getDescription( geom, buffer, sizeof( buffer ) );
    buffer[sizeof( buffer ) - 1] = '\0';
    std::cerr << "ERROR: " << desc << std::endl
              << "  Error code: " << err << std::endl
              << "  Error desc: " << buffer << std::endl
              << "  At        : " << file << ':' << line << std::endl;
    return false;  // must always return false or CHECK macro will break
Definition at line 1469 of file testgeom.cpp.
References CHECK, FBiGeom_addEntToSet, FBiGeom_createCylinder, FBiGeom_createEntSet, FBiGeom_deleteEnt, FBiGeom_destroyEntSet, FBiGeom_getNumEntSets, FBiGeom_getNumOfType, FBiGeom_getRootSet, FBiGeom_load, FBiGeom_save, iBase_FAILURE, iBase_REGION, and print_error().
    int err;
#ifdef FORCE_OCC
    std::string filename = "testout.brep";
#elif defined( HAVE_ACIS )
    std::string filename = "testout.sat";
#elif defined( HAVE_OCC )
#else
#endif
    // initialize number of ents and sets to compare with later
    int num_ents_bef, num_sets_bef;
    CHECK( "Failed to get root set." );
    FBiGeom_getNumEntSets( geom, root, 1, &num_sets_bef, &err );
    CHECK( "Failed to get number of ent sets." );
    FBiGeom_getNumOfType( geom, root, iBase_REGION, &num_ents_bef, &err );
    CHECK( "Failed to get number of entities." );
    // create set, and entity to add to set
    iBase_EntityHandle cyl;
    CHECK( "Problems creating cylinder for save entset test." );
    iBase_EntitySetHandle seth;
    FBiGeom_createEntSet( geom, true, &seth, &err );
    CHECK( "Problems creating entity set for save entset test." );
    // add the entity
    FBiGeom_addEntToSet( geom, cyl, seth, &err );
    CHECK( "Problems adding entity to set for save entset test." );
    // save/restore the model, and see if the entity is there
    FBiGeom_save( geom, filename.c_str(), NULL, &err, filename.length(), 0 );
    CHECK( "Problems saving file for save entset test." );
    FBiGeom_destroyEntSet( geom, seth, &err );
    CHECK( "Failed to destroy entity set." );
    FBiGeom_deleteEnt( geom, cyl, &err );
    CHECK( "Failed to destroy entity." );
    // read the file back in
    FBiGeom_load( geom, filename.c_str(), NULL, &err, filename.length(), 0 );
    CHECK( "Problems reading file for save entset test." );
    // check number of sets and entities
    int num_ents_aft, num_sets_aft;
    FBiGeom_getNumEntSets( geom, root, 1, &num_sets_aft, &err );
    FBiGeom_getNumOfType( geom, root, iBase_REGION, &num_ents_aft, &err );
    bool success = true;
    if( num_ents_aft != 2 * num_ents_bef + 1 )
        print_error( "Failed to get the right number of entities.", iBase_FAILURE, geom, __FILE__, __LINE__ );
        success = false;
    else if( num_sets_aft != 2 * num_sets_bef + 1 )
        print_error( "Failed to get the right number of entity sets.", iBase_FAILURE, geom, __FILE__, __LINE__ );
        success = false;
    // otherwise, we succeeded
    return success;
bool shutdown_test ( FBiGeom_Instance  geom,
std::string &  engine_opt
Definition at line 1452 of file testgeom.cpp.
References CHECK, FBiGeom_dtor, FBiGeom_newGeom, and geom.
    int err;
    // test shutdown & startup of interface
    FBiGeom_dtor( geom, &err );
    CHECK( "Interface destruction didn't work properly." );
    CHECK( "Interface re-construction didn't work properly." );
    CHECK( "2nd Interface destruction didn't work properly." );
    return true;
Definition at line 440 of file testgeom.cpp.
References ARRAY_IN, ARRAY_INOUT, SimpleArray< T >::capacity(), CHECK, dim, FBiGeom_createTag, FBiGeom_destroyTag, FBiGeom_getArrData, FBiGeom_getEntities, FBiGeom_getRootSet, FBiGeom_setArrData, iBase_BYTES, SimpleArray< T >::ptr(), root_set, SimpleArray< T >::size(), and moab::sum().
Referenced by tags_test().
    int err;
    // create an arbitrary tag, size 4
    iBase_TagHandle this_tag;
    std::string tag_name( "tag_get_set tag" );
    FBiGeom_createTag( geom, &tag_name[0], sizeof( int ), iBase_BYTES, &this_tag, &err, tag_name.length() );
    CHECK( "ERROR : can not create a tag for get_set test." );
    // set this tag to an integer on each entity; keep track of total sum
    int sum = 0, num = 0, dim;
    for( dim = 0; dim <= 3; dim++ )
        SimpleArray< iBase_EntityHandle > gentity_handles;
        FBiGeom_getEntities( geom, root_set, dim, ARRAY_INOUT( gentity_handles ), &err );
        int num_ents = gentity_handles.size();
        std::vector< int > tag_vals( num_ents );
        for( int i = 0; i < num_ents; ++i )
            tag_vals[i] = num;
            sum += num;
            ++num;
        FBiGeom_setArrData( geom, ARRAY_IN( gentity_handles ), this_tag, (char*)&tag_vals[0],
                            tag_vals.size() * sizeof( int ), &err );
        CHECK( "ERROR : can't set tag on entities" );
    // check tag values for entities now
    int get_sum = 0;
        SimpleArray< char > tag_vals;
        FBiGeom_getArrData( geom, ARRAY_IN( gentity_handles ), this_tag, (void**)tag_vals.ptr(), &tag_vals.capacity(),
                            &tag_vals.size(), &err );
        CHECK( "ERROR : can't get tag on entities" );
        int* tag_ptr = (int*)( &tag_vals[0] );
            get_sum += tag_ptr[i];
    if( get_sum != sum )
        std::cerr << "ERROR: getData didn't return consistent results." << std::endl;
        return false;
    FBiGeom_destroyTag( geom, this_tag, true, &err );
    CHECK( "ERROR : couldn't delete tag." );
    return true;
Definition at line 345 of file testgeom.cpp.
References ARRAY_INOUT, SimpleArray< T >::begin(), CHECK, SimpleArray< T >::end(), entities, FBiGeom_createTag, FBiGeom_destroyTag, FBiGeom_getAllTags, FBiGeom_getEntities, FBiGeom_getRootSet, FBiGeom_getTagHandle, FBiGeom_getTagName, FBiGeom_getTagSizeBytes, FBiGeom_getTagSizeValues, FBiGeom_getTagType, moab::GeomUtil::first(), iBase_ALL_TYPES, iBase_BYTES, root_set, and SimpleArray< T >::size().
Referenced by tags_test(), and vertex_tag_test().
    int err;
    iBase_TagHandle this_tag, tmp_handle;
    std::string tag_name( "tag_info tag" ), tmp_name;
    FBiGeom_createTag( geom, &tag_name[0], 4, iBase_BYTES, &this_tag, &err, tag_name.length() );
    CHECK( "ERROR : can not create a tag." );
    // get information on the tag
    char name_buffer[256];
    FBiGeom_getTagName( geom, this_tag, name_buffer, &err, sizeof( name_buffer ) );
    CHECK( "ERROR : Couldn't get tag name." );
    if( tag_name != name_buffer )
        std::cerr << "ERROR: getTagName returned '" << name_buffer << "' for tag created as '" << tag_name << "'"
                  << std::endl;
        return false;
    FBiGeom_getTagHandle( geom, &tag_name[0], &tmp_handle, &err, tag_name.length() );
    CHECK( "ERROR : Couldn't get tag handle." );
    if( tmp_handle != this_tag )
        std::cerr << "ERROR: getTagHandle didn't return consistent result." << std::endl;
        return false;
    int tag_size;
    FBiGeom_getTagSizeBytes( geom, this_tag, &tag_size, &err );
    CHECK( "ERROR : Couldn't get tag size." );
    if( tag_size != 4 )
        std::cerr << "ERROR: getTagSizeBytes: expected 4, got " << tag_size << std::endl;
        return false;
    FBiGeom_getTagSizeValues( geom, this_tag, &tag_size, &err );
    if( tag_size != 4 )
        std::cerr << "ERROR: getTagSizeValues: expected 4, got " << tag_size << std::endl;
        return false;
    int tag_type;
    FBiGeom_getTagType( geom, this_tag, &tag_type, &err );
    CHECK( "ERROR : Couldn't get tag type." );
    if( tag_type != iBase_BYTES )
        std::cerr << "ERROR: getTagType: expected " << iBase_BYTES << ", got " << tag_type << std::endl;
        return false;
    CHECK( "ERROR : Couldn't delete a tag." );
    // print information about all the tags in the model
    std::set< iBase_TagHandle > tags;
    SimpleArray< iBase_EntityHandle > entities;
    FBiGeom_getEntities( geom, root_set, iBase_ALL_TYPES, ARRAY_INOUT( entities ), &err );
    CHECK( "getEntities( ..., iBase_ALL_TYPES, ... ) failed." );
    for( int i = 0; i < entities.size(); ++i )
        SimpleArray< iBase_TagHandle > tag_arr;
        FBiGeom_getAllTags( geom, entities[i], ARRAY_INOUT( tag_arr ), &err );
        CHECK( "getAllTags failed." );
        std::copy( tag_arr.begin(), tag_arr.end(), std::inserter( tags, tags.begin() ) );
    std::cout << "Tags defined on model: ";
    bool first = true;
    for( std::set< iBase_TagHandle >::iterator sit = tags.begin(); sit != tags.end(); ++sit )
        FBiGeom_getTagName( geom, *sit, name_buffer, &err, sizeof( name_buffer ) );
        name_buffer[sizeof( name_buffer ) - 1] = '\0';  // mnake sure of NUL termination
        CHECK( "getTagName failed." );
        if( !first ) std::cout << ", ";
        std::cout << name_buffer;
        first = false;
    if( first ) std::cout << "<none>";
    std::cout << std::endl;
    return true;
bool tags_test ( FBiGeom_Instance  geom)
Test:
Test tag creating, reading, writing, deleting
  • Load a mesh file
Test:
  • Load a mesh file
Test:
  • Load a mesh file
Definition at line 334 of file testgeom.cpp.
References tag_get_set_test(), and tag_info_test().
    bool success = tag_info_test( geom );
    if( !success ) return success;
    success = tag_get_set_test( geom );
    return true;
Test:
TSTTG topology adjacencies Test
  • Check adjacency
Test:
  • Check adjacency
Test:
  • Check adjacency
Definition at line 890 of file testgeom.cpp.
References ARRAY_INOUT, SimpleArray< T >::begin(), CHECK, SimpleArray< T >::end(), FBiGeom_getEntAdj, FBiGeom_getEntities, FBiGeom_getNumOfType, FBiGeom_getRootSet, iBase_ALL_TYPES, iBase_REGION, iBase_VERTEX, root_set, SimpleArray< T >::size(), and size.
    int i, err;
    // check number of entities for each topology
        int num_tops = 0;
        FBiGeom_getNumOfType( geom, root_set, i, &num_tops, &err );
        CHECK( "Failed to get number of gentities in adjacencies_test." );
        if( static_cast< int >( gentity_vectors[i].size() ) != num_tops )
            std::cerr << "Number of gentities doesn't agree with number returned for dimension " << i << std::endl;
            return false;
            // check downward adjacencies
            for( int j = iBase_VERTEX; j < i; j++ )
                SimpleArray< iBase_EntityHandle > lower_ents;
                FBiGeom_getEntAdj( geom, this_gent, j, ARRAY_INOUT( lower_ents ), &err );
                CHECK( "Bi-directional adjacencies test failed." );
                // for each of them, make sure they are adjacent to the upward ones
                int num_lower = lower_ents.size();
                for( int k = 0; k < num_lower; k++ )
                    SimpleArray< iBase_EntityHandle > upper_ents;
                    FBiGeom_getEntAdj( geom, lower_ents[k], i, ARRAY_INOUT( upper_ents ), &err );
                    if( std::find( upper_ents.begin(), upper_ents.end(), this_gent ) == upper_ents.end() )
                        std::cerr << "Didn't find lower-upper adjacency which was supposed to be "
                                     "there, dims = "
                                  << i << ", " << j << std::endl;
                        return false;
    return true;
Definition at line 1168 of file testgeom.cpp.
References CHECK, FBiGeom_createBrick, FBiGeom_deleteEnt, FBiGeom_getEntBoundBox, FBiGeom_moveEnt, FBiGeom_reflectEnt, and FBiGeom_rotateEnt.
    int err;
    iBase_EntityHandle brick = 0;
    FBiGeom_createBrick( geom, 1.0, 2.0, 3.0, &brick, &err );
    CHECK( "Problems creating brick for transforms test." );
    // move it, then test bounding box
    FBiGeom_moveEnt( geom, brick, 0.5, 1.0, 1.5, &err );
    CHECK( "Problems moving brick for transforms test." );
    double bb_min[3], bb_max[3];
    FBiGeom_getEntBoundBox( geom, brick, bb_min, bb_min + 1, bb_min + 2, bb_max, bb_max + 1, bb_max + 2, &err );
    CHECK( "Problems getting bounding box after move." );
    if( ( bb_min[0] ) >= dtol || ( bb_min[0] ) <= -dtol || ( bb_min[1] ) >= dtol || ( bb_min[1] ) <= -dtol ||
        ( bb_min[2] ) >= dtol || ( bb_min[2] ) <= -dtol || ( bb_max[0] - 1 ) >= dtol || 1 - bb_max[0] >= dtol ||
        ( bb_max[1] - 2 ) >= dtol || 2 - bb_max[1] >= dtol || ( bb_max[2] - 3 ) >= dtol || 3 - bb_max[2] >= dtol )
        std::cerr << "Wrong bounding box after move." << std::endl;
        return false;
    // now rotate it about +x, then test bounding box
    FBiGeom_rotateEnt( geom, brick, 90, 1.0, 0.0, 0.0, &err );
    CHECK( "Problems rotating brick for transforms test." );
    CHECK( "Problems getting bounding box after rotate." );
    if( ( bb_min[0] ) >= dtol || -bb_min[0] >= dtol || ( bb_min[1] + 3 ) >= dtol || -( bb_min[1] + 3 ) >= dtol ||
        ( bb_min[2] ) >= dtol || -( bb_min[2] ) >= dtol || ( bb_max[0] - 1 ) >= dtol || 1 - bb_max[0] >= dtol ||
        ( bb_max[1] ) >= dtol || -( bb_max[1] ) >= dtol || ( bb_max[2] - 2 ) >= dtol || 2 - bb_max[2] >= dtol )
        std::cerr << "Wrong bounding box after rotate." << std::endl;
        return false;
    // now reflect through y plane; should recover original bb
    FBiGeom_reflectEnt( geom, brick, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, &err );
    CHECK( "Problems reflecting brick for transforms test." );
    CHECK( "Problems getting bounding box after reflect." );
    if( ( bb_min[0] ) >= dtol || -( bb_min[0] ) >= dtol || ( bb_min[1] ) >= dtol || ( bb_min[2] ) >= dtol ||
        -( bb_min[1] ) >= dtol || -( bb_min[2] ) >= dtol || ( bb_max[0] - 1 ) >= dtol || 1 - bb_max[0] >= dtol ||
        ( bb_max[1] - 3 ) >= dtol || 3 - bb_max[1] >= dtol || ( bb_max[2] - 2 ) >= dtol || 2 - bb_max[2] >= dtol )
        std::cerr << "Wrong bounding box after reflect." << std::endl;
        return false;
    FBiGeom_deleteEnt( geom, brick, &err );
    CHECK( "Problems deleting brick after transforms check." );
    return true;
