AWUntangleBeta.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2006 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2010) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file AWUntangleBeta.cpp
00028  *  \brief
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "AWUntangleBeta.hpp"
00034 #include "MsqMatrix.hpp"
00035 #include "TMPDerivs.hpp"
00036 #include "TMPCommon.hpp"
00037
00038 namespace MBMesquite
00039 {
00040
00041 std::string AWUntangleBeta::get_name() const
00042 {
00043     return "AWUntangleBeta";
00044 }
00045
00046 AWUntangleBeta::~AWUntangleBeta() {}
00047
00048 const int P = 3;
00049
00050 template < unsigned DIM >
00051 inline bool AWUntangleBeta::eval( const MsqMatrix< DIM, DIM >& A, const MsqMatrix< DIM, DIM >& W, double& result )
00052 {
00053     const double alpha = det( A );
00054     const double omega = det( W );
00055     double tmp         = alpha - mGamma * omega;
00056     tmp                = fabs( tmp ) - tmp;
00057     result             = tmp;
00058     for( int i = 1; i < P; ++i )
00059         result *= tmp;
00060
00061     return true;
00062 }
00063
00064 template < unsigned DIM >
00065 inline bool AWUntangleBeta::grad( const MsqMatrix< DIM, DIM >& A,
00066                                   const MsqMatrix< DIM, DIM >& W,
00067                                   double& result,
00068                                   MsqMatrix< DIM, DIM >& deriv )
00069 {
00070     const double alpha = det( A );
00071     const double omega = det( W );
00072     double tmp         = 2 * ( mGamma * omega - alpha );
00073     if( tmp < 0.0 )
00074     {
00075         result = 0.0;
00076         deriv  = MsqMatrix< DIM, DIM >( 0.0 );
00077         return true;
00078     }
00079
00080     double prod = 1.0;
00081     for( int i = 1; i < P; ++i )
00082         prod *= tmp;
00083     result = prod * tmp;
00084
00085     deriv = -2 * P * prod * transpose_adj( A );
00086     return true;
00087 }
00088 /*
00089 template <unsigned DIM> inline
00090 bool AWUntangleBeta::hess( const MsqMatrix<DIM,DIM>& A,
00091                            const MsqMatrix<DIM,DIM>& W,
00092                            double& result,
00093                            MsqMatrix<DIM,DIM>& deriv,
00094                            MsqMatrix<DIM,DIM>* second )
00095 {
00096   result = det(A) - det(W);
00097   deriv = transpose_adj(A);
00098   set_scaled_outer_product( second, 2.0, deriv );
00099   pluseq_scaled_2nd_deriv_of_det( second, 2*result, A );
00100   deriv *= 2*result;
00101   result *= result;
00102   return true;
00103 }
00104 */
00105 TMP_AW_TEMPL_IMPL_COMMON_NO2ND( AWUntangleBeta )
00106
00107 }  // namespace MBMesquite
