GeomSetHierarchy.cpp
00001 #include "moab/Core.hpp"
00002 #include "moab/Range.hpp"
00003 #include "MBCN.hpp"
00004 #include "MBTagConventions.hpp"
00005 #include "moab/GeomTopoTool.hpp"
00006 #include <iostream>
00007 #include <cassert>
00008
00009 const char* ent_names[] = { "Vertex", "Edge", "Face", "Region" };
00010
00011 int main( int argc, char** argv )
00012 {
00013     if( 1 == argc )
00014     {
00015         std::cout << "Usage: " << argv[0] << " <filename>" << std::endl;
00016         return 0;
00017     }
00018
00019     // instantiate & load a file
00020     moab::Interface* mb  = new moab::Core();
00021     moab::ErrorCode rval = mb->load_file( argv[1] );
00022     assert( moab::MB_SUCCESS == rval );
00023
00024     // get the geometric topology tag handle
00025     moab::Tag geom_tag, gid_tag;
00026     rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, moab::MB_TYPE_INTEGER, geom_tag );
00027     assert( moab::MB_SUCCESS == rval );
00028     gid_tag = mb->globalId_tag();
00029     assert( NULL != gid_tag );
00030
00031     // traverse the model, from dimension 3 downward
00032     moab::Range psets, chsets;
00033     std::vector< moab::EntityHandle > sense_ents;
00034     std::vector< int > senses;
00035     int dim, pgid, chgid;
00036     void* dim_ptr = &dim;
00037     int sense;
00038
00039     moab::GeomTopoTool gt( mb, true );
00040
00041     for( dim = 3; dim >= 0; dim-- )
00042     {
00043         // get parents at this dimension
00044         chsets.clear();
00045         rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, &dim_ptr, 1, chsets, 1, false );
00046         assert( moab::MB_SUCCESS == rval );
00047
00048         // for each child, get parents and do something with them
00049         moab::Range::iterator ch_it, p_it;
00050         for( ch_it = chsets.begin(); ch_it != chsets.end(); ++ch_it )
00051         {
00052             // get the children and put in child set list
00053             psets.clear();
00054             rval = mb->get_parent_meshsets( *ch_it, psets );
00055             assert( moab::MB_SUCCESS == rval );
00056
00057             rval = mb->tag_get_data( gid_tag, &( *ch_it ), 1, &chgid );
00058             assert( moab::MB_SUCCESS == rval );
00059
00060             // print # parents
00061             std::cout << ent_names[dim] << " " << chgid << " has " << psets.size() << " parents." << std::endl;
00062
00063             if( 2 == dim )
00064             {
00065                 for( p_it = psets.begin(); p_it != psets.end(); ++p_it )
00066                 {
00067                     rval = mb->tag_get_data( gid_tag, &( *p_it ), 1, &pgid );
00068                     assert( moab::MB_SUCCESS == rval );
00069                     rval = gt.get_sense( *ch_it, *p_it, sense );
00070                     if( moab::MB_SUCCESS != rval ) continue;
00071                     std::cout << ent_names[dim + 1] << " " << pgid << ", " << ent_names[dim] << " " << chgid
00072                               << " sense is: ";
00073                     if( 1 == sense )
00074                         std::cout << "FORWARD" << std::endl;
00075                     else
00076                         std::cout << "REVERSE" << std::endl;
00077                 }
00078             }
00079             else if( 1 == dim )
00080             {
00081                 sense_ents.clear();
00082                 senses.clear();
00083                 rval = gt.get_senses( *ch_it, sense_ents, senses );
00084                 if( moab::MB_SUCCESS != rval ) continue;
00085                 for( unsigned int i = 0; i < sense_ents.size(); i++ )
00086                 {
00087                     rval = mb->tag_get_data( gid_tag, &sense_ents[i], 1, &pgid );
00088                     assert( moab::MB_SUCCESS == rval );
00089                     std::cout << ent_names[dim + 1] << " " << pgid << ", " << ent_names[dim] << " " << chgid
00090                               << " sense is: ";
00091                     if( -1 == senses[i] )
00092                         std::cout << "REVERSED" << std::endl;
00093                     else if( 0 == senses[i] )
00094                         std::cout << "BOTH" << std::endl;
00095                     else if( 1 == senses[i] )
00096                         std::cout << "FORWARD" << std::endl;
00097                     else
00098                         std::cout << "(invalid)" << std::endl;
00099                 }
00100             }
00101         }
00102     }
00103
00104     delete mb;
00105
00106     return 0;
00107 }
