update_tracer.cpp File Reference
#include "iMesh.h"
#include "MBiMesh.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/IntxMesh/Intx2MeshOnSphere.hpp"
#include "moab/IntxMesh/IntxUtils.hpp"
#include "IntxUtilsCSLAM.hpp"
+ Include dependency graph for update_tracer.cpp:
Functions
void update_tracer (iMesh_Instance instance, iBase_EntitySetHandle imesh_euler_set, int *ierr)
Function Documentation
void update_tracer ( iMesh_Instance  instance,
int *  ierr
Definition at line 9 of file update_tracer.cpp.
References moab::Intx2Mesh::create_departure_mesh_2nd_alg(), moab::Core::create_meshset(), moab::debug, moab::IntxUtils::enforce_convexity(), ErrorCode, ERRORV, gtol, moab::Intx2Mesh::intersect_meshes(), mb, MB_CHK_SET_ERR_RET, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MESHSET_SET, MOABI, radius, moab::Intx2Mesh::set_error_tolerance(), moab::Intx2MeshOnSphere::set_radius_destination_mesh(), moab::Intx2MeshOnSphere::set_radius_source_mesh(), moab::Core::tag_get_handle(), moab::Intx2MeshOnSphere::update_tracer_data(), and moab::Core::write_file().
    using namespace moab;
    const double radius = 1.;
    const double gtol   = 1.e-9;
    const bool debug    = false;
    Range ents;
    moab::Interface* mb = MOABI;
    *ierr               = 1;
    EntityHandle euler_set = (EntityHandle)imesh_euler_set;
    Intx2MeshOnSphere worker( mb );
    worker.set_radius_source_mesh( radius );
    worker.set_radius_destination_mesh( radius );
    worker.set_error_tolerance( gtol );
    EntityHandle covering_lagr_set;
    ErrorCode rval = mb->create_meshset( MESHSET_SET, covering_lagr_set );MB_CHK_SET_ERR_RET( rval, "can't create covering set " );
    // we need to update the correlation tag and remote tuples
    rval = worker.create_departure_mesh_2nd_alg( euler_set, covering_lagr_set );MB_CHK_SET_ERR_RET( rval, "can't populate covering set " );
    if( debug )
        rval = mb->write_file( "lagr.h5m", 0, 0, &covering_lagr_set, 1 );MB_CHK_SET_ERR_RET( rval, "can't write covering set " );
    // enforce convexity for the set
    rval = moab::IntxUtils::enforce_convexity( mb, covering_lagr_set );MB_CHK_SET_ERR_RET( rval, "can't write covering set " );
    EntityHandle outputSet;
    rval = mb->create_meshset( MESHSET_SET, outputSet );MB_CHK_SET_ERR_RET( rval, "can't create output set " );
    rval = worker.intersect_meshes( covering_lagr_set, euler_set, outputSet );MB_CHK_SET_ERR_RET( rval, "can't intersect " );
    if( debug )
        rval = mb->write_file( "output.vtk", 0, 0, &outputSet, 1 );MB_CHK_SET_ERR_RET( rval, "can't write covering set " );
    // tagElem is the average computed at each element, from nodal values
    Tag tagElem = 0;
    std::string tag_name2( "TracerAverage" );
    rval = mb->tag_get_handle( tag_name2.c_str(), 1, MB_TYPE_DOUBLE, tagElem, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_RET( rval, "can't get tracer tag " );
    // area of the euler element is fixed, store it; it is used to recompute the averages at each
    // time step
    Tag tagArea = 0;
    std::string tag_name4( "Area" );
    rval = mb->tag_get_handle( tag_name4.c_str(), 1, MB_TYPE_DOUBLE, tagArea, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_RET( rval, "can't get area tag" );
    rval = worker.update_tracer_data( outputSet, tagElem, tagArea );MB_CHK_SET_ERR_RET( rval, "can't update tracer " );
    // everything can be deleted now from intx data; polygons, etc.
    *ierr = 0;
    return;
