DataSetConverter.h
00001 #ifndef __smoab_DataSetConverter_h
00002 #define __smoab_DataSetConverter_h
00003
00004 #include "SimpleMoab.h"
00005 #include "CellSets.h"
00006 #include "detail/LoadGeometry.h"
00007 #include "detail/ReadSparseTag.h"
00008
00009 #include <vtkCellData.h>
00010 #include <vtkDoubleArray.h>
00011 #include <vtkFieldData.h>
00012 #include <vtkIntArray.h>
00013 #include <vtkIdTypeArray.h>
00014 #include <vtkNew.h>
00015
00016 #include <algorithm>
00017
00018 namespace smoab
00019 {
00020 class DataSetConverter
00021 {
00022     const smoab::Interface& Interface;
00023     moab::Interface* Moab;
00024     const smoab::Tag* Tag;
00025     bool ReadMaterialIds;
00026     bool ReadProperties;
00027     std::string MaterialName;
00028
00029   public:
00030     DataSetConverter( const smoab::Interface& interface, const smoab::Tag* tag )
00031         : Interface( interface ), Moab( interface.Moab ), Tag( tag ), ReadMaterialIds( false ), ReadProperties( false )
00032     {
00033     }
00034
00035     void readMaterialIds( bool add )
00036     {
00037         this->ReadMaterialIds = add;
00038     }
00039     bool readMaterialIds() const
00040     {
00041         return this->ReadMaterialIds;
00042     }
00043
00044     void readProperties( bool readProps )
00045     {
00046         this->ReadProperties = readProps;
00047     }
00048     bool readProperties() const
00049     {
00050         return this->ReadProperties;
00051     }
00052
00053     //----------------------------------------------------------------------------
00054     //given a range of entity handles merge them all into a single unstructured
00055     //grid. Currently doesn't support reading properties.
00056     //Will read in material ids,  if no material id is assigned to an entity,
00057     //its cells will be given an unique id
00058     template < typename VTKGridType >
00059     bool fill( const smoab::Range& entities, VTKGridType* grid ) const
00060     {
00061         //create a helper datastructure which can determines all the unique point ids
00062         //and converts moab connecitvity info to vtk connectivity
00063
00064         //get all the cells for each parent entity and create
00065         // an entity set of those items
00066         int dim = this->Tag->value();
00067         typedef smoab::Range::const_iterator iterator;
00068         smoab::CellSets entitySets;
00069         for( iterator i = entities.begin(); i != entities.end(); ++i )
00070         {
00071             smoab::Range entitiesCells;
00072             if( this->Tag->isComparable() )
00073             {
00074                 //if we are comparable only find the cells that match our tags dimension
00075                 entitiesCells = this->Interface.findEntitiesWithDimension( *i, dim, true );
00076             }
00077             else
00078             {
00079                 entitiesCells = this->Interface.findHighestDimensionEntities( *i, true );
00080             }
00081             smoab::CellSet set( *i, entitiesCells );
00082             entitySets.push_back( set );
00083         }
00084
00085         moab::Range cells = smoab::getAllCells( entitySets );
00086
00087         //convert the datastructure from a list of cells to a vtk data set
00088         detail::LoadGeometry loadGeom( cells, dim, this->Interface );
00089         loadGeom.fill( grid );
00090
00091         if( this->readMaterialIds() )
00092         {
00093
00094             detail::ReadSparseTag materialTagReading( entitySets, cells, this->Interface );
00095
00096             smoab::MaterialTag mtag;
00097             vtkNew< vtkIntArray > materials;
00098             materials->SetName( mtag.name() );
00099             materialTagReading.fill( materials.GetPointer(), &mtag );
00100             grid->GetCellData()->AddArray( materials.GetPointer() );
00101         }
00102
00103         //by default we always try to load the default tag
00104         detail::ReadSparseTag sTagReading( entitySets, cells, this->Interface );
00105
00106         vtkNew< vtkIntArray > sparseTagData;
00107         sparseTagData->SetName( this->Tag->name() );
00108         sTagReading.fill( sparseTagData.GetPointer(), this->Tag );
00109         grid->GetCellData()->AddArray( sparseTagData.GetPointer() );
00110
00111         return true;
00112     }
00113
00114     //----------------------------------------------------------------------------
00115     //given a single entity handle create a unstructured grid from it.
00116     //optional third parameter is the material id to use if readMaterialIds
00117     //is on, and no material sparse tag is found for this entity
00118     template < typename VTKGridType >
00119     bool fill( const smoab::EntityHandle& entity, VTKGridType* grid, const int materialId = 0 ) const
00120     {
00121         //create a helper datastructure which can determines all the unique point ids
00122         //and converts moab connecitvity info to vtk connectivity
00123
00124         smoab::Range cells;
00125         int dim = this->Tag->value();
00126         if( this->Tag->isComparable() )
00127         {
00128             //if we are comparable only find the cells that match our tags dimension
00129             cells = this->Interface.findEntitiesWithDimension( entity, dim, true );
00130         }
00131         else
00132         {
00133             //load subentities
00134             cells = this->Interface.findHighestDimensionEntities( entity, true );
00135         }
00136
00137         //convert the datastructure from a list of cells to a vtk data set
00138         detail::LoadGeometry loadGeom( cells, dim, this->Interface );
00139         loadGeom.fill( grid );
00140
00141         const smoab::Range& points = loadGeom.moabPoints();
00142
00143         if( this->readProperties() )
00144         {
00145             this->readProperties( cells, grid->GetCellData() );
00146             this->readProperties( points, grid->GetPointData() );
00147         }
00148
00149         smoab::CellSets cellSets;
00150         smoab::CellSet set( entity, cells );
00151         cellSets.push_back( set );
00152         if( this->readMaterialIds() )
00153         {
00154             smoab::MaterialTag mtag;
00155             detail::ReadSparseTag materialTagReading( cellSets, cells, this->Interface );
00156
00157             vtkNew< vtkIntArray > materials;
00158             materials->SetName( mtag.name() );
00159             materialTagReading.fill( materials.GetPointer(), &mtag );
00160             grid->GetCellData()->AddArray( materials.GetPointer() );
00161         }
00162
00163         //by default we always try to load the default tag
00164         detail::ReadSparseTag sTagReading( cellSets, cells, this->Interface );
00165
00166         vtkNew< vtkIntArray > sparseTagData;
00167         sparseTagData->SetName( this->Tag->name() );
00168         sTagReading.fill( sparseTagData.GetPointer(), this->Tag );
00169         grid->GetCellData()->AddArray( sparseTagData.GetPointer() );
00170
00171         return true;
00172     }
00173
00174   private:
00175     //----------------------------------------------------------------------------
00176     void readProperties( smoab::Range const& entities, vtkFieldData* field ) const
00177     {
00178         if( entities.empty() )
00179         {
00180             return;
00181         }
00182
00183         //so we get all the tags and parse out the sparse and dense tags
00184         //that we support
00185         typedef std::vector< moab::Tag >::const_iterator iterator;
00186         std::vector< moab::Tag > tags;
00187         this->Moab->tag_get_tags_on_entity( entities.front(), tags );
00188
00189         this->readDenseTags( tags, entities, field );
00190     }
00191
00192     //----------------------------------------------------------------------------
00193     void readDenseTags( std::vector< moab::Tag >& tags, smoab::Range const& entities, vtkFieldData* field ) const
00194     {
00195         typedef std::vector< moab::Tag >::const_iterator iterator;
00196
00197         for( iterator i = tags.begin(); i != tags.end(); ++i )
00198         {
00199             moab::TagType tagType;
00200             moab::DataType tagDataType;
00201
00202             this->Moab->tag_get_type( *i, tagType );
00203             this->Moab->tag_get_data_type( *i, tagDataType );
00204
00205             //make sure it is only dense
00206             if( tagType != moab::MB_TAG_DENSE )
00207             {
00208                 continue;
00209             }
00210             //and only integer and double
00211             if( tagDataType != moab::MB_TYPE_DOUBLE && tagDataType != moab::MB_TYPE_INTEGER )
00212             {
00213                 //unsupported type, skip to next tag
00214                 continue;
00215             }
00216
00217             //read the name of the tag
00218             std::string name;
00219             name.reserve( 32 );
00220             this->Moab->tag_get_name( *i, name );
00221
00222             //read the number of components of the tag
00223             int numComps = 1;
00224
00225             this->Moab->tag_get_length( *i, numComps );
00226
00227             //read the data if it is one of the two types we support
00228             int size = entities.size();
00229             if( tagDataType == moab::MB_TYPE_DOUBLE )
00230             {
00231                 vtkNew< vtkDoubleArray > array;
00232                 array->SetName( name.c_str() );
00233                 array->SetNumberOfComponents( numComps );
00234                 array->SetNumberOfTuples( size );
00235
00236                 //read directly into the double array
00237                 this->Moab->tag_get_data( *i, entities, array->GetVoidPointer( 0 ) );
00238                 field->AddArray( array.GetPointer() );
00239             }
00240             else if( tagDataType == moab::MB_TYPE_INTEGER )
00241             {
00242                 vtkNew< vtkIntArray > array;
00243                 array->SetName( name.c_str() );
00244                 array->SetNumberOfComponents( numComps );
00245                 array->SetNumberOfTuples( size );
00246
00247                 //read directly into the double array
00248                 this->Moab->tag_get_data( *i, entities, array->GetVoidPointer( 0 ) );
00249                 field->AddArray( array.GetPointer() );
00250             }
00251             else
00252             {
00253             }
00254         }
00255     }
00256 };
00257
00258 }  // namespace smoab
00259 #endif  // __smoab_DataSetConverter_h
