FileRead.cpp File Reference
#include <iostream>
#include <fstream>
#include <vector>
#include <string>
#include <sstream>
#include "moab/Core.hpp"
#include "moab/ReadUtilIface.hpp"
+ Include dependency graph for FileRead.cpp:
Functions
int comment (string &line)
ErrorCode ReadTriangleOutput (Interface *mb, string fileBase)
int main (int argc, char **argv)
Function Documentation
int comment ( string &  line)
Definition at line 13 of file FileRead.cpp.
Referenced by ReadTriangleOutput().
    // if a line starts with '#' is a comment
    // eat white space characters
    size_t found = line.find_first_not_of( " \t" );
    if( found == string::npos ) return 1;  // empty line
    if( '#' == line[found] ) return 1;     // a comment indeed
    return 0;                              // a line with some data in it, then
int main ( int  argc,
char **  argv
Definition at line 137 of file FileRead.cpp.
References ErrorCode, filename, mb, MB_SUCCESS, outfile, ReadTriangleOutput(), and moab::Core::write_file().
    if( 3 != argc )
        cout << "Usage: " << argv[0] << " <filename>  <outFile> " << endl;
        cout << "       <filename>  is the base file name; *.ele and *.node file are read; outFile "
                "is a file with an extension recognized by MOAB "
             << endl;
        return 0;
    string filename = argv[1];
    char* outfile   = argv[2];
    // get MOAB instance and read the file
    Core* mb = new Core();
    ErrorCode rval = ReadTriangleOutput( mb, filename );
    if( rval == MB_SUCCESS )
        cout << "Writing output file " << outfile << endl;
        mb->write_file( outfile );
    delete mb;
    return 0;
ErrorCode ReadTriangleOutput ( Interface mb,
string  fileBase
Definition at line 22 of file FileRead.cpp.
References comment(), ErrorCode, moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), iface, MB_FILE_DOES_NOT_EXIST, MB_SUCCESS, MBTRI, moab::Interface::query_interface(), and moab::Interface::release_interface().
Referenced by main().
    // get the read interface from moab
    ReadUtilIface* iface;
    ErrorCode rval = mb->query_interface( iface );
    if( MB_SUCCESS != rval )
        cout << "Can't get interface.\n";
        return MB_FAILURE;
    // Triangle default <name>.node
    string nodeFileName = fileBase + ".node";
    ifstream nodeFile( nodeFileName.c_str() );
    if( !nodeFile.is_open() )
        cout << "can't open node file .\n";
        return MB_FILE_DOES_NOT_EXIST;
    cout << "reading nodes from file " << nodeFileName.c_str() << endl;
    string eleFileName = fileBase + ".ele";
    ifstream eleFile( eleFileName.c_str() );
    if( !eleFile.is_open() )
        cout << "can't open element file .\n";
    cout << "reading elements from file " << eleFileName.c_str() << endl;
    string line;
    // ignore comment lines that start with #
    int num_nodes = 0, num_triangles = 0;
    while( num_nodes == 0 )
        getline( nodeFile, line );
        if( comment( line ) ) continue;
        stringstream tks( line );
        tks >> num_nodes;  // ignore the rest of the first line
                           // maybe will read attributes some other time
        cout << "num nodes:" << num_nodes << endl;
    //  allocate a block of vertex handles and read xyz’s into them
    //  we know the size of the node arrays, and this call will allocate
    //   needed arrays, coordinate arrays
    //   also, it will return a starting handle for the node sequence
    vector< double* > arrays;
    EntityHandle startv;
    rval = iface->get_node_coords( 2, num_nodes, 0, startv, arrays );
    for( int i = 0; i < num_nodes; i++ )
            i--;  // read one more line
            continue;
        stringstream tokens( line );
        int nodeId;
        tokens >> nodeId >> arrays[0][i] >> arrays[1][i];
    // now read the element data from a different file
    // first, find out how many elements are out there
    // first line with data should have it
    while( num_triangles == 0 )
        getline( eleFile, line );
        tks >> num_triangles;  // ignore the rest of the line
        cout << "num triangles:" << num_triangles << endl;
    EntityHandle starte;
    EntityHandle* starth;  // the connectivity array that will get populated
                           // with triangle data
    // allocate block of triangle handles and read connectivity into them
    rval = iface->get_element_connect( num_triangles, 3, MBTRI, 0, starte, starth );
    for( int j = 0; j < num_triangles; j++ )
            j--;  // read one more line
            continue;
        int eleId;
        unsigned int node;
        tokens >> eleId;
        for( int k = 0; k < 3; k++ )
            tokens >> node;
            // vertex handles start at startv
            starth[3 * j + k] = startv + node - 1;
    mb->release_interface( iface );
    return MB_SUCCESS;
