util.h
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #ifndef mhdf_FILE_UTIL_H
00017 #define mhdf_FILE_UTIL_H
00018
00019 #include <sys/types.h>
00020 #include <H5Ipublic.h>
00021 #include "status.h"
00022 #include "file-handle.h"
00023
00024 #ifdef __cplusplus
00025 extern "C" {
00026 #endif
00027
00028 void* mhdf_malloc( size_t size, mhdf_Status* status );
00029 void* mhdf_realloc( void* ptr, size_t size, mhdf_Status* status );
00030
00031 size_t mhdf_name_to_path( const char* name, char* path, size_t path_len );
00032
00033 int mhdf_path_to_name( const char* path, char* name );
00034
00035 char* mhdf_name_to_path_copy( const char* name, mhdf_Status* status );
00036
00037 char* mhdf_name_to_path_cat( const char* prefix, const char* name, mhdf_Status* status );
00038
00039 hid_t mhdf_elem_group_from_handle( FileHandle* file_ptr, const char* elem_handle, mhdf_Status* status );
00040
00041 int mhdf_create_scalar_attrib( hid_t object, const char* name, hid_t type, const void* value, mhdf_Status* status );
00042
00043 /* If type is zero, assumes opaque type.
00044    On error, sets status and returns zero.
00045    On success, returns non-zero and does not modify status */
00046 int mhdf_read_scalar_attrib( hid_t object, const char* name, hid_t type, void* value, mhdf_Status* status );
00047
00048 /* Search the specified object to see if it contains an
00049    an attribute with passed name.  Returns -1 on error, 1
00050    if attribute was found, and zero if attribute was not
00051    found.
00052 */
00053 int mhdf_find_attribute( hid_t object, const char* attrib_name, unsigned int* index_out, mhdf_Status* status );
00054
00055 int mhdf_is_in_group( hid_t group, const char* name, mhdf_Status* status );
00056
00057 int mhdf_read_data( hid_t data_table,
00058                     long offset,
00059                     long count,
00060                     hid_t type,
00061                     void* array,
00062                     hid_t read_prop,
00063                     mhdf_Status* status );
00064
00065 int mhdf_write_data( hid_t data_table,
00066                      long offset,
00067                      long count,
00068                      hid_t type,
00069                      const void* array,
00070                      hid_t write_prop,
00071                      mhdf_Status* status );
00072
00073 int mhdf_read_column( hid_t data_table,
00074                       int column,
00075                       long offset,
00076                       long count,
00077                       hid_t type,
00078                       void* array,
00079                       hid_t read_prop,
00080                       mhdf_Status* status );
00081
00082 int mhdf_write_column( hid_t data_table,
00083                        int column,
00084                        long offset,
00085                        long count,
00086                        hid_t type,
00087                        const void* array,
00088                        hid_t write_prop,
00089                        mhdf_Status* status );
00090
00091 hid_t mhdf_create_table( hid_t group, const char* path, hid_t type, int rank, hsize_t* dims, mhdf_Status* status );
00092
00093 hid_t mhdf_create_table_with_prop( hid_t group,
00094                                    const char* path,
00095                                    hid_t type,
00096                                    int rank,
00097                                    hsize_t* dims,
00098                                    hid_t dataset_creation_prop,
00099                                    mhdf_Status* status );
00100
00101 hid_t mhdf_open_table( hid_t group, const char* path, int columns, hsize_t* rows_out, mhdf_Status* status );
00102
00103 hid_t mhdf_open_table2( hid_t group,
00104                         const char* path,
00105                         int rank,
00106                         hsize_t* dims_out,
00107                         long* start_id_out,
00108                         mhdf_Status* status );
00109
00110 hid_t mhdf_open_table_simple( hid_t group, const char* path, mhdf_Status* status );
00111
00112 int mhdf_compact_to_ranges( int* length_in_out, int* ids_in, int ordered );
00113
00114 hid_t get_elem_type_enum( FileHandle* file_ptr, mhdf_Status* status );
00115
00116 void mhdf_api_begin_internal( void );
00117 void mhdf_api_end_internal( int expected_diff, const char* filename, int linenumber );
00118
00119 int mhdf_write_max_id( FileHandle* file_ptr, mhdf_Status* status );
00120
00121 #ifndef DEBUG_OPEN_HANDLES
00122 #define API_BEGIN
00123 #define API_END_H( n )
00124 #else
00125 #define API_BEGIN      mhdf_api_begin_internal()
00126 #define API_END_H( n ) mhdf_api_end_internal( n, __FILE__, __LINE__ )
00127 #endif
00128 #define API_END API_END_H( 0 )
00129
00130 #ifdef __cplusplus
00131 } /* extern "C" */
00132 #endif
00133
00134 #endif
