MOAB: Mesh Oriented datABase  (version 5.1.1)
HexLagrangeShapeTest.cpp File Reference
#include "Mesquite.hpp"
#include "HexLagrangeShape.hpp"
#include "TopologyInfo.hpp"
#include "MsqError.hpp"
#include "IdealElements.hpp"
#include "JacobianCalculator.hpp"
#include "UnitUtil.hpp"
#include <vector>
#include <algorithm>
#include <iostream>
#include <sstream>
+ Include dependency graph for HexLagrangeShapeTest.cpp:
Classes
class  HexLagrangeShapeTest
Defines
#define ASSERT_VALUES_EQUAL(v1, v2, location)   ASSERT_MESSAGE( value_message( (location), (v1), (v2) ), test_value((v1), (v2)) )
Typedefs
typedef double(* f_t )(double)
Enumerations
enum  { XI = 0, ETA = 1, ZETA = 2 }
Functions
static bool test_value (double v1, double v2)
static CppUnit::Message value_message (unsigned location, double v1, double v2)
static bool test_value (MsqVector< 3 > v1, MsqVector< 3 > v2)
static CppUnit::Message value_message (unsigned location, MsqVector< 3 > v1, MsqVector< 3 > v2)
 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (HexLagrangeShapeTest,"HexLagrangeShapeTest")
 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (HexLagrangeShapeTest,"Unit")
static double l21 (double xi)
static double l22 (double xi)
static double l23 (double xi)
static double dl21 (double xi)
static double dl22 (double xi)
static double dl23 (double xi)
static MsqVector< 3 > XI_corner (int i)
static MsqVector< 3 > XI_edge (int i)
static MsqVector< 3 > XI_face (int i)
static MsqVector< 3 > XI_elem ()
static double N (int i, MsqVector< 3 > xi)
static MsqVector< 3 > dN (int i, MsqVector< 3 > xi)
static void get_coeffs (MsqVector< 3 > xi, double coeffs_out[27])
static void get_derivs (MsqVector< 3 > xi, MsqVector< 3 > derivs_out[27])
static void check_valid_indices (const size_t *vertices, size_t num_vtx)
static void check_no_zeros (const MsqVector< 3 > *derivs, size_t num_vtx)
static void compare_coefficients (const double *coeffs, const size_t *indices, size_t num_coeff, const double *expected_coeffs, unsigned loc)
static void compare_derivatives (const size_t *vertices, size_t num_vtx, const MsqVector< 3 > *actual, const MsqVector< 3 > *expected, unsigned loc)
Variables
const double epsilon = 1e-6
const double min_xi = 0
const double max_xi = 1
const double mid_xi = 0.5*(min_xi + max_xi)
f_t l [4] = { 0, &l21, &l22, &l23 }
f_t dl [4] = { 0, &dl21, &dl22, &dl23 }
const int C [][3]
const double corners [8][3]
Detailed Description
Author:
Jason Kraftcheck
Definition in file HexLagrangeShapeTest.cpp.
Define Documentation
#define ASSERT_VALUES_EQUAL (   v1,
  v2,
  location
Definition at line 50 of file HexLagrangeShapeTest.cpp.
Referenced by compare_coefficients(), and compare_derivatives().
Typedef Documentation
typedef double(* f_t)(double)
Definition at line 185 of file HexLagrangeShapeTest.cpp.
Enumeration Type Documentation
anonymous enum
Enumerator:
XI
ETA
ZETA
Definition at line 170 of file HexLagrangeShapeTest.cpp.
{ XI = 0, ETA = 1, ZETA = 2 };
Function Documentation
static void check_no_zeros ( const MsqVector< 3 > *  derivs,
size_t  num_vtx
) [static]
Definition at line 306 of file HexLagrangeShapeTest.cpp.
References CPPUNIT_ASSERT, and MBMesquite::length().
Referenced by compare_derivatives().
  for (unsigned i = 0; i < num_vtx; ++i) {
    CPPUNIT_ASSERT( length(derivs[i]) > 1e-6 );
static void check_valid_indices ( const size_t *  vertices,
size_t  num_vtx
) [static]
Definition at line 291 of file HexLagrangeShapeTest.cpp.
References CPPUNIT_ASSERT.
    // check valid size of list (at least fout, at most all nodes)
  CPPUNIT_ASSERT( num_vtx <= 27 );
  CPPUNIT_ASSERT( num_vtx >= 4 );
    // make sure vertex indices are valid (in [0,26])
  size_t vertcopy[27];
  std::copy( vertices, vertices+num_vtx, vertcopy );
  std::sort( vertcopy, vertcopy+num_vtx );
  CPPUNIT_ASSERT( vertcopy[num_vtx-1] <= 26 ); // max value less than 27
    // make sure there are no duplicates in the list
  const size_t* iter = std::unique( vertcopy, vertcopy+num_vtx );
  CPPUNIT_ASSERT( iter == vertcopy+num_vtx );
static void compare_coefficients ( const double *  coeffs,
const size_t *  indices,
size_t  num_coeff,
const double *  expected_coeffs,
unsigned  loc
) [static]
Definition at line 313 of file HexLagrangeShapeTest.cpp.
References ASSERT_VALUES_EQUAL.
Referenced by HexLagrangeShapeTest::test_corner_coeff(), HexLagrangeShapeTest::test_edge_coeff(), HexLagrangeShapeTest::test_face_coeff(), and HexLagrangeShapeTest::test_mid_coeff().
    // find the location in the returned list for each node
  size_t revidx[27];
  double test_vals[27];
  for (size_t i = 0; i < 27; ++i) {
    revidx[i] = std::find( indices, indices+num_coeff, i ) - indices;
    test_vals[i] = (revidx[i] == num_coeff) ? 0.0 : coeffs[revidx[i]];
    // compare expected and actual coefficient values
  ASSERT_VALUES_EQUAL( expected_coeffs[0], test_vals[0], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[1], test_vals[1], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[2], test_vals[2], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[3], test_vals[3], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[4], test_vals[4], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[5], test_vals[5], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[6], test_vals[6], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[7], test_vals[7], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[8], test_vals[8], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[9], test_vals[9], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[10], test_vals[10], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[11], test_vals[11], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[12], test_vals[12], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[13], test_vals[13], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[14], test_vals[14], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[15], test_vals[15], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[16], test_vals[16], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[17], test_vals[17], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[18], test_vals[18], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[19], test_vals[19], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[20], test_vals[20], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[21], test_vals[21], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[22], test_vals[22], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[23], test_vals[23], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[24], test_vals[24], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[25], test_vals[25], loc );
  ASSERT_VALUES_EQUAL( expected_coeffs[26], test_vals[26], loc );
static void compare_derivatives ( const size_t *  vertices,
size_t  num_vtx,
const MsqVector< 3 > *  actual,
const MsqVector< 3 > *  expected,
unsigned  loc
) [static]
Definition at line 357 of file HexLagrangeShapeTest.cpp.
References ASSERT_VALUES_EQUAL, check_no_zeros(), check_valid_indices(), and CPPUNIT_ASSERT.
Referenced by HexLagrangeShapeTest::test_corner_derivs(), HexLagrangeShapeTest::test_edge_derivs(), HexLagrangeShapeTest::test_face_derivs(), and HexLagrangeShapeTest::test_mid_derivs().
  check_valid_indices( vertices, num_vtx );
  check_no_zeros( actual, num_vtx );
    // Input has values in dxi & deta & dzeta only for nodes in 'vertices'
    // Convert to values for every possible node, with zero's for
    // nodes that are not present.
  CPPUNIT_ASSERT(num_vtx <= 9);
  MsqVector<3> expanded[27];
  std::fill( expanded, expanded+27,MsqVector<3>(0.0) );
    CPPUNIT_ASSERT(vertices[i] <= 26);
    expanded[vertices[i]] = actual[i];
  ASSERT_VALUES_EQUAL( expected[0], expanded[0], loc );
  ASSERT_VALUES_EQUAL( expected[1], expanded[1], loc );
  ASSERT_VALUES_EQUAL( expected[2], expanded[2], loc );
  ASSERT_VALUES_EQUAL( expected[3], expanded[3], loc );
  ASSERT_VALUES_EQUAL( expected[4], expanded[4], loc );
  ASSERT_VALUES_EQUAL( expected[5], expanded[5], loc );
  ASSERT_VALUES_EQUAL( expected[6], expanded[6], loc );
  ASSERT_VALUES_EQUAL( expected[7], expanded[7], loc );
  ASSERT_VALUES_EQUAL( expected[8], expanded[8], loc );
  ASSERT_VALUES_EQUAL( expected[9], expanded[9], loc );
  ASSERT_VALUES_EQUAL( expected[10], expanded[10], loc );
  ASSERT_VALUES_EQUAL( expected[11], expanded[11], loc );
  ASSERT_VALUES_EQUAL( expected[12], expanded[12], loc );
  ASSERT_VALUES_EQUAL( expected[13], expanded[13], loc );
  ASSERT_VALUES_EQUAL( expected[14], expanded[14], loc );
  ASSERT_VALUES_EQUAL( expected[15], expanded[15], loc );
  ASSERT_VALUES_EQUAL( expected[16], expanded[16], loc );
  ASSERT_VALUES_EQUAL( expected[17], expanded[17], loc );
  ASSERT_VALUES_EQUAL( expected[18], expanded[18], loc );
  ASSERT_VALUES_EQUAL( expected[19], expanded[19], loc );
  ASSERT_VALUES_EQUAL( expected[20], expanded[20], loc );
  ASSERT_VALUES_EQUAL( expected[21], expanded[21], loc );
  ASSERT_VALUES_EQUAL( expected[22], expanded[22], loc );
  ASSERT_VALUES_EQUAL( expected[23], expanded[23], loc );
  ASSERT_VALUES_EQUAL( expected[24], expanded[24], loc );
  ASSERT_VALUES_EQUAL( expected[25], expanded[25], loc );
  ASSERT_VALUES_EQUAL( expected[26], expanded[26], loc );
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION ( HexLagrangeShapeTest  ,
static double dl21 ( double  xi) [static]
Definition at line 181 of file HexLagrangeShapeTest.cpp.
{ return 4 * xi - 3; }
static double dl22 ( double  xi) [static]
Definition at line 182 of file HexLagrangeShapeTest.cpp.
References MBMesquite::xi.
{ return  4 - 8 * xi; }
static double dl23 ( double  xi) [static]
Definition at line 183 of file HexLagrangeShapeTest.cpp.
{ return  4 * xi - 1; }
static MsqVector<3> dN ( int  i,
MsqVector< 3 >  xi
) [static]
Definition at line 267 of file HexLagrangeShapeTest.cpp.
References C, dl, ETA, l, XI, and ZETA.
Referenced by get_derivs().
  MsqVector<3> result;
  const int* c = C[i];
  result[XI  ] = dl[c[XI]](xi[XI]) *  l[c[ETA]](xi[ETA]) *  l[c[ZETA]](xi[ZETA]);
  result[ETA ] =  l[c[XI]](xi[XI]) * dl[c[ETA]](xi[ETA]) *  l[c[ZETA]](xi[ZETA]);
  result[ZETA] =  l[c[XI]](xi[XI]) *  l[c[ETA]](xi[ETA]) * dl[c[ZETA]](xi[ZETA]);
  return result;
static void get_coeffs ( MsqVector< 3 >  xi,
) [static]
Definition at line 277 of file HexLagrangeShapeTest.cpp.
References N.
  for (int i = 0; i < 27; ++i)
    coeffs_out[i] = N(i, xi);
static void get_derivs ( MsqVector< 3 >  xi,
) [static]
static double l21 ( double  xi) [static]
Definition at line 177 of file HexLagrangeShapeTest.cpp.
{ return (2 * xi - 1) * (xi - 1); }
static double l22 ( double  xi) [static]
Definition at line 178 of file HexLagrangeShapeTest.cpp.
{ return 4 * xi * (1 - xi); }
static double l23 ( double  xi) [static]
Definition at line 179 of file HexLagrangeShapeTest.cpp.
{ return xi * (2 * xi - 1); }
static double N ( int  i,
MsqVector< 3 >  xi
) [static]
Definition at line 261 of file HexLagrangeShapeTest.cpp.
References C, ETA, l, XI, and ZETA.
  return l[c[XI]](xi[XI]) * l[c[ETA]](xi[ETA]) * l[c[ZETA]](xi[ZETA]);
static bool test_value ( MsqVector< 3 >  v1,
MsqVector< 3 >  v2
) [static]
Definition at line 84 of file HexLagrangeShapeTest.cpp.
References epsilon, and MBMesquite::length().
  { return length(v1 - v2) < epsilon; }
static CppUnit::Message value_message ( unsigned  location,
double  v1,
double  v2
) [inline, static]
Definition at line 56 of file HexLagrangeShapeTest.cpp.
  CppUnit::Message m( "equality assertion failed" );
  std::ostringstream buffer1;
  buffer1 << "Expected : " << v1;
   m.addDetail( buffer1.str() );
  std::ostringstream buffer2;
  buffer2 << "Actual   : " << v2;
  m.addDetail( buffer2.str() );
  std::ostringstream buffer3;
  buffer3 << "Location : ";
  if (location < 9)
    buffer3 << "Corner " << location;
  else if (location < 20)
    buffer3 << "Edge " << location-8;
  else if (location < 26)
    buffer3 << "Face " << location-20;
  else if (location == 26)
    buffer3 << "Mid-element";
  else
    buffer3 << "INVALID!!";
  m.addDetail( buffer3.str() );
  return m;
MsqVector< 3 >  v1,
MsqVector< 3 >  v2
) [inline, static]
Definition at line 87 of file HexLagrangeShapeTest.cpp.
  buffer1 << "Expected : [" << v1[0] << ", " << v1[1] << ", " << v1[2] << "]";
  buffer2 << "Actual   : [" << v2[0] << ", " << v2[1] << ", " << v2[2] << "]";
  if (location < 9)
  else
  return m;
static MsqVector<3> XI_corner ( int  i) [static]
static MsqVector<3> XI_edge ( int  i) [static]
Definition at line 238 of file HexLagrangeShapeTest.cpp.
References MBMesquite::HEXAHEDRON, and XI_corner().
Referenced by HexLagrangeShapeTest::test_edge_coeff(), and HexLagrangeShapeTest::test_edge_derivs().
    const unsigned* idx = TopologyInfo::edge_vertices( HEXAHEDRON, i );
    return 0.5 * (XI_corner(idx[0]) + XI_corner(idx[1]));
static MsqVector<3> XI_elem ( ) [static]
Definition at line 255 of file HexLagrangeShapeTest.cpp.
References mid_xi.
Referenced by HexLagrangeShapeTest::test_mid_coeff(), and HexLagrangeShapeTest::test_mid_derivs().
    const double vals[] = { mid_xi, mid_xi, mid_xi };
    return MsqVector<3>(vals);
static MsqVector<3> XI_face ( int  i) [static]
Definition at line 244 of file HexLagrangeShapeTest.cpp.
References MBMesquite::HEXAHEDRON, n, and XI_corner().
Referenced by HexLagrangeShapeTest::test_face_coeff(), and HexLagrangeShapeTest::test_face_derivs().
    unsigned n;
    const unsigned* idx = TopologyInfo::face_vertices( HEXAHEDRON, i, n );
    MsqVector<3> result = XI_corner(idx[0]);
    for (unsigned j = 1; j < n; ++j)
      result += XI_corner(idx[j]);
    result *= 1.0/n;
    return result;
Variable Documentation
const int C[][3]
Definition at line 188 of file HexLagrangeShapeTest.cpp.
Referenced by MBMesquite::MsqMatrix< R, C >::add_row(), MBMesquite::MsqMatrix< R, C >::assign_add_product(), MBMesquite::MsqMatrix< R, C >::assign_add_transpose(), MBMesquite::MsqMatrix< R, C >::assign_multiply_elements(), MBMesquite::MsqMatrix< R, C >::assign_product(), moab::borderPointsOfCSinRLL(), moab::borderPointsOfXinY2(), moab::MeshGeneration::BrickInstance(), MBMesquite::MsqMatrix< R, C >::diag(), dN(), moab::EdgeIntxRllCs(), moab::enforce_convexity(), gather_related_test(), ident_check(), MBMesquite::inner_product(), MBMesquite::MsqMatrix< R, C >::make_minor(), mat_equal_check(), msq_mat_str(), mxm_cc(), mxm_cr(), mxm_rc(), N(), MBMesquite::MsqMatrix< 3, 3 >::operator()(), MBMesquite::operator*(), MBMesquite::MsqMatrix< R, C >::operator*=(), MBMesquite::MsqMatrix< R, C >::operator+=(), MBMesquite::operator-(), MBMesquite::MsqMatrix< R, C >::operator-=(), MBMesquite::MsqMatrix< R, C >::operator/=(), MBMesquite::operator<<(), MBMesquite::operator==(), MBMesquite::operator>>(), MBMesquite::MsqMatrixA< R, C >::operator[](), MBMesquite::outer(), MBMesquite::pmean_corner_hessians(), moab::SimplexTemplateRefiner::refine_3_simplex(), MBMesquite::MsqMatrix< 3, 3 >::row(), MBMesquite::MsqMatrix< 3, 3 >::set(), MBMesquite::MsqMatrix< R, C >::set(), MBMesquite::MsqMatrix< R, C >::set_columns(), MBMesquite::MsqMatrix< R, C >::set_row(), MBMesquite::MsqMatrix< R, C >::set_row_transpose(), MBMesquite::sqr_Frobenius(), MBMesquite::sum_corner_hessians(), MBMesquite::sum_sqr_corner_hessians(), SymMatrix3DTest::test_divide_eq(), test_great_arc_clat_intx(), test_great_arc_intx(), PMeanPMetricTest::test_hessian(), test_leaf_containing_point_bounded_tree(), test_leaf_containing_point_unbounded_tree(), SymMatrix3DTest::test_minus(), SymMatrix3DTest::test_minus_eq(), SymMatrix3DTest::test_minus_nonsym(), SymMatrix3DTest::test_multiply(), SymMatrix3DTest::test_nonsym_multiply(), SymMatrix3DTest::test_plus(), SymMatrix3DTest::test_plus_eq(), SymMatrix3DTest::test_plus_nonsym(), SymMatrix3DTest::test_scalar_multiply(), SymMatrix3DTest::test_times_eq(), MBMesquite::transpose(), and v_tet_aspect_ratio().
const double corners[8][3]
Initial value:
  { min_xi, min_xi, min_xi },
  { max_xi, min_xi, min_xi },
  { max_xi, max_xi, min_xi },
  { min_xi, max_xi, min_xi },
  { min_xi, min_xi, max_xi },
  { max_xi, min_xi, max_xi },
  { max_xi, max_xi, max_xi },
  { min_xi, max_xi, max_xi } }
Definition at line 225 of file HexLagrangeShapeTest.cpp.
Referenced by MBMesquite::append_elem_samples(), MBMesquite::ArrayMesh::ArrayMesh(), MBMesquite::average_corner_diagonals(), MBMesquite::AveragingQM::average_corner_gradients(), MBMesquite::AveragingQM::average_corner_hessians(), TopologyInfoTest::bad_type(), moab::GeomUtil::box_hex_overlap(), moab::GeomUtil::box_linear_elem_overlap(), moab::GeomUtil::box_tet_overlap(), moab::BoxPlaneIter::BoxPlaneIter(), moab::BSPTreeIter::calculate_polyhedron(), MBMesquite::MsqMeshEntity::check_element_orientation(), check_no_slaved_corners(), check_slaved_coords(), MBMesquite::MeshImplData::clear_element(), MBMesquite::MappingFunction::convert_connectivity_indices(), MBMesquite::MappingFunction::convert_connectivity_indices_impl(), MBMesquite::MeshImplData::copy_mesh(), MBMesquite::create_ideal_element_patch(), create_regular_mesh(), moab::ReadCGM::create_surface_facets(), moab::BSPTree::create_tree(), MBMesquite::derivatives_at_mid_elem(), LinearMappingFunctionTest::do_coeff_test(), LinearMappingFunctionTest::do_deriv_test(), LinearMappingFunctionTest::do_ideal_test(), MBMesquite::MeshImplData::element_topology(), MBMesquite::PatchData::fill(), find_face(), MBMesquite::find_skin(), MBMesquite::PatchData::get_adjacent_vertex_indices(), PatchDataTest::get_higher_order_vertices(), QualityMetricTester::get_ideal_element(), PatchDataTest::get_quad8_mesh_and_domain(), MBMesquite::PatchData::get_samples(), TopologyInfoTest::hex(), MBMesquite::Instruction::initialize_vertex_byte(), moab::BSPTreeIter::intersect_ray(), MBMesquite::SlaveBoundaryVertices::loop_over_mesh(), main(), SlaveBoundaryVerticesTest::make_mesh(), MBMesquite::MeshImpl::MeshImpl(), MBMesquite::next_vertex(), MBMesquite::PatchData::non_slave_node_set(), MBMesquite::MeshImplData::num_vertex_uses(), MBMesquite::pmean_corner_diagonals(), MBMesquite::pmean_corner_hessians(), MBMesquite::populate_data(), TopologyInfoTest::pyramid(), TopologyInfoTest::quad(), MBMesquite::QualityMetric::remove_fixed_diagonals(), MBMesquite::QualityMetric::remove_fixed_gradients(), MBMesquite::QualityMetric::remove_fixed_hessians(), MBMesquite::NodeSet::set_all_corner_nodes(), MBMesquite::MeshImpl::set_all_slaved_flags(), MBMesquite::MeshImplData::set_element(), MBMesquite::ArrayMesh::set_mesh(), moab::BSPTree::set_tree_box(), moab::CN::SubEntityNodeIndices(), MBMesquite::sum_corner_hessians(), MBMesquite::sum_sqr_corner_hessians(), TopologyInfoTest::test_adj(), test_box_iter_neighbors(), test_box_iterator(), test_box_tree_create(), MsqMeshEntityTest::test_check_element_orientation_linear(), NodeSetTest::test_clear_node(), test_construct_from_hex(), QuadLagrangeShapeTest::test_corner_coeff(), QuadLagrangeShapeTest::test_corner_derivs(), test_cut_with_plane(), QualityMetricTester::test_diagonal_with_fixed_vertex(), QualityMetricTester::test_get_indices_fixed(), QualityMetricTester::test_gradient_with_fixed_vertex(), QualityMetricTester::test_hessian_with_fixed_vertex(), test_leaf_containing_point_bounded_tree(), test_leaf_intersects_ray_common(), test_merge_leaf(), NodeSetTest::test_num_before(), TopologyInfoTest::test_poly(), VtkTest::test_read_quadratic(), TopologyInfoTest::test_rev_adj(), SlaveBoundaryVerticesTest::test_slaved_common(), test_sub_entity_nodes(), MsqMeshEntityTest::test_unsigned_area_common(), test_volume(), TopologyInfoTest::tet(), TopologyInfoTest::tri(), MBMesquite::MsqMeshEntity::vertex_count(), MBMesquite::vertices_in_topology(), moab::ReadVtk::vtk_create_structured_elems(), MBMesquite::MeshImpl::vtk_create_structured_elems(), TopologyInfoTest::wedge(), LinearMappingFunctionTest::xi_at_corners(), and XI_corner().
f_t dl[4] = { 0, &dl21, &dl22, &dl23 }
Definition at line 187 of file HexLagrangeShapeTest.cpp.
Referenced by check_mesh_is_tet(), and dN().
Definition at line 49 of file HexLagrangeShapeTest.cpp.
Definition at line 173 of file HexLagrangeShapeTest.cpp.
Definition at line 174 of file HexLagrangeShapeTest.cpp.
Referenced by MBMesquite::derivatives_at_corner(), and XI_elem().
Definition at line 172 of file HexLagrangeShapeTest.cpp.
