LVQDTargetCalculator.hpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2006 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2006) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file LVQDTargetCalculator.hpp
00028  *  \brief
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #ifndef MSQ_LVQD_TARGET_CALCULATOR_HPP
00033 #define MSQ_LVQD_TARGET_CALCULATOR_HPP
00034
00035 #include "Mesquite.hpp"
00036 #include "TargetCalculator.hpp"
00037
00038 namespace MBMesquite
00039 {
00040
00041 /** \brief Construct target matrices from factors of guide matrices
00042  *
00043  * Given a set of guide matrices, extract certain properties
00044  * from them and combine those properties to produce a target
00045  * matrix.
00046  * \f$\mathbf{W}=\lambda(\mathbf{W_\lambda}) \times \mathbf{V}(\mathbf{W_V}) \times
00047  * \mathbf{Q}(\mathbf{W_Q}) \times \mathbf{\Delta}(\mathbf{W_\Delta})\f$
00048  * - \f$\lambda\f$ - scalar - size component of \f$\mathbf{W_\lambda}\f$
00049  * - \f$\mathbf{V}\f$ - 3x3 or 3x2 - orientation component of \f$\mathbf{W_V}\f$
00050  * - \f$\mathbf{Q}\f$ - 3x3 or 2x2 - shape component of \f$\mathbf{W_Q}\f$
00051  * - \f$\mathbf{\Delta}\f$ - 3x3 or 2x2 - aspect ratio component of \f$\mathbf{W_\Delta}\f$
00052  */
00053 class LVQDTargetCalculator : public TargetCalculator
00054 {
00055   public:
00056     LVQDTargetCalculator( TargetCalculator* lambda_source,
00057                           TargetCalculator* V_source,
00058                           TargetCalculator* Q_source,
00059                           TargetCalculator* delta_source );
00060
00061     ~LVQDTargetCalculator();
00062
00063     bool get_3D_target( PatchData& pd, size_t element, Sample sample, MsqMatrix< 3, 3 >& W_out, MsqError& err );
00064
00065     bool get_surface_target( PatchData& pd, size_t element, Sample sample, MsqMatrix< 3, 2 >& W_out, MsqError& err );
00066
00067     bool get_2D_target( PatchData& pd, size_t element, Sample sample, MsqMatrix< 2, 2 >& W_out, MsqError& err );
00068
00069     bool have_surface_orient() const;
00070
00071   private:
00072     int add_source( TargetCalculator* source );
00073
00074     bool evaluate_guide_2D( PatchData& pd,
00075                             size_t element,
00076                             Sample sample,
00077                             int idx,
00078                             double& lambda,
00079                             MsqMatrix< 3, 2 >& V,
00080                             MsqMatrix< 2, 2 >& Q,
00081                             MsqMatrix< 2, 2 >& delta,
00082                             MsqError& err );
00083
00084     TargetCalculator* uniqueGuides[4];    //!< Up to 4 unique target sources
00085     int numUniqueGuides;                  //!< Number of unique target sources
00086     int lambdaIdx, vIdx, qIdx, deltaIdx;  //!< Index into uniqueGuides for respective source,
00087                                           //!< or -1 for no source.
00088 };
00089
00090 }  // namespace MBMesquite
00091
00092 #endif
