LPtoPTemplate.hpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2004 Sandia Corporation and Argonne National
00005     Laboratory.  Under the terms of Contract DE-AC04-94AL85000
00006     with Sandia Corporation, the U.S. Government retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     [email protected], [email protected], [email protected],
00024     [email protected], [email protected], [email protected]
00025
00026   ***************************************************************** */
00027 // -*- Mode : c++; tab-width: 3; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 3
00028 // -*-
00029
00030 /*! \file LPtoPTemplate.hpp
00031   \brief Header file for the MBMesquite::LPtoPTemplate class
00032  \author Michael Brewer
00033  \author Thomas Leurent
00034   \date   2002-05-23
00035  */
00036
00037 #ifndef LPtoPTemplate_hpp
00038 #define LPtoPTemplate_hpp
00039
00040 #include "Mesquite.hpp"
00041 #include "ObjectiveFunctionTemplate.hpp"
00042
00043 namespace MBMesquite
00044 {
00045 class Matrix3D;
00046
00047 /*! \class LPtoPTemplate
00048   \brief Calculates the L_p objective function raised to the pth
00049   power.  That is, sums the p_th powers of (the absolute value of)
00050   the quality metric values.
00051
00052   \todo MB. Suggestions made by Todd Munson:
00053   a)  There is an inconsistent use of fabs.  The hessian evaluation
00054   when using the one norm does not take the absolute value, while the
00055   gradient does.
00056   b)  The analytic gradient and hessian evaluations are incorrect when
00057   the quality metric changes sign due to taking the absolute value.
00058   The negative of the element gradient and hessian also needs to be
00059   taken.
00060   c)  Done.  The analytic gradient and hessian evaluations are
00061   incorrect when the negate flag is set to -1.  The negative
00062   of the element gradient and hessian also needs to be taken
00063   in this case.
00064   d)  The malloc in the concrete_eval routine should be removed.
00065
00066 */
00067 class LPtoPTemplate : public ObjectiveFunctionTemplate
00068 {
00069   public:
00070     MESQUITE_EXPORT
00071     LPtoPTemplate( QualityMetric*, short, MsqError& );
00072     MESQUITE_EXPORT
00073     LPtoPTemplate( short, QualityMetric* );
00074
00075     MESQUITE_EXPORT
00076     virtual ~LPtoPTemplate();
00077
00078     MESQUITE_EXPORT
00079     virtual void clear();
00080
00081     MESQUITE_EXPORT
00082     virtual bool evaluate( EvalType type, PatchData& pd, double& value_out, bool free, MsqError& err );
00083
00084     MESQUITE_EXPORT
00085     virtual bool evaluate_with_gradient( EvalType type,
00086                                          PatchData& pd,
00087                                          double& value_out,
00088                                          std::vector< Vector3D >& grad_out,
00089                                          MsqError& err );
00090
00091     MESQUITE_EXPORT
00092     virtual bool evaluate_with_Hessian_diagonal( EvalType type,
00093                                                  PatchData& pd,
00094                                                  double& value_out,
00095                                                  std::vector< Vector3D >& grad_out,
00096                                                  std::vector< SymMatrix3D >& hess_diag_out,
00097                                                  MsqError& err );
00098
00099     MESQUITE_EXPORT
00100     virtual bool evaluate_with_Hessian( EvalType type,
00101                                         PatchData& pd,
00102                                         double& value_out,
00103                                         std::vector< Vector3D >& grad_out,
00104                                         MsqHessian& Hessian_out,
00105                                         MsqError& err );
00106
00107     MESQUITE_EXPORT
00108     virtual ObjectiveFunction* clone() const;
00109
00110     /*!Use set_dividing_by_n to control whether this objective
00111       function divides it's final value by the number of
00112       metric values used to compute the objective function
00113       value.  That is, if the associated metric is element
00114       based, the obejctive function value is divided by
00115       the number of elements.  If it is vertex based, the
00116       objective function is divided by the number of vertices.
00117       If this function is passed 'true', the function value
00118       will be scale.  If it is passed false, the function
00119       value will not be scaled.*/
00120     MESQUITE_EXPORT
00121     void set_dividing_by_n( bool d_bool )
00122     {
00123         dividingByN = d_bool;
00124     }
00125
00126   private:
00127     double get_value( double power_sum, size_t count, EvalType type, size_t& global_count, MsqError& err );
00128
00129     //! The metric value entries are raised to the pVal power
00130     short pVal;
00131     //! dividingByN is true if we are dividing the objective function
00132     //! by the number of metric values.
00133     bool dividingByN;
00134
00135     size_t mCount;     /**< The number of accumulated entires */
00136     double mPowSum;    /**< The accumulated sum of values */
00137     size_t saveCount;  /**< Saved count from previous patch */
00138     double savePowSum; /**< Saved sum from previous patch */
00139
00140     /** Temporary storage for qm sample handles */
00141     mutable std::vector< size_t > qmHandles;
00142     /** Temporary storage for qm vertex indices */
00143     mutable std::vector< size_t > mIndices;
00144     /** Temporary storage for qm gradient */
00145     mutable std::vector< Vector3D > mGradient;
00146     /** Temporary storage for qm Hessian diagonal blocks */
00147     mutable std::vector< SymMatrix3D > mDiag;
00148     /** Temporary storage for qm Hessian */
00149     mutable std::vector< Matrix3D > mHessian;
00150 };
00151
00152 }  // namespace MBMesquite
00153
00154 #endif  // LPtoPTemplate_hpp
