urefine_mesh_test.cpp File Reference
#include <iostream>
#include <string>
#include <sstream>
#include <ctime>
#include <vector>
#include <algorithm>
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/MeshTopoUtil.hpp"
#include "moab/ReadUtilIface.hpp"
#include "moab/NestedRefine.hpp"
#include "TestUtil.hpp"
+ Include dependency graph for urefine_mesh_test.cpp:
Functions
void handle_error_code (ErrorCode rv, int &number_failed, int &number_successful)
ErrorCode test_adjacencies (Interface *mbImpl, NestedRefine *nr, const Range &all_ents)
ErrorCode refine_entities (Interface *mb, ParallelComm *pc, EntityHandle fset, int *level_degrees, const int num_levels, bool output)
ErrorCode create_single_entity (Interface *mbImpl, EntityType type)
ErrorCode create_mesh (Interface *mbImpl, EntityType type)
ErrorCode create_simple_mesh (Interface *mbImpl, EntityType type)
ErrorCode test_entities (int mesh_type, EntityType type, int *level_degrees, int num_levels, bool output)
ErrorCode test_1D ()
ErrorCode test_2D ()
ErrorCode test_3D ()
ErrorCode test_mesh (const char *filename, int *level_degrees, int num_levels)
int main (int argc, char *argv[])
Variables
int number_tests_successful = 0
int number_tests_failed = 0
Function Documentation
ErrorCode create_mesh ( Interface mbImpl,
EntityType  type
Definition at line 712 of file urefine_mesh_test.cpp.
References CHECK_ERR, conn, moab::Interface::create_element(), moab::Interface::create_vertex(), edges, moab::error(), ErrorCode, MBMesquite::faces, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTET, and MBTRI.
    ErrorCode error;
    if( type == MBEDGE )
        const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, -1, 0, 0, 0, -1, 0 };
        const size_t num_vtx  = sizeof( coords ) / sizeof( double ) / 3;
        const int conn[]       = { 1, 0, 0, 3, 2, 0, 0, 4 };
        const size_t num_elems = sizeof( conn ) / sizeof( int ) / 2;
        EntityHandle verts[num_vtx], edges[num_elems];
        for( size_t i = 0; i < num_vtx; ++i )
            error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error );
        for( size_t i = 0; i < num_elems; ++i )
            EntityHandle c[2];
            c[0] = verts[conn[2 * i]];
            c[1] = verts[conn[2 * i + 1]];
            error = mbImpl->create_element( MBEDGE, c, 2, edges[i] );CHECK_ERR( error );
    else if( type == MBTRI )
        const double coords[] = { 0, 0, 0, 1, -1, 0, 1, 1, 0, -1, 1, 0, -1, -1, 0, 0, 0, 1 };
        const int conn[] = { 0, 1, 2, 0, 2, 3, 0, 3, 4, 0, 4, 1, 0, 5, 3, 0, 2, 5, 0, 4, 5, 0, 5, 1 };
        const size_t num_elems = sizeof( conn ) / sizeof( int ) / 3;
        EntityHandle verts[num_vtx], faces[num_elems];
            EntityHandle c[3];
            for( int j = 0; j < 3; j++ )
                c[j] = verts[conn[3 * i + j]];
            error = mbImpl->create_element( MBTRI, c, 3, faces[i] );CHECK_ERR( error );
    else if( type == MBQUAD )
        const double coords[] = { 0,  0,  0, 1, 0,  0, 1, 1,  0, 0, 1, 0, -1, 1, 0, -1, 0,  0,
                                  -1, -1, 0, 0, -1, 0, 1, -1, 0, 0, 1, 1, 0,  0, 1, 0,  -1, 1 };
        const int conn[] = { 0, 1, 2, 3, 0, 3, 4, 5, 7, 8, 1, 0, 6, 7, 0, 5, 0, 3, 9, 10, 0, 10, 11, 7 };
        const size_t num_elems = sizeof( conn ) / sizeof( int ) / 4;
            EntityHandle c[4];
            for( int j = 0; j < 4; j++ )
                c[j] = verts[conn[4 * i + j]];
            error = mbImpl->create_element( MBQUAD, c, 4, faces[i] );CHECK_ERR( error );
    else if( type == MBTET )
        const double coords[] = { 0, -1, 0, 0, 2, 0, 1, 0, 0, -0.5, 0, 0, 0, 0, 1, 0, 0, -2 };
        const int conn[] = { 0, 2, 1, 4, 3, 0, 1, 4, 5, 2, 1, 0, 5, 0, 1, 3 };
        EntityHandle verts[num_vtx], cells[num_elems];
            EntityHandle c[4];
            error = mbImpl->create_element( MBTET, c, 4, cells[i] );CHECK_ERR( error );
    else if( type == MBHEX )
        const double coords[] = { 0, -1, 0,  1, -1, 0,  1, 1, 0,  0, 1, 0,  -1, 1, 0,  -1, -1, 0,
                                  0, -1, 1,  1, -1, 1,  1, 1, 1,  0, 1, 1,  -1, 1, 1,  -1, -1, 1,
                                  0, -1, -1, 1, -1, -1, 1, 1, -1, 0, 1, -1, -1, 1, -1, -1, -1, -1 };
        const int conn[]       = { 0,  1,  2,  3,  6, 7, 8, 9, 5,  0,  3,  4,  11, 6, 9, 10,
                             12, 13, 14, 15, 0, 1, 2, 3, 17, 12, 15, 16, 5,  0, 3, 4 };
        const size_t num_elems = sizeof( conn ) / sizeof( int ) / 8;
            EntityHandle c[8];
            for( int j = 0; j < 8; j++ )
                c[j] = verts[conn[8 * i + j]];
            error = mbImpl->create_element( MBHEX, c, 8, cells[i] );CHECK_ERR( error );
    return MB_SUCCESS;
ErrorCode create_simple_mesh ( Interface mbImpl,
EntityType  type
Definition at line 843 of file urefine_mesh_test.cpp.
    ErrorCode error;
        const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 3, 0, 0, 4, 0, 0,
                                  4, 1, 0, 3, 1, 0, 2, 1, 0, 1, 1, 0, 0, 1, 0 };
        const int conn[]       = { 1, 0, 1, 2, 2, 3, 3, 4, 4, 5, 5, 6, 6, 7, 7, 8, 8, 9, 9, 0 };
            EntityHandle c[2];
        const double coords[] = { 0, 0,    0, 1, 0,    0,  2, 0,   0,  2.5, 1,   0,  1.5, 1,   0,  0.5, 1,
                                  0, -0.5, 1, 0, -0.5, -1, 0, 0.5, -1, 0,   1.5, -1, 0,   2.5, -1, 0 };
        const int conn[] = { 0, 5, 6, 0, 1, 5, 1, 4, 5, 1, 2, 4, 2, 3,  4,
                             7, 8, 0, 8, 1, 0, 8, 9, 1, 9, 2, 1, 9, 10, 2 };
            EntityHandle c[3];
        const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 3, 0, 0, 4, 0, 0, 5, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0,
                                  3, 1, 0, 4, 1, 0, 5, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0, 3, 2, 0, 4, 2, 0, 5, 2, 0 };
        const int conn[] = { 0, 1, 7,  6,  1, 2, 8,  7,  2, 3, 9,  8,  3, 4,  10, 9,  4,  5,  11, 10,
                             6, 7, 13, 12, 7, 8, 14, 13, 8, 9, 15, 14, 9, 10, 16, 15, 10, 11, 17, 16 };
            EntityHandle c[4];
        const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, -1, 0, 0, 0, -1, 0, 0, 0, 1 };
        const int conn[] = { 0, 1, 2, 5, 3, 0, 2, 5, 4, 1, 0, 5, 4, 0, 3, 5 };
            EntityHandle c[4];
        const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0,
                                  0, 0, 1, 1, 0, 1, 2, 0, 1, 0, 1, 1, 1, 1, 1, 2, 1, 1, 0, 2, 1, 1, 2, 1, 2, 2, 1 };
        const int conn[]       = { 0, 1, 4, 3, 9,  10, 13, 12, 1, 2, 5, 4, 10, 11, 14, 13,
                             3, 4, 7, 6, 12, 13, 16, 15, 4, 5, 8, 7, 13, 14, 17, 16 };
            EntityHandle c[8];
    return MB_SUCCESS;
ErrorCode create_single_entity ( Interface mbImpl,
EntityType  type
Definition at line 583 of file urefine_mesh_test.cpp.
Referenced by test_entities().
    ErrorCode error;
        const double coords[] = { 0.0, 0.0, 0.0, 1.0, 0.0, 0.0 };
        const int conn[]       = { 0, 1 };
        const size_t num_elems = sizeof( conn ) / sizeof( conn[0] ) / 2;
        std::cout << "Specify verts and ents" << std::endl;
        std::cout << "Created vertices" << std::endl;
            EntityHandle c[2];
            c[0] = verts[conn[0]];
            c[1] = verts[conn[1]];
        std::cout << "Created ents" << std::endl;
        const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0 };
        const int conn[]       = { 0, 1, 2 };
            if( error != MB_SUCCESS ) return error;
            EntityHandle c[3];
        const double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0 };
        const int conn[]       = { 0, 1, 2, 3 };
            EntityHandle c[4];
                c[j] = verts[conn[j]];
        const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1 };
            EntityHandle c[4];
        const double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1 };
        const int conn[]       = { 0, 1, 2, 3, 4, 5, 6, 7 };
            EntityHandle c[8];
    return MB_SUCCESS;
void handle_error_code ( ErrorCode  rv,
int &  number_failed,
int &  number_successful
Definition at line 38 of file urefine_mesh_test.cpp.
References MB_SUCCESS, MPI_COMM_WORLD, and rank.
    if( rv == MB_SUCCESS )
#ifdef MOAB_HAVE_MPI
        int rank = 0;
        MPI_Comm_rank( MPI_COMM_WORLD, &rank );
        if( rank == 0 ) std::cout << "Success";
#else
#endif
        number_successful++;
    else
        std::cout << "Failure";
        number_failed++;
int main ( int  argc,
char *  argv[]
Definition at line 1159 of file urefine_mesh_test.cpp.
References ErrorCode, filename, handle_error_code(), MPI_COMM_WORLD, number_tests_failed, number_tests_successful, rank, test_1D(), test_2D(), test_3D(), and test_mesh().
    MPI_Init( &argc, &argv );
    int nprocs, rank;
    MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
#endif
    ErrorCode result;
    if( argc == 1 )
        result = test_1D();
        handle_error_code( result, number_tests_failed, number_tests_successful );
        std::cout << "\n";
        result = test_2D();
        std::cout << "\n";
        result = test_3D();
        std::cout << "\n";
    else if( argc == 2 )
        const char* filename = argv[1];
        int deg[1]           = { 2 };
        int len              = sizeof( deg ) / sizeof( int );
        result               = test_mesh( filename, deg, len );
        std::cout << "\n";
    MPI_Finalize();
#endif
    return number_tests_failed;
ErrorCode refine_entities ( Interface mb,
ParallelComm pc,
EntityHandle  fset,
int *  level_degrees,
bool  output
Definition at line 351 of file urefine_mesh_test.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::NestedRefine::child_to_parent(), children, dim, moab::Range::empty(), moab::Range::end(), moab::error(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::NestedRefine::generate_mesh_hierarchy(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), l, MB_CHK_ERR, MB_SUCCESS, moab::NestedRefine::parent_to_child(), PSTATUS_GHOST, PSTATUS_NOT, size, moab::Range::size(), moab::Range::subset_by_dimension(), test_adjacencies(), moab::NestedRefine::timeall, moab::NestedRefine::codeperf::tm_refine, moab::NestedRefine::codeperf::tm_resolve, moab::NestedRefine::codeperf::tm_total, and moab::Interface::write_file().
Referenced by test_entities(), and test_mesh().
    ErrorCode error;
    // Get the range of entities in the initial mesh
    Range init_ents[4];
    int dim[3] = { 1, 2, 3 };
    if( output )
        //  int inents = init_ents.size();
        std::stringstream file;
        file << "MESH_LEVEL_0.h5m";
#else
        file << "MESH_LEVEL_0.vtk";
#endif
        std::string str         = file.str();
        const char* output_file = str.c_str();
        error = mb->write_file( output_file, 0, ";;PARALLEL=WRITE_PART" );CHECK_ERR( error );
#else
        error = mb->write_file( output_file, 0, NULL );CHECK_ERR( error );
#endif
    // Create an hm object and generate the hierarchy
    std::cout << "Creating a hm object" << std::endl;
    Range averts, aedges, afaces, acells;
    error = mb->get_entities_by_dimension( fset, 0, averts );MB_CHK_ERR( error );
    error = mb->get_entities_by_dimension( fset, 1, aedges );MB_CHK_ERR( error );
    error = mb->get_entities_by_dimension( fset, 2, afaces );MB_CHK_ERR( error );
    error = mb->get_entities_by_dimension( fset, 3, acells );MB_CHK_ERR( error );
    /* filter based on parallel status */
    if( pc )
        error = pc->filter_pstatus( averts, PSTATUS_GHOST, PSTATUS_NOT, -1, &init_ents[0] );MB_CHK_ERR( error );
        error = pc->filter_pstatus( aedges, PSTATUS_GHOST, PSTATUS_NOT, -1, &init_ents[1] );MB_CHK_ERR( error );
        error = pc->filter_pstatus( afaces, PSTATUS_GHOST, PSTATUS_NOT, -1, &init_ents[2] );MB_CHK_ERR( error );
        error = pc->filter_pstatus( acells, PSTATUS_GHOST, PSTATUS_NOT, -1, &init_ents[3] );MB_CHK_ERR( error );
    else
        init_ents[0] = averts;
        init_ents[1] = aedges;
        init_ents[2] = afaces;
        init_ents[3] = acells;
#else
    error = mb->get_entities_by_dimension( fset, 0, init_ents[0] );CHECK_ERR( error );
    error = mb->get_entities_by_dimension( fset, 1, init_ents[1] );CHECK_ERR( error );
    error = mb->get_entities_by_dimension( fset, 2, init_ents[2] );CHECK_ERR( error );
    error = mb->get_entities_by_dimension( fset, 3, init_ents[3] );CHECK_ERR( error );
#endif
    NestedRefine uref( dynamic_cast< Core* >( mb ), pc, fset );
    std::vector< EntityHandle > set;
    std::cout << "Starting hierarchy generation" << std::endl;
    bool opt = true;
    // bool opt = false;
    error = uref.generate_mesh_hierarchy( num_levels, level_degrees, set, opt );CHECK_ERR( error );
    std::cout << "Finished hierarchy generation in " << uref.timeall.tm_total << "  secs" << std::endl;
    if( pc )
        std::cout << "Time taken for refinement " << uref.timeall.tm_refine << "  secs" << std::endl;
        std::cout << "Time taken for resolving shared interface " << uref.timeall.tm_resolve << "  secs" << std::endl;
#endif
    // error = uref.exchange_ghosts(set, 1); CHECK_ERR(error);
    std::cout << std::endl;
    std::cout << "Mesh size for level 0  :: inverts = " << init_ents[0].size() << ", inedges = " << init_ents[1].size()
              << ", infaces = " << init_ents[2].size() << ", incells = " << init_ents[3].size() << std::endl;
    Range prev_ents[4];
    for( int i = 0; i < 4; i++ )
        prev_ents[i] = init_ents[i];
    // Loop over each mesh level and check its topological properties
    for( int l = 0; l < num_levels; l++ )
        Range all_ents;
        error = mb->get_entities_by_handle( set[l + 1], all_ents );CHECK_ERR( error );
        Range ents[4];
        for( int k = 0; k < 4; k++ )
            ents[k] = all_ents.subset_by_dimension( k );
        if( ents[0].empty() || all_ents.empty() ) std::cout << "Something is not right" << std::endl;
        std::cout << "Mesh size for level " << l + 1 << "  :: nverts = " << ents[0].size()
                  << ", nedges = " << ents[1].size() << ", nfaces = " << ents[2].size()
                  << ", ncells = " << ents[3].size() << std::endl;
        // Check if the number of new entities created are correct.
        for( int type = 1; type < 3; type++ )
            int factor = 1;
            if( !ents[type + 1].empty() )
                for( int p = 0; p <= l; p++ )
                    for( int d = 0; d < dim[type]; d++ )
                        factor *= level_degrees[p];
                int expected_nents = factor * init_ents[type + 1].size();
                CHECK_EQUAL( expected_nents, (int)ents[type + 1].size() );
        // Check adjacencies
        error = test_adjacencies( mb, &uref, all_ents );CHECK_ERR( error );
        // Check interlevel child-parent query between previous and current level
            if( !prev_ents[type + 1].empty() )
                for( Range::iterator e = prev_ents[type + 1].begin(); e != prev_ents[type + 1].end(); e++ )
                    std::vector< EntityHandle > children;
                    error = uref.parent_to_child( *e, l, l + 1, children );CHECK_ERR( error );
                    for( int i = 0; i < (int)children.size(); i++ )
                        EntityHandle parent;
                        error = uref.child_to_parent( children[i], l + 1, l, &parent );CHECK_ERR( error );
                        assert( parent == *e );
            prev_ents[i] = ents[i];
        // Print out the boundary vertices
        /*  EntityHandle bnd_set;
          error = mb->create_meshset(MESHSET_SET, bnd_set); MB_CHK_ERR(error);
          std::vector<EntityHandle> vbnd;
          for (int k=0; k<3; k++){
              std::cout<<"Finding boundary of dimension "<<k<<" with size
          "<<ents[k].size()<<std::endl; if (ents[k].size() != 0){ for (Range::iterator v =
          ents[k].begin(); v != ents[k].end(); v++)
                      EntityHandle ent = *v;
                      bool bnd = uref.is_entity_on_boundary(ent);
                      if (bnd)
                        vbnd.push_back(*v);
          std::cout<<"vbnd.size = "<<vbnd.size()<<std::endl;
          error = mb->add_entities(bnd_set, &vbnd[0], (int)vbnd.size()); MB_CHK_ERR(error);
          if (output)
              file <<  "VBND_LEVEL_" <<l+1<<".vtk";
              char * write_opts = NULL;
              error = mb->write_file(output_file, 0, write_opts, &bnd_set, 1); CHECK_ERR(error);
        // Print out the mesh
        if( output )
            file << "MESH_LEVEL_" << l + 1 << ".h5m";
#else
            file << "MESH_LEVEL_" << l + 1 << ".vtk";
#endif
            error = mb->write_file( output_file, 0, ";;PARALLEL=WRITE_PART", &set[l + 1], 1 );CHECK_ERR( error );
#else
            error = mb->write_file( output_file, 0, NULL, &set[l + 1], 1 );CHECK_ERR( error );
#endif
    // Check interlevel child-parent query between initial and most refined mesh
        if( !init_ents[type + 1].empty() )
            for( Range::iterator e = init_ents[type + 1].begin(); e != init_ents[type + 1].end(); e++ )
                error = uref.parent_to_child( *e, 0, num_levels, children );CHECK_ERR( error );
                    error = uref.child_to_parent( children[i], num_levels, 0, &parent );CHECK_ERR( error );
    // Print out the whole hierarchy into a single file
    /* if (output)
         file <<  "MESH_HIERARCHY.vtk";
         error = mb->write_file(output_file); CHECK_ERR(error);
    return MB_SUCCESS;
Definition at line 1009 of file urefine_mesh_test.cpp.
References CHECK_ERR, moab::error(), ErrorCode, MB_SUCCESS, MBEDGE, and test_entities().
    ErrorCode error;
    std::cout << "Testing EDGE" << std::endl;
    EntityType type = MBEDGE;
    std::cout << "Testing single entity" << std::endl;
    int deg[3] = { 2, 3, 5 };
    error      = test_entities( 1, type, deg, len, false );CHECK_ERR( error );
    std::cout << "Testing a small mesh" << std::endl;
    error = test_entities( 2, type, deg, len, false );CHECK_ERR( error );
    std::cout << "Testing a small simple mesh" << std::endl;
    int degree[4] = { 5, 5, 2, 2 };
    len           = sizeof( degree ) / sizeof( int );
    error         = test_entities( 3, type, degree, len, false );CHECK_ERR( error );
    return MB_SUCCESS;
Definition at line 1034 of file urefine_mesh_test.cpp.
References CHECK_ERR, moab::error(), ErrorCode, length(), MB_SUCCESS, MBQUAD, MBTRI, and test_entities().
    ErrorCode error;
    std::cout << "Testing TRI" << std::endl;
    EntityType type = MBTRI;
    int degree[2] = { 5, 2 };
    int length    = sizeof( degree ) / sizeof( int );
    error         = test_entities( 3, type, degree, length, false );CHECK_ERR( error );
    std::cout << "Testing QUAD" << std::endl;
    type = MBQUAD;
    return MB_SUCCESS;
Definition at line 1074 of file urefine_mesh_test.cpp.
References CHECK_ERR, moab::error(), ErrorCode, length(), MB_SUCCESS, MBHEX, MBTET, and test_entities().
    ErrorCode error;
    std::cout << "Testing TET" << std::endl;
    EntityType type = MBTET;
    int deg[2]      = { 2, 3 };
    int degree[4] = { 2, 2, 2, 2 };
    std::cout << "Testing HEX" << std::endl;
    type = MBHEX;
    return MB_SUCCESS;
ErrorCode test_adjacencies ( Interface mbImpl,
NestedRefine nr,
const Range all_ents
Definition at line 58 of file urefine_mesh_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), conn, edges, moab::Range::empty(), moab::Range::end(), moab::error(), ErrorCode, MBMesquite::faces, moab::NestedRefine::get_adjacencies(), moab::Interface::get_adjacencies(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_connectivity(), MB_SUCCESS, moab::Range::print(), moab::Interface::query_interface(), moab::Range::size(), moab::Range::subset_by_dimension(), moab::subtract(), and moab::ReadUtilIface::update_adjacencies().
Referenced by refine_entities().
    MeshTopoUtil mtu( mbImpl );
    ErrorCode error;
    Range verts, edges, faces, cells;
    verts = all_ents.subset_by_dimension( 0 );
    edges = all_ents.subset_by_dimension( 1 );
    faces = all_ents.subset_by_dimension( 2 );
    cells = all_ents.subset_by_dimension( 3 );
    std::vector< EntityHandle > adjents;
    Range mbents, ahfents;
    // Update the moab native data structures
    ReadUtilIface* read_face;
    error = mbImpl->query_interface( read_face );CHECK_ERR( error );
    std::vector< EntityHandle > ents, conn;
    if( !edges.empty() )
        conn.clear();
        ents.clear();
        for( Range::iterator it = edges.begin(); it != edges.end(); it++ )
            ents.push_back( *it );
        //  std::copy(edges.begin(), edges.end(), ents.begin());
        error = mbImpl->get_connectivity( &ents[0], (int)ents.size(), conn );CHECK_ERR( error );
        error = read_face->update_adjacencies( *ents.begin(), (int)ents.size(), 2, &conn[0] );CHECK_ERR( error );
    if( !faces.empty() )
        conn.clear();
        ents.clear();
        for( Range::iterator it = faces.begin(); it != faces.end(); it++ )
        //  std::copy(faces.begin(), faces.end(), ents.begin());
        error = mbImpl->get_connectivity( &ents[0], 1, conn );CHECK_ERR( error );
        int nvF = conn.size();
        conn.clear();
        error = read_face->update_adjacencies( *ents.begin(), (int)ents.size(), nvF, &conn[0] );CHECK_ERR( error );
    if( !cells.empty() )
        conn.clear();
        ents.clear();
        for( Range::iterator it = cells.begin(); it != cells.end(); it++ )
        // std::copy(cells.begin(), cells.end(), ents.begin());
        conn.clear();
        // 1D Queries //
        // IQ1: For every vertex, obtain incident edges
        for( Range::iterator i = verts.begin(); i != verts.end(); ++i )
            adjents.clear();
            mbents.clear();
            ahfents.clear();
            error = nr->get_adjacencies( *i, 1, adjents );CHECK_ERR( error );
            error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );CHECK_ERR( error );
            std::sort( adjents.begin(), adjents.end() );
            std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) );
            if( ahfents.size() != mbents.size() )
                std::cout << "ahf results = " << std::endl;
                ahfents.print();
                std::cout << "native results = " << std::endl;
                mbents.print();
            CHECK_EQUAL( adjents.size(), mbents.size() );
            mbents = subtract( mbents, ahfents );
                //   std::cout<<"ahf results = "<<std::endl;
                //  ahfents.print();
                //   std::cout<<"native results = "<<std::endl;
                //   mbents.print();
            //  CHECK_EQUAL(adjents.size(),mbents.size());
            CHECK( !mbents.size() );
        // NQ1:  For every edge, obtain neighbor edges
        for( Range::iterator i = edges.begin(); i != edges.end(); ++i )
            adjents.clear();
            mbents.clear();
            ahfents.clear();
            error = mtu.get_bridge_adjacencies( *i, 0, 1, mbents );CHECK_ERR( error );
        // IQ21: For every vertex, obtain incident faces
            adjents.clear();
            mbents.clear();
            ahfents.clear();
            error = nr->get_adjacencies( *i, 2, adjents );CHECK_ERR( error );
            error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents );CHECK_ERR( error );
        // IQ22: For every edge, obtain incident faces
                adjents.clear();
                mbents.clear();
                ahfents.clear();
        // NQ2: For every face, obtain neighbor faces
        for( Range::iterator i = faces.begin(); i != faces.end(); ++i )
            adjents.clear();
            mbents.clear();
            ahfents.clear();
            error = mtu.get_bridge_adjacencies( *i, 1, 2, mbents );CHECK_ERR( error );
                adjents.clear();
                mbents.clear();
                ahfents.clear();
        // IQ 31: For every vertex, obtain incident cells
            adjents.clear();
            mbents.clear();
            ahfents.clear();
            error = nr->get_adjacencies( *i, 3, adjents );CHECK_ERR( error );
            error = mbImpl->get_adjacencies( &*i, 1, 3, false, mbents );CHECK_ERR( error );
            if( adjents.size() != mbents.size() )
                //  ahfents.print();
                //   mbents.print();
                adjents.clear();
                mbents.clear();
                ahfents.clear();
                adjents.clear();
                mbents.clear();
                ahfents.clear();
        // NQ3: For every cell, obtain neighbor cells
        for( Range::iterator i = cells.begin(); i != cells.end(); ++i )
            adjents.clear();
            mbents.clear();
            ahfents.clear();
            error = mtu.get_bridge_adjacencies( *i, 2, 3, mbents );CHECK_ERR( error );
                adjents.clear();
                mbents.clear();
                ahfents.clear();
                adjents.clear();
                mbents.clear();
                ahfents.clear();
    return MB_SUCCESS;
ErrorCode test_entities ( int  mesh_type,
EntityType  type,
int  num_levels,
bool  output
Definition at line 977 of file urefine_mesh_test.cpp.
References create_mesh(), create_simple_mesh(), create_single_entity(), moab::error(), ErrorCode, mb, MB_SUCCESS, and refine_entities().
Referenced by test_1D(), test_2D(), and test_3D().
    ErrorCode error;
    Core mb;
    Interface* mbimpl = &mb;
    // Create entities
    if( mesh_type == 1 )
        error = create_single_entity( mbimpl, type );
        std::cout << "Entity created successfully" << std::endl;
    else if( mesh_type == 2 )
        error = create_mesh( mbimpl, type );
        std::cout << "Small mesh created successfully" << std::endl;
    else if( mesh_type == 3 )
        error = create_simple_mesh( mbimpl, type );
        std::cout << "Small simple mesh created successfully" << std::endl;
    // Generate hierarchy
    error = refine_entities( mbimpl, 0, 0, level_degrees, num_levels, output );
    return MB_SUCCESS;
ErrorCode test_mesh ( const char *  filename,
int  num_levels
Definition at line 1114 of file urefine_mesh_test.cpp.
References CHECK_ERR, moab::Interface::create_meshset(), moab::error(), ErrorCode, moab::ParallelComm::get_comm_procs(), moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), MB_CHK_ERR, MB_SUCCESS, MESHSET_SET, MPI_COMM_WORLD, read_options, and refine_entities().
    Core moab;
    Interface* mbImpl = &moab;
    ParallelComm* pc  = NULL;
    EntityHandle fileset;
    ErrorCode error;
    error = mbImpl->create_meshset( moab::MESHSET_SET, fileset );CHECK_ERR( error );
    MPI_Comm comm = MPI_COMM_WORLD;
    EntityHandle partnset;
    error = mbImpl->create_meshset( moab::MESHSET_SET, partnset );MB_CHK_ERR( error );
    pc = moab::ParallelComm::get_pcomm( mbImpl, partnset, &comm );
    int procs = 1;
    MPI_Comm_size( MPI_COMM_WORLD, &procs );
    if( procs > 1 )
        read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
        error = mbImpl->load_file( filename, &fileset, read_options.c_str() );CHECK_ERR( error );
        // DBG
        std::set< unsigned int > shprocs;
        error = pc->get_comm_procs( shprocs );CHECK_ERR( error );
        std::cout << "#sprocs = " << shprocs.size() << std::endl;
        // DBG
    else if( procs == 1 )
#endif
        error = mbImpl->load_file( filename, &fileset );CHECK_ERR( error );
#endif
    error = refine_entities( &moab, pc, fileset, level_degrees, num_levels, false );CHECK_ERR( error );
    return MB_SUCCESS;
Variable Documentation
Definition at line 36 of file urefine_mesh_test.cpp.
Definition at line 35 of file urefine_mesh_test.cpp.
