ucdtrvpart.cpp
00001 #include "TestUtil.hpp"
00002 #include "moab/Core.hpp"
00003 #include "moab/ParallelComm.hpp"
00004 #include "moab/ProgOptions.hpp"
00005 #include "MBParallelConventions.h"
00006 #include "moab/ReadUtilIface.hpp"
00007
00008 using namespace moab;
00009
00010 std::string example = TestDir + "unittest/io/homme3x3458.t.3.nc";
00011
00012 void test_read_parallel_ucd_trivial();
00013 void test_read_parallel_ucd_trivial_spectral();
00014 void test_read_parallel( int num_verts, bool test_nb_nodes );
00015
00016 void test_multiple_loads_of_same_file();
00017
00018 std::string partition_method;
00019 const int levels = 3;
00020
00021 int main( int argc, char* argv[] )
00022 {
00023     MPI_Init( &argc, &argv );
00024     int result = 0;
00025
00026     result += RUN_TEST( test_read_parallel_ucd_trivial );
00027     result += RUN_TEST( test_read_parallel_ucd_trivial_spectral );
00028     result += RUN_TEST( test_multiple_loads_of_same_file );
00029
00030     MPI_Finalize();
00031     return result;
00032 }
00033
00034 void test_read_parallel_ucd_trivial()
00035 {
00036     partition_method = std::string( ";PARTITION_METHOD=TRIVIAL;PARALLEL_RESOLVE_SHARED_ENTS" );
00037     test_read_parallel( 3458, true );
00038 }
00039
00040 void test_read_parallel_ucd_trivial_spectral()
00041 {
00042     partition_method = std::string( ";PARTITION_METHOD=TRIVIAL;SPECTRAL_MESH;PARALLEL_RESOLVE_SHARED_ENTS" );
00043     test_read_parallel( 3458, false );
00044 }
00045
00046 void test_read_parallel( int num_verts, bool test_nb_nodes )
00047 {
00048     Core moab;
00049     Interface& mb = moab;
00050     EntityHandle file_set;
00051     ErrorCode rval;
00052     rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval );
00053
00054     std::string opt = std::string( "PARALLEL=READ_PART" ) + partition_method;
00055     // Create gather set in processor 0
00056     opt += std::string( ";GATHER_SET=0" );
00057     rval = mb.load_file( example.c_str(), &file_set, opt.c_str() );CHECK_ERR( rval );
00058
00059     ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
00060     int procs           = pcomm->proc_config().proc_size();
00061     int rank            = pcomm->proc_config().proc_rank();
00062
00063     rval = pcomm->check_all_shared_handles();CHECK_ERR( rval );
00064
00065     // Get the total # owned verts
00066     Range verts;
00067     rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval );
00068
00069     int my_num = verts.size();
00070     if( test_nb_nodes && 2 == procs )
00071     {
00072         if( 0 == rank )
00073             CHECK_EQUAL( 5283, my_num );  // Gather set vertices included
00074         else if( 1 == rank )
00075             CHECK_EQUAL( 1825, my_num );  // Not owned vertices included
00076     }
00077
00078     rval = pcomm->filter_pstatus( verts, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
00079
00080     my_num = verts.size();
00081     if( test_nb_nodes && 2 == procs )
00082     {
00083         if( 0 == rank )
00084             CHECK_EQUAL( 5283, my_num );  // Gather set vertices included
00085         else if( 1 == rank )
00086             CHECK_EQUAL( 1633, my_num );  // Not owned vertices excluded
00087     }
00088
00089     if( 0 == rank )
00090     {
00091         // Get gather set
00092         EntityHandle gather_set;
00093         ReadUtilIface* readUtilIface;
00094         rval = mb.query_interface( readUtilIface );CHECK_ERR( rval );
00095         rval = readUtilIface->get_gather_set( gather_set );CHECK_ERR( rval );
00096
00097         // Get gather set entities
00098         Range gather_ents;
00099         rval = mb.get_entities_by_handle( gather_set, gather_ents );CHECK_ERR( rval );
00100
00101         // Remove gather set vertices in processor 0
00102         verts = subtract( verts, gather_ents );
00103     }
00104
00105     my_num = verts.size();
00106     if( test_nb_nodes && 2 == procs )
00107     {
00108         if( 0 == rank )
00109             CHECK_EQUAL( 1825, my_num );  // Gather set vertices excluded
00110         else if( 1 == rank )
00111             CHECK_EQUAL( 1633, my_num );  // Not owned vertices excluded
00112     }
00113
00114     std::cout << "proc: " << rank << " verts:" << my_num << "\n";
00115
00116     int total_verts;
00117     MPI_Reduce( &my_num, &total_verts, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
00118
00119     if( 0 == rank )
00120     {
00121         std::cout << "total vertices: " << total_verts << "\n";
00122         if( test_nb_nodes ) CHECK_EQUAL( total_verts, num_verts );
00123     }
00124
00125 #ifdef MOAB_HAVE_HDF5_PARALLEL
00126     std::string write_options( "PARALLEL=WRITE_PART;" );
00127     mb.write_file( "test.h5m", NULL, write_options.c_str() );
00128 #endif
00129 }
00130
00131 void test_multiple_loads_of_same_file()
00132 {
00133     Core moab;
00134     Interface& mb = moab;
00135     EntityHandle file_set;
00136     ErrorCode rval;
00137     rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval );
00138
00139     // Read first only header information, no mesh, no variable
00140     std::string opts( "PARALLEL=READ_PART;PARTITION;NOMESH;VARIABLE=;PARTITION_METHOD=TRIVIAL" );
00141     rval = mb.load_file( example.c_str(), &file_set, opts.c_str() );CHECK_ERR( rval );
00142
00143     opts = "PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION_METHOD=TRIVIAL;"
00144            "VARIABLE=";
00145     // Create gather set in processor 1
00146     opts += std::string( ";GATHER_SET=1" );
00147     rval = mb.load_file( example.c_str(), &file_set, opts.c_str() );CHECK_ERR( rval );
00148
00149     opts = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=TRIVIAL;NOMESH;VARIABLE=T;TIMESTEP=0";
00150     rval = mb.load_file( example.c_str(), &file_set, opts.c_str() );CHECK_ERR( rval );
00151
00152     // Check values of tag T0 (first level) at some strategically chosen places below
00153     ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
00154     int procs           = pcomm->proc_config().proc_size();
00155     int rank            = pcomm->proc_config().proc_rank();
00156
00157     // Make check runs this test in two processors
00158     if( 2 == procs )
00159     {
00160         Range verts;
00161         rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval );
00162
00163         int my_num = verts.size();
00164         if( 0 == rank )
00165             CHECK_EQUAL( 1825, my_num );
00166         else if( 1 == rank )
00167         {
00168             CHECK_EQUAL( 5283,
00169                          my_num );  // Gather set vertices included; Not owned vertices included
00170
00171             // Get gather set
00172             EntityHandle gather_set;
00173             ReadUtilIface* readUtilIface;
00174             rval = mb.query_interface( readUtilIface );CHECK_ERR( rval );
00175             rval = readUtilIface->get_gather_set( gather_set );CHECK_ERR( rval );
00176
00177             // Get gather set entities
00178             Range gather_ents;
00179             rval = mb.get_entities_by_handle( gather_set, gather_ents );CHECK_ERR( rval );
00180
00181             // Remove gather set vertices in processor 1
00182             verts  = subtract( verts, gather_ents );
00183             my_num = verts.size();
00184             CHECK_EQUAL( 1825,
00185                          my_num );  // Gather set vertices excluded; Not owned vertices included
00186         }
00187
00188         Tag Ttag0;
00189         rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0, MB_TAG_DENSE );CHECK_ERR( rval );
00190
00191         int count;
00192         void* Tbuf;
00193         rval = mb.tag_iterate( Ttag0, verts.begin(), verts.end(), count, Tbuf );CHECK_ERR( rval );
00194         CHECK_EQUAL( count, my_num );
00195
00196         const double eps = 0.0001;
00197         double* data     = (double*)Tbuf;
00198
00199         if( 0 == rank )
00200         {
00201             CHECK_REAL_EQUAL( 233.1136, data[0 * levels], eps );     // First vert
00202             CHECK_REAL_EQUAL( 237.1977, data[912 * levels], eps );   // Median vert
00203             CHECK_REAL_EQUAL( 234.9711, data[1824 * levels], eps );  // Last vert
00204         }
00205         else if( 1 == rank )
00206         {
00207             CHECK_REAL_EQUAL( 233.1136, data[0 * levels], eps );     // First vert
00208             CHECK_REAL_EQUAL( 231.0446, data[912 * levels], eps );   // Median vert
00209             CHECK_REAL_EQUAL( 234.0416, data[1824 * levels], eps );  // Last vert
00210         }
00211     }
00212 }
