MOAB_iMeshP_unit_tests.cpp
00001 #include "iMeshP.h"
00002 #include "moab_mpi.h"
00003 #include <iostream>
00004 #include <algorithm>
00005 #include <vector>
00006 #include <sstream>
00007 #include <cassert>
00008 #include <cmath>
00009 #include <map>
00010 #include <cstring>
00011 #include <cstdio>  // remove()
00012
00013 #if !defined( _MSC_VER ) && !defined( __MINGW32__ )
00014 #include <unistd.h>
00015 #endif
00016
00017 #define STRINGIFY_( X ) #X
00018 #define STRINGIFY( X )  STRINGIFY_( X )
00019 const char* const FILENAME = "iMeshP_test_file";
00020
00021 /**************************************************************************
00022                               Error Checking
00023  **************************************************************************/
00024
00025 #define CHKERR        \
00026     do        \
00027     {        \
00028         if( ierr )        \
00029         {        \
00030             std::cerr << "Error code  " << ierr << " at " << __FILE__ << ":" << __LINE__ << std::endl; \
00031             return ierr;        \
00032         }        \
00033     } while( false )
00034
00035 #define PCHECK                            \
00036     do                                    \
00037     {                                     \
00038         ierr = is_any_proc_error( ierr ); \
00039         CHKERR;                           \
00040     } while( false )
00041
00042 // Use my_rank instead of rank to avoid shadowed declaration
00043 #define ASSERT( A )        \
00044     do        \
00045     {        \
00046         if( is_any_proc_error( !( A ) ) )        \
00047         {        \
00048             int my_rank = 0;        \
00049             MPI_Comm_rank( MPI_COMM_WORLD, &my_rank );                                                              \
00050             if( 0 == my_rank )        \
00051                 std::cerr << "Failed assertion: " #A << std::endl << "  at " __FILE__ ":" << __LINE__ << std::endl; \
00052             return 1;        \
00053         }        \
00054     } while( false )
00055
00056 // Test if is_my_error is non-zero on any processor in MPI_COMM_WORLD
00057 int is_any_proc_error( int is_my_error )
00058 {
00059     int result;
00060     int err = MPI_Allreduce( &is_my_error, &result, 1, MPI_INT, MPI_MAX, MPI_COMM_WORLD );
00061     return err || result;
00062 }
00063
00064 /**************************************************************************
00065                            Test  Declarations
00066  **************************************************************************/
00067
00068 class PartMap;
00069
00070 /**\brief Consistency check for parallel load
00071  *
00072  * All other tests depend on this one.
00073  */
00074 int test_load( iMesh_Instance, iMeshP_PartitionHandle prtn, PartMap& map, int comm_size );
00075
00076 /**\brief Test partition query methods
00077  *
00078  * Test:
00079  * - iMeshP_getPartitionComm
00080  * - iMeshP_getNumPartitions
00081  * - iMeshP_getPartitions
00082  */
00083 int test_get_partitions( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00084
00085 /**\brief Test part quyery methods
00086  *
00087  * Test:
00088  * - iMeshP_getNumGlobalParts
00089  * - iMeshP_getNumLocalParts
00090  * - iMeshP_getLocalParts
00091  */
00092 int test_get_parts( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00093
00094 /**\brief Test query by entity type
00095  *
00096  * Test:
00097  * - iMeshP_getNumOfTypeAll
00098  * - iMeshP_getNumOfType
00099  * - iMeshP_getEntities
00100  * -
00101  */
00102 int test_get_by_type( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00103
00104 /**\brief Test query by entity topology
00105  *
00106  * Test:
00107  * - iMeshP_getNumOfTopoAll
00108  * - iMeshP_getNumOfTopo
00109  * - iMeshP_getEntities
00110  * -
00111  */
00112 int test_get_by_topo( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00113
00114 /**\brief Test mapping from part id to part handle
00115  *
00116  * Test:
00117  * - iMeshP_getPartIdFromPartHandle
00118  * - iMeshP_getPartIdsFromPartHandlesArr
00119  * - iMeshP_getPartHandleFromPartId
00120  * - iMeshP_getPartHandlesFromPartsIdsArr
00121  * - iMeshP_getRankOfPart
00122  * - iMeshP_getRankOfPartArr
00123  */
00124 int test_part_id_handle( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00125
00126 /**\brief Test get part rank
00127  *
00128  * Tests:
00129  * - iMeshP_getRankOfPart
00130  * - iMeshP_getRankOfPartArr
00131  */
00132 int test_part_rank( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00133
00134 /**\brief Test querying of part neighbors
00135  *
00136  * Test:
00137  * - iMeshP_getNumPartNbors
00138  * - iMeshP_getNumPartNborsArr
00139  * - iMeshP_getPartNbors
00140  * - iMeshP_getPartNborsArr
00141  */
00142 int test_get_neighbors( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00143
00144 /**\brief Test querying of part boundary entities
00145  *
00146  * Test:
00147  * - iMeshP_getNumPartBdryEnts
00148  * - iMeshP_getPartBdryEnts
00149  */
00150 int test_get_part_boundary( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00151
00152 /**\brief Test querying of part boundary entities
00153  *
00154  * Test:
00155  * - iMeshP_initPartBdryEntIter
00156  * - iMeshP_initPartBdryEntArrIter
00157  */
00158 int test_part_boundary_iter( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00159
00160 /**\brief Test adjacent entity query
00161  *
00162  * Test:
00163  * - iMeshP_getAdjEntities
00164  */
00165 int test_get_adjacencies( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00166
00167 /**\brief Test entity iterators
00168  *
00169  * Test:
00170  * - iMeshP_initEntIter
00171  * - iMeshP_initEntArrIter
00172  */
00173 int test_entity_iterator( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00174
00175 /**\brief Test entity owner queries
00176  *
00177  * Test:
00178  * - iMeshP_getEntOwnerPart
00179  * - iMeshP_getEntOwnerPartArr
00180  * - iMeshP_isEntOwner
00181  * - iMeshP_isEntOwnerArr
00182  */
00183 int test_entity_owner( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00184
00185 /**\brief Test entity status
00186  *
00187  * Test:
00188  * - iMeshP_getEntStatus
00189  * - iMeshP_getEntStatusArr
00190  */
00191 int test_entity_status( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00192
00193 /**\brief Test information about entity copies for interface entities
00194  *
00195  * Test:
00196  * - iMeshP_getNumCopies
00197  * - iMeshP_getCopyParts
00198  */
00199 int test_entity_copy_parts( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00200
00201 /**\brief Test information about entity copies for interface entities
00202  *
00203  * Test:
00204  * - iMeshP_getCopies
00205  * - iMeshP_getCopyOnPart
00206  * - iMeshP_getOwnerCopy
00207  */
00208 int test_entity_copies( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00209
00210 /**\brief Test creation of ghost entities
00211  *
00212  * Test:
00213  * - iMeshP_createGhostEntsAll
00214  */
00215 int test_create_ghost_ents( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00216
00217 /**\brief Test commuinication of tag data
00218  *
00219  * Test:
00220  * - iMeshP_pushTags
00221  * - iMeshP_pushTagsEnt
00222  */
00223 int test_push_tag_data_iface( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00224 int test_push_tag_data_ghost( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
00225
00226 int test_exchange_ents( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map );
00227
00228 /**************************************************************************
00229                               Helper Funcions
00230  **************************************************************************/
00231
00232 class PartMap
00233 {
00234   public:
00235     int num_parts() const
00236     {
00237         return sortedPartList.size();
00238     }
00239
00240     iMeshP_Part part_id_from_local_id( int local_id ) const
00241     {
00242         return sortedPartList[idx_from_local_id( local_id )];
00243     }
00244
00245     int local_id_from_part_id( iMeshP_Part part ) const
00246     {
00247         return partLocalIds[idx_from_part_id( part )];
00248     }
00249
00250     int rank_from_part_id( iMeshP_Part part ) const
00251     {
00252         return partRanks[idx_from_part_id( part )];
00253     }
00254
00255     int rank_from_local_id( int id ) const
00256     {
00257         return partRanks[idx_from_local_id( id )];
00258     }
00259
00260     int count_from_rank( int rank ) const
00261     {
00262         return std::count( partRanks.begin(), partRanks.end(), rank );
00263     }
00264
00265     void part_id_from_rank( int rank, std::vector< iMeshP_Part >& parts ) const;
00266
00267     void local_id_from_rank( int rank, std::vector< int >& ids ) const;
00268
00269     const std::vector< iMeshP_Part >& get_parts() const
00270     {
00271         return sortedPartList;
00272     }
00273
00274     const std::vector< int >& get_ranks() const
00275     {
00276         return partRanks;
00277     }
00278
00279     int build_map( iMesh_Instance imesh, iMeshP_PartitionHandle partition, int num_expected_parts );
00280
00281     static int part_from_coords( iMesh_Instance imesh, iMeshP_PartHandle part, int& id_out );
00282
00283   private:
00284     inline int idx_from_part_id( iMeshP_Part id ) const
00285     {
00286         return std::lower_bound( sortedPartList.begin(), sortedPartList.end(), id ) - sortedPartList.begin();
00287     }
00288     inline int idx_from_local_id( int id ) const
00289     {
00290         return localIdReverseMap[id];
00291     }
00292
00293     std::vector< iMeshP_Part > sortedPartList;
00294     std::vector< int > partRanks;
00295     std::vector< int > partLocalIds;
00296     std::vector< int > localIdReverseMap;
00297 };
00298
00299 /**\brief Create mesh for use in parallel tests */
00300 int create_mesh( const char* filename, int num_parts );
00301
00302 int create_mesh_in_memory( int rank, int size, iMesh_Instance imesh, iMeshP_PartitionHandle& prtn, PartMap& map );
00303
00304 /**\brief get unique identifier for each vertex */
00305 int vertex_tag( iMesh_Instance imesh, iBase_EntityHandle vertex, int& tag );
00306
00307 int get_local_parts( iMesh_Instance instance,
00308                      iMeshP_PartitionHandle prtn,
00309                      std::vector< iMeshP_PartHandle >& handles,
00310                      std::vector< iMeshP_Part >* ids = 0 )
00311 {
00312     iMeshP_PartHandle* arr = 0;
00313     int ierr, alloc = 0, size;
00314     iMeshP_getLocalParts( instance, prtn, &arr, &alloc, &size, &ierr );CHKERR;
00315     handles.resize( size );
00316     std::copy( arr, arr + size, handles.begin() );
00317     free( arr );
00318     if( !ids ) return iBase_SUCCESS;
00319
00320     ids->resize( size );
00321     alloc            = size;
00322     iMeshP_Part* ptr = &( *ids )[0];
00323     iMeshP_getPartIdsFromPartHandlesArr( instance, prtn, &handles[0], handles.size(), &ptr, &alloc, &size, &ierr );CHKERR;
00324     assert( size == (int)ids->size() );
00325     assert( ptr == &( *ids )[0] );
00326     return iBase_SUCCESS;
00327 }
00328
00329 static int get_entities( iMesh_Instance imesh,
00330                          iBase_EntitySetHandle set,
00331                          iBase_EntityType type,
00332                          iMesh_EntityTopology topo,
00333                          std::vector< iBase_EntityHandle >& entities )
00334 {
00335     iBase_EntityHandle* array = 0;
00336     int junk = 0, size = 0, err;
00337     iMesh_getEntities( imesh, set, type, topo, &array, &junk, &size, &err );
00338     if( !err )
00339     {
00340         entities.clear();
00341         entities.resize( size );
00342         std::copy( array, array + size, entities.begin() );
00343         free( array );
00344     }
00345     return err;
00346 }
00347
00348 static int get_part_quads_and_verts( iMesh_Instance imesh,
00349                                      iMeshP_PartHandle part,
00350                                      std::vector< iBase_EntityHandle >& elems,
00351                                      std::vector< iBase_EntityHandle >& verts )
00352 {
00353     int ierr = get_entities( imesh, part, iBase_FACE, iMesh_QUADRILATERAL, elems );CHKERR;
00354
00355     verts.resize( 4 * elems.size() );
00356     std::vector< int > junk( elems.size() + 1 );
00357     int junk1 = verts.size(), count, junk2 = junk.size(), junk3;
00358     iBase_EntityHandle* junk4 = &verts[0];
00359     int* junk5                = &junk[0];
00360     iMesh_getEntArrAdj( imesh, &elems[0], elems.size(), iBase_VERTEX, &junk4, &junk1, &count, &junk5, &junk2, &junk3,
00361                         &ierr );CHKERR;
00362     assert( junk1 == (int)verts.size() );
00363     assert( count == (int)( 4 * elems.size() ) );
00364     assert( junk2 == (int)junk.size() );
00365     assert( junk4 == &verts[0] );
00366     assert( junk5 == &junk[0] );
00367     std::sort( verts.begin(), verts.end() );
00368     verts.erase( std::unique( verts.begin(), verts.end() ), verts.end() );
00369     return iBase_SUCCESS;
00370 }
00371
00372 static int get_coords( iMesh_Instance imesh, const iBase_EntityHandle* verts, int num_verts, double* coords )
00373 {
00374     double* junk1 = coords;
00375     int junk2     = 3 * num_verts;
00376     int junk3;
00377     int ierr;
00378     iMesh_getVtxArrCoords( imesh, verts, num_verts, iBase_INTERLEAVED, &junk1, &junk2, &junk3, &ierr );
00379     if( iBase_SUCCESS != ierr ) return ierr;
00380     assert( junk1 == coords );
00381     assert( junk2 == 3 * num_verts );
00382     assert( junk3 == 3 * num_verts );
00383     return iBase_SUCCESS;
00384 }
00385
00386 /**************************************************************************
00387                               Main Method
00388  **************************************************************************/
00389
00390 #define RUN_TEST( A ) run_test( &( A ), #A )
00391
00392 int run_test( int ( *func )( iMesh_Instance, iMeshP_PartitionHandle, const PartMap& ), const char* func_name )
00393 {
00394     int rank, size, ierr;
00395     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00396     MPI_Comm_size( MPI_COMM_WORLD, &size );
00397     iMesh_Instance imesh;
00398     iMesh_newMesh( 0, &imesh, &ierr, 0 );
00399     PCHECK;
00400
00401     iMeshP_PartitionHandle prtn;
00402     iMeshP_createPartitionAll( imesh, MPI_COMM_WORLD, &prtn, &ierr );
00403     PCHECK;
00404
00405     PartMap map;
00406
00407 #ifdef MOAB_HAVE_HDF5
00408     if( rank == 0 )
00409     {
00410         ierr = create_mesh( FILENAME, size );
00411     }
00412     MPI_Bcast( &ierr, 1, MPI_INT, 0, MPI_COMM_WORLD );
00413     if( ierr )
00414     {
00415         if( rank == 0 )
00416         {
00417             std::cerr << "Failed to create input test file on root processor.  Aborting." << std::endl;
00418         }
00419         abort();
00420     }
00421
00422     ierr = test_load( imesh, prtn, map, size );
00423     if( ierr )
00424     {
00425         if( rank == 0 )
00426         {
00427             std::cerr << "Failed to load input mesh." << std::endl
00428                       << "Cannot run further tests." << std::endl
00429                       << "ABORTING" << std::endl;
00430         }
00431         abort();
00432     }
00433 #else
00434     // so we have MPI and no HDF5; in order to run the test we need to create the
00435     // model in memory, and then call sync to resolve shared ents, as if it was read
00436     ierr = create_mesh_in_memory( rank, size, imesh, prtn, map );
00437     MPI_Bcast( &ierr, 1, MPI_INT, 0, MPI_COMM_WORLD );
00438     if( ierr )
00439     {
00440         if( rank == 0 )
00441         {
00442             std::cerr << "Failed to create mesh.  Aborting." << std::endl;
00443         }
00444         abort();
00445     }
00446
00447 #endif
00448     int result = ( *func )( imesh, prtn, map );
00449     int is_err = is_any_proc_error( result );
00450     if( rank == 0 )
00451     {
00452         if( is_err )
00453             std::cout << func_name << " : FAILED!!" << std::endl;
00454         else
00455             std::cout << func_name << " : success" << std::endl;
00456     }
00457
00458     iMesh_dtor( imesh, &ierr );CHKERR;
00459     return is_err;
00460 }
00461
00462 int main( int argc, char* argv[] )
00463 {
00464     MPI_Init( &argc, &argv );
00465     int size, rank;
00466     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00467     MPI_Comm_size( MPI_COMM_WORLD, &size );
00468
00469     if( argc > 2 && !strcmp( argv[1], "-p" ) )
00470     {
00471 #if !defined( _MSC_VER ) && !defined( __MINGW32__ )
00472         std::cout << "Processor " << rank << " of " << size << " with PID " << getpid() << std::endl;
00473         std::cout.flush();
00474 #endif
00475         // loop forever on requested processor, giving the user time
00476         // to attach a debugger.  Once the debugger in attached, user
00477         // can change 'pause'.  E.g. on gdb do "set var pause = 0"
00478         if( atoi( argv[2] ) == rank )
00479         {
00480             volatile int pause = 1;
00481             while( pause )
00482                 ;
00483         }
00484         MPI_Barrier( MPI_COMM_WORLD );
00485     }
00486
00487     int num_errors = 0;
00488     num_errors += RUN_TEST( test_get_partitions );
00489     num_errors += RUN_TEST( test_get_parts );
00490     num_errors += RUN_TEST( test_get_by_type );
00491     num_errors += RUN_TEST( test_get_by_topo );
00492     num_errors += RUN_TEST( test_part_id_handle );
00493     num_errors += RUN_TEST( test_part_rank );
00494     num_errors += RUN_TEST( test_get_neighbors );
00495     num_errors += RUN_TEST( test_get_part_boundary );
00496     num_errors += RUN_TEST( test_part_boundary_iter );
00497     num_errors += RUN_TEST( test_get_adjacencies );
00498     num_errors += RUN_TEST( test_entity_iterator );
00499     num_errors += RUN_TEST( test_entity_owner );
00500     num_errors += RUN_TEST( test_entity_status );
00501     num_errors += RUN_TEST( test_entity_copy_parts );
00502     num_errors += RUN_TEST( test_entity_copies );
00503     num_errors += RUN_TEST( test_push_tag_data_iface );
00504     num_errors += RUN_TEST( test_push_tag_data_ghost );
00505     num_errors += RUN_TEST( test_create_ghost_ents );
00506     num_errors += RUN_TEST( test_exchange_ents );
00507
00508     // wait until all procs are done before writing summary data
00509     std::cout.flush();
00510     MPI_Barrier( MPI_COMM_WORLD );
00511
00512 #ifdef MOAB_HAVE_HDF5
00513     // clean up output file
00514     if( rank == 0 ) remove( FILENAME );
00515 #endif
00516
00517     if( rank == 0 )
00518     {
00519         if( !num_errors )
00520             std::cout << "All tests passed" << std::endl;
00521         else
00522             std::cout << num_errors << " TESTS FAILED!" << std::endl;
00523     }
00524
00525     MPI_Finalize();
00526     return num_errors;
00527 }
00528
00529 // Create a mesh
00530 //
00531 //
00532 // Groups of four quads will be arranged into parts as follows:
00533 // +------+------+------+------+------+-----
00534 // |             |             |
00535 // |             |             |
00536 // +    Part 0   +    Part 2   +    Part 4
00537 // |             |             |
00538 // |             |             |
00539 // +------+------+------+------+------+-----
00540 // |             |             |
00541 // |             |             |
00542 // +    Part 1   +    Part 3   +    Part 5
00543 // |             |             |
00544 // |             |             |
00545 // +------+------+------+------+------+-----
00546 //
00547 // Vertices will be enumerated as follows:
00548 // 1------6-----11-----16-----21-----26-----
00549 // |             |             |
00550 // |             |             |
00551 // 2      7     12     17     22     27
00552 // |             |             |
00553 // |             |             |
00554 // 3------8-----13-----18-----23-----28-----
00555 // |             |             |
00556 // |             |             |
00557 // 4      9     14     19     24     29
00558 // |             |             |
00559 // |             |             |
00560 // 5-----10-----15-----20-----25-----30-----
00561 //
00562 // Element IDs will be [4*rank+1,4*rank+5]
00563 template < int size >
00564 struct EHARR
00565 {
00566     iBase_EntityHandle h[size];
00567     iBase_EntityHandle& operator[]( int i )
00568     {
00569         return h[i];
00570     }
00571     operator iBase_EntityHandle*()
00572     {
00573         return h;
00574     }
00575 };
00576 int create_mesh( const char* filename, int num_parts )
00577 {
00578     const char* tagname = "GLOBAL_ID";
00579     int ierr;
00580
00581     iMesh_Instance imesh;
00582     iMesh_newMesh( 0, &imesh, &ierr, 0 );CHKERR;
00583
00584     const int num_full_cols  = 2 * ( num_parts / 2 );
00585     const int need_half_cols = num_parts % 2;
00586     const int num_cols       = num_full_cols + 2 * need_half_cols;
00587     const int num_vtx        = 5 + 5 * num_cols - 4 * ( num_parts % 2 );
00588     std::vector< EHARR< 5 > > vertices( num_cols + 1 );
00589     std::vector< EHARR< 4 > > elements( num_cols );
00590     std::vector< int > vertex_ids( num_vtx );
00591     std::vector< iBase_EntityHandle > vertex_list( num_vtx );
00592     for( int i = 0; i < num_vtx; ++i )
00593         vertex_ids[i] = i + 1;
00594
00595     // create vertices
00596     int vl_pos = 0;
00597     for( int i = 0; i <= num_cols; ++i )
00598     {
00599         double coords[15]       = { static_cast< double >( i ), 0, 0, static_cast< double >( i ), 1, 0,
00600                               static_cast< double >( i ), 2, 0, static_cast< double >( i ), 3, 0,
00601                               static_cast< double >( i ), 4, 0 };
00602         iBase_EntityHandle* ptr = vertices[i];
00603         const int n             = ( num_full_cols == num_cols || i <= num_full_cols ) ? 5 : 3;
00604         int junk1 = n, junk2 = n;
00605         iMesh_createVtxArr( imesh, n, iBase_INTERLEAVED, coords, 3 * n, &ptr, &junk1, &junk2, &ierr );CHKERR;
00606         assert( ptr == vertices[i] );
00607         assert( junk1 == n );
00608         assert( junk2 == n );
00609         for( int j = 0; j < n; ++j )
00610             vertex_list[vl_pos++] = vertices[i][j];
00611     }
00612
00613     // create elements
00614     for( int i = 0; i < num_cols; ++i )
00615     {
00616         iBase_EntityHandle conn[16];
00617         for( int j = 0; j < 4; ++j )
00618         {
00619             conn[4 * j]     = vertices[i][j];
00620             conn[4 * j + 1] = vertices[i][j + 1];
00621             conn[4 * j + 2] = vertices[i + 1][j + 1];
00622             conn[4 * j + 3] = vertices[i + 1][j];
00623         }
00624         iBase_EntityHandle* ptr = elements[i];
00625         const int n             = ( i < num_full_cols ) ? 4 : 2;
00626         int junk1 = n, junk2 = n, junk3 = n, junk4 = n;
00627         int stat[4];
00628         int* ptr2 = stat;
00629         iMesh_createEntArr( imesh, iMesh_QUADRILATERAL, conn, 4 * n, &ptr, &junk1, &junk2, &ptr2, &junk3, &junk4,
00630                             &ierr );CHKERR;
00631         assert( ptr == elements[i] );
00632         assert( junk1 == n );
00633         assert( junk2 == n );
00634         assert( ptr2 == stat );
00635         assert( junk3 == n );
00636         assert( junk4 == n );
00637     }
00638
00639     // create partition
00640     iMeshP_PartitionHandle partition;
00641     iMeshP_createPartitionAll( imesh, MPI_COMM_SELF, &partition, &ierr );CHKERR;
00642     for( int i = 0; i < num_parts; ++i )
00643     {
00644         iMeshP_PartHandle part;
00645         iMeshP_createPart( imesh, partition, &part, &ierr );CHKERR;
00646         iBase_EntityHandle quads[] = { elements[2 * ( i / 2 )][2 * ( i % 2 )],
00647                                        elements[2 * ( i / 2 ) + 1][2 * ( i % 2 )],
00648                                        elements[2 * ( i / 2 )][2 * ( i % 2 ) + 1],
00649                                        elements[2 * ( i / 2 ) + 1][2 * ( i % 2 ) + 1] };
00650         iMesh_addEntArrToSet( imesh, quads, 4, part, &ierr );CHKERR;
00651     }
00652
00653     // assign global ids to vertices
00654     iBase_TagHandle id_tag = 0;
00655     iMesh_getTagHandle( imesh, tagname, &id_tag, &ierr, strlen( tagname ) );
00656     if( iBase_SUCCESS == ierr )
00657     {
00658         int tag_size, tag_type;
00659         iMesh_getTagSizeValues( imesh, id_tag, &tag_size, &ierr );CHKERR;
00660         if( tag_size != 1 ) return iBase_TAG_ALREADY_EXISTS;
00661         iMesh_getTagType( imesh, id_tag, &tag_type, &ierr );CHKERR;
00662         if( tag_type != iBase_INTEGER ) return iBase_TAG_ALREADY_EXISTS;
00663     }
00664     else
00665     {
00666         iMesh_createTag( imesh, tagname, 1, iBase_INTEGER, &id_tag, &ierr, strlen( tagname ) );CHKERR;
00667     }
00668     iMesh_setIntArrData( imesh, &vertex_list[0], num_vtx, id_tag, &vertex_ids[0], num_vtx, &ierr );CHKERR;
00669
00670     // write file
00671     iBase_EntitySetHandle root_set;
00672     iMesh_getRootSet( imesh, &root_set, &ierr );
00673     iMeshP_saveAll( imesh, partition, root_set, filename, 0, &ierr, strlen( filename ), 0 );CHKERR;
00674
00675     iMesh_dtor( imesh, &ierr );CHKERR;
00676
00677     return 0;
00678 }
00679 int create_mesh_in_memory( int rank,
00680                            int num_parts,
00681                            iMesh_Instance imesh,
00682                            iMeshP_PartitionHandle& partition,
00683                            PartMap& map )
00684 {
00685     const char* tagname = "GLOBAL_ID";
00686     int ierr;
00687
00688     const int num_cols = 2;
00689     const int num_vtx  = 9;
00690     // we are on the top or botton row
00691     int bottom = rank % 2;  // 0  2
00692                             // 1  3
00693     std::vector< EHARR< 3 > > vertices( 3 );
00694     std::vector< EHARR< 2 > > elements( 2 );  // 4 elements per process
00695     std::vector< int > vertex_ids( num_vtx );
00696     std::vector< iBase_EntityHandle > vertex_list( num_vtx );
00697     int start = 1 + 2 * bottom + 10 * ( rank / 2 );
00698
00699     for( int i = 0; i < 3; ++i )
00700         for( int j = 0; j < 3; ++j )
00701         {
00702             vertex_ids[i + 3 * j] = start + i + 5 * j;
00703         }
00704
00705     // create vertices
00706     int vl_pos = 0;
00707     int startI = 2 * ( rank / 2 );  // so it will be 0, 0, 2, 2, ...)
00708     for( int i = 0; i <= 2; ++i )
00709     {
00710         double coords[9] = {
00711             static_cast< double >( i + startI ), 2. * bottom,     0,
00712             static_cast< double >( i + startI ), 1 + 2. * bottom, 0,
00713             static_cast< double >( i + startI ), 2 + 2. * bottom, 0,
00714         };
00715         iBase_EntityHandle* ptr = vertices[i];
00716         const int n             = 3;
00717         int junk1 = n, junk2 = n;
00718         iMesh_createVtxArr( imesh, n, iBase_INTERLEAVED, coords, 3 * n, &ptr, &junk1, &junk2, &ierr );CHKERR;
00719         assert( ptr == vertices[i] );
00720         assert( junk1 == n );
00721         assert( junk2 == n );
00722         for( int j = 0; j < n; ++j )
00723             vertex_list[vl_pos++] = vertices[i][j];
00724     }
00725
00726     // create elements
00727     for( int i = 0; i < num_cols; ++i )
00728     {
00729         iBase_EntityHandle conn[8];
00730         for( int j = 0; j < 2; ++j )
00731         {
00732             conn[4 * j]     = vertices[i][j];
00733             conn[4 * j + 1] = vertices[i][j + 1];
00734             conn[4 * j + 2] = vertices[i + 1][j + 1];
00735             conn[4 * j + 3] = vertices[i + 1][j];
00736         }
00737         iBase_EntityHandle* ptr = elements[i];
00738         const int n             = 2;
00739         int junk1 = n, junk2 = n, junk3 = n, junk4 = n;
00740         int stat[4];
00741         int* ptr2 = stat;
00742         iMesh_createEntArr( imesh, iMesh_QUADRILATERAL, conn, 4 * n, &ptr, &junk1, &junk2, &ptr2, &junk3, &junk4,
00743                             &ierr );CHKERR;
00744         assert( ptr == elements[i] );
00745         assert( junk1 == n );
00746         assert( junk2 == n );
00747         assert( ptr2 == stat );
00748         assert( junk3 == n );
00749         assert( junk4 == n );
00750     }
00751
00752     // create partition
00753     iMeshP_createPartitionAll( imesh, MPI_COMM_WORLD, &partition, &ierr );CHKERR;
00754
00755     iMeshP_PartHandle part;
00756     iMeshP_createPart( imesh, partition, &part, &ierr );CHKERR;
00757     iBase_EntityHandle quads[] = { elements[0][0], elements[0][1], elements[1][0], elements[1][1] };
00758     iMesh_addEntArrToSet( imesh, quads, 4, part, &ierr );CHKERR;
00759
00760     // assign global ids to vertices
00761     iBase_TagHandle id_tag = 0;
00762     iMesh_getTagHandle( imesh, tagname, &id_tag, &ierr, strlen( tagname ) );
00763     if( iBase_SUCCESS == ierr )
00764     {
00765         int tag_size, tag_type;
00766         iMesh_getTagSizeValues( imesh, id_tag, &tag_size, &ierr );CHKERR;
00767         if( tag_size != 1 ) return iBase_TAG_ALREADY_EXISTS;
00768         iMesh_getTagType( imesh, id_tag, &tag_type, &ierr );CHKERR;
00769         if( tag_type != iBase_INTEGER ) return iBase_TAG_ALREADY_EXISTS;
00770     }
00771     else
00772     {
00773         iMesh_createTag( imesh, tagname, 1, iBase_INTEGER, &id_tag, &ierr, strlen( tagname ) );CHKERR;
00774     }
00775     iMesh_setIntArrData( imesh, &vertex_list[0], num_vtx, id_tag, &vertex_ids[0], num_vtx, &ierr );CHKERR;
00776
00777     // some mesh sync
00778     iMeshP_syncPartitionAll( imesh, partition, &ierr );CHKERR;
00779     iMeshP_syncMeshAll( imesh, partition, &ierr );CHKERR;
00780
00781     ierr = map.build_map( imesh, partition, num_parts );CHKERR;
00782     return 0;
00783 }
00784 // generate unique for each vertex from coordinates.
00785 // Assume integer coordinate values with x in [0,inf] and y in [0,4]
00786 // as generated by create_mean(..).
00787 int vertex_tag( iMesh_Instance imesh, iBase_EntityHandle vertex, int& tag )
00788 {
00789     int ierr;
00790     double x, y, z;
00791     iMesh_getVtxCoord( imesh, vertex, &x, &y, &z, &ierr );CHKERR;
00792
00793     int xc = (int)round( x );
00794     int yc = (int)round( y );
00795     tag    = 5 * xc + yc + 1;
00796     return ierr;
00797 }
00798
00799 /**************************************************************************
00800                            Test  Implementations
00801  **************************************************************************/
00802
00803 int test_load( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, PartMap& map, int proc_size )
00804 {
00805     int ierr;
00806
00807     iBase_EntitySetHandle root_set;
00808     iMesh_getRootSet( imesh, &root_set, &ierr );
00809     const char* opt = "moab:PARTITION=PARALLEL_PARTITION";
00810     iMeshP_loadAll( imesh, prtn, root_set, FILENAME, opt, &ierr, strlen( FILENAME ), strlen( opt ) );
00811     PCHECK;
00812
00813     ierr = map.build_map( imesh, prtn, proc_size );CHKERR;
00814     return iBase_SUCCESS;
00815 }
00816
00817 /**\brief Test partition query methods
00818  *
00819  * Test:
00820  * - iMeshP_getPartitionComm
00821  * - iMeshP_getNumPartitions
00822  * - iMeshP_getPartitions
00823  */
00824 int test_get_partitions( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& )
00825 {
00826     int ierr;
00827
00828     // test iMeshP_getPartitionCom
00829     MPI_Comm comm = MPI_COMM_SELF;
00830     iMeshP_getPartitionComm( imesh, prtn, &comm, &ierr );
00831     PCHECK;
00832     ASSERT( comm == MPI_COMM_WORLD );
00833
00834     // test iMeshP_getPartitions
00835     iMeshP_PartitionHandle* array = 0;
00836     int alloc = 0, size = -1;
00837     iMeshP_getPartitions( imesh, &array, &alloc, &size, &ierr );
00838     PCHECK;
00839     ASSERT( array != 0 );
00840     ASSERT( alloc == size );
00841     ASSERT( size > 0 );
00842     int idx = std::find( array, array + size, prtn ) - array;
00843     free( array );
00844     ASSERT( idx < size );
00845
00846     // test iMesP_getNumPartitions
00847     int size2 = -1;
00848     iMeshP_getNumPartitions( imesh, &size2, &ierr );
00849     PCHECK;
00850     ASSERT( size2 == size );
00851     return 0;
00852 }
00853
00854 /**\brief Test part quyery methods
00855  *
00856  * Test:
00857  * - iMeshP_getNumGlobalParts
00858  * - iMeshP_getNumLocalParts
00859  * - iMeshP_getLocalParts
00860  */
00861 int test_get_parts( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
00862 {
00863     int size, rank, ierr;
00864     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00865     MPI_Comm_size( MPI_COMM_WORLD, &size );
00866
00867     int num_part_g;
00868     iMeshP_getNumGlobalParts( imesh, prtn, &num_part_g, &ierr );
00869     PCHECK;
00870     ASSERT( num_part_g == map.num_parts() );
00871
00872     int num_part_l;
00873     iMeshP_getNumLocalParts( imesh, prtn, &num_part_l, &ierr );
00874     PCHECK;
00875     ASSERT( num_part_l == map.count_from_rank( rank ) );
00876
00877     std::vector< iMeshP_PartHandle > parts( num_part_l );
00878     iMeshP_PartHandle* ptr = &parts[0];
00879     int junk1 = num_part_l, count = -1;
00880     iMeshP_getLocalParts( imesh, prtn, &ptr, &junk1, &count, &ierr );
00881     PCHECK;
00882     assert( ptr == &parts[0] );
00883     assert( junk1 == num_part_l );
00884     ASSERT( count == num_part_l );
00885
00886     return iBase_SUCCESS;
00887 }
00888
00889 static int test_get_by_type_topo_all( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, bool test_type, int num_parts )
00890 {
00891     // calculate number of quads and vertices in entire mesh
00892     // from number of parts (see create_mesh(..) function.)
00893     const int expected_global_quad_count = 4 * num_parts;
00894     const int num_col                    = 2 * ( num_parts / 2 + num_parts % 2 );
00895     const int expected_global_vtx_count  = num_parts == 1 ? 9 : num_parts % 2 ? 1 + 5 * num_col : 5 + 5 * num_col;
00896
00897     // test getNumOf*All for root set
00898     int ierr, count;
00899     iBase_EntitySetHandle root;
00900     iMesh_getRootSet( imesh, &root, &ierr );
00901     if( test_type )
00902         iMeshP_getNumOfTypeAll( imesh, prtn, root, iBase_VERTEX, &count, &ierr );
00903     else
00904         iMeshP_getNumOfTopoAll( imesh, prtn, root, iMesh_POINT, &count, &ierr );
00905     PCHECK;
00906     ASSERT( count == expected_global_vtx_count );
00907     if( test_type )
00908         iMeshP_getNumOfTypeAll( imesh, prtn, root, iBase_FACE, &count, &ierr );
00909     else
00910         iMeshP_getNumOfTopoAll( imesh, prtn, root, iMesh_QUADRILATERAL, &count, &ierr );
00911     PCHECK;
00912     ASSERT( count == expected_global_quad_count );
00913
00914     // create an entity set containing half of the quads
00915     std::vector< iBase_EntityHandle > all_quads, half_quads;
00916     ierr = get_entities( imesh, root, iBase_FACE, iMesh_QUADRILATERAL, all_quads );
00917     assert( 0 == all_quads.size() % 2 );
00918     half_quads.resize( all_quads.size() / 2 );
00919     for( size_t i = 0; i < all_quads.size() / 2; ++i )
00920         half_quads[i] = all_quads[2 * i];
00921     iBase_EntitySetHandle set;
00922     iMesh_createEntSet( imesh, 1, &set, &ierr );CHKERR;
00923     iMesh_addEntArrToSet( imesh, &half_quads[0], half_quads.size(), set, &ierr );CHKERR;
00924
00925     // test getNumOf*All with defined set
00926     if( test_type )
00927         iMeshP_getNumOfTypeAll( imesh, prtn, set, iBase_VERTEX, &count, &ierr );
00928     else
00929         iMeshP_getNumOfTopoAll( imesh, prtn, set, iMesh_POINT, &count, &ierr );
00930     PCHECK;
00931     ASSERT( count == 0 );
00932     if( test_type )
00933         iMeshP_getNumOfTypeAll( imesh, prtn, set, iBase_FACE, &count, &ierr );
00934     else
00935         iMeshP_getNumOfTopoAll( imesh, prtn, set, iMesh_QUADRILATERAL, &count, &ierr );
00936     PCHECK;
00937     ASSERT( count == expected_global_quad_count / 2 );
00938
00939     return 0;
00940 }
00941
00942 static int test_get_by_type_topo_local( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, bool test_type )
00943 {
00944     int ierr;
00945     iBase_EntitySetHandle root;
00946     iMesh_getRootSet( imesh, &root, &ierr );
00947
00948     // select a single part
00949     std::vector< iMeshP_PartHandle > parts;
00950     ierr = get_local_parts( imesh, prtn, parts );CHKERR;
00951     iMeshP_PartHandle part = parts.front();
00952
00953     // get the entities contained in the part
00954     std::vector< iBase_EntityHandle > part_quads, part_all;
00955     ierr = get_entities( imesh, part, iBase_FACE, iMesh_QUADRILATERAL, part_quads );CHKERR;
00956     ierr = get_entities( imesh, part, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, part_all );CHKERR;
00957
00958     // compare local counts (using root set)
00959
00960     int count;
00961     if( test_type )
00962         iMeshP_getNumOfType( imesh, prtn, part, root, iBase_FACE, &count, &ierr );
00963     else
00964         iMeshP_getNumOfTopo( imesh, prtn, part, root, iMesh_QUADRILATERAL, &count, &ierr );CHKERR;
00965     ASSERT( count == (int)part_quads.size() );
00966
00967     if( test_type )
00968         iMeshP_getNumOfType( imesh, prtn, part, root, iBase_ALL_TYPES, &count, &ierr );
00969     else
00970         iMeshP_getNumOfTopo( imesh, prtn, part, root, iMesh_ALL_TOPOLOGIES, &count, &ierr );CHKERR;
00971     ASSERT( count == (int)part_all.size() );
00972
00973     // compare local contents (using root set)
00974
00975     iBase_EntityHandle* ptr = 0;
00976     int num_ent, junk1 = 0;
00977     iMeshP_getEntities( imesh, prtn, part, root, test_type ? iBase_FACE : iBase_ALL_TYPES,
00978                         test_type ? iMesh_ALL_TOPOLOGIES : iMesh_QUADRILATERAL, &ptr, &junk1, &num_ent, &ierr );CHKERR;
00979     std::vector< iBase_EntityHandle > act_quads( ptr, ptr + num_ent );
00980     free( ptr );
00981     junk1 = num_ent = 0;
00982     ptr             = 0;
00983     iMeshP_getEntities( imesh, prtn, part, root, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &ptr, &junk1, &num_ent, &ierr );CHKERR;
00984     std::vector< iBase_EntityHandle > act_all( ptr, ptr + num_ent );
00985     free( ptr );
00986     std::sort( part_quads.begin(), part_quads.end() );
00987     std::sort( part_all.begin(), part_all.end() );
00988     std::sort( act_quads.begin(), act_quads.end() );
00989     std::sort( act_all.begin(), act_all.end() );
00990     ASSERT( part_quads == act_quads );
00991     ASSERT( part_all == act_all );
00992
00993     // create an entity set containing half of the quads from the part
00994     std::vector< iBase_EntityHandle > half_quads( part_quads.size() / 2 );
00995     for( size_t i = 0; i < half_quads.size(); ++i )
00996         half_quads[i] = part_quads[2 * i];
00997     iBase_EntitySetHandle set;
00998     iMesh_createEntSet( imesh, 1, &set, &ierr );CHKERR;
00999     iMesh_addEntArrToSet( imesh, &half_quads[0], half_quads.size(), set, &ierr );CHKERR;
01000
01001     // check if there exists any quads not in the part that we
01002     // can add to the set
01003     std::vector< iBase_EntityHandle > all_quads, other_quads;
01004     ierr = get_entities( imesh, root, iBase_FACE, iMesh_QUADRILATERAL, all_quads );CHKERR;
01005     std::sort( all_quads.begin(), all_quads.end() );
01006     std::sort( part_quads.begin(), part_quads.end() );
01007     std::set_difference( all_quads.begin(), all_quads.end(), part_quads.begin(), part_quads.end(),
01008                          std::back_inserter( other_quads ) );
01009     iMesh_addEntArrToSet( imesh, &other_quads[0], other_quads.size(), set, &ierr );CHKERR;
01010
01011     // compare local counts (using non-root set)
01012
01013     if( test_type )
01014         iMeshP_getNumOfType( imesh, prtn, part, set, iBase_FACE, &count, &ierr );
01015     else
01016         iMeshP_getNumOfTopo( imesh, prtn, part, set, iMesh_QUADRILATERAL, &count, &ierr );CHKERR;
01017     ASSERT( count == (int)half_quads.size() );
01018
01019     if( test_type )
01020         iMeshP_getNumOfType( imesh, prtn, part, set, iBase_VERTEX, &count, &ierr );
01021     else
01022         iMeshP_getNumOfTopo( imesh, prtn, part, set, iMesh_POINT, &count, &ierr );CHKERR;
01023     ASSERT( count == 0 );
01024
01025     // compare local contents (using non-root set)
01026
01027     junk1   = 0;
01028     num_ent = 0;
01029     ptr     = 0;
01030     iMeshP_getEntities( imesh, prtn, part, set, test_type ? iBase_FACE : iBase_ALL_TYPES,
01031                         test_type ? iMesh_ALL_TOPOLOGIES : iMesh_QUADRILATERAL, &ptr, &junk1, &num_ent, &ierr );CHKERR;
01032     act_quads.resize( num_ent );
01033     std::copy( ptr, ptr + num_ent, act_quads.begin() );
01034     free( ptr );
01035     std::sort( half_quads.begin(), half_quads.end() );
01036     std::sort( act_quads.begin(), act_quads.end() );
01037     ASSERT( act_quads == half_quads );
01038
01039     return iBase_SUCCESS;
01040 }
01041
01042 /**\brief Test query by entity type
01043  *
01044  * Test:
01045  * - iMeshP_getNumOfTypeAll
01046  * - iMeshP_getNumOfType
01047  * - iMeshP_getEntities
01048  * -
01049  */
01050 int test_get_by_type( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
01051 {
01052     int ierr;
01053     ierr = test_get_by_type_topo_all( imesh, prtn, true, map.num_parts() );
01054     PCHECK;
01055     ierr = test_get_by_type_topo_local( imesh, prtn, true );
01056     PCHECK;
01057     return 0;
01058 }
01059
01060 /**\brief Test query by entity topology
01061  *
01062  * Test:
01063  * - iMeshP_getNumOfTopoAll
01064  * - iMeshP_getNumOfTopo
01065  * - iMeshP_getEntities
01066  * -
01067  */
01068 int test_get_by_topo( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
01069 {
01070     int ierr;
01071     ierr = test_get_by_type_topo_all( imesh, prtn, false, map.num_parts() );
01072     PCHECK;
01073     ierr = test_get_by_type_topo_local( imesh, prtn, false );
01074     PCHECK;
01075     return 0;
01076 }
01077
01078 /**\brief Test mapping from part id to part handle
01079  *
01080  * Test:
01081  * - iMeshP_getPartIdFromPartHandle
01082  * - iMeshP_getPartIdsFromPartHandlesArr
01083  * - iMeshP_getPartHandleFromPartId
01084  * - iMeshP_getPartHandlesFromPartsIdsArr
01085  */
01086 int test_part_id_handle( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
01087 {
01088     // get local part ids
01089     int rank, ierr;
01090     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
01091     std::vector< iMeshP_Part > ids;
01092     map.part_id_from_rank( rank, ids );
01093
01094     // check single-part functions and build list of part handles
01095     std::vector< iMeshP_PartHandle > handles( ids.size() );
01096     size_t i;
01097     for( i = 0; i < ids.size(); ++i )
01098     {
01099         iMeshP_getPartHandleFromPartId( imesh, prtn, ids[i], &handles[i], &ierr );CHKERR;
01100         iMeshP_Part id;
01101         iMeshP_getPartIdFromPartHandle( imesh, prtn, handles[i], &id, &ierr );CHKERR;
01102         if( id != ids[i] ) break;
01103     }
01104     ASSERT( i == ids.size() );
01105
01106     // test iMeshP_getPartIdsFromPartHandlesArr
01107     std::vector< iMeshP_Part > ids2( ids.size() );
01108     int junk1 = ids.size(), junk2 = 0;
01109     iMeshP_Part* ptr = &ids2[0];
01110     iMeshP_getPartIdsFromPartHandlesArr( imesh, prtn, &handles[0], handles.size(), &ptr, &junk1, &junk2, &ierr );
01111     PCHECK;
01112     ASSERT( ptr == &ids2[0] );
01113     ASSERT( junk2 == (int)ids2.size() );
01114     ASSERT( ids == ids2 );
01115
01116     // test iMeshP_getPartHandlesFromPartsIdsArr
01117     std::vector< iMeshP_PartHandle > handles2( handles.size() );
01118     junk1                   = handles.size();
01119     junk2                   = 0;
01120     iMeshP_PartHandle* ptr2 = &handles2[0];
01121     iMeshP_getPartHandlesFromPartsIdsArr( imesh, prtn, &ids[0], ids.size(), &ptr2, &junk1, &junk2, &ierr );
01122     PCHECK;
01123     ASSERT( ptr2 == &handles2[0] );
01124     ASSERT( junk2 == (int)handles2.size() );
01125     ASSERT( handles == handles2 );
01126
01127     return 0;
01128 }
01129
01130 /**\brief Test get part rank
01131  *
01132  * Tests:
01133  * - iMeshP_getRankOfPart
01134  * - iMeshP_getRankOfPartArr
01135  */
01136 int test_part_rank( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
01137 {
01138     int ierr = 0, rank;
01139     std::vector< iMeshP_Part > invalid, failed;
01140     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
01141
01142     // test iMeshP_getRankOfPart
01143     for( size_t i = 0; i < map.get_parts().size(); ++i )
01144     {
01145         int pr;
01146         iMeshP_getRankOfPart( imesh, prtn, map.get_parts()[i], &pr, &ierr );
01147         if( iBase_SUCCESS != ierr )
01148             failed.push_back( map.get_parts()[i] );
01149         else if( pr != map.get_ranks()[i] )
01150             invalid.push_back( map.get_parts()[i] );
01151     }
01152     if( !failed.empty() )
01153     {
01154         std::cerr << "Processor " << rank << ": iMeshP_getRankOfPart failed for " << failed.size() << " parts."
01155                   << std::endl;
01156         ierr = iBase_FAILURE;
01157     }
01158     if( !invalid.empty() )
01159     {
01160         std::cerr << "Processor " << rank << ": iMeshP_getRankOfPart was incorrect for " << invalid.size() << " parts."
01161                   << std::endl;
01162         ierr = iBase_FAILURE;
01163     }
01164     PCHECK;
01165
01166     // test iMeshP_getRankOfPartArr
01167     std::vector< int > ranks( map.get_parts().size() );
01168     int junk1 = ranks.size(), junk2, *ptr = &ranks[0];
01169     iMeshP_getRankOfPartArr( imesh, prtn, &map.get_parts()[0], map.get_parts().size(), &ptr, &junk1, &junk2, &ierr );
01170     PCHECK;
01171     assert( ptr == &ranks[0] );
01172     assert( junk1 == (int)ranks.size() );
01173     ASSERT( junk2 == (int)ranks.size() );
01174     for( size_t i = 0; i < map.get_parts().size(); ++i )
01175     {
01176         if( ranks[i] != map.get_ranks()[i] ) invalid.push_back( map.get_parts()[i] );
01177     }
01178     if( !invalid.empty() )
01179     {
01180         std::cerr << "Processor " << rank << ": iMeshP_getRankOfPartArr was incorrect for " << invalid.size()
01181                   << " parts." << std::endl;
01182         ierr = iBase_FAILURE;
01183     }
01184     PCHECK;
01185
01186     return 0;
01187 }
01188
01189 // see create_mesh(..)
01190 static void get_part_neighbors( int logical_part_id, int num_parts, int neighbors[5], int& num_neighbors )
01191 {
01192     num_neighbors = 0;
01193     if( logical_part_id + 1 < num_parts ) neighbors[num_neighbors++] = logical_part_id + 1;
01194     if( logical_part_id + 2 < num_parts ) neighbors[num_neighbors++] = logical_part_id + 2;
01195     if( logical_part_id % 2 )
01196     {
01197         neighbors[num_neighbors++] = logical_part_id - 1;
01198         if( logical_part_id > 2 )
01199         {
01200             neighbors[num_neighbors++] = logical_part_id - 3;
01201             neighbors[num_neighbors++] = logical_part_id - 2;
01202         }
01203     }
01204     else
01205     {
01206         if( logical_part_id + 3 < num_parts ) neighbors[num_neighbors++] = logical_part_id + 3;
01207         if( logical_part_id > 1 )
01208         {
01209             neighbors[num_neighbors++] = logical_part_id - 1;
01210             neighbors[num_neighbors++] = logical_part_id - 2;
01211         }
01212     }
01213 }
01214
01215 /**\brief Test querying of part neighbors
01216  *
01217  * Test:
01218  * - iMeshP_getNumPartNbors
01219  * - iMeshP_getNumPartNborsArr
01220  * - iMeshP_getPartNbors
01221  * - iMeshP_getPartNborsArr
01222  */
01223 int test_get_neighbors( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
01224 {
01225     int ierr, rank;
01226     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
01227
01228     std::vector< iMeshP_Part > local_parts;
01229     map.part_id_from_rank( rank, local_parts );
01230
01231     // get handles for local parts
01232     std::vector< iMeshP_PartHandle > handles( local_parts.size() );
01233     iMeshP_PartHandle* ptr = &handles[0];
01234     int junk1 = handles.size(), junk2 = 0;
01235     iMeshP_getPartHandlesFromPartsIdsArr( imesh, prtn, &local_parts[0], local_parts.size(), &ptr, &junk1, &junk2,
01236                                           &ierr );
01237     PCHECK;
01238     assert( ptr == &handles[0] );
01239     assert( junk2 == (int)handles.size() );
01240
01241     // get logical ids for local parts
01242     std::vector< int > logical_ids;
01243     map.local_id_from_rank( rank, logical_ids );
01244
01245     // get neighbors for each local part
01246     std::vector< std::vector< iMeshP_Part > > neighbors( logical_ids.size() );
01247     for( size_t i = 0; i < logical_ids.size(); ++i )
01248     {
01249         int logical_neighbors[5], num_neighbors;
01250         get_part_neighbors( logical_ids[i], map.num_parts(), logical_neighbors, num_neighbors );
01251         neighbors[i].resize( num_neighbors );
01252         for( int j = 0; j < num_neighbors; ++j )
01253             neighbors[i][j] = map.part_id_from_local_id( logical_neighbors[j] );
01254         std::sort( neighbors[i].begin(), neighbors[i].end() );
01255     }
01256
01257     // test iMeshP_getNumPartNbors
01258     std::vector< iMeshP_Part > invalid, failed;
01259     for( size_t i = 0; i < local_parts.size(); ++i )
01260     {
01261         int count;
01262         iMeshP_getNumPartNbors( imesh, prtn, handles[i], iBase_VERTEX, &count, &ierr );
01263         if( ierr )
01264             failed.push_back( local_parts[i] );
01265         else if( count != (int)neighbors[i].size() )
01266             invalid.push_back( local_parts[i] );
01267     }
01268     if( !failed.empty() )
01269     {
01270         std::cerr << "Processor " << rank << ": iMeshP_getNumPartNbors failed for " << failed.size() << " parts."
01271                   << std::endl;
01272         ierr = iBase_FAILURE;
01273         PCHECK;
01274     }
01275     if( !invalid.empty() )
01276     {
01277         std::cerr << "Processor " << rank << ": iMeshP_getNumPartNbors was incorrect for " << invalid.size()
01278                   << " parts." << std::endl;
01279         ierr = iBase_FAILURE;
01280         PCHECK;
01281     }
01282
01283     // test iMeshP_getPartNbors
01284     ierr = 0;
01285     for( size_t i = 0; i < local_parts.size(); ++i )
01286     {
01287         int count, junk = 0, another_count;
01288         iMeshP_Part* list = 0;
01289         iMeshP_getPartNbors( imesh, prtn, handles[i], iBase_VERTEX, &another_count, &list, &junk, &count, &ierr );
01290         assert( count == another_count );
01291         if( ierr )
01292             failed.push_back( local_parts[i] );
01293         else
01294         {
01295             std::sort( list, list + count );
01296             std::vector< iMeshP_Part > cpy( list, list + count );
01297             if( cpy != neighbors[i] ) invalid.push_back( local_parts[i] );
01298             free( list );
01299         }
01300     }
01301     if( !failed.empty() )
01302     {
01303         std::cerr << "Processor " << rank << ": iMeshP_getPartNbors failed for " << failed.size() << " parts."
01304                   << std::endl;
01305         ierr = iBase_FAILURE;
01306     }
01307     if( !invalid.empty() )
01308     {
01309         std::cerr << "Processor " << rank << ": iMeshP_getPartNbors was incorrect for " << invalid.size() << " parts."
01310                   << std::endl;
01311         ierr = iBase_FAILURE;
01312     }
01313     PCHECK;
01314
01315     // test iMeshP_getNumPartNborsArr
01316     std::vector< int > count_vect( handles.size() );
01317     int* count_arr = &count_vect[0];
01318     junk1          = handles.size();
01319     iMeshP_getNumPartNborsArr( imesh, prtn, &handles[0], handles.size(), iBase_VERTEX, &count_arr, &junk1, &junk2,
01320                                &ierr );
01321     PCHECK;
01322     assert( count_arr == &count_vect[0] );
01323     assert( junk2 == (int)handles.size() );
01324     for( size_t i = 0; i < local_parts.size(); ++i )
01325     {
01326         if( count_arr[i] != (int)neighbors[i].size() ) invalid.push_back( local_parts[i] );
01327     }
01328     if( !invalid.empty() )
01329     {
01330         std::cerr << "Processor " << rank << ": iMeshP_getNumPartNborsArr was incorrect for " << invalid.size()
01331                   << " parts." << std::endl;
01332         ierr = iBase_FAILURE;
01333     }
01334     PCHECK;
01335
01336     // test iMeshP_getPartNborsArr
01337     iMeshP_Part* nbor_arr = 0;
01338     junk1 = handles.size(), junk2 = 0;
01339     int junk3 = 0, nbor_size;
01340     iMeshP_getPartNborsArr( imesh, prtn, &handles[0], handles.size(), iBase_VERTEX, &count_arr, &junk1, &junk2,
01341                             &nbor_arr, &junk3, &nbor_size, &ierr );
01342     PCHECK;
01343     assert( count_arr == &count_vect[0] );
01344     assert( junk2 == (int)handles.size() );
01345     std::vector< iMeshP_Part > all_nbors( nbor_arr, nbor_arr + nbor_size );
01346     free( nbor_arr );
01347     std::vector< iMeshP_Part >::iterator j = all_nbors.begin();
01348     bool bad_length                        = false;
01349     for( size_t i = 0; i < local_parts.size(); ++i )
01350     {
01351         if( all_nbors.end() - j > count_arr[i] )
01352         {
01353             bad_length = true;
01354             break;
01355         }
01356         if( count_arr[i] != (int)neighbors[i].size() )
01357         {
01358             invalid.push_back( local_parts[i] );
01359         }
01360         else
01361         {
01362             std::vector< iMeshP_Part >::iterator e = j + count_arr[i];
01363             std::sort( j, e );
01364             if( !std::equal( j, e, neighbors[i].begin() ) ) invalid.push_back( local_parts[i] );
01365         }
01366     }
01367     if( bad_length )
01368     {
01369         std::cerr << "Processor " << rank << ": iMeshP_getPartNborsArr had inconsistent result array lengths."
01370                   << std::endl;
01371         ierr = iBase_FAILURE;
01372     }
01373     if( !invalid.empty() )
01374     {
01375         std::cerr << "Processor " << rank << ": iMeshP_getPartNborsArr was incorrect for " << invalid.size()
01376                   << " parts." << std::endl;
01377         ierr = iBase_FAILURE;
01378     }
01379     PCHECK;
01380
01381     return 0;
01382 }
01383
01384 // Determine the expected vertices on the interface between two parts.
01385 // Returns no vertices for non-adjacient parts and fails if both parts
01386 // are the same.
01387 // See create_mesh(..) for the assumed mesh.
01388 static int interface_verts( iMesh_Instance imesh,
01389                             iMeshP_PartitionHandle prtn,
01390                             iMeshP_PartHandle local_part,
01391                             iMeshP_Part other_part,
01392                             const PartMap& map,
01393                             std::vector< iBase_EntityHandle >& vtx_handles )
01394 {
01395     int ierr, rank;
01396     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
01397
01398     iMeshP_Part local_id;
01399     iMeshP_getPartIdFromPartHandle( imesh, prtn, local_part, &local_id, &ierr );CHKERR;
01400
01401     const int local_logical = map.local_id_from_part_id( local_id );
01402     const int other_logical = map.local_id_from_part_id( other_part );
01403
01404     // get grid of local vertices
01405
01406     iBase_EntityHandle verts[3][3];
01407     const double xbase = ( local_id / 2 ) * 2;
01408     const double ybase = ( local_id % 2 ) * 2;
01409
01410     // get quads in partition
01411     iBase_EntityHandle quads[4], *ptr = quads;
01412     int junk1 = 4, junk2;
01413     iMesh_getEntities( imesh, local_part, iBase_FACE, iMesh_QUADRILATERAL, &ptr, &junk1, &junk2, &ierr );CHKERR;
01414     assert( ptr == quads );
01415     assert( junk1 == 4 );
01416     assert( junk2 == 4 );
01417
01418     // get vertices in quads
01419     iBase_EntityHandle conn[16];
01420     int offsets[5], *off_ptr = offsets, junk3 = 5, junk4;
01421     ptr   = conn;
01422     junk1 = 16;
01423     iMesh_getEntArrAdj( imesh, quads, 4, iBase_VERTEX, &ptr, &junk1, &junk2, &off_ptr, &junk3, &junk4, &ierr );CHKERR;
01424     assert( ptr == conn );
01425     assert( junk1 == 16 );
01426     assert( junk2 == 16 );
01427     assert( off_ptr == offsets );
01428     assert( junk3 == 5 );
01429     assert( junk4 == 5 );
01430
01431     // make unique vertex list
01432     std::sort( conn, conn + 16 );
01433     const int num_vtx = std::unique( conn, conn + 16 ) - conn;
01434     assert( 9 == num_vtx );
01435
01436     // get vertex coords
01437     std::vector< double > coords( 27 );
01438     ierr = get_coords( imesh, conn, 9, &coords[0] );CHKERR;
01439
01440     // use vertex coords to determine logical position
01441     for( int i = 0; i < num_vtx; ++i )
01442     {
01443         int x = (int)round( coords[3 * i] - xbase );
01444         int y = (int)round( coords[3 * i + 1] - ybase );
01445         if( x < 0 || x > 2 || y < 0 || y > 2 )
01446         {
01447             std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01448                       << "  Invalid vertex coordinate: (" << coords[3 * i] << ", " << coords[3 * i + 1] << ", "
01449                       << coords[3 * i + 2] << ")" << std::endl
01450                       << "  For logical partition " << local_id << std::endl;
01451             return iBase_FAILURE;
01452         }
01453         verts[x][y] = conn[i];
01454     }
01455
01456     if( local_logical % 2 )
01457     {
01458         switch( other_logical - local_logical )
01459         {
01460             case 0:
01461                 return iBase_FAILURE;
01462             case 1:  // upper right
01463                 vtx_handles.resize( 1 );
01464                 vtx_handles[0] = verts[2][0];
01465                 break;
01466             case 2:  // right
01467                 vtx_handles.resize( 3 );
01468                 std::copy( verts[2], verts[2] + 3, vtx_handles.begin() );
01469                 break;
01470             case -1:  // above
01471                 vtx_handles.resize( 3 );
01472                 vtx_handles[0] = verts[0][0];
01473                 vtx_handles[1] = verts[1][0];
01474                 vtx_handles[2] = verts[2][0];
01475                 break;
01476             case -2:  // left
01477                 vtx_handles.resize( 3 );
01478                 std::copy( verts[0], verts[0] + 3, vtx_handles.begin() );
01479                 break;
01480             case -3:  // upper left
01481                 vtx_handles.resize( 1 );
01482                 vtx_handles[0] = verts[0][0];
01483                 break;
01484             default:
01485                 vtx_handles.clear();
01486                 break;
01487         }
01488     }
01489     else
01490     {
01491         switch( other_logical - local_logical )
01492         {
01493             case 0:
01494                 return iBase_FAILURE;
01495             case 1:  // below
01496                 vtx_handles.resize( 3 );
01497                 vtx_handles[0] = verts[0][2];
01498                 vtx_handles[1] = verts[1][2];
01499                 vtx_handles[2] = verts[2][2];
01500                 break;
01501             case 2:  // right
01502                 vtx_handles.resize( 3 );
01503                 std::copy( verts[2], verts[2] + 3, vtx_handles.begin() );
01504                 break;
01505             case 3:  // lower right
01506                 vtx_handles.resize( 1 );
01507                 vtx_handles[0] = verts[2][2];
01508                 break;
01509             case -1:  // lower left
01510                 vtx_handles.resize( 1 );
01511                 vtx_handles[0] = verts[0][2];
01512                 break;
01513             case -2:  // left
01514                 vtx_handles.resize( 3 );
01515                 std::copy( verts[0], verts[0] + 3, vtx_handles.begin() );
01516                 break;
01517             default:
01518                 vtx_handles.clear();
01519                 break;
01520         }
01521     }
01522
01523     return iBase_SUCCESS;
01524 }
01525
01526 /**\brief Test querying of part boundary entities
01527  *
01528  * Test:
01529  * - iMeshP_getNumPartBdryEnts
01530  * - iMeshP_getPartBdryEnts
01531  */
01532 int test_get_part_boundary( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
01533 {
01534     int ierr, rank;
01535     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
01536
01537     // get local part handles and part ids, and global part id list
01538     std::vector< iMeshP_PartHandle > local_handles;
01539     std::vector< iMeshP_Part > local_ids;
01540     std::vector< iMeshP_Part > all_parts = map.get_parts();
01541     std::map< iMeshP_PartHandle, std::vector< iBase_EntityHandle > > part_bdry;
01542     ierr = get_local_parts( imesh, prtn, local_handles, &local_ids );CHKERR;
01543
01544     // for each combination of local part with any other part,
01545     // check for valid function values.
01546     std::vector< std::pair< iMeshP_Part, iMeshP_Part > > num_failed, num_error, list_failed, list_error, error;
01547     for( size_t i = 0; i < local_handles.size(); ++i )
01548     {
01549         iMeshP_PartHandle local_handle = local_handles[i];
01550         iMeshP_Part local_id           = local_ids[i];
01551         for( std::vector< iMeshP_Part >::iterator j = all_parts.begin(); j != all_parts.end(); ++j )
01552         {
01553             iMeshP_Part other_id = *j;
01554             if( other_id == local_id ) continue;
01555
01556             std::pair< iMeshP_Part, iMeshP_Part > part_pair;
01557             part_pair.first  = local_id;
01558             part_pair.second = other_id;
01559
01560             // get expected values
01561             std::vector< iBase_EntityHandle > shared_verts;
01562             ierr = interface_verts( imesh, prtn, local_handle, other_id, map, shared_verts );
01563             if( ierr != iBase_SUCCESS )
01564             {
01565                 error.push_back( part_pair );
01566                 continue;
01567             }
01568             std::sort( shared_verts.begin(), shared_verts.end() );
01569
01570             // test iMeshP_getNumPartBdryEnts
01571             int count;
01572             iMeshP_getNumPartBdryEnts( imesh, prtn, local_handle, iBase_VERTEX, iMesh_POINT, other_id, &count, &ierr );
01573             if( iBase_SUCCESS != ierr )
01574                 num_error.push_back( part_pair );
01575             else if( count != (int)shared_verts.size() )
01576                 num_failed.push_back( part_pair );
01577
01578             // test iMeshP_getPartBdryEnts
01579             iBase_EntityHandle* ptr = 0;
01580             int junk                = 0;
01581             iMeshP_getPartBdryEnts( imesh, prtn, local_handle, iBase_VERTEX, iMesh_POINT, other_id, &ptr, &junk, &count,
01582                                     &ierr );
01583             if( iBase_SUCCESS != ierr )
01584                 list_error.push_back( part_pair );
01585             else
01586             {
01587                 std::copy( ptr, ptr + count, std::back_inserter( part_bdry[local_handles[i]] ) );
01588                 std::sort( ptr, ptr + count );
01589                 if( (int)shared_verts.size() != count || !std::equal( shared_verts.begin(), shared_verts.end(), ptr ) )
01590                     list_failed.push_back( part_pair );
01591                 free( ptr );
01592             }
01593         }
01594     }
01595
01596     if( !error.empty() )
01597     {
01598         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01599                   << "  Internal error for " << error.size() << " part pairs." << std::endl;
01600         ierr = iBase_FAILURE;
01601     }
01602     if( !num_error.empty() )
01603     {
01604         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01605                   << "  iMeshP_getNumPartBdryEnts return error for " << num_error.size() << " part pairs." << std::endl;
01606         ierr = iBase_FAILURE;
01607     }
01608     if( !list_error.empty() )
01609     {
01610         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01611                   << "  iMeshP_getPartBdryEnts return error for " << list_error.size() << " part pairs." << std::endl;
01612         ierr = iBase_FAILURE;
01613     }
01614     if( !num_failed.empty() )
01615     {
01616         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01617                   << "  iMeshP_getNumPartBdryEnts return incorrect results for " << num_failed.size() << " part pairs."
01618                   << std::endl;
01619         ierr = iBase_FAILURE;
01620     }
01621     if( !list_failed.empty() )
01622     {
01623         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01624                   << "  iMeshP_getPartBdryEnts return incorrect results for " << list_failed.size() << " part pairs."
01625                   << std::endl;
01626         ierr = iBase_FAILURE;
01627     }
01628
01629     if( iBase_SUCCESS != ierr ) return ierr;
01630
01631     // test with iMeshP_ALL_PARTS
01632     for( size_t i = 0; i < local_handles.size(); ++i )
01633     {
01634         std::vector< iBase_EntityHandle >& exp_bdry = part_bdry[local_handles[i]];
01635         std::sort( exp_bdry.begin(), exp_bdry.end() );
01636         exp_bdry.erase( std::unique( exp_bdry.begin(), exp_bdry.end() ), exp_bdry.end() );
01637         std::pair< iMeshP_Part, iMeshP_Part > part_pair;
01638         part_pair.first  = local_ids[i];
01639         part_pair.second = iMeshP_ALL_PARTS;
01640
01641         int num = 0;
01642         iMeshP_getNumPartBdryEnts( imesh, prtn, local_handles[i], iBase_VERTEX, iMesh_POINT, iMeshP_ALL_PARTS, &num,
01643                                    &ierr );
01644         if( ierr )
01645             num_error.push_back( part_pair );
01646         else if( num != (int)exp_bdry.size() )
01647             num_failed.push_back( part_pair );
01648
01649         iBase_EntityHandle* bdry = 0;
01650         int junk = num = 0;
01651         iMeshP_getPartBdryEnts( imesh, prtn, local_handles[i], iBase_VERTEX, iMesh_POINT, iMeshP_ALL_PARTS, &bdry,
01652                                 &junk, &num, &ierr );
01653         if( ierr )
01654             list_error.push_back( part_pair );
01655         else
01656         {
01657             std::sort( bdry, bdry + num );
01658             if( num != (int)exp_bdry.size() || !std::equal( bdry, bdry + num, exp_bdry.begin() ) )
01659                 list_failed.push_back( part_pair );
01660             free( bdry );
01661         }
01662     }
01663     if( !num_error.empty() )
01664     {
01665         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01666                   << "  iMeshP_getNumPartBdryEnts return error for " << num_error.size() << " part pairs." << std::endl;
01667         ierr = iBase_FAILURE;
01668     }
01669     if( !list_error.empty() )
01670     {
01671         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01672                   << "  iMeshP_getPartBdryEnts return error for " << list_error.size() << " part pairs." << std::endl;
01673         ierr = iBase_FAILURE;
01674     }
01675     if( !num_failed.empty() )
01676     {
01677         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01678                   << "  iMeshP_getNumPartBdryEnts return incorrect results for " << num_failed.size() << " part pairs."
01679                   << std::endl;
01680         ierr = iBase_FAILURE;
01681     }
01682     if( !list_failed.empty() )
01683     {
01684         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01685                   << "  iMeshP_getPartBdryEnts return incorrect results for " << list_failed.size() << " part pairs."
01686                   << std::endl;
01687         ierr = iBase_FAILURE;
01688     }
01689
01690     return ierr;
01691 }
01692
01693 /**\brief Test querying of part boundary entities
01694  *
01695  * Test:
01696  * - iMeshP_initPartBdryEntIter
01697  * - iMeshP_initPartBdryEntArrIter
01698  */
01699 int test_part_boundary_iter( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
01700 {
01701     int ierr, rank, has_data;
01702     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
01703
01704     // get local part handles and part ids, and global part id list
01705     std::vector< iMeshP_PartHandle > local_handles;
01706     std::vector< iMeshP_Part > local_ids;
01707     std::vector< iMeshP_Part > all_parts = map.get_parts();
01708     ierr                                 = get_local_parts( imesh, prtn, local_handles, &local_ids );CHKERR;
01709
01710     std::vector< std::pair< iMeshP_Part, iMeshP_Part > > single_failed, single_error, single_step_error, array_failed,
01711         array_error, array_step_error;
01712     for( size_t i = 0; i < local_handles.size(); ++i )
01713     {
01714         iMeshP_PartHandle local_handle = local_handles[i];
01715         iMeshP_Part local_id           = local_ids[i];
01716         for( std::vector< iMeshP_Part >::iterator j = all_parts.begin(); j != all_parts.end(); ++j )
01717         {
01718             iMeshP_Part other_id = *j;
01719             if( other_id == local_id ) continue;
01720
01721             std::pair< iMeshP_Part, iMeshP_Part > part_pair;
01722             part_pair.first  = local_id;
01723             part_pair.second = other_id;
01724
01725             // get expected values
01726             std::vector< iBase_EntityHandle > shared_verts;
01727             ierr = interface_verts( imesh, prtn, local_handle, other_id, map, shared_verts );
01728             if( ierr != iBase_SUCCESS || 0 == shared_verts.size() ) continue;
01729             std::sort( shared_verts.begin(), shared_verts.end() );
01730
01731             // test single entity iterator
01732             iBase_EntityIterator siter;
01733             iMeshP_initPartBdryEntIter( imesh, prtn, local_handle, iBase_VERTEX, iMesh_POINT, other_id, &siter, &ierr );
01734             if( ierr != iBase_SUCCESS )
01735             {
01736                 single_error.push_back( part_pair );
01737             }
01738             else
01739             {
01740                 std::vector< iBase_EntityHandle > results;
01741                 for( ;; )
01742                 {
01743                     iBase_EntityHandle handle;
01744                     iMesh_getNextEntIter( imesh, siter, &handle, &has_data, &ierr );
01745                     if( ierr != iBase_SUCCESS )
01746                     {
01747                         single_step_error.push_back( part_pair );
01748                         break;
01749                     }
01750                     if( !has_data ) break;
01751                     results.push_back( handle );
01752                 }
01753
01754                 std::sort( results.begin(), results.end() );
01755                 if( results.size() != shared_verts.size() ||
01756                     !std::equal( results.begin(), results.end(), shared_verts.begin() ) )
01757                     single_failed.push_back( part_pair );
01758             }
01759             iMesh_endEntIter( imesh, siter, &ierr );
01760
01761             // test array iterator
01762             iBase_EntityArrIterator aiter;
01763             iMeshP_initPartBdryEntArrIter( imesh, prtn, local_handle, iBase_VERTEX, iMesh_POINT, shared_verts.size(),
01764                                            other_id, &aiter, &ierr );
01765             if( ierr != iBase_SUCCESS )
01766             {
01767                 array_error.push_back( part_pair );
01768                 iMesh_endEntArrIter( imesh, aiter, &ierr );
01769                 continue;
01770             }
01771             iBase_EntityHandle results[5], *ptr = results;
01772             int junk = 5, count;
01773             iMesh_getNextEntArrIter( imesh, aiter, &ptr, &junk, &count, &has_data, &ierr );
01774             if( ierr != iBase_SUCCESS || !has_data )
01775             {
01776                 array_step_error.push_back( part_pair );
01777                 iMesh_endEntArrIter( imesh, aiter, &ierr );
01778                 continue;
01779             }
01780             iMesh_endEntArrIter( imesh, aiter, &ierr );
01781             assert( count <= 5 );
01782             assert( ptr == results );
01783             std::sort( ptr, ptr + count );
01784             if( count != (int)shared_verts.size() || !std::equal( shared_verts.begin(), shared_verts.end(), results ) )
01785                 array_failed.push_back( part_pair );
01786         }
01787     }
01788
01789     if( !single_error.empty() )
01790     {
01791         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01792                   << "  iMeshP_initPartBdryEntIter return error for " << single_error.size() << " part pairs."
01793                   << std::endl;
01794         ierr = iBase_FAILURE;
01795     }
01796     if( !single_step_error.empty() )
01797     {
01798         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01799                   << "  iMesh_getNextEntIter return error for " << single_step_error.size() << " part pairs."
01800                   << std::endl;
01801         ierr = iBase_FAILURE;
01802     }
01803     if( !single_failed.empty() )
01804     {
01805         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01806                   << "  iMeshP_initPartBdryEntIter iterator iterated over invalid entities for " << single_failed.size()
01807                   << " part pairs." << std::endl;
01808         ierr = iBase_FAILURE;
01809     }
01810
01811     if( !array_error.empty() )
01812     {
01813         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01814                   << "  iMeshP_initPartBdryEntArrIter return error for " << array_error.size() << " part pairs."
01815                   << std::endl;
01816         ierr = iBase_FAILURE;
01817     }
01818     if( !array_step_error.empty() )
01819     {
01820         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01821                   << "  iMesh_getNextEntArrIter return error for " << array_step_error.size() << " part pairs."
01822                   << std::endl;
01823         ierr = iBase_FAILURE;
01824     }
01825     if( !array_failed.empty() )
01826     {
01827         std::cerr << "Processor " << rank << ": Error at " __FILE__ ":" << __LINE__ << std::endl
01828                   << "  iMeshP_initPartBdryEntArrIter iterator iterated over invalid entities for "
01829                   << array_failed.size() << " part pairs." << std::endl;
01830         ierr = iBase_FAILURE;
01831     }
01832
01833     return ierr;
01834 }
01835
01836 /**\brief Test adjacent entity query
01837  *
01838  * Test:
01839  * - iMeshP_getAdjEntities
01840  */
01841 int test_get_adjacencies( iMesh_Instance /* imesh */, iMeshP_PartitionHandle /* prtn */, const PartMap& )
01842 {
01843     return iBase_SUCCESS;
01844 }
01845
01846 /**\brief Test entity iterators
01847  *
01848  * Test:
01849  * - iMeshP_initEntIter
01850  * - iMeshP_initEntArrIter
01851  */
01852 int test_entity_iterator( iMesh_Instance /*imesh */, iMeshP_PartitionHandle /*prtn*/, const PartMap& )
01853 {
01854     return iBase_SUCCESS;
01855 }
01856
01857 /**\brief Test entity owner queries
01858  *
01859  * Test:
01860  * - iMeshP_getEntOwnerPart
01861  * - iMeshP_getEntOwnerPartArr
01862  * - iMeshP_isEntOwner
01863  * - iMeshP_isEntOwnerArr
01864  */
01865 int test_entity_owner( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& /* map */ )
01866 {
01867     int ierr, rank, size;
01868     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
01869     MPI_Comm_size( MPI_COMM_WORLD, &size );
01870
01871     // get local part handles and part ids
01872     std::vector< iMeshP_PartHandle > local_handles;
01873     std::vector< iMeshP_Part > local_ids;
01874     ierr = get_local_parts( imesh, prtn, local_handles, &local_ids );
01875     PCHECK;
01876
01877     // test iMeshP_getEntOwnerPart for quads in each part
01878     std::vector< iBase_EntityHandle > all_quads;
01879     std::vector< iMeshP_Part > quad_owners;
01880     int invalid_count = 0;
01881     for( size_t i = 0; i < local_handles.size(); ++i )
01882     {
01883         std::vector< iBase_EntityHandle > quads;
01884         ierr = get_entities( imesh, local_handles[0], iBase_FACE, iMesh_QUADRILATERAL, quads );
01885         if( ierr ) break;
01886
01887         for( size_t j = 0; j < quads.size(); ++j )
01888         {
01889             all_quads.push_back( quads[j] );
01890             quad_owners.push_back( local_ids[i] );
01891             iMeshP_Part owner;
01892             iMeshP_getEntOwnerPart( imesh, prtn, quads[j], &owner, &ierr );
01893             if( iBase_SUCCESS != ierr ) break;
01894
01895             if( owner != local_ids[i] ) ++invalid_count;
01896         }
01897         if( iBase_SUCCESS != ierr ) break;
01898     }
01899     PCHECK;
01900     ASSERT( 0 == invalid_count );
01901
01902     // test iMeshP_getEntOwnerPartArr for quads in each part
01903     invalid_count = 0;
01904     for( size_t i = 0; i < local_handles.size(); ++i )
01905     {
01906         std::vector< iBase_EntityHandle > quads;
01907         ierr = get_entities( imesh, local_handles[0], iBase_FACE, iMesh_QUADRILATERAL, quads );
01908         if( ierr ) break;
01909
01910         std::vector< iMeshP_Part > owners( quads.size() ), expected( quads.size(), local_ids[i] );
01911         int junk         = owners.size(), count;
01912         iMeshP_Part* ptr = &owners[0];
01913         iMeshP_getEntOwnerPartArr( imesh, prtn, &quads[0], quads.size(), &ptr, &junk, &count, &ierr );
01914         if( ierr ) break;
01915         assert( ptr == &owners[0] );
01916         assert( junk == (int)owners.size() );
01917         assert( count == (int)quads.size() );
01918         if( owners != expected ) ++invalid_count;
01919     }
01920     PCHECK;
01921     ASSERT( 0 == invalid_count );
01922
01923     // get all vertices
01924     iBase_EntityHandle* vtx_arr = 0;
01925     int junk1                   = 0, num_vtx;
01926     int *junk2 = 0, junk3 = 0, junk4;
01927     iMesh_getEntArrAdj( imesh, &all_quads[0], all_quads.size(), iBase_VERTEX, &vtx_arr, &junk1, &num_vtx, &junk2,
01928                         &junk3, &junk4, &ierr );
01929     PCHECK;
01930     free( junk2 );
01931     std::sort( vtx_arr, vtx_arr + num_vtx );
01932     num_vtx = std::unique( vtx_arr, vtx_arr + num_vtx ) - vtx_arr;
01933     std::vector< iBase_EntityHandle > all_verts( vtx_arr, vtx_arr + num_vtx );
01934     free( vtx_arr );
01935
01936     // check consistency between iMeshP_getEntOwnerPart and iMeshP_getEntOwnerPartArr
01937     // for all vertices
01938     std::vector< iMeshP_Part > vert_owners( all_verts.size() );
01939     junk1              = vert_owners.size();
01940     iMeshP_Part* junk5 = &vert_owners[0];
01941     iMeshP_getEntOwnerPartArr( imesh, prtn, &all_verts[0], all_verts.size(), &junk5, &junk1, &junk3, &ierr );
01942     PCHECK;
01943     assert( junk5 == &vert_owners[0] );
01944     assert( junk1 == (int)vert_owners.size() );
01945     assert( junk3 == (int)all_verts.size() );
01946
01947     invalid_count = 0;
01948     for( size_t i = 0; i < all_verts.size(); ++i )
01949     {
01950         iMeshP_Part owner;
01951         iMeshP_getEntOwnerPart( imesh, prtn, all_verts[i], &owner, &ierr );
01952         if( iBase_SUCCESS != ierr || owner != vert_owners[i] ) ++invalid_count;
01953     }
01954     ASSERT( 0 == invalid_count );
01955
01956     // get lists for all entities
01957     std::vector< iBase_EntityHandle > all_entities( all_verts );
01958     std::copy( all_quads.begin(), all_quads.end(), std::back_inserter( all_entities ) );
01959     std::vector< iMeshP_Part > all_owners( vert_owners );
01960     std::copy( quad_owners.begin(), quad_owners.end(), std::back_inserter( all_owners ) );
01961
01962     // check consistency of iMeshP_isEntOwner for all entities
01963     invalid_count = 0;
01964     ierr          = iBase_SUCCESS;
01965     for( size_t i = 0; i < local_handles.size(); ++i )
01966     {
01967         for( size_t j = 0; ierr == iBase_SUCCESS && j < all_entities.size(); ++j )
01968         {
01969             int is_owner;
01970             iMeshP_isEntOwner( imesh, prtn, local_handles[i], all_entities[j], &is_owner, &ierr );
01971             if( ierr != iBase_SUCCESS ) break;
01972             if( !is_owner == ( local_ids[i] == all_owners[j] ) ) ++invalid_count;
01973         }
01974     }
01975     PCHECK;
01976     ASSERT( 0 == invalid_count );
01977
01978     // check consistency of iMeshP_isEntOwnerArr for all entities
01979     for( size_t i = 0; i < local_handles.size(); ++i )
01980     {
01981         std::vector< int > is_owner_list( all_entities.size() );
01982         junk1      = is_owner_list.size();
01983         int* junk6 = &is_owner_list[0];
01984         iMeshP_isEntOwnerArr( imesh, prtn, local_handles[i], &all_entities[0], all_entities.size(), &junk6, &junk1,
01985                               &junk3, &ierr );
01986         if( iBase_SUCCESS != ierr ) break;
01987         assert( junk6 == &is_owner_list[0] );
01988         assert( junk1 == (int)is_owner_list.size() );
01989         assert( junk3 == (int)all_entities.size() );
01990         invalid_count = 0;
01991         for( size_t j = 0; j < all_entities.size(); ++j )
01992         {
01993             if( !( is_owner_list[j] ) == ( local_ids[0] == all_owners[j] ) ) ++invalid_count;
01994         }
01995     }
01996     PCHECK;
01997     ASSERT( 0 == invalid_count );
01998
01999     // check globally consistent owners for all vertices
02000
02001     // first communicate total number of vertex entries to be sent to root proc
02002     int local_count = all_verts.size(), global_count = 0;
02003     ierr = MPI_Reduce( &local_count, &global_count, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD );CHKERR;
02004
02005     // for each vertex, store { (x << 2) | y, owning part id }
02006     std::vector< int > vtxdata( 2 * all_verts.size() );
02007     std::vector< double > coords( 3 * all_verts.size() );
02008     ierr = get_coords( imesh, &all_verts[0], all_verts.size(), &coords[0] );CHKERR;
02009     for( size_t i = 0; i < all_verts.size(); ++i )
02010     {
02011         int x              = (int)round( coords[3 * i] );
02012         int y              = (int)round( coords[3 * i + 1] );
02013         vtxdata[2 * i]     = ( x << 3 ) | y;
02014         vtxdata[2 * i + 1] = vert_owners[i];
02015     }
02016
02017     // collect all data on root procesor
02018     std::vector< int > all_data( 2 * global_count );
02019     std::vector< int > displ( size ), counts( size );
02020     for( int i = 0; i < size; i++ )
02021     {
02022         counts[i] = vtxdata.size();
02023         displ[i]  = i * vtxdata.size();
02024     }
02025
02026     // we could have used a simple gather, because all sequences are the same
02027     ierr = MPI_Gatherv( &vtxdata[0], vtxdata.size(), MPI_INT, &all_data[0], &counts[0], &displ[0], MPI_INT, 0,
02028                         MPI_COMM_WORLD );CHKERR;
02029
02030     if( rank == 0 )
02031     {
02032         // map from vertex tag to indices into data
02033         std::multimap< int, int > data_map;
02034         for( int i = 0; i < global_count; ++i )
02035         {
02036             std::pair< int, int > p;
02037             p.first  = all_data[2 * i];
02038             p.second = i;
02039             data_map.insert( p );
02040         }
02041
02042         // check consistent data for each vtx
02043         std::multimap< int, int >::const_iterator a, b;
02044         for( a = data_map.begin(); a != data_map.end(); a = b )
02045         {
02046             for( b = a; b != data_map.end() && a->first == b->first; ++b )
02047             {
02048                 int idx1 = a->second;
02049                 int idx2 = b->second;
02050                 if( all_data[2 * idx1 + 1] == all_data[2 * idx2 + 1] ) continue;
02051
02052                 ierr = iBase_FAILURE;
02053
02054                 int proc1 = std::lower_bound( displ.begin(), displ.end(), 2 * idx1 ) - displ.begin();
02055                 if( displ[proc1] != 2 * idx1 ) ++proc1;
02056                 int proc2 = std::lower_bound( displ.begin(), displ.end(), 2 * idx2 ) - displ.begin();
02057                 if( displ[proc2] != 2 * idx2 ) ++proc2;
02058
02059                 std::cerr << "Error at " __FILE__ ":" << __LINE__ << " : " << std::endl
02060                           << "  For vertex at (" << ( a->first >> 2 ) << ", " << ( a->first & 3 ) << ") :" << std::endl
02061                           << "  Processor " << proc1 << " has " << all_data[2 * idx1 + 1] << " as the owning part"
02062                           << std::endl
02063                           << "  Processor " << proc2 << " has " << all_data[2 * idx2 + 1] << " as the owning part"
02064                           << std::endl;
02065             }
02066         }
02067     }
02068
02069     return ierr;
02070 }
02071
02072 static int get_part_boundary_verts( iMesh_Instance imesh,
02073                                     iMeshP_PartitionHandle prtn,
02074                                     const PartMap& map,
02075                                     iMeshP_PartHandle part,
02076                                     std::vector< iBase_EntityHandle >& boundary )
02077 {
02078     int ierr, logical_id;
02079     ierr = map.part_from_coords( imesh, part, logical_id );CHKERR;
02080
02081     int neighbors[5], num_neighbors;
02082     get_part_neighbors( logical_id, map.get_parts().size(), neighbors, num_neighbors );
02083
02084     for( int j = 0; j < num_neighbors; ++j )
02085     {
02086         std::vector< iBase_EntityHandle > iface;
02087         ierr = interface_verts( imesh, prtn, part, neighbors[j], map, iface );CHKERR;
02088         std::copy( iface.begin(), iface.end(), std::back_inserter( boundary ) );
02089     }
02090
02091     std::sort( boundary.begin(), boundary.end() );
02092     boundary.erase( std::unique( boundary.begin(), boundary.end() ), boundary.end() );
02093     return iBase_SUCCESS;
02094 }
02095
02096 /**\brief Test entity status
02097  *
02098  * Test:
02099  * - iMeshP_getEntStatus
02100  * - iMeshP_getEntStatusArr
02101  */
02102 int test_entity_status( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
02103 {
02104     int ierr, rank, size;
02105     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
02106     MPI_Comm_size( MPI_COMM_WORLD, &size );
02107
02108     // get local part handles
02109     std::vector< iMeshP_PartHandle > parts;
02110     ierr = get_local_parts( imesh, prtn, parts );
02111     PCHECK;
02112
02113     // for each part
02114     int num_quad_ent_incorrect = 0, num_quad_ent_error = 0;
02115     int num_quad_arr_incorrect = 0, num_quad_arr_error = 0;
02116     int num_vert_ent_incorrect = 0, num_vert_ent_error = 0;
02117     int num_vert_arr_incorrect = 0, num_vert_arr_error = 0;
02118     for( size_t i = 0; i < parts.size(); ++i )
02119     {
02120         const iMeshP_PartHandle part = parts[i];
02121
02122         // get quads and vertices
02123         std::vector< iBase_EntityHandle > quads, verts;
02124         ierr = get_part_quads_and_verts( imesh, part, quads, verts );
02125         if( ierr ) break;
02126
02127         // check quad status (no ghosting yet)
02128         for( size_t j = 0; j < quads.size(); ++j )
02129         {
02130             int status;
02131             iMeshP_getEntStatus( imesh, prtn, part, quads[j], &status, &ierr );
02132             if( ierr != iBase_SUCCESS )
02133             {
02134                 ++num_quad_ent_error;
02135                 ierr = iBase_SUCCESS;
02136                 continue;
02137             }
02138
02139             if( status != iMeshP_INTERNAL ) ++num_quad_ent_incorrect;
02140         }
02141
02142         // check quad status using iMeshP_getEntStatusArr
02143         std::vector< int > stat_list( quads.size() );
02144         int* junk1 = &stat_list[0];
02145         int junk2  = stat_list.size(), count;
02146         iMeshP_getEntStatusArr( imesh, prtn, part, &quads[0], quads.size(), &junk1, &junk2, &count, &ierr );
02147         if( ierr != iBase_SUCCESS )
02148         {
02149             ++num_quad_arr_error;
02150             ierr = iBase_SUCCESS;
02151             continue;
02152         }
02153         assert( junk1 == &stat_list[0] );
02154         assert( junk2 == (int)stat_list.size() );
02155         assert( count == (int)quads.size() );
02156         for( size_t j = 0; j < quads.size(); ++j )
02157             if( stat_list[j] != iMeshP_INTERNAL ) ++num_quad_arr_incorrect;
02158
02159         // figure out which vertices are on the boundary
02160         std::vector< iBase_EntityHandle > boundary;
02161         ierr = get_part_boundary_verts( imesh, prtn, map, part, boundary );
02162         if( ierr ) break;
02163         std::sort( boundary.begin(), boundary.end() );
02164
02165         // check vertex status (no ghosting yet)
02166         for( size_t j = 0; j < verts.size(); ++j )
02167         {
02168             int status;
02169             iMeshP_getEntStatus( imesh, prtn, part, verts[j], &status, &ierr );
02170             if( ierr != iBase_SUCCESS )
02171             {
02172                 ++num_vert_ent_error;
02173                 ierr = iBase_SUCCESS;
02174                 continue;
02175             }
02176             bool on_boundary = std::binary_search( boundary.begin(), boundary.end(), verts[j] );
02177             if( status != ( on_boundary ? iMeshP_BOUNDARY : iMeshP_INTERNAL ) ) ++num_vert_ent_incorrect;
02178         }
02179
02180         // check vert status using iMeshP_getEntStatusArr
02181         stat_list.resize( verts.size() );
02182         junk1 = &stat_list[0];
02183         junk2 = stat_list.size();
02184         iMeshP_getEntStatusArr( imesh, prtn, part, &verts[0], verts.size(), &junk1, &junk2, &count, &ierr );
02185         if( ierr != iBase_SUCCESS )
02186         {
02187             ++num_vert_arr_error;
02188             ierr = iBase_SUCCESS;
02189             continue;
02190         }
02191         assert( junk1 == &stat_list[0] );
02192         assert( junk2 == (int)stat_list.size() );
02193         assert( count == (int)verts.size() );
02194         for( size_t j = 0; j < verts.size(); ++j )
02195         {
02196             bool on_boundary = std::binary_search( boundary.begin(), boundary.end(), verts[j] );
02197             if( stat_list[j] != ( on_boundary ? iMeshP_BOUNDARY : iMeshP_INTERNAL ) ) ++num_vert_arr_incorrect;
02198         }
02199     }
02200     PCHECK;  // check if loop interrupted by any internal errors
02201
02202     ASSERT( 0 == num_quad_ent_error );
02203     ASSERT( 0 == num_quad_arr_error );
02204     ASSERT( 0 == num_vert_ent_error );
02205     ASSERT( 0 == num_vert_arr_error );
02206     ASSERT( 0 == num_quad_ent_incorrect );
02207     ASSERT( 0 == num_quad_arr_incorrect );
02208     ASSERT( 0 == num_vert_ent_incorrect );
02209     ASSERT( 0 == num_vert_arr_incorrect );
02210
02211     return iBase_SUCCESS;
02212 }
02213
02214 /**\brief Test information about entity copies for interface entities
02215  *
02216  * Test:
02217  * - iMeshP_getNumCopies
02218  * - iMeshP_getCopyParts
02219  */
02220 int test_entity_copy_parts( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
02221 {
02222     int ierr, rank, size;
02223     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
02224     MPI_Comm_size( MPI_COMM_WORLD, &size );
02225
02226     // get local part handles
02227     std::vector< iMeshP_PartHandle > parts;
02228     ierr = get_local_parts( imesh, prtn, parts );
02229     PCHECK;
02230     ASSERT( !parts.empty() );
02231
02232     // select a singe part to test
02233     const iMeshP_PartHandle part = parts[0];
02234     int logical_id;
02235     ierr = map.part_from_coords( imesh, part, logical_id );CHKERR;
02236     const iMeshP_Part part_id = map.part_id_from_local_id( logical_id );
02237
02238     // get vertices in part
02239     std::vector< iBase_EntityHandle > quads, verts;
02240     ierr = get_part_quads_and_verts( imesh, part, quads, verts );
02241     PCHECK;
02242
02243     // get neighbors
02244     int neighbors[5], num_neighbors;
02245     get_part_neighbors( logical_id, map.get_parts().size(), neighbors, num_neighbors );
02246
02247     // build map of sharing data for each vertex
02248     std::map< iBase_EntityHandle, std::vector< iMeshP_Part > > vert_sharing;
02249     for( int j = 0; j < num_neighbors; ++j )
02250     {
02251         std::vector< iBase_EntityHandle > iface;
02252         ierr = interface_verts( imesh, prtn, part, neighbors[j], map, iface );CHKERR;
02253         for( size_t k = 0; k < iface.size(); ++k )
02254             vert_sharing[iface[k]].push_back( map.part_id_from_local_id( neighbors[j] ) );
02255     }
02256
02257     // test getNumCopies for each vertex
02258     std::map< iBase_EntityHandle, std::vector< iMeshP_Part > >::iterator i;
02259     int num_failed = 0, num_incorrect = 0;
02260     for( i = vert_sharing.begin(); i != vert_sharing.end(); ++i )
02261     {
02262         int count;
02263         iBase_EntityHandle vtx = i->first;
02264         iMeshP_getNumCopies( imesh, prtn, vtx, &count, &ierr );
02265         if( ierr )
02266             ++num_failed;
02267         else if( (unsigned)count != i->second.size() + 1 )  // add one for the part we queried from
02268             ++num_incorrect;
02269     }
02270     ASSERT( 0 == num_failed );
02271     ASSERT( 0 == num_incorrect );
02272
02273     // get getCopyParts for each vertex
02274     num_failed = num_incorrect = 0;
02275     for( i = vert_sharing.begin(); i != vert_sharing.end(); ++i )
02276     {
02277         iMeshP_Part* list = 0;
02278         int junk          = 0, count;
02279         iMeshP_getCopyParts( imesh, prtn, i->first, &list, &junk, &count, &ierr );
02280         if( iBase_SUCCESS != ierr )
02281         {
02282             ++num_failed;
02283             continue;
02284         }
02285         if( (unsigned)count != i->second.size() + 1 )
02286         {  // add one for the part we queried from
02287             ++num_incorrect;
02288             free( list );
02289             continue;
02290         }
02291
02292         std::vector< iMeshP_Part > expected( i->second );
02293         expected.push_back( part_id );
02294         std::sort( list, list + count );
02295         std::sort( expected.begin(), expected.end() );
02296         bool eq = std::equal( list, list + count, expected.begin() );
02297         free( list );
02298         if( !eq ) ++num_incorrect;
02299     }
02300     ASSERT( 0 == num_failed );
02301     ASSERT( 0 == num_incorrect );
02302
02303     return iBase_SUCCESS;
02304 }
02305
02306 // store remote handle data for a vertex
02307 struct VtxCopyData
02308 {
02309     std::vector< iMeshP_Part > parts;
02310     std::vector< iBase_EntityHandle > handles;
02311 };
02312
02313 /**\brief Test information about entity copies for interface entities
02314  *
02315  * Test:
02316  * - iMeshP_getCopies
02317  * - iMeshP_getCopyOnPart
02318  * - iMeshP_getOwnerCopy
02319  */
02320 int test_entity_copies( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& /* map */ )
02321 {
02322     int ierr, rank, size;
02323     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
02324     MPI_Comm_size( MPI_COMM_WORLD, &size );
02325
02326     // generate a unique ID for each vertex using the coordinates.
02327     // see create_mesh(..): each vertex has integer coordinates (x,y,0)
02328     //                      with x in [0,inf] and y in [0,4]
02329     // then to an Allgatherv to exchange handles for each processor
02330
02331     // cast everything to iBase_EntityHandle so we can pack it all in one communication
02332     MPI_Datatype tmp_type;
02333     if( sizeof( iBase_EntityHandle ) == sizeof( unsigned ) )
02334         tmp_type = MPI_UNSIGNED;
02335     else if( sizeof( iBase_EntityHandle ) == sizeof( unsigned long ) )
02336         tmp_type = MPI_UNSIGNED_LONG;
02337     else if( sizeof( iBase_EntityHandle ) == sizeof( unsigned long long ) )
02338         tmp_type = MPI_UNSIGNED_LONG_LONG;
02339     else
02340         return iBase_FAILURE;
02341     const MPI_Datatype type = tmp_type;  // make it const
02342
02343     // get local part handles
02344     std::vector< iMeshP_PartHandle > parts;
02345     ierr = get_local_parts( imesh, prtn, parts );
02346     PCHECK;
02347     std::vector< iMeshP_Part > part_ids( parts.size() );
02348     iMeshP_Part* junk1 = &part_ids[0];
02349     int junk2          = part_ids.size(), junk3;
02350     iMeshP_getPartIdsFromPartHandlesArr( imesh, prtn, &parts[0], parts.size(), &junk1, &junk2, &junk3, &ierr );
02351     PCHECK;
02352     assert( junk1 == &part_ids[0] );
02353     assert( junk2 == (int)part_ids.size() );
02354     assert( junk3 == (int)parts.size() );
02355
02356     // build list of {vtx_id, part_id, handle} tuples to send
02357     // also build list of local vertex handles
02358     std::vector< iBase_EntityHandle > local_data, local_vertices;
02359     for( size_t i = 0; i < parts.size(); ++i )
02360     {
02361         // get vertices
02362         std::vector< iBase_EntityHandle > quads, verts;
02363         ierr = get_part_quads_and_verts( imesh, parts[i], quads, verts );
02364         if( ierr ) break;
02365
02366         // add all vertices to local_data
02367         for( size_t j = 0; j < verts.size(); ++j )
02368         {
02369             int tag = 0;
02370             ierr    = vertex_tag( imesh, verts[j], tag );
02371             if( ierr ) break;
02372             long tmp_h = tag;
02373             local_data.push_back( (iBase_EntityHandle)tmp_h );
02374             tmp_h = part_ids[i];
02375             local_data.push_back( (iBase_EntityHandle)tmp_h );
02376             local_data.push_back( verts[j] );
02377         }
02378         if( ierr ) break;
02379
02380         std::copy( verts.begin(), verts.end(), std::back_inserter( local_vertices ) );
02381     }
02382
02383     // build list of local vertices
02384     std::sort( local_vertices.begin(), local_vertices.end() );
02385     local_vertices.erase( std::unique( local_vertices.begin(), local_vertices.end() ), local_vertices.end() );
02386     std::vector< int > local_vtx_tags( local_vertices.size() );CHKERR;
02387     for( size_t i = 0; i < local_vertices.size(); ++i )
02388     {
02389         ierr = vertex_tag( imesh, local_vertices[i], local_vtx_tags[i] );
02390         if( ierr ) break;
02391     }
02392     CHKERR;
02393
02394     // communicate data
02395     std::vector< int > gcounts( size ), gdisp( size );
02396     int local_data_size = local_data.size();
02397     ierr                = MPI_Allgather( &local_data_size, 1, MPI_INT, &gcounts[0], 1, MPI_INT, MPI_COMM_WORLD );CHKERR;
02398     gdisp[0] = 0;
02399     for( int i = 1; i < size; ++i )
02400         gdisp[i] = gdisp[i - 1] + gcounts[i - 1];
02401     std::vector< iBase_EntityHandle > global_data( gdisp[size - 1] + gcounts[size - 1] );
02402     ierr = MPI_Allgatherv( &local_data[0], local_data_size, type, &global_data[0], &gcounts[0], &gdisp[0], type,
02403                            MPI_COMM_WORLD );CHKERR;
02404
02405     // arrange global data in a more useful way
02406     std::map< int, VtxCopyData > vtx_sharing;
02407     assert( global_data.size() % 3 == 0 );
02408     for( size_t i = 0; i < global_data.size(); i += 3 )
02409     {
02410         int tag                   = (int)(size_t)global_data[i];
02411         iMeshP_Part part          = (iMeshP_Part)(size_t)global_data[i + 1];
02412         iBase_EntityHandle handle = global_data[i + 2];
02413         vtx_sharing[tag].parts.push_back( part );
02414         vtx_sharing[tag].handles.push_back( handle );
02415     }
02416
02417     // test iMeshP_getCopies for each local vertex
02418     int num_error = 0, num_incorrect = 0, junk4;
02419     for( size_t i = 0; i < local_vertices.size(); ++i )
02420     {
02421         int num_copies = -1;
02422         // iMeshP_Part* part_ids = 0;
02423         iMeshP_Part* ptr_part_ids  = 0;  // Use ptr_part_ids to avoid shadowing std::vector<iMeshP_Part> part_ids
02424         iBase_EntityHandle* copies = 0;
02425         junk2 = junk3 = junk4 = 0;
02426         iMeshP_getCopies( imesh, prtn, local_vertices[i], &ptr_part_ids, &junk2, &num_copies, &copies, &junk3, &junk4,
02427                           &ierr );
02428         if( iBase_SUCCESS != ierr )
02429         {
02430             ++num_error;
02431             continue;
02432         }
02433         assert( junk4 == num_copies );
02434
02435         VtxCopyData& expected = vtx_sharing[local_vtx_tags[i]];
02436         if( num_copies != (int)expected.parts.size() )
02437             ++num_incorrect;
02438         else
02439             for( size_t j = 0; j < expected.parts.size(); ++j )
02440             {
02441                 int idx = std::find( ptr_part_ids, ptr_part_ids + num_copies, expected.parts[j] ) - ptr_part_ids;
02442                 if( idx == num_copies || copies[idx] != expected.handles[j] )
02443                 {
02444                     ++num_incorrect;
02445                     break;
02446                 }
02447             }
02448         free( ptr_part_ids );
02449         free( copies );
02450     }
02451     ASSERT( 0 == num_error );
02452     ASSERT( 0 == num_incorrect );
02453
02454     // test iMeshP_getCopyOnPart for each local vertex
02455     num_error = num_incorrect = 0;
02456     for( size_t i = 0; i < local_vertices.size(); ++i )
02457     {
02458         VtxCopyData& expected = vtx_sharing[local_vtx_tags[i]];
02459         for( size_t j = 0; j < expected.parts.size(); ++j )
02460         {
02461             iBase_EntityHandle copy;
02462             iMeshP_getCopyOnPart( imesh, prtn, local_vertices[i], expected.parts[j], &copy, &ierr );
02463             if( iBase_SUCCESS != ierr )
02464                 ++num_error;
02465             else if( expected.handles[j] != copy )
02466                 ++num_incorrect;
02467         }
02468     }
02469     ASSERT( 0 == num_error );
02470     ASSERT( 0 == num_incorrect );
02471
02472     // test iMeshP_getOwnerCopy for each local vertex
02473     num_error = num_incorrect = 0;
02474     for( size_t i = 0; i < local_vertices.size(); ++i )
02475     {
02476         VtxCopyData& expected = vtx_sharing[local_vtx_tags[i]];
02477         iMeshP_Part owner_id  = 0;
02478         iMeshP_getEntOwnerPart( imesh, prtn, local_vertices[i], &owner_id, &ierr );
02479         if( iBase_SUCCESS != ierr ) continue;  // not testing getEntOwnerPart here
02480
02481         size_t idx = std::find( expected.parts.begin(), expected.parts.end(), owner_id ) - expected.parts.begin();
02482         if( idx == expected.parts.size() ) continue;  // not testing getEntOwnerPart here
02483
02484         iMeshP_Part owner_id_2  = 0;
02485         iBase_EntityHandle copy = 0;
02486         iMeshP_getOwnerCopy( imesh, prtn, local_vertices[i], &owner_id_2, &copy, &ierr );
02487         if( iBase_SUCCESS != ierr )
02488             ++num_error;
02489         else if( owner_id_2 != owner_id && copy != expected.handles[idx] )
02490             ++num_incorrect;
02491     }
02492     ASSERT( 0 == num_error );
02493     ASSERT( 0 == num_incorrect );
02494
02495     return iBase_SUCCESS;
02496 }
02497
02498 int get_num_adj_quads( iMesh_Instance imesh, iBase_EntityHandle vtx, int& num )
02499 {
02500     iBase_EntityHandle* list = 0;
02501     int ierr, junk = 0;
02502     iMesh_getEntAdj( imesh, vtx, iBase_FACE, &list, &junk, &num, &ierr );
02503     if( iBase_SUCCESS == ierr ) free( list );
02504     return ierr;
02505 }
02506
02507 int get_adj( iMesh_Instance imesh, iBase_EntityHandle ent, int type, std::vector< iBase_EntityHandle >& adj )
02508 {
02509     iBase_EntityHandle* list = 0;
02510     int ierr, num, junk = 0;
02511     iMesh_getEntAdj( imesh, ent, type, &list, &junk, &num, &ierr );
02512     if( iBase_SUCCESS == ierr )
02513     {
02514         std::copy( list, list + num, std::back_inserter( adj ) );
02515         free( list );
02516     }
02517     return ierr;
02518 }
02519
02520 // assume regular quad mesh
02521 int get_boundary_vertices( iMesh_Instance imesh, std::vector< iBase_EntityHandle >& bdry )
02522 {
02523     int ierr, n;
02524     iBase_EntitySetHandle root;
02525     iMesh_getRootSet( imesh, &root, &ierr );CHKERR;
02526     std::vector< iBase_EntityHandle > all_verts;
02527     ierr = get_entities( imesh, root, iBase_VERTEX, iMesh_POINT, all_verts );CHKERR;
02528     bdry.clear();
02529     for( size_t i = 0; i < all_verts.size(); ++i )
02530     {
02531         ierr = get_num_adj_quads( imesh, all_verts[i], n );CHKERR;
02532         if( n != 4 ) bdry.push_back( all_verts[i] );
02533     }
02534     return iBase_SUCCESS;
02535 }
02536
02537 int check_one_layer( iMesh_Instance imesh,
02538                      iBase_EntityHandle vtx,
02539                      const std::vector< iBase_EntityHandle >& sorted_vertices )
02540 {
02541     int ierr;
02542     if( std::binary_search( sorted_vertices.begin(), sorted_vertices.end(), vtx ) ) return iBase_SUCCESS;
02543     std::vector< iBase_EntityHandle > quads, verts;
02544     ierr = get_adj( imesh, vtx, iBase_FACE, quads );CHKERR;
02545     for( size_t i = 0; i < quads.size(); ++i )
02546     {
02547         verts.clear();
02548         ierr = get_adj( imesh, quads[i], iBase_VERTEX, verts );CHKERR;
02549         for( size_t j = 0; j < verts.size(); ++j )
02550         {
02551             if( std::binary_search( sorted_vertices.begin(), sorted_vertices.end(), verts[j] ) ) return iBase_SUCCESS;
02552         }
02553     }
02554
02555     return iBase_FAILURE;
02556 }
02557
02558 // get number of adjacent quads to each vertex, both on the local
02559 // processor and in the entire mesh
02560 int get_num_adj_all( iMesh_Instance imesh,
02561                      const std::vector< iBase_EntityHandle >& verts,
02562                      std::vector< int >& num_local_adj,
02563                      std::vector< int >& num_all_adj )
02564 {
02565     int ierr, size;
02566     MPI_Comm_size( MPI_COMM_WORLD, &size );
02567
02568     std::vector< int > vtx_tags( verts.size() );
02569     num_local_adj.resize( verts.size() );
02570     for( size_t i = 0; i < verts.size(); ++i )
02571     {
02572         ierr = get_num_adj_quads( imesh, verts[i], num_local_adj[i] );CHKERR;
02573         ierr = vertex_tag( imesh, verts[i], vtx_tags[i] );CHKERR;
02574     }
02575
02576     std::vector< int > counts( size ), displ( size );
02577     int num_vtx = verts.size();
02578     ierr        = MPI_Allgather( &num_vtx, 1, MPI_INT, &counts[0], 1, MPI_INT, MPI_COMM_WORLD );CHKERR;
02579     displ[0] = 0;
02580     for( int i = 1; i < size; ++i )
02581         displ[i] = displ[i - 1] + counts[i - 1];
02582     int total = displ[size - 1] + counts[size - 1];
02583     std::vector< int > all_tags( total ), all_adj_counts( total );
02584     ierr = MPI_Allgatherv( &vtx_tags[0], vtx_tags.size(), MPI_INT, &all_tags[0], &counts[0], &displ[0], MPI_INT,
02585                            MPI_COMM_WORLD );CHKERR;
02586     ierr = MPI_Allgatherv( &num_local_adj[0], num_local_adj.size(), MPI_INT, &all_adj_counts[0], &counts[0], &displ[0],
02587                            MPI_INT, MPI_COMM_WORLD );CHKERR;
02588
02589     num_all_adj.clear();
02590     num_all_adj.resize( total, 0 );
02591     for( int i = 0; i < total; ++i )
02592     {
02593         std::vector< int >::iterator it = std::find( vtx_tags.begin(), vtx_tags.end(), all_tags[i] );
02594         if( it == vtx_tags.end() ) continue;
02595         int idx = it - vtx_tags.begin();
02596         num_all_adj[idx] += all_adj_counts[i];
02597     }
02598
02599     return iBase_SUCCESS;
02600 }
02601
02602 /**\brief Test creation of ghost entities
02603  *
02604  * Test:
02605  * - iMeshP_createGhostEntsAll
02606  */
02607 int test_create_ghost_ents( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& /* map */ )
02608 {
02609     int ierr;
02610
02611     // get boundary vertices
02612     std::vector< iBase_EntityHandle > bdry;
02613     ierr = get_boundary_vertices( imesh, bdry );
02614     PCHECK;
02615     // get counts of adjacent entities
02616     std::vector< int > num_local_adj, num_global_adj;
02617     ierr = get_num_adj_all( imesh, bdry, num_local_adj, num_global_adj );
02618     PCHECK;
02619     // create one layer of ghost entities
02620     iMeshP_createGhostEntsAll( imesh, prtn, iBase_FACE, iBase_VERTEX, 1, 0, &ierr );
02621     PCHECK;
02622     // check that each vertex has the correct number of adjacent entities
02623     int num_incorrect = 0;
02624     for( size_t i = 0; i < bdry.size(); ++i )
02625     {
02626         int n;
02627         ierr = get_num_adj_quads( imesh, bdry[i], n );
02628         if( iBase_SUCCESS != ierr || num_global_adj[i] != n ) ++num_incorrect;
02629     }
02630     ASSERT( 0 == num_incorrect );
02631     // get new the new boundary
02632     std::vector< iBase_EntityHandle > new_bdry;
02633     ierr = get_boundary_vertices( imesh, new_bdry );
02634     PCHECK;
02635     // check that each vertex on the new boundary is separated by
02636     // at most one layer from the old boundary
02637     std::sort( bdry.begin(), bdry.end() );
02638     num_incorrect = 0;
02639     for( size_t i = 0; i < new_bdry.size(); ++i )
02640     {
02641         ierr = check_one_layer( imesh, new_bdry[i], bdry );
02642         if( ierr ) ++num_incorrect;
02643     }
02644     ASSERT( 0 == num_incorrect );
02645     // make another layer of ghost entiites
02646     bdry.swap( new_bdry );
02647     new_bdry.clear();
02648     ierr = get_num_adj_all( imesh, bdry, num_local_adj, num_global_adj );
02649     PCHECK;
02650     iMeshP_createGhostEntsAll( imesh, prtn, iBase_FACE, iBase_VERTEX, 2, 0, &ierr );
02651     PCHECK;
02652     // check that each vertex has the correct number of adjacent entities
02653     num_incorrect = 0;
02654     for( size_t i = 0; i < bdry.size(); ++i )
02655     {
02656         int n;
02657         ierr = get_num_adj_quads( imesh, bdry[i], n );
02658         if( iBase_SUCCESS != ierr || num_global_adj[i] != n ) ++num_incorrect;
02659     }
02660     // check that each vertex on the new boundary is separated by
02661     // at most one layer from the old boundary
02662     std::sort( bdry.begin(), bdry.end() );
02663     num_incorrect = 0;
02664     for( size_t i = 0; i < new_bdry.size(); ++i )
02665     {
02666         ierr = check_one_layer( imesh, new_bdry[i], bdry );
02667         if( ierr ) ++num_incorrect;
02668     }
02669     ASSERT( 0 == num_incorrect );
02670
02671     return iBase_SUCCESS;
02672 }
02673
02674 /**\brief Test exchange entities
02675  *
02676  * Test:
02677  * - iMeshP_exchEntArrToPartsAll
02678  */
02679 int test_exchange_ents( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map )
02680 {
02681     int ierr, rank, size;
02682     int num_err = 0;
02683     iMeshP_RequestHandle request;
02684     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
02685     MPI_Comm_size( MPI_COMM_WORLD, &size );
02686
02687     std::vector< iBase_EntityHandle > all_elems;
02688     std::vector< iMeshP_Part > all_ids;
02689     std::vector< iBase_EntityHandle > quads;
02690
02691     // get local part handles and part ids
02692     std::vector< iMeshP_PartHandle > local_handles;
02693     std::vector< iMeshP_Part > local_ids;
02694     ierr = get_local_parts( imesh, prtn, local_handles, &local_ids );
02695     PCHECK;
02696
02697     // get loacal quads before exchange
02698     quads.clear();
02699     ierr = get_entities( imesh, local_handles[0], iBase_FACE, iMesh_QUADRILATERAL, quads );CHKERR;
02700     int n_quads = quads.size();
02701
02702     // send all elements in local processor to all other processors
02703     for( size_t i = 0; i < map.get_parts().size(); ++i )
02704     {
02705         if( map.get_parts()[i] == (unsigned int)rank ) continue;  // skip own rank
02706
02707         for( int j = 0; j < n_quads; j++ )
02708         {
02709             all_elems.push_back( quads[j] );
02710             all_ids.push_back( map.get_parts()[i] );
02711         }
02712     }
02713
02714     // exchange entities
02715     iMeshP_exchEntArrToPartsAll( imesh, prtn, &all_elems[0], all_elems.size(), &all_ids[0], 0, 0, &request, &ierr );
02716     if( iBase_SUCCESS != ierr ) ++num_err;
02717
02718     // get local quads after exchange
02719     quads.clear();
02720     ierr = get_entities( imesh, local_handles[0], iBase_FACE, iMesh_QUADRILATERAL, quads );CHKERR;
02721
02722     // # of elements should be # of quads * # of processors
02723     ASSERT( quads.size() == (unsigned int)n_quads * size );
02724
02725     ASSERT( 0 == num_err );
02726
02727     return iBase_SUCCESS;
02728 }
02729
02730 /**\brief Test commuinication of tag data
02731  *
02732  * Test:
02733  * - iMeshP_pushTags
02734  * - iMeshP_pushTagsEnt
02735  */
02736 int test_push_tag_data_common( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, int num_ghost_layers )
02737 {
02738     const char* src_name = "test_src";
02739     const char* dst_name = "test_dst";
02740     int ierr, rank;
02741     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
02742
02743     if( num_ghost_layers )
02744     {
02745         iMeshP_createGhostEntsAll( imesh, prtn, iBase_FACE, iBase_VERTEX, num_ghost_layers, 0, &ierr );
02746         PCHECK;
02747     }
02748
02749     iBase_TagHandle src_tag, dst_tag;
02750     iMesh_createTag( imesh, src_name, 1, iBase_INTEGER, &src_tag, &ierr, strlen( src_name ) );CHKERR;
02751     iMesh_createTag( imesh, dst_name, 1, iBase_INTEGER, &dst_tag, &ierr, strlen( dst_name ) );CHKERR;
02752
02753     iBase_EntitySetHandle root;
02754     iMesh_getRootSet( imesh, &root, &ierr );CHKERR;
02755
02756     std::vector< iBase_EntityHandle > verts;
02757     ierr = get_entities( imesh, root, iBase_VERTEX, iMesh_POINT, verts );CHKERR;
02758
02759     // test iMeshP_pushTags
02760     // each processor writes its rank on all vertices
02761     // after push, each vertex should be tagged with the rank of its owner
02762
02763     std::vector< int > tag_vals( verts.size(), rank );
02764     iMesh_setIntArrData( imesh, &verts[0], verts.size(), src_tag, &tag_vals[0], tag_vals.size(), &ierr );CHKERR;
02765
02766     iMeshP_pushTags( imesh, prtn, src_tag, dst_tag, iBase_VERTEX, iMesh_POINT, &ierr );
02767     PCHECK;
02768
02769     tag_vals.clear();
02770     tag_vals.resize( verts.size(), -1 );
02771     iBase_TagHandle id_tag;
02772     iMesh_getTagHandle( imesh, "GLOBAL_ID", &id_tag, &ierr, strlen( "GLOBAL_ID" ) );
02773     std::vector< int > ids( verts.size() );
02774     int *junk1 = &ids[0], junk2 = ids.size(), junk3;
02775     iMesh_getIntArrData( imesh, &verts[0], verts.size(), id_tag, &junk1, &junk2, &junk3, &ierr );
02776     PCHECK;
02777     int errcount = 0;
02778     for( size_t i = 0; i < verts.size(); ++i )
02779     {
02780         iMesh_getIntData( imesh, verts[i], dst_tag, &tag_vals[i], &ierr );
02781         if( ierr != iBase_SUCCESS )
02782         {
02783             std::cerr << "Rank " << rank << " : getIntData failed for vertex " << ids[i] << std::endl;
02784             std::cerr.flush();
02785             ++errcount;
02786         }
02787     }
02788     ASSERT( 0 == errcount );
02789
02790     //  int *junk1 = &tag_vals[0], junk2 = tag_vals.size(), junk3;
02791     //  iMesh_getIntArrData( imesh, &verts[0], verts.size(), dst_tag, &junk1, &junk2, &junk3, &ierr
02792     //  ); PCHECK; assert( junk1 == &tag_vals[0] ); assert( junk2 == (int)tag_vals.size() ); assert(
02793     //  junk3 == (int)verts.size() );
02794
02795     std::vector< int > expected( verts.size() );
02796     std::vector< iMeshP_Part > parts( verts.size() );
02797     iMeshP_Part* junk4 = &parts[0];
02798     junk2              = parts.size();
02799     iMeshP_getEntOwnerPartArr( imesh, prtn, &verts[0], verts.size(), &junk4, &junk2, &junk3, &ierr );
02800     PCHECK;
02801     assert( junk4 == &parts[0] );
02802     assert( junk2 == (int)parts.size() );
02803     assert( junk3 == (int)verts.size() );
02804     junk1 = &expected[0];
02805     junk2 = expected.size();
02806     iMeshP_getRankOfPartArr( imesh, prtn, &parts[0], parts.size(), &junk1, &junk2, &junk3, &ierr );
02807     PCHECK;
02808     assert( junk1 == &expected[0] );
02809     assert( junk2 == (int)expected.size() );
02810     assert( junk3 == (int)parts.size() );
02811
02812     ASSERT( tag_vals == expected );
02813
02814     // test iMeshP_pushTagsEnt
02815     // write -1 on all vertices
02816     // For each vertex owned by this processor and shared with more than
02817     // two others, write the rank of the owning processor.
02818
02819     tag_vals.clear();
02820     tag_vals.resize( verts.size(), -1 );
02821     iMesh_setIntArrData( imesh, &verts[0], verts.size(), src_tag, &tag_vals[0], tag_vals.size(), &ierr );
02822     PCHECK;
02823     tag_vals.resize( verts.size(), -1 );
02824     iMesh_setIntArrData( imesh, &verts[0], verts.size(), dst_tag, &tag_vals[0], tag_vals.size(), &ierr );
02825     PCHECK;
02826
02827     std::vector< iBase_EntityHandle > some;
02828     for( size_t i = 0; i < verts.size(); ++i )
02829     {
02830         int num;
02831         iMeshP_getNumCopies( imesh, prtn, verts[i], &num, &ierr );
02832         if( iBase_SUCCESS != ierr ) break;
02833         if( num > 2 )
02834             some.push_back( verts[i] );
02835         else
02836             expected[i] = -1;
02837     }
02838
02839     tag_vals.clear();
02840     tag_vals.resize( some.size(), rank );
02841     iMesh_setIntArrData( imesh, &some[0], some.size(), src_tag, &tag_vals[0], tag_vals.size(), &ierr );
02842     PCHECK;
02843
02844     iMeshP_pushTagsEnt( imesh, prtn, src_tag, dst_tag, &some[0], some.size(), &ierr );
02845     PCHECK;
02846
02847     tag_vals.clear();
02848     tag_vals.resize( verts.size(), -1 );
02849     junk1 = &tag_vals[0];
02850     junk2 = tag_vals.size();
02851     iMesh_getIntArrData( imesh, &verts[0], verts.size(), dst_tag, &junk1, &junk2, &junk3, &ierr );CHKERR;
02852     assert( junk1 == &tag_vals[0] );
02853     assert( junk2 == (int)tag_vals.size() );
02854     assert( junk3 == (int)verts.size() );
02855
02856     ASSERT( tag_vals == expected );
02857     return iBase_SUCCESS;
02858 }
02859
02860 /**\brief Test commuinication of tag data
02861  *
02862  * Test:
02863  * - iMeshP_pushTags
02864  * - iMeshP_pushTagsEnt
02865  */
02866 int test_push_tag_data_iface( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& )
02867 {
02868     return test_push_tag_data_common( imesh, prtn, 0 );
02869 }
02870
02871 /**\brief Test commuinication of tag data
02872  *
02873  * Test:
02874  * - iMeshP_pushTags
02875  * - iMeshP_pushTagsEnt
02876  */
02877 int test_push_tag_data_ghost( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& )
02878 {
02879     return test_push_tag_data_common( imesh, prtn, 1 );
02880 }
02881
02882 /**************************************************************************
02883                           PartMap class
02884  **************************************************************************/
02885
02886 int PartMap::build_map( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, int num_expected_parts )
02887 {
02888     int ierr, rank, size;
02889     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
02890     MPI_Comm_size( MPI_COMM_WORLD, &size );
02891
02892     // get local parts
02893     std::vector< iMeshP_PartHandle > local_parts;
02894     std::vector< iMeshP_Part > imesh_ids;
02895     ierr = get_local_parts( imesh, prtn, local_parts, &imesh_ids );CHKERR;
02896
02897     // get logical ids for local parts
02898     std::vector< int > local_ids( local_parts.size() );
02899     for( size_t i = 0; i < local_parts.size(); ++i )
02900     {
02901         ierr = part_from_coords( imesh, local_parts[i], local_ids[i] );CHKERR;
02902     }
02903
02904     // get total number of parts
02905     int num_global = 0, num_local = local_parts.size();
02906     ierr = MPI_Allreduce( &num_local, &num_global, 1, MPI_INT, MPI_SUM, MPI_COMM_WORLD );CHKERR;
02907     if( num_global != num_expected_parts )
02908     {
02909         std::cerr << "Invalid/unexpected global part count at " __FILE__ ":" << __LINE__ << " (proc " << rank
02910                   << "): " << std::endl
02911                   << "  Expected: " << num_expected_parts << std::endl
02912                   << "  Actual:   " << num_global << std::endl;
02913         return 1;
02914     }
02915
02916     // get counts and displacements for Allgatherv calls
02917     std::vector< int > dspls( size ), counts( size );
02918     ierr = MPI_Allgather( &num_local, 1, MPI_INT, &counts[0], 1, MPI_INT, MPI_COMM_WORLD );CHKERR;
02919     dspls[0] = 0;
02920     for( int i = 1; i < size; ++i )
02921         dspls[i] = dspls[i - 1] + counts[i - 1];
02922
02923     // gather iMeshP_Part list from each processor
02924     std::vector< unsigned > global_part_ids( num_expected_parts );
02925     assert( sizeof( iMeshP_Part ) == sizeof( int ) );
02926     ierr = MPI_Allgatherv( &imesh_ids[0], num_local, MPI_UNSIGNED, &global_part_ids[0], &counts[0], &dspls[0],
02927                            MPI_UNSIGNED, MPI_COMM_WORLD );CHKERR;
02928
02929     // gather local ids from each processor
02930     std::vector< int > global_id_list( num_expected_parts );
02931     ierr = MPI_Allgatherv( &local_ids[0], num_local, MPI_INT, &global_id_list[0], &counts[0], &dspls[0], MPI_INT,
02932                            MPI_COMM_WORLD );CHKERR;
02933
02934     // build owner list
02935     std::vector< int > global_owners( num_expected_parts );
02936     for( int i = 0; i < size; ++i )
02937         for( int j = 0; j < counts[i]; ++j )
02938             global_owners[dspls[i] + j] = i;
02939
02940     // populate member lists
02941     sortedPartList = global_part_ids;
02942     std::sort( sortedPartList.begin(), sortedPartList.end() );
02943     partLocalIds.resize( num_expected_parts );
02944     partRanks.resize( num_expected_parts );
02945     for( int i = 0; i < num_expected_parts; ++i )
02946     {
02947         int idx = std::lower_bound( sortedPartList.begin(), sortedPartList.end(), global_part_ids[i] ) -
02948                   sortedPartList.begin();
02949         partLocalIds[idx] = global_id_list[i];
02950         partRanks[idx]    = global_owners[i];
02951     }
02952
02953     // do some consistency checking
02954     if( std::unique( sortedPartList.begin(), sortedPartList.end() ) != sortedPartList.end() )
02955     {
02956         if( rank == 0 )
02957         {
02958             std::cerr << "ERROR: Duplicate iMeshP_Part values detected at " __FILE__ ":" << __LINE__ << std::endl;
02959         }
02960         return 1;
02961     }
02962
02963     // build revesre local id map and check for duplicates
02964     localIdReverseMap.clear();
02965     localIdReverseMap.resize( num_expected_parts, -1 );
02966     for( int i = 0; i < num_expected_parts; ++i )
02967     {
02968         int idx = partLocalIds[i];
02969         if( localIdReverseMap[idx] != -1 )
02970         {
02971             if( rank == 0 )
02972             {
02973                 std::cerr << "ERROR: Part mesh has been duplicated in multiple parts." << std::endl
02974                           << "  Detected at " __FILE__ ":" << __LINE__ << std::endl
02975                           << "  See PartMap::part_from_coords" << std::endl;
02976             }
02977             return 1;
02978         }
02979         if( idx >= num_expected_parts )
02980         {
02981             if( rank == 0 )
02982             {
02983                 std::cerr << "ERROR: Part mesh invalid/incorrect mesh." << std::endl
02984                           << "  Detected at " __FILE__ ":" << __LINE__ << std::endl
02985                           << "  See PartMap::part_from_coords" << std::endl;
02986             }
02987             return 1;
02988         }
02989
02990         localIdReverseMap[idx] = i;
02991     }
02992
02993     return 0;
02994 }
02995
02996 void PartMap::part_id_from_rank( int rank, std::vector< iMeshP_Part >& parts ) const
02997 {
02998     for( size_t i = 0; i < sortedPartList.size(); ++i )
02999         if( partRanks[i] == rank ) parts.push_back( sortedPartList[i] );
03000 }
03001
03002 void PartMap::local_id_from_rank( int rank, std::vector< int >& ids ) const
03003 {
03004     for( size_t i = 0; i < sortedPartList.size(); ++i )
03005         if( partRanks[i] == rank ) ids.push_back( partLocalIds[i] );
03006 }
03007
03008 int PartMap::part_from_coords( iMesh_Instance imesh, iMeshP_PartHandle part, int& id )
03009 {
03010     int ierr, rank;
03011     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
03012
03013     // get elements
03014     const int num_elem = 4;
03015     iBase_EntityHandle array[num_elem];
03016     iBase_EntityHandle* ptr = array;
03017     int junk1 = num_elem, n = -1;
03018     iMesh_getEntities( imesh, part, iBase_FACE, iMesh_QUADRILATERAL, &ptr, &junk1, &n, &ierr );CHKERR;
03019     assert( ptr == array );
03020     assert( junk1 == num_elem );
03021     if( n != num_elem )
03022     {
03023         std::cerr << "Internal error at " __FILE__ ":" << __LINE__ << " (proc " << rank
03024                   << "): Expected all parts to have " << num_elem << " elements.  Found one with " << n << std::endl;
03025         return 1;
03026     }
03027
03028     // get vertices
03029     iBase_EntityHandle adj_array[4 * num_elem];
03030     int junk2, junk3, offset_array[5];
03031     ptr       = adj_array;
03032     junk1     = sizeof( adj_array ) / sizeof( adj_array[0] );
03033     junk2     = sizeof( offset_array ) / sizeof( offset_array[0] );
03034     int* ptr2 = offset_array;
03035     iMesh_getEntArrAdj( imesh, array, num_elem, iBase_VERTEX, &ptr, &junk1, &n, &ptr2, &junk2, &junk3, &ierr );CHKERR;
03036     assert( ptr == adj_array );
03037     assert( ptr2 == offset_array );
03038     assert( junk1 == sizeof( adj_array ) / sizeof( adj_array[0] ) );
03039     assert( junk2 == sizeof( offset_array ) / sizeof( offset_array[0] ) );
03040     assert( n == 4 * num_elem );
03041     assert( offset_array[0] == 0 );
03042     for( int i = 1; i < junk3; ++i )
03043         assert( offset_array[i] - offset_array[i - 1] == 4 );
03044
03045     // find center vertex
03046     iBase_EntityHandle vtx;
03047     bool all_match;
03048     for( int i = 0; i < 4; ++i )
03049     {
03050         vtx       = adj_array[i];
03051         all_match = true;
03052         for( int j = 1; j < 4; ++j )
03053         {
03054             iBase_EntityHandle* mvtx = adj_array + 4 * j;
03055             int k;
03056             for( k = 0; k < 4; ++k )
03057                 if( mvtx[k] == vtx ) break;
03058             if( k == 4 ) all_match = false;
03059         }
03060         if( all_match ) break;
03061     }
03062     assert( all_match );
03063
03064     // get center vertex coordinates
03065     double x, y, z;
03066     iMesh_getVtxCoord( imesh, vtx, &x, &y, &z, &ierr );CHKERR;
03067     assert( 0.0 == z );
03068     const int xi = ( (int)round( x ) - 1 ) / 2;
03069     const int yi = ( (int)round( y ) - 1 ) / 2;
03070     assert( xi >= 0 );
03071     assert( yi >= 0 );
03072     assert( fabs( x - 2 * xi - 1 ) < 1e-12 );
03073     assert( fabs( y - 2 * yi - 1 ) < 1e-12 );
03074
03075     id = 2 * xi + yi;
03076     return 0;
03077 }
