ExodusTest.cpp File Reference
#include <cstdio>
#include "Mesquite.hpp"
#include "MeshImpl.hpp"
#include "MsqVertex.hpp"
#include "MsqError.hpp"
#include "cppunit/extensions/HelperMacros.h"
#include <iostream>
#include <algorithm>
#include <unistd.h>
+ Include dependency graph for ExodusTest.cpp:
Classes
class  ExodusTest
Functions
static bool create_exodus_file (const char *filename)
 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (ExodusTest,"ExodusTest")
 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (ExodusTest,"Unit")
Function Documentation
bool create_exodus_file ( const char *  filename) [static]
Definition at line 252 of file ExodusTest.cpp.
Referenced by ExodusTest::test_read(), and ExodusTest::test_write().
    // This is the binary data composing an ExodusII mesh.
    // This mesh was generated using the following commands
    // in Cubit 9.2b Build 113:
    //  CUBIT> brick x 10
    //  CUBIT> cylinder radius 2 z 10
    //  CUBIT> subtract 2 from 1
    //  CUBIT> volume 1 size 1 scheme auto
    //  CUBIT> mesh volume 1
    //  CUBIT> export mesh 'mesh.g'
    // To extract this data into a file for debugging, do
    //  $ CC -DDEBUG ExodusTest.cpp -o exodump
    //  $ ./exodump mesh.g
    static const unsigned char binary_data[] = {
        0x43, 0x44, 0x46, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00,
        0x00, 0x0a, 0x6c, 0x65, 0x6e, 0x5f, 0x73, 0x74, 0x72, 0x69, 0x6e, 0x67, 0x00, 0x00, 0x00, 0x00, 0x00, 0x21,
        0x00, 0x00, 0x00, 0x08, 0x6c, 0x65, 0x6e, 0x5f, 0x6c, 0x69, 0x6e, 0x65, 0x00, 0x00, 0x00, 0x51, 0x00, 0x00,
        0x00, 0x04, 0x66, 0x6f, 0x75, 0x72, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x09, 0x74, 0x69, 0x6d, 0x65,
        0x5f, 0x73, 0x74, 0x65, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x6e, 0x75,
        0x6d, 0x5f, 0x64, 0x69, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x6e, 0x75, 0x6d, 0x5f,
        0x6e, 0x6f, 0x64, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd8, 0x00, 0x00, 0x00, 0x08, 0x6e, 0x75,
        0x6d, 0x5f, 0x65, 0x6c, 0x65, 0x6d, 0x00, 0x00, 0x00, 0x73, 0x00, 0x00, 0x00, 0x0a, 0x6e, 0x75, 0x6d, 0x5f,
        0x65, 0x6c, 0x5f, 0x62, 0x6c, 0x6b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x0e, 0x6e, 0x75,
        0x6d, 0x5f, 0x65, 0x6c, 0x5f, 0x69, 0x6e, 0x5f, 0x62, 0x6c, 0x6b, 0x31, 0x00, 0x00, 0x00, 0x00, 0x00, 0x73,
        0x00, 0x00, 0x00, 0x0f, 0x6e, 0x75, 0x6d, 0x5f, 0x6e, 0x6f, 0x64, 0x5f, 0x70, 0x65, 0x72, 0x5f, 0x65, 0x6c,
        0x31, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x0a, 0x6e, 0x75, 0x6d, 0x5f, 0x71, 0x61, 0x5f, 0x72,
        0x65, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00,
        0x00, 0x0b, 0x61, 0x70, 0x69, 0x5f, 0x76, 0x65, 0x72, 0x73, 0x69, 0x6f, 0x6e, 0x00, 0x00, 0x00, 0x00, 0x05,
        0x00, 0x00, 0x00, 0x01, 0x40, 0x80, 0x51, 0xec, 0x00, 0x00, 0x00, 0x07, 0x76, 0x65, 0x72, 0x73, 0x69, 0x6f,
        0x6e, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x01, 0x40, 0x40, 0xa3, 0xd7, 0x00, 0x00, 0x00, 0x18,
        0x66, 0x6c, 0x6f, 0x61, 0x74, 0x69, 0x6e, 0x67, 0x5f, 0x70, 0x6f, 0x69, 0x6e, 0x74, 0x5f, 0x77, 0x6f, 0x72,
        0x64, 0x5f, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x08,
        0x00, 0x00, 0x00, 0x09, 0x66, 0x69, 0x6c, 0x65, 0x5f, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x74, 0x69, 0x74, 0x6c,
        0x65, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x35, 0x63, 0x75, 0x62, 0x69, 0x74, 0x28,
        0x62, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x77, 0x69, 0x74, 0x68, 0x2d, 0x68, 0x6f, 0x6c, 0x65, 0x2d, 0x68, 0x65,
        0x78, 0x65, 0x73, 0x2e, 0x67, 0x29, 0x3a, 0x20, 0x31, 0x31, 0x2f, 0x32, 0x34, 0x2f, 0x32, 0x30, 0x30, 0x34,
        0x3a, 0x20, 0x31, 0x32, 0x3a, 0x33, 0x34, 0x3a, 0x32, 0x35, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0b,
        0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x0a, 0x74, 0x69, 0x6d, 0x65, 0x5f, 0x77, 0x68, 0x6f, 0x6c, 0x65,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x09, 0x65, 0x62,
        0x5f, 0x73, 0x74, 0x61, 0x74, 0x75, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x07,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00,
        0x10, 0x00, 0x00, 0x00, 0x00, 0x08, 0x65, 0x62, 0x5f, 0x70, 0x72, 0x6f, 0x70, 0x31, 0x00, 0x00, 0x00, 0x01,
        0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x04, 0x6e, 0x61,
        0x6d, 0x65, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x49, 0x44, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04,
        0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x10, 0x04, 0x00, 0x00, 0x00, 0x08, 0x63, 0x6f, 0x6e, 0x6e, 0x65, 0x63,
        0x74, 0x31, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x0c,
        0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x09, 0x65, 0x6c, 0x65, 0x6d, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x05, 0x48, 0x45, 0x58, 0x38, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x0e, 0x60, 0x00, 0x00, 0x10, 0x08, 0x00, 0x00, 0x00, 0x05, 0x63, 0x6f,
        0x6f, 0x72, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x05,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x14, 0x40, 0x00, 0x00,
        0x1e, 0x68, 0x00, 0x00, 0x00, 0x0a, 0x71, 0x61, 0x5f, 0x72, 0x65, 0x63, 0x6f, 0x72, 0x64, 0x73, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x84, 0x00, 0x00, 0x32, 0xa8,
        0x00, 0x00, 0x00, 0x0a, 0x63, 0x6f, 0x6f, 0x72, 0x5f, 0x6e, 0x61, 0x6d, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x02, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x64, 0x00, 0x00, 0x33, 0x2c, 0x00, 0x00, 0x00, 0x08, 0x65, 0x6c,
        0x65, 0x6d, 0x5f, 0x6d, 0x61, 0x70, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xcc, 0x00, 0x00, 0x33, 0x90, 0x00, 0x00,
        0x00, 0x0c, 0x65, 0x6c, 0x65, 0x6d, 0x5f, 0x6e, 0x75, 0x6d, 0x5f, 0x6d, 0x61, 0x70, 0x00, 0x00, 0x00, 0x01,
        0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00,
        0x01, 0xcc, 0x00, 0x00, 0x35, 0x5c, 0x00, 0x00, 0x00, 0x0c, 0x6e, 0x6f, 0x64, 0x65, 0x5f, 0x6e, 0x75, 0x6d,
        0x5f, 0x6d, 0x61, 0x70, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x03, 0x60, 0x00, 0x00, 0x37, 0x28, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01,
        0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x3f, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x00, 0xa7, 0x00, 0x00,
        0x00, 0x04, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x3f,
        0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x84, 0x00, 0x00, 0x00, 0x85, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00,
        0x00, 0x06, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x19, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0xa9,
        0x00, 0x00, 0x00, 0x83, 0x00, 0x00, 0x00, 0x84, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00,
        0x00, 0x17, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0xaa,
        0x00, 0x00, 0x00, 0xa9, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00,
        0x00, 0x1d, 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x98, 0x00, 0x00, 0x00, 0x99, 0x00, 0x00, 0x00, 0xaa,
        0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00,
        0x00, 0x2e, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0xab, 0x00, 0x00, 0x00, 0x98, 0x00, 0x00, 0x00, 0x01,
        0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00,
        0x00, 0xac, 0x00, 0x00, 0x00, 0xb0, 0x00, 0x00, 0x00, 0xab, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x20,
        0x00, 0x00, 0x00, 0x24, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00,
        0x00, 0xad, 0x00, 0x00, 0x00, 0xac, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x21,
        0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0xa7, 0x00, 0x00, 0x00, 0xae, 0x00, 0x00,
        0x00, 0x41, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x22, 0x00, 0x00, 0x00, 0x03,
        0x00, 0x00, 0x00, 0xa7, 0x00, 0x00, 0x00, 0x6b, 0x00, 0x00, 0x00, 0x6c, 0x00, 0x00, 0x00, 0xae, 0x00, 0x00,
        0x00, 0x1b, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x22, 0x00, 0x00, 0x00, 0x85,
        0x00, 0x00, 0x00, 0x86, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x00, 0x3f, 0x00, 0x00, 0x00, 0x19, 0x00, 0x00,
        0x00, 0x1a, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x9a, 0x00, 0x00, 0x00, 0x7b,
        0x00, 0x00, 0x00, 0x83, 0x00, 0x00, 0x00, 0xa9, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00,
        0x00, 0x17, 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00, 0x00, 0xa9, 0x00, 0x00, 0x00, 0xaa, 0x00, 0x00, 0x00, 0x99,
        0x00, 0x00, 0x00, 0x9a, 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00,
        0x00, 0x0c, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x00, 0x86, 0x00, 0x00, 0x00, 0x62, 0x00, 0x00, 0x00, 0x6a,
        0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x1a, 0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00,
        0x00, 0x6a, 0x00, 0x00, 0x00, 0x6b, 0x00, 0x00, 0x00, 0xa7, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x00, 0x0f,
        0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x44, 0x00, 0x00,
        0x00, 0x51, 0x00, 0x00, 0x00, 0xaf, 0x00, 0x00, 0x00, 0x6d, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x13,
        0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x6c, 0x00, 0x00, 0x00, 0x6d, 0x00, 0x00,
        0x00, 0xaf, 0x00, 0x00, 0x00, 0xae, 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x23,
        0x00, 0x00, 0x00, 0x22, 0x00, 0x00, 0x00, 0x98, 0x00, 0x00, 0x00, 0xab, 0x00, 0x00, 0x00, 0xb0, 0x00, 0x00,
        0x00, 0x97, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x24, 0x00, 0x00, 0x00, 0x09,
        0x00, 0x00, 0x00, 0x4d, 0x00, 0x00, 0x00, 0x97, 0x00, 0x00, 0x00, 0xb0, 0x00, 0x00, 0x00, 0x54, 0x00, 0x00,
        0x00, 0x07, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x24, 0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0x54,
        0x00, 0x00, 0x00, 0xb0, 0x00, 0x00, 0x00, 0xac, 0x00, 0x00, 0x00, 0x53, 0x00, 0x00, 0x00, 0x16, 0x00, 0x00,
        0x00, 0x24, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x52, 0x00, 0x00, 0x00, 0x53,
        0x00, 0x00, 0x00, 0xac, 0x00, 0x00, 0x00, 0xad, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00,
        0x00, 0x20, 0x00, 0x00, 0x00, 0x21, 0x00, 0x00, 0x00, 0xaf, 0x00, 0x00, 0x00, 0x51, 0x00, 0x00, 0x00, 0x52,
        0x00, 0x00, 0x00, 0xad, 0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00,
        0x00, 0x21, 0x00, 0x00, 0x00, 0xad, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00, 0x00, 0xae, 0x00, 0x00, 0x00, 0xaf,
        0x00, 0x00, 0x00, 0x21, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x22, 0x00, 0x00, 0x00, 0x23, 0x00, 0x00,
        0x00, 0x3b, 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0xb2, 0x00, 0x00, 0x00, 0xb1, 0x00, 0x00, 0x00, 0x40,
        0x00, 0x00, 0x00, 0x3f, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x00, 0xa7, 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00,
        0x00, 0x39, 0x00, 0x00, 0x00, 0x88, 0x00, 0x00, 0x00, 0x89, 0x00, 0x00, 0x00, 0x3f, 0x00, 0x00, 0x00, 0x3e,
        0x00, 0x00, 0x00, 0x84, 0x00, 0x00, 0x00, 0x85, 0x00, 0x00, 0x00, 0x39, 0x00, 0x00, 0x00, 0xb3, 0x00, 0x00,
        0x00, 0x87, 0x00, 0x00, 0x00, 0x88, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0xa9, 0x00, 0x00, 0x00, 0x83,
        0x00, 0x00, 0x00, 0x84, 0x00, 0x00, 0x00, 0x39, 0x00, 0x00, 0x00, 0x2d, 0x00, 0x00, 0x00, 0xb4, 0x00, 0x00,
        0x00, 0xb3, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0xaa, 0x00, 0x00, 0x00, 0xa9,
        0x00, 0x00, 0x00, 0x2d, 0x00, 0x00, 0x00, 0x9c, 0x00, 0x00, 0x00, 0x9d, 0x00, 0x00, 0x00, 0xb4, 0x00, 0x00,
        0x00, 0x2e, 0x00, 0x00, 0x00, 0x98, 0x00, 0x00, 0x00, 0x99, 0x00, 0x00, 0x00, 0xaa, 0x00, 0x00, 0x00, 0x2d,
        0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x9c, 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00,
        0x00, 0x42, 0x00, 0x00, 0x00, 0xab, 0x00, 0x00, 0x00, 0x98, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0xb6,
        0x00, 0x00, 0x00, 0xba, 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0xac, 0x00, 0x00,
        0x00, 0xb0, 0x00, 0x00, 0x00, 0xab, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0xb7,
        0x00, 0x00, 0x00, 0xb6, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00, 0x00, 0xad, 0x00, 0x00,
        0x00, 0xac, 0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0xb1, 0x00, 0x00, 0x00, 0xb8, 0x00, 0x00, 0x00, 0x3c,
        0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0xa7, 0x00, 0x00, 0x00, 0xae, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00,
        0x00, 0xb1, 0x00, 0x00, 0x00, 0x6f, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0xb8, 0x00, 0x00, 0x00, 0xa7,
        0x00, 0x00, 0x00, 0x6b, 0x00, 0x00, 0x00, 0x6c, 0x00, 0x00, 0x00, 0xae, 0x00, 0x00, 0x00, 0x89, 0x00, 0x00,
        0x00, 0x8a, 0x00, 0x00, 0x00, 0xb2, 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x85, 0x00, 0x00, 0x00, 0x86,
        0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x00, 0x3f, 0x00, 0x00, 0x00, 0x9e, 0x00, 0x00, 0x00, 0x7c, 0x00, 0x00,
        0x00, 0x87, 0x00, 0x00, 0x00, 0xb3, 0x00, 0x00, 0x00, 0x9a, 0x00, 0x00, 0x00, 0x7b, 0x00, 0x00, 0x00, 0x83,
        0x00, 0x00, 0x00, 0xa9, 0x00, 0x00, 0x00, 0xb3, 0x00, 0x00, 0x00, 0xb4, 0x00, 0x00, 0x00, 0x9d, 0x00, 0x00,
        0x00, 0x9e, 0x00, 0x00, 0x00, 0xa9, 0x00, 0x00, 0x00, 0xaa, 0x00, 0x00, 0x00, 0x99, 0x00, 0x00, 0x00, 0x9a,
        0x00, 0x00, 0x00, 0xb2, 0x00, 0x00, 0x00, 0x8a, 0x00, 0x00, 0x00, 0x63, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00,
        0x00, 0xa8, 0x00, 0x00, 0x00, 0x86, 0x00, 0x00, 0x00, 0x62, 0x00, 0x00, 0x00, 0x6a, 0x00, 0x00, 0x00, 0x6e,
        0x00, 0x00, 0x00, 0x6f, 0x00, 0x00, 0x00, 0xb1, 0x00, 0x00, 0x00, 0xb2, 0x00, 0x00, 0x00, 0x6a, 0x00, 0x00,
        0x00, 0x6b, 0x00, 0x00, 0x00, 0xa7, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x00, 0x45, 0x00, 0x00, 0x00, 0x55,
        0x00, 0x00, 0x00, 0xb9, 0x00, 0x00, 0x00, 0x71, 0x00, 0x00, 0x00, 0x44, 0x00, 0x00, 0x00, 0x51, 0x00, 0x00,
        0x00, 0xaf, 0x00, 0x00, 0x00, 0x6d, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x71, 0x00, 0x00, 0x00, 0xb9,
        0x00, 0x00, 0x00, 0xb8, 0x00, 0x00, 0x00, 0x6c, 0x00, 0x00, 0x00, 0x6d, 0x00, 0x00, 0x00, 0xaf, 0x00, 0x00,
        0x00, 0xae, 0x00, 0x00, 0x00, 0x9c, 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0xba, 0x00, 0x00, 0x00, 0x9b,
        0x00, 0x00, 0x00, 0x98, 0x00, 0x00, 0x00, 0xab, 0x00, 0x00, 0x00, 0xb0, 0x00, 0x00, 0x00, 0x97, 0x00, 0x00,
        0x00, 0x4e, 0x00, 0x00, 0x00, 0x9b, 0x00, 0x00, 0x00, 0xba, 0x00, 0x00, 0x00, 0x58, 0x00, 0x00, 0x00, 0x4d,
        0x00, 0x00, 0x00, 0x97, 0x00, 0x00, 0x00, 0xb0, 0x00, 0x00, 0x00, 0x54, 0x00, 0x00, 0x00, 0x58, 0x00, 0x00,
        0x00, 0xba, 0x00, 0x00, 0x00, 0xb6, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0x54, 0x00, 0x00, 0x00, 0xb0,
        0x00, 0x00, 0x00, 0xac, 0x00, 0x00, 0x00, 0x53, 0x00, 0x00, 0x00, 0x56, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00,
        0x00, 0xb6, 0x00, 0x00, 0x00, 0xb7, 0x00, 0x00, 0x00, 0x52, 0x00, 0x00, 0x00, 0x53, 0x00, 0x00, 0x00, 0xac,
        0x00, 0x00, 0x00, 0xad, 0x00, 0x00, 0x00, 0xb9, 0x00, 0x00, 0x00, 0x55, 0x00, 0x00, 0x00, 0x56, 0x00, 0x00,
        0x00, 0xb7, 0x00, 0x00, 0x00, 0xaf, 0x00, 0x00, 0x00, 0x51, 0x00, 0x00, 0x00, 0x52, 0x00, 0x00, 0x00, 0xad,
        0x00, 0x00, 0x00, 0xb7, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0xb8, 0x00, 0x00, 0x00, 0xb9, 0x00, 0x00,
        0x00, 0xad, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00, 0x00, 0xae, 0x00, 0x00, 0x00, 0xaf, 0x00, 0x00, 0x00, 0x36,
        0x00, 0x00, 0x00, 0x35, 0x00, 0x00, 0x00, 0xbc, 0x00, 0x00, 0x00, 0xbb, 0x00, 0x00, 0x00, 0x3b, 0x00, 0x00,
        0x00, 0x3a, 0x00, 0x00, 0x00, 0xb2, 0x00, 0x00, 0x00, 0xb1, 0x00, 0x00, 0x00, 0x35, 0x00, 0x00, 0x00, 0x34,
        0x00, 0x00, 0x00, 0x8c, 0x00, 0x00, 0x00, 0x8d, 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x39, 0x00, 0x00,
        0x00, 0x88, 0x00, 0x00, 0x00, 0x89, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0xbd, 0x00, 0x00, 0x00, 0x8b,
        0x00, 0x00, 0x00, 0x8c, 0x00, 0x00, 0x00, 0x39, 0x00, 0x00, 0x00, 0xb3, 0x00, 0x00, 0x00, 0x87, 0x00, 0x00,
        0x00, 0x88, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0xbe, 0x00, 0x00, 0x00, 0xbd,
        0x00, 0x00, 0x00, 0x39, 0x00, 0x00, 0x00, 0x2d, 0x00, 0x00, 0x00, 0xb4, 0x00, 0x00, 0x00, 0xb3, 0x00, 0x00,
        0x00, 0x2c, 0x00, 0x00, 0x00, 0xa0, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0xbe, 0x00, 0x00, 0x00, 0x2d,
        0x00, 0x00, 0x00, 0x9c, 0x00, 0x00, 0x00, 0x9d, 0x00, 0x00, 0x00, 0xb4, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00,
        0x00, 0x38, 0x00, 0x00, 0x00, 0xbf, 0x00, 0x00, 0x00, 0xa0, 0x00, 0x00, 0x00, 0x2d, 0x00, 0x00, 0x00, 0x3d,
        0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x9c, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00,
        0x00, 0xc4, 0x00, 0x00, 0x00, 0xbf, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0xb6, 0x00, 0x00, 0x00, 0xba,
        0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x37, 0x00, 0x00, 0x00, 0xc1, 0x00, 0x00,
        0x00, 0xc0, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0xb7, 0x00, 0x00, 0x00, 0xb6,
        0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x00, 0xbb, 0x00, 0x00, 0x00, 0xc2, 0x00, 0x00, 0x00, 0x37, 0x00, 0x00,
        0x00, 0x3b, 0x00, 0x00, 0x00, 0xb1, 0x00, 0x00, 0x00, 0xb8, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0xbb,
        0x00, 0x00, 0x00, 0x73, 0x00, 0x00, 0x00, 0x74, 0x00, 0x00, 0x00, 0xc2, 0x00, 0x00, 0x00, 0xb1, 0x00, 0x00,
        0x00, 0x6f, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0xb8, 0x00, 0x00, 0x00, 0x8d, 0x00, 0x00, 0x00, 0x8e,
        0x00, 0x00, 0x00, 0xbc, 0x00, 0x00, 0x00, 0x35, 0x00, 0x00, 0x00, 0x89, 0x00, 0x00, 0x00, 0x8a, 0x00, 0x00,
        0x00, 0xb2, 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0xa2, 0x00, 0x00, 0x00, 0x7d, 0x00, 0x00, 0x00, 0x8b,
        0x00, 0x00, 0x00, 0xbd, 0x00, 0x00, 0x00, 0x9e, 0x00, 0x00, 0x00, 0x7c, 0x00, 0x00, 0x00, 0x87, 0x00, 0x00,
        0x00, 0xb3, 0x00, 0x00, 0x00, 0xbd, 0x00, 0x00, 0x00, 0xbe, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0xa2,
        0x00, 0x00, 0x00, 0xb3, 0x00, 0x00, 0x00, 0xb4, 0x00, 0x00, 0x00, 0x9d, 0x00, 0x00, 0x00, 0x9e, 0x00, 0x00,
        0x00, 0xbc, 0x00, 0x00, 0x00, 0x8e, 0x00, 0x00, 0x00, 0x64, 0x00, 0x00, 0x00, 0x72, 0x00, 0x00, 0x00, 0xb2,
        0x00, 0x00, 0x00, 0x8a, 0x00, 0x00, 0x00, 0x63, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00, 0x00, 0x72, 0x00, 0x00,
        0x00, 0x73, 0x00, 0x00, 0x00, 0xbb, 0x00, 0x00, 0x00, 0xbc, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00, 0x00, 0x6f,
        0x00, 0x00, 0x00, 0xb1, 0x00, 0x00, 0x00, 0xb2, 0x00, 0x00, 0x00, 0x46, 0x00, 0x00, 0x00, 0x59, 0x00, 0x00,
        0x00, 0xc3, 0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0x45, 0x00, 0x00, 0x00, 0x55, 0x00, 0x00, 0x00, 0xb9,
        0x00, 0x00, 0x00, 0x71, 0x00, 0x00, 0x00, 0x74, 0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0xc3, 0x00, 0x00,
        0x00, 0xc2, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x71, 0x00, 0x00, 0x00, 0xb9, 0x00, 0x00, 0x00, 0xb8,
        0x00, 0x00, 0x00, 0xa0, 0x00, 0x00, 0x00, 0xbf, 0x00, 0x00, 0x00, 0xc4, 0x00, 0x00, 0x00, 0x9f, 0x00, 0x00,
        0x00, 0x9c, 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0xba, 0x00, 0x00, 0x00, 0x9b, 0x00, 0x00, 0x00, 0x4f,
        0x00, 0x00, 0x00, 0x9f, 0x00, 0x00, 0x00, 0xc4, 0x00, 0x00, 0x00, 0x5c, 0x00, 0x00, 0x00, 0x4e, 0x00, 0x00,
        0x00, 0x9b, 0x00, 0x00, 0x00, 0xba, 0x00, 0x00, 0x00, 0x58, 0x00, 0x00, 0x00, 0x5c, 0x00, 0x00, 0x00, 0xc4,
        0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x5b, 0x00, 0x00, 0x00, 0x58, 0x00, 0x00, 0x00, 0xba, 0x00, 0x00,
        0x00, 0xb6, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0x5a, 0x00, 0x00, 0x00, 0x5b, 0x00, 0x00, 0x00, 0xc0,
        0x00, 0x00, 0x00, 0xc1, 0x00, 0x00, 0x00, 0x56, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0xb6, 0x00, 0x00,
        0x00, 0xb7, 0x00, 0x00, 0x00, 0xc3, 0x00, 0x00, 0x00, 0x59, 0x00, 0x00, 0x00, 0x5a, 0x00, 0x00, 0x00, 0xc1,
        0x00, 0x00, 0x00, 0xb9, 0x00, 0x00, 0x00, 0x55, 0x00, 0x00, 0x00, 0x56, 0x00, 0x00, 0x00, 0xb7, 0x00, 0x00,
        0x00, 0xc1, 0x00, 0x00, 0x00, 0x37, 0x00, 0x00, 0x00, 0xc2, 0x00, 0x00, 0x00, 0xc3, 0x00, 0x00, 0x00, 0xb7,
        0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0xb8, 0x00, 0x00, 0x00, 0xb9, 0x00, 0x00, 0x00, 0x31, 0x00, 0x00,
        0x00, 0x30, 0x00, 0x00, 0x00, 0xc6, 0x00, 0x00, 0x00, 0xc5, 0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x00, 0x35,
        0x00, 0x00, 0x00, 0xbc, 0x00, 0x00, 0x00, 0xbb, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00,
        0x00, 0x90, 0x00, 0x00, 0x00, 0x91, 0x00, 0x00, 0x00, 0x35, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x8c,
        0x00, 0x00, 0x00, 0x8d, 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00, 0x00, 0xc7, 0x00, 0x00, 0x00, 0x8f, 0x00, 0x00,
        0x00, 0x90, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0xbd, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x8c,
        0x00, 0x00, 0x00, 0x2f, 0x00, 0x00, 0x00, 0x2b, 0x00, 0x00, 0x00, 0xc8, 0x00, 0x00, 0x00, 0xc7, 0x00, 0x00,
        0x00, 0x34, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0xbe, 0x00, 0x00, 0x00, 0xbd, 0x00, 0x00, 0x00, 0x2b,
        0x00, 0x00, 0x00, 0xa4, 0x00, 0x00, 0x00, 0xa5, 0x00, 0x00, 0x00, 0xc8, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00,
        0x00, 0xa0, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0xbe, 0x00, 0x00, 0x00, 0x2b, 0x00, 0x00, 0x00, 0x33,
        0x00, 0x00, 0x00, 0xc9, 0x00, 0x00, 0x00, 0xa4, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00,
        0x00, 0xbf, 0x00, 0x00, 0x00, 0xa0, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x00, 0xca, 0x00, 0x00, 0x00, 0xce,
        0x00, 0x00, 0x00, 0xc9, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0xc4, 0x00, 0x00,
        0x00, 0xbf, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x00, 0xcb, 0x00, 0x00, 0x00, 0xca,
        0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x37, 0x00, 0x00, 0x00, 0xc1, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00,
        0x00, 0x31, 0x00, 0x00, 0x00, 0xc5, 0x00, 0x00, 0x00, 0xcc, 0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x00, 0x36,
        0x00, 0x00, 0x00, 0xbb, 0x00, 0x00, 0x00, 0xc2, 0x00, 0x00, 0x00, 0x37, 0x00, 0x00, 0x00, 0xc5, 0x00, 0x00,
        0x00, 0x77, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0xcc, 0x00, 0x00, 0x00, 0xbb, 0x00, 0x00, 0x00, 0x73,
        0x00, 0x00, 0x00, 0x74, 0x00, 0x00, 0x00, 0xc2, 0x00, 0x00, 0x00, 0x91, 0x00, 0x00, 0x00, 0x92, 0x00, 0x00,
        0x00, 0xc6, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x8d, 0x00, 0x00, 0x00, 0x8e, 0x00, 0x00, 0x00, 0xbc,
        0x00, 0x00, 0x00, 0x35, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x7e, 0x00, 0x00, 0x00, 0x8f, 0x00, 0x00,
        0x00, 0xc7, 0x00, 0x00, 0x00, 0xa2, 0x00, 0x00, 0x00, 0x7d, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0xbd,
        0x00, 0x00, 0x00, 0xc7, 0x00, 0x00, 0x00, 0xc8, 0x00, 0x00, 0x00, 0xa5, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00,
        0x00, 0xbd, 0x00, 0x00, 0x00, 0xbe, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0xa2, 0x00, 0x00, 0x00, 0xc6,
        0x00, 0x00, 0x00, 0x92, 0x00, 0x00, 0x00, 0x65, 0x00, 0x00, 0x00, 0x76, 0x00, 0x00, 0x00, 0xbc, 0x00, 0x00,
        0x00, 0x8e, 0x00, 0x00, 0x00, 0x64, 0x00, 0x00, 0x00, 0x72, 0x00, 0x00, 0x00, 0x76, 0x00, 0x00, 0x00, 0x77,
        0x00, 0x00, 0x00, 0xc5, 0x00, 0x00, 0x00, 0xc6, 0x00, 0x00, 0x00, 0x72, 0x00, 0x00, 0x00, 0x73, 0x00, 0x00,
        0x00, 0xbb, 0x00, 0x00, 0x00, 0xbc, 0x00, 0x00, 0x00, 0x47, 0x00, 0x00, 0x00, 0x5d, 0x00, 0x00, 0x00, 0xcd,
        0x00, 0x00, 0x00, 0x79, 0x00, 0x00, 0x00, 0x46, 0x00, 0x00, 0x00, 0x59, 0x00, 0x00, 0x00, 0xc3, 0x00, 0x00,
        0x00, 0x75, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x79, 0x00, 0x00, 0x00, 0xcd, 0x00, 0x00, 0x00, 0xcc,
        0x00, 0x00, 0x00, 0x74, 0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0xc3, 0x00, 0x00, 0x00, 0xc2, 0x00, 0x00,
        0x00, 0xa4, 0x00, 0x00, 0x00, 0xc9, 0x00, 0x00, 0x00, 0xce, 0x00, 0x00, 0x00, 0xa3, 0x00, 0x00, 0x00, 0xa0,
        0x00, 0x00, 0x00, 0xbf, 0x00, 0x00, 0x00, 0xc4, 0x00, 0x00, 0x00, 0x9f, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00,
        0x00, 0xa3, 0x00, 0x00, 0x00, 0xce, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x4f, 0x00, 0x00, 0x00, 0x9f,
        0x00, 0x00, 0x00, 0xc4, 0x00, 0x00, 0x00, 0x5c, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0xce, 0x00, 0x00,
        0x00, 0xca, 0x00, 0x00, 0x00, 0x5f, 0x00, 0x00, 0x00, 0x5c, 0x00, 0x00, 0x00, 0xc4, 0x00, 0x00, 0x00, 0xc0,
        0x00, 0x00, 0x00, 0x5b, 0x00, 0x00, 0x00, 0x5e, 0x00, 0x00, 0x00, 0x5f, 0x00, 0x00, 0x00, 0xca, 0x00, 0x00,
        0x00, 0xcb, 0x00, 0x00, 0x00, 0x5a, 0x00, 0x00, 0x00, 0x5b, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0xc1,
        0x00, 0x00, 0x00, 0xcd, 0x00, 0x00, 0x00, 0x5d, 0x00, 0x00, 0x00, 0x5e, 0x00, 0x00, 0x00, 0xcb, 0x00, 0x00,
        0x00, 0xc3, 0x00, 0x00, 0x00, 0x59, 0x00, 0x00, 0x00, 0x5a, 0x00, 0x00, 0x00, 0xc1, 0x00, 0x00, 0x00, 0xcb,
        0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x00, 0xcc, 0x00, 0x00, 0x00, 0xcd, 0x00, 0x00, 0x00, 0xc1, 0x00, 0x00,
        0x00, 0x37, 0x00, 0x00, 0x00, 0xc2, 0x00, 0x00, 0x00, 0xc3, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x27,
        0x00, 0x00, 0x00, 0xd0, 0x00, 0x00, 0x00, 0xcf, 0x00, 0x00, 0x00, 0x31, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00,
        0x00, 0xc6, 0x00, 0x00, 0x00, 0xc5, 0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x00, 0x81,
        0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00, 0x00, 0x90, 0x00, 0x00,
        0x00, 0x91, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x00, 0xd1, 0x00, 0x00, 0x00, 0x82, 0x00, 0x00, 0x00, 0x81,
        0x00, 0x00, 0x00, 0x2f, 0x00, 0x00, 0x00, 0xc7, 0x00, 0x00, 0x00, 0x8f, 0x00, 0x00, 0x00, 0x90, 0x00, 0x00,
        0x00, 0x26, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0xd2, 0x00, 0x00, 0x00, 0xd1, 0x00, 0x00, 0x00, 0x2f,
        0x00, 0x00, 0x00, 0x2b, 0x00, 0x00, 0x00, 0xc8, 0x00, 0x00, 0x00, 0xc7, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00,
        0x00, 0x95, 0x00, 0x00, 0x00, 0x94, 0x00, 0x00, 0x00, 0xd2, 0x00, 0x00, 0x00, 0x2b, 0x00, 0x00, 0x00, 0xa4,
        0x00, 0x00, 0x00, 0xa5, 0x00, 0x00, 0x00, 0xc8, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0x2a, 0x00, 0x00,
        0x00, 0xd3, 0x00, 0x00, 0x00, 0x95, 0x00, 0x00, 0x00, 0x2b, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x00, 0xc9,
        0x00, 0x00, 0x00, 0xa4, 0x00, 0x00, 0x00, 0x2a, 0x00, 0x00, 0x00, 0xd4, 0x00, 0x00, 0x00, 0xd8, 0x00, 0x00,
        0x00, 0xd3, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x00, 0xca, 0x00, 0x00, 0x00, 0xce, 0x00, 0x00, 0x00, 0xc9,
        0x00, 0x00, 0x00, 0x2a, 0x00, 0x00, 0x00, 0x29, 0x00, 0x00, 0x00, 0xd5, 0x00, 0x00, 0x00, 0xd4, 0x00, 0x00,
        0x00, 0x33, 0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x00, 0xcb, 0x00, 0x00, 0x00, 0xca, 0x00, 0x00, 0x00, 0x28,
        0x00, 0x00, 0x00, 0xcf, 0x00, 0x00, 0x00, 0xd6, 0x00, 0x00, 0x00, 0x29, 0x00, 0x00, 0x00, 0x31, 0x00, 0x00,
        0x00, 0xc5, 0x00, 0x00, 0x00, 0xcc, 0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x00, 0xcf, 0x00, 0x00, 0x00, 0x68,
        0x00, 0x00, 0x00, 0x67, 0x00, 0x00, 0x00, 0xd6, 0x00, 0x00, 0x00, 0xc5, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00,
        0x00, 0x78, 0x00, 0x00, 0x00, 0xcc, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0xd0,
        0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x91, 0x00, 0x00, 0x00, 0x92, 0x00, 0x00, 0x00, 0xc6, 0x00, 0x00,
        0x00, 0x30, 0x00, 0x00, 0x00, 0x93, 0x00, 0x00, 0x00, 0x7a, 0x00, 0x00, 0x00, 0x82, 0x00, 0x00, 0x00, 0xd1,
        0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x7e, 0x00, 0x00, 0x00, 0x8f, 0x00, 0x00, 0x00, 0xc7, 0x00, 0x00,
        0x00, 0xd1, 0x00, 0x00, 0x00, 0xd2, 0x00, 0x00, 0x00, 0x94, 0x00, 0x00, 0x00, 0x93, 0x00, 0x00, 0x00, 0xc7,
        0x00, 0x00, 0x00, 0xc8, 0x00, 0x00, 0x00, 0xa5, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0xd0, 0x00, 0x00,
        0x00, 0x7f, 0x00, 0x00, 0x00, 0x61, 0x00, 0x00, 0x00, 0x69, 0x00, 0x00, 0x00, 0xc6, 0x00, 0x00, 0x00, 0x92,
        0x00, 0x00, 0x00, 0x65, 0x00, 0x00, 0x00, 0x76, 0x00, 0x00, 0x00, 0x69, 0x00, 0x00, 0x00, 0x68, 0x00, 0x00,
        0x00, 0xcf, 0x00, 0x00, 0x00, 0xd0, 0x00, 0x00, 0x00, 0x76, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x00, 0xc5,
        0x00, 0x00, 0x00, 0xc6, 0x00, 0x00, 0x00, 0x43, 0x00, 0x00, 0x00, 0x4c, 0x00, 0x00, 0x00, 0xd7, 0x00, 0x00,
        0x00, 0x66, 0x00, 0x00, 0x00, 0x47, 0x00, 0x00, 0x00, 0x5d, 0x00, 0x00, 0x00, 0xcd, 0x00, 0x00, 0x00, 0x79,
        0x00, 0x00, 0x00, 0x67, 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0xd7, 0x00, 0x00, 0x00, 0xd6, 0x00, 0x00,
        0x00, 0x78, 0x00, 0x00, 0x00, 0x79, 0x00, 0x00, 0x00, 0xcd, 0x00, 0x00, 0x00, 0xcc, 0x00, 0x00, 0x00, 0x95,
        0x00, 0x00, 0x00, 0xd3, 0x00, 0x00, 0x00, 0xd8, 0x00, 0x00, 0x00, 0x96, 0x00, 0x00, 0x00, 0xa4, 0x00, 0x00,
        0x00, 0xc9, 0x00, 0x00, 0x00, 0xce, 0x00, 0x00, 0x00, 0xa3, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00, 0x00, 0x96,
        0x00, 0x00, 0x00, 0xd8, 0x00, 0x00, 0x00, 0x49, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0xa3, 0x00, 0x00,
        0x00, 0xce, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x49, 0x00, 0x00, 0x00, 0xd8, 0x00, 0x00, 0x00, 0xd4,
        0x00, 0x00, 0x00, 0x4a, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0xce, 0x00, 0x00, 0x00, 0xca, 0x00, 0x00,
        0x00, 0x5f, 0x00, 0x00, 0x00, 0x4b, 0x00, 0x00, 0x00, 0x4a, 0x00, 0x00, 0x00, 0xd4, 0x00, 0x00, 0x00, 0xd5,
        0x00, 0x00, 0x00, 0x5e, 0x00, 0x00, 0x00, 0x5f, 0x00, 0x00, 0x00, 0xca, 0x00, 0x00, 0x00, 0xcb, 0x00, 0x00,
        0x00, 0xd7, 0x00, 0x00, 0x00, 0x4c, 0x00, 0x00, 0x00, 0x4b, 0x00, 0x00, 0x00, 0xd5, 0x00, 0x00, 0x00, 0xcd,
        0x00, 0x00, 0x00, 0x5d, 0x00, 0x00, 0x00, 0x5e, 0x00, 0x00, 0x00, 0xcb, 0x00, 0x00, 0x00, 0xd5, 0x00, 0x00,
        0x00, 0x29, 0x00, 0x00, 0x00, 0xd6, 0x00, 0x00, 0x00, 0xd7, 0x00, 0x00, 0x00, 0xcb, 0x00, 0x00, 0x00, 0x32,
        0x00, 0x00, 0x00, 0xcc, 0x00, 0x00, 0x00, 0xcd, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0xc0, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0xc0, 0x0a, 0xb9, 0x00, 0xe6, 0x16, 0x57, 0x22, 0xc0, 0x08, 0x67, 0xed, 0xd7, 0x8c, 0xf3, 0x2a, 0x40, 0x08,
        0x93, 0x0c, 0xe4, 0x23, 0x2e, 0x2d, 0x40, 0x0a, 0xdb, 0xae, 0xf6, 0xb6, 0x64, 0xb9, 0x40, 0x08, 0x01, 0x02,
        0x45, 0x0d, 0x10, 0xc3, 0x3f, 0xf0, 0x03, 0x57, 0x24, 0xfe, 0x03, 0xda, 0xbf, 0xf0, 0x16, 0x60, 0xea, 0xcd,
        0xf8, 0x3a, 0xc0, 0x09, 0x11, 0xe3, 0x63, 0x56, 0x24, 0x87, 0xc0, 0x08, 0x4d, 0xb1, 0x06, 0xba, 0xa2, 0x60,
        0x40, 0x08, 0x00, 0x9e, 0xd7, 0xe4, 0x5a, 0x35, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0,
        0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x3f, 0xef, 0xff, 0xff, 0xff, 0xff,
        0xff, 0xff, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
        0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x3f, 0xef,
        0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xbf, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x02, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
        0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xef,
        0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xc0, 0x14, 0x00, 0x00,
        0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00,
        0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xef,
        0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x40, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x08, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x03, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
        0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x07,
        0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x01, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00,
        0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0,
        0x00, 0x00, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
        0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x08, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x02, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x02, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
        0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xc0, 0x08,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xc0, 0x0a, 0xb9, 0x00, 0xe6, 0x16, 0x57, 0x22, 0xc0, 0x08, 0x67, 0xed, 0xd7, 0x8c,
        0xf3, 0x2a, 0x40, 0x08, 0x93, 0x0c, 0xe4, 0x23, 0x2e, 0x2d, 0x40, 0x0a, 0xdb, 0xae, 0xf6, 0xb6, 0x64, 0xb9,
        0x40, 0x08, 0x01, 0x02, 0x45, 0x0d, 0x10, 0xc3, 0x3f, 0xf0, 0x03, 0x57, 0x24, 0xfe, 0x03, 0xda, 0xbf, 0xf0,
        0x16, 0x60, 0xea, 0xcd, 0xf8, 0x3a, 0xc0, 0x09, 0x11, 0xe3, 0x63, 0x56, 0x24, 0x87, 0xc0, 0x08, 0x4d, 0xb1,
        0x06, 0xba, 0xa2, 0x60, 0x40, 0x08, 0x00, 0x9e, 0xd7, 0xe4, 0x5a, 0x35, 0xc0, 0x0a, 0xb9, 0x00, 0xe6, 0x16,
        0x57, 0x22, 0xc0, 0x08, 0x67, 0xed, 0xd7, 0x8c, 0xf3, 0x2a, 0x40, 0x08, 0x93, 0x0c, 0xe4, 0x23, 0x2e, 0x2d,
        0x40, 0x0a, 0xdb, 0xae, 0xf6, 0xb6, 0x64, 0xb9, 0x40, 0x08, 0x01, 0x02, 0x45, 0x0d, 0x10, 0xc3, 0x3f, 0xf0,
        0x03, 0x57, 0x24, 0xfe, 0x03, 0xdb, 0xbf, 0xf0, 0x16, 0x60, 0xea, 0xcd, 0xf8, 0x39, 0xc0, 0x09, 0x11, 0xe3,
        0x63, 0x56, 0x24, 0x87, 0xc0, 0x08, 0x4d, 0xb1, 0x06, 0xba, 0xa2, 0x60, 0x40, 0x08, 0x00, 0x9e, 0xd7, 0xe4,
        0x5a, 0x35, 0xc0, 0x0a, 0xb9, 0x00, 0xe6, 0x16, 0x57, 0x22, 0xc0, 0x08, 0x67, 0xed, 0xd7, 0x8c, 0xf3, 0x2a,
        0x40, 0x08, 0x93, 0x0c, 0xe4, 0x23, 0x2e, 0x2d, 0x40, 0x0a, 0xdb, 0xae, 0xf6, 0xb6, 0x64, 0xb9, 0x40, 0x08,
        0x01, 0x02, 0x45, 0x0d, 0x10, 0xc3, 0x3f, 0xf0, 0x03, 0x57, 0x24, 0xfe, 0x03, 0xda, 0xbf, 0xf0, 0x16, 0x60,
        0xea, 0xcd, 0xf8, 0x3a, 0xc0, 0x09, 0x11, 0xe3, 0x63, 0x56, 0x24, 0x87, 0xc0, 0x08, 0x4d, 0xb1, 0x06, 0xba,
        0xa2, 0x60, 0x40, 0x08, 0x00, 0x9e, 0xd7, 0xe4, 0x5a, 0x34, 0xc0, 0x0a, 0xb9, 0x00, 0xe6, 0x16, 0x57, 0x22,
        0xc0, 0x08, 0x67, 0xed, 0xd7, 0x8c, 0xf3, 0x2a, 0x40, 0x08, 0x93, 0x0c, 0xe4, 0x23, 0x2e, 0x2d, 0x40, 0x0a,
        0xdb, 0xae, 0xf6, 0xb6, 0x64, 0xb9, 0x40, 0x08, 0x01, 0x02, 0x45, 0x0d, 0x10, 0xc3, 0x3f, 0xf0, 0x03, 0x57,
        0x24, 0xfe, 0x03, 0xda, 0xbf, 0xf0, 0x16, 0x60, 0xea, 0xcd, 0xf8, 0x3a, 0xc0, 0x09, 0x11, 0xe3, 0x63, 0x56,
        0x24, 0x87, 0xc0, 0x08, 0x4d, 0xb1, 0x06, 0xba, 0xa2, 0x60, 0x40, 0x08, 0x00, 0x9e, 0xd7, 0xe4, 0x5a, 0x34,
        0x40, 0x08, 0x00, 0x9e, 0xd7, 0xe4, 0x5a, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xfb,
        0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xaa, 0xbf, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xaa, 0xbc, 0xb1, 0xa6, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x3f, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xa8, 0x3f, 0xfb, 0xb6, 0x7a, 0xe8, 0x58,
        0x4c, 0xaa, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14,
        0x3f, 0xe0, 0xb3, 0x17, 0xb3, 0x8e, 0x9a, 0x9a, 0x40, 0x04, 0xa1, 0x15, 0xcf, 0x9d, 0xa3, 0x56, 0x40, 0x06,
        0x8e, 0x9f, 0x90, 0x1b, 0xac, 0xc3, 0x3f, 0xf4, 0x5f, 0x15, 0x0a, 0xbd, 0x1d, 0xd7, 0xc0, 0x00, 0x5f, 0xf7,
        0xd7, 0xbd, 0xfe, 0x90, 0xc0, 0x0a, 0xf1, 0x0d, 0x18, 0x85, 0xfb, 0xd0, 0xc0, 0x0a, 0xa8, 0xa6, 0x19, 0x12,
        0x5e, 0xdc, 0xbf, 0xf5, 0xe6, 0x13, 0x67, 0x45, 0xd0, 0x8c, 0xc0, 0x09, 0x7f, 0x08, 0xc2, 0x31, 0xf5, 0x25,
        0xc0, 0x0b, 0x4c, 0x51, 0xef, 0x67, 0x04, 0x17, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xfb,
        0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xaa, 0x3f, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xaa, 0x3c, 0xb1, 0xa6, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xbf, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xa8, 0xbf, 0xfb, 0xb6, 0x7a, 0xe8, 0x58,
        0x4c, 0xaa, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xfb,
        0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xaa, 0x3f, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xab, 0x3c, 0xa5, 0x2d, 0x99,
        0x99, 0x99, 0x99, 0x9a, 0xbf, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xa8, 0xbf, 0xfb, 0xb6, 0x7a, 0xe8, 0x58,
        0x4c, 0xaa, 0x3f, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xaa, 0x3f, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xab,
        0x3c, 0x8c, 0x3c, 0xcc, 0xcc, 0xcc, 0xcc, 0xca, 0xbf, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xa9, 0xbf, 0xfb,
        0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xab, 0x3f, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xab, 0x3f, 0xfb, 0xb6, 0x7a,
        0xe8, 0x58, 0x4c, 0xa9, 0xbc, 0x8c, 0x3c, 0xcc, 0xcc, 0xcc, 0xcc, 0xcc, 0xbf, 0xfb, 0xb6, 0x7a, 0xe8, 0x58,
        0x4c, 0xab, 0xbf, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xaa, 0x3f, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xaa,
        0x3f, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xa9, 0xbc, 0xa5, 0x2d, 0x99, 0x99, 0x99, 0x99, 0x9a, 0xbf, 0xfb,
        0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xab, 0xbf, 0xfb, 0xb6, 0x7a, 0xe8, 0x58, 0x4c, 0xaa, 0xc0, 0x14, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0xbf, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x40, 0x08,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x03, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x02, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
        0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xc0, 0x08, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x01, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x3f, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x40, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x08,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x03, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x02, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
        0x40, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x08, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x01, 0x3f, 0xe0, 0xb3, 0x17, 0xb3, 0x8e, 0x9a, 0x9a, 0x40, 0x04, 0xa1, 0x15, 0xcf, 0x9d,
        0xa3, 0x56, 0x40, 0x06, 0x8e, 0x9f, 0x90, 0x1b, 0xac, 0xc3, 0x3f, 0xf4, 0x5f, 0x15, 0x0a, 0xbd, 0x1d, 0xd7,
        0xc0, 0x00, 0x5f, 0xf7, 0xd7, 0xbd, 0xfe, 0x90, 0xc0, 0x0a, 0xf1, 0x0d, 0x18, 0x85, 0xfb, 0xd0, 0xc0, 0x0a,
        0xa8, 0xa6, 0x19, 0x12, 0x5e, 0xdc, 0xbf, 0xf5, 0xe6, 0x13, 0x67, 0x45, 0xd0, 0x8c, 0xc0, 0x09, 0x7f, 0x08,
        0xc2, 0x31, 0xf5, 0x25, 0xc0, 0x0b, 0x4c, 0x51, 0xef, 0x67, 0x04, 0x17, 0x3f, 0xe0, 0xb3, 0x17, 0xb3, 0x8e,
        0x9a, 0x98, 0x40, 0x04, 0xa1, 0x15, 0xcf, 0x9d, 0xa3, 0x56, 0x40, 0x06, 0x8e, 0x9f, 0x90, 0x1b, 0xac, 0xc3,
        0x3f, 0xf4, 0x5f, 0x15, 0x0a, 0xbd, 0x1d, 0xd8, 0xc0, 0x00, 0x5f, 0xf7, 0xd7, 0xbd, 0xfe, 0x90, 0xc0, 0x0a,
        0xf1, 0x0d, 0x18, 0x85, 0xfb, 0xd0, 0xc0, 0x0a, 0xa8, 0xa6, 0x19, 0x12, 0x5e, 0xdc, 0xbf, 0xf5, 0xe6, 0x13,
        0x67, 0x45, 0xd0, 0x8d, 0xc0, 0x09, 0x7f, 0x08, 0xc2, 0x31, 0xf5, 0x25, 0xc0, 0x0b, 0x4c, 0x51, 0xef, 0x67,
        0x04, 0x17, 0x3f, 0xe0, 0xb3, 0x17, 0xb3, 0x8e, 0x9a, 0x9a, 0x40, 0x04, 0xa1, 0x15, 0xcf, 0x9d, 0xa3, 0x56,
        0x40, 0x06, 0x8e, 0x9f, 0x90, 0x1b, 0xac, 0xc3, 0x3f, 0xf4, 0x5f, 0x15, 0x0a, 0xbd, 0x1d, 0xd7, 0xc0, 0x00,
        0x5f, 0xf7, 0xd7, 0xbd, 0xfe, 0x90, 0xc0, 0x0a, 0xf1, 0x0d, 0x18, 0x85, 0xfb, 0xd0, 0xc0, 0x0a, 0xa8, 0xa6,
        0x19, 0x12, 0x5e, 0xdc, 0xbf, 0xf5, 0xe6, 0x13, 0x67, 0x45, 0xd0, 0x8c, 0xc0, 0x09, 0x7f, 0x08, 0xc2, 0x31,
        0xf5, 0x25, 0xc0, 0x0b, 0x4c, 0x51, 0xef, 0x67, 0x04, 0x17, 0x3f, 0xe0, 0xb3, 0x17, 0xb3, 0x8e, 0x9a, 0x9a,
        0x40, 0x04, 0xa1, 0x15, 0xcf, 0x9d, 0xa3, 0x56, 0x40, 0x06, 0x8e, 0x9f, 0x90, 0x1b, 0xac, 0xc3, 0x3f, 0xf4,
        0x5f, 0x15, 0x0a, 0xbd, 0x1d, 0xd7, 0xc0, 0x00, 0x5f, 0xf7, 0xd7, 0xbd, 0xfe, 0x90, 0xc0, 0x0a, 0xf1, 0x0d,
        0x18, 0x85, 0xfb, 0xd0, 0xc0, 0x0a, 0xa8, 0xa6, 0x19, 0x12, 0x5e, 0xdc, 0xbf, 0xf5, 0xe6, 0x13, 0x67, 0x45,
        0xd0, 0x8c, 0xc0, 0x09, 0x7f, 0x08, 0xc2, 0x31, 0xf5, 0x25, 0xc0, 0x0b, 0x4c, 0x51, 0xef, 0x67, 0x04, 0x17,
        0xc0, 0x0b, 0x4c, 0x51, 0xef, 0x67, 0x04, 0x17, 0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x14,
        0x40, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14,
        0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xbf, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
        0x40, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfd, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x07,
        0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00,
        0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xbf, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x07, 0xff, 0xff,
        0xff, 0xff, 0xff, 0xfe, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff,
        0xff, 0xff, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08,
        0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
        0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x07,
        0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x07, 0xff, 0xff,
        0xff, 0xff, 0xff, 0xff, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
        0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xbf, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff,
        0xff, 0xff, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
        0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x07,
        0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x14, 0x00, 0x00,
        0xff, 0xff, 0xff, 0xff, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x08, 0x00, 0x00,
        0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x3f, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x3f, 0xef,
        0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xef, 0xff, 0xff, 0xff, 0xff,
        0xff, 0xfe, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfd, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfd,
        0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xf0,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xf0, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xbf, 0xef, 0xff, 0xff, 0xff, 0xff,
        0xff, 0xff, 0xbf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
        0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x08,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x08, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0xc0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x43, 0x55, 0x42, 0x49, 0x54, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x39, 0x2e, 0x32, 0x62, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x31, 0x31, 0x2f, 0x32, 0x34, 0x2f, 0x32, 0x30, 0x30, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x31,
        0x32, 0x3a, 0x33, 0x34, 0x3a, 0x32, 0x35, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
        0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00,
        0x00, 0x08, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x0c,
        0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00,
        0x00, 0x11, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x15,
        0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0x17, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x19, 0x00, 0x00,
        0x00, 0x1a, 0x00, 0x00, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00, 0x00, 0x1e,
        0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x21, 0x00, 0x00, 0x00, 0x22, 0x00, 0x00,
        0x00, 0x23, 0x00, 0x00, 0x00, 0x24, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x00, 0x27,
        0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x29, 0x00, 0x00, 0x00, 0x2a, 0x00, 0x00, 0x00, 0x2b, 0x00, 0x00,
        0x00, 0x2c, 0x00, 0x00, 0x00, 0x2d, 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00, 0x00, 0x30,
        0x00, 0x00, 0x00, 0x31, 0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00,
        0x00, 0x35, 0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x00, 0x37, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x39,
        0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00,
        0x00, 0x3e, 0x00, 0x00, 0x00, 0x3f, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00, 0x00, 0x42,
        0x00, 0x00, 0x00, 0x43, 0x00, 0x00, 0x00, 0x44, 0x00, 0x00, 0x00, 0x45, 0x00, 0x00, 0x00, 0x46, 0x00, 0x00,
        0x00, 0x47, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00, 0x00, 0x49, 0x00, 0x00, 0x00, 0x4a, 0x00, 0x00, 0x00, 0x4b,
        0x00, 0x00, 0x00, 0x4c, 0x00, 0x00, 0x00, 0x4d, 0x00, 0x00, 0x00, 0x4e, 0x00, 0x00, 0x00, 0x4f, 0x00, 0x00,
        0x00, 0x50, 0x00, 0x00, 0x00, 0x51, 0x00, 0x00, 0x00, 0x52, 0x00, 0x00, 0x00, 0x53, 0x00, 0x00, 0x00, 0x54,
        0x00, 0x00, 0x00, 0x55, 0x00, 0x00, 0x00, 0x56, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0x58, 0x00, 0x00,
        0x00, 0x59, 0x00, 0x00, 0x00, 0x5a, 0x00, 0x00, 0x00, 0x5b, 0x00, 0x00, 0x00, 0x5c, 0x00, 0x00, 0x00, 0x5d,
        0x00, 0x00, 0x00, 0x5e, 0x00, 0x00, 0x00, 0x5f, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x61, 0x00, 0x00,
        0x00, 0x62, 0x00, 0x00, 0x00, 0x63, 0x00, 0x00, 0x00, 0x64, 0x00, 0x00, 0x00, 0x65, 0x00, 0x00, 0x00, 0x66,
        0x00, 0x00, 0x00, 0x67, 0x00, 0x00, 0x00, 0x68, 0x00, 0x00, 0x00, 0x69, 0x00, 0x00, 0x00, 0x6a, 0x00, 0x00,
        0x00, 0x6b, 0x00, 0x00, 0x00, 0x6c, 0x00, 0x00, 0x00, 0x6d, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00, 0x00, 0x6f,
        0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x71, 0x00, 0x00, 0x00, 0x72, 0x00, 0x00, 0x00, 0x73, 0x00, 0x00,
        0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x05,
        0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00,
        0x00, 0x0a, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x0e,
        0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00,
        0x00, 0x13, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0x17,
        0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x19, 0x00, 0x00, 0x00, 0x1a, 0x00, 0x00, 0x00, 0x1b, 0x00, 0x00,
        0x00, 0x1c, 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x20,
        0x00, 0x00, 0x00, 0x21, 0x00, 0x00, 0x00, 0x22, 0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00, 0x24, 0x00, 0x00,
        0x00, 0x25, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x29,
        0x00, 0x00, 0x00, 0x2a, 0x00, 0x00, 0x00, 0x2b, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0x2d, 0x00, 0x00,
        0x00, 0x2e, 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x31, 0x00, 0x00, 0x00, 0x32,
        0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x35, 0x00, 0x00, 0x00, 0x36, 0x00, 0x00,
        0x00, 0x37, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x39, 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x3b,
        0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x3f, 0x00, 0x00,
        0x00, 0x40, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x43, 0x00, 0x00, 0x00, 0x44,
        0x00, 0x00, 0x00, 0x45, 0x00, 0x00, 0x00, 0x46, 0x00, 0x00, 0x00, 0x47, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00,
        0x00, 0x49, 0x00, 0x00, 0x00, 0x4a, 0x00, 0x00, 0x00, 0x4b, 0x00, 0x00, 0x00, 0x4c, 0x00, 0x00, 0x00, 0x4d,
        0x00, 0x00, 0x00, 0x4e, 0x00, 0x00, 0x00, 0x4f, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x51, 0x00, 0x00,
        0x00, 0x52, 0x00, 0x00, 0x00, 0x53, 0x00, 0x00, 0x00, 0x54, 0x00, 0x00, 0x00, 0x55, 0x00, 0x00, 0x00, 0x56,
        0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0x58, 0x00, 0x00, 0x00, 0x59, 0x00, 0x00, 0x00, 0x5a, 0x00, 0x00,
        0x00, 0x5b, 0x00, 0x00, 0x00, 0x5c, 0x00, 0x00, 0x00, 0x5d, 0x00, 0x00, 0x00, 0x5e, 0x00, 0x00, 0x00, 0x5f,
        0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x61, 0x00, 0x00, 0x00, 0x62, 0x00, 0x00, 0x00, 0x63, 0x00, 0x00,
        0x00, 0x64, 0x00, 0x00, 0x00, 0x65, 0x00, 0x00, 0x00, 0x66, 0x00, 0x00, 0x00, 0x67, 0x00, 0x00, 0x00, 0x68,
        0x00, 0x00, 0x00, 0x69, 0x00, 0x00, 0x00, 0x6a, 0x00, 0x00, 0x00, 0x6b, 0x00, 0x00, 0x00, 0x6c, 0x00, 0x00,
        0x00, 0x6d, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00, 0x00, 0x6f, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x71,
        0x00, 0x00, 0x00, 0x72, 0x00, 0x00, 0x00, 0x73, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00,
        0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x07,
        0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00,
        0x00, 0x0c, 0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x10,
        0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00,
        0x00, 0x15, 0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0x17, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x19,
        0x00, 0x00, 0x00, 0x1a, 0x00, 0x00, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00,
        0x00, 0x1e, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x21, 0x00, 0x00, 0x00, 0x22,
        0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00, 0x24, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00,
        0x00, 0x27, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x29, 0x00, 0x00, 0x00, 0x2a, 0x00, 0x00, 0x00, 0x2b,
        0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0x2d, 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00,
        0x00, 0x30, 0x00, 0x00, 0x00, 0x31, 0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x00, 0x34,
        0x00, 0x00, 0x00, 0x35, 0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x00, 0x37, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00,
        0x00, 0x39, 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0x3d,
        0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x3f, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00,
        0x00, 0x42, 0x00, 0x00, 0x00, 0x43, 0x00, 0x00, 0x00, 0x44, 0x00, 0x00, 0x00, 0x45, 0x00, 0x00, 0x00, 0x46,
        0x00, 0x00, 0x00, 0x47, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00, 0x00, 0x49, 0x00, 0x00, 0x00, 0x4a, 0x00, 0x00,
        0x00, 0x4b, 0x00, 0x00, 0x00, 0x4c, 0x00, 0x00, 0x00, 0x4d, 0x00, 0x00, 0x00, 0x4e, 0x00, 0x00, 0x00, 0x4f,
        0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x51, 0x00, 0x00, 0x00, 0x52, 0x00, 0x00, 0x00, 0x53, 0x00, 0x00,
        0x00, 0x54, 0x00, 0x00, 0x00, 0x55, 0x00, 0x00, 0x00, 0x56, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0x58,
        0x00, 0x00, 0x00, 0x59, 0x00, 0x00, 0x00, 0x5a, 0x00, 0x00, 0x00, 0x5b, 0x00, 0x00, 0x00, 0x5c, 0x00, 0x00,
        0x00, 0x5d, 0x00, 0x00, 0x00, 0x5e, 0x00, 0x00, 0x00, 0x5f, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x61,
        0x00, 0x00, 0x00, 0x62, 0x00, 0x00, 0x00, 0x63, 0x00, 0x00, 0x00, 0x64, 0x00, 0x00, 0x00, 0x65, 0x00, 0x00,
        0x00, 0x66, 0x00, 0x00, 0x00, 0x67, 0x00, 0x00, 0x00, 0x68, 0x00, 0x00, 0x00, 0x69, 0x00, 0x00, 0x00, 0x6a,
        0x00, 0x00, 0x00, 0x6b, 0x00, 0x00, 0x00, 0x6c, 0x00, 0x00, 0x00, 0x6d, 0x00, 0x00, 0x00, 0x6e, 0x00, 0x00,
        0x00, 0x6f, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x71, 0x00, 0x00, 0x00, 0x72, 0x00, 0x00, 0x00, 0x73,
        0x00, 0x00, 0x00, 0x74, 0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0x76, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00,
        0x00, 0x78, 0x00, 0x00, 0x00, 0x79, 0x00, 0x00, 0x00, 0x7a, 0x00, 0x00, 0x00, 0x7b, 0x00, 0x00, 0x00, 0x7c,
        0x00, 0x00, 0x00, 0x7d, 0x00, 0x00, 0x00, 0x7e, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00,
        0x00, 0x81, 0x00, 0x00, 0x00, 0x82, 0x00, 0x00, 0x00, 0x83, 0x00, 0x00, 0x00, 0x84, 0x00, 0x00, 0x00, 0x85,
        0x00, 0x00, 0x00, 0x86, 0x00, 0x00, 0x00, 0x87, 0x00, 0x00, 0x00, 0x88, 0x00, 0x00, 0x00, 0x89, 0x00, 0x00,
        0x00, 0x8a, 0x00, 0x00, 0x00, 0x8b, 0x00, 0x00, 0x00, 0x8c, 0x00, 0x00, 0x00, 0x8d, 0x00, 0x00, 0x00, 0x8e,
        0x00, 0x00, 0x00, 0x8f, 0x00, 0x00, 0x00, 0x90, 0x00, 0x00, 0x00, 0x91, 0x00, 0x00, 0x00, 0x92, 0x00, 0x00,
        0x00, 0x93, 0x00, 0x00, 0x00, 0x94, 0x00, 0x00, 0x00, 0x95, 0x00, 0x00, 0x00, 0x96, 0x00, 0x00, 0x00, 0x97,
        0x00, 0x00, 0x00, 0x98, 0x00, 0x00, 0x00, 0x99, 0x00, 0x00, 0x00, 0x9a, 0x00, 0x00, 0x00, 0x9b, 0x00, 0x00,
        0x00, 0x9c, 0x00, 0x00, 0x00, 0x9d, 0x00, 0x00, 0x00, 0x9e, 0x00, 0x00, 0x00, 0x9f, 0x00, 0x00, 0x00, 0xa0,
        0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0xa2, 0x00, 0x00, 0x00, 0xa3, 0x00, 0x00, 0x00, 0xa4, 0x00, 0x00,
        0x00, 0xa5, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0xa7, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x00, 0xa9,
        0x00, 0x00, 0x00, 0xaa, 0x00, 0x00, 0x00, 0xab, 0x00, 0x00, 0x00, 0xac, 0x00, 0x00, 0x00, 0xad, 0x00, 0x00,
        0x00, 0xae, 0x00, 0x00, 0x00, 0xaf, 0x00, 0x00, 0x00, 0xb0, 0x00, 0x00, 0x00, 0xb1, 0x00, 0x00, 0x00, 0xb2,
        0x00, 0x00, 0x00, 0xb3, 0x00, 0x00, 0x00, 0xb4, 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0xb6, 0x00, 0x00,
        0x00, 0xb7, 0x00, 0x00, 0x00, 0xb8, 0x00, 0x00, 0x00, 0xb9, 0x00, 0x00, 0x00, 0xba, 0x00, 0x00, 0x00, 0xbb,
        0x00, 0x00, 0x00, 0xbc, 0x00, 0x00, 0x00, 0xbd, 0x00, 0x00, 0x00, 0xbe, 0x00, 0x00, 0x00, 0xbf, 0x00, 0x00,
        0x00, 0xc0, 0x00, 0x00, 0x00, 0xc1, 0x00, 0x00, 0x00, 0xc2, 0x00, 0x00, 0x00, 0xc3, 0x00, 0x00, 0x00, 0xc4,
        0x00, 0x00, 0x00, 0xc5, 0x00, 0x00, 0x00, 0xc6, 0x00, 0x00, 0x00, 0xc7, 0x00, 0x00, 0x00, 0xc8, 0x00, 0x00,
        0x00, 0xc9, 0x00, 0x00, 0x00, 0xca, 0x00, 0x00, 0x00, 0xcb, 0x00, 0x00, 0x00, 0xcc, 0x00, 0x00, 0x00, 0xcd,
        0x00, 0x00, 0x00, 0xce, 0x00, 0x00, 0x00, 0xcf, 0x00, 0x00, 0x00, 0xd0, 0x00, 0x00, 0x00, 0xd1, 0x00, 0x00,
        0x00, 0xd2, 0x00, 0x00, 0x00, 0xd3, 0x00, 0x00, 0x00, 0xd4, 0x00, 0x00, 0x00, 0xd5, 0x00, 0x00, 0x00, 0xd6,
        0x00, 0x00, 0x00, 0xd7, 0x00, 0x00, 0x00, 0xd8 };
    FILE* file = fopen( filename, "w" );
    if( !file ) return false;
    size_t rval = fwrite( binary_data, sizeof( binary_data ), 1, file );
    fclose( file );
    return rval == 1;
