FBiGeom_MOAB.cpp File Reference
#include <iostream>
#include <map>
#include "FBiGeom_MOAB.hpp"
#include "moab/GeomTopoTool.hpp"
#include "moab/OrientedBoxTreeTool.hpp"
#include "moab/CartVect.hpp"
#include "moab/FileOptions.hpp"
#include "MBTagConventions.hpp"
#include <cstdlib>
#include <cstring>
#include <cassert>
+ Include dependency graph for FBiGeom_MOAB.cpp:
Defines
#define COPY_RANGE(r, vec)
#define TAG_HANDLE(tagh)   reinterpret_cast< Tag >( tagh )
#define COPY_DOUBLEVEC(r, vec)
Functions
static int compare_no_case1 (const char *str1, const char *str2, size_t n)
static std::string filter_options1 (const char *begin, const char *end)
void FBiGeom_getDescription (FBiGeom_Instance instance, char *descr, int descr_len)
 Get a description of the error returned from the last FBiGeom call.
void FBiGeom_getErrorType (FBiGeom_Instance instance, int *error_type)
 Get the error type returned from the last FBiGeom function.
void FBiGeom_newGeom (char const *options, FBiGeom_Instance *instance_out, int *err, int options_len)
 Construct a new FBiGeom instance.
void FBiGeom_dtor (FBiGeom_Instance instance, int *err)
void FBiGeom_newGeomFromMesh (iMesh_Instance mesh, iBase_EntitySetHandle set, const char *options, FBiGeom_Instance *geom, int *err, int)
void FBiGeom_dtor2 (FBiGeom_Instance instance, int *err)
void FBiGeom_load (FBiGeom_Instance instance, char const *name, char const *options, int *err, int, int options_len)
 Load a geom from a file.
void FBiGeom_save (FBiGeom_Instance instance, char const *name, char const *options, int *err, int name_len, int options_len)
 Save a geom to a file.
void FBiGeom_getRootSet (FBiGeom_Instance instance, iBase_EntitySetHandle *root_set, int *err)
 Get handle of the root set for this instance.
void FBiGeom_getBoundBox (FBiGeom_Instance instance, double *, double *, double *, double *, double *, double *, int *err)
 Get the bounding box of the entire model.
void FBiGeom_getEntities (FBiGeom_Instance instance, iBase_EntitySetHandle set_handle, int entity_type, iBase_EntityHandle **entity_handles, int *entity_handles_allocated, int *entity_handles_size, int *err)
 Get entities of specific type in set or instance.
void FBiGeom_getNumOfType (FBiGeom_Instance instance, iBase_EntitySetHandle set_handle, int entity_type, int *num_out, int *err)
 Get the number of entities with the specified type in the instance or set.
void FBiGeom_getEntType (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, int *type, int *err)
 Get the entity type for the specified entity.
void FBiGeom_getArrType (FBiGeom_Instance instance, iBase_EntityHandle const *entity_handles, int entity_handles_size, int **type, int *type_allocated, int *type_size, int *err)
 Get the entity type for the specified entities.
void FBiGeom_getEntAdj (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, int to_dimension, iBase_EntityHandle **adj_entities, int *adj_entities_allocated, int *adj_entities_size, int *err)
 Get entities of specified type adjacent to an entity.
void FBiGeom_getArrAdj (FBiGeom_Instance instance, iBase_EntityHandle const *entity_handles, int entity_handles_size, int requested_entity_type, iBase_EntityHandle **adj_entity_handles, int *adj_entity_handles_allocated, int *adj_entity_handles_size, int **offset, int *offset_allocated, int *offset_size, int *err)
 Get entities of specified type adjacent to entities.
void FBiGeom_getEnt2ndAdj (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, int bridge_dimension, int to_dimension, iBase_EntityHandle **adjacent_entities, int *adjacent_entities_allocated, int *adjacent_entities_size, int *err)
 Get "2nd order" adjacencies to an entity.
void FBiGeom_getArr2ndAdj (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, int, iBase_EntityHandle **, int *, int *, int **, int *, int *, int *err)
 Get "2nd order" adjacencies to an array of entities.
void FBiGeom_isEntAdj (FBiGeom_Instance instance, iBase_EntityHandle entity_handle1, iBase_EntityHandle entity_handle2, int *are_adjacent, int *err)
 Return whether two entities are adjacent.
void FBiGeom_isArrAdj (FBiGeom_Instance instance, iBase_EntityHandle const *entity_handles_1, int entity_handles_1_size, iBase_EntityHandle const *entity_handles_2, int entity_handles_2_size, int **is_adjacent_info, int *is_adjacent_info_allocated, int *is_adjacent_info_size, int *err)
 Return whether entity pairs are adjacent.
void FBiGeom_getEntClosestPt (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, double near_x, double near_y, double near_z, double *on_x, double *on_y, double *on_z, int *err)
 Get closest point to an entity.
void FBiGeom_getArrClosestPt (FBiGeom_Instance instance, iBase_EntityHandle const *entity_handles, int entity_handles_size, int storage_order, double const *near_coordinates, int near_coordinates_size, double **on_coordinates, int *on_coordinates_allocated, int *on_coordinates_size, int *err)
 Get closest point for an array of entities and points For surfaces, it made sure the closest point in on surface. Get closest point for an array of entities and points. If either the number of entities or number of coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
void FBiGeom_getEntNrmlXYZ (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, double x, double y, double z, double *nrml_i, double *nrml_j, double *nrml_k, int *err)
 Get the normal vector on an entity at the given position Get the normal vector on an entity at the given position.
void FBiGeom_getArrNrmlXYZ (FBiGeom_Instance instance, iBase_EntityHandle const *entity_handles, int entity_handles_size, int storage_order, double const *coordinates, int coordinates_size, double **normals, int *normals_allocated, int *normals_size, int *err)
 Get the normal vector on an entity(ies) at given position(s)
void FBiGeom_getEntNrmlPlXYZ (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, double x, double y, double z, double *pt_x, double *pt_y, double *pt_z, double *nrml_i, double *nrml_j, double *nrml_k, int *err)
 Get the normal vector AND closest point on an entity at given position.
void FBiGeom_getArrNrmlPlXYZ (FBiGeom_Instance instance, iBase_EntityHandle const *entity_handles, int entity_handles_size, int storage_order, double const *near_coordinates, int near_coordinates_size, double **on_coordinates, int *on_coordinates_allocated, int *on_coordinates_size, double **normals, int *normals_allocated, int *normals_size, int *err)
 Get the normal vector AND closest point on an entity(ies) at given position(s)
void FBiGeom_getEntTgntXYZ (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double *, double *, double *, int *err)
 Get the tangent vector on an entity at given position.
void FBiGeom_getArrTgntXYZ (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, int *err)
 Get the tangent vector on an entity(ies) at given position(s)
void FBiGeom_getEntBoundBox (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, double *min_x, double *min_y, double *min_z, double *max_x, double *max_y, double *max_z, int *err)
 Get the bounding box of the specified entity.
void FBiGeom_getArrBoundBox (FBiGeom_Instance instance, iBase_EntityHandle const *entity_handles, int entity_handles_size, int storage_order, double **min_corner, int *min_corner_allocated, int *min_corner_size, double **max_corner, int *max_corner_allocated, int *max_corner_size, int *err)
 Get the bounding box of the specified entities.
void FBiGeom_getVtxCoord (FBiGeom_Instance instance, iBase_EntityHandle vertex_handle, double *x, double *y, double *z, int *err)
 Get coordinates of specified vertex.
void FBiGeom_getVtxArrCoords (FBiGeom_Instance instance, iBase_EntityHandle const *entity_handles, int entity_handles_size, int storage_order, double **coordinates, int *coordinates_allocated, int *coordinates_size, int *err)
 Get coordinates of specified vertices.
void FBiGeom_getPntRayIntsct (FBiGeom_Instance instance, double x, double y, double z, double dir_x, double dir_y, double dir_z, iBase_EntityHandle **intersect_entity_handles, int *intersect_entity_handles_allocated, int *intersect_entity_handles_size, int storage_order, double **intersect_coords, int *intersect_coords_allocated, int *intersect_coords_size, double **param_coords, int *param_coords_allocated, int *param_coords_size, int *err)
 Intersect a ray with the model.
void FBiGeom_getPntArrRayIntsct (FBiGeom_Instance instance, int, const double *, int, const double *, int, iBase_EntityHandle **, int *, int *, int **, int *, int *, double **, int *, int *, double **, int *, int *, int *err)
 Intersect an array of rays with the model.
void FBiGeom_getEntNrmlSense (FBiGeom_Instance instance, iBase_EntityHandle face, iBase_EntityHandle region, int *sense_out, int *err)
 Get the sense of a face with respect to a region.
void FBiGeom_getArrNrmlSense (FBiGeom_Instance instance, iBase_EntityHandle const *, int, iBase_EntityHandle const *, int, int **, int *, int *, int *err)
 Get the senses of an array of faces with respect to an array of regions.
void FBiGeom_getEgFcSense (FBiGeom_Instance instance, iBase_EntityHandle edge, iBase_EntityHandle face, int *sense_out, int *err)
 Get the sense of an edge with respect to a face Get the sense of an edge with respect to a face. Sense returned is -1, 0, or 1, representing "reversed", "both", or "forward". "both" sense indicates that edge bounds the face once with each sense.
void FBiGeom_getEgFcArrSense (FBiGeom_Instance instance, iBase_EntityHandle const *, int, iBase_EntityHandle const *, int, int **, int *, int *, int *err)
 Get the senses of an array of edges with respect to an array of faces.
void FBiGeom_getEgVtxSense (FBiGeom_Instance instance, iBase_EntityHandle edge, iBase_EntityHandle vertex1, iBase_EntityHandle vertex2, int *sense_out, int *err)
 Get the sense of a vertex pair with respect to an edge.
void FBiGeom_getEgVtxArrSense (FBiGeom_Instance instance, iBase_EntityHandle const *, int, iBase_EntityHandle const *, int, iBase_EntityHandle const *, int, int **, int *, int *, int *err)
 Get the senses of vertex pair with respect to a edges.
void FBiGeom_measure (FBiGeom_Instance instance, iBase_EntityHandle const *entity_handles, int entity_handles_size, double **measures, int *measures_allocated, int *measures_size, int *err)
 Return the measure (length, area, or volume) of entities.
void FBiGeom_getFaceType (FBiGeom_Instance instance, iBase_EntityHandle, char *face_type, int *err, int *face_type_length)
 Get the geometric type of a face.
void FBiGeom_getParametric (FBiGeom_Instance instance, int *is_parametric, int *err)
 Return whether interface has information about parameterization.
void FBiGeom_isEntParametric (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, int *parametric, int *err)
 Return whether an entity has a parameterization.
void FBiGeom_isArrParametric (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int **, int *, int *, int *err)
 Return whether entities have parameterizations.
void FBiGeom_getEntUVtoXYZ (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double *, double *, double *, int *err)
 Return coordinate position at specified parametric position on entity.
void FBiGeom_getArrUVtoXYZ (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, int *err)
 Return coordinate positions at specified parametric position(s) on entity(ies)
void FBiGeom_getEntUtoXYZ (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, double u, double *x, double *y, double *z, int *err)
void FBiGeom_getArrUtoXYZ (FBiGeom_Instance instance, iBase_EntityHandle const *, int, double const *, int, int, double **, int *, int *, int *err)
void FBiGeom_getEntXYZtoUV (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double *, double *, int *err)
 Return parametric position at specified spatial position on entity.
void FBiGeom_getEntXYZtoU (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double *, int *err)
void FBiGeom_getArrXYZtoUV (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, int *err)
 Return parametric positions at specified spatial position(s) on entity(ies) Return parametric positions at specified spatial position(s) on entity(ies). If either the number of entities or number of spatial coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
void FBiGeom_getArrXYZtoU (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, int *err)
 Return spatial positions at specified parametric position(s) on entity(ies)
void FBiGeom_getEntXYZtoUVHint (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double *, double *, int *err)
 Return parametric position at specified spatial position on entity, based on parametric position hint.
void FBiGeom_getArrXYZtoUVHint (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, int *err)
 Return parametric positions at specified spatial position(s) on entity(ies), based on parametric position hints Return parametric positions at specified spatial position(s) on entity(ies), based on parametric position hints. If either the number of entities or number of spatial coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
void FBiGeom_getEntUVRange (FBiGeom_Instance instance, iBase_EntityHandle, double *, double *, double *, double *, int *err)
 Get parametric range of entity.
void FBiGeom_getEntURange (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, double *u_min, double *u_max, int *err)
void FBiGeom_getArrUVRange (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double **, int *, int *, double **, int *, int *, int *err)
 Get parametric range of entities.
void FBiGeom_getArrURange (FBiGeom_Instance instance, iBase_EntityHandle const *, int, double **, int *, int *, double **, int *, int *, int *err)
void FBiGeom_getEntUtoUV (FBiGeom_Instance instance, iBase_EntityHandle, iBase_EntityHandle, double, double *, double *, int *err)
 Return the face parametric coordinates for a parametric position on a bounding edge.
void FBiGeom_getVtxToUV (FBiGeom_Instance instance, iBase_EntityHandle, iBase_EntityHandle, double *, double *, int *err)
 Return parametric coordinates on face of vertex position.
void FBiGeom_getVtxToU (FBiGeom_Instance instance, iBase_EntityHandle, iBase_EntityHandle, double *, int *err)
 Return parametric coordinates on edge of vertex position.
void FBiGeom_getArrUtoUV (FBiGeom_Instance instance, iBase_EntityHandle const *, int, iBase_EntityHandle const *, int, double const *, int, int, double **, int *, int *, int *err)
 Return the face parametric coordinates for a parametric position on bounding edges.
void FBiGeom_getVtxArrToUV (FBiGeom_Instance instance, iBase_EntityHandle const *, int, iBase_EntityHandle const *, int, int, double **, int *, int *, int *err)
 Return parametric coordinates on faces of vertex positions.
void FBiGeom_getVtxArrToU (FBiGeom_Instance instance, iBase_EntityHandle const *, int, iBase_EntityHandle const *, int, double **, int *, int *, int *err)
 Return parametric coordinates on edges of vertex positions.
void FBiGeom_getEntNrmlUV (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double *, double *, double *, int *err)
 Return the normal at a specified parametric position.
void FBiGeom_getArrNrmlUV (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, int *err)
 Return the normals at specified parametric positions.
void FBiGeom_getEntTgntU (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, double u, double *tgnt_i, double *tgnt_j, double *tgnt_k, int *err)
 Return the tangent at a specified parametric position.
void FBiGeom_getArrTgntU (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, int *err)
 Return the tangents at specified parametric positions.
void FBiGeom_getEnt1stDrvt (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double **, int *, int *, double **, int *, int *, int *err)
 Get the first derivative of a face at specified parametric position.
void FBiGeom_getArr1stDrvt (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, int **, int *, int *, double **, int *, int *, int **, int *, int *, int *err)
 Get the first derivatives of faces at specified parametric positions.
void FBiGeom_getEnt2ndDrvt (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double **, int *, int *, double **, int *, int *, double **, int *, int *, int *err)
 Get the second derivative of a face at specified parametric position.
void FBiGeom_getArr2ndDrvt (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, int **, int *, int *, double **, int *, int *, int **, int *, int *, double **, int *, int *, int **, int *, int *, int *err)
 Get the second derivatives of faces at specified parametric positions.
void FBiGeom_getFcCvtrUV (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double *, double *, double *, double *, double *, double *, int *err)
 Get the two principle curvature vectors for a face at a parametric position.
void FBiGeom_getFcArrCvtrUV (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, double **, int *, int *, int *err)
 Get the curvature(s) on face(s) at given parametric position(s)
void FBiGeom_isEntPeriodic (FBiGeom_Instance, iBase_EntityHandle, int *in_u, int *in_v, int *err)
 Return whether an entity is periodic.
void FBiGeom_isArrPeriodic (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int **, int *, int *, int *err)
 Return whether entities are periodic.
void FBiGeom_isFcDegenerate (FBiGeom_Instance instance, iBase_EntityHandle, int *, int *err)
 Return whether a face is degenerate.
void FBiGeom_isFcArrDegenerate (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int **, int *, int *, int *err)
 Return whether faces are degenerate.
void FBiGeom_initEntIter (FBiGeom_Instance instance, iBase_EntitySetHandle, int, iBase_EntityIterator *, int *err)
 Initialize an iterator over specified entity type.
void FBiGeom_initEntArrIter (FBiGeom_Instance instance, iBase_EntitySetHandle, int, int, iBase_EntityArrIterator *, int *err)
 Initialize an array iterator over specified entity type and size.
void FBiGeom_getNextEntIter (FBiGeom_Instance instance, iBase_EntityIterator, iBase_EntityHandle *, int *, int *err)
 Get entity corresponding to an iterator and increment iterator.
void FBiGeom_getNextEntArrIter (FBiGeom_Instance instance, iBase_EntityArrIterator, iBase_EntityHandle **, int *, int *, int *, int *err)
 Get entities contained in array iterator and increment iterator.
void FBiGeom_resetEntIter (FBiGeom_Instance instance, iBase_EntityIterator, int *err)
 Reset the iterator.
void FBiGeom_resetEntArrIter (FBiGeom_Instance instance, iBase_EntityArrIterator, int *err)
 Reset the array iterator.
void FBiGeom_endEntIter (FBiGeom_Instance instance, iBase_EntityIterator, int *err)
 Destroy the specified iterator.
void FBiGeom_endEntArrIter (FBiGeom_Instance instance, iBase_EntityArrIterator, int *err)
 Destroy the specified array iterator.
void FBiGeom_copyEnt (FBiGeom_Instance instance, iBase_EntityHandle, iBase_EntityHandle *, int *err)
 Make a copy of the specified entity.
void FBiGeom_sweepEntAboutAxis (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double, iBase_EntityHandle *, int *err)
 Sweep (extrude) an entity about an axis.
void FBiGeom_deleteAll (FBiGeom_Instance instance, int *err)
 Delete all entities and sets.
void FBiGeom_deleteEnt (FBiGeom_Instance instance, iBase_EntityHandle, int *err)
 Delete specified entity.
void FBiGeom_createSphere (FBiGeom_Instance instance, double, iBase_EntityHandle *, int *err)
 Create a sphere.
void FBiGeom_createPrism (FBiGeom_Instance instance, double, int, double, double, iBase_EntityHandle *, int *err)
 Create a prism.
void FBiGeom_createBrick (FBiGeom_Instance instance, double, double, double, iBase_EntityHandle *, int *err)
 Create an axis-oriented box.
void FBiGeom_createCylinder (FBiGeom_Instance instance, double, double, double, iBase_EntityHandle *, int *err)
 Create a cylinder.
void FBiGeom_createCone (FBiGeom_Instance instance, double, double, double, double, iBase_EntityHandle *, int *err)
 Create a cone or tapered cylinder.
void FBiGeom_createTorus (FBiGeom_Instance instance, double, double, iBase_EntityHandle *, int *err)
 Create a torus.
void FBiGeom_moveEnt (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, int *err)
 Move an entity by the given vector.
void FBiGeom_rotateEnt (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double, int *err)
 Rotate an entity about an axis.
void FBiGeom_reflectEnt (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double, double, double, int *err)
 Reflect an entity across a plane.
void FBiGeom_scaleEnt (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double, double, double, int *err)
 Scale an entity in the x, y, and z directions.
void FBiGeom_uniteEnts (FBiGeom_Instance instance, iBase_EntityHandle const *, int, iBase_EntityHandle *, int *err)
 Geometrically unite entities.
void FBiGeom_subtractEnts (FBiGeom_Instance instance, iBase_EntityHandle, iBase_EntityHandle, iBase_EntityHandle *, int *err)
 Geometrically subtract one entity from another.
void FBiGeom_intersectEnts (FBiGeom_Instance instance, iBase_EntityHandle, iBase_EntityHandle, iBase_EntityHandle *, int *err)
 Geometrically intersect a pair of entities.
void FBiGeom_sectionEnt (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double, int, iBase_EntityHandle *, int *err)
 Section (cut) a region with a plane.
void FBiGeom_imprintEnts (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int *err)
 Imprint entities.
void FBiGeom_mergeEnts (FBiGeom_Instance instance, iBase_EntityHandle const *, int, double, int *err)
 Merge ents.
void FBiGeom_createEntSet (FBiGeom_Instance instance, int isList, iBase_EntitySetHandle *entity_set_created, int *err)
 Create an entity set.
void FBiGeom_destroyEntSet (FBiGeom_Instance instance, iBase_EntitySetHandle, int *err)
 Destroy an entity set.
void FBiGeom_isList (FBiGeom_Instance instance, iBase_EntitySetHandle, int *, int *err)
 Return whether a specified set is ordered or unordered.
void FBiGeom_getNumEntSets (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set_handle, int, int *num_sets, int *err)
 Get the number of entity sets contained in a set or interface.
void FBiGeom_getEntSets (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set_handle, int, iBase_EntitySetHandle **contained_set_handles, int *contained_set_handles_allocated, int *contained_set_handles_size, int *err)
 Get the entity sets contained in a set or interface.
void FBiGeom_addEntToSet (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_EntitySetHandle entity_set, int *err)
 Add an entity to a set.
void FBiGeom_rmvEntFromSet (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_EntitySetHandle entity_set, int *err)
 Remove an entity from a set.
void FBiGeom_addEntArrToSet (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_EntitySetHandle entity_set, int *err)
 Add an array of entities to a set.
void FBiGeom_rmvEntArrFromSet (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_EntitySetHandle entity_set, int *err)
 Remove an array of entities from a set.
void FBiGeom_addEntSet (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set_to_add, iBase_EntitySetHandle entity_set_handle, int *err)
 Add an entity set to a set.
void FBiGeom_rmvEntSet (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set_to_remove, iBase_EntitySetHandle entity_set_handle, int *err)
 Remove an entity set from a set.
void FBiGeom_isEntContained (FBiGeom_Instance instance, iBase_EntitySetHandle containing_entity_set, iBase_EntityHandle contained_entity, int *is_contained, int *err)
 Return whether an entity is contained in another set.
void FBiGeom_isEntArrContained (FBiGeom_Instance instance, iBase_EntitySetHandle containing_set, const iBase_EntityHandle *entity_handles, int num_entity_handles, int **is_contained, int *is_contained_allocated, int *is_contained_size, int *err)
 Return whether entities are contained in a set.
void FBiGeom_isEntSetContained (FBiGeom_Instance instance, iBase_EntitySetHandle containing_entity_set, iBase_EntitySetHandle contained_entity_set, int *is_contained, int *err)
 Return whether an entity set is contained in another set.
void FBiGeom_addPrntChld (FBiGeom_Instance instance, iBase_EntitySetHandle parent_entity_set, iBase_EntitySetHandle child_entity_set, int *err)
 Add parent/child links between two sets.
void FBiGeom_rmvPrntChld (FBiGeom_Instance instance, iBase_EntitySetHandle parent_entity_set, iBase_EntitySetHandle child_entity_set, int *err)
 Remove parent/child links between two sets.
void FBiGeom_isChildOf (FBiGeom_Instance instance, iBase_EntitySetHandle parent_entity_set, iBase_EntitySetHandle child_entity_set, int *is_child, int *err)
 Return whether two sets are related by parent/child links.
void FBiGeom_getNumChld (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, int num_hops, int *num_child, int *err)
 Get the number of child sets linked from a specified set.
void FBiGeom_getNumPrnt (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, int num_hops, int *num_parent, int *err)
 Get the number of parent sets linked from a specified set.
void FBiGeom_getChldn (FBiGeom_Instance instance, iBase_EntitySetHandle from_entity_set, int num_hops, iBase_EntitySetHandle **entity_set_handles, int *entity_set_handles_allocated, int *entity_set_handles_size, int *err)
 Get the child sets linked from a specified set.
void FBiGeom_getPrnts (FBiGeom_Instance instance, iBase_EntitySetHandle from_entity_set, int num_hops, iBase_EntitySetHandle **entity_set_handles, int *entity_set_handles_allocated, int *entity_set_handles_size, int *err)
 Get the parent sets linked from a specified set.
void FBiGeom_createTag (FBiGeom_Instance instance, const char *tag_name, int tag_size, int tag_type, iBase_TagHandle *tag_handle, int *err, int tag_name_len)
 Create a tag with specified name, size, and type.
void FBiGeom_destroyTag (FBiGeom_Instance instance, iBase_TagHandle tag_handle, int, int *err)
 Destroy a tag.
void FBiGeom_getTagName (FBiGeom_Instance instance, iBase_TagHandle tag_handle, char *name, int *err, int name_len)
 Get the name for a given tag handle.
void FBiGeom_getTagSizeValues (FBiGeom_Instance instance, iBase_TagHandle tag_handle, int *tag_size, int *err)
 Get size of a tag in units of numbers of tag data type.
void FBiGeom_getTagSizeBytes (FBiGeom_Instance instance, iBase_TagHandle tag_handle, int *tag_size, int *err)
 Get size of a tag in units of bytes.
void FBiGeom_getTagHandle (FBiGeom_Instance instance, const char *tag_name, iBase_TagHandle *tag_handle, int *err, int tag_name_len)
 Get a the handle of an existing tag with the specified name.
void FBiGeom_getTagType (FBiGeom_Instance instance, iBase_TagHandle tag_handle, int *tag_type, int *err)
 Get the data type of the specified tag handle.
void FBiGeom_setEntSetData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set_handle, iBase_TagHandle tag_handle, const void *tag_value, int tag_value_size, int *err)
 Set a tag value of arbitrary type on an entity set.
void FBiGeom_setEntSetIntData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, iBase_TagHandle tag_handle, int tag_value, int *err)
 Set a tag value of integer type on an entity set.
void FBiGeom_setEntSetDblData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, iBase_TagHandle tag_handle, double tag_value, int *err)
 Set a tag value of double type on an entity set.
void FBiGeom_setEntSetEHData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, iBase_TagHandle tag_handle, iBase_EntityHandle tag_value, int *err)
 Set a tag value of entity handle type on an entity set.
void FBiGeom_setEntSetESHData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, iBase_TagHandle tag_handle, iBase_EntitySetHandle tag_value, int *err)
 Set a tag value of entity set handle type on an entity set.
void FBiGeom_getEntSetData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set_handle, iBase_TagHandle tag_handle, void **tag_value, int *tag_value_allocated, int *tag_value_size, int *err)
 Get the value of a tag of arbitrary type on an entity set.
void FBiGeom_getEntSetIntData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, iBase_TagHandle tag_handle, int *out_data, int *err)
 Get the value of a tag of integer type on an entity set.
void FBiGeom_getEntSetDblData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, iBase_TagHandle tag_handle, double *out_data, int *err)
 Get the value of a tag of double type on an entity set.
void FBiGeom_getEntSetEHData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, iBase_TagHandle tag_handle, iBase_EntityHandle *out_data, int *err)
 Get the value of a tag of entity handle type on an entity set.
void FBiGeom_getEntSetESHData (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set, iBase_TagHandle tag_handle, iBase_EntitySetHandle *out_data, int *err)
 Get the value of a tag of entity set handle type on an entity set.
void FBiGeom_getAllEntSetTags (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set_handle, iBase_TagHandle **tag_handles, int *tag_handles_allocated, int *tag_handles_size, int *err)
 Get all the tags associated with a specified entity set.
void FBiGeom_rmvEntSetTag (FBiGeom_Instance instance, iBase_EntitySetHandle entity_set_handle, iBase_TagHandle tag_handle, int *err)
 Remove a tag value from an entity set.
void FBiGeom_getArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, void **tag_values, int *tag_values_allocated, int *tag_values_size, int *err)
 Get tag values of arbitrary type for an array of entities.
void FBiGeom_getIntArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, int **tag_values, int *tag_values_allocated, int *tag_values_size, int *err)
 Get tag values of integer type for an array of entities.
void FBiGeom_getDblArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, double **tag_values, int *tag_values_allocated, int *tag_values_size, int *err)
 Get tag values of double type for an array of entities.
void FBiGeom_getEHArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, iBase_EntityHandle **tag_value, int *tag_value_allocated, int *tag_value_size, int *err)
 Get tag values of entity handle type for an array of entities.
void FBiGeom_getESHArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, iBase_EntitySetHandle **tag_value, int *tag_value_allocated, int *tag_value_size, int *err)
 Get tag values of entity set handle type for an array of entities.
void FBiGeom_setArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, const void *tag_values, int tag_values_size, int *err)
 Set tag values of arbitrary type on an array of entities.
void FBiGeom_setIntArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, const int *tag_values, int tag_values_size, int *err)
 Set tag values of integer type on an array of entities.
void FBiGeom_setDblArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, const double *tag_values, const int tag_values_size, int *err)
 Set tag values of double type on an array of entities.
void FBiGeom_setEHArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, const iBase_EntityHandle *tag_values, int tag_values_size, int *err)
 Set tag values of entity handle type on an array of entities.
void FBiGeom_setESHArrData (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, const iBase_EntitySetHandle *tag_values, int tag_values_size, int *err)
 Set tag values of entity set handle type on an array of entities.
void FBiGeom_rmvArrTag (FBiGeom_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_TagHandle tag_handle, int *err)
 Remove a tag value from an array of entities.
void FBiGeom_getData (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, void **tag_value, int *tag_value_allocated, int *tag_value_size, int *err)
 Get the value of a tag of arbitrary type on an entity.
void FBiGeom_getIntData (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, int *out_data, int *err)
 Get the value of a tag of integer type on an entity.
void FBiGeom_getDblData (FBiGeom_Instance instance, const iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, double *out_data, int *err)
 Get the value of a tag of double type on an entity.
void FBiGeom_getEHData (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, iBase_EntityHandle *out_data, int *err)
 Get the value of a tag of entity handle type on an entity.
void FBiGeom_getESHData (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, iBase_EntitySetHandle *out_data, int *err)
 Get the value of a tag of entity set handle type on an entity.
void FBiGeom_setData (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, const void *tag_value, int tag_value_size, int *err)
 Set a tag value of arbitrary type on an entity.
void FBiGeom_setIntData (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, int tag_value, int *err)
 Set a tag value of integer type on an entity.
void FBiGeom_setDblData (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, double tag_value, int *err)
 Set a tag value of double type on an entity.
void FBiGeom_setEHData (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, iBase_EntityHandle tag_value, int *err)
 Set a tag value of entity handle type on an entity.
void FBiGeom_setESHData (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, iBase_EntitySetHandle tag_value, int *err)
 Set a tag value of entity set handle type on an entity.
void FBiGeom_getAllTags (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle **tag_handles, int *tag_handles_allocated, int *tag_handles_size, int *err)
 Get all the tags associated with a specified entity handle.
void FBiGeom_rmvTag (FBiGeom_Instance instance, iBase_EntityHandle entity_handle, iBase_TagHandle tag_handle, int *err)
 Remove a tag value from an entity.
void FBiGeom_subtract (FBiGeom_Instance instance, iBase_EntitySetHandle, iBase_EntitySetHandle, iBase_EntitySetHandle *, int *err)
 Subtract contents of one entity set from another.
void FBiGeom_intersect (FBiGeom_Instance instance, iBase_EntitySetHandle, iBase_EntitySetHandle, iBase_EntitySetHandle *, int *err)
 Intersect contents of one entity set with another.
void FBiGeom_unite (FBiGeom_Instance instance, iBase_EntitySetHandle, iBase_EntitySetHandle, iBase_EntitySetHandle *, int *err)
 Unite contents of one entity set with another.
void FBiGeom_getEntClosestPtTrimmed (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double *, double *, double *, int *err)
 Get closest point for an array of entities and points For surfaces, closest point could be on the void space inside it. Get closest point for an array of entities and points. If either the number of entities or number of coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
void FBiGeom_getFcCvtrXYZ (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double *, double *, double *, double *, double *, double *, int *err)
 Get the two principle curvature vectors for a face at a point.
void FBiGeom_getEgCvtrXYZ (FBiGeom_Instance instance, iBase_EntityHandle, double, double, double, double *, double *, double *, int *err)
 Get the principle curvature vector for an edge at a point.
void FBiGeom_getEntArrCvtrXYZ (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, double **, int *, int *, int *err)
 Get the curvature(s) on an entity(ies) at given position(s)
void FBiGeom_getEgEvalXYZ (FBiGeom_Instance instance, iBase_EntityHandle edge, double x, double y, double z, double *on_x, double *on_y, double *on_z, double *tngt_i, double *tngt_j, double *tngt_k, double *cvtr_i, double *cvtr_j, double *cvtr_k, int *err)
 Get closest point, tangent, and curvature of edge.
void FBiGeom_getFcEvalXYZ (FBiGeom_Instance instance, iBase_EntityHandle face_handle, double x, double y, double z, double *on_x, double *on_y, double *on_z, double *nrml_i, double *nrml_j, double *nrml_k, double *cvtr1_i, double *cvtr1_j, double *cvtr1_k, double *cvtr2_i, double *cvtr2_j, double *cvtr2_k, int *err)
 Get closest point, tangent, and curvature of face.
void FBiGeom_getArrEgEvalXYZ (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, double **, int *, int *, double **, int *, int *, int *err)
 Get the closest point(s), tangent(s), and curvature(s) on an entity(ies) at given position(s)
void FBiGeom_getArrFcEvalXYZ (FBiGeom_Instance instance, iBase_EntityHandle const *, int, int, double const *, int, double **, int *, int *, double **, int *, int *, double **, int *, int *, double **, int *, int *, int *err)
void FBiGeom_getPntClsf (FBiGeom_Instance instance, double, double, double, iBase_EntityHandle *, int *err)
 Get the entity on which a point is located.
void FBiGeom_getPntArrClsf (FBiGeom_Instance instance, int, double const *, int, iBase_EntityHandle **, int *, int *, int *err)
 Get the entities on which points are located.
void FBiGeom_getFacets (FBiGeom_Instance instance, iBase_EntityHandle, double, double, int, int, int, int, int, int *err)
void FBiGeom_getEntTolerance (FBiGeom_Instance instance, iBase_EntityHandle, double *, int *err)
 Get the tolerance of the specified entity.
void FBiGeom_getArrTolerance (FBiGeom_Instance instance, iBase_EntityHandle const *, int, double **, int *, int *, int *err)
 Get the tolerances of the specified entities.
void FBiGeom_getTolerance (FBiGeom_Instance instance, int *, double *, int *err)
 Get the tolerance of the instance.
Variables
bool debug_igeom = false
bool Debug_surf_eval = false
Define Documentation
#define COPY_DOUBLEVEC (   r,
  vec
Value:
        double* tmp_ptr = reinterpret_cast< double* >( vec ); \
        std::copy( ( r ).begin(), ( r ).end(), tmp_ptr );     \
Definition at line 58 of file FBiGeom_MOAB.cpp.
Referenced by FBiGeom_getPntRayIntsct().
#define COPY_RANGE (   r,
  vec
Value:
        EntityHandle* tmp_ptr = reinterpret_cast< EntityHandle* >( vec ); \
Definition at line 50 of file FBiGeom_MOAB.cpp.
Referenced by FBiGeom_getArrAdj(), FBiGeom_getEnt2ndAdj(), FBiGeom_getEntAdj(), FBiGeom_getEntities(), FBiGeom_getEntSets(), and FBiGeom_getPntRayIntsct().
#define TAG_HANDLE (   tagh)    reinterpret_cast< Tag >( tagh )
Definition at line 56 of file FBiGeom_MOAB.cpp.
Referenced by FBiGeom_destroyTag().
Function Documentation
static int compare_no_case1 ( const char *  str1,
const char *  str2,
size_t  n
) [static]
Definition at line 16 of file FBiGeom_MOAB.cpp.
Referenced by filter_options1().
    for( size_t i = 1; i != n && *str1 && toupper( *str1 ) == toupper( *str2 ); ++i, ++str1, ++str2 )
    return toupper( *str2 ) - toupper( *str1 );
void FBiGeom_addEntArrToSet ( FBiGeom_Instance  instance,
const iBase_EntityHandle entity_handles,
int *  err
Parameters:
instanceFBiGeom instance handle
entity_handlesArray of entities being added
entity_handles_sizeNumber of entities in entity_handles array
entity_setPointer to the set being added to
*errPointer to error type returned from function
Definition at line 1871 of file FBiGeom_MOAB.cpp.
References iMesh_addEntArrToSet, and IMESH_INSTANCE.
    iMesh_addEntArrToSet( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, entity_set, err );
void FBiGeom_addEntSet ( FBiGeom_Instance  instance,
int *  err
Parameters:
entity_set_to_addThe entity set being added
entity_set_handlePointer to the set being added to
Definition at line 1889 of file FBiGeom_MOAB.cpp.
References iMesh_addEntSet, and IMESH_INSTANCE.
    iMesh_addEntSet( IMESH_INSTANCE( instance ), entity_set_to_add, entity_set_handle, err );
void FBiGeom_addEntToSet ( FBiGeom_Instance  instance,
int *  err
Parameters:
entity_handleThe entity being added
Definition at line 1855 of file FBiGeom_MOAB.cpp.
References iMesh_addEntToSet, and IMESH_INSTANCE.
    iMesh_addEntToSet( IMESH_INSTANCE( instance ), entity_handle, entity_set, err );
void FBiGeom_addPrntChld ( FBiGeom_Instance  instance,
int *  err
Add parent/child links between two sets. Makes parent point to child and child point to parent.
Parameters:
parent_entity_setPointer to parent set
child_entity_setPointer to child set
Definition at line 1937 of file FBiGeom_MOAB.cpp.
References iMesh_addPrntChld, and IMESH_INSTANCE.
    iMesh_addPrntChld( IMESH_INSTANCE( instance ), parent_entity_set, child_entity_set, err );
void FBiGeom_copyEnt ( FBiGeom_Instance  instance,
iBase_EntityHandle  source,
iBase_EntityHandle copy,
int *  err
Parameters:
sourceentity to be copied
copythe newly-created entity
Definition at line 1638 of file FBiGeom_MOAB.cpp.
References iBase_NOT_SUPPORTED, and RETURN.
void FBiGeom_createBrick ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
iBase_EntityHandle geom_entity,
int *  err
Create an axis-oriented box of the given dimensions, centered at the origin.
Parameters:
xx dimension of new box
yy dimension of new box
zz dimension of new box
geom_entityPointer to new entity handle returned from function
Definition at line 1676 of file FBiGeom_MOAB.cpp.
void FBiGeom_createCone ( FBiGeom_Instance  instance,
double  height,
double  major_rad_base,
double  minor_rad_base,
double  rad_top,
int *  err
Create a cone parallel to the z-axis and centered at the origin (so that its z-coordinate extents are +height/2 and -height/2). The 'base' of the cylinder is at z = -height/2, and the top is at +height/2.
Parameters:
heightThe height of the cone.
major_rad_baseThe x-axis radius at the base of the cylinder
minor_rad_baseThe y-axis radius at the base. If minor_rad_base is 0, the cylinder will be circular (as if minor_rad_base == major_rad_base)
rad_topThe x-axis radius at the top of the cone. The y-axis radius at the top of the cone will be inferred to keep the aspect ratio of the top of the cone the same as the bottom. If rad_top is 0, the cone terminates at a point.
Definition at line 1686 of file FBiGeom_MOAB.cpp.
void FBiGeom_createCylinder ( FBiGeom_Instance  instance,
double  height,
double  major_rad,
double  minor_rad,
int *  err
Create a cylinder.
Create a cylinder parallel to the z-axis and centered at the origin (so that its z-coordinate extents are +height/2 and -height/2).
Parameters:
heightThe height of the cylinder.
major_radThe x-axis radius
minor_radThe y-axis radius. If minor_rad is 0, the cylinder will be circular (as if minor_rad == major_rad).
Definition at line 1681 of file FBiGeom_MOAB.cpp.
void FBiGeom_createEntSet ( FBiGeom_Instance  instance,
int  isList,
iBase_EntitySetHandle entity_set_created,
int *  err
Create an entity set, either ordered (isList=1) or unordered (isList=0). Unordered entity sets can contain a given entity or set only once.
Parameters:
isListIf non-zero, an ordered list is created, otherwise an unordered set is created.
entity_set_createdEntity set created by function
Definition at line 1779 of file FBiGeom_MOAB.cpp.
References FWDERR, iMesh_createEntSet, and IMESH_INSTANCE.
    iMesh_createEntSet( IMESH_INSTANCE( instance ), isList, entity_set_created, err );
    FWDERR();
void FBiGeom_createPrism ( FBiGeom_Instance  instance,
double  height,
int  n_sides,
double  major_rad,
double  minor_rad,
int *  err
Create a prism.
Create a prism parallel to the z-axis and centered at the origin (so that its z-coordinate extents are +height/2 and -height/2).
Parameters:
heightheight of new prism
n_sidesnumber of sides of new prism
major_radmajor radius of new prism
minor_radminor radius of new prism
Definition at line 1671 of file FBiGeom_MOAB.cpp.
void FBiGeom_createSphere ( FBiGeom_Instance  instance,
double  radius,
int *  err
Create a sphere.
Create a sphere of the specified radius centered on the origin.
Parameters:
radiusradius of the sphere
Definition at line 1666 of file FBiGeom_MOAB.cpp.
void FBiGeom_createTag ( FBiGeom_Instance  instance,
const char *  tag_name,
int  tag_size,
int  tag_type,
int *  err,
int  tag_name_len
Create a tag with specified name, size, and type. Tag size is in units of size of tag_type data types. Value input for tag type must be value in iBase_TagType enumeration.
Parameters:
tag_nameCharacter string indicating tag name
tag_sizeSize of each tag value, in units of number of tag_type entities
tag_typeData type for data stored in this tag
tag_handlePointer to tag handle returned from function
tag_name_lenLength of tag name string
Definition at line 2004 of file FBiGeom_MOAB.cpp.
References iMesh_createTag, and IMESH_INSTANCE.
    iMesh_createTag( IMESH_INSTANCE( instance ), tag_name, tag_size, tag_type, tag_handle, err, tag_name_len );
void FBiGeom_createTorus ( FBiGeom_Instance  instance,
double  major_rad,
double  minor_rad,
int *  err
Create a torus.
Create a torus centered on the origin and encircling the z-axis.
Parameters:
major_radThe distance from the origin to the center of the torus's circular cross-section.
minor_radThe radius of the cross-section.
Definition at line 1691 of file FBiGeom_MOAB.cpp.
void FBiGeom_deleteAll ( FBiGeom_Instance  instance,
int *  err
Parameters:
Definition at line 1655 of file FBiGeom_MOAB.cpp.
    // it means deleting some sets from moab db ; is this what we want?
    RETURN( iBase_NOT_SUPPORTED );
void FBiGeom_deleteEnt ( FBiGeom_Instance  instance,
int *  err
Parameters:
entity_handleEntity to be deleted
Definition at line 1661 of file FBiGeom_MOAB.cpp.
void FBiGeom_destroyEntSet ( FBiGeom_Instance  instance,
int *  err
Parameters:
entity_setEntity set to be destroyed
Definition at line 1785 of file FBiGeom_MOAB.cpp.
void FBiGeom_destroyTag ( FBiGeom_Instance  instance,
int  forced,
int *  err
Destroy a tag.
Destroy a tag. If forced is non-zero and entities still have values set for this tag, tag is deleted anyway and those values disappear, otherwise tag is not deleted.
Parameters:
tag_handleHandle of tag to be deleted
forcedIf non-zero, delete the tag even if entities have values set for that tag
Definition at line 2016 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, iBase_SUCCESS, MBI, RETURN, and TAG_HANDLE.
    ErrorCode rval = MBI->tag_delete( TAG_HANDLE( tag_handle ) );CHKERR( rval, "Failed to delete tag" );
    RETURN( iBase_SUCCESS );
void FBiGeom_dtor ( FBiGeom_Instance  instance,
int *  err
Construct a new FBiGeom instance, using an existing moab iMesh instance and a root set that encapsulates the topological model
Parameters:
meshiMesh_Instance
setroot set for the mesh based geometry
optionsPointer to implementation-specific options string
instancePointer to FBiGeom instance handle returned from function
options_lenLength of the character string pointed to by optionsDestroy an FBiGeom instance
Parameters:
instanceFBiGeom instance to be destroyed
Definition at line 87 of file FBiGeom_MOAB.cpp.
References iBase_SUCCESS.
    MBiGeom** mbigeom = reinterpret_cast< MBiGeom** >( &instance );
    if( *mbigeom ) delete *mbigeom;
    *err = iBase_SUCCESS;
void FBiGeom_dtor2 ( FBiGeom_Instance  instance,
int *  err
Definition at line 119 of file FBiGeom_MOAB.cpp.
References FBE_cast(), moab::FBEngine::get_gtt(), and iBase_SUCCESS.
Referenced by shutdown_test2().
    moab::FBEngine* fbe = FBE_cast( instance );
    if( fbe )
        moab::GeomTopoTool* gtt = fbe->get_gtt();
        if( gtt ) delete gtt;
        delete fbe;
void FBiGeom_endEntArrIter ( FBiGeom_Instance  instance,
iBase_EntityArrIterator  entArr_iterator,
int *  err
Parameters:
entArr_iteratorIterator which gets destroyed
Definition at line 1633 of file FBiGeom_MOAB.cpp.
void FBiGeom_endEntIter ( FBiGeom_Instance  instance,
iBase_EntityIterator  entity_iterator,
int *  err
Parameters:
entity_iteratorIterator which gets destroyed
Definition at line 1628 of file FBiGeom_MOAB.cpp.
void FBiGeom_getAllEntSetTags ( FBiGeom_Instance  instance,
iBase_TagHandle **  tag_handles,
int *  tag_handles_allocated,
int *  tag_handles_size,
int *  err
Parameters:
entity_set_handleEntity being queried
*tag_handlesPointer to array of tag_handles returned from function
*tag_handles_allocatedPointer to allocated size of tag_handles array
*tag_handles_sizePointer to occupied size of tag_handles array
Definition at line 2145 of file FBiGeom_MOAB.cpp.
References iMesh_getAllEntSetTags, and IMESH_INSTANCE.
    iMesh_getAllEntSetTags( IMESH_INSTANCE( instance ), entity_set_handle, tag_handles, tag_handles_allocated,
                            tag_handles_size, err );
void FBiGeom_getAllTags ( FBiGeom_Instance  instance,
int *  err
Parameters:
entity_handleEntity being queried
Definition at line 2392 of file FBiGeom_MOAB.cpp.
References iMesh_getAllTags, and IMESH_INSTANCE.
    iMesh_getAllTags( IMESH_INSTANCE( instance ), entity_handle, tag_handles, tag_handles_allocated, tag_handles_size,
                      err );
void FBiGeom_getArr1stDrvt ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  entity_handles,
int  storage_order,
double const *  uv,
int  uv_size,
double **  dvrt_u,
int *  dvrt_u_allocated,
int *  dvrt_u_size,
int **  u_offset,
int *  u_offset_allocated,
int *  u_offset_size,
double **  dvrt_v,
int *  dvrt_v_allocated,
int *  dvrt_v_size,
int **  v_offset,
int *  v_offset_allocated,
int *  v_offset_size,
int *  err
Get the first derivatives of faces at specified parametric positions. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
entity_handlesArray of entity handles being queried
storage_orderStorage order of coordinates input and output
uvParametric coordinates being queried
uv_sizeNumber of coordinates in array
dvrt_uPointer to array of coordinates of derivative with respect to u at specified position returned from function
dvrt_u_allocatedAllocated size of dvrt_u array
dvrt_u_sizeOccupied size of dvrt_u array
u_offsetPointer to array of offsets for dvrt_u returned from function
u_offset_allocatedPointer to allocated size of u_offset array
u_offset_sizePointer to occupied size of u_offset array
dvrt_vPointer to array of coordinates of derivative with respect to v at specified position returned from function
dvrt_v_allocatedAllocated size of dvrt_v array
dvrt_v_sizeOccupied size of dvrt_v array
v_offsetPointer to array of offsets for dvrt_v returned from function
v_offset_allocatedPointer to allocated size of v_offset array
v_offset_sizePointer to occupied size of v_offset array
Definition at line 1466 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArr2ndAdj ( FBiGeom_Instance  instance,
int  order_adjacent_key,
iBase_EntityHandle **  adj_entity_handles,
int *  adj_entity_handles_allocated,
int *  adj_entity_handles_size,
int **  offset,
int *  offset_allocated,
int *  offset_size,
int *  err
Get "2nd order" adjacencies to an array of entities, that is, from each entity, through other entities of a specified "bridge" dimension, to other entities of another specified "to" dimension.
Parameters:
entity_handlesEntities from which adjacencies are requested
entity_handles_sizeNumber of entities whose adjacencies are requested
bridge_dimensionBridge dimension for 2nd order adjacencies
to_dimensionDimension of adjacent entities returned
adj_entity_handlesAdjacent entities
adj_entity_handles_allocatedAllocated size of returned array
adj_entity_handles_sizeOccupied size of returned array
offsetOffset[i] is offset into adj_entity_handles of 2nd order adjacencies of ith entity in entity_handles
offset_allocatedAllocated size of offset array
offset_sizeOccupied size of offset array
Definition at line 388 of file FBiGeom_MOAB.cpp.
    // not implemented
    // who would need this monster, anyway?
void FBiGeom_getArr2ndDrvt ( FBiGeom_Instance  instance,
int  storage_order,
double const *  uv,
int  uv_size,
double **  dvtr_uu,
int *  dvrt_uu_allocated,
int *  dvrt_uu_size,
int **  uu_offset,
int *  uu_offset_allocated,
int *  uu_offset_size,
double **  dvtr_vv,
int *  dvrt_vv_allocated,
int *  dvrt_vv_size,
int **  vv_offset,
int *  vv_offset_allocated,
int *  vv_offset_size,
double **  dvrt_uv,
int *  dvrt_uv_allocated,
int *  dvrt_uv_size,
int **  uv_offset,
int *  uv_offset_allocated,
int *  uv_offset_size,
int *  err
Get the second derivatives of faces at specified parametric positions. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
dvrt_uuPointer to array of coordinates of derivative with respect to u at specified position returned from function
dvrt_uu_allocatedAllocated size of dvrt_uu array
dvrt_uu_sizeOccupied size of dvrt_uu array
uu_offsetPointer to array of offsets for dvrt_uu returned from function
uu_offset_allocatedPointer to allocated size of uu_offset array
uu_offset_sizePointer to occupied size of uu_offset array
dvrt_vvPointer to array of coordinates of derivative with respect to v at specified position returned from function
dvrt_vv_allocatedAllocated size of dvrt_vv array
dvrt_vv_sizeOccupied size of dvrt_vv array
vv_offsetPointer to array of offsets for dvrt_vv returned from function
vv_offset_allocatedPointer to allocated size of vv_offset array
vv_offset_sizePointer to occupied size of vv_offset array
dvrt_uvPointer to array of coordinates of derivative with respect to u and v at specified position returned from function
dvrt_uv_allocatedAllocated size of dvrt_uv array
dvrt_uv_sizeOccupied size of dvrt_uv array
uv_offsetPointer to array of offsets for dvrt_uv returned from function
uv_offset_allocatedPointer to allocated size of uv_offset array
uv_offset_sizePointer to occupied size of uv_offset array
Definition at line 1505 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrAdj ( FBiGeom_Instance  instance,
int **  offset,
int *  offset_size,
int *  err
Get entities of specified type adjacent to entities. Specified type must be value in the iBase_EntityType enumeration. offset(i) is index of first entity in adjacentEntityHandles array adjacent to entity_handles[i].
Parameters:
entity_type_requestedType of adjacent entities requested
*adjacentEntityHandlesPointer to array of adjacentEntityHandles returned from function
*adjacentEntityHandles_allocatedPointer to allocated size of adjacentEntityHandles array
*adj_entity_handles_sizePointer to occupied size of adjacentEntityHandles array
*offsetPointer to array of offsets returned from function
*offset_allocatedPointer to allocated size of offset array
*offset_sizePointer to occupied size of offset array
Definition at line 312 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, CHKERR, moab::Range::clear(), COPY_RANGE, ErrorCode, FBE_cast(), moab::FBEngine::getEntAdj(), iBase_SUCCESS, MBH_cast(), moab::Range::merge(), RETURN, and moab::Range::size().
    // check offset array size
    Range temp_range, total_range;
    CHECK_SIZE( *offset, *offset_allocated, entity_handles_size + 1, int, NULL );
    *offset_size = entity_handles_size + 1;
    // get adjacent entities
    for( int i = 0; i < entity_handles_size; ++i )
        ( *offset )[i] = total_range.size();
        temp_range.clear();
        ErrorCode rval =
            FBE_cast( instance )->getEntAdj( MBH_cast( entity_handles[i] ), requested_entity_type, temp_range );CHKERR( rval, "Failed to get adjacent entities in FBiGeom_getArrAdj." );
        total_range.merge( temp_range );
    int nTot                         = total_range.size();
    ( *offset )[entity_handles_size] = nTot;
    // copy adjacent entities
    CHECK_SIZE( *adj_entity_handles, *adj_entity_handles_allocated, nTot, iBase_EntityHandle, NULL );
    COPY_RANGE( total_range, *adj_entity_handles );
    *adj_entity_handles_size = nTot;
void FBiGeom_getArrBoundBox ( FBiGeom_Instance  instance,
int  storage_order,
double **  min_corner,
int *  min_corner_allocated,
int *  min_corner_size,
double **  max_corner,
int *  max_corner_allocated,
int *  max_corner_size,
int *  err
Get the bounding box of the specified entities. Storage order passed in should be a member of iBase_StorageOrder enum.
Parameters:
entity_handlesEntity handles being queried
enttiy_handles_sizeNumber of entities being queried
storage_orderStorage order of coordinates passed back
min_cornerMinimum coordinates of bounding boxes
min_corner_allocatedAllocated size of minimum coordinates array
min_corner_sizeOccupied size of minimum coordinates array
max_cornerMaximum coordinates of bounding boxes
max_corner_allocatedAllocated size of maximum coordinates array
max_corner_sizeOccupied size of maximum coordinates array
Definition at line 853 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, FBiGeom_getEntBoundBox, FWDERR, iBase_BLOCKED, iBase_SUCCESS, init(), and RETURN.
    // check or pre-allocate the coordinate arrays
    CHECK_SIZE( *min_corner, *min_corner_allocated, 3 * entity_handles_size, double, NULL );
    CHECK_SIZE( *max_corner, *max_corner_allocated, 3 * entity_handles_size, double, NULL );
    size_t step, init;
    if( storage_order == iBase_BLOCKED )
        step = 1;
        init = entity_handles_size;
    else
        step = 3;
        init = 1;
    double *min_x, *min_y, *min_z, *max_x, *max_y, *max_z;
    min_x = *min_corner;
    max_x = *max_corner;
    min_y = min_x + init;
    max_y = max_x + init;
    min_z = min_y + init;
    max_z = max_y + init;
        FBiGeom_getEntBoundBox( instance, entity_handles[i], min_x, min_y, min_z, max_x, max_y, max_z, err );
        FWDERR();
        min_x += step;
        max_x += step;
        min_y += step;
        max_y += step;
        min_z += step;
        max_z += step;
    *min_corner_size = 3 * entity_handles_size;
    *max_corner_size = 3 * entity_handles_size;
void FBiGeom_getArrClosestPt ( FBiGeom_Instance  instance,
int  storage_order,
double const *  near_coordinates,
double **  on_coordinates,
int *  on_coordinates_allocated,
int *  on_coordinates_size,
int *  err
Parameters:
entity_handlesEntity(ies) being queried
entity_handles_sizeNumber of entities being queried
storage_orderStorage order of input points
near_coordinatesCoordinates of starting point(s)
near_coordinates_sizeNumber of values in near_coordinates array
on_coordinatesCoordinates of closest points
on_coordinates_allocatedAllocated size of closest point array
on_coordinates_sizeOccupied size of closest point array
Definition at line 494 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, FBiGeom_getEntClosestPt, FWDERR, iBase_BLOCKED, iBase_INTERLEAVED, iBase_SUCCESS, and RETURN.
    CHECK_SIZE( *on_coordinates, *on_coordinates_allocated, near_coordinates_size, double, NULL );
    for( int i = 0; i < entity_handles_size; i++ )
        if( storage_order == iBase_INTERLEAVED )
            FBiGeom_getEntClosestPt( instance, entity_handles[i], near_coordinates[3 * i], near_coordinates[3 * i + 1],
                                     near_coordinates[3 * i + 2], on_coordinates[3 * i], on_coordinates[3 * i + 1],
                                     on_coordinates[3 * i + 2], err );
        else if( storage_order == iBase_BLOCKED )
            FBiGeom_getEntClosestPt( instance, entity_handles[i], near_coordinates[i],
                                     near_coordinates[i + entity_handles_size],
                                     near_coordinates[i + 2 * entity_handles_size], on_coordinates[i],
                                     on_coordinates[i + entity_handles_size],
                                     on_coordinates[i + 2 * entity_handles_size], err );
        FWDERR();
    *on_coordinates_size = near_coordinates_size;
void FBiGeom_getArrData ( FBiGeom_Instance  instance,
void **  tag_values,
int *  tag_values_allocated,
int *  tag_values_size,
int *  err
Get tag values of arbitrary type for an array of entities. Tag data is returned as void*. tag_values_size specifies the size of the memory pointed to by tag_values in terms of bytes. Applications may use this function to get data of any type, not just iBase_BYTES. However, because this function supports data of arbitrary type, in all cases the size specified by tag_values_size always in terms of bytes.
Parameters:
entity_handlesEntity array on which tag is being set
entity_handles_sizeNumber of entities in array
tag_handleTag being set on an entity
*tag_valuesPointer to tag data array being returned from function. Note that the implicit INTERLEAVED storage order rule applies (see section ITAPS Storage Orders)
tag_values_allocatedPointer to allocated size of tag data array
tag_values_sizePointer to occupied size in bytes of tag data array
Definition at line 2164 of file FBiGeom_MOAB.cpp.
References iMesh_getArrData, and IMESH_INSTANCE.
    iMesh_getArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_values,
                      tag_values_allocated, tag_values_size, err );
void FBiGeom_getArrEgEvalXYZ ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  edge_handles,
int  edge_handles_size,
int  storage_order,
double const *  coords,
int  coords_size,
double **  on_coords,
int *  on_coords_allocated,
int *  on_coords_size,
double **  tangent,
int *  tangent_allocated,
int *  tangent_size,
double **  cvtr,
int *  cvtr_allocated,
int *  cvtr_size,
int *  err
Get the closest point(s), tangent(s), and curvature(s) on an entity(ies) at given position(s). If either the number of entities or number of coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
edge_handlesEdge(s) being queried
edge_handles_sizeNumber of edges being queried
coordsStarting coordinates
coords_sizeNumber of values in coordinates array
on_coordsClosest point array
on_coords_allocatedAllocated size of closest point array
on_coords_sizeOccupied size of closest point array
tangentTangent array
tangent_allocatedAllocated size of tangent array
tangent_sizeOccupied size of tangent array
cvtrFirst principal curvatures
cvtr_allocatedAllocated size of first curvature array
cvtr_sizeOccupied size of first curvature array
Definition at line 2559 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrFcEvalXYZ ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  face_handles,
int  face_handles_size,
int  storage_order,
int  coords_size,
double **  normal,
int *  normal_allocated,
int *  normal_size,
double **  cvtr1,
int *  cvtr1_allocated,
int *  cvtr1_size,
double **  cvtr2,
int *  cvtr2_allocated,
int *  cvtr2_size,
int *  err
Parameters:
normalNormal array
normal_allocatedAllocated size of normal array
normal_sizeOccupied size of normal array
cvtr_1First principal curvatures
cvtr_1_allocatedAllocated size of first curvature array
cvtr_1_sizeOccupied size of first curvature array
cvtr_2Second principal curvatures
cvtr_2_allocatedAllocated size of second curvature array
cvtr_2_sizeOccupied size of second curvature array
Definition at line 2579 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrNrmlPlXYZ ( FBiGeom_Instance  instance,
int  storage_order,
double **  normals,
int *  normals_allocated,
int *  normals_size,
int *  err
Get the normal vector AND closest point on an entity(ies) at given position(s). If either the number of entities or number of coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
entity_handles_sizeNumber of entity(ies) being queried
storage_orderStorage order in near_coordinates array
near_coordinatesStarting coordinates
on_coordinatesClosest point array
normalsNormal array
normals_allocatedAllocated size of normal array
normals_sizeOccupied size of normal array
Definition at line 664 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, ERROR, FBiGeom_getEntNrmlPlXYZ, FWDERR, iBase_BLOCKED, iBase_INTERLEAVED, iBase_INVALID_ENTITY_COUNT, iBase_SUCCESS, and RETURN.
    // set up iteration according to storage order.
    // allow either gentity_handles or near_coordinates to contain
    // only one value, where that single value is applied for every
    // entry in the other list.
    size_t index = 0;
    size_t near_step, on_step = 1, ent_step;
    int count;
    if( 3 * entity_handles_size == near_coordinates_size )
        near_step = ent_step = 1;
        count                = entity_handles_size;
    else if( near_coordinates_size == 3 )
        near_step = 0;
        ent_step  = 1;
    else if( entity_handles_size == 1 )
        near_step = 1;
        ent_step  = 0;
        count     = near_coordinates_size / 3;
    else
        ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched array sizes" );
    CHECK_SIZE( *on_coordinates, *on_coordinates_allocated, 3 * count, double, NULL );
    CHECK_SIZE( *normals, *normals_allocated, 3 * count, double, NULL );
    const double *near_x, *near_y, *near_z;
    double *on_x, *on_y, *on_z;
    double *norm_x, *norm_y, *norm_z;
        near_x  = near_coordinates;
        near_y  = near_x + near_coordinates_size / 3;
        near_z  = near_y + near_coordinates_size / 3;
        on_x    = *on_coordinates;
        on_y    = on_x + count;
        on_z    = on_y + count;
        norm_x  = *normals;
        norm_y  = norm_x + count;
        norm_z  = norm_y + count;
        on_step = 1;
    else
        storage_order = iBase_INTERLEAVED; /* set if unspecified */
        near_y        = near_x + 1;
        near_z        = near_x + 2;
        on_y          = on_x + 1;
        on_z          = on_x + 2;
        norm_x        = *normals;
        norm_y        = norm_x + 1;
        norm_z        = norm_x + 2;
        near_step *= 3;
        on_step = 3;
    for( int i = 0; i < count; ++i )
        FBiGeom_getEntNrmlPlXYZ( instance, entity_handles[index], *near_x, *near_y, *near_z, on_x, on_y, on_z, norm_x,
                                 norm_y, norm_z, err );
        FWDERR();
        // entities += ent_step;
        index += ent_step;
        near_x += near_step;
        near_y += near_step;
        near_z += near_step;
        on_x += on_step;
        on_y += on_step;
        on_z += on_step;
        norm_x += on_step;
        norm_y += on_step;
        norm_z += on_step;
    *on_coordinates_size = count * 3;
    *normals_size        = count;
void FBiGeom_getArrNrmlSense ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  region_handles,
int  region_handles_size,
int **  sense,
int *  sense_allocated,
int *  sense_size,
int *  err
Get the senses of an array of faces with respect to an array of regions. Sense returned is -1, 0, or 1, representing "reversed", "both", or "forward". "both" sense indicates that face bounds the region once with each sense.
Parameters:
face_handlesFaces being queried
face_handles_sizeSize of face handles array
region_handlesRegions being queried
region_handles_sizeSize of region handles array
senseSenses of faces with respect to regions
sense_allocatedAllocated size of senses array
sense_sizeOccupied size of senses array
Definition at line 1049 of file FBiGeom_MOAB.cpp.
    // not implemented
void FBiGeom_getArrNrmlUV ( FBiGeom_Instance  instance,
int  storage_order,
double const *  parameters,
int  parameters_size,
double **  normals,
int *  normals_size,
int *  err
Return the normals at specified parametric positions. If either the number of entities or number of spatial coordinate pairs is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
face_handleFaces being queried
face_handles_sizeNumber of faces being queried
parametersParametric coordinates being queried
parameters_sizeNumber of coordinates in array
normalsCoordinates of normals at specified positions
normals_allocatedAllocated size of normals array
normals_sizeOccupied size of normals array
Definition at line 1414 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrNrmlXYZ ( FBiGeom_Instance  instance,
int  storage_order,
double const *  coordinates,
int  coordinates_size,
double **  normals,
int *  normals_size,
int *  err
Get the normal vector on an entity(ies) at given position(s)
Get the normal vector on an entity(ies) at given position(s). If either the number of entities or number of coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
coordinates_sizeNumber of values in coordinates array
normalsNormal coordinates
Definition at line 545 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, ERROR, FBiGeom_getEntNrmlXYZ, FWDERR, iBase_BLOCKED, iBase_INTERLEAVED, iBase_INVALID_ENTITY_COUNT, iBase_SUCCESS, and RETURN.
    size_t index = 0;
    size_t coord_step, norm_step = 1, ent_step;
    int count;
    if( 3 * entity_handles_size == coordinates_size )
        coord_step = ent_step = 1;
    else if( coordinates_size == 3 )
        coord_step = 0;
        ent_step   = 1;
        coord_step = 1;
        ent_step   = 0;
        count      = coordinates_size / 3;
    else
    const double *coord_x, *coord_y, *coord_z;
        coord_x   = coordinates;
        coord_y   = coord_x + coordinates_size / 3;
        coord_z   = coord_y + coordinates_size / 3;
        norm_x    = *normals;
        norm_step = 1;
    else
        coord_y       = coord_x + 1;
        coord_z       = coord_x + 2;
        norm_x        = *normals;
        coord_step *= 3;
        norm_step = 3;
        FBiGeom_getEntNrmlXYZ( instance, entity_handles[index], *coord_x, *coord_y, *coord_z, norm_x, norm_y, norm_z,
                               err );
        FWDERR();
        index += ent_step;
        coord_x += coord_step;
        coord_y += coord_step;
        coord_z += coord_step;
        norm_x += norm_step;
        norm_y += norm_step;
        norm_z += norm_step;
void FBiGeom_getArrTgntU ( FBiGeom_Instance  instance,
int  storage_order,
double **  tangents,
int *  tangents_allocated,
int *  tangents_size,
int *  err
Return the tangents at specified parametric positions. If either the number of entities or number of spatial coordinates is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
edge_handleEdges being queried
edge_handles_sizeNumber of faces being queried
storage_orderStorage order of coordinates output
tangentsCoordinates of tangents at specified positions
tangents_allocatedAllocated size of tangents array
tangents_sizeOccupied size of tangents array
Definition at line 1439 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrTgntXYZ ( FBiGeom_Instance  instance,
int  storage_order,
double **  tangents,
int *  err
Get the tangent vector on an entity(ies) at given position(s)
Get the tangent vector on an entity(ies) at given position(s). If either the number of entities or number of coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum
Parameters:
tangentsTangent coordinates
Definition at line 779 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrTolerance ( FBiGeom_Instance  instance,
double **  tolerances,
int *  tolerances_allocated,
int *  tolerances_size,
int *  err
Parameters:
tolerancePointer to array of tolerances returned from function
tolerance_allocatedPointer to allocated size of tolerance array
tololerance_sizePointer to occupied size of tolerance array
Definition at line 2637 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrType ( FBiGeom_Instance  instance,
int **  type,
int *  type_allocated,
int *  type_size,
int *  err
Get the entity type for the specified entities.
Get the entity type for the specified entities. Types returned are values in the iBase_EntityType enumeration.
Parameters:
*typePointer to array of types returned from function
*type_allocatedPointer to allocated size of type array
*type_sizePointer to occupied size of type array
Definition at line 263 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, ERROR, FBiGeom_getEntType, iBase_SUCCESS, and RETURN.
    CHECK_SIZE( *type, *type_allocated, entity_handles_size, int, NULL );
    *type_size = entity_handles_size;
    int tmp_err;
        FBiGeom_getEntType( instance, entity_handles[i], *type + i, &tmp_err );
        if( iBase_SUCCESS != tmp_err )
            ERROR( tmp_err, "Failed to get entity type in FBiGeom_getArrType." );
void FBiGeom_getArrURange ( FBiGeom_Instance  instance,
double **  u_min,
int *  u_min_allocated,
int *  u_min_size,
double **  u_max,
int *  u_max_allocated,
int *  u_max_size,
int *  err
Parameters:
entity_handlesEntities being queried
storage_orderStorage order of parametric coordinates being returned
u_minMinimum parametric coordinate for entities
u_min_allocatedAllocated size of minimum parametric coordinate array
u_min_sizeOccupied size of minimum parametric coordinate array
u_maxMaximum parametric coordinate for entities
u_max_allocatedAllocated size of maximum parametric coordinate array
u_max_sizeOccupied size of maximum parametric coordinate array
Definition at line 1332 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrUtoUV ( FBiGeom_Instance  instance,
double const *  u_in,
int  u_in_size,
int  storage_order,
double **  uv,
int *  uv_allocated,
int *  uv_size,
int *  err
Parameters:
edge_handlesEdges being queried
u_inParametric positions on edges
u_in_sizeNumber of parametric positions on edges
storage_orderStorage order of coordinates returned
uvCorresponding parametric positions on faces
uv_allocatedAllocated size of parameter array
uv_sizeOccupied size of parameter array
Definition at line 1363 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrUtoXYZ ( FBiGeom_Instance  instance,
double const *  u,
int  u_size,
int  storage_order,
int *  err
Return coordinate positions at specified parametric position(s) on entity(ies)
Return coordinate positions at specified parametric position(s) on entity(ies). If either the number of entities or number of parametric coordinate pairs is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
storage_orderStorage order of resulting coordinates
uvCoordinates being queried
coordinatesCoordinates of parametric positions
coordinates_allocatedAllocated size of coordinates array
coordinates_sizeOccupied size of coordinates array
Definition at line 1219 of file FBiGeom_MOAB.cpp.
    // not implemented
void FBiGeom_getArrUVRange ( FBiGeom_Instance  instance,
int  storage_order,
double **  uv_min,
int *  uv_min_allocated,
int *  uv_min_size,
double **  uv_max,
int *  uv_max_allocated,
int *  uv_max_size,
int *  err
Get parametric range of entities.
Parameters:
uv_minMinimum parametric coordinate for entities
uv_min_allocatedAllocated size of minimum parametric coordinate array
uv_min_sizeOccupied size of minimum parametric coordinate array
uv_maxMaximum parametric coordinate for entities
uv_max_allocatedAllocated size of maximum parametric coordinate array
uv_max_sizeOccupied size of maximum parametric coordinate array
Definition at line 1318 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrUVtoXYZ ( FBiGeom_Instance  instance,
int  storage_order,
double const *  uv,
int  uv_size,
double **  coordinates,
int *  coordinates_allocated,
int *  coordinates_size,
int *  err
Parameters:
storage_orderStorage order of uv coordinates input and xyz coordinate output
Definition at line 1186 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrXYZtoU ( FBiGeom_Instance  instance,
int  storage_order,
double **  u,
int *  u_allocated,
int *  u_size,
int *  err
Return spatial positions at specified parametric position(s) on entity(ies)
Return spatial positions at specified parametric position(s) on entity(ies). If either the number of entities or number of spatial coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
storage_orderStorage order of spatial coordinates input
coordinatesCoordinates being queried
coordinates_sizeNumber of coordinates in array
uCoordinates of parametric positions
u_allocatedAllocated size of coordinates array
u_sizeOccupied size of coordinates array
Definition at line 1261 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrXYZtoUV ( FBiGeom_Instance  instance,
int  storage_order,
double **  uv,
int *  uv_allocated,
int *  uv_size,
int *  err
Return parametric positions at specified spatial position(s) on entity(ies) Return parametric positions at specified spatial position(s) on entity(ies). If either the number of entities or number of spatial coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
uvCoordinates of parametric positions
uv_allocatedAllocated size of coordinates array
uv_sizeOccupied size of coordinates array
Definition at line 1248 of file FBiGeom_MOAB.cpp.
void FBiGeom_getArrXYZtoUVHint ( FBiGeom_Instance  instance,
int  storage_order,
int  coords_size,
double **  uv,
int *  uv_allocated,
int *  uv_size,
int *  err
Return parametric positions at specified spatial position(s) on entity(ies), based on parametric position hints Return parametric positions at specified spatial position(s) on entity(ies), based on parametric position hints. If either the number of entities or number of spatial coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
Definition at line 1285 of file FBiGeom_MOAB.cpp.
void FBiGeom_getBoundBox ( FBiGeom_Instance  instance,
double *  min_x,
double *  min_y,
double *  min_z,
double *  max_x,
double *  max_y,
double *  max_z,
int *  err
Get the bounding box of the entire model.
Parameters:
min_xMinimum coordinate of bounding box
min_yMinimum coordinate of bounding box
min_zMinimum coordinate of bounding box
max_xMaximum coordinate of bounding box
max_yMaximum coordinate of bounding box
max_zMaximum coordinate of bounding box
Definition at line 209 of file FBiGeom_MOAB.cpp.
void FBiGeom_getChldn ( FBiGeom_Instance  instance,
int  num_hops,
iBase_EntitySetHandle **  entity_set_handles,
int *  entity_set_handles_allocated,
int *  entity_set_handles_size,
int *  err
Get the child sets linked from a specified set. If num_hops is not -1, this represents the maximum hops from entity_set to any child.
Parameters:
from_entity_setEntity set being queried
num_hopsMaximum hops from entity_set_handle to child set, not inclusive of the child set
*entity_set_handlesPointer to array of child sets returned from function
*entity_set_handles_allocatedPointer to allocated size of entity_set_handles array
*entity_set_handles_sizePointer to occupied size of entity_set_handles array
Definition at line 1980 of file FBiGeom_MOAB.cpp.
References iMesh_getChldn, and IMESH_INSTANCE.
    iMesh_getChldn( IMESH_INSTANCE( instance ), from_entity_set, num_hops, entity_set_handles,
                    entity_set_handles_allocated, entity_set_handles_size, err );
void FBiGeom_getData ( FBiGeom_Instance  instance,
void **  tag_value,
int *  tag_value_allocated,
int *  tag_value_size,
int *  err
Get the value of a tag of arbitrary type on an entity. Tag data is passed back as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications may use this function to get data of any type, not just iBase_BYTES. However, because this function supports arbitrary type, in all cases the size specified by tag_value_size is always in terms of bytes.
Parameters:
entity_handleEntity on which tag is being set
*tag_valuePointer to tag data array being queried
*tag_value_allocatedPointer to tag data array allocated size
*tag_value_sizePointer to occupied size in bytes of tag data array
Definition at line 2298 of file FBiGeom_MOAB.cpp.
References iMesh_getData, and IMESH_INSTANCE.
    iMesh_getData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, tag_value, tag_value_allocated,
                   tag_value_size, err );
void FBiGeom_getDblArrData ( FBiGeom_Instance  instance,
double **  tag_values,
int *  err
Parameters:
tag_values_sizePointer to occupied size of tag data array
Definition at line 2190 of file FBiGeom_MOAB.cpp.
References iMesh_getDblArrData, and IMESH_INSTANCE.
    iMesh_getDblArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_values,
void FBiGeom_getDblData ( FBiGeom_Instance  instance,
double *  out_data,
int *  err
Parameters:
*out_dataPointer to tag value returned from function
Definition at line 2319 of file FBiGeom_MOAB.cpp.
References iMesh_getDblData, and IMESH_INSTANCE.
    iMesh_getDblData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, out_data, err );
void FBiGeom_getDescription ( FBiGeom_Instance  instance,
char *  descr,
int  descr_len
Get a description of the error returned from the last FBiGeom call.
Get a description of the error returned from the last FBiGeom function
Parameters:
descrPointer to a character string to be filled with a description of the error from the last FBiGeom function
descr_lenLength of the character string pointed to by descr
Definition at line 64 of file FBiGeom_MOAB.cpp.
References iMesh_getDescription, and IMESH_INSTANCE.
    iMesh_getDescription( IMESH_INSTANCE( instance ), descr, descr_len );
void FBiGeom_getEgCvtrXYZ ( FBiGeom_Instance  instance,
iBase_EntityHandle  edge_handle,
double  x,
double  y,
double  z,
double *  cvtr_i,
double *  cvtr_j,
double *  cvtr_k,
int *  err
Get the principle curvature vector for an edge at a point. Magnitude of vector is the curvature, direction is direction of principal curvature.
Parameters:
edge_handleEdge being queried
xPosition being queried
yPosition being queried
zPosition being queried
cvtr_iMaximum curvature vector
cvtr_jMaximum curvature vector
cvtr_kMaximum curvature vector
Definition at line 2465 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEgEvalXYZ ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double *  on_x,
double *  on_y,
double *  on_z,
double *  tgnt_i,
double *  tgnt_j,
double *  tgnt_k,
double *  cvtr_i,
double *  cvtr_j,
double *  cvtr_k,
int *  err
Parameters:
xPoint at which entity is being queried
yPoint at which entity is being queried
zPoint at which entity is being queried
on_xClosest point at point being queried
on_yClosest point at point being queried
on_zClosest point at point being queried
tgnt_iTangent at point being queried
tgnt_jTangent at point being queried
tgnt_kTangent at point being queried
cvtr_iCurvature at point being queried
cvtr_jCurvature at point being queried
cvtr_kCurvature at point being queried
Definition at line 2495 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEgEvalXYZ(), iBase_SUCCESS, and RETURN.
    ErrorCode rval = FBE_cast( instance )
                         ->getEgEvalXYZ( (moab::EntityHandle)edge, x, y, z, *on_x, *on_y, *on_z, *tngt_i, *tngt_j,
                                         *tngt_k, *cvtr_i, *cvtr_j, *cvtr_k );CHKERR( rval, "can't get point on edge " );
void FBiGeom_getEgFcArrSense ( FBiGeom_Instance  instance,
int **  sense,
int *  sense_size,
int *  err
Get the senses of an array of edges with respect to an array of faces.
Get the senses of an array of edges with respect to an array of faces. Sense returned is -1, 0, or 1, representing "reversed", "both", or "forward". "both" sense indicates that edge bounds the face once with each sense.
Parameters:
edge_handles_sizeSize of edge handles array
Definition at line 1086 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEgFcSense ( FBiGeom_Instance  instance,
iBase_EntityHandle  face,
int *  sense_out,
int *  err
Get the sense of an edge with respect to a face Get the sense of an edge with respect to a face. Sense returned is -1, 0, or 1, representing "reversed", "both", or "forward". "both" sense indicates that edge bounds the face once with each sense.
Parameters:
edgeEdge being queried
faceFace being queried
sense_outSense of edge with respect to face
Definition at line 1072 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEgFcSense(), iBase_SUCCESS, MBH_cast(), and RETURN.
    // this one is important, for establishing the orientation of the edges in faces
    // bummer, I "thought" it is already implemented
    // use senses
    ErrorCode rval = FBE_cast( instance )->getEgFcSense( MBH_cast( edge ), MBH_cast( face ), *sense_out );
    CHKERR( rval, "Failed to get edge senses in FBiGeom_getEgFcSense." );
void FBiGeom_getEgVtxArrSense ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  vertex_handles_1,
int  veretx_handles_1_size,
iBase_EntityHandle const *  vertex_handles_2,
int  vertex_handles_2_size,
int **  sense,
int *  sense_size,
int *  err
Get the senses of vertex pair with respect to a edges.
Get the senses of vertex pairs with respect to edges. Sense returned is -1, 0, or 1, representing "reversed", "both", or "forward". "both" sense indicates that both vertices in pair are identical and that vertex bounds both sides of the edge.
Parameters:
vertex_handles_1First vertex being queried
vertex_handles_1_sizeNumber of vertices in vertices array
vertex_handles_2Second vertex being queried
vertex_handles_2_sizeNumber of vertices in vertices array
senseSense of vertex pair with respect to edge
sense_allocatedAllocated size of sense array
sense_sizeOccupied size of sense array
Definition at line 1111 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEgVtxSense ( FBiGeom_Instance  instance,
iBase_EntityHandle  vertex1,
iBase_EntityHandle  vertex2,
int *  sense_out,
int *  err
Get the sense of a vertex pair with respect to an edge.
Get the sense of a vertex pair with respect to an edge. Sense returned is -1, 0, or 1, representing "reversed", "both", or "forward". "both" sense indicates that vertices are identical and that vertex bounds both sides of the edge.
Parameters:
vertex1First vertex being queried
vertex2Second vertex being queried
sense_outSense of vertex pair with respect to edge
Definition at line 1099 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEgVtxSense(), iBase_SUCCESS, MBH_cast(), and RETURN.
    ErrorCode rval =
        FBE_cast( instance )->getEgVtxSense( MBH_cast( edge ), MBH_cast( vertex1 ), MBH_cast( vertex2 ), *sense_out );CHKERR( rval, "Failed to get vertex sense wrt edge in FBiGeom_getEgVtxSense" );
void FBiGeom_getEHArrData ( FBiGeom_Instance  instance,
iBase_EntityHandle **  tag_value,
int *  err
Parameters:
*tag_valuePointer to tag data array being returned from function
tag_value_allocatedPointer to allocated size of tag data array
tag_value_sizePointer to occupied size of tag data array
Definition at line 2203 of file FBiGeom_MOAB.cpp.
References iMesh_getEHArrData, and IMESH_INSTANCE.
    iMesh_getEHArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_value,
                        tag_value_allocated, tag_value_size, err );
void FBiGeom_getEHData ( FBiGeom_Instance  instance,
iBase_EntityHandle out_data,
int *  err
Parameters:
Definition at line 2328 of file FBiGeom_MOAB.cpp.
References iMesh_getEHData, and IMESH_INSTANCE.
    iMesh_getEHData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, out_data, err );
void FBiGeom_getEnt1stDrvt ( FBiGeom_Instance  instance,
double  u,
double  v,
double **  drvt_u,
int *  drvt_u_allocated,
int *  drvt_u_size,
double **  drvt_v,
int *  dvrt_v_size,
int *  err
Get the first derivative of a face at specified parametric position.
Parameters:
uParametric position being queried
vParametric position being queried
dvrt_uPointer to coordinates of derivative with respect to u at specified position returned from function
dvrt_vPointer to coordinates of derivative with respect to v at specified position returned from function
Definition at line 1452 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEnt2ndAdj ( FBiGeom_Instance  instance,
int  bridge_dimension,
int  to_dimension,
iBase_EntityHandle **  adjacent_entities,
int *  adjacent_entities_allocated,
int *  adjacent_entities_size,
int *  err
Get "2nd order" adjacencies to an entity.
Get "2nd order" adjacencies to an entity, that is, from an entity, through other entities of a specified "bridge" dimension, to other entities of another specified "to" dimension.
Parameters:
entity_handleEntity from which adjacencies are requested
adjacent_entitiesAdjacent entities
adjacent_entities_allocatedAllocated size of returned array
adjacent_entities_sizeOccupied size of returned array
Definition at line 349 of file FBiGeom_MOAB.cpp.
References moab::Range::begin(), CHECK_SIZE, CHKERR, moab::Range::clear(), COPY_RANGE, moab::Range::end(), ErrorCode, FBE_cast(), moab::Range::find(), moab::FBEngine::getEntAdj(), iBase_SUCCESS, moab::Range::insert(), MBH_cast(), RETURN, and moab::Range::size().
    Range to_ents, bridge_ents, tmp_ents;
    ErrorCode rval = FBE_cast( instance )->getEntAdj( MBH_cast( entity_handle ), bridge_dimension, bridge_ents );
    CHKERR( rval, "Failed to get adjacent entities in FBiGeom_getEnt2ndAdj." );
    Range::iterator iter, jter, kter, end_jter;
    Range::iterator end_iter = bridge_ents.end();
    for( iter = bridge_ents.begin(); iter != end_iter; ++iter )
        rval = FBE_cast( instance )->getEntAdj( *iter, to_dimension, tmp_ents );
        for( jter = tmp_ents.begin(); jter != end_jter; ++jter )
            if( to_ents.find( *jter ) == to_ents.end() )
                to_ents.insert( *jter );
        tmp_ents.clear();
    *adjacent_entities_size = to_ents.size();
    CHECK_SIZE( *adjacent_entities, *adjacent_entities_allocated, *adjacent_entities_size, iBase_EntityHandle, NULL );
    COPY_RANGE( to_ents, *adjacent_entities );
void FBiGeom_getEnt2ndDrvt ( FBiGeom_Instance  instance,
double  u,
double  v,
double **  drvt_uu,
int *  drvt_uu_allocated,
int *  drvt_uu_size,
double **  drvt_vv,
int *  dvrt_vv_size,
double **  drvt_uv,
int *  dvrt_uv_size,
int *  err
Get the second derivative of a face at specified parametric position.
Parameters:
dvrt_uuPointer to coordinates of derivative with respect to u at specified position returned from function
dvrt_vvPointer to coordinates of derivative with respect to v at specified position returned from function
dvrt_uvPointer to coordinates of derivative with respect to u and v at specified position returned from function
Definition at line 1488 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntAdj ( FBiGeom_Instance  instance,
int  to_dimension,
iBase_EntityHandle **  adj_entities,
int *  adj_entities_allocated,
int *  adj_entities_size,
int *  err
Get entities of specified type adjacent to an entity.
Get entities of specified type adjacent to an entity. Specified type must be value in the iBase_EntityType enumeration.
Parameters:
entity_handleEntity handle being queried
*adj_entity_handlesPointer to array of adjacent entities returned from function
*adj_entity_handles_allocatedPointer to allocated size of adj_entity_handles array
*adj_entity_handles_sizePointer to occupied size of adj_entity_handles array
Definition at line 288 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, CHKERR, COPY_RANGE, ErrorCode, FBE_cast(), moab::FBEngine::getEntAdj(), iBase_SUCCESS, MBH_cast(), RETURN, and moab::Range::size().
    Range adjs;
    EntityHandle this_ent = MBH_cast( entity_handle );
    ErrorCode rval = FBE_cast( instance )->getEntAdj( this_ent, to_dimension, adjs );
    CHKERR( rval, "Failed to get adjacent entities in FBiGeom_getEntAdj." );
    *adj_entities_size = adjs.size();
    CHECK_SIZE( *adj_entities, *adj_entities_allocated, *adj_entities_size, iBase_EntityHandle, NULL );
    COPY_RANGE( adjs, *adj_entities );
void FBiGeom_getEntArrCvtrXYZ ( FBiGeom_Instance  instance,
int  storage_order,
int  coords_size,
double **  cvtr_1,
int *  cvtr_1_allocated,
int *  cvtr_1_size,
double **  cvtr_2,
int *  cvtr_2_allocated,
int *  cvtr_2_size,
int *  err
Get the curvature(s) on an entity(ies) at given position(s). If either the number of entities or number of coordinate triples is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
Definition at line 2478 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntBoundBox ( FBiGeom_Instance  instance,
double *  min_x,
double *  min_y,
double *  min_z,
double *  max_x,
double *  max_y,
double *  max_z,
int *  err
Get the bounding box of the specified entity.
Parameters:
Definition at line 793 of file FBiGeom_MOAB.cpp.
References moab::CartVect::array(), moab::OrientedBoxTreeTool::box(), center(), CHKERR, ERROR, ErrorCode, FBiGeom_getEntType, FBiGeom_getVtxCoord, FWDERR, moab::GeomTopoTool::get_root(), GETGTT, iBase_FAILURE, iBase_INVALID_ENTITY_TYPE, iBase_NOT_SUPPORTED, iBase_SUCCESS, MBH_cast(), moab::GeomTopoTool::obb_tree(), and RETURN.
    ErrorCode rval;
    int type;
    FBiGeom_getEntType( instance, entity_handle, &type, err );
    FWDERR();
    if( type == 0 )
        FBiGeom_getVtxCoord( instance, entity_handle, min_x, min_y, min_z, err );
        FWDERR();
        max_x = min_x;
        max_y = min_y;
        max_z = min_z;
    else if( type == 1 )
        // it could be relatively easy to support
        *err = iBase_NOT_SUPPORTED;
        FWDERR();
    else if( type == 2 || type == 3 )
        EntityHandle root;
        CartVect center, axis[3];
        GeomTopoTool* gtt = GETGTT( instance );
        if( !gtt ) ERROR( iBase_FAILURE, "Can't get geom topo tool." );
        rval = gtt->get_root( MBH_cast( entity_handle ), root );CHKERR( rval, "Failed to get tree root in FBiGeom_getEntBoundBox." );
        rval = gtt->obb_tree()->box( root, center.array(), axis[0].array(), axis[1].array(), axis[2].array() );CHKERR( rval, "Failed to get box from obb tree." );
        CartVect absv[3];
        for( int i = 0; i < 3; i++ )
            absv[i] = CartVect( fabs( axis[i][0] ), fabs( axis[i][1] ), fabs( axis[i][2] ) );
        CartVect min, max;
        min    = center - absv[0] - absv[1] - absv[2];
        max    = center + absv[0] + absv[1] + absv[2];
        *min_x = min[0];
        *min_y = min[1];
        *min_z = min[2];
        *max_x = max[0];
        *max_y = max[1];
        *max_z = max[2];
    else
        RETURN( iBase_INVALID_ENTITY_TYPE );
void FBiGeom_getEntClosestPt ( FBiGeom_Instance  instance,
double  near_x,
double  near_y,
double  near_z,
double *  on_x,
double *  on_y,
double *  on_z,
int *  err
Get closest point to an entity.
Get closest point to a specified position on an entity
Parameters:
near_xCoordinates of starting point
near_yCoordinates of starting point
near_zCoordinates of starting point
on_xClosest point on entity
on_yClosest point on entity
on_zClosest point on entity
Definition at line 477 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEntClosestPt(), iBase_SUCCESS, MBH_cast(), and RETURN.
    ErrorCode rval =
        FBE_cast( instance )->getEntClosestPt( MBH_cast( entity_handle ), near_x, near_y, near_z, on_x, on_y, on_z );CHKERR( rval, "Failed to get closest point" );
void FBiGeom_getEntClosestPtTrimmed ( FBiGeom_Instance  instance,
double  near_x,
double  near_y,
double  near_z,
double *  on_x,
double *  on_y,
double *  on_z,
int *  err
Parameters:
Definition at line 2436 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntities ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  set_handle,
int  entity_type,
iBase_EntityHandle **  entity_handles,
int *  entity_handles_allococated,
int *  entity_handles_size,
int *  err
Get entities of specific type in set or instance.
Get entities of specific type in set or instance. All entities are requested by specifying iBase_ALL_TYPES. Specified type must be a value in the iBase_EntityType enumeration.
Parameters:
entity_set_handleEntity set being queried
entity_typeType of entities being requested
entity_topologyTopology of entities being requested
*entity_handlesPointer to array of entity handles returned from function
*entity_handles_allocatedPointer to allocated size of entity_handles array
*entity_handles_sizePointer to occupied size of entity_handles array
Definition at line 214 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, CHKERR, COPY_RANGE, ERROR, ErrorCode, FBE_cast(), moab::FBEngine::getEntities(), iBase_INVALID_ENTITY_TYPE, iBase_SUCCESS, RETURN, and moab::Range::size().
    if( 0 > entity_type || 4 < entity_type )
        ERROR( iBase_INVALID_ENTITY_TYPE, "Bad entity type." );
    else /* 0<= entity_type <= 4) */
        Range gentities;
        ErrorCode rval = FBE_cast( instance )->getEntities( (EntityHandle)set_handle, entity_type, gentities );CHKERR( rval, "can't get entities " );
        *entity_handles_size = gentities.size();
        CHECK_SIZE( *entity_handles, *entity_handles_allocated, *entity_handles_size, iBase_EntityHandle, NULL );
        COPY_RANGE( gentities, *entity_handles );
void FBiGeom_getEntNrmlPlXYZ ( FBiGeom_Instance  instance,
iBase_EntityHandle  entity_handle,
double  x,
double  y,
double  z,
double *  pt_x,
double *  pt_y,
double *  pt_z,
double *  nrml_i,
double *  nrml_j,
double *  nrml_k,
int *  err
Get the normal vector AND closest point on an entity at given position.
Get the normal vector AND closest point on an entity at a given position.
Parameters:
xStarting coordinates
yStarting coordinates
zStarting coordinates
pt_xClosest point
pt_yClosest point
pt_zClosest point
nrml_iNormal at closest point
nrml_jNormal at closest point
nrml_kNormal at closest point
Definition at line 631 of file FBiGeom_MOAB.cpp.
References ERROR, FBiGeom_getEntClosestPt, FBiGeom_getEntNrmlXYZ, FBiGeom_getEntType, FWDERR, iBase_INVALID_ENTITY_TYPE, iBase_SUCCESS, and RETURN.
    // just do for surface and volume
    int type;
    FWDERR();
    if( type != 2 && type != 3 )
        ERROR( iBase_INVALID_ENTITY_TYPE, "Entities passed into gentityNormal must be face or volume." );
    // do 2 searches, so it is not fast enough
    FBiGeom_getEntClosestPt( instance, entity_handle, x, y, z, pt_x, pt_y, pt_z, err );
    FWDERR();
    FBiGeom_getEntNrmlXYZ( instance, entity_handle, *pt_x, *pt_y, *pt_z, nrml_i, nrml_j, nrml_k, err );
    FWDERR();
void FBiGeom_getEntNrmlSense ( FBiGeom_Instance  instance,
iBase_EntityHandle  region,
int *  sense_out,
int *  err
Get the sense of a face with respect to a region.
Get the sense of a face with respect to a region. Sense returned is -1, 0, or 1, representing "reversed", "both", or "forward". "both" sense indicates that face bounds the region once with each sense.
Parameters:
regionRegion being queried
sense_outSense of face with respect to region
Definition at line 1038 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEgFcSense(), iBase_SUCCESS, and RETURN.
    moab::EntityHandle mbregion = (moab::EntityHandle)region;
    moab::EntityHandle mbface   = (moab::EntityHandle)face;
    moab::ErrorCode rval        = FBE_cast( instance )->getEgFcSense( mbface, mbregion, *sense_out );CHKERR( rval, "can't get normal sense " );
void FBiGeom_getEntNrmlUV ( FBiGeom_Instance  instance,
double  u,
double  v,
double *  nrml_i,
double *  nrml_j,
double *  nrml_k,
int *  err
Return the normal at a specified parametric position.
Parameters:
nrml_iNormal at specified position
nrml_jNormal at specified position
nrml_kNormal at specified position
*errPointer to error type returned from functino
Definition at line 1403 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntNrmlXYZ ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double *  nrml_i,
double *  nrml_j,
double *  nrml_k,
int *  err
Get the normal vector on an entity at the given position Get the normal vector on an entity at the given position.
Parameters:
nrml_iNormal vector at starting point
nrml_jNormal vector at starting point
nrml_kNormal vector at starting point
Definition at line 530 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEntNrmlXYZ(), iBase_SUCCESS, MBH_cast(), and RETURN.
    ErrorCode rval = FBE_cast( instance )->getEntNrmlXYZ( MBH_cast( entity_handle ), x, y, z, nrml_i, nrml_j, nrml_k );CHKERR( rval, "Failed to get normal" );
void FBiGeom_getEntSetData ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  entity_set_handle,
iBase_TagHandle  tag_handle,
void **  tag_value,
int *  err
Get the value of a tag of arbitrary type on an entity set.
Get the value of a tag of arbitrary type on an entity set. Tag data is returned back as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications may use this function to get data of any type, not just iBase_BYTES. However because this function supports data of arbitrary type, in all cases the size specified by tag_value_size is always in terms of bytes.
Parameters:
entity_set_handleEntity set on which tag is being set
tag_handleTag being set on an entity set
Definition at line 2097 of file FBiGeom_MOAB.cpp.
References iMesh_getEntSetData, and IMESH_INSTANCE.
    iMesh_getEntSetData( IMESH_INSTANCE( instance ), entity_set_handle, tag_handle, tag_value, tag_value_allocated,
void FBiGeom_getEntSetDblData ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  entity_set,
double *  out_data,
int *  err
Get the value of a tag of double type on an entity set.
Parameters:
instanceFBiGeom instance handle
entity_setEntity set on which tag is being set
*errPointer to error type returned from function
Definition at line 2118 of file FBiGeom_MOAB.cpp.
References iMesh_getEntSetDblData, and IMESH_INSTANCE.
    iMesh_getEntSetDblData( IMESH_INSTANCE( instance ), entity_set, tag_handle, out_data, err );
void FBiGeom_getEntSetEHData ( FBiGeom_Instance  instance,
int *  err
Get the value of a tag of entity handle type on an entity set.
Parameters:
Definition at line 2127 of file FBiGeom_MOAB.cpp.
References iMesh_getEntSetEHData, and IMESH_INSTANCE.
    iMesh_getEntSetEHData( IMESH_INSTANCE( instance ), entity_set, tag_handle, out_data, err );
void FBiGeom_getEntSetESHData ( FBiGeom_Instance  instance,
iBase_EntitySetHandle out_data,
int *  err
Get the value of a tag of entity set handle type on an entity set.
Parameters:
Definition at line 2136 of file FBiGeom_MOAB.cpp.
References iMesh_getEntSetESHData, and IMESH_INSTANCE.
    iMesh_getEntSetESHData( IMESH_INSTANCE( instance ), entity_set, tag_handle, out_data, err );
void FBiGeom_getEntSetIntData ( FBiGeom_Instance  instance,
int *  out_data,
int *  err
Get the value of a tag of integer type on an entity set.
Parameters:
Definition at line 2109 of file FBiGeom_MOAB.cpp.
References iMesh_getEntSetIntData, and IMESH_INSTANCE.
    iMesh_getEntSetIntData( IMESH_INSTANCE( instance ), entity_set, tag_handle, out_data, err );
void FBiGeom_getEntSets ( FBiGeom_Instance  instance,
int  num_hops,
iBase_EntitySetHandle **  contained_set_handles,
int *  contained_set_handles_allocated,
int *  contained_set_handles_size,
int *  err
Get the entity sets contained in a set or interface.
Get the entity sets contained in a set or interface. If a set is input which is not the root set, num_hops indicates the maximum number of contained sets from entity_set_handle to one of the contained sets, not inclusive of the contained set.
Parameters:
num_hopsMaximum hops from entity_set_handle to contained set, not inclusive of the contained set
*contained_set_handlesPointer to array of set handles returned from function
contained_set_handles_allocatedPointer to allocated length of contained_set_handles array
contained_set_handles_sizePointer to occupied length of contained_set_handles array
Definition at line 1824 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, CHKERR, COPY_RANGE, ErrorCode, GEOM_DIMENSION_TAG_NAME, geomTag, moab::GeomTopoTool::geoRanges(), GETGTT, iBase_FAILURE, iBase_SUCCESS, moab::intersect(), MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, MBI, RETURN, and moab::Range::size().
    //  we get only the entity sets that have gents as members
    // we keep the convention that entity sets of geom dimension 4 are
    // sets of geo entities; they should contain only gentities as elements (or other sets of gents)
    Tag geomTag;
    ErrorCode rval = MBI->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag );
    if( MB_SUCCESS != rval ) RETURN( iBase_FAILURE );
    const Range* gRange = gtt->geoRanges();
    // get all sets of geom dimension 4 from the entity set
    EntityHandle moabSet         = (EntityHandle)entity_set_handle;
    const int four               = 4;
    const void* const four_val[] = { &four };
    Range tmp;
    rval = MBI->get_entities_by_type_and_tag( moabSet, MBENTITYSET, &geomTag, four_val, 1, tmp );CHKERR( rval, "can't get sets of geo dim 4 " );
    tmp                         = intersect( tmp, gRange[4] );
    *contained_set_handles_size = tmp.size();
    CHECK_SIZE( *contained_set_handles, *contained_set_handles_allocated, *contained_set_handles_size,
                iBase_EntitySetHandle, NULL );
    COPY_RANGE( tmp, *contained_set_handles );
void FBiGeom_getEntTgntU ( FBiGeom_Instance  instance,
double  u,
double *  tgnt_i,
double *  tgnt_j,
double *  tgnt_k,
int *  err
Return the tangent at a specified parametric position.
Parameters:
tgnt_iTangent at specified position
tgnt_jTangent at specified position
tgnt_kTangent at specified position
Definition at line 1427 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEntTgntU(), iBase_SUCCESS, and RETURN.
    ErrorCode rval =
        FBE_cast( instance )->getEntTgntU( (moab::EntityHandle)entity_handle, u, *tgnt_i, *tgnt_j, *tgnt_k );CHKERR( rval, "Failed to get tangent from u" );
void FBiGeom_getEntTgntXYZ ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double *  tgnt_i,
double *  tgnt_j,
double *  tgnt_k,
int *  err
Get the tangent vector on an entity at given position.
Get the tangent vector on an entity at a given position.
Parameters:
tgnt_iTangent at closest point
tgnt_jTangent at closest point
tgnt_kTangent at closest point
Definition at line 766 of file FBiGeom_MOAB.cpp.
References iBase_NOT_SUPPORTED, and RETURN.
void FBiGeom_getEntTolerance ( FBiGeom_Instance  instance,
double *  tolerance,
int *  err
Get the tolerance of the specified entity.
Parameters:
tolerancePointer to tolerance returned from function
Definition at line 2633 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntType ( FBiGeom_Instance  instance,
int *  type,
int *  err
Get the entity type for the specified entity.
Get the entity type for the specified entity. Type returned is a value in the iBase_EntityType enumeration.
Parameters:
entity_handleentity handle being queried
*typePointer to location at which to store the returned type
Definition at line 255 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEntType(), iBase_SUCCESS, and RETURN.
    ErrorCode rval = FBE_cast( instance )->getEntType( (EntityHandle)entity_handle, type );CHKERR( rval, "can't get entity type " );
void FBiGeom_getEntURange ( FBiGeom_Instance  instance,
double *  u_min,
double *  u_max,
int *  err
Get parametric range of entity.
Parameters:
u_minMinimum parametric coordinate for entity
u_maxMaximum parametric coordinate for entity
Definition at line 1309 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEntURange(), iBase_SUCCESS, and RETURN.
    ErrorCode rval = FBE_cast( instance )->getEntURange( (EntityHandle)entity_handle, *u_min, *u_max );CHKERR( rval, "Failed to get range" );
void FBiGeom_getEntUtoUV ( FBiGeom_Instance  instance,
iBase_EntityHandle  face_handle,
double  in_u,
double *  u,
double *  v,
int *  err
Return the face parametric coordinates for a parametric position on a bounding edge.
Parameters:
face_handleFace being queried
in_uParametric position on edge
uCorresponding parametric position on face
vCorresponding parametric position on face
Definition at line 1345 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntUtoXYZ ( FBiGeom_Instance  instance,
double  u,
double *  x,
double *  y,
double *  z,
int *  err
Return coordinate position at specified parametric position on entity.
Parameters:
uParametric coordinate being queried
xSpatial coordinate at parametric position being queried
ySpatial coordinate at parametric position being queried
zSpatial coordinate at parametric position being queried
Definition at line 1200 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), FBiGeom_getEntType, FWDERR, moab::FBEngine::getEntUtoXYZ(), iBase_NOT_SUPPORTED, iBase_SUCCESS, and RETURN.
    int type;
    FWDERR();
    if( type != 1 )  // not edge
        RETURN( iBase_NOT_SUPPORTED );
    ErrorCode rval = FBE_cast( instance )->getEntUtoXYZ( (EntityHandle)entity_handle, u, *x, *y, *z );CHKERR( rval, "Failed to get position from parameter" );
    RETURN( iBase_SUCCESS );
void FBiGeom_getEntUVRange ( FBiGeom_Instance  instance,
double *  u_min,
double *  v_min,
double *  u_max,
double *  v_max,
int *  err
Parameters:
v_minMinimum parametric coordinate for entity
v_maxMaximum parametric coordinate for entity
Definition at line 1298 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntUVtoXYZ ( FBiGeom_Instance  instance,
double  u,
double  v,
double *  x,
double *  y,
double *  z,
int *  err
Parameters:
vParametric coordinate being queried
Definition at line 1175 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntXYZtoU ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double *  u,
int *  err
Return parametric position at specified spatial position on entity.
Parameters:
xSpatial coordinate being queried
ySpatial coordinate being queried
zSpatial coordinate being queried
uParametric coordinate at spatial position being queried
Definition at line 1244 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntXYZtoUV ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double *  u,
double *  v,
int *  err
Parameters:
vParametric coordinate at spatial position being queried
Definition at line 1233 of file FBiGeom_MOAB.cpp.
void FBiGeom_getEntXYZtoUVHint ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double *  u,
double *  v,
int *  err
Return parametric position at specified spatial position on entity, based on parametric position hint.
Return parametric position at specified spatial position on entity, based on parametric position hint. For this function, u and v are input with parameters from which to start search. Typically this will reduce the search time for new parametric coordinates.
Parameters:
Definition at line 1274 of file FBiGeom_MOAB.cpp.
void FBiGeom_getErrorType ( FBiGeom_Instance  instance,
int *  error_type
Get the error type returned from the last FBiGeom function.
Get the error type returned from the last FBiGeom function. Value returned is a member of the iBase_ErrorType enumeration.
Parameters:
*error_typeError type returned from last FBiGeom function
Definition at line 69 of file FBiGeom_MOAB.cpp.
References iMesh_getErrorType, and IMESH_INSTANCE.
    iMesh_getErrorType( IMESH_INSTANCE( instance ), /*out*/ error_type );
void FBiGeom_getESHArrData ( FBiGeom_Instance  instance,
const iBase_EntityHandle entity_handles,
int  entity_handles_size,
iBase_EntitySetHandle **  tag_value,
int *  err
Get tag values of entity set handle type for an array of entities.
Parameters:
Definition at line 2216 of file FBiGeom_MOAB.cpp.
References iMesh_getESHArrData, and IMESH_INSTANCE.
    iMesh_getESHArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_value,
void FBiGeom_getESHData ( FBiGeom_Instance  instance,
int *  err
Get the value of a tag of entity set handle type on an entity.
Parameters:
Definition at line 2337 of file FBiGeom_MOAB.cpp.
References iMesh_getESHData, and IMESH_INSTANCE.
    iMesh_getESHData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, out_data, err );
void FBiGeom_getFacets ( FBiGeom_Instance  instance,
iBase_EntityHandle  ,
double  ,
double  ,
int  ,
int  ,
int  ,
int  ,
int  ,
int *  err
Definition at line 2619 of file FBiGeom_MOAB.cpp.
void FBiGeom_getFaceType ( FBiGeom_Instance  instance,
char *  face_type,
int *  err,
int *  face_type_length
Get the geometric type of a face.
Get the geometric type of a face. Specific types depend on implementation.
Parameters:
face_typeFace type
face_type_lengthLength of face type string
Definition at line 1141 of file FBiGeom_MOAB.cpp.
References iBase_SUCCESS, and RETURN.
    std::string type = "nonplanar";  // for swept faces created with rays between surfaces,
                                     // we could actually create planar surfaces; maybe we should
                                     // recognize them as such
    face_type = new char[type.length() + 1];
    strcpy( face_type, type.c_str() );
    *face_type_length = type.length() + 1;
void FBiGeom_getFcArrCvtrUV ( FBiGeom_Instance  instance,
int  storage_order,
double const *  uv,
int  uv_size,
double **  cvtr_1,
int *  cvtr_1_size,
double **  cvtr_2,
int *  cvtr_2_size,
int *  err
Get the curvature(s) on face(s) at given parametric position(s)
Get the curvature(s) on face(s) at given parametric position(s). If either the number of faces or number of coordinate pairs is unity, then all points or entities are queried for that entity or point, respectively, otherwise each point corresponds to each entity. storage_order should be a value in the iBase_StorageOrder enum.
Parameters:
face_handlesFace(s) being queried
face_handles_sizeNumber of entities being queried
uvStarting parametric coordinates
uv_sizeNumber of values in uv array
Definition at line 1547 of file FBiGeom_MOAB.cpp.
void FBiGeom_getFcCvtrUV ( FBiGeom_Instance  instance,
double  u,
double  v,
double *  cvtr1_i,
double *  cvtr1_j,
double *  cvtr1_k,
double *  cvtr2_i,
double *  cvtr2_j,
double *  cvtr2_k,
int *  err
Get the two principle curvature vectors for a face at a parametric position.
Get the two principle curvature vectors for a face at a parametric position. Magnitudes of vectors are curvature, directions are directions of principal curvatures.
Parameters:
cvtr1_iMaximum curvature vector
cvtr1_jMaximum curvature vector
cvtr1_kMaximum curvature vector
cvtr2_iMinimum curvature vector
cvtr2_jMinimum curvature vector
cvtr2_kMinimum curvature vector
Definition at line 1533 of file FBiGeom_MOAB.cpp.
void FBiGeom_getFcCvtrXYZ ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double *  cvtr1_i,
double *  cvtr1_j,
double *  cvtr1_k,
double *  cvtr2_i,
double *  cvtr2_j,
double *  cvtr2_k,
int *  err
Get the two principle curvature vectors for a face at a point.
Get the two principle curvature vectors for a face at a point. Magnitudes of vectors are curvature, directions are directions of principal curvatures.
Parameters:
Definition at line 2449 of file FBiGeom_MOAB.cpp.
void FBiGeom_getFcEvalXYZ ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double *  on_x,
double *  on_y,
double *  on_z,
double *  nrml_i,
double *  nrml_j,
double *  nrml_k,
double *  cvtr1_i,
double *  cvtr1_j,
double *  cvtr1_k,
double *  cvtr2_i,
double *  cvtr2_j,
double *  cvtr2_k,
int *  err
Get closest point, tangent, and curvature of face.
Get closest point, tangent, and curvature of face. If any of input coordinate pointers are NULL, that value is not returned.
Parameters:
nrml_iNormal at point being queried
nrml_jNormal at point being queried
nrml_kNormal at point being queried
cvtr1_iFirst principal curvature at point being queried
cvtr1_jFirst principal curvature at point being queried
cvtr1_kFirst principal curvature at point being queried
cvtr2_iSecond principal curvature at point being queried
cvtr2_jSecond principal curvature at point being queried
cvtr2_kSecond principal curvature at point being queried
Definition at line 2517 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getEntClosestPt(), moab::FBEngine::getEntNrmlXYZ(), iBase_SUCCESS, and RETURN.
      moab::ErrorCode rval = _fbEngine->getFcEvalXYZ( (moab::EntityHandle) face,
      x,  y, z,
      on_x, on_y, on_z,
      cvtr1_i, cvtr1_j, cvtr1_k,
      cvtr2_i, cvtr2_j,  cvtr2_k );*/
    // camal really does not use curvatures
    // the most it is calling for normals and for closest point
    // return all curvatures = 0 for the time being, because we
    // know camal is not requesting them
    *cvtr1_i = *cvtr1_j = *cvtr1_k = *cvtr2_i = *cvtr2_j = *cvtr2_k = 0.;
    // first get closest point, then normal, separately
    ErrorCode rval =
        FBE_cast( instance )->getEntClosestPt( (moab::EntityHandle)face_handle, x, y, z, on_x, on_y, on_z );CHKERR( rval, "can't get closest point on surface " );
               ->getEntNrmlXYZ( (moab::EntityHandle)face_handle, x, y, z, nrml_i, nrml_j,
                                nrml_k );  // some inconsistency here, we use pointers, not refs
    CHKERR( rval, "can't get normal on closest point on surface " );
void FBiGeom_getIntArrData ( FBiGeom_Instance  instance,
int **  tag_values,
int *  err
Get tag values of integer type for an array of entities.
Parameters:
Definition at line 2177 of file FBiGeom_MOAB.cpp.
References iMesh_getIntArrData, and IMESH_INSTANCE.
    iMesh_getIntArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_values,
void FBiGeom_getIntData ( FBiGeom_Instance  instance,
int *  out_data,
int *  err
Get the value of a tag of integer type on an entity.
Parameters:
Definition at line 2310 of file FBiGeom_MOAB.cpp.
References iMesh_getIntData, and IMESH_INSTANCE.
    iMesh_getIntData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, out_data, err );
void FBiGeom_getNextEntArrIter ( FBiGeom_Instance  instance,
iBase_EntityArrIterator  entArr_iterator,
int *  entity_handles_allocated,
int *  has_data,
int *  err
Get entities contained in array iterator and increment iterator.
Get the entities contained in an array iterator, and increment the iterator. Also return whether the next value of the iterator has any entities (if non-zero, next iterator value is the end of the iteration).
Parameters:
entArr_iteratorIterator being queried
*entity_handlesPointer to array of entity handles contained in current value of iterator
has_dataPointer to a flag indicating if the value(s) returned in entity_handles are valid. A non-zero value indicates the value(s) are valid. A zero value indicates the value(s) are NOT valid.
Definition at line 1607 of file FBiGeom_MOAB.cpp.
void FBiGeom_getNextEntIter ( FBiGeom_Instance  instance,
iBase_EntityIterator  entity_iterator,
int *  has_data,
int *  err
Get entity corresponding to an iterator and increment iterator.
Get the entity corresponding to an array iterator, and increment the iterator. Also return whether the next value of the iterator has an entity (if non-zero, next iterator value is the end of the iteration).
Parameters:
entity_iteratorIterator being queried
entity_handlePointer to an entity handle corresponding to the current value of iterator
has_dataPointer to a flag indicating if the value returned in entity_handle is valid. A non-zero value indicates the value is valid. A zero value indicates the value is NOT valid.
Definition at line 1602 of file FBiGeom_MOAB.cpp.
void FBiGeom_getNumChld ( FBiGeom_Instance  instance,
int  num_hops,
int *  num_child,
int *  err
Get the number of child sets linked from a specified set.
Get the number of child sets linked from a specified set. If num_hops is not -1, this represents the maximum hops from entity_set to any child in the count.
Parameters:
num_childPointer to number of children returned from function
Definition at line 1962 of file FBiGeom_MOAB.cpp.
References iMesh_getNumChld, and IMESH_INSTANCE.
    iMesh_getNumChld( IMESH_INSTANCE( instance ), entity_set, num_hops, num_child, err );
void FBiGeom_getNumEntSets ( FBiGeom_Instance  instance,
int  num_hops,
int *  num_sets,
int *  err
Get the number of entity sets contained in a set or interface.
Get the number of entity sets contained in a set or interface. If a set is input which is not the root set, num_hops indicates the maximum number of contained sets from entity_set_handle to one of the contained sets, not inclusive of the contained set.
Parameters:
num_setsPointer to the number of sets returned from function
Definition at line 1795 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, GEOM_DIMENSION_TAG_NAME, geomTag, moab::GeomTopoTool::geoRanges(), GETGTT, iBase_FAILURE, iBase_SUCCESS, moab::intersect(), MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, MBI, RETURN, and moab::Range::size().
    //  here, we get only the entity sets that have gents as members
    // we have the convention that entity sets of geom dimension 4 are
    // we should also consider the number of hops
    // first, get all sets of geo dim 4 from the entity_set_handle; then intersect with
    // the range from geom topo tool
    Tag geomTag;
    const int four               = 4;
    Range tmp;
    *num_sets = tmp.size();  // ignore, for the time being, number of hops
void FBiGeom_getNumOfType ( FBiGeom_Instance  instance,
int  entity_type,
int *  num_out,
int *  err
Get the number of entities with the specified type in the instance or set.
Get the number of entities with the specified type in the instance or set. If entity set handle is zero, return information for instance, otherwise for set. Value of entity type must be from the iBase_EntityType enumeration. If iBase_ALL_TYPES is specified, total number of entities (excluding entity sets) is returned.
Parameters:
entity_typeType of entity requested
num_typePointer to number of entities, returned from function
Definition at line 240 of file FBiGeom_MOAB.cpp.
References CHKERR, ERROR, ErrorCode, FBE_cast(), moab::FBEngine::getNumOfType(), iBase_INVALID_ENTITY_TYPE, iBase_SUCCESS, and RETURN.
    ErrorCode rval = FBE_cast( instance )->getNumOfType( (EntityHandle)set_handle, entity_type, num_out );CHKERR( rval, "can't get number of type " );
void FBiGeom_getNumPrnt ( FBiGeom_Instance  instance,
int  num_hops,
int *  num_parent,
int *  err
Get the number of parent sets linked from a specified set.
Get the number of parent sets linked from a specified set. If num_hops is not -1, this represents the maximum hops from entity_set to any parent in the count.
Parameters:
num_hopsMaximum hops from entity_set_handle to parent set, not inclusive of the parent set
num_parentPointer to number of parents returned from function
Definition at line 1971 of file FBiGeom_MOAB.cpp.
References iMesh_getNumPrnt, and IMESH_INSTANCE.
    iMesh_getNumPrnt( IMESH_INSTANCE( instance ), entity_set, num_hops, num_parent, err );
void FBiGeom_getParametric ( FBiGeom_Instance  instance,
int *  is_parametric,
int *  err
Return whether interface has information about parameterization.
Return whether an interface has information about parameterization (!=0) or not (0)
Parameters:
is_parametricIf non-zero, interface has information about parameterization
Definition at line 1155 of file FBiGeom_MOAB.cpp.
    *is_parametric = 0;  //(false)
void FBiGeom_getPntArrClsf ( FBiGeom_Instance  instance,
int  storage_order,
double const *  coords,
int  coords_size,
int *  err
Get the entities on which points are located.
Get the entities on which points are located. Storage orders should be members of the iBase_StorageOrder enumeration.
Parameters:
storage_orderStorage order of coordinates in coords
coordsPoints being queried
coords_sizeNumber of entries in coords array
entity_handlesEntities on which points are located
entity_handles_allocatedAllocated size of entity_handles array
entity_handles_sizeOccupied size of entity_handles array
Definition at line 2607 of file FBiGeom_MOAB.cpp.
void FBiGeom_getPntArrRayIntsct ( FBiGeom_Instance  instance,
int  storage_order,
const double *  coords,
int  coords_size,
const double *  directions,
int  directions_size,
iBase_EntityHandle **  intersect_entity_handles,
int *  intersect_entity_handles_allocated,
int *  intersect_entity_hangles_size,
int **  offset,
int *  offset_allocated,
int *  offset_size,
double **  intersect_coords,
int *  intersect_coords_allocated,
int *  intersect_coords_size,
double **  param_coords,
int *  param_coords_allocated,
int *  param_coords_size,
int *  err
Intersect an array of rays with the model.
Intersect an array of rays with the model. Storage order passed in is a member of the iBase_StorageOrder enumeration.
Parameters:
storage_orderStorage order of input coordinates
coordsPoints from which rays are fired
coords_sizeNumber of points from which rays are fired
directionsDirections in which rays are fired
directions_sizeNumber of coordinates in directions array
intersect_entity_handlesEntities intersected by ray
intersect_entity_handles_allocatedAllocated size of intersections array
intersect_entity_hangles_sizeOccupied size of intersections array
offsetOffset[i] is offset into intersect_entity_handles of ith ray
offset_allocatedAllocated size of offset array
offset_sizeOccupied size of offset array
storage_orderStorage order of coordinates passed back
intersect_coordsCoordinates of intersections
intersect_coords_allocatedAllocated size of coordinates array
intersect_coords_sizeOccupied size of coordinates array
param_coordsDistances along ray of intersections
param_coords_allocatedAllocated size of param_coords array
param_coords_sizeOccupied size of param_coords array
Definition at line 1014 of file FBiGeom_MOAB.cpp.
    // not implemented
void FBiGeom_getPntClsf ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
int *  err
Get the entity on which a point is located.
Parameters:
xPoint being queried
yPoint being queried
zPoint being queried
entity_handleEntity on which point is located
Definition at line 2602 of file FBiGeom_MOAB.cpp.
void FBiGeom_getPntRayIntsct ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double  dir_x,
double  dir_y,
double  dir_z,
int  storage_order,
int *  err
Intersect a ray with the model.
Intersect a ray with the model. Storage orders passed in should be a member of the iBase_StorageOrder enumeration.
Parameters:
xPoint from which ray is fired
yPoint from which ray is fired
zPoint from which ray is fired
dir_xDirection in which ray is fired
dir_yDirection in which ray is fired
dir_zDirection in which ray is fired
Definition at line 956 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, CHKERR, COPY_DOUBLEVEC, COPY_RANGE, ErrorCode, FBE_cast(), moab::FBEngine::getPntRayIntsct(), iBase_BLOCKED, iBase_SUCCESS, and RETURN.
    // this is pretty cool
    // we will return only surfaces
    // storage order is ignored
    std::vector< EntityHandle > intersect_handles;
    std::vector< double > coords;
    std::vector< double > params;
    ErrorCode rval =
        FBE_cast( instance )->getPntRayIntsct( x, y, z, dir_x, dir_y, dir_z, intersect_handles, coords, params );CHKERR( rval, "can't get ray intersections " );
    *intersect_entity_handles_size = (int)intersect_handles.size();
    CHECK_SIZE( *intersect_entity_handles, *intersect_entity_handles_allocated, *intersect_entity_handles_size,
    *intersect_coords_size = 3 * (int)intersect_handles.size();
    CHECK_SIZE( *intersect_coords, *intersect_coords_allocated, *intersect_coords_size, double, NULL );
    *param_coords_size = (int)intersect_handles.size();
    CHECK_SIZE( *param_coords, *param_coords_allocated, *param_coords_size, double, NULL );
    COPY_RANGE( intersect_handles, *intersect_entity_handles );
    COPY_DOUBLEVEC( params, *param_coords );
    if( storage_order == iBase_BLOCKED )
        int sz = (int)intersect_handles.size();
        for( int i = 0; i < sz; i++ )
            *intersect_coords[i]          = coords[3 * i];
            *intersect_coords[sz + i]     = coords[3 * i + 1];
            *intersect_coords[2 * sz + i] = coords[3 * i + 2];
    else
        COPY_DOUBLEVEC( coords, *intersect_coords );
void FBiGeom_getPrnts ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  from_entity_set,
int  num_hops,
int *  err
Get the parent sets linked from a specified set.
Get the parent sets linked from a specified set. If num_hops is not -1, this represents the maximum hops from entity_set to any parent.
Parameters:
*entity_set_handlesPointer to array of parent sets returned from function
Definition at line 1992 of file FBiGeom_MOAB.cpp.
References iMesh_getPrnts, and IMESH_INSTANCE.
    iMesh_getPrnts( IMESH_INSTANCE( instance ), from_entity_set, num_hops, entity_set_handles,
void FBiGeom_getRootSet ( FBiGeom_Instance  instance,
iBase_EntitySetHandle root_set,
int *  err
Get handle of the root set for this instance.
Get handle of the root set for this instance. All geom in this instance can be accessed from this set.
Parameters:
root_setPointer to set handle returned from function
Definition at line 201 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getRootSet(), iBase_SUCCESS, and RETURN.
    EntityHandle modelSet;
    ErrorCode rval = FBE_cast( instance )->getRootSet( &modelSet );CHKERR( rval, "can't get root set " );
    *root_set = (iBase_EntitySetHandle)modelSet;
void FBiGeom_getTagHandle ( FBiGeom_Instance  instance,
const char *  tag_name,
int *  err,
int  tag_name_len
Get a the handle of an existing tag with the specified name.
Parameters:
tag_nameName of tag being queried
tag_handlePointer to tag handle returned from function
tag_name_lenLength of tag name string
Definition at line 2037 of file FBiGeom_MOAB.cpp.
References iMesh_getTagHandle, and IMESH_INSTANCE.
    iMesh_getTagHandle( IMESH_INSTANCE( instance ), tag_name, tag_handle, err, tag_name_len );
void FBiGeom_getTagName ( FBiGeom_Instance  instance,
char *  name,
int *  err,
int  name_len
Get the name for a given tag handle.
Parameters:
tag_handleTag handle being queried
namePointer to character string to store name returned from function
name_lenLength of character string input to function
Definition at line 2022 of file FBiGeom_MOAB.cpp.
References iMesh_getTagName, and IMESH_INSTANCE.
    iMesh_getTagName( IMESH_INSTANCE( instance ), tag_handle, name, err, name_len );
void FBiGeom_getTagSizeBytes ( FBiGeom_Instance  instance,
int *  tag_size,
int *  err
Get size of a tag in units of bytes.
Parameters:
tag_handleHandle of tag being queried
tag_sizePointer to tag size returned from function
Definition at line 2032 of file FBiGeom_MOAB.cpp.
References iMesh_getTagSizeBytes, and IMESH_INSTANCE.
    iMesh_getTagSizeBytes( IMESH_INSTANCE( instance ), tag_handle, tag_size, err );
void FBiGeom_getTagSizeValues ( FBiGeom_Instance  instance,
int *  tag_size,
int *  err
Get size of a tag in units of numbers of tag data type.
Parameters:
Definition at line 2027 of file FBiGeom_MOAB.cpp.
References iMesh_getTagSizeValues, and IMESH_INSTANCE.
    iMesh_getTagSizeValues( IMESH_INSTANCE( instance ), tag_handle, tag_size, err );
void FBiGeom_getTagType ( FBiGeom_Instance  instance,
int *  tag_type,
int *  err
Get the data type of the specified tag handle.
Get the data type of the specified tag handle. Tag type is a value in the iBase_TagType enumeration.
Parameters:
tag_handleHandle for the tag being queried
tag_typePointer to tag type returned from function
Definition at line 2046 of file FBiGeom_MOAB.cpp.
References iMesh_getTagType, and IMESH_INSTANCE.
    iMesh_getTagType( IMESH_INSTANCE( instance ), tag_handle, tag_type, err );
void FBiGeom_getTolerance ( FBiGeom_Instance  instance,
int *  type,
double *  tolerance,
int *  err
Get the tolerance of the instance.
Get the tolerance at the modeler level. type is an integer representing the type of the tolerance, where 0 = no tolerance information, 1 = modeler-level tolerance, 2 = entity-level tolerances. If type is 1, tolerance returns the modeler-level tolerance. If type is 2, use FBiGeom_getEntTolerance to query the tolerance on a per-entity basis.
Parameters:
typeType of tolerance used by the modeler
toleranceModeler-level tolerance, if any
Definition at line 2647 of file FBiGeom_MOAB.cpp.
void FBiGeom_getVtxArrCoords ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  entity_handles,
int  storage_order,
int *  err
Get coordinates of specified vertices.
Get coordinates of specified vertices. If storage order is passed in with a value other than iBase_UNDETERMINED, coordinates are returned in the specified storage order, otherwise storage order is that native to the implementation. Storage order of returned coordinates is also returned.
Parameters:
vertex_handlesArray of geom vertex handles whose coordinates are being requested
vertex_handles_sizeNumber of vertices in vertex_handles array
storage_orderStorage order requested for coordinate data
*coordsPointer to array of coordinates returned from function
*coords_allocatedPointer to allocated size of coords array
*coords_sizePointer to occupied size of coords array
Definition at line 916 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, FBiGeom_getVtxCoord, iBase_BLOCKED, iBase_SUCCESS, and RETURN.
    // check or pre-allocate the coordinate arrays
    CHECK_SIZE( *coordinates, *coordinates_allocated, 3 * entity_handles_size, double, NULL );
    double *x, *y, *z;
    size_t step;
        x    = *coordinates;
        y    = x + entity_handles_size;
        z    = y + entity_handles_size;
        step = 1;
    else
        x    = *coordinates;
        y    = x + 1;
        z    = x + 2;
        step = 3;
    for( int i = 0; i < entity_handles_size; i++ )
        FBiGeom_getVtxCoord( instance, entity_handles[i], x, y, z, err );
        x += step;
        y += step;
        z += step;
    *coordinates_size = 3 * entity_handles_size;
void FBiGeom_getVtxArrToU ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  vertex_handles,
int  vertex_handles_size,
iBase_EntityHandle const *  edge_handles,
int  edge_handles_size,
double **  u,
int *  u_allocated,
int *  u_size,
int *  err
Return parametric coordinates on edges of vertex positions.
Parameters:
vertex_handlesVertices being queried
vertex_handles_sizeNumber of vertices being queried
edge_handles_sizeNumber of edges being queried
uCorresponding parametric positions on faces
u_allocatedAllocated size of positions array
u_sizeOccupied size of positions array
Definition at line 1391 of file FBiGeom_MOAB.cpp.
void FBiGeom_getVtxArrToUV ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  face_handles,
int  face_handles_size,
int  storage_order,
double **  uv,
int *  uv_allocated,
int *  uv_size,
int *  err
Return parametric coordinates on faces of vertex positions.
Parameters:
face_handlesFaces being queried
face_handles_sizeNumber of faces being queried
uv_allocatedAllocated size of positions array
uv_sizeOccupied size of positions array
Definition at line 1378 of file FBiGeom_MOAB.cpp.
void FBiGeom_getVtxCoord ( FBiGeom_Instance  instance,
iBase_EntityHandle  vertex_handle,
double *  x,
double *  y,
double *  z,
int *  err
Get coordinates of specified vertex.
Parameters:
vertex_handleGeom vertex being queried
*xPointer to x coordinate returned from function
*yPointer to y coordinate returned from function
*zPointer to z coordinate returned from function
Definition at line 905 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::FBEngine::getVtxCoord(), iBase_SUCCESS, MBH_cast(), and RETURN.
    ErrorCode rval = FBE_cast( instance )->getVtxCoord( MBH_cast( vertex_handle ), x, y, z );CHKERR( rval, "Failed to vertex position" );
void FBiGeom_getVtxToU ( FBiGeom_Instance  instance,
double *  u,
int *  err
Return parametric coordinates on edge of vertex position.
Parameters:
vertex_handleVertex being queried
Definition at line 1359 of file FBiGeom_MOAB.cpp.
void FBiGeom_getVtxToUV ( FBiGeom_Instance  instance,
double *  u,
double *  v,
int *  err
Return parametric coordinates on face of vertex position.
Parameters:
Definition at line 1355 of file FBiGeom_MOAB.cpp.
void FBiGeom_imprintEnts ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  geom_entities,
int  geom_entities_size,
int *  err
Imprint entities.
Imprint entities by merging coincident surfaces.
Parameters:
geom_entitiesArray of entity handles being imprinted
geom_entities_sizeNumber of entities in geom_entities array
Definition at line 1768 of file FBiGeom_MOAB.cpp.
void FBiGeom_initEntArrIter ( FBiGeom_Instance  instance,
int  requested_entity_type,
int  requested_array_size,
int *  err
Initialize an array iterator over specified entity type and size.
Initialize an array iterator over specified entity type and size for a specified set or instance. Iterator returned can be used as input to functions returning entities for the iterator. If all entities of a specified type are to be iterated, specify iBase_ALL_TYPES. Specified type must be a value in the iBase_EntityType enumerations.
Parameters:
entity_set_handleEntity set being iterated
requested_entity_typeType of entity to iterate
requested_array_sizeSize of chunks of handles returned for each value of the iterator
entArr_iteratorPointer to iterator returned from function
Definition at line 1592 of file FBiGeom_MOAB.cpp.
void FBiGeom_initEntIter ( FBiGeom_Instance  instance,
int *  err
Initialize an iterator over specified entity type.
Initialize an iterator over specified entity type for a specified set or instance. Iterator returned can be used as input to functions returning the entity for the iterator. If all entities of a specified type are to be iterated, specify iBase_ALL_TYPES. Specified type must be a value in the iBase_EntityType enumeration.
Parameters:
entity_iteratorPointer to iterator returned from function
Definition at line 1587 of file FBiGeom_MOAB.cpp.
void FBiGeom_intersect ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  entity_set_1,
iBase_EntitySetHandle  entity_set_2,
iBase_EntitySetHandle result_entity_set,
int *  err
Intersect contents of one entity set with another.
Parameters:
entity_set_1Entity set being intersected with another
entity_set_2Entity set being intersected with another
result_entity_setPointer to entity set returned from function
Definition at line 2417 of file FBiGeom_MOAB.cpp.
void FBiGeom_intersectEnts ( FBiGeom_Instance  instance,
iBase_EntityHandle  entity2,
iBase_EntityHandle  entity1,
iBase_EntityHandle geom_entity,
int *  err
Geometrically intersect a pair of entities.
Parameters:
entity1The entity to intersect
entity2The entity to intersect
geom_entityPointer to new entity handle returned from function
Definition at line 1746 of file FBiGeom_MOAB.cpp.
void FBiGeom_isArrAdj ( FBiGeom_Instance  instance,
iBase_EntityHandle const *  entity_handles_1,
int  entity_handles_1_size,
iBase_EntityHandle const *  entity_handles_2,
int  entity_handles_2_size,
int **  is_adjacent_info,
int *  is_adjacent_info_allocated,
int *  is_adjacent_info_size,
int *  err
Return whether entity pairs are adjacent.
Return whether entity pairs are adjacent, i.e. if entity_handles_1[i] is adjacent to entity_handles_2[i]. This function requires entity_handles_1_size and entity_handles_2_size to be equal.
Parameters:
entity_handles_1First array of entities
entity_handles_1_sizeNumber of entities in first array
entity_handles_2Second array of entities
entity_handles_2_sizeNumber of entities in second array
is_adjacent_infoArray of flags returned from function
is_adjacent_info_allocatedAllocated size of flags array
is_adjacent_info_sizeOccupied size of flags array
Definition at line 421 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, FBiGeom_isEntAdj, FWDERR, iBase_INVALID_ENTITY_COUNT, iBase_SUCCESS, and RETURN.
    int index1 = 0;
    int index2 = 0;
    size_t index1_step, index2_step;
    int count;
    // If either list contains only 1 entry, compare that entry with
    // every entry in the other list.
    if( entity_handles_1_size == entity_handles_2_size )
        index1_step = index2_step = 1;
        count                     = entity_handles_1_size;
    else if( entity_handles_1_size == 1 )
        index1_step = 0;
        index2_step = 1;
        count       = entity_handles_2_size;
    else if( entity_handles_2_size == 1 )
        index1_step = 1;
        index2_step = 0;
    else
        RETURN( iBase_INVALID_ENTITY_COUNT );
    CHECK_SIZE( *is_adjacent_info, *is_adjacent_info_allocated, count, int, NULL );
    for( int i = 0; i < count; ++i )
        FBiGeom_isEntAdj( instance, entity_handles_1[index1], entity_handles_2[index2], &( ( *is_adjacent_info )[i] ),
                          err );
        FWDERR();
        index1 += index1_step;
        index2 += index2_step;
    // it is now safe to set the size
    *is_adjacent_info_size = count;
void FBiGeom_isArrParametric ( FBiGeom_Instance  instance,
int **  is_parametric,
int *  is_parametric_allocated,
int *  is_parametric_size,
int *  err
Return whether entities have parameterizations.
Return whether entities have parameterizations (=1) or not (=0)
Parameters:
entity_handlesEntities being queried
entity_handles_sizeNumber of entities being queried
is_parametricentity_handles[i] has a parameterization (=1) or not (=0)
is_parametric_allocatedAllocated size of is_parametric array
is_parametric_sizeOccupied size of is_parametric array
Definition at line 1170 of file FBiGeom_MOAB.cpp.
    // not implemented
void FBiGeom_isArrPeriodic ( FBiGeom_Instance  instance,
int **  in_uv,
int *  in_uv_allocated,
int *  in_uv_size,
int *  err
Return whether entities are periodic.
Return whether entities are periodic (=1) or not (=0) in the u and v directions.
Parameters:
in_uvArray of pairs of integers representing whether entity_handles[i] is periodic (=1) or not (=0) in u and v directions
in_uv_allocatedAllocated size of in_uv array
in_uv_sizeOccupied size of in_uv array
Definition at line 1574 of file FBiGeom_MOAB.cpp.
void FBiGeom_isChildOf ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  parent_entity_set,
iBase_EntitySetHandle  child_entity_set,
int *  is_child,
int *  err
Return whether two sets are related by parent/child links.
Return whether two sets are related (*is_child=1) or not (*is_child=0) by parent/child links
Parameters:
parent_entity_setPointer to parent set
child_entity_setPointer to child set
is_childPointer to flag returned from function
Definition at line 1953 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_isChildOf.
    iMesh_isChildOf( IMESH_INSTANCE( instance ), parent_entity_set, child_entity_set, is_child, err );
void FBiGeom_isEntAdj ( FBiGeom_Instance  instance,
iBase_EntityHandle  entity_handle1,
iBase_EntityHandle  entity_handle2,
int *  are_adjacent,
int *  err
Return whether two entities are adjacent.
Parameters:
entity_handle1First entity queried
entity_handle2Second entity queried
are_adjacentIf returned non-zero, entities are adjacent, otherwise they are not
Definition at line 406 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), iBase_SUCCESS, moab::FBEngine::isEntAdj(), MBH_cast(), and RETURN.
    bool adjacent_out;
    ErrorCode rval =
        FBE_cast( instance )->isEntAdj( MBH_cast( entity_handle1 ), MBH_cast( entity_handle2 ), adjacent_out );CHKERR( rval, "Failed to get adjacent info" );
    *are_adjacent = (int)adjacent_out;  // 0 or 1, really
void FBiGeom_isEntArrContained ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  containing_set,
int  num_entity_handles,
int **  is_contained,
int *  is_contained_allocated,
int *  is_contained_size,
int *  err
Return whether entities are contained in a set.
Return whether each entity is contained in the set.
Parameters:
instanceiMesh instance handle
containing_entity_setEntity set being queried
entity_handlesList of entities for which to check containment.
is_containedOne value for each input entity, 1 if contained in set, zero otherwise.
Definition at line 1914 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_isEntArrContained.
    iMesh_isEntArrContained( IMESH_INSTANCE( instance ), containing_set, entity_handles, num_entity_handles,
                             is_contained, is_contained_allocated, is_contained_size, err );
void FBiGeom_isEntContained ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  containing_entity_set,
iBase_EntityHandle  contained_entity,
int *  is_contained,
int *  err
Return whether an entity is contained in another set.
Return whether an entity is contained (*is_contained=1) or not contained (*is_contained=0) in another set
Parameters:
contained_entityEntity potentially contained in containing_entity_set
is_containedPointer to flag returned from function
Definition at line 1905 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_isEntContained.
    iMesh_isEntContained( IMESH_INSTANCE( instance ), containing_entity_set, contained_entity, is_contained, err );
void FBiGeom_isEntParametric ( FBiGeom_Instance  instance,
int *  parametric,
int *  err
Return whether an entity has a parameterization.
Return whether an entity has a parameterization (=1) or not (=0)
Parameters:
entity_handleEntity being queried
is_parametricEntity has a parameterization (=1) or not (=0)
Definition at line 1160 of file FBiGeom_MOAB.cpp.
References FBiGeom_getEntType, iBase_SUCCESS, and RETURN.
    int type = -1;
    if( type == 1 )
        *parametric = 1;  // true
    else
        *parametric = 0;  // false
void FBiGeom_isEntPeriodic ( FBiGeom_Instance  instance,
int *  in_u,
int *  in_v,
int *  err
Return whether an entity is periodic.
Return whether an entity is periodic (=1) or not (=0) in the u and v directions.
Parameters:
in_uEntity is periodic in u direction (=1) or not (=0)
in_vEntity is periodic in v direction (=1) or not (=0)
Definition at line 1563 of file FBiGeom_MOAB.cpp.
    *in_u = 0;
    *in_v = 0;
    *err  = 0;
    return;
void FBiGeom_isEntSetContained ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  contained_entity_set,
int *  is_contained,
int *  err
Return whether an entity set is contained in another set.
Return whether a set is contained (*is_contained=1) or not contained (*is_contained=0) in another set
Parameters:
contained_entity_setEntity set potentially contained in containing_entity_set
Definition at line 1927 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_isEntSetContained.
    iMesh_isEntSetContained( IMESH_INSTANCE( instance ), containing_entity_set, contained_entity_set, is_contained,
                             err );
void FBiGeom_isFcArrDegenerate ( FBiGeom_Instance  instance,
int **  degenerate,
int *  degenerate_allocated,
int *  degenerate_size,
int *  err
Return whether faces are degenerate.
Return whether faces are degenerate (=1) or not (=0).
Parameters:
degenerateface_handles[i] is degenerate (=1) or not (=0)
degenerate_allocatedAllocated size of degenerate array
degenerate_sizeOccupied size of degenerate array
Definition at line 1582 of file FBiGeom_MOAB.cpp.
void FBiGeom_isFcDegenerate ( FBiGeom_Instance  instance,
int *  is_degenerate,
int *  err
Return whether a face is degenerate.
Return whether a face is degenerate (=1) or not (=0).
Parameters:
is_degenerateFace is degenerate (=1) or not (=0)
Definition at line 1578 of file FBiGeom_MOAB.cpp.
void FBiGeom_isList ( FBiGeom_Instance  instance,
int *  is_list,
int *  err
Return whether a specified set is ordered or unordered.
Return whether a specified set is ordered (*is_list=1) or unordered (*is_list=0)
Parameters:
is_listPointer to flag returned from function
Definition at line 1790 of file FBiGeom_MOAB.cpp.
void FBiGeom_load ( FBiGeom_Instance  instance,
char const *  name,
char const *  options,
int *  err,
int  name_len,
int  options_len
Load a geom from a file.
Load a geom from a file. If entity set is specified, loaded geom is added to that set; specify zero if that is not desired.
Parameters:
entity_set_handleSet to which loaded geom will be added, zero if not desired
nameFile name from which geom is to be loaded
optionsPointer to implementation-specific options string
name_lenLength of the file name character string
options_lenLength of the options character string
Definition at line 133 of file FBiGeom_MOAB.cpp.
References CHKERR, ErrorCode, FBE_cast(), moab::GeomTopoTool::find_geomsets(), GETGTT, iBase_FAILURE, iBase_SUCCESS, moab::FBEngine::Init(), MBI, RETURN, and moab::FBEngine::set_smooth().
    // first remove option for smooth facetting
    const char smth[] = "SMOOTH;";
    bool smooth       = false;
    const char* res   = NULL;
    char* reducedOptions = NULL;
    bool localReduce     = false;
    if( options ) res = strstr( options, smth );
    if( res )
        // extract that option, will not be recognized by our moab/imesh
        reducedOptions = new char[options_len - 6];
        localReduce    = true;
        int preLen     = (int)( res - options );
        strncpy( reducedOptions, options, preLen );
        int postLen = options_len - 7 - preLen;
        char* tmp = reducedOptions + preLen;
        strncpy( tmp, res + 7, postLen );
        reducedOptions[options_len - 7] = 0;
        std::cout << reducedOptions << std::endl;
        smooth = true;
    else
        reducedOptions = const_cast< char* >( options );
    // load mesh-based geometry
    const EntityHandle* file_set = 0;
    ErrorCode rval               = MBI->load_file( name, file_set, reducedOptions );CHKERR( rval, "can't load mesh file" );
    if( localReduce ) delete[] reducedOptions;
    FBEngine* fbe = FBE_cast( instance );
    if( fbe == NULL )
        *err = iBase_FAILURE;
        return;
    if( gtt == NULL )
        return;
    // keep mesh-based geometries in Range
    rval = gtt->find_geomsets();CHKERR( rval, "Failure to find geometry lists." );
    if( smooth ) fbe->set_smooth();  // assumes that initialization did not happen yet
    fbe->Init();  // major computation
void FBiGeom_measure ( FBiGeom_Instance  instance,
double **  measures,
int *  measures_allocated,
int *  measures_size,
int *  err
Return the measure (length, area, or volume) of entities.
Parameters:
entity_handlesArray of entities being queried
entity_handles_sizeNumber of entities in entity array
measuresMeasures of entities being queried
measures_allocatedAllocated size of measures array
measures_sizeOccupied size of measures array
Definition at line 1126 of file FBiGeom_MOAB.cpp.
References CHECK_SIZE, CHKERR, ErrorCode, FBE_cast(), iBase_SUCCESS, moab::FBEngine::measure(), and RETURN.
    CHECK_SIZE( *measures, *measures_allocated, entity_handles_size, double, NULL );
    ErrorCode rval = FBE_cast( instance )->measure( (EntityHandle*)( entity_handles ), entity_handles_size, *measures );CHKERR( rval, "Failed to get measures" );
    *measures_size = entity_handles_size;
void FBiGeom_mergeEnts ( FBiGeom_Instance  instance,
double  tolerance,
int *  err
Merge ents.
Merge entities of corresponding topology/geometry within the specified tolerance.
Parameters:
toleranceTolerance within which entities are considered the same
Definition at line 1773 of file FBiGeom_MOAB.cpp.
void FBiGeom_moveEnt ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
int *  err
Move an entity by the given vector.
Move an entity by translating it along the given vector.
Parameters:
geom_entitythe entity to move
xx coordinate of the vector
yy coordinate of the vector
zz coordinate of the vector
Definition at line 1696 of file FBiGeom_MOAB.cpp.
void FBiGeom_newGeom ( char const *  options,
FBiGeom_Instance instance_out,
int *  err,
int  options_len
Construct a new FBiGeom instance.
Construct a new FBiGeom instance, using implementation-specific options
Parameters:
instancePointer to FBiGeom instance handle returned from function
options_lenLength of the character string pointed to by options
Definition at line 74 of file FBiGeom_MOAB.cpp.
References filter_options1(), and iBase_SUCCESS.
    std::string tmp_options = filter_options1( options, options + options_len );
    FileOptions opts( tmp_options.c_str() );
    // process some options?
    MBiGeom** mbigeom = reinterpret_cast< MBiGeom** >( instance_out );
    *mbigeom          = NULL;
    *mbigeom          = new MBiGeom();
    *err              = iBase_SUCCESS;
void FBiGeom_newGeomFromMesh ( iMesh_Instance  mesh,
iBase_EntitySetHandle  set,
const char *  options,
FBiGeom_Instance geom,
int *  err,
int
Definition at line 94 of file FBiGeom_MOAB.cpp.
References geom, iBase_SUCCESS, moab::FBEngine::Init(), MBiMesh::mbImpl, and mesh.
Referenced by main().
    MBiMesh* mbimesh           = reinterpret_cast< MBiMesh* >( mesh );
    moab::Interface* mbi       = mbimesh->mbImpl;
    moab::EntityHandle rootSet = reinterpret_cast< moab::EntityHandle >( set );
    moab::GeomTopoTool* gtt    = new moab::GeomTopoTool( mbi, true, rootSet );
    bool smooth                = false;  // decide from options
    const char* res            = strstr( options, smth );
    if( res != NULL ) smooth = true;
    moab::FBEngine* fbe = new moab::FBEngine( mbi, gtt, smooth );
    MBiGeom** mbigeom   = reinterpret_cast< MBiGeom** >( geom );
    *mbigeom            = NULL;
    *mbigeom            = new MBiGeom( mbimesh, fbe );
    // will do now the initialization of the engine;
    // heavy duty computation
    fbe->Init();
void FBiGeom_reflectEnt ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double  plane_normal_x,
double  plane_normal_y,
double  plane_normal_z,
int *  err
Reflect an entity across a plane.
Reflect an entity across the given plane
Parameters:
geom_entitythe entity to reflect,
point_xx coordinate of the point that the reflecting plane goes though
point_yy coordinate of the point that the reflecting plane goes though
point_zz coordinate of the point that the reflecting plane goes though
plane_normal_xx coordinate of the plane's normal
plane_normal_yy coordinate of the plane's normal
plane_normal_zz coordinate of the plane's normal
Definition at line 1706 of file FBiGeom_MOAB.cpp.
void FBiGeom_resetEntArrIter ( FBiGeom_Instance  instance,
int *  err
Reset the array iterator.
Parameters:
entArr_iteratorIterator to reset
Definition at line 1623 of file FBiGeom_MOAB.cpp.
void FBiGeom_resetEntIter ( FBiGeom_Instance  instance,
int *  err
Reset the iterator.
Reset the iterator
Parameters:
entity_iteratorIterator to reset
Definition at line 1618 of file FBiGeom_MOAB.cpp.
void FBiGeom_rmvArrTag ( FBiGeom_Instance  instance,
int *  err
Remove a tag value from an array of entities.
Parameters:
entity_handlesEntity from which tag is being removed
tag_handleTag handle of tag being removed
Definition at line 2289 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_rmvArrTag.
    iMesh_rmvArrTag( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, err );
void FBiGeom_rmvEntArrFromSet ( FBiGeom_Instance  instance,
int *  err
Remove an array of entities from a set.
Parameters:
entity_handlesArray of entities being remove
entity_handles_sizeNumber of entities in entity_handles array
entity_setPointer to the set being removed from
Definition at line 1880 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_rmvEntArrFromSet.
    iMesh_rmvEntArrFromSet( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, entity_set, err );
void FBiGeom_rmvEntFromSet ( FBiGeom_Instance  instance,
int *  err
Remove an entity from a set.
Parameters:
entity_handleThe entity being removed
Definition at line 1863 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_rmvEntFromSet.
    iMesh_rmvEntFromSet( IMESH_INSTANCE( instance ), entity_handle, entity_set, err );
void FBiGeom_rmvEntSet ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  entity_set_to_remove,
int *  err
Remove an entity set from a set.
Parameters:
entity_set_to_removeThe entity set being removed
entity_set_handlePointer to the set being removed from
Definition at line 1897 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_rmvEntSet.
    iMesh_rmvEntSet( IMESH_INSTANCE( instance ), entity_set_to_remove, entity_set_handle, err );
void FBiGeom_rmvEntSetTag ( FBiGeom_Instance  instance,
int *  err
Remove a tag value from an entity set.
Parameters:
entity_set_handleEntity set from which tag is being removed
Definition at line 2156 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_rmvEntSetTag.
    iMesh_rmvEntSetTag( IMESH_INSTANCE( instance ), entity_set_handle, tag_handle, err );
void FBiGeom_rmvPrntChld ( FBiGeom_Instance  instance,
int *  err
Remove parent/child links between two sets.
Parameters:
Definition at line 1945 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_rmvPrntChld.
    iMesh_rmvPrntChld( IMESH_INSTANCE( instance ), parent_entity_set, child_entity_set, err );
void FBiGeom_rmvTag ( FBiGeom_Instance  instance,
int *  err
Remove a tag value from an entity.
Parameters:
entity_handleEntity from which tag is being removed
Definition at line 2403 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_rmvTag.
    iMesh_rmvTag( IMESH_INSTANCE( instance ), entity_handle, tag_handle, err );
void FBiGeom_rotateEnt ( FBiGeom_Instance  instance,
double  angle,
double  axis_x,
double  axis_y,
double  axis_z,
int *  err
Rotate an entity about an axis.
Rotate an entity by the given angle about the given axis.
Parameters:
geom_entitythe entity to rotate
anglethe rotational angle, in degrees
axis_xx coordinate of the axis
axis_yy coordinate of the axis
axis_zz coordinate of the axis
Definition at line 1701 of file FBiGeom_MOAB.cpp.
void FBiGeom_save ( FBiGeom_Instance  instance,
char const *  name,
int *  err,
int  name_len,
int  options_len
Save a geom to a file.
Save a geom to a file. If entity set is specified, save only the geom contained in that set.
Parameters:
entity_set_handleEntity set being saved
nameFile name to which geom is to be saved
Definition at line 191 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_save.
    iMesh_save( IMESH_INSTANCE( instance ), NULL, name, options, err, name_len, options_len );
void FBiGeom_scaleEnt ( FBiGeom_Instance  instance,
double  x,
double  y,
double  z,
double  scale_x,
double  scale_y,
double  scale_z,
int *  err
Scale an entity in the x, y, and z directions.
Parameters:
geom_entitythe entity to scale,
point_xx coordinate of the scaling center
point_yy coordinate of the scaling center
point_zz coordinate of the scaling center
scale_xfactor to scale by in the x direction
scale_yfactor to scale by in the y direction
scale_zfactor to scale by in the z direction
Definition at line 1719 of file FBiGeom_MOAB.cpp.
void FBiGeom_sectionEnt ( FBiGeom_Instance  instance,
double  offset,
int  reverse,
iBase_EntityHandle geom_entity2,
int *  err
Section (cut) a region with a plane.
Section (cut) a region with a plane, retaining one of the pieces and discarding the other.
Parameters:
geom_entityThe entity to section
offsetDistance of the plane from the origin
reverseKeep the piece on the normal's side (=0) or not (=1)
geom_entity2Pointer to new entity handle returned from function
Definition at line 1755 of file FBiGeom_MOAB.cpp.
void FBiGeom_setArrData ( FBiGeom_Instance  instance,
const void *  tag_values,
int  tag_values_size,
int *  err
Set tag values of arbitrary type on an array of entities.
Set tag values of arbitrary type on an array of entities. Tag data is passed as void*. tag_values_size specifies the size of the memory pointed to by tag_values in terms of bytes. Applications may use this function to set data of any type, not just iBase_BYTES. However, because this function supports data of arbitrary type, in all cases the size specified by tag_values_size is always in terms of bytes.
Parameters:
entity_handlesEntity array on which tag is being set
entity_handles_sizeNumber of entities in array
tag_valuesPointer to tag data being set on entity. Note that the implicit INTERLEAVED storage order rule applies (see section ITAPS Storage Orders)
tag_values_sizeSize in bytes of tag data
Definition at line 2229 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setArrData.
    iMesh_setArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_values,
                      tag_values_size, err );
void FBiGeom_setData ( FBiGeom_Instance  instance,
iBase_EntityHandle  entity_handle,
const void *  tag_value,
int  tag_value_size,
int *  err
Set a tag value of arbitrary type on an entity.
Set a tag value of arbitrary type on an entity. Tag data is passed as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications may use this function to set data of any type, not just iBase_BYTES. However, because this function supports data of arbitrary type, in all cases the size specified by tag_value_size is always in terms of bytes.
Parameters:
entity_handleEntity on which tag is being set
tag_valuePointer to tag data being set on entity
tag_value_sizeSize in bytes of tag data
Definition at line 2346 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setData.
    iMesh_setData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, tag_value, tag_value_size, err );
void FBiGeom_setDblArrData ( FBiGeom_Instance  instance,
const double *  tag_values,
const int  tag_values_size,
int *  err
Set tag values of double type on an array of entities.
Parameters:
tag_valuesPointer to tag data being set on entities
tag_values_sizeSize in total number of doubles of tag data
Definition at line 2253 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setDblArrData.
    iMesh_setDblArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_values,
void FBiGeom_setDblData ( FBiGeom_Instance  instance,
double  tag_value,
int *  err
Set a tag value of double type on an entity.
Parameters:
tag_valueTag value being set on entity
Definition at line 2365 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setDblData.
    iMesh_setDblData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, tag_value, err );
void FBiGeom_setEHArrData ( FBiGeom_Instance  instance,
const iBase_EntityHandle tag_values,
int *  err
Set tag values of entity handle type on an array of entities.
Parameters:
tag_values_sizeSize in total number of entity handles of tag data
Definition at line 2265 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setEHArrData.
    iMesh_setEHArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_values,
void FBiGeom_setEHData ( FBiGeom_Instance  instance,
iBase_TagHandle  tag_handle,
iBase_EntityHandle  tag_value,
int *  err
Set a tag value of entity handle type on an entity.
Parameters:
Definition at line 2374 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setEHData.
    iMesh_setEHData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, tag_value, err );
void FBiGeom_setEntSetData ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  entity_set_handle,
const iBase_TagHandle  tag_handle,
const int  tag_value_size,
int *  err
Set a tag value of arbitrary type on an entity set.
Set a tag value of arbitrary type on an entity set. The tag data is passed as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications are free to use this function to set data of any type, not just iBase_BYTES. However, in all cases, the size specified by tag_value_size is always in terms of bytes.
Parameters:
entity_set_handleEntity set on which tag is being set
tag_handleTag being set on an entity set
tag_valuePointer to tag data being set on entity set
Definition at line 2051 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setEntSetData.
    iMesh_setEntSetData( IMESH_INSTANCE( instance ), entity_set_handle, tag_handle, tag_value, tag_value_size, err );
void FBiGeom_setEntSetDblData ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  entity_set,
double  tag_value,
int *  err
Set a tag value of double type on an entity set.
Parameters:
instanceFBiGeom instance handle
entity_setEntity set on which tag is being set
tag_valueTag value being set on entity set
*errPointer to error type returned from function
Definition at line 2070 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setEntSetDblData.
    iMesh_setEntSetDblData( IMESH_INSTANCE( instance ), entity_set, tag_handle, tag_value, err );
void FBiGeom_setEntSetEHData ( FBiGeom_Instance  instance,
int *  err
Set a tag value of entity handle type on an entity set.
Parameters:
Definition at line 2079 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setEntSetEHData.
    iMesh_setEntSetEHData( IMESH_INSTANCE( instance ), entity_set, tag_handle, tag_value, err );
void FBiGeom_setEntSetESHData ( FBiGeom_Instance  instance,
iBase_EntitySetHandle  tag_value,
int *  err
Set a tag value of entity set handle type on an entity set.
Parameters:
Definition at line 2088 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setEntSetESHData.
    iMesh_setEntSetESHData( IMESH_INSTANCE( instance ), entity_set, tag_handle, tag_value, err );
void FBiGeom_setEntSetIntData ( FBiGeom_Instance  instance,
int  tag_value,
int *  err
Set a tag value of integer type on an entity set.
Parameters:
Definition at line 2061 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setEntSetIntData.
    iMesh_setEntSetIntData( IMESH_INSTANCE( instance ), entity_set, tag_handle, tag_value, err );
void FBiGeom_setESHArrData ( FBiGeom_Instance  instance,
const iBase_EntitySetHandle tag_values,
int *  err
Set tag values of entity set handle type on an array of entities.
Parameters:
Definition at line 2277 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setESHArrData.
    iMesh_setESHArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_values,
void FBiGeom_setESHData ( FBiGeom_Instance  instance,
int *  err
Set a tag value of entity set handle type on an entity.
Parameters:
Definition at line 2383 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setESHData.
    iMesh_setESHData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, tag_value, err );
void FBiGeom_setIntArrData ( FBiGeom_Instance  instance,
const int *  tag_values,
int *  err
Set tag values of integer type on an array of entities.
Parameters:
tag_values_sizeSize in total number of integers of tag data
Definition at line 2241 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setIntArrData.
    iMesh_setIntArrData( IMESH_INSTANCE( instance ), entity_handles, entity_handles_size, tag_handle, tag_values,
void FBiGeom_setIntData ( FBiGeom_Instance  instance,
int  tag_value,
int *  err
Set a tag value of integer type on an entity.
Parameters:
Definition at line 2356 of file FBiGeom_MOAB.cpp.
References IMESH_INSTANCE, and iMesh_setIntData.
    iMesh_setIntData( IMESH_INSTANCE( instance ), entity_handle, tag_handle, tag_value, err );
void FBiGeom_subtract ( FBiGeom_Instance  instance,
int *  err
Subtract contents of one entity set from another.
Parameters:
entity_set_1Entity set from which other set is being subtracted
entity_set_2Entity set being subtracted from other set
Definition at line 2408 of file FBiGeom_MOAB.cpp.
void FBiGeom_subtractEnts ( FBiGeom_Instance  instance,
iBase_EntityHandle  blank,
iBase_EntityHandle  tool,
int *  err
Geometrically subtract one entity from another.
Geometrically subtract the entity tool from the entity blank.
Parameters:
blankThe entity to subtract from
toolThe entity to subtract
Definition at line 1737 of file FBiGeom_MOAB.cpp.
void FBiGeom_sweepEntAboutAxis ( FBiGeom_Instance  instance,
double  angle,
double  axis_x,
double  axis_y,
double  axis_z,
int *  err
Sweep (extrude) an entity about an axis.
Sweep (extrude) an entity by the given angle about the given axis.
Parameters:
Definition at line 1643 of file FBiGeom_MOAB.cpp.
void FBiGeom_unite ( FBiGeom_Instance  instance,
int *  err
Unite contents of one entity set with another.
Parameters:
entity_set_1Entity set being united with another
entity_set_2Entity set being united with another
Definition at line 2426 of file FBiGeom_MOAB.cpp.
void FBiGeom_uniteEnts ( FBiGeom_Instance  instace,
int *  err
Geometrically unite entities.
Geometrically unite the specified entities.
Parameters:
geom_entitiesArray of entity handles being united
Definition at line 1732 of file FBiGeom_MOAB.cpp.
References iBase_NOT_SUPPORTED, and RETURN.
static std::string filter_options1 ( const char *  begin,
const char *  end
) [static]
Definition at line 23 of file FBiGeom_MOAB.cpp.
References compare_no_case1(), and moab::GeomUtil::first().
Referenced by FBiGeom_newGeom().
    const char* opt_begin = begin;
    const char* opt_end   = begin;
    std::string filtered;
    bool first = true;
    while( opt_end != end )
        opt_end = std::find( opt_begin, end, ' ' );
        if( opt_end - opt_begin >= 5 && compare_no_case1( opt_begin, "moab:", 5 ) == 0 )
            if( !first ) filtered.push_back( ';' );
            first = false;
            filtered.append( opt_begin + 5, opt_end );
        opt_begin = opt_end + 1;
    return filtered;
Variable Documentation
bool debug_igeom = false
Definition at line 47 of file FBiGeom_MOAB.cpp.
bool Debug_surf_eval = false
Definition at line 48 of file FBiGeom_MOAB.cpp.
