HelloMOAB.cpp
00001 /** @example HelloMOAB.cpp
00002  * Description: read a mesh, get the entities.\n
00003  * HelloMOAB is a simple test file which is used to read meshes from VTK file and test how many
00004  * entities there are.\n
00005  *
00006  * To run: ./HelloMOAB [meshfile]\n
00007  * (default values can run if users don't specify a mesh file)
00008  */
00009
00010 #include "moab/Core.hpp"
00011 #include <iostream>
00012
00013 using namespace moab;
00014 using namespace std;
00015
00016 #ifndef MESH_DIR
00017 #define MESH_DIR "."
00018 #endif
00019
00020 // Note: change the file name below to test a trivial "No such file or directory" error
00021 string test_file_name = string( MESH_DIR ) + string( "/3k-tri-sphere.vtk" );
00022
00023 int main( int argc, char** argv )
00024 {
00025     // Get MOAB instance
00026     Interface* mb = new( std::nothrow ) Core;
00027     if( NULL == mb ) return 1;
00028
00029     // Need option handling here for input filename
00030     if( argc > 1 )
00031     {
00032         // User has input a mesh file
00033         test_file_name = argv[1];
00034     }
00035
00036     // Load the mesh from vtk file
00037     ErrorCode rval = mb->load_mesh( test_file_name.c_str() );MB_CHK_ERR( rval );
00038
00039     // Get verts entities, by type
00040     Range verts;
00041     rval = mb->get_entities_by_type( 0, MBVERTEX, verts );MB_CHK_ERR( rval );
00042
00043     // Get edge entities, by type
00044     Range edges;
00045     rval = mb->get_entities_by_type( 0, MBEDGE, edges );MB_CHK_ERR( rval );
00046
00047     // Get faces, by dimension, so we stay generic to entity type
00048     Range faces;
00049     rval = mb->get_entities_by_dimension( 0, 2, faces );MB_CHK_ERR( rval );
00050
00051     // Get regions, by dimension, so we stay generic to entity type
00052     Range elems;
00053     rval = mb->get_entities_by_dimension( 0, 3, elems );MB_CHK_ERR( rval );
00054
00055     // Output the number of entities
00056     cout << "Number of vertices is " << verts.size() << endl;
00057     cout << "Number of edges is " << edges.size() << endl;
00058     cout << "Number of faces is " << faces.size() << endl;
00059     cout << "Number of elements is " << elems.size() << endl;
00060
00061     delete mb;
00062
00063     return 0;
00064 }
