KDTree.cpp File Reference
#include "moab/Core.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/Range.hpp"
#include "moab/GeomUtil.hpp"
#include <iostream>
#include <string>
+ Include dependency graph for KDTree.cpp:
Defines
#define CHKERR(err)
Functions
void print_error (moab::Interface &mb, moab::ErrorCode err)
moab::EntityHandle hex_containing_point (moab::Interface &mb, moab::EntityHandle set, const double point[3])
void print_hex (moab::Interface &mb, moab::EntityHandle hex)
int main ()
Variables
const double EPSILON = 1e-6
Define Documentation
#define CHKERR (   err)
Value:
do        \
        if( moab::MB_SUCCESS != ( err ) )                                                       \
            print_error( mb, ( err ) );                                                         \
            std::cerr << "Unexpected failure at: " << __FILE__ << ":" << __LINE__ << std::endl; \
            return 2;        \
    } while( false )
Definition at line 30 of file KDTree.cpp.
Referenced by hex_containing_point(), and main().
Function Documentation
moab::EntityHandle hex_containing_point ( moab::Interface mb,
Definition at line 103 of file KDTree.cpp.
References CHKERR, EPSILON, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), MBHEX, and moab::GeomUtil::point_in_trilinear_hex().
Referenced by main().
    moab::ErrorCode rval;
    moab::CartVect pt( point );      // input location
    moab::CartVect coords[8];        // coordinates of corners of hexahedron
    const moab::EntityHandle* conn;  // hex connectivity
    int conn_len;
    // Get hexes in leaf
    std::vector< moab::EntityHandle > hexes;
    rval = mb.get_entities_by_type( set, moab::MBHEX, hexes );CHKERR( rval );
    // Check which hex the point is in
    std::vector< moab::EntityHandle >::const_iterator i;
    for( i = hexes.begin(); i != hexes.end(); ++i )
        rval = mb.get_connectivity( *i, conn, conn_len );CHKERR( rval );
        rval = mb.get_coords( conn, 8, &coords[0][0] );CHKERR( rval );
        if( moab::GeomUtil::point_in_trilinear_hex( coords, pt, EPSILON ) ) return *i;
    // Return 0 if no hex contains point.
    return 0;
int main ( )
Definition at line 49 of file KDTree.cpp.
References moab::AdaptiveKDTree::build_tree(), CHKERR, moab::Range::empty(), ErrorCode, filename, moab::Interface::get_entities_by_type(), hex_containing_point(), leaf, moab::Interface::load_file(), mb, MB_SUCCESS, MBHEX, print_error(), and print_hex().
    // Ask user for file to read
    std::string filename;
    std::cout << "Hex mesh file name: ";
    std::cin >> filename;
    // Read file into MOAB instance
    moab::Core moab;
    moab::Interface& mb = moab;
    rval                = mb.load_file( filename.c_str() );
    if( moab::MB_SUCCESS != rval )
        print_error( mb, rval );
        std::cerr << filename << ": file load failed" << std::endl;
        return 1;
    // Get all hex elemeents
    moab::Range elems;
    rval = mb.get_entities_by_type( 0, moab::MBHEX, elems );CHKERR( rval );
    if( elems.empty() )
        std::cerr << filename << ": file containd no hexahedra" << std::endl;
        return 1;
    // Build a kD-tree from hex elements
    moab::EntityHandle tree_root;
    moab::AdaptiveKDTree tool( &mb );
    rval = tool.build_tree( elems, tree_root );CHKERR( rval );
    // Loop forever (or until EOF), asking user for a point
    // to query and printing the hex element containing that
    // point.
    for( ;; )
        double point[3];
        std::cout << "Point coordinates: ";
        if( !( std::cin >> point[0] >> point[1] >> point[2] ) ) break;
        moab::EntityHandle leaf;
        rval = tool.leaf_containing_point( tree_root, point, leaf );CHKERR( rval );
        moab::EntityHandle hex = hex_containing_point( mb, leaf, point );
        if( 0 == hex )
            std::cout << "Point is not contained in any hexahedron." << std::endl;
        else
            print_hex( mb, hex );
    return 0;
void print_error ( moab::Interface mb,
moab::ErrorCode  err
Definition at line 19 of file KDTree.cpp.
References moab::Interface::get_error_string(), moab::Interface::get_last_error(), and MB_SUCCESS.
    std::string message;
    std::string code;
    if( moab::MB_SUCCESS != mb.get_last_error( message ) ) message.clear();
    code = mb.get_error_string( err );
    std::cerr << "Error: " << code << std::endl;
    if( !message.empty() ) std::cerr << "  " << message << std::endl;
void print_hex ( moab::Interface mb,
Definition at line 128 of file KDTree.cpp.
References moab::Interface::get_connectivity(), moab::Interface::get_coords(), and moab::Interface::id_from_handle().
    // Get MOAB's internal ID for hex element
    int id = mb.id_from_handle( hex );
    // Get vertex handles for hex corners
    int conn_len;
    mb.get_connectivity( hex, conn, conn_len );
    // Get coordinates of vertices
    double coords[3 * 8];
    mb.get_coords( conn, 8, coords );
    // Print
    std::cout << " Point is in hex " << id << " with corners: " << std::endl;
    for( int i = 0; i < 8; ++i )
        std::cout << " (" << coords[3 * i] << ", " << coords[3 * i + 1] << ", " << coords[3 * i + 2] << ")"
                  << std::endl;
Variable Documentation
