IODebugTrack.hpp
00001 #ifndef moab_IO_DEBUG_TRACK_HPP
00002 #define moab_IO_DEBUG_TRACK_HPP
00003
00004 #include <list>
00005 #include <iosfwd>
00006 #include <string>
00007
00008 namespace moab
00009 {
00010
00011 /**\brief Tool for debugging binary IO
00012  *
00013  * Track which ranges of a table of data have been read/written,
00014  * watching for overlapping IO requests and ranges of unaccessed
00015  * data.
00016  *
00017  * Notes:  This class assumes MPI_COMM_WORLD is the communicator
00018  *         for parallel.
00019  */
00020 class IODebugTrack
00021 {
00022   private:
00023     struct DRange
00024     {
00025         unsigned long begin;
00026         unsigned long end;
00027         unsigned long rank;
00028     };
00029
00030     bool enableOutput;
00031     std::string tableName;
00032     std::list< DRange > dataSet;
00033     std::ostream& ostr;
00034     unsigned long maxSize;
00035     int mpiRank;
00036     bool haveMPI;
00037
00038     void record_io( DRange data );
00039
00040   public:
00041     /**\brief Constuctor requires stream to which to log errors
00042      *\param table_name    Used to tag output
00043      *\param output_stream Stream to which to print error messages
00044      *\param table_size Max table size.  No limit if unspecified
00045      */
00046     IODebugTrack( bool enable,
00047                   const std::string& table_name,
00048                   std::ostream& output_stream,
00049                   unsigned long table_size = 0 );
00050
00051     /**\brief Constuctor requires stream to which to log errors
00052      *\param table_name    Used to tag output
00053      *\param table_size Max table size.  No limit if unspecified
00054      */
00055     IODebugTrack( bool enable, const std::string& table_name, unsigned long table_size = 0 );
00056
00057     /**\brief Destructor prints errors about unaccessed ranges */
00058     ~IODebugTrack();
00059
00060     /**\brief Notify of IO request
00061      *\param begin  First table row being read/written
00062      *\param count  Num consecutive table rows being read/written
00063      */
00064     void record_io( unsigned long begin, unsigned long count );
00065
00066     /**\brief Push all data to root process
00067      *
00068      * Does nothing if MPI support is not enabled
00069      */
00070     void all_reduce();
00071 };
00072
00073 }  // namespace moab
00074
00075 #endif
