validate.c File Reference
#include "mhdf.h"
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <sys/stat.h>
#include <H5Tpublic.h>
+ Include dependency graph for validate.c:
Functions
static int check_valid_file_ids (struct mhdf_FileDesc *desc)
static int check_file_contains_holes (const char *filename)
static int check_valid_connectivity (mhdf_FileHandle file, struct mhdf_FileDesc *desc)
static int check_valid_adjacencies (mhdf_FileHandle file, struct mhdf_FileDesc *desc)
static int check_valid_sets (mhdf_FileHandle file, struct mhdf_FileDesc *desc)
static int check_valid_tags (mhdf_FileHandle file, struct mhdf_FileDesc *desc)
static const char * desc_name (struct mhdf_FileDesc *desc, struct mhdf_EntDesc *grp)
static int id_contained (long file_id, const long *ranges, int num_range)
static int ids_contained (const long *ids, int num_ids, const long *ranges, int num_ranges)
static int ranges_contained (const long *id_ranges, int num_id_ranges, const long *ranges, int num_ranges)
static int string_contained (const char *str, const char *const *const list)
static int contains_duplicates (long *array, long n)
static int ranges_contain_duplicates (long *ranges, long nranges)
static long * all_id_ranges (struct mhdf_FileDesc *desc, int include_null, int *num_ranges_out)
static long * get_dim_ranges (struct mhdf_FileDesc *desc, int dim, int *num_ranges_out)
static int merge_ranges (long *ranges, int nranges)
static int check_valid_end_indices (const long *indices, long num_idx, int min_len, long start_id, long max_value, const char *typestr, const char *name)
static int check_valid_elem_conn (int idx, mhdf_FileHandle file, struct mhdf_FileDesc *desc, int conn_dim)
static int check_valid_poly_conn (int idx, mhdf_FileHandle file, struct mhdf_FileDesc *desc, int conn_dim)
static int check_valid_tag (int tag_idx, mhdf_FileHandle file, struct mhdf_FileDesc *desc)
static int check_valid_var_len_tag (int tag_idx, mhdf_FileHandle file, struct mhdf_FileDesc *desc)
static int check_valid_adj_list (long start_id, long count, const long *data, long data_len, const long *valid_ranges, long num_valid_ranges, const char *name)
static int check_valid_parents_children (long start_id, long count, hid_t meta_handle, hid_t data_handle, long data_len, int parents)
static int check_valid_set_contents (struct mhdf_FileDesc *desc, long start_id, long count, hid_t meta_handle, hid_t data_handle, long data_len)
static int lcomp (const void *p1, const void *p2)
static int dcomp (const void *p1, const void *p2)
int main (int argc, char *argv[])
Variables
int verbose = 0
 program-wide verbose output flag
Function Documentation
static long * all_id_ranges ( struct mhdf_FileDesc desc,
int  include_null,
int *  num_ranges_out
) [static]
Definition at line 907 of file validate.c.
References mhdf_EntDesc::count, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, merge_ranges(), mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::sets, and mhdf_EntDesc::start_id.
Referenced by check_valid_set_contents(), check_valid_tag(), and check_valid_var_len_tag().
    int i, num_ranges = 0;
    struct mhdf_EntDesc* group;
    long* ranges = malloc( 2 * sizeof( long ) * ( desc->num_elem_desc + 2 + !!include_null ) );
    if( include_null )
        num_ranges = 1;
        ranges[0]  = 0;
        ranges[1]  = 1;
    for( i = -1; i <= desc->num_elem_desc; ++i )
        if( i == -1 )
            group = &desc->nodes;
        else if( i == desc->num_elem_desc )
            group = &desc->sets;
        else
            group = &desc->elems[i].desc;
        if( num_ranges && ranges[2 * num_ranges - 2] + ranges[2 * num_ranges - 1] == group->start_id )
            ranges[2 * num_ranges - 1] += group->count;
        else
            ranges[2 * num_ranges]     = group->start_id;
            ranges[2 * num_ranges + 1] = group->count;
            ++num_ranges;
    *num_ranges_out = merge_ranges( ranges, num_ranges );
    return ranges;
int check_file_contains_holes ( const char *  filename) [static]
Definition at line 231 of file validate.c.
Referenced by main().
#ifndef _WIN32
    const int blocksize = 512;
#endif
    int errorcode;
    struct stat buf;
    errorcode = stat( filename, &buf );
    if( errorcode )
        perror( filename );
        return 1;
#ifndef _WIN32 /*Does not have st_blocks*/
    if( buf.st_size / blocksize > buf.st_blocks + 1 )
        printf( "File \"%s\" contains holes.  This indicates that portions of the file were never "
                "written.\n",
                filename );
        return 1;
#endif
    return 0;
static int check_valid_adj_list ( long  start_id,
long  count,
const long *  data,
long  data_len,
const long *  valid_ranges,
const char *  name
) [static]
Definition at line 637 of file validate.c.
References ids_contained(), and verbose.
Referenced by check_valid_adjacencies().
    long i, n, id, invalid_id = 0, invalid_vals = 0;
    const long* iter      = data;
    const long* const end = data + data_len;
    int result            = 0;
    for( i = 0; iter != end; ++i )
        id = *iter;
        ++iter;
        if( iter == end )
            printf( "Entry %ld in %s adjacency data (ID %ld) is truncated by the end of the "
                    "adjacency list.\n",
                    i, name, id );
            result = 1;
            break;
        if( id < start_id || ( id - start_id ) >= count )
            if( verbose )
                printf( "Entry %ld in %s adjacency data has ID %ld outside of group range [%ld,%ld].\n", i, name, id,
                        start_id, start_id + count - 1 );
            ++invalid_id;
        n = *iter;
        ++iter;
        if( n < 1 )
            printf( "Entry %ld in %s adjacency data (ID %ld) has %ld adjacency entries.\n", i, name, id, n );
            result = 1;
            if( n < 0 ) break; /* data is corrupt.  don't proceed further */
        if( iter + n > end )
                    i, name, id );
            result = 1;
            break;
        if( !ids_contained( iter, n, valid_ranges, num_valid_ranges ) )
            if( verbose )
                printf( "Entry %ld in %s adjacency data (ID %ld) has invalid IDs in its adjacency "
                        "list.\n",
                        i, name, id );
            ++invalid_vals;
        iter += n;
    if( invalid_id )
        printf( "%ld entries in %s adjacency data were for entities not in %s\n", invalid_id, name, name );
        result = 1;
    if( invalid_vals )
        printf( "%ld entries in %s adjacency data contained invalid adjacent entity ids\n", invalid_id, name );
        result = 1;
    return result;
int check_valid_adjacencies ( mhdf_FileHandle  file,
) [static]
Definition at line 584 of file validate.c.
References buffer, check_valid_adj_list(), mhdf_EntDesc::count, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, mhdf_ElemDesc::handle, mhdf_ElemDesc::have_adj, mhdf_closeData(), mhdf_isError(), mhdf_message(), mhdf_openAdjacency(), mhdf_readAdjacency(), mhdf_FileDesc::num_elem_desc, and mhdf_EntDesc::start_id.
    const int num_ranges = desc->num_elem_desc;
    long *ranges, *buffer;
    int i;
    int invalid = 0;
    long count;
    hid_t handle;
    mhdf_Status status;
    /* Build list of ID ranges for all elements.  Consider any element ID to be a valid
     * thing to be adjacent to.  So we disallow adjacency to nodes, sets, or undefined IDs */
    ranges = malloc( sizeof( long ) * 2 * num_ranges );
    for( i = 0; i < num_ranges; ++i )
        ranges[2 * i]     = desc->elems[i].desc.start_id;
        ranges[2 * i + 1] = desc->elems[i].desc.count;
        if( !desc->elems[i].have_adj ) continue;
        handle = mhdf_openAdjacency( file, desc->elems[i].handle, &count, &status );
        if( mhdf_isError( &status ) )
            fprintf( stderr, "Internal error openening adjacency list for %s: %s\n", desc->elems[i].handle,
                     mhdf_message( &status ) );
            free( ranges );
            return 1;
        buffer = malloc( sizeof( long ) * count );
        mhdf_readAdjacency( handle, 0, count, H5T_NATIVE_LONG, buffer, &status );
            fprintf( stderr, "Internal error reading adjacency list for %s: %s\n", desc->elems[i].handle,
            free( ranges );
            mhdf_closeData( file, handle, &status );
            return 1;
        invalid += check_valid_adj_list( desc->elems[i].desc.start_id, desc->elems[i].desc.count, buffer, count, ranges,
                                         num_ranges, desc->elems[i].handle );
        free( buffer );
    free( ranges );
    return invalid;
int check_valid_connectivity ( mhdf_FileHandle  file,
) [static]
Definition at line 259 of file validate.c.
References check_valid_elem_conn(), check_valid_poly_conn(), mhdf_ElemDesc::desc, dim, mhdf_FileDesc::elems, mhdf_POLYHEDRON_TYPE_NAME, mhdf_FileDesc::num_elem_desc, mhdf_ElemDesc::type, and mhdf_EntDesc::vals_per_ent.
    int idx, dim, result = 0;
    for( idx = 0; idx < desc->num_elem_desc; ++idx )
        if( !strcmp( desc->elems[idx].type, mhdf_POLYHEDRON_TYPE_NAME ) )
            dim = 2;
        else
            dim = 0;
        if( desc->elems[idx].desc.vals_per_ent == -1 )
            result += check_valid_poly_conn( idx, file, desc, dim );
        else
            result += check_valid_elem_conn( idx, file, desc, dim );
    return result;
int check_valid_elem_conn ( int  idx,
int  conn_dim
) [static]
Definition at line 379 of file validate.c.
References buffer, mhdf_EntDesc::count, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, get_dim_ranges(), mhdf_ElemDesc::handle, ids_contained(), mhdf_closeData(), mhdf_isError(), mhdf_message(), mhdf_openConnectivitySimple(), mhdf_readConnectivity(), mhdf_EntDesc::start_id, mhdf_EntDesc::vals_per_ent, and verbose.
Referenced by check_valid_connectivity().
    long *ranges, *buffer, *iter;
    int num_ranges;
    long i, invalid = 0;
    hid_t handle;
    mhdf_Status status;
    const long count = desc->elems[idx].desc.count;
    const long len   = desc->elems[idx].desc.vals_per_ent;
    ranges = get_dim_ranges( desc, conn_dim, &num_ranges );
    handle = mhdf_openConnectivitySimple( file, desc->elems[idx].handle, &status );
        fprintf( stderr, "Internal error opening connectivity for %s: %s\n", desc->elems[idx].handle,
        free( ranges );
        return 1;
    buffer = malloc( sizeof( long ) * count * len );
    mhdf_readConnectivity( handle, 0, count, H5T_NATIVE_LONG, buffer, &status );
        fprintf( stderr, "Internal error reading connectivity for %s: %s\n", desc->elems[idx].handle,
        free( ranges );
        free( buffer );
        return 1;
    iter = buffer;
    for( i = 0; i < count; ++i, iter += len )
        if( !ids_contained( iter, len, ranges, num_ranges ) )
            if( verbose )
                printf( "Invalid connectivity for element %ld (ID %ld) in %s\n", i, i + desc->elems[idx].desc.start_id,
                        desc->elems[idx].handle );
            ++invalid;
    free( buffer );
    free( ranges );
    if( invalid )
        printf( "%ld elements with invalid connectivity in %s\n", invalid, desc->elems[idx].handle );
        return 1;
    return 0;
static int check_valid_end_indices ( const long *  indices,
long  num_idx,
int  min_len,
long  start_id,
long  max_value,
const char *  typestr,
const char *  name
) [static]
Definition at line 434 of file validate.c.
References verbose.
Referenced by check_valid_parents_children(), check_valid_poly_conn(), check_valid_set_contents(), and check_valid_var_len_tag().
    long i, invalid = 0, prev = -1;
    if( num_idx == 0 )
        printf( "WARNING: Empty index list for %s %s\n", name, typestr );
        return 0;
    for( i = 0; i < num_idx; ++i )
        if( indices[i] < prev )
            if( verbose )
                if( start_id > 0 )
                    printf( "Invalid end index %ld for %s %ld (ID %ld).  Prev index is %ld\n", indices[i], name, i,
                            i + start_id, prev );
                else
                    printf( "Invalid end index %ld for entry %ld in %s %s.  Prev index is %ld\n", indices[i], i, name,
                            typestr, prev );
            ++invalid;
        else if( indices[i] - prev < min_len )
            if( verbose )
                if( start_id > 0 )
                    printf( "%s %ld (ID %ld) has only %ld values\n", name, i, start_id, indices[i] - prev );
                else
                    printf( "Entry %ld in %s %s has only %ld values\n", i, name, typestr, indices[i] - prev );
            ++invalid;
        else if( indices[i] >= max_value )
            if( verbose )
                if( start_id > 0 )
                    printf( "%s %ld (ID %ld) end index exceeds upper bound of %ld\n", name, i, start_id, max_value );
                else
                    printf( "Entry %ld in %s %s end index exceeds uppper bound of %ld\n", i, name, typestr, max_value );
            ++invalid;
        prev = indices[i];
    if( invalid )
        printf( "%ld invalid end indices for %s %s\n", invalid, typestr, name );
    return invalid;
int check_valid_file_ids ( struct mhdf_FileDesc desc) [static]
Definition at line 195 of file validate.c.
References mhdf_EntDesc::count, dcomp(), mhdf_ElemDesc::desc, desc_name(), mhdf_FileDesc::elems, mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::sets, and mhdf_EntDesc::start_id.
    const int ngrp = 2 + desc->num_elem_desc;
    int i, err = 0;
    struct mhdf_EntDesc** sorted = malloc( ngrp * sizeof( struct mhdf_EntDesc* ) );
    for( i = 0; i < desc->num_elem_desc; ++i )
        sorted[i] = &desc->elems[i].desc;
    sorted[i++] = &desc->nodes;
    sorted[i]   = &desc->sets;
    qsort( sorted, ngrp, sizeof( struct mhdf_EntDesc* ), &dcomp );
    for( i = 0; i < ngrp; ++i )
        if( sorted[i]->count < 0 )
            printf( "Group \"%s\" has negative count!\n", desc_name( desc, sorted[i] ) );
            ++err;
        if( sorted[i]->count && sorted[i]->start_id == 0 )
            printf( "Group \"%s\" contains NULL ID!\n", desc_name( desc, sorted[i] ) );
            ++err;
        if( i > 0 && sorted[i - 1]->start_id + sorted[i - 1]->count > sorted[i]->start_id )
            printf( "Conflicting group IDs for \"%s\" [%ld,%ld] and \"%s\" [%ld,%ld]\n",
                    desc_name( desc, sorted[i - 1] ), sorted[i - 1]->start_id,
                    sorted[i - 1]->start_id + sorted[i - 1]->count - 1, desc_name( desc, sorted[i] ),
                    sorted[i]->start_id, sorted[i]->start_id + sorted[i]->count - 1 );
            ++err;
    free( sorted );
    return err;
static int check_valid_parents_children ( long  start_id,
long  count,
hid_t  meta_handle,
hid_t  data_handle,
long  data_len,
int  parents
) [static]
Definition at line 796 of file validate.c.
References check_valid_end_indices(), contains_duplicates(), ids_contained(), mhdf_isError(), mhdf_message(), mhdf_readSetChildEndIndices(), mhdf_readSetParentEndIndices(), mhdf_readSetParentsChildren(), and verbose.
Referenced by check_valid_sets().
    mhdf_Status status;
    long *indices, *contents;
    const char parstr[] = "Parent";
    const char cldstr[] = "Child";
    const char* name    = parents ? parstr : cldstr;
    long i, prev, start, n;
    long invalid = 0, invalid_dup = 0;
    long range[2];
    int result = 0;
    range[0]   = start_id;
    range[1]   = count;
    indices = malloc( sizeof( long ) * count );
    if( parents )
        mhdf_readSetParentEndIndices( meta_handle, 0, count, H5T_NATIVE_LONG, indices, &status );
    else
        mhdf_readSetChildEndIndices( meta_handle, 0, count, H5T_NATIVE_LONG, indices, &status );
        fprintf( stderr, "Internal error reading set %s end indices: %s\n", name, mhdf_message( &status ) );
        free( indices );
        return 1;
    if( check_valid_end_indices( indices, count, 0, start_id, data_len, "Set", name ) )
        free( indices );
        return 1;
    contents = malloc( sizeof( long ) * data_len );
    mhdf_readSetParentsChildren( data_handle, 0, data_len, H5T_NATIVE_LONG, contents, &status );
        fprintf( stderr, "Internal error reading set %s IDs: %s\n", name, mhdf_message( &status ) );
        free( indices );
        free( contents );
        return 1;
    prev = -1;
    for( i = 0; i < count; ++i )
        start = prev + 1;
        n     = indices[i] - prev;
        prev  = indices[i];
        if( !ids_contained( contents + start, n, range, 1 ) )
            if( verbose ) printf( "Set %ld (ID %ld) has invalid %s IDs.\n", i, start_id + i, name );
            ++invalid;
        else if( contains_duplicates( contents + start, n ) )
            if( verbose ) printf( "Set %ld (ID %ld) %s list contains duplicate IDs.\n", i, start_id + i, name );
            ++invalid_dup;
    free( indices );
    free( contents );
    if( invalid )
        printf( "%ld sets had invalid %s lists.\n", invalid, name );
        result = 1;
    if( invalid_dup )
        printf( "%ld sets had duplicate handles in %s lists.\n", invalid_dup, name );
        result = 1;
    return result;
int check_valid_poly_conn ( int  idx,
int  conn_dim
) [static]
Definition at line 498 of file validate.c.
References buffer, check_valid_end_indices(), mhdf_FileDesc::elems, get_dim_ranges(), mhdf_ElemDesc::handle, ids_contained(), mhdf_closeData(), mhdf_isError(), mhdf_message(), mhdf_openPolyConnectivity(), mhdf_POLYHEDRON_TYPE_NAME, mhdf_readPolyConnIDs(), mhdf_readPolyConnIndices(), mhdf_ElemDesc::type, and verbose.
    long *ranges, *buffer, *indices, *iter;
    int num_ranges;
    long i, invalid, num_poly, num_conn, first_id, prev, len;
    hid_t handles[2];
    mhdf_Status status;
    int min_conn_len;
    if( !strcmp( mhdf_POLYHEDRON_TYPE_NAME, desc->elems[idx].type ) )
        min_conn_len = 4;
    else
        min_conn_len = 3;
    mhdf_openPolyConnectivity( file, desc->elems[idx].handle, &num_poly, &num_conn, &first_id, handles, &status );
        return 1;
    indices = malloc( sizeof( long ) * num_poly );
    mhdf_readPolyConnIndices( handles[0], 0, num_poly, H5T_NATIVE_LONG, indices, &status );
        fprintf( stderr, "Internal error reading poly indices for %s: %s\n", desc->elems[idx].handle,
        free( indices );
        mhdf_closeData( file, handles[0], &status );
        mhdf_closeData( file, handles[1], &status );
        return 1;
    invalid = check_valid_end_indices( indices, num_poly, min_conn_len, first_id, num_conn, "Connectivity",
    if( invalid )
        free( indices );
        return 1;
    buffer = malloc( sizeof( long ) * num_conn );
    mhdf_readPolyConnIDs( handles[1], 0, num_conn, H5T_NATIVE_LONG, buffer, &status );
        free( ranges );
        free( indices );
        free( buffer );
        return 1;
    prev = -1;
    iter = buffer;
    for( i = 0; i < num_poly; ++i )
        len  = indices[i] - prev;
        prev = indices[i];
            if( verbose )
                printf( "Invalid connectivity for element %ld (ID %ld) in %s\n", i, i + first_id,
            ++invalid;
        iter += len;
    free( indices );
    free( buffer );
    free( ranges );
    if( invalid )
        return 1;
    return 0;
static int check_valid_set_contents ( struct mhdf_FileDesc desc,
long  start_id,
long  count,
hid_t  meta_handle,
hid_t  data_handle,
long  data_len
) [static]
Definition at line 943 of file validate.c.
References all_id_ranges(), check_valid_end_indices(), contains_duplicates(), mhdf_EntDesc::count, ids_contained(), mhdf_isError(), mhdf_message(), mhdf_readSetContentEndIndices(), mhdf_readSetData(), mhdf_readSetFlags(), mhdf_SET_ORDER_BIT, mhdf_SET_RANGE_BIT, ranges_contain_duplicates(), ranges_contained(), and verbose.
    mhdf_Status status;
    short* flags;
    long invalid_len = 0, invalid_handle = 0, invalid_dup = 0;
    long* ranges;
    int num_ranges;
    int tmpresult;
    mhdf_readSetContentEndIndices( meta_handle, 0, count, H5T_NATIVE_LONG, indices, &status );
        fprintf( stderr, "Internal error reading set content end indices: %s\n", mhdf_message( &status ) );
        free( indices );
        return 1;
    if( check_valid_end_indices( indices, count, 0, start_id, data_len, "Set", "Content" ) )
        free( indices );
        return 1;
    ranges = all_id_ranges( desc, 0, &num_ranges );
    flags = malloc( sizeof( short ) * count );
    mhdf_readSetFlags( meta_handle, 0, count, H5T_NATIVE_SHORT, flags, &status );
        fprintf( stderr, "Internal error reading set flags: %s\n", mhdf_message( &status ) );
        free( indices );
        free( flags );
        free( ranges );
        return 1;
    mhdf_readSetData( data_handle, 0, data_len, H5T_NATIVE_LONG, contents, &status );
        fprintf( stderr, "Internal error reading set content IDs: %s\n", mhdf_message( &status ) );
        free( indices );
        free( contents );
        free( flags );
        free( ranges );
        return 1;
    prev = -1;
        start = prev + 1;
        prev  = indices[i];
        if( flags[i] & mhdf_SET_RANGE_BIT )
            if( n % 2 )
                if( verbose )
                    printf( "Set %ld (ID %ld) is marked as range-compressed but has odd number of "
                            "content values.\n",
                            i + 1, start_id + i );
                ++invalid_len;
                continue;
            tmpresult = ranges_contained( contents + start, n / 2, ranges, num_ranges );
        else
            tmpresult = ids_contained( contents + start, n, ranges, num_ranges );
        if( !tmpresult )
            if( verbose ) printf( "Set %ld (ID %ld) has invalid content IDs.\n", i + 1, start_id + i );
            ++invalid_handle;
            continue;
        if( flags[i] & mhdf_SET_ORDER_BIT ) continue;
            tmpresult = ranges_contain_duplicates( contents + start, n / 2 );
        else
            tmpresult = contains_duplicates( contents + start, n );
        if( tmpresult )
            if( verbose )
                printf( "Set %ld (ID %ld) is not ordered but contains duplicate handles.\n", i + 1, start_id + i );
            ++invalid_dup;
    free( indices );
    free( contents );
    free( flags );
    free( ranges );
    tmpresult = 0;
    if( invalid_len )
        printf( "%ld ranged sets had invalid (odd) content list lengths.\n", invalid_len );
        tmpresult = 1;
    if( invalid_handle )
        printf( "%ld sets had invalid IDs in their content lists.\n", invalid_handle );
        tmpresult = 1;
    if( invalid_dup )
        printf( "%ld unordered sets had duplicate IDs in their content lists.\n", invalid_dup );
        tmpresult = 1;
    return tmpresult;
int check_valid_sets ( mhdf_FileHandle  file,
) [static]
Definition at line 714 of file validate.c.
References check_valid_parents_children(), check_valid_set_contents(), mhdf_EntDesc::count, mhdf_FileDesc::have_set_children, mhdf_FileDesc::have_set_contents, mhdf_FileDesc::have_set_parents, mhdf_closeData(), mhdf_isError(), mhdf_message(), mhdf_openSetChildren(), mhdf_openSetData(), mhdf_openSetMeta(), mhdf_openSetParents(), and mhdf_FileDesc::sets.
    long count, start_id, data_len;
    mhdf_Status status;
    hid_t meta, handle;
    int result = 0;
    if( desc->sets.count == 0 ) return 0;
    meta = mhdf_openSetMeta( file, &count, &start_id, &status );
        fprintf( stderr, "Internal error opening set description table: %s\n", mhdf_message( &status ) );
        return 1;
    if( desc->have_set_contents )
        handle = mhdf_openSetData( file, &data_len, &status );
            fprintf( stderr, "Internal error opening set contents table: %s\n", mhdf_message( &status ) );
        else
            result += check_valid_set_contents( desc, start_id, count, meta, handle, data_len );
    if( desc->have_set_children )
        handle = mhdf_openSetChildren( file, &data_len, &status );
            fprintf( stderr, "Internal error opening set child table: %s\n", mhdf_message( &status ) );
            mhdf_closeData( file, meta, &status );
        else
            result += check_valid_parents_children( start_id, count, meta, handle, data_len, 0 );
    if( desc->have_set_parents )
        handle = mhdf_openSetParents( file, &data_len, &status );
        else
            result += check_valid_parents_children( start_id, count, meta, handle, data_len, 1 );
    return result;
static int check_valid_tag ( int  tag_idx,
) [static]
Definition at line 1082 of file validate.c.
References all_id_ranges(), contains_duplicates(), mhdf_EntDesc::count, mhdf_TagDesc::default_value, mhdf_TagDesc::dense_elem_indices, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, mhdf_TagDesc::global_value, mhdf_ElemDesc::handle, mhdf_TagDesc::have_sparse, ids_contained(), mhdf_closeData(), mhdf_ENTITY_ID, mhdf_isError(), mhdf_message(), mhdf_node_type_handle(), mhdf_openDenseTagData(), mhdf_openSparseTagData(), mhdf_readSparseTagEntities(), mhdf_readTagValues(), mhdf_set_type_handle(), mhdf_TagDesc::name, mhdf_FileDesc::nodes, mhdf_TagDesc::num_dense_indices, mhdf_FileDesc::sets, size, mhdf_TagDesc::size, mhdf_EntDesc::start_id, mhdf_FileDesc::tags, and mhdf_TagDesc::type.
Referenced by check_valid_tags().
    long *ids = 0, count, junk;
    long* ranges;
    int nranges;
    hid_t handles[3];
    mhdf_Status status;
    const struct mhdf_TagDesc* tag = &( desc->tags[tag_idx] );
    int i, result = 0;
    long srange[2] = { 0, 0 };
    const char* name;
    hid_t h5type;
    hsize_t size;
    if( tag->have_sparse )
        mhdf_openSparseTagData( file, tag->name, &count, &junk, handles, &status );
            fprintf( stderr, "Internal error opening sparse data for tag \"%s\": %s\n", tag->name,
            return 1;
        ids = malloc( sizeof( long ) * count );
        mhdf_readSparseTagEntities( handles[0], 0, count, H5T_NATIVE_LONG, ids, &status );
            fprintf( stderr, "Internal error reading sparse entities for tag \"%s\": %s\n", tag->name,
            free( ids );
            return 1;
        ranges = all_id_ranges( desc, 0, &nranges );
        if( !ids_contained( ids, count, ranges, nranges ) )
            ++result;
            printf( "Sparse data for tag \"%s\" has values for invalid IDs\n", tag->name );
        else if( contains_duplicates( ids, count ) )
            ++result;
            printf( "Sparse data for tag \"%s\" has duplicate values for one or more entities\n", tag->name );
        free( ranges );
        for( i = 0; i < tag->num_dense_indices; ++i )
            if( tag->dense_elem_indices[i] == -2 )
                name  = mhdf_set_type_handle();
            else if( tag->dense_elem_indices[i] == -1 )
                name  = mhdf_node_type_handle();
            else
                name  = desc->elems[tag->dense_elem_indices[i]].handle;
                group = &desc->elems[tag->dense_elem_indices[i]].desc;
            srange[0] = group->start_id;
            srange[1] = group->count;
            if( ids_contained( ids, count, srange, 2 ) )
                ++result;
                printf( "Tag \"%s\" has both sparse values and dense values for one or more "
                        "entities in \"%s\"\n",
                        tag->name, name );
        free( ids );
    if( tag->type != mhdf_ENTITY_ID )
        if( tag->have_sparse ) mhdf_closeData( file, handles[1], &status );
        return result;
    ranges = all_id_ranges( desc, 1, &nranges );
    if( tag->default_value && !ids_contained( tag->default_value, tag->size, ranges, nranges ) )
        ++result;
        printf( "Handle tag \"%s\" has invalid ID(s) in its default value.\n", tag->name );
    if( tag->global_value && !ids_contained( tag->global_value, tag->size, ranges, nranges ) )
        ++result;
        printf( "Handle tag \"%s\" has invalid ID(s) in its global/mesh value.\n", tag->name );
    h5type = H5T_NATIVE_LONG;
    if( tag->size > 1 )
        size = tag->size;
#if defined( H5Tarray_create_vers ) && H5Tarray_create_vers > 1
        h5type = H5Tarray_create( H5T_NATIVE_LONG, 1, &size );
#else
        h5type = H5Tarray_create( H5T_NATIVE_LONG, 1, &size, NULL );
#endif
        ids = malloc( tag->size * count * sizeof( long ) );
        mhdf_readTagValues( handles[1], 0, count, h5type, ids, &status );
            fprintf( stderr, "Internal error reading sparse values for handle tag \"%s\": %s\n", tag->name,
            free( ids );
            free( ranges );
            if( tag->size > 1 ) H5Tclose( h5type );
            return 1;
        if( !ids_contained( ids, tag->size * count, ranges, nranges ) )
            ++result;
            printf( "Sparse data for one or more entities with handle tag \"%s\" has invalid ID(s).\n", tag->name );
        free( ids );
            /*group = &desc->sets;*/
            /*group = &desc->nodes;*/
        else
            /*group = &desc->elems[ tag->dense_elem_indices[i] ].desc;*/
        handles[0] = mhdf_openDenseTagData( file, tag->name, name, &count, &status );
            fprintf( stderr, "Internal dense values for handle tag \"%s\" on \"%s\": %s\n", tag->name, name,
            ++result;
            continue;
        mhdf_readTagValues( handles[0], 0, count, h5type, ids, &status );
            fprintf( stderr, "Internal error reading dense values for handle tag \"%s\" on \"%s\": %s\n", tag->name,
            free( ids );
            ++result;
            continue;
            ++result;
            printf( "Dense data on \"%s\" for handle tag \"%s\" has invalid ID(s) for one or more "
                    "entities.\n",
                    name, tag->name );
        free( ids );
    return result;
int check_valid_tags ( mhdf_FileHandle  file,
) [static]
Definition at line 1069 of file validate.c.
References check_valid_tag(), check_valid_var_len_tag(), mhdf_FileDesc::num_tag_desc, mhdf_TagDesc::size, and mhdf_FileDesc::tags.
    int i, result = 0;
    for( i = 0; i < desc->num_tag_desc; ++i )
        if( desc->tags[i].size < 0 )
            result += check_valid_var_len_tag( i, file, desc );
        else
            result += check_valid_tag( i, file, desc );
    return result;
static int check_valid_var_len_tag ( int  tag_idx,
) [static]
Definition at line 1273 of file validate.c.
References all_id_ranges(), check_valid_end_indices(), contains_duplicates(), mhdf_EntDesc::count, mhdf_TagDesc::default_value, mhdf_TagDesc::default_value_size, mhdf_TagDesc::global_value, mhdf_TagDesc::global_value_size, mhdf_TagDesc::have_sparse, ids_contained(), mhdf_closeData(), mhdf_ENTITY_ID, mhdf_isError(), mhdf_message(), mhdf_openSparseTagData(), mhdf_readSparseTagEntities(), mhdf_readSparseTagIndices(), mhdf_readTagValues(), mhdf_TagDesc::name, mhdf_TagDesc::num_dense_indices, mhdf_TagDesc::size, mhdf_FileDesc::tags, and mhdf_TagDesc::type.
    long *ids = 0, count, num_val;
    long* ranges;
    int nranges;
    hid_t handles[3];
    mhdf_Status status;
    int result                     = 0;
    if( tag->num_dense_indices != 0 )
        printf( "Dense data for tag \"%s\" not allowed for variable-length tags\n", tag->name );
        ++result;
        mhdf_openSparseTagData( file, tag->name, &count, &num_val, handles, &status );
            return 1;
            mhdf_closeData( file, handles[2], &status );
            free( ids );
            return 1;
            ++result;
            ++result;
        free( ranges );
        mhdf_readSparseTagIndices( handles[2], 0, count, H5T_NATIVE_LONG, ids, &status );
            fprintf( stderr, "Internal error reading indices for variable length tag \"%s\": %s\n", tag->name,
            free( ids );
            return 1;
        if( check_valid_end_indices( ids, count, 1, 0, num_val, "Variable-length tag", tag->name ) ) ++result;
        free( ids );
        return result;
    if( tag->default_value && !ids_contained( tag->default_value, tag->default_value_size, ranges, nranges ) )
        ++result;
    if( tag->global_value && !ids_contained( tag->global_value, tag->global_value_size, ranges, nranges ) )
        ++result;
        ids = malloc( num_val * sizeof( long ) );
        mhdf_readTagValues( handles[1], 0, num_val, H5T_NATIVE_LONG, ids, &status );
            fprintf( stderr, "Internal error reading values for variable-length handle tag \"%s\": %s\n", tag->name,
            free( ids );
            free( ranges );
            return 1;
            ++result;
            printf( "Data for one or more entities with variable-length handle tag \"%s\" has "
                    "invalid ID(s).\n",
                    tag->name );
        free( ids );
    return result;
static int contains_duplicates ( long *  array,
long  n
) [static]
Definition at line 778 of file validate.c.
References lcomp().
Referenced by check_valid_parents_children(), check_valid_set_contents(), check_valid_tag(), and check_valid_var_len_tag().
    long i;
    qsort( array, n, sizeof( long ), &lcomp );
    for( i = 1; i < n; ++i )
        if( array[i - 1] == array[i] ) return 1;
    return 0;
static int dcomp ( const void *  p1,
const void *  p2
) [static]
Definition at line 127 of file validate.c.
References lcomp(), and mhdf_EntDesc::start_id.
Referenced by check_valid_file_ids().
    const struct mhdf_EntDesc* d1 = *(const struct mhdf_EntDesc**)( p1 );
    const struct mhdf_EntDesc* d2 = *(const struct mhdf_EntDesc**)( p2 );
    return lcomp( &d1->start_id, &d2->start_id );
static const char * desc_name ( struct mhdf_FileDesc desc,
struct mhdf_EntDesc grp
) [static]
Definition at line 182 of file validate.c.
References mhdf_ElemDesc::desc, mhdf_ElemDesc::handle, mhdf_FileDesc::nodes, and mhdf_FileDesc::sets.
    struct mhdf_ElemDesc junk, *elem;
    const size_t diff         = (char*)&junk.desc - (char*)&junk;
    static const char nodes[] = "Vertices";
    static const char sets[]  = "Sets";
    if( grp == &desc->nodes ) return nodes;
    if( grp == &desc->sets ) return sets;
    elem = (struct mhdf_ElemDesc*)( (char*)grp - diff );
    return elem->handle;
static long * get_dim_ranges ( struct mhdf_FileDesc desc,
int  dim,
) [static]
Definition at line 329 of file validate.c.
References mhdf_EntDesc::count, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, mdhf_HEX_TYPE_NAME, mdhf_KNIFE_TYPE_NAME, merge_ranges(), mhdf_EDGE_TYPE_NAME, mhdf_POLYGON_TYPE_NAME, mhdf_POLYHEDRON_TYPE_NAME, mhdf_PRISM_TYPE_NAME, mhdf_PYRAMID_TYPE_NAME, mhdf_QUAD_TYPE_NAME, mhdf_SEPTAHEDRON_TYPE_NAME, mhdf_TET_TYPE_NAME, mhdf_TRI_TYPE_NAME, mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_EntDesc::start_id, string_contained(), and mhdf_ElemDesc::type.
Referenced by check_valid_elem_conn(), and check_valid_poly_conn().
    long* ranges = 0;
    int i, j;
    const char* const types1D[] = { mhdf_EDGE_TYPE_NAME, 0 };
    const char* const types2D[] = { mhdf_TRI_TYPE_NAME, mhdf_QUAD_TYPE_NAME, mhdf_POLYGON_TYPE_NAME, 0 };
    const char* const types3D[] = { mhdf_TET_TYPE_NAME,         mhdf_PYRAMID_TYPE_NAME,
                                    mhdf_PRISM_TYPE_NAME,       mdhf_KNIFE_TYPE_NAME,
                                    mdhf_HEX_TYPE_NAME,         mhdf_POLYHEDRON_TYPE_NAME,
                                    mhdf_SEPTAHEDRON_TYPE_NAME, 0 };
    char const* const* typelist;
    switch( dim )
        case 0:
            *num_ranges_out = 1;
            ranges          = malloc( 2 * sizeof( long ) );
            ranges[0]       = desc->nodes.start_id;
            ranges[1]       = desc->nodes.count;
            return ranges;
        case 1:
            typelist = types1D;
            break;
        case 2:
            typelist = types2D;
            break;
        case 3:
            typelist = types3D;
            break;
        default:
            fprintf( stderr, "Internal error at %s:%d: request for entities of dimesion %d\n", __FILE__, __LINE__,
                     dim );
            abort();
    *num_ranges_out = 0;
        if( string_contained( desc->elems[i].type, typelist ) ) ++*num_ranges_out;
    ranges = malloc( *num_ranges_out * 2 * sizeof( long ) );
    for( i = 0, j = 0; i < desc->num_elem_desc; ++i )
            ranges[j++] = desc->elems[i].desc.start_id;
            ranges[j++] = desc->elems[i].desc.count;
    *num_ranges_out = merge_ranges( ranges, *num_ranges_out );
    return ranges;
static int id_contained ( long  file_id,
const long *  ranges,
int  num_range
) [static]
Definition at line 279 of file validate.c.
Referenced by ids_contained().
    const long* end = ranges + 2 * num_range;
    for( ; ranges != end; ranges += 2 )
        if( file_id >= ranges[0] && ( file_id - ranges[0] ) < ranges[1] ) return 1;
    return 0;
static int ids_contained ( const long *  ids,
int  num_ids,
int  num_ranges
) [static]
Definition at line 289 of file validate.c.
References id_contained().
Referenced by check_valid_adj_list(), check_valid_elem_conn(), check_valid_parents_children(), check_valid_poly_conn(), check_valid_set_contents(), check_valid_tag(), and check_valid_var_len_tag().
    int i;
    for( i = 0; i < num_ids; ++i )
        if( !id_contained( ids[i], ranges, num_ranges ) ) return 0;
    return 1;
static int lcomp ( const void *  p1,
const void *  p2
) [static]
Definition at line 119 of file validate.c.
Referenced by contains_duplicates(), dcomp(), merge_ranges(), and ranges_contain_duplicates().
    long l1 = *(const long*)p1;
    long l2 = *(const long*)p2;
    return l1 < l2 ? -1 : l1 > l2 ? 1 : 0;
int main ( int  argc,
char *  argv[]
Definition at line 136 of file validate.c.
References check_file_contains_holes(), check_valid_adjacencies(), check_valid_connectivity(), check_valid_file_ids(), check_valid_sets(), check_valid_tags(), mhdf_EntDesc::count, mhdf_closeFile(), mhdf_getFileSummary(), mhdf_isError(), mhdf_message(), mhdf_openFile(), mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, and verbose.
    int result = 0;
    mhdf_FileHandle file;
    mhdf_Status status;
    unsigned long max_id;
    struct mhdf_FileDesc* desc;
    if( argc < 2 || argc > 3 )
        fprintf( stderr, "Usage: %s <filename> <verbose_option> \n", argv[0] );
        return 1;
    file = mhdf_openFile( argv[1], 0, &max_id, -1, &status );
        fprintf( stderr, "%s: %s\n", argv[1], mhdf_message( &status ) );
        return 1;
    if( argc == 3 )
        verbose = atoi( argv[2] );
    desc = mhdf_getFileSummary( file, H5T_NATIVE_LONG, &status, 0 ); /*no extra set info*/
        return 1;
    if( desc->nodes.count < 1 ) puts( "WARNING: file contains no vertices." );
    if( desc->num_elem_desc < 1 ) puts( "WARNING: file contains no elements." );
    result += check_valid_file_ids( desc );
    result += check_file_contains_holes( argv[1] );
    result += check_valid_connectivity( file, desc );
    result += check_valid_adjacencies( file, desc );
    result += check_valid_sets( file, desc );
    result += check_valid_tags( file, desc );
    free( desc );
    mhdf_closeFile( file, &status );
    return result;
static int merge_ranges ( long *  ranges,
int  nranges
) [static]
Definition at line 880 of file validate.c.
References lcomp().
Referenced by all_id_ranges(), and get_dim_ranges().
    long i, n;
    if( nranges < 1 ) return 0;
    /* merge adjacent */
    qsort( ranges, nranges, 2 * sizeof( long ), &lcomp );
    n = 1;
    for( i = 1; i < nranges; ++i )
        if( ranges[2 * n - 2] + ranges[2 * n - 1] == ranges[2 * i] )
            ranges[2 * n - 1] += ranges[2 * i + 1]; /*compact the range*/
        else
            /* do not compact, just copy, and increase number of ranges*/
            ranges[2 * n]     = ranges[2 * i];
            ranges[2 * n + 1] = ranges[2 * i + 1];
            ++n;
    return n;
static int ranges_contain_duplicates ( long *  ranges,
long  nranges
) [static]
Definition at line 787 of file validate.c.
References lcomp().
Referenced by check_valid_set_contents().
    long i;
    qsort( ranges, nranges, 2 * sizeof( long ), &lcomp ); /* sort by first value in each pair */
        if( ranges[2 * i - 2] + ranges[2 * i - 1] > ranges[2 * i] ) return 1;
    return 0;
static int ranges_contained ( const long *  id_ranges,
int  num_id_ranges,
int  num_ranges
) [static]
Definition at line 297 of file validate.c.
    int i;
    long start, count, avail;
    const long* end = ranges + 2 * num_ranges;
    const long* iter;
    for( i = 0; i < num_id_ranges; ++i )
        start = id_ranges[2 * i];
        count = id_ranges[2 * i + 1];
        while( count > 0 )
            for( iter = ranges; iter != end; iter += 2 )
                if( start >= iter[0] && ( start - iter[0] ) < iter[1] ) break;
            if( iter == end ) return 0;
            avail = iter[1] - ( start - iter[0] );
            count -= avail;
            start += avail;
    return 1;
static int string_contained ( const char *  str,
) [static]
Definition at line 322 of file validate.c.
Referenced by get_dim_ranges().
    for( ; *list; ++list )
        if( !strcmp( str, *list ) ) return 1;
    return 0;
Variable Documentation
